| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript FormsService Class of Forms Functional Module Application Programming Interface (API).
The following section provides an alphabetical listing of the methods in the OpenScript FormsService API.
The following table lists the FormsService API methods in alphabetical order.
Table 15-1 List of FormsService Methods
| Method | Description |
Identifies an Oracle Forms alertDialog object by its path. |
Identifies an Oracle Forms AppletAdapter object by its applet name. |
Construct property data of a single attribute. |
Utility function to return a list of property tests. |
Identifies an Oracle Forms blockScroller object by its path. |
Identifies an Oracle Forms Button object by its path. |
Identifies an Oracle Forms calendar object by its path. |
Capture the screen shot at runtime. |
Constructs the test data of a table cell. |
Constructs the list of table cell tests. |
Identifies an Oracle Forms checkBox object by its path. |
Identifies an Oracle Forms choiceBox object by its path. |
Close the running forms. |
Identifies an Oracle Forms comboBox object by its path. |
Identifies an Oracle Forms editBox object by its path. |
Identifies an Oracle Forms EditorDialog object by its path. |
Identifies an Oracle Forms FlexWindow object by its path. |
Gets all forms objects. |
Gets the bar count shown in the bottom of the forms client. |
Gets the error code shown in the status bar of the forms client. |
Gets the item shown in the status bar of forms client. |
Gets the item count shown in the status bar of forms client. |
Gets the message shown in the status bar of forms client. |
Gets the record info shown in the status bar of the forms client. |
Identifies an Oracle Forms HGridApp object by its path. |
Identifies an Oracle Forms helpDialog object by its path. |
Identifies an Oracle Forms imageItem object by its path. |
Identifies an Oracle Forms infoBox object by its path. |
Identifies an Oracle Forms list object by its path. |
Identifies an Oracle Forms listOfValues object by its path. |
Identifies an Oracle Forms logonDialog object by its path. |
Identifies an Oracle Forms otsHGrid object by its path. |
Identifies an Oracle Forms radioButton object by its path. |
Identifies an Oracle Forms responseBox object by its path. |
Identifies an Oracle Forms schedulingDataClient object by its path. |
Identifies an Oracle Forms spreadTable object by its path. |
Identifies an Oracle Forms StatusBar object by its recorded ID and path. |
Identifies an Oracle Forms tab object by its path. |
Identifies an Oracle Forms tableBox object by its path. |
Identifies an Oracle Forms textField object by its path. |
Identifies an Oracle Forms tree object by its path. |
Identifies an Oracle Forms treeList object by its path. |
Identifies an Oracle Forms window object by its path. |
The following sections provide detailed reference information for each method and enum in the FormsService Class of Forms Functional Module Application Programming Interface.
Format
The forms.alertDialog method has the following command format(s):
forms.alertDialog(path);
forms.alertDialog(recid, path);
Command Parameters
Optional the ID of a previously recorded navigation, used for comparison purposes. May be null.
a String specifying the path to identify the forms alertDialog. For example, //forms:alertDialog. Must not be null. Since it is only possible to show one alertDialog in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the alertDialog object.
Format
The forms.appletAdapter method has the following command format(s):
forms.appletAdapter(path);
forms.appletAdapter(recid, path);
Command Parameters
a String specifying the applet name to identify the forms appletAdater. For example, //forms:appletAdapter[(@appletName='NAV_CONTROLS_EXPAND_ALL_0')]. Must not be null.
Format
The forms.attribute method has the following command format(s):
forms.attribute(property, expectedValue, operator);
Command Parameters
a String specifying the property name.
a String specifying the expected value.
a TestOperator enum defining the type and the match approach of the data.
Example
Specify the attributes of an object.
forms.textField(248, "//forms:textField[" +
"(@name='STUB_APPLICATION_NAME_0')]")
.setFocus();
forms.textField(249,"//forms:textField[" +
.setText("abc");
forms.textField("//forms:textField[" +
.verifyAttributes("test1",forms.attributes(
forms.attribute("enabled", "true",
TestOperator.StringExact),
forms.attribute("text", "Sales",
forms.attribute("visible", "true",
forms.attribute("name", "STUB_APPLICATION_NAME_0",
forms.attribute("showing", "true",
forms.attribute("prompt", "Application",
forms.attribute("editable", "true",
TestOperator.StringExact)));
Command Parameters
an array of PropertyTest attribute objects specifying all the tests included in the forms object test.
Example
.setFocus();
.setText("abc");
Format
The forms.blockScroller method has the following command format(s):
forms.blockScroller(path);
forms.blockScroller(recid, path);
Command Parameters
a String specifying the path to identify the forms blockScroller. For example, //forms:blockScroller. Must not be null. Without further notice, this method only works properly when only one blockScroller exists in a window.
Throws
represents an exception that may be thrown during the execution of a script where the exception should be reported to an end user through the controller.
Example
Performs an action on an Oracle Forms blockScroller object specified by its recorded ID and path.
int maxNum=forms.blockScroller(50, "//forms:blockScroller") .getMaximum(); int minNum=forms.blockScroller50, "//forms:blockScroller") .getMinimum(); int value=forms.blockScroller(50, "//forms:blockScroller") .getValue(); info("maxNum:"+maxNum+" minNum:"+minNum+" value8:"+value); forms.blockScroller(50, "//forms:blockScroller") .scrollDown(); int scrollDownValue=forms.blockScroller(50, "//forms:blockScroller") .getValue(); forms.blockScroller(50, "//forms:blockScroller") .scrollUp(); int scrollUpValue=forms.blockScroller(50, "//forms:blockScroller") .getValue(); if(value!=8)warn("scroll to error!"); if(scrollDownValue!=9)warn("scroll to error!"); if(scrollUpValue!=8)warn("scroll up error!");
Format
The forms.button method has the following command format(s):
forms.button(path);
forms.button(recid, path);
Command Parameters
a String specifying the path to identify the forms button. For example, //forms:button[(@name='NAV_CONTROLS_EXPAND_ALL_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms Button object specified by its recorded ID and path.
forms.button(32, "//forms:button[(@name='CALENDAR_OK_0')]")
.setFocus();
String accName1=forms.button(32, "//forms:button[(@name='CALENDAR_OK_0')]")
.getAccessibleName();
String label1=forms.button(32, "//forms:button[(@name='CALENDAR_OK_0')]")
.getLabel();
info("accssibleName: " + accName1);
info("Label: " + label1);
Format
The forms.calendar method has the following command format(s):
forms.calendar(path);
forms.calendar(recid, path);
Command Parameters
a String specifying the path to identify the forms calendar. For example, //forms:calendar. Must not be null. Since it is only possible to show one calendar in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the calendar object.
Throws
Example
Performs an action on an Oracle Forms calendar object specified by its recorded ID and path.
forms.textField(111, "//forms:textField[" + "(@name='GROUPS_EXPENDITURE_ENDING_DATE_0')]") .openDialog(); forms.button(114, "//forms:button[" + "(@name='CALENDAR_OK_0')]") .setFocus(); forms.calendar(115, "//forms:calendar") .enter("06-JAN-2011"); forms.window(118, "//forms:window[" + "(@name='GROUPS_DETAIL')]") .activate(true); forms.textField(119, "//forms:textField[" + "(@name='GROUPS_EXPENDITURE_ENDING_DATE_0')]") .openDialog(); forms.button(122, "//forms:button[(@name='CALENDAR_OK_0')]") .setFocus(); forms.calendar(123, "//forms:calendar") .clickOk();
Capture the screen shot at runtime. Please refer to {@link #captureScreenshot(Integer,String)}.
Format
The forms.captureScreenshot method has the following command format(s):
forms.captureScreenshot( );
forms.captureScreenshot(recid);
Command Parameters
Format
The forms.cell method has the following command format(s):
forms.cell(row, column, expectedValue, operator);
Command Parameters
a 1-based index value specifying the row number.
a 1-based index value specifying the column number.
a String specifying the expected value of the property.
a TestOperator enum that defines the type and the match approach of the data.
Example
Adds a table test for specifying exact match or wildcard match for individual cells.
forms.otsHGrid("//forms:otsHGrid[(@name='ASTEVENR_CONF_HGRID_ITEMS_0')]" +
.assertCells("MyTableTest",
forms.cells(forms.cell(1, 1, "Ticker ",TestOperator.StringExact),
forms.cell(1, 2,"Company ", TestOperator.StringExact),
forms.cell(2, 1, "ORCL*", TestOperator.StringWildCard),
forms.cell(2, 2, "Oracle", TestOperator.StringExact)));
Example
Adds a table test for specifying exact match or wildcard match for each cell.
web.cells(forms.cell(1, 1, "Ticker ",TestOperator.StringExact),
Format
The forms.checkBox method has the following command format(s):
forms.checkBox(path);
forms.checkBox(recid, path);
Command Parameters
a String specifying the path to identify the forms checkBox. For example, //forms:checkBox[(@name='MTL_SYSTEM_ITEMS_INVENTORY_ITEM_FLAG_MIR_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms checkBox object specified by its recorded ID and path.
forms.checkBox(35, "//forms:checkBox[" + "(@name='JOBS_QF_SHOW_STAGES_0')]") .check(true); forms.checkBox(35, "//forms:checkBox[" + "(@name='JOBS_QF_SHOW_STAGES_0')]") .verifyAttribute("checkbox status", "state", "true", TestOperator.StringExact); if( !forms.checkBox(35, "//forms:checkBox[" + "(@name='JOBS_QF_SHOW_STAGES_0')]") .isSelected())warn("check statement error"); String accessibleName=forms.checkBox(35, "//forms:checkBox[" + "(@name='JOBS_QF_SHOW_STAGES_0')]") .getAccessibleName(); String label=forms.checkBox(35, "//forms:checkBox[" + "(@name='JOBS_QF_SHOW_STAGES_0')]") .getLabel(); //output accessible name and label info("check box's acccessible name: " + accessibleName); info("check box's label: " + label);
Format
The forms.choiceBox method has the following command format(s):
forms.choiceBox(path);
forms.choiceBox(recid, path);
Command Parameters
a String specifying the path to identify the forms choiceBox. For example, //forms:choiceBox. Must not be null. Since it is only possible to show one choiceBox in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the choiceBox object.
Close the running forms. Please refer to forms.close
Format
The forms.close method has the following command format(s):
forms.close( );
forms.close(recid);
Command Parameters
the ID of a previously recorded element which is another corresponding element to this, holding all the info recorded.
Format
The forms.comboBox method has the following command format(s):
forms.comboBox(path);
forms.comboBox(recid, path);
Command Parameters
a String specifying the path to identify the forms comboBox. For example, //forms:comboBox[(@name='ALL_WIDGETS_LIST508_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms comboBox object specified by its recorded ID and path.
//get accessible name and count String accessName=forms.comboBox(20, "//forms:comboBox[" + "(@name='ALL_WIDGETS_LIST508_0')]") .getAccessibleName(); int itemCount=forms.comboBox(20, "//forms:comboBox[" + "(@name='ALL_WIDGETS_LIST508_0')]") .getItemCount(); info("accessible Name: " + accessName); info("item count: " + itemCount); forms.comboBox(20, "//forms:comboBox[" + "(@name='ALL_WIDGETS_LIST508_0')]") .setFocus(); forms.comboBox(20, "//forms:comboBox[" + "(@name='ALL_WIDGETS_LIST508_0')]") .setText("text"); String itemValue = forms.comboBox(20, "//forms:comboBox[" + "(@name='ALL_WIDGETS_LIST508_0')]") .getItemValue(""); info(itemValue);
Format
The forms.editBox method has the following command format(s):
forms.editBox(path);
forms.editBox(recid, path);
Command Parameters
a String specifying the path to identify the forms editBox. For example, //forms:calendar. Must not be null. Since it is only possible to show one editBox in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the editBox object.
Throws
Example
Performs an action on an Oracle Forms editBox object specified by its recorded ID and path.
forms.window(65, "//forms:window[(@name='GROUPS_DETAIL')]")
.selectMenu("Help|About Oracle Applications...");
forms.editBox(68, "//forms:editBox").clickOk();
String text1 = forms.editBox(68, "//forms:editBox")
.getText();
info("editBox text: " + text1);
Format
The forms.editorDialog method has the following command format(s):
forms.editorDialog(path);
forms.editorDialog(recid, path);
Command Parameters
a String specifying the path to identify the forms editorDialog. For example, //forms:editorDialog. Must not be null. Since it is only possible to show one editorDialog in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the editorDialog object.
Format
The forms.flexWindow method has the following command format(s):
forms.flexWindow(path);
forms.flexWindow(recid, path);
Command Parameters
a String specifying the path to identify the forms flexWindow. For example, //forms:flexWindow. Must not be null. Since it is only possible to show one flexWindow in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the flexWindow object.
Throws
Example
Performs an action on an Oracle Forms FlexWindow object specified by its recorded ID and path.
forms.textField(156, "//forms:textField[" +
"(@name='LINES_ACCOUNTING_FLEXFIELD_0')]")
.openDialog();
forms.flexWindow(159, "//forms:flexWindow")
.setTextAndClickOk("Account Alias", "",
"01-000-2225-0000-000");
Format
The forms.getStatusBarCount method has the following command format(s):
forms.getStatusBarCount( );
Format
The forms.getStatusBarErrorCode method has the following command format(s):
forms.getStatusBarErrorCode( );
Format
The forms.getStatusBarItem method has the following command format(s):
forms.getStatusBarItem(barIndex, barItemIndex);
Command Parameters
the index of the status bar starting from 0.
the item index of the status bar starting from 0.
Format
The forms.getStatusBarItemCount method has the following command format(s):
forms.getStatusBarItemCount(index);
Format
The forms.getStatusBarMessage method has the following command format(s):
forms.getStatusBarMessage( );
Format
The forms.getStatusBarRecordInfo method has the following command format(s):
forms.getStatusBarRecordInfo( );
Format
The forms.helpDialog method has the following command format(s):
forms.helpDialog(path);
forms.helpDialog(recid, path);
Command Parameters
a String specifying the path to identify the forms helpDialog. For example, //forms:helpDialog. Must not be null. Since it is only possible to show one helpDialog in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the helpDialog object.
Format
The forms.hGridApp method has the following command format(s):
forms.hGridApp(path);
forms.hGridApp(recid, path);
Command Parameters
a String specifying the path to identify the forms HGridApp. For example, //hGridApp[@name='IEU_HGRID_IEU_HGRID_0']. Must not be null.
Format
The forms.imageItem method has the following command format(s):
forms.imageItem(path);
forms.imageItem(recid, path);
Command Parameters
a String specifying the path to identify the forms imageItem. For example, //forms:imageItem[(@name='NAV_CONTROLS_EXPAND_ALL_0')]. Must not be null.
Format
The forms.infoBox method has the following command format(s):
forms.infoBox(path);
forms.infoBox(recid, path);
Command Parameters
a String specifying the path to identify the forms infoBox. For example, //forms:infoBox. Must not be null. Since it is only possible to show one infoBox in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the infoBox object.
Format
The forms.list method has the following command format(s):
forms.list(path);
forms.list(recid, path);
Command Parameters
a String specifying the path to identify the forms list. For example, //forms:list[(@name='JTF_SORT_COLUMN1_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms list object specified by its recorded ID and path.
String accessName=forms.list(25, "//forms:list[" + "(@name='GROUPS_SYSTEM_LINKAGE_FUNCTION_0')]") .getAccessibleName(); int itemCount=forms.list(25, "//forms:list[" + "(@name='GROUPS_SYSTEM_LINKAGE_FUNCTION_0')]") .getItemCount(); info("accessible Name: " + accessName); info("item count: " + itemCount); //getItemValue forms.list(25, "//forms:list[" + "(@name='GROUPS_SYSTEM_LINKAGE_FUNCTION_0')]") .selectItem("Usages"); String itemValue=forms.list(25, "//forms:list[" + "(@name='GROUPS_SYSTEM_LINKAGE_FUNCTION_0')]") .getItemValue(); info(itemValue); //isItemInList boolean isItem=forms.list(25, "//forms:list[" + "(@name='GROUPS_SYSTEM_LINKAGE_FUNCTION_0')]") .isItemInList("Usages"); if(!isItem)warn("Item not in list"); //isItemSelected boolean isSelected=forms.list(25, "//forms:list[" + "(@name='GROUPS_SYSTEM_LINKAGE_FUNCTION_0')]") .isItemSelected("Usages"); if(!isSelected)warn("Item not selected");
Format
The forms.listOfValues method has the following command format(s):
forms.listOfValues(path);
forms.listOfValues(recid, path);
Command Parameters
a String specifying the path to identify the forms listOfValues. For example, //forms:listOfValues. Must not be null. Since it is only possible to show one listOfValues in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the listOfValues object.
Throws
Example
Performs an action on an Oracle Forms listOfValues object specified by its recorded ID and path.
//get item count int itemcount=forms.listOfValues(20, "//forms:listOfValues") .getItemCount(); info("Item count: " + itemcount); //get text String text = ""; for(int i=0;i<itemcount;i++) { text=forms.listOfValues(21, "//forms:listOfValues") .getText(i); info("Item " + i + "text: " + text); }
Format
The forms.logonDialog method has the following command format(s):
forms.logonDialog(path);
forms.logonDialog(recid, path);
Command Parameters
a String specifying the path to identify the forms logonDialog. For example, //logonDialog. Must not be null. Since it is only possible to show one logonDialog in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the logonDialog object.
Format
The forms.otsHGrid method has the following command format(s):
forms.otsHGrid(path);
forms.otsHGrid(recid, path);
Command Parameters
a String specifying the path to identify the forms otsHGrid. For example, //forms:otsHGrid[(@name='ASTEVENR_CONF_HGRID_ITEMS_0')]. Must not be null.
Format
The forms.radioButton method has the following command format(s):
forms.radioButton(path);
forms.radioButton(recid, path);
Command Parameters
a String specifying the path to identify the forms radioButton. For example, //forms:radioButton[(@name='EXPENDITURES_TRANSACTION_STATUS_REJECTED_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms radioButton object specified by its recorded ID and path.
String radioLabel=forms.radioButton(24,"//forms:radioButton[" + "(@name='JOBS_QF_WHICH_JOBS_MY_UNCOMPLETED_0')]") .getLabel(); boolean isSelected=forms.radioButton(24, "//forms:radioButton[" + "(@name='JOBS_QF_WHICH_JOBS_MY_UNCOMPLETED_0')]") .isSelected(); info("radio label:"+radioLabel+" selected:"+isSelected); if(isSelected)warn("select error!"); forms.radioButton(24, "//forms:radioButton[" + "(@name='JOBS_QF_WHICH_JOBS_MY_UNCOMPLETED_0')]") .select();
Format
The forms.responseBox method has the following command format(s):
forms.responseBox(path);
forms.responseBox(recid, path);
Command Parameters
a String specifying the path to identify the forms responseBox. For example, //forms:responseBox. Must not be null. Since it is only possible to show one responseBox in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the responseBox object.
Format
The forms.schedulingDataClient method has the following command format(s):
forms.schedulingDataClient(path);
forms.schedulingDataClient(recid, path);
Command Parameters
a String specifying the path to identify the forms schedulingDataClient. For example, //forms:schedulingDataClient[(@name='GANTT_GANTTBEAN_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms schedulingDataClient object specified by its recorded ID and path.
forms.schedulingDataClient(32, "//forms:schedulingDataClient[" + "(@name='GANTT_GANTTBEAN_0')]") .clickNext(); forms.schedulingDataClient(33, "//forms:schedulingDataClient[" + "(@name='GANTT_GANTTBEAN_0')]") .clickPrevious(); forms.schedulingDataClient(34, "//forms:schedulingDataClient[" + "(@name='GANTT_GANTTBEAN_0')]") .clickAssigneeCell(3, 1);
Format
The forms.spreadTable method has the following command format(s):
forms.spreadTable(path);
forms.spreadTable(recid, path);
Command Parameters
a String specifying the path to identify the forms spreadTable. For example, //forms:spreadTable[(@name='BLK_INBOX_INBOX_GRID_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms spreadTable object specified by its recorded ID and path.
forms.spreadTable(66, "//forms:spreadTable[" + "(@name='SR_TASK_GRID_GRID_ITEM_0')]") .selectRows(1, 1); forms.spreadTable(66, "//forms:spreadTable[" + "(@name='SR_TASK_GRID_GRID_ITEM_0')]") .focusCell(1, 1); String cellValue=forms.spreadTable(66, "//forms:spreadTable[" + "(@name='SR_TASK_GRID_GRID_ITEM_0')]") .getCell(1, 2); forms.spreadTable(66, "//forms:spreadTable[" + "(@name='SR_TASK_GRID_GRID_ITEM_0')]") .storeCell("testVar", 1, 2); if(!cellValue.equals("{{testVar}}"))warn("get cell value error"); //test column count and row count forms.spreadTable(66, "//forms:spreadTable[" + "(@name='SR_TASK_GRID_GRID_ITEM_0')]") .verifyAttributes("objectTest1", forms.attributes( forms.attribute("columnCount", "42", TestOperator.StringExact), forms.attribute("rowCount", "2", TestOperator.StringExact))); forms.spreadTable(66, "//forms:spreadTable[" + "(@name='SR_TASK_GRID_GRID_ITEM_0')]") .focusRow(1);
Format
The forms.statusBar method has the following command format(s):
forms.statusBar(path);
forms.statusBar(recid, path);
Command Parameters
a String specifying the path to identify the forms statusBar. For example, //forms:statusBar. Must not be null. Since it is only possible to show one statusBar in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the Status Bar object.
Format
The forms.tab method has the following command format(s):
forms.tab(path);
forms.tab(recid, path);
Command Parameters
a String specifying the path to identify the forms tab. For example, //forms:tab[(@name='ATTRIBUTE_GROUPS_REGIONS')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms tab object specified by its recorded ID and path.
forms.tab(485, "//forms:tab[" + "(@name='FLOWDOWN_TAB')]") .select("Terms & Conditions"); String selectedStr=forms.tab(485, "//forms:tab[" + "(@name='FLOWDOWN_TAB')]") .getSelectedTabLabel(); if(!selectedStr.equals("Terms & Conditions")) warn("getSelectedTabLabel() error"); boolean isItem=forms.tab(485, "//forms:tab[" + "(@name='FLOWDOWN_TAB')]") .isItemInList("Terms & Conditions"); if(!isItem) warn("isItemInList(string) error"); boolean isSelected=forms.tab(485, "//forms:tab[" + "(@name='FLOWDOWN_TAB')]") .isItemSelected("Terms & Conditions"); if(!isSelected) warn("isItemSelected(string) error");
Format
The forms.tableBox method has the following command format(s):
forms.tableBox(path);
forms.tableBox(recid, path);
Command Parameters
a String specifying the path to identify the forms tableBox. For example, //forms:tableBox. Must not be null. Since it is only possible to show one tableBox in Oracle Forms at runtime, it is not necessary to specify additional conditions in the path to locate the tableBox object.
Format
The forms.textField method has the following command format(s):
forms.textField(path);
forms.textField(recid, path);
Command Parameters
a String specifying the path to identify the forms textField. For example, //forms:textField[(@name='NAVIGATOR_TYPE_0')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms textField object specified by its recorded ID and path.
forms.textField(248, "//forms:textField[" + "(@name='STUB_APPLICATION_NAME_0')]") .setFocus(); forms.textField(249,"//forms:textField[" + "(@name='STUB_APPLICATION_NAME_0')]") .setText("abc"); forms.textField("//forms:textField[" + "(@name='STUB_APPLICATION_NAME_0')]") .verifyAttributes("test1",forms.attributes( forms.attribute("enabled", "true", TestOperator.StringExact), forms.attribute("text", "Sales", TestOperator.StringExact), forms.attribute("visible", "true", TestOperator.StringExact), forms.attribute("name", "STUB_APPLICATION_NAME_0", TestOperator.StringExact), forms.attribute("showing", "true", TestOperator.StringExact), forms.attribute("prompt", "Application", TestOperator.StringExact), forms.attribute("editable", "true", TestOperator.StringExact)));
Format
The forms.tree method has the following command format(s):
forms.tree(path);
forms.tree(recid, path);
Command Parameters
a String specifying the path to identify the forms tree. For example, //forms:tree[@accessibleName='Navigator']. Must not be null.
Throws
Example
Performs an action on an Oracle Forms tree object specified by its recorded ID and path.
forms.tree(24, "//forms:tree[(@name='APPTREE_NAV_TREE_NAVIGATOR_0')]") .selectNode("Personal Shortcuts"); forms.list(25, "//forms:list[(@name='APPTREE_VIEW_BY_VIEW_BY_0')]") .setFocus(); forms.tree(26, "//forms:tree[(@name='APPTREE_NAV_TREE_NAVIGATOR_0')]") .expandNode("People By Name"); forms.tree(27, "//forms:tree[(@name='APPTREE_NAV_TREE_NAVIGATOR_0')]") .selectNode("People By Name|A"); forms.tree(28, "//forms:tree[(@name='APPTREE_NAV_TREE_NAVIGATOR_0')]") .expandNode("People By Name|B"); forms.tree(29, "//forms:tree[(@name='APPTREE_NAV_TREE_NAVIGATOR_0')]") .collapseNode("People By Name|B");
Format
The forms.treeList method has the following command format(s):
forms.treeList(path);
forms.treeList(recid, path);
Command Parameters
a String specifying the path to identify the forms treeList. For example, //forms:treeList[(@name='NAVIGATOR_LIST_0')]. Must not be null.
Format
The forms.window method has the following command format(s):
forms.window(path);
forms.window(recid, path);
Command Parameters
a String specifying the path to identify the forms window. For example, //forms:window[(@name='NAVIGATOR')]. Must not be null.
Throws
Example
Performs an action on an Oracle Forms window object specified by its recorded ID and path.
forms.window(24, "//forms:window[(@name='STUB')]") .activate(true); forms.window(25, "//forms:window[(@name='STUB')]") .clickToolBarButton("Save"); forms.statusBar(26, "//forms:statusBar").assertText( "FormsFT AutoValidation: Verify StatusBar text value", "FRM-40401: No changes to save.", MatchOption.Exact); forms.window(27, "//forms:window[(@name='STUB')]") .selectMenu("File|Print..."); boolean isMenu=forms.window(27, "//forms:window[" + "(@name='STUB')]") .isMenuEnabled("File|Print..."); if(!isMenu)warn("isMenuEnabled(string) error"); forms.window(28, "//forms:window[(@name='STUB')]") .close();
