| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript ADFService Class of ADF Module Application Programming Interface (API).
The following section provides an alphabetical listing of the methods in the OpenScript ADFService API.
The following table lists the ADFService API methods in alphabetical order.
Table 16-1 List of ADFService Methods
| Method | Description |
Identifies an ADFButton by its recorded ID and path. |
Identifies an ADFCalendar by its recorded ID and path. |
Identifies an ADFCarousel by its recorded ID and path. |
Identifies an ADFDVTChart by its recorded ID and path. |
Identifies an ADFCodeEditor by its recorded ID and path. |
Identifies an ADFCommandButton by its recorded ID and path. |
Identifies an ADFCommandImageLink by its recorded ID and path. |
Identifies an ADFCommandLink by its recorded ID and path. |
Identifies an ADFCommandMenuItem by its recorded ID and path. |
Identifies an ADFCommandNavigationItem by its path. |
Identifies an ADFCommandToolbarButton by its recorded ID and path. |
Identifies an ADFContextInfo by its recorded ID and path. |
Identifies an ADFDVTDiagram by its recorded ID and path. |
Identifies an ADFDialog by its recorded ID and path. |
Identifies an ADFDVTGauge by its path. |
Identifies an ADFGoButton by its path. |
Identifies an ADFGoImageLink by its path. |
Identifies an ADFGoLink by its path. |
Identifies an ADFGoMenuItem by its recorded ID and path. |
Identifies an ADFDVTGraph by its recorded ID and path. |
Identifies an ADFDVTHierarchyViewer by its recorded ID and path. |
Identifies an ADFImage by its recorded ID and path. |
Identifies an ADFInputColor by its recorded ID and path. |
Identifies an ADFInputComboboxListOfValues by its recorded ID and path. |
Identifies an ADFInputDate by its recorded ID and path. |
Identifies an ADFInputFile by its recorded ID and path. |
Identifies an ADFInputListOfValues by its recorded ID and path. |
Identifies an ADFInputNumberSlider by its recorded ID and path. |
Identifies an ADFInputNumberSpinbox by its recorded ID and path. |
Identifies an ADFInputRangeSlider by its recorded ID and path. |
Identifies an ADFInputText by its recorded ID and path. |
Identifies an ADFLink by its recorded ID and path. |
Identifies an ADFListItem by its recorded ID and path. |
Identifies an ADFListView by its recorded ID and path. |
Identifies an ADFMenu by its recorded ID and path. |
Identifies an ADFMessage by its recorded ID and path. |
Identifies an ADFMessages by its recorded ID and path. |
Identifies an ADFNavigationPane by its recorded ID and path. |
Identifies an ADFNoteWindow by its recorded ID and path. |
Identifies an ADFOutputFormatted by its recorded ID and path. |
Identifies an ADFOutputLabel by its recorded ID and path. |
Identifies an ADFOutputText by its recorded ID and path. |
Identifies an ADFPage by its recorded ID and path. |
Identifies an ADFPanelAccordion by its recorded ID and path. |
Identifies an ADFPanelBox by its recorded ID and path. |
Identifies an ADFPanelDrawer by its recorded ID and path. |
Identifies an ADFPanelHeader by its recorded ID and path. |
Identifies an ADFPanelLabelAndMessage by its recorded ID and path. |
Identifies an ADFPanelList by its recorded ID and path. |
Identifies an ADFPanelSplitter by its recorded ID and path. |
Identifies an ADFPanelSpringboard by its recorded ID and path. |
Identifies an ADFPanelTabbed by its recorded ID and path. |
Identifies an ADFPanelWindow by its recorded ID and path. |
Identifies an ADFDVTPivotTable by its path. |
Identifies an ADFProgressIndicator by its recorded ID and path. |
Identifies an ADFQuery by its recorded ID and path. |
Identifies an ADFQuickQuery by its recorded ID and path. |
Identifies an ADFRegion by its path. |
Identifies an ADFResetButton by its recorded ID and path. |
Identifies an ADFRichTextEditor by its recorded ID and path. |
Identifies an ADFSelectBooleanCheckbox by its recorded ID and path. |
Identifies an ADFSelectBooleanRadio by its recorded ID and path. |
Identifies an ADFSelectManyCheckbox by its recorded ID and path. |
Identifies an ADFSelectManyChoice by its recorded ID and path. |
Identifies an ADFSelectManyListbox by its recorded ID and path. |
Identifies an ADFSelectManyShuttle by its recorded ID and path. |
Identifies an ADFSelectOneChoice by its recorded ID and path. |
Identifies an ADFSelectOneListbox by its recorded ID and path. |
Identifies an ADFSelectOneRadio by its recorded ID and path. |
Identifies an ADFSelectOrderShuttle by its recorded ID and path. |
Identifies an ADFShowDetail by its recorded ID and path. |
Identifies an ADFShowDetailHeader by its recorded ID and path. |
Identifies an ADFDVTSunburstNode by its recorded ID and path. |
Identifies an ADFTable by its recorded ID and path. |
Identifies an ADFToolbar by its recorded ID and path. |
Identifies an ADFTrain by its path. |
Identifies an ADFTrain by its recorded ID and path. |
Identifies an ADFTree by its recorded ID and path. |
Identifies an ADFTreeTable by its recorded ID and path. |
Wait for ADF page to be fully loaded. |
The following sections provide detailed reference information for each method and enum in the ADFService Class of ADF Module Application Programming Interface.
Format
The adf.button method has the following command format(s):
adf.button(path);
adf.button(recId, path);
Command Parameters
a String specifying the object path.
the ID of a previously recorded navigation, used for comparison purposes.
Format
The adf.calendar method has the following command format(s):
adf.calendar(path);
adf.calendar(recId, path);
Command Parameters
Format
The adf.carousel method has the following command format(s):
adf.carousel(path);
adf.carousel(recId, path);
Command Parameters
Format
The adf.chart method has the following command format(s):
adf.chart(path);
adf.chart(recId, path);
Command Parameters
Format
The adf.codeEditor method has the following command format(s):
adf.codeEditor(path);
adf.codeEditor(recId, path);
Command Parameters
Throws
represents an exception that may be thrown during the execution of a script where the exception should be reported to an end user through the controller.
Example
Performs a setValue action on an ADFCodeEditor object specified by its recorded ID and path.
adf.codeEditor(7, "/web:window[@index='0' or @title='Tag Guide']" +
"/web:ADFCodeEditor[@id='tmplt:abcCols:cols:0:secs:2:itms:13:cmd' " +
"and @text='tmplt:abcCols:cols:0:secs:2:itms:13:cmd']")
.setValue();
Format
The adf.commandButton method has the following command format(s):
adf.commandButton(path);
adf.commandButton(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFCommandButton object specified by its recorded ID and path.
adf.commandButton(22, "/web:window[@index='0' " +
"or @title='commandButton Demo']" +
"/web:document[@index='0' or @name='_afr_init_']" +
"/web:ADFCommandButton[@id='dmoTpl:usewindowButton' " +
"and @text='Click here']")
.click();
Format
The adf.commandImageLink method has the following command format(s):
adf.commandImageLink(path);
adf.commandImageLink(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFCommandImageLink object specified by its recorded ID and path.
adf.commandImageLink(6, "/web:window[@index='0' " +
"or @title='commandImageLink Demo']" +
"/web:ADFCommandImageLink[@id='dmoTpl:cil1' and @text='dmoTpl:cil1']")
.click();
Format
The adf.commandLink method has the following command format(s):
adf.commandLink(path);
adf.commandLink(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFCommandLink object specified by its recorded ID and path.
adf.commandLink(32, "/web:window[@index='0' or @title='Tag Guide']" +
"/web:ADFCommandLink[@id='tmplt:abcCols:cols:0:secs:2:itms:13:cmd' " +
.click();
Format
The adf.commandMenuItem method has the following command format(s):
adf.commandMenuItem(path);
adf.commandMenuItem(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFCommandMenuItem object specified by its recorded ID and path.
adf.commandMenuItem(45, "/web:window[@index='0' " +
"or @title='commandMenuItem Demo']" +
"/web:ADFCommandMenuItem[@text='Radio 1' " +
"and @id='dmoTpl:commandMenuItem8']")
.click();
Format
The adf.commandNavigationItem method has the following command format(s):
adf.commandNavigationItem(path);
adf.commandNavigationItem(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFCommandNavigationItem object specified by its recorded ID and path.
import oracle.oats.scripting.modules.adf.api.elements.ADFCommandNavigationItem;
Map<String, String> attributes = adf.commandNavigationItem(7, "/web:window[@index='0' " +
"or @title='commandNavigationItem Demo']" +
"/web:document[@index='0']" +
"/web:ADFCommandNavigationItem[@id='dmoTpl:editorExample:commandNavigationItem1' " +
"and @text='Editor Item' " +
"and @absoluteLocator='dmoTpl:editorExample:commandNavigationItem1' " +
"and @disabled='False']")
.getAttributes();
int pass_attr = 0;
for (String key : attributes.keySet()) {
if (key.equals("id") && attributes.get(key)
.equals("dmoTpl:editorExample:commandNavigationItem1"))
pass_attr++;
if (key.equals("text") && attributes.get(key)
.equals("Editor Item"))
pass_attr++;
if (key.equals("absoluteLocator") && attributes.get(key)
pass_attr++;
if (key.equals("disabled") && attributes.get(key)
.equals("False"))
pass_attr++;
info("Attribute: " + key + " ; " + "Value: " + attributes.get(key));
if (pass_attr == 4)
info("API getAttributes() passed");
else
fail("API getAttributes() failed");
Format
The adf.commandToolbarButton method has the following command format(s):
adf.commandToolbarButton(path);
adf.commandToolbarButton(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFCommandToolbarButton object specified by its recorded ID and path.
adf.commandToolbarButton(57, "/web:window[@index='0' " +
"or @title='commandToolbarButton Demo']" +
"/web:ADFCommandToolbarButton[@id='dmoTpl:commandToolbarButton3' " +
"and @text='forward']")
.clickButton();
Format
The adf.contextInfo method has the following command format(s):
adf.contextInfo(path);
adf.contextInfo(recId, path);
Command Parameters
Format
The adf.diagram method has the following command format(s):
adf.diagram(path);
adf.diagram(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFDVTDiagram object specified by its recorded ID and path.
adf.diagram(27,"/web:window[@index='0' or @title='Dependency Graph Demo']" + "/web:document[@index='0' or @name='9pqocazpp']" + "/web:ADFDVTDiagram[@absoluteLocator='r5:DEPENDENCYGRAPH']") .leftClick("node[19]:ecardIconLayout"); ADFDVTDiagramNode node = adf.diagram(27,"/web:window[@index='0' " + "or @title='Dependency Graph Demo']" + "/web:document[@index='0' or @name='9pqocazpp']" + "/web:ADFDVTDiagram[@absoluteLocator='r5:DEPENDENCYGRAPH']") .getNode("node[1]"); info(node.getShortDesc()); adf.diagram(33,"/web:window[@index='0' or @title='Dependency Graph Demo']" + "/web:document[@index='0' or @name='9pqocazpp']" + "/web:ADFDVTDiagram[@absoluteLocator='r5:DEPENDENCYGRAPH']") .rightClick("node[0]:titlePanel2");
Format
The adf.dialog method has the following command format(s):
adf.dialog(path);
adf.dialog(recId, path);
Command Parameters
Format
The adf.gauge method has the following command format(s):
adf.gauge(path);
adf.gauge(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFDVTGauge object specified by its recorded ID and path.
Map<String, String> attributes =adf.gauge(7, "/web:window[@index='0' " +
"or @title='Gauge Gallery']" +
"/web:document[@index='0' or @name='w0']" +
"/web:ADFDVTGauge[@absoluteLocator='demo:g3']").getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("demo:g3"))
pass_attr++;
if (key.equals("absoluteLocator") && attributes.get(key).equals("demo:g3"))
pass_attr++;
if (key.equals("indicatorValue") && attributes.get(key).equals("63.0"))
pass_attr++;
if (pass_attr == 3)
else
warn("API getAttributes() failed");
Format
The adf.goButton method has the following command format(s):
adf.goButton(path);
adf.goButton(recId, path);
Command Parameters
Throws
Example
Performs a click action on an ADFGoButton object specified by its recorded ID and path.
adf.goButton(7, "/web:window[@index='0' or @title='goButton Demo']" +
"web:ADFGoButton[@absoluteLocator='dmoTpl:btn1' or @text='A link to example.com']")
.click();
Format
The adf.goImageLink method has the following command format(s):
adf.goImageLink(path);
adf.goImageLink(recId, path);
Command Parameters
Throws
Example
Performs a click action on an ADFGoImageLink object specified by its recorded ID and path.
adf.goImageLink(7, "/web:window[@index='0' or @title='outputText Demo']" +
"/web:ADFGoImageLink[@absoluteLocator='dmoTpl:gil1' or @text='A link to example.com']")
.click();
Format
The adf.goLink method has the following command format(s):
adf.goLink(path);
adf.goLink(recId, path);
Command Parameters
Throws
Example
Performs a click action on an ADFGoLink object specified by its recorded ID and path.
adf.goLink(7, "/web:window[@index='0' or @title='goLink Demo']" +
"web:ADFGoLink[@absoluteLocator='dmoTpl:gl1' or @text='A link to example.com']")
.click();
Format
The adf.goMenuItem method has the following command format(s):
adf.goMenuItem(path);
adf.goMenuItem(recId, path);
Command Parameters
Format
The adf.graph method has the following command format(s):
adf.graph(path);
adf.graph(recId, path);
Command Parameters
Format
The adf.hierarchyViewer method has the following command format(s):
adf.hierarchyViewer(path);
adf.hierarchyViewer(recId, path);
Command Parameters
Throws
Example
Defines an ADFDVTHierarchyViewer object specified by its recorded ID and path.
ADFDVTHierarchyViewer hv = adf.hierarchyViewer(6, "/web:window[@index='0' " +
"or @title='pivotTable']" +
"/web:document[@index='0' or @name='n6ceri8cu']" +
"/web:ADFDVTHierarchyViewer[@absoluteLocator='demo:hv1']");
Format
The adf.image method has the following command format(s):
adf.image(path);
adf.image(recId, path);
Command Parameters
Format
The adf.inputColor method has the following command format(s):
adf.inputColor(path);
adf.inputColor(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputColor object specified by its recorded ID and path.
adf.inputColor(7, "/web:window[@index='0' or @title='InputColor Demo']" +
"/web:ADFInputColor[@id='dmoTpl:iColor' and @label='Select a color']")
.setValue("FFFFFF");
Format
The adf.inputComboboxListOfValues method has the following command format(s):
adf.inputComboboxListOfValues(path);
adf.inputComboboxListOfValues(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputComboboxListOfValues object specified by its recorded ID and path.
adf.inputComboboxListOfValues(7, "/web:window[@index='0' " +
"or @title='inputComboboxListOfValues Demo']" +
"/web:ADFInputComboboxListOfValues[" +
@id='dmoTpl:idInputComboboxListOfValues' " +
"and @label='Ename']")
.showDropDown();
Format
The adf.inputDate method has the following command format(s):
adf.inputDate(path);
adf.inputDate(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputDate object specified by its recorded ID and path.
adf.inputDate(9, "/web:window[@index='0' or @title='inputDate Demo']" +
"/web:ADFInputDate[@id='dmoTpl:iDate' " +
"and @label='Select a date: ']")
.setValue("12/12/2010");
Format
The adf.inputFile method has the following command format(s):
adf.inputFile(path);
adf.inputFile(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputFile object specified by its recorded ID and path.
import java.util.Map;
Map<String, String> attributes = adf.inputFile(7, "/web:window[@index='0' " +
"or @title='inputFile Demo']" +
"/web:ADFInputFile[@id='dmoTpl:testid' " +
"and @label='File Upload']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:testid"))
pass_attr++;
if (key.equals("value") && attributes.get(key).equals(""))
pass_attr++;
if (key.equals("label") && attributes.get(key).equals("File Upload"))
pass_attr++;
if (key.equals("required") && attributes.get(key).equals("False"))
pass_attr++;
//info("Attribute: " + key + " ; " + "Value: " + attributes.get(key));
if (pass_attr == 4)
else {
info(pass_attr + " attributes passed");
Format
The adf.inputListOfValues method has the following command format(s):
adf.inputListOfValues(path);
adf.inputListOfValues(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputListOfValues object specified by its recorded ID and path.
adf.inputListOfValues(7, "/web:window[@index='0' " +
"or @title='inputListOfValues Demo']" +
"/web:ADFInputListOfValues[@id='dmoTpl:idInputText' " +
.setValue("test", "Click");
Format
The adf.inputNumberSlider method has the following command format(s):
adf.inputNumberSlider(path);
adf.inputNumberSlider(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputNumberSlider object specified by its recorded ID and path.
adf.inputNumberSlider(89, "/web:window[@index='0' " +
"or @title='inputNumberSlider Demo']" +
"/web:ADFInputNumberSlider[@id='dmoTpl:slider12' " +
"and @label='Vertical Slider']")
.setValue("300");
Format
The adf.inputNumberSpinbox method has the following command format(s):
adf.inputNumberSpinbox(path);
adf.inputNumberSpinbox(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputNumberSpinbox object specified by its recorded ID and path.
adf.inputNumberSpinbox(7, "/web:window[@index='0' " +
"or @title='InputNumberSpinbox Demo']" +
"/web:ADFInputNumberSpinbox[@id='dmoTpl:idInputNumberSpinbox' " +
"and @label='Label']")
.setValue("2011");
Format
The adf.inputRangeSlider method has the following command format(s):
adf.inputRangeSlider(path);
adf.inputRangeSlider(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFInputRangeSlider object specified by its recorded ID and path.
adf.inputRangeSlider(113, "/web:window[@index='0' " +
"or @title='inputRangeSlider Demo']" +
"/web:ADFInputRangeSlider[@id='dmoTpl:rangeSlider1' " +
"and @label='Horizontal Slider']")
.setRange("0", "6");
Format
The adf.inputText method has the following command format(s):
adf.inputText(path);
adf.inputText(recId, path);
Command Parameters
Format
The adf.link method has the following command format(s):
adf.link(path);
adf.link(recId, path);
Command Parameters
Format
The adf.listItem method has the following command format(s):
adf.listItem(path);
adf.listItem(recId, path);
Command Parameters
Throws
Example
Gets the attributes of an ADFListItem object specified by its recorded ID and path.
Map<String, String> attributes = adf.listItem(0, "/web:window[@index='0' " +
"or @title='listItem']" +
"/web:ADFListItem[@id='demo:t1' or @absoluteLocator='demo:t1']")
.getAttributes();
int pass_attr = 0;
.equals("demo:t1"))
pass_attr++;
.equals("demo:t1"))
pass_attr++;
// info("Attribute: " + key + " ; " + "Value: " + attributes.get(key));
if (pass_attr == 2)
else
Format
The adf.listView method has the following command format(s):
adf.listView(path);
adf.listView(recId, path);
Command Parameters
Throws
Example
Defines an ADFListView object specified by its recorded ID and path.
ADFListView view = adf.listView(0, "/web:window[@index='0' " +
"or @title='listView']" +
"/web:ADFListView[@id='demo:t1' or @absoluteLocator='demo:t1']");
int count = view.getItemCount();
info("item count = " + count);
Format
The adf.menu method has the following command format(s):
adf.menu(path);
adf.menu(recId, path);
Command Parameters
Format
The adf.message method has the following command format(s):
adf.message(path);
adf.message(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFMessage object specified by its recorded ID and path.
Map<String, String> attributes = adf.message(7, "/web:window[@index='0' " +
"or @title='message Demo']" +
"/web:ADFMessage[@id='dmoTpl:message1']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:message1"))
pass_attr++;
if (key.equals("message") && attributes.get(key).equals(""))
pass_attr++;
if (key.equals("shortDesc") && attributes.get(key).equals(""))
pass_attr++;
if (key.equals("messageType") && attributes.get(key).equals("none"))
pass_attr++;
if (pass_attr == 4)
else {
Format
The adf.messages method has the following command format(s):
adf.messages(path);
adf.messages(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFMessages object specified by its recorded ID and path.
Map<String, String> attributes = adf.messages(7, "/web:window[@index='0' " +
"or @title='messages Demo']" +
"/web:ADFMessages[@id='dmoTpl:messages1']")
.getAttributes();
int pass_attr = 0;
.equals("dmoTpl:messages1"))
pass_attr++;
.equals("Please read this carefully:"))
pass_attr++;
.equals("Sample shortDesc text"))
pass_attr++;
if (key.equals("rendererType") && attributes.get(key)
.equals("oracle.adf.rich.Messages"))
pass_attr++;
if (pass_attr == 4)
else {
Format
The adf.navigationPane method has the following command format(s):
adf.navigationPane(path);
adf.navigationPane(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFNavigationPane object specified by its recorded ID and path.
adf.navigationPane(152, "/web:window[@index='0' " +
"or @title='navigationPane Demo']" +
"/web:ADFNavigationPane[@id='dmoTpl:barExample']")
.select("Bar Item 1", "xdc xh5");
Format
The adf.noteWindow method has the following command format(s):
adf.noteWindow(path);
adf.noteWindow(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFNoteWindow object specified by its recorded ID and path.
Map<String, String> attributes = adf.noteWindow(
"or @title='noteWindow Demo']" +
"/web:ADFNoteWindow[@id='dmoTpl:nw1']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:nw1"))
pass_attr++;
if (key.equals("content") && !attributes.get(key).equals(""))
pass_attr++;
if (pass_attr == 2)
else {
Format
The adf.outputFormatted method has the following command format(s):
adf.outputFormatted(path);
adf.outputFormatted(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFOutputFormatted object specified by its path.
Map<String, String> attributes = adf.outputFormatted("/web:window[@index='0' " +
"or @title='outputFormatted Demo']" +
"/web:ADFOutputFormatted[@id='dmoTpl:of3']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:of3"))
pass_attr++;
if (key.equals("displayText") && attributes.get(key).equals("This should be red"))
pass_attr++;
.equals("<SPAN style=\"COLOR: red\">This should be red</SPAN>"))
pass_attr++;
if (key.equals("absoluteLocator") && attributes.get(key).equals("dmoTpl:of3"))
pass_attr++;
if (pass_attr == 4)
else
Format
The adf.outputLabel method has the following command format(s):
adf.outputLabel(path);
adf.outputLabel(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFOutputLabel object specified by its recorded ID and path.
Map<String, String> attributes = adf.outputLabel(7, "/web:window[@index='0' " +
"or @title='outputLabel Demo']" +
"/web:ADFOutputLabel[@id='dmoTpl:_OutputLabel']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:_OutputLabel"))
pass_attr++;
if (key.equals("value") && attributes.get(key).equals("Test Output Label"))
pass_attr++;
if (pass_attr == 2)
else {
Format
The adf.outputText method has the following command format(s):
adf.outputText(path);
adf.outputText(recId, path);
Command Parameters
Throws
Example
Get value attribute from an ADFOutputText object specified by its recorded ID and path.
String value = adf.outputText(7, "/web:window[@index='0' " +
"/web:ADFOutputText[@id='dmoTpl:ot1']")
.getAttribute("value");
info("value = " + value);
Format
The adf.page method has the following command format(s):
adf.page(path);
adf.page(recId, path);
Command Parameters
Format
The adf.panelAccordion method has the following command format(s):
adf.panelAccordion(path);
adf.panelAccordion(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFPanelAccordion object specified by its recorded ID and path.
adf.panelAccordion(8, "/web:window[@index='0' " +
"or @title='panelAccordion Demo']/" +
"web:document[@index='0' or @name='_afr_init_']" +
"/web:ADFPanelAccordion[@id='dmoTpl:sampleAccordion']")
.expand("dmoTpl:doubleFlexPane");
Format
The adf.panelBox method has the following command format(s):
adf.panelBox(path);
adf.panelBox(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFPanelBox object specified by its recorded ID and path.
adf.panelBox(8, "/web:window[@index='0' or @title='panelBox Demo']" +
"/web:ADFPanelBox[@id='dmoTpl:panelBoxB3' " +
"and @text='Highlight Light']")
.expand();
Format
The adf.panelDrawer method has the following command format(s):
adf.panelDrawer(path);
adf.panelDrawer(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFPanelDrawer object specified by its recorded ID and path.
Map<String, String> attributes = adf.panelDrawer(7, "/web:window[@index='0' " +
"or @title='panelHeader Demo']" +
"/web:ADFPanelHeader[@id='dmoTpl:panelHeader' " +
"and @text='Automatic Header' " +
"and @absoluteLocator='dmoTpl:panelDrawer']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:panelDrawer"))
pass_attr++;
if (key.equals("absoluteLocator") && attributes.get(key).equals("dmoTpl:panelDrawer"))
pass_attr++;
if (pass_attr == 2)
else
Format
The adf.panelHeader method has the following command format(s):
adf.panelHeader(path);
adf.panelHeader(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFPanelHeader object specified by its recorded ID and path.
Map<String, String> attributes = adf.panelHeader(7, "/web:window[@index='0' " +
"and @absoluteLocator='dmoTpl:panelHeader']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:panelHeader"))
pass_attr++;
if (key.equals("text") && attributes.get(key).equals("Automatic Header"))
pass_attr++;
pass_attr++;
if (pass_attr == 3)
else
Format
The adf.panelLabelAndMessage method has the following command format(s):
adf.panelLabelAndMessage(path);
adf.panelLabelAndMessage(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFPanelLabelAndMessage object specified by its recorded ID and path.
import oracle.oats.scripting.modules.adf.api.elements.ADFPanelLabelAndMessage;
Map<String, String> attributes = adf.panelLabelAndMessage(7, "/web:window[@index='0' " +
"or @title='panelLabelAndMessage Demo']" +
"/web:ADFPanelLabelAndMessage[@id='dmoTpl:panelLabelAndMessage' " +
"and @absoluteLocator='dmoTpl:panelLabelAndMessage' and @label='Label']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:panelLabelAndMessage"))
pass_attr++;
if (key.equals("label") && attributes.get(key).equals("Label"))
pass_attr++;
pass_attr++;
if (pass_attr == 3)
else
Format
The adf.panelList method has the following command format(s):
adf.panelList(path);
adf.panelList(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFPanelList object specified by its recorded ID and path.
Map<String, String> attributes = adf.panelList(8, "/web:window[@index='0' " +
"or @title='panelList Demo']" +
"/web:ADFPanelList[@id='dmoTpl:panelList']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("dmoTpl:panelList"))
pass_attr++;
if (key.equals("maxColumns") && attributes.get(key).equals("3"))
pass_attr++;
if (key.equals("rows") && attributes.get(key).equals("2147483647"))
pass_attr++;
if (pass_attr == 3)
else {
Format
The adf.panelSplitter method has the following command format(s):
adf.panelSplitter(path);
adf.panelSplitter(recId, path);
Command Parameters
Format
The adf.panelSpringboard method has the following command format(s):
adf.panelSpringboard(path);
adf.panelSpringboard(recId, path);
Command Parameters
Throws
Example
Defines an ADFPanelSpringboard object specified by its recorded ID and path.
ADFPanelSpringboard springboard = adf.panelSpringboard(6, + "/web:window[@index='0'or @title='panelSpringboard']" +
"/web:ADFPanelSpringboard[@absoluteLocator='demo:ps1']");
String itemName = springboard.getSelectedItemName();
info("itemName = " + itemName);
Format
The adf.panelTabbed method has the following command format(s):
adf.panelTabbed(path);
adf.panelTabbed(recId, path);
Command Parameters
Format
The adf.panelWindow method has the following command format(s):
adf.panelWindow(path);
adf.panelWindow(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFPanelWindow object specified by its recorded ID and path.
adf.commandButton(7, "/web:window[@index='0' or @title='panelWindow Demo']" +
"/web:ADFCommandButton[@id='dmoTpl:commandButton' " +
"and @text='Show Window']")
.click();
adf.panelWindow(8, "/web:window[@index='0' or @title='panelWindow Demo']" +
"/web:ADFPanelWindow[@id='dmoTpl:panelWindow1' " +
"and @title='Test Window']")
.clickCloseIcon();
Format
The adf.pivotTable method has the following command format(s):
adf.pivotTable(path);
adf.pivotTable(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFDVTPivotTable object specified by its recorded ID and path.
Map<String, String> attributes =adf.pivotTable(7, "/web:window[@index='0' " +
"or @title='PivotTable']" +
"/web:ADFDVTPivotTable[@id='demo:pt1' and @absoluteLocator='demo:pt1']")
.getAttributes();
int pass_attr = 0;
if (key.equals("id") && attributes.get(key).equals("demo:pt1"))
pass_attr++;
if (key.equals("absoluteLocator") && attributes.get(key).equals("demo:pt1"))
pass_attr++;
if (pass_attr == 2)
else
Format
The adf.progressIndicator method has the following command format(s):
adf.progressIndicator(path);
adf.progressIndicator(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFProgressIndicator object specified by its recorded ID and path.
Map<String, String> attributes = adf.progressIndicator(
7, "/web:window[@index='0' or @title='progressIndicator Demo']" +
"/web:ADFProgressIndicator[@id='dmoTpl:progressIndicator']")
.getAttributes();
int pass_attr = 0;
.equals("dmoTpl:progressIndicator"))
pass_attr++;
if (key.equals("value") && attributes.get(key).equals("0%"))
pass_attr++;
if (pass_attr == 2)
else {
Format
The adf.query method has the following command format(s):
adf.query(path);
adf.query(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFQuery object specified by its recorded ID and path.
adf.query(11, "/web:window[@index='0' or @title='query Demo']" +
"/web:ADFQuery[@id='dmoTpl:highSalariedClerksQueryId' " +
"and @headerText='Search']")
.clickButton("Search");
Format
The adf.quickQuery method has the following command format(s):
adf.quickQuery(path);
adf.quickQuery(recId, path);
Command Parameters
Format
The adf.region method has the following command format(s):
adf.region(path);
adf.region(recId, path);
Command Parameters
Format
The adf.resetButton method has the following command format(s):
adf.resetButton(path);
adf.resetButton(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFResetButton object specified by its recorded ID and path.
adf.resetButton(351,"/web:window[@index='0' or @title='resetButton Demo']" +
"/web:ADFResetButton[@id='dmoTpl:idResetButton' " +
"and @text='Rich ResetButton']")
.click();
Format
The adf.richTextEditor method has the following command format(s):
adf.richTextEditor(path);
adf.richTextEditor(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFRichTextEditor object specified by its recorded ID and path.
adf.richTextEditor(35, "/web:window[@index='0' " +
"or @title='richTextEditor Demo']" +
"/web:ADFRichTextEditor[@id='dmoTpl:idRichTextEditor' " +
"and @label='Rich text value']")
.setValue("<P dir=ltr style=\"MARGIN-RIGHT: 0px\">Hello World</P>\r\n");
Format
The adf.selectBooleanCheckbox method has the following command format(s):
adf.selectBooleanCheckbox(path);
adf.selectBooleanCheckbox(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectBooleanCheckbox object specified by its recorded ID and path.
adf.selectBooleanCheckbox(47,"/web:window[@index='0' " +
"or @title='selectBooleanCheckbox Demo']" +
"/web:ADFSelectBooleanCheckbox[@id='dmoTpl:idSBC2' " +
"and @label='Extra Keys']")
.select();
Format
The adf.selectBooleanRadio method has the following command format(s):
adf.selectBooleanRadio(path);
adf.selectBooleanRadio(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectBooleanRadio object specified by its recorded ID and path.
adf.selectBooleanRadio(8, "/web:window[@index='0' " +
"or @title='selectBooleanRadio Demo']" +
"/web:ADFSelectBooleanRadio[@id='dmoTpl:radio1' " +
"and @label='Age']")
.select("10-18");
Format
The adf.selectManyCheckbox method has the following command format(s):
adf.selectManyCheckbox(path);
adf.selectManyCheckbox(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectManyCheckbox object specified by its recorded ID and path.
adf.selectManyCheckbox(8, "/web:window[@index='0' " +
"or @title='selectManyCheckbox Demo']" +
"/web:ADFSelectManyCheckbox[@id='dmoTpl:targetListbox' " +
"and @label='Drinks']")
.select("milk", "4");
Format
The adf.selectManyChoice method has the following command format(s):
adf.selectManyChoice(path);
adf.selectManyChoice(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectManyChoice object specified by its recorded ID and path.
adf.selectManyChoice(7, "/web:window[@index='0' " +
"or @title='selectManyChoice Demo']" +
"/web:ADFSelectManyChoice[@id='dmoTpl:targetChoice' " +
.select("coffee");
Format
The adf.selectManyListbox method has the following command format(s):
adf.selectManyListbox(path);
adf.selectManyListbox(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectManyListbox object specified by its recorded ID and path.
adf.selectManyListbox(8, "/web:window[@index='0' " +
"or @title='selectManyListbox Demo']" +
"/web:ADFSelectManyListbox[@id='dmoTpl:targetListbox' " +
.select("tea;green", "1");
Format
The adf.selectManyShuttle method has the following command format(s):
adf.selectManyShuttle(path);
adf.selectManyShuttle(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectManyShuttle object specified by its recorded ID and path.
adf.selectManyShuttle(18, "/web:window[@index='0' " +
"or @title='selectManyShuttle Demo']" +
"/web:ADFSelectManyShuttle[@id='dmoTpl:manyShuttle' " +
.move();
Format
The adf.selectOneChoice method has the following command format(s):
adf.selectOneChoice(path);
adf.selectOneChoice(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectOneChoice object specified by its recorded ID and path.
adf.selectOneChoice(127, "/web:window[@index='0' " +
"or @title='selectOneChoice Demo']" +
"/web:ADFSelectOneChoice[@id='dmoTpl:targetChoice' " +
"and @label='Drink']")
.select("coffee");
Format
The adf.selectOneListbox method has the following command format(s):
adf.selectOneListbox(path);
adf.selectOneListbox(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectOneListbox object specified by its recorded ID and path.
adf.selectOneListbox(7, "/web:window[@index='0' " +
"or @title='selectOneListbox Demo']" +
"/web:ADFSelectOneListbox[@id='dmoTpl:targetListbox' " +
.select("tea;green");
Format
The adf.selectOneRadio method has the following command format(s):
adf.selectOneRadio(path);
adf.selectOneRadio(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectOneRadio object specified by its recorded ID and path.
adf.selectOneRadio(7, "/web:window[@index='0' " +
"or @title='selectOneRadio Demo']" +
"/web:ADFSelectOneRadio[@id='dmoTpl:targetRadio' " +
.select("lemonade");
Format
The adf.selectOrderShuttle method has the following command format(s):
adf.selectOrderShuttle(path);
adf.selectOrderShuttle(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFSelectOrderShuttle object specified by its recorded ID and path.
adf.selectOrderShuttle(11, "/web:window[@index='0' " +
"or @title='selectOrderShuttle Demo']" +
"/web:ADFSelectOrderShuttle[@id='dmoTpl:manyShuttle' " +
.moveUp();
Format
The adf.showDetail method has the following command format(s):
adf.showDetail(path);
adf.showDetail(recId, path);
Command Parameters
Format
The adf.showDetailHeader method has the following command format(s):
adf.showDetailHeader(path);
adf.showDetailHeader(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFShowDetailHeader object specified by its recorded ID and path.
adf.showDetailHeader(7, "/web:window[@index='0' " +
"or @title='showDetailHeader Demo']" +
"/web:ADFShowDetailHeader[@id='dmoTpl:showDetailHeader' " +
"and @text='Automatic Header']")
.expand();
Identifies an ADFDVTSunburst by its recorded ID and path.
Format
The adf.sunburst method has the following command format(s):
adf.sunburst(path);
adf.sunburst(recId, path);
Command Parameters
Throws
Example
Gets the attributes of an ADFDVTSunburst object specified by its recorded ID and path.
Map<String, String> attributes1 = adf.sunburst(11,
"/web:window[@index='0' or @title='sunburst']" +
"/web:document[@index='0' or @name='wp410']" +
"/web:ADFDVTSunburst[@id='demo:sunburst1' " +
"and @absoluteLocator='demo:sunburst1']")
.getAttributes();
int pass_attr1 = 0;
.equals("demo:sunburst1"))
pass_attr1++;
pass_attr1++;
if (pass_attr1 == 2)
else
Format
The adf.table method has the following command format(s):
adf.table(path);
adf.table(recId, path);
Command Parameters
Throws
Example
Performs an action on an ADFTable object specified by its recorded ID and path.
String getCell = adf.table(11, "/web:window[@index='0' " +
"or @title='table Demo']" +
"/web:ADFTable[@id='dmoTpl:table']")
.getCell(1, 1);
info("Cell Value = " + getCell);
Format
The adf.toolbar method has the following command format(s):
adf.toolbar(path);
adf.toolbar(recId, path);
Command Parameters
Format
The adf.train method has the following command format(s):
adf.train(path);
adf.train(recId, path);
Command Parameters
Format
The adf.trainButtonBar method has the following command format(s):
adf.trainButtonBar(path);
adf.trainButtonBar(recId, path);
Command Parameters
Format
The adf.tree method has the following command format(s):
adf.tree(path);
adf.tree(recId, path);
Command Parameters
Format
The adf.treeTable method has the following command format(s):
adf.treeTable(path);
adf.treeTable(recId, path);
Command Parameters
Wait for ADF page to be fully loaded. It would use the object time out value as the default time out value.
Format
The adf.waitForPageLoaded method has the following command format(s):
adf.waitForPageLoaded(path);
adf.waitForPageLoaded(path, timeout);
Command Parameters
a String specifying the document path.
a Long specifying the timeout value (in miliseconds) of the wait action.
