| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript SiebelService Class of Siebel Load Module Application Programming Interface (API).
The following section provides an alphabetical listing of the methods in the OpenScript SiebelService API.
The following table lists the SiebelService API methods in alphabetical order.
Table 8-1 List of SiebelService Methods
| Method | Description |
Gets the Siebel Settings object. |
Parse a Siebel value from the most recent navigation's contents and store it as a variable. |
The following sections provide detailed reference information for each method and enum in the SiebelService Class of Siebel Load Module Application Programming Interface.
Example
Gets the Siebel Settings object and check validation enabled.
import oracle.oats.scripting.modules.siebel.api.SiebelSettings;
SiebelSettings settings = siebel.getSettings();
settings.setIsSiebelValidationEnabled(true);
boolean isvalidationEnabled = settings.getIsSiebelValidationEnabled();
info("isvalidationEnabled = " + isvalidationEnabled);
This method honors the "Solve Variable Failed" error recovery setting. If "Solve Variable Failed" error recovery is not set to fail, then the script will continue running even if a non-optional variable cannot be solved.
Format
The siebel.solve method has the following command format(s):
siebel.solve(varName, pattern, errorMsg, isOptional, sourceType);
Command Parameters
a String specifying the name of the variable to create. Must not be null.
a String specifying the Siebel pattern specifying what to extract from the most recent navigation's contents. May contain a transform expression. Must not be null.
a String specifying an optional error message to display if the pattern cannot be solved. If null, a meaningful error message is automatically generated.
a Boolean specifying true if the pattern does not have to be solved. If the pattern cannot be solved, the method quietly returns.
a Source enum specifying the part of the most recent navigation's contents (i.e. body or headers) against which to solve the pattern. If null, this method will assume Source.Html.
Throws
if any failure.
If the given pattern cannot be matched to the previous contents and the pattern is not optional.
Example
http.post(107,
"http://siebel005.example.com/callcenter_enu/start.swe",
null, http.postdata(http.param("SWEC", "{{@SWECInc(1)}}"),
http.param("SWERPC", "1"),
http.param("SWENeedContext", "false"),
http.param("SWEView", "Account List View"),
http.param("SWECmd", "GotoView"),
http.param("SWEKeepContext", "1")), null, true,
"UTF8", "UTF8");
siebel.solve(
"_Siebel_CORRLIB_FIELD_1294336896147__S_BC1_S17_R01_F01_#_3 scripts co",
"_Siebel_CORRLIB_FIELD__TEXT", null, false,
Source.Html);
siebel.solve(
"_Siebel_CORRLIB_FIELD_1294336896147__S_BC1_S17_R01_F04_#_Qualified",
Source.Html);
siebel.solve(
"_Siebel_CORRLIB_FIELD_1294336896147__S_BC1_S17_R01_F03_#_",
"_Siebel_CORRLIB_FIELD__PHONE", null, false,
Source.Html);
siebel.solve(
"_Siebel_CORRLIB_FIELD_1294336896147__S_BC1_S17_R01_F05_#_",
Source.Html);
siebel.solve(
"_Siebel_CORRLIB_FIELD_1294336896147__S_BC1_S17_R01_F02_#_abc",
Source.Html);
siebel.solve(
"_Siebel_CORRLIB_ROWID_1294336896147__S_BC1_S17_R01_FID_#_1-J8TZ",
"_Siebel_CORRLIB_ROWID", null, false,
Source.Html);
http.get(111,"http://siebel005.example.com/callcenter_enu/start.swe",
http.querystring(
http.param("SWECmd","GetViewLayout"),
http.param("SWEView","Account List View"),
http.param("SWEVI", ""),
http.param("SWEVLC",
"{{SWEVLC,0-1_Siebel+Universal+Agent_37%7c1119321220%7c0_0_19221_00_L}}")),
null, true, "UTF8", "UTF8");
