| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript HyperionLoadService Class of Hyperion Load Module Application Programming Interface (API).
The following section provides an alphabetical listing of the methods in the OpenScript HyperionLoadService API.
The following table lists the HyperionLoadService API methods in alphabetical order.
Table 7-1 List of HyperionLoadService Methods
| Method | Description |
Gets an implementation class of IEncoder, providing an encode method of replacing '\n' to '@'. |
Gets an implementation class of IEncoder, providing an encode method of replacing '\' plus '\n' to "\r\n". |
Gets an implementation class of IEncoder, providing an encode method of replacing '\' plus '\n' to '\n'. |
Gets an implementation class of IEncoder, providing an encode method of replacing '\n' to "\r\n*". |
Gets an implementation class of IEncoder, providing an encode method of replacing '\n' to '*'. |
The following sections provide detailed reference information for each method and enum in the HyperionLoadService Class of Hyperion Load Module Application Programming Interface.
Gets an implementation class of IEncoder, providing an encode method of replacing 'n' to '@'. Will be used to provide custom encode options.
Format
The hyperion.getAtSignEncoder method has the following command format(s):
hyperion.getAtSignEncoder( );
Returns
an implementation class of IEncoder, providing an encode method of replacing newlines to '@'.
Example
Performs an encode action replacing replacing newlines to '@'.
String str_withnewline = "test\nclassofIEcoder";
String str_line = "test\\nclassofIEcoder";
String str_getAtSign = hyperion.getAtSignEncoder().encode(str_withnewline);
String str_getAtSign1 = hyperion.getAtSignEncoder().encode(str_line); *
if (str_getAtSign.equals("test@classofIEcoder"))
info("API getAtSignEncoder().encode() passed!");
else
warn("API getAtSignEncoder().encode() failed!");
if (str_getAtSign1.equals("test\\nclassofIEcoder"))
else
if (hyperion.getAtSignEncoder().getEncoderName().equals("getAtSignEncoder"))
info("API getAtSignEncoder().getEncoderName() passed!");
else
warn("API getAtSignEncoder().getEncoderName() failed!");
Gets an implementation class of IEncoder, providing an encode method of replacing '' plus 'n' to "rn". Will be used to provide custom encode options.
Format
The hyperion.getBNToCRLFEncoder method has the following command format(s):
hyperion.getBNToCRLFEncoder( );
Returns
Example
Performs an encode action replacing replacing '' plus 'n' to "rn".
String getBNToCRLF = hyperion.getBNToCRLFEncoder().encode(str_withnewline);
String getBNToCRLF1 = hyperion.getBNToCRLFEncoder().encode(str_line);
if (getBNToCRLF.equals("test\nclassofIEcoder"))
info("API getBNToCRLFEncoder().encode() passed!");
else
warn("API getBNToCRLFEncoder().encode() failed!");
if (getBNToCRLF1.equals("test\r\nclassofIEcoder"))
else
if (hyperion.getBNToCRLFEncoder().getEncoderName().equals("getBNToCRLFEncoder"))
info("API getBNToCRLFEncoder().getEncoderName() passed!");
else
warn("API getBNToCRLFEncoder().getEncoderName() failed!");
Gets an implementation class of IEncoder, providing an encode method of replacing '' plus 'n' to 'n'. Will be used to provide custom encode options.
Format
The hyperion.getBNToLFEncoder method has the following command format(s):
hyperion.getBNToLFEncoder( );
Returns
Example
Performs an encode action replacing replacing '' plus 'n' to 'n'.
String getBNToLF = hyperion.getBNToLFEncoder().encode(str_withnewline);
String getBNToLF1 = hyperion.getBNToLFEncoder().encode(str_line);
if (getBNToLF.equals("test\nclassofIEcoder"))
info("API getBNToLFEncoder().encode() passed!");
else
warn("API getBNToLFEncoder().encode() failed!");
if (getBNToLF1.equals("test\nclassofIEcoder"))
else
if (hyperion.getBNToLFEncoder().getEncoderName().equals("getBNToLFEncoder"))
info("API getBNToLFEncoder().getEncoderName() passed!");
else
warn("API getBNToLFEncoder().getEncoderName() failed!");
Gets an implementation class of IEncoder, providing an encode method of replacing 'n' to "rn*". Will be used to provide custom encode options.
Format
The hyperion.getCRLFSEncoder method has the following command format(s):
hyperion.getCRLFSEncoder( );
Returns
Example
Performs an encode action replacing replacing 'n' to "rn*".
String str_getCRLF = hyperion.getCRLFSEncoder().encode(str_withnewline);
String str_getCRLF1 = hyperion.getCRLFSEncoder().encode(str_line);
if (str_getCRLF.equals("test\r\n*classofIEcoder"))
info("API getCRLFSEncoder().encode() passed!");
else
warn("API getCRLFSEncoder().encode() failed!");
if (str_getCRLF1.equals("test\\nclassofIEcoder"))
else
if (hyperion.getCRLFSEncoder().getEncoderName().equals("getCRLFSEncoder"))
info("API getCRLFSEncoder().getEncoderName() passed!");
else
warn("API getCRLFSEncoder().getEncoderName() failed!");
Gets an implementation class of IEncoder, providing an encode method of replacing 'n' to '*'. Will be used to provide custom encode options.
Format
The hyperion.getStarEncoder method has the following command format(s):
hyperion.getStarEncoder( );
Returns
an implementation class of IEncoder, providing an encode method of replacing newlines to '*'.
Example
Performs an encode action replacing newlines to '*'
String str_getStar = hyperion.getStarEncoder().encode(str_withnewline);
String str_getStar1 = hyperion.getStarEncoder().encode(str_line);
if (str_getStar.equals("test*classofIEcoder"))
info("API getStarEncoder().encode() passed!");
else
warn("API getStarEncoder().encode() failed!");
if (str_getStar1.equals("test\\nclassofIEcoder"))
else
if (hyperion.getStarEncoder().getEncoderName().equals("getStarEncoder"))
info("API getStarEncoder().getEncoderName() passed!");
else
warn("API getStarEncoder().getEncoderName() failed!");
