| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript Siebel Open UI Module Application Programming Interface (API).
The following section provides an alphabetical listing of the methods in the OpenScript Siebel OpenUI API.
The following table lists the Siebel Open UI API methods in alphabetical order.
Table 20-1 List of Siebel Open UI Methods
| Method | Description |
Identifies an Siebel Open UI Control by its recorded ID and path. |
The following sections provide detailed reference information for each method in the Open UI Class of Siebel open UI Module Application Programming Interface.
Format
The openui.syncPagemethod has the following command format(s):
openui.syncPage(windowPath);
openui.syncPage(recId, windowPath);
openui.syncPage(recId, windowPath, timeoutMillis);
openui.syncPage(recId, windowPath, timeoutMillis, delayMillisBeforeSync, durationMillisBetweenEachCheck, matchCount);
Command Parameters
a String specifying the object path.
the ID of a previously recorded navigation, used for comparison purposes.
a Long specifying the timeout in milliseconds.
a Long specifying the delay in milliseconds before sync.
a Long specifying the duration in milliseconds between each check.
an Int specifying the match count.
