| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript SiebelFTService Class of Siebel Functional Module Application Programming Interface (API).
The Siebel Functional Test Module provides support for functional testing of Siebel web applications that use Standard Siebel High Interactivity (HI) and Standard Interactivity (SI) components. If the Siebel application uses the Siebel OpenUI, use the OpenScript Web Functional Testing module to record Siebel OpenUI scripts and use the OpenScript Siebel OpenUI function library to customize scripts. See Chapter 21, "Siebel OpenUI Function Library" for information about the function library.
The following section provides an alphabetical listing of the methods in the OpenScript SiebelFTService API.
The following table lists the SiebelFTService API methods in alphabetical order.
Table 19-1 List of SiebelFTService Methods
| Method | Description |
Creates a Siebel Applet element. |
Creates a Siebel Application element. |
Construct property data of a single attribute. |
Utility function to return a list of property tests. |
Creates a Siebel Button element. |
Creates a Siebel Calculator element. |
Creates a Siebel Calendar element. |
Construct a test data of a table cell. |
Utility function to return a list of cell tests. |
Creates a Siebel Currency element. |
Creates a generic Siebel element. |
Checks for the existence of a Siebel control. |
Creates a Siebel List element. |
Creates a Siebel Menu element. |
Creates a Siebel PageTabs element. |
Creates a Siebel PDQ element. |
Creates a Siebel RichText element. |
Creates a Siebel Screen element. |
Creates a Siebel ScreenViews element. |
Creates a Siebel Text element. |
Creates a Siebel TextArea element. |
Creates a Siebel Threadbar element. |
Creates a Siebel Toolbar element. |
Creates a Siebel Tree element. |
The following sections provide detailed reference information for each method and enum in the SiebelFTService Class of Siebel Functional Module Application Programming Interface.
Format
The siebelFT.applet method has the following command format(s):
siebelFT.applet(path);
siebelFT.applet(recid, path);
Command Parameters
a String specifying the path of the element.
the ID of a previously recorded navigation, used for comparison purposes. May be null.
Example
Performs an action on a Siebel Applet element.
String SiebApplet="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Siebel Universal Agent']" +
"/siebelft:cas[@ClassName='SiebScreen' " +
"and @RepositoryName='Opportunities Screen']" +
"/siebelft:cas[@ClassName='SiebView' " +
"and @RepositoryName='Opportunity List View']" +
"/siebelft:cas[@ClassName='SiebApplet' " +
"and @RepositoryName='Opportunity Form Applet - Child']";
try{
String result=siebelFT.applet(10, SiebApplet)
.childPathFromRepositoryName("SiebTextArea", "Description");
String expected="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Opportunity Form Applet - Child']" +
"/siebelft:cas[@ClassName='SiebTextArea' " +
"and @RepositoryName='Description']";
if (!result.equals(expected)) {
warn("childPathFromRepositoryName returned " + result);
}catch(Exception exp) {}
Format
The siebelFT.application method has the following command format(s):
siebelFT.application(path);
siebelFT.application(recid, path);
Command Parameters
Example
Performs an action on a Siebel Application element.
String SiebApplication="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Siebel Universal Agent']";
try{
"and @RepositoryName='Web Call Center Home Screen']";
String result=siebelFT.application(10, SiebApplication)
.childPathFromRepositoryName("SiebScreen", "Web Call Center Home Screen");
Format
The siebelFT.attribute method has the following command format(s):
siebelFT.attribute(property, expectedValue, operator);
Command Parameters
A String specifying the property to test.
a String specifying ther expected value.
a TestOperator that defines the type and the match approach of the data.
Example
Specifies individual Siebel element attributes.
String path="/siebelft:cas[@ClassName='SiebApplication' " +
"/siebelft:cas[@ClassName='SiebMenu' " +
"and @RepositoryName='SiebMenu']";
siebelFT.menu(path).assertAttributes("attributes",
siebelFT.attributes(siebelFT.attribute("ClassName",
"SiebMenu", TestOperator.StringExact),
siebelFT..attribute("RepositoryName", "SiebMenu",
siebelFT..attribute("UIName", "Menu",
siebelFT..attribute("Count", "60",
TestOperator.StringExact)));
siebelFT.menu(path).assertAttribute("attribute", "UIName", "Menu",
TestOperator.StringExact);
try{
boolean result=siebelFT.element(path).exists();
if (!result) {
warn("exists returned " + result);
Format
The siebelFT.attributes method has the following command format(s):
siebelFT.attributes(tests);
Example
Specifies a set of Siebel element attributes.
siebelFT.attribute("RepositoryName", "SiebMenu",
siebelFT.attribute("UIName", "Menu",
siebelFT.attribute("Count", "60",
try{
if (!result) {
Format
The siebelFT.button method has the following command format(s):
siebelFT.button(path);
siebelFT.button(recid, path);
Command Parameters
Example
Performs an action on a Siebel Button element.
String SiebButton="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Accounts Screen']" +
"and @RepositoryName='Account List View']" +
"and @RepositoryName='Account Entry Applet']" +
"/siebelft:cas[@ClassName='SiebButton' " +
"and @RepositoryName='NewRecord']";
try{
Boolean result=siebelFT.button(10, SiebButton).isEnabled();
if (!result) {
warn("isEnabled() returned " + result);
siebelFT.button(15, "/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='DeleteRecord']")
.click();
Format
The siebelFT.calculator method has the following command format(s):
siebelFT.calculator(path);
siebelFT.calculator(recid, path);
Command Parameters
Example
Performs an action on a Siebel Calculator element.
String SiebCurrency="/siebelft:cas[@ClassName='SiebApplication' " +
"/siebelft:cas[@ClassName='SiebCurrency' " +
"and @RepositoryName='Revenue']";
String SiebCalculator="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Revenue']" +
"/siebelft:cas[@ClassName='SiebCalculator' " +
"and @RepositoryName='Amount']";
siebelFT.currency(SiebCurrency).openPopup();
siebelFT.calculator(10, SiebCalculator).openPopup();
siebelFT.calculator(12, SiebCalculator).clickKey("9");
siebelFT.calculator(14, SiebCalculator).clickKeys("99");
siebelFT.calculator(16, SiebCalculator).processKey("EnterKey");
siebelFT.calculator(18, SiebCalculator).processKey("EnterKey");
try{
String result=siebelFT.calculator(20, SiebCalculator).getText();
if (!result.equals("$999.00")) {
warn("getText returned " + result);
try{
Boolean result=siebelFT.calculator(22, SiebCalculator).isEnabled();
if (!result) {
warn("isEnabled returned " + result);
try{
Boolean result=siebelFT.calculator(24, SiebCalculator).isOpen();
if (result) {
warn("isOpen returned " + result);
siebelFT.currency(SiebCurrency).closePopup();
Format
The siebelFT.calendar method has the following command format(s):
siebelFT.calendar(path);
siebelFT.calendar(recid, path);
Command Parameters
Example
Performs an action on a Siebel Calendar element.
String SiebCalendar="/siebelft:cas[@ClassName='SiebApplication' " +
"/siebelft:cas[@ClassName='SiebCalendar' " +
"and @RepositoryName='CloseDate']";
siebelFT.calendar(SiebCalendar).openPopup();
try{
String result=siebelFT.calendar(SiebCalendar)
.getCalendarType();
if (!result.equals("Date")) {
warn("getCalendarType returned " + result);
try{
String result=siebelFT.calendar(10, SiebCalendar)
.getDay();
if (!result.equals("27")) {
info("getDay returned " + result);
try{
String result=siebelFT.calendar(12, SiebCalendar)
.getMonth();
if (!result.equals("8")) {
info("getMonth returned " + result);
try{
String result=siebelFT.calendar(14, SiebCalendar)
.getYear();
if (!result.equals("2010")) {
info("getYear returned " + result);
try{
String result="none"+siebelFT.calendar(16, SiebCalendar)
.getTime();
if (!result.equals("none")) {
warn("getTime returned " + result);
Format
The siebelFT.cell method has the following command format(s):
siebelFT.cell(row, column, expectedValue, operator);
Command Parameters
the row value starting from 1.
the column value starting from 1.
a String specifying the expected value.
Example
Specifies individual Siebel cell elements.
String SiebThreadbar1="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Activities Screen']" +
"/siebelft:cas[@ClassName='SiebThreadbar' " +
"and @RepositoryName='SiebThreadbar']";
siebelFT.threadbar(SiebThreadbar).assertCells("assert",
siebelFT.cells(
siebelFT.cell(1, 1,"Opportunity Detail - Activities View0",
siebelFT.threadbar(SiebThreadbar).verifyCells("verify",
siebelFT.cells(
try{
String result=siebelFT.threadbar(SiebThreadbar)
.getActiveThreadItem();
if (!result.equals("Opportunity Detail - Activities View0")) {
warn("getActiveThreadItem returned " + result);
Example
Specifies set of Siebel cell elements.
siebelFT.cells(
siebelFT.cells(
try{
Format
The siebelFT.currency method has the following command format(s):
siebelFT.currency(path);
siebelFT.currency(recid, path);
Command Parameters
Example
Performs an action on a Siebel Currency element.
try{
String result=siebelFT.currency(5, SiebCurrency)
.getAmount();
if (!result.equals("$.00")) {
info("getAmount returned " + result);
try{
String result=siebelFT.currency(7, SiebCurrency)
.getText();
if (!result.equals("$0.00")) {
info("getText() returned " + result);
try{
Boolean result=siebelFT.currency(9, SiebCurrency).isEnabled();
if (!result) {
try{
Boolean result=siebelFT.currency(11, SiebCurrency).isOpen();
if (result) {
siebelFT.currency(14, SiebCurrency).setText("999");
siebelFT.currency(16, SiebCurrency).processKey("EnterKey");
siebelFT.currency(18, SiebCurrency).openPopup();
siebelFT.currency(20, SiebCurrency).cancelPopup();
Format
The siebelFT.element method has the following command format(s):
siebelFT.element(path);
siebelFT.element(recid, path);
Command Parameters
Example
Performs an action on a generic Siebel element.
web.window(1376,"/web:window[@index='0' " +
"or @title='about:blank']")
.navigate("http://example.com/callcenter_enu/start.swe?SWECmd=AutoOn");
web.textBox(1378,"/web:window[@index='0' " +
"or @title='Siebel Call Center']" +
"/web:document[@index='0']" +
"/web:form[@name='SWEEntryForm' or @index='0']" +
"/web:input_text[@rn='_SweUserName' " +
"and @ot='SiebWebText' and @un='_SweUserName']")
.setText("sadmin");
think(0.156);
web.textBox(1379,"/web:window[@index='0' " +
.pressTab();
think(0.031);
web.textBox(1380,"/web:window[@index='0' " +
"/web:input_password[@rn='_SwePassword' " +
"and @ot='SiebWebPassword' and @un='_SwePassword']")
.setPassword(decrypt("OvCQi9wcp7lT2jehewJtOQ=="));
think(1.232);
web.image(1381,"/web:window[@index='0' " +
"/web:img[@alt='Login' or @index='3' " +
"or @src='http://example.com/callcenter_enu/images/login77_d.gif']")
.click();
siebelFT.menu(path).assertAttributes("attributes",siebelFT.attributes(
siebelFT.attribute("ClassName","SiebMenu",
try{
boolean result=siebelFT.element(10, path).exists();
if (!result) {
try{
String result=siebelFT.element(12, path).getAttribute("RepositoryName");
if (!result.equals("SiebMenu")) {
warn("getClassName returned " + result);
try{
String result=siebelFT.element(14, path).getRepositoryName();
warn("getRepositoryName returned " + result);
try{
siebelFT.element(16, path).storeAttribute("var", "Count");
if (!eval("{{var}}").equals("60")) {
warn("Count returned " + eval("{{var}}"));
siebelFT.element(18, path).waitForAttribute("Count", "60", 10);
Throws
represents an exception that may be thrown during the execution of a script where the exception should be reported to an end user through the controller.
Example
Checks if the specified Siebel element exists.
try{
if(siebelFT.exists("/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='SiebThreadbar']")) {
info("element exists");
Format
The siebelFT.list method has the following command format(s):
siebelFT.list(path);
siebelFT.list(recid, path);
Command Parameters
Example
Performs an action on a Siebel List element.
String pdq="/siebelft:cas[@ClassName='SiebApplication' " +
"/siebelft:cas[@ClassName='SiebPDQ' " +
"and @RepositoryName='SiebPDQ']";
siebelFT.pdq(pdq).select("** All Opportunities");
think(11.13);
siebelFT.list(72,"/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Opportunity List Applet']" +
"/siebelft:cas[@ClassName='SiebList' " +
"and @RepositoryName='SiebList']")
.activateRow(1);
think(0.031);
siebelFT.list(73,"/siebelft:cas[@ClassName='SiebApplication' " +
.drillDownColumn("Name", 1);
Format
The siebelFT.menu method has the following command format(s):
siebelFT.menu(path);
siebelFT.menu(recid, path);
Format
The siebelFT.pageTabs method has the following command format(s):
siebelFT.pageTabs(path);
siebelFT.pageTabs(recid, path);
Format
The siebelFT.pdq method has the following command format(s):
siebelFT.pdq(path);
siebelFT.pdq(recid, path);
Command Parameters
Example
Performs an action on a Siebel PDQ element.
siebelFT.pdq(10, pdq).select("** All Opportunities");
think(11.13);
.activateRow(1);
think(0.031);
Format
The siebelFT.richText method has the following command format(s):
siebelFT.richText(path);
siebelFT.richText(recid, path);
Command Parameters
Example
Performs an action on a Siebel RichText element.
String SiebRichText="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Projects Screen (ePS)']" +
"and @RepositoryName='Project Private Note View']" +
"and @RepositoryName='Project Private Note Form Applet']" +
"/siebelft:cas[@ClassName='SiebRichText' " +
"and @RepositoryName='Note']";
siebelFT.button(249,"/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='NewRecord']")
.click();
think(6.812);
siebelFT.richText(5, SiebRichText).setText("zopa");
try{
String result=siebelFT.richText(7, SiebRichText).getText();
if (!result.equals("zopa")) {
try{
Boolean result=siebelFT.richText(9, SiebRichText).isEnabled();
if (!result) {
try{
Boolean result=siebelFT.richText(11, SiebRichText).isRequired();
if (result) {
warn("isRequired returned " + result);
Format
The siebelFT.screen method has the following command format(s):
siebelFT.screen(path);
siebelFT.screen(recid, path);
Command Parameters
Example
Performs an action on a Siebel Screen element.
String SiebScreen="/siebelft:cas[@ClassName='SiebApplication' " +
"and @RepositoryName='Accounts Screen']";
try{
String result=siebelFT.screen(3, SiebScreen)
.childPathFromRepositoryName("SiebPDQ", "SiebPDQ");
try{
Integer result=siebelFT.screen(5, SiebScreen)
.getClassCount("SiebPDQ");
if (result<1) {
warn("getClassCountreturned " + result);
try{
String result=siebelFT.screen(7, SiebScreen)
.getRepositoryNameByIndex("SiebPDQ", 0);
if (!result.equals("SiebPDQ")) {
warn("getRepositoryNameByIndex returned " + result);
}catch(Exception exp) {} *
Format
The siebelFT.screenViews method has the following command format(s):
siebelFT.screenViews(path);
siebelFT.screenViews(recid, path);
Command Parameters
Example
Performs an action on a Siebel ScreenViews element.
String SiebScreenView="/siebelft:cas[@ClassName='SiebApplication' " + "and @RepositoryName='Siebel Universal Agent']" + "/siebelft:cas[@ClassName='SiebScreen' " + "and @RepositoryName='Activities Screen']" + "/siebelft:cas[@ClassName='SiebScreenViews' " + "and @RepositoryName='SiebScreenViews']"; siebelFT.screenViews(5, SiebScreenView).assertCells("screenView assert", siebelFT.cells(siebelFT.cell(2, 1, "Attachments", TestOperator.StringExact))); siebelFT.screenViews(6, SiebScreenView).verifyCells("screenView verify", siebelFT.cells(siebelFT.cell(2, 1, "Attachments", TestOperator.StringExact))); try{ String result=siebelFT.screenViews(7, SiebScreenView) .getActiveView(); if (!result.equals("Activity Attachment View")) { warn("getActiveView returned " + result); } }catch(Exception exp) {} try{ String result=siebelFT.screenViews(8, SiebScreenView) .getCell(1, 1); if (!result.equals("More Info")) { warn("getCell returned " + result); } }catch(Exception exp) {} try{ Integer result=siebelFT.screenViews(9, SiebScreenView) .getL2Count(); if (result <0) { warn("getL2Count returned " + result); } }catch(Exception exp) {} try{ Integer result=siebelFT.screenViews(10, SiebScreenView) .getL3Count(); if (result <1) { warn("getL3Count returned " + result); } }catch(Exception exp) {} try{ Integer result=siebelFT.screenViews(11, SiebScreenView) ;.getL4Count(); if (result <0) { warn("getL4Count returned " + result); } }catch(Exception exp) {} try{ String result=siebelFT.screenViews(12, SiebScreenView) .getUIName("Activity Detail View", "L3"); if (!result.equals("More Info")) { warn("getUIName returned " + result); } }catch(Exception exp) {}
Format
The siebelFT.text method has the following command format(s):
siebelFT.text(path);
siebelFT.text(recid, path);
Command Parameters
Example
Performs an action on a Siebel Text element.
String SiebText="/siebelft:cas[@ClassName='SiebApplication' " + "and @RepositoryName='Siebel Universal Agent']" + "/siebelft:cas[@ClassName='SiebScreen' " + "and @RepositoryName='Accounts Screen']" + "/siebelft:cas[@ClassName='SiebView' " + "and @RepositoryName='Account List View']" + "/siebelft:cas[@ClassName='SiebApplet' " + "and @RepositoryName='Account Entry Applet']" + "/siebelft:cas[@ClassName='SiebText' " + "and @RepositoryName='Location']"; siebelFT.text(SiebText).setText("zopa"); siebelFT.text(SiebText).getPopupType(); try{ String result=siebelFT.text(5, SiebText).getText(); if (!result.equals("zopa")) { warn("getText returned " + result); } }catch(Exception exp) {} try{ Boolean result=siebelFT.text(6, SiebText).isEnabled(); if (!result) { warn("isEnabled returned " + result); } }catch(Exception exp) {} try{ Boolean result=siebelFT.text(7, SiebText).isEncrypted(); if (result) { warn("isEncrypted() returned " + result); } }catch(Exception exp) {} siebelFT.text(8, SiebText).openPopup(); siebelFT.text(9, SiebText).setPassword("abc"); siebelFT.text(10, SiebText).processKey("EnterKey");
Format
The siebelFT.textArea method has the following command format(s):
siebelFT.textArea(path);
siebelFT.textArea(recid, path);
Command Parameters
Example
Performs an action on a Siebel TextArea element.
String SiebTextArea="/siebelft:cas[@ClassName='SiebApplication' " + "and @RepositoryName='Siebel Universal Agent']" + "/siebelft:cas[@ClassName='SiebScreen' " + "and @RepositoryName='Opportunities Screen']" + "/siebelft:cas[@ClassName='SiebView' " + "and @RepositoryName='Opportunity List View']" + "/siebelft:cas[@ClassName='SiebApplet' " + "and @RepositoryName='Opportunity Form Applet - Child']" + "/siebelft:cas[@ClassName='SiebTextArea' " + "and @RepositoryName='Description']"; siebelFT.textArea(5, SiebTextArea).setText("zopa"); try{ String result=siebelFT.textArea(6, SiebTextArea) .getText(); if (!result.equals("zopa")) { warn("getText returned " + result); } }catch(Exception exp) {} try{ Boolean result=siebelFT.textArea(7, SiebTextArea) .isEnabled(); if (!result) { warn("isEnabled returned " + result); } }catch(Exception exp) {}
Format
The siebelFT.threadbar method has the following command format(s):
siebelFT.threadbar(path);
siebelFT.threadbar(recid, path);
Command Parameters
Example
Performs an action on a Siebel Threadbar element.
String SiebThreadbar="/siebelft:cas[@ClassName='SiebApplication' " + "and @RepositoryName='Siebel Universal Agent']" + "/siebelft:cas[@ClassName='SiebScreen' " + "and @RepositoryName='Activities Screen']" + "/siebelft:cas[@ClassName='SiebThreadbar' " + "and @RepositoryName='SiebThreadbar']"; siebelFT.threadbar(2, SiebThreadbar).assertCells("assert", siebelFT.cells(siebelFT.cell(1, 1,"Opportunity Detail - Activities View0", TestOperator.StringExact))); siebelFT.threadbar(4, SiebThreadbar).verifyCells("verify", siebelFT.cells(siebelFT.cell(1, 1,"Opportunity Detail - Activities View0", TestOperator.StringExact))); try{ String result=siebelFT.threadbar(5, SiebThreadbar) .getActiveThreadItem(); if (!result.equals("Opportunity Detail - Activities View0")) { warn("getActiveThreadItem returned " + result); } }catch(Exception exp) {} try{ String result=siebelFT.threadbar(6, SiebThreadbar) .getCell(1, 1); if (!result.equals("Opportunity Detail - Activities View0")) { warn("getCell returned " + result); } }catch(Exception exp) {} try{ Integer result=siebelFT.threadbar(7, SiebThreadbar) .getCount(); if (result <1) { warn("getCount returned " + result); } }catch(Exception exp) {} try{ String result=siebelFT.threadbar(8, SiebThreadbar) .getThreadItemByIndex(0); if (!result.equals("Opportunity Detail - Activities View0")) { warn("getThreadItemByIndex returned " + result); } }catch(Exception exp) {} try{ String result=siebelFT.threadbar(9, SiebThreadbar) .getThreadItems(); if (!result.equals("Opportunity Detail - Activities View0")) { warn("getThreadItems returned " + result); } }catch(Exception exp) {} try{ Boolean result=siebelFT.threadbar(10, SiebThreadbar) .isExists("Opportunity Detail - Activities View0"); if (!result) { warn("isExists returned " + result); } }catch(Exception exp) {} siebelFT.threadbar(11, SiebThreadbar).storeCell("var", 1, 1); if (!eval("{{var}}").equals("Opportunity Detail - Activities View0")){ warn("storeCell returned " + eval("{{var}}")); }
Format
The siebelFT.toolbar method has the following command format(s):
siebelFT.toolbar(path);
siebelFT.toolbar(recid, path);
Format
The siebelFT.tree method has the following command format(s):
siebelFT.tree(path);
siebelFT.tree(recid, path);
Command Parameters
Example
Performs an action on a Siebel Tree element.
String SiebTree="/siebelft:cas[@ClassName='SiebApplication' " + "and @RepositoryName='Siebel Universal Agent']" + "/siebelft:cas[@ClassName='SiebScreen' " + "and @RepositoryName='Opportunities Screen']" + "/siebelft:cas[@ClassName='SiebView' " + "and @RepositoryName='Opportunity Explorer View']" + "/siebelft:cas[@ClassName='SiebApplet' " + "and @RepositoryName='Opportunity Tree Applet']" + "/siebelft:cas[@ClassName='SiebTree' " + "and @RepositoryName='SiebTree']"; siebelFT.tree(4, SiebTree).expand("1"); siebelFT.tree(5, SiebTree).select("1.2"); try{ String result=siebelFT.tree(6, SiebTree) .getActiveTreeItem(); if ((result.length()<1)) { warn("getActiveTreeItem returned " + result); } }catch(Exception exp) {} try{ String result=siebelFT.tree(7, SiebTree) .getTreeItemName("1.2"); if (result.length()<1) { warn("getTreeItemName returned " + result); } }catch(Exception exp) {} try{ Integer result=siebelFT.tree(8, SiebTree) .getChildCount("1"); if (result <1) { warn("getChildCount returned " + result); } }catch(Exception exp) {} try{ Boolean result=siebelFT.tree(9, SiebTree) .isExpanded("1"); if (!result) { warn("isExpanded returned " + result); } }catch(Exception exp) {} siebelFT.tree(10, SiebTree).nextPage(); siebelFT.tree(11, SiebTree).previousPage(); siebelFT.tree(12, SiebTree).collapse("1");
