| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript UtilitiesService Class of Utilitis Module Application Programming Interface (API).
The following section provides an alphabetical listing of the methods in the OpenScript UtilitiesService API.
The following table lists the UtilitiesService API methods in alphabetical order.
Table 27-1 List of UtilitiesService Methods
| Method | Description |
Gets a file service instance for this Utilities service. |
Gets a SQL service instance for this Utilities service. |
Load the given comma-separated-value file as InputStream into a |
Load a specified XML file as InputStream into an XML tree. |
Load a specified XML contents into an XML tree. |
Convenience method to create a list of parameters for SQL a query. |
Parses the given JSON input using the default Configuration and returns a DocumentContext for path evaluation. |
Reads the given LSON path or creates a new JsonPath and applies it to the provided JSON string or JSON file. |
Saves a table to a CSV file format. |
The following sections provide detailed reference information for each method and enum in the UtilitiesService Class of Utilitis Module Application Programming Interface.
Gets a file service instance for this Utilities service. The FileService provides methods for working with the file system in general.
Format
The utilities.getFileService method has the following command format(s):
utilities.getFileService( );
Example
Creates a new file and appends the text strings to the file.
utilities.getFileService().createDestinationFile("myFile.txt", false); String line1 = "This is a new line 1"; String line2 = "This is a another new line 2"; String contents = "\n" + line1 + "\n" + line2; utilities.getFileService().appendStringToFile("myFile.txt", contents);
Gets a SQL service instance for this Utilities service. SQLService provides methods for working with SQL databases.
Format
The utilities.getSQLService method has the following command format(s):
utilities.getSQLService( );
Example
Create a database connection, execute SQL statements and query database, then disconnect the database connecton.
//define database utilities.getSQLService().define("myOracleDB", "oracle.jdbc.driver.OracleDriver", "jdbc:oracle:thin:@mySystem:1521:mySystem", "username", decrypt("ZSL2IzF3WpLh8ydBZYDV3Q==")); //connect to database utilities.getSQLService().connect("myOracleDB"); //execute SQL statement String query = "Create table Employee (ID number(4) not null unique, " + "FirstName varchar2(40) not null, LastName varchar2(40) not null, " + "Country varchar2(40), HireDate date)"; info("Query: " + query); utilities.getSQLService().execute("myOracleDB", query); //execute update SQL statement query = "Insert into Employee (ID, FirstName, LastName, Country, HireDate) " + "Values (101, 'Tom', 'Smith', 'USA', '01-JAN-95')"; utilities.getSQLService().executeUpdate("myOracleDB", query); //query SQL statement query = "Select * from Employee"; Table table = utilities.getSQLService().query("myOracleDB", query); //print table for (int i=0; i<table.getRowCount(); i++) { Row row = table.getRow(i); String [] rowValue = row.getAll(); String rowContent = ""; for (int col=0; col<rowValue.length; col++) rowContent += rowValue[col] + " "; info(rowContent); } //disconnect from database utilities.getSQLService().disconnect("myOracleDB");
Load the given comma-separated-value file as InputStream into a Table object.
Format
The utilities.loadCSV method has the following command format(s):
utilities.loadCSV(filePath);
utilities.loadCSV(url);
utilities.loadCSV(fileInput);
utilities.loadCSV(repository, pathRelToRepository);
Command Parameters
a File object specifying the file containing CSV-formatted data.
a String specifying the name of repository containing CSV-formatted data file. May contain {{ }} syntax for transforming.
String specifying the path to the CSV-formatted data file within the named repository. May contain {{ }} syntax for transforming. Must not be null. Any leading file separator on the path, such as / or \, is ignored.
a URL object specifying the path to the CSV file.
a FileInputStream.
Throws
represents an exception that may be thrown during the execution of a script where the exception should be reported to an end user through the controller.
on any exception while loading and reading the CSV file.
Example
Loads a CSV file into a Table object and prints the contents to the Results view.
String filePath = "c:\\fmstocks_data.csv";
InputStream in = null;
in = new FileInputStream(new File(filePath));
Table table = utilities.loadCSV(in);
//Print the CSV file
String columns = "";
int columnNumber = table.getColumns().getColumnCount();
String [] columnNames = table.getColumns().getColumnNames();
for (int index=0; index<columnNumber; index++)
columns += columnNames[index] + " ";
info(columns);
List <Row> rows = table.getRows();
for (int index=0; index<rows.size(); index++) {
String [] rowValue = rows.get(index).getAll();
for (int columnIndex=0; columnIndex<rowValue.length; columnIndex++)
rowContent += rowValue[columnIndex] + " ";
info(rowContent);
Format
The utilities.loadXML method has the following command format(s):
utilities.loadXML(filePath);
utilities.loadXML(url);
utilities.loadXML(fileInput);
utilities.loadXML(repository, pathRelToRepository);
Command Parameters
a String specifying the file path to be loaded. May contain {{ }} syntax for transforming.
a String specifying the name of repository containing XML file to load. May contain {{ }} syntax for transforming.
String specifying the path to the XML file within the named repository. May contain {{ }} syntax for transforming. Must not be null.Any leading file separator on the path, such as / or \, is ignored.
a URL object specifying the URL.
a FileInputStream.
Throws
if the file is not found.
if an error occurs loading the XML.
Example
Loads an XML file into a XML object and prints the contents to the Results view.
import java.io.File;
import java.io.FileInputStream;
import java.io.InputStream;
//load XML file by InputStream
String filePath = "c:\\myxmlfile.xml";
XML xml = utilities.loadXML(in);
info(xml.toString());
info("*** getChildren() ***");
XML [] children = xml.getChildren();
String lsChild = "";
for (int i=0; i<children.length; i++) {
if (i != 0)
lsChild += ", ";
lsChild += children[i].getTagName() + " ";
if (lsChild.equals(""))
info("No child present of xml element " + xml.getTagName());
else
info("List of all child elements of xml element " +
xml.getTagName() + ": " + lsChild);
XML child = children[i];
// print tag name
String tagName = child.getTagName();
info("Tag Name: " + tagName);
//print attributes
String [] allAttr = child.getAttributeNames();
if (allAttr != null) {
for (int j=0; j<allAttr.length; j++) {
info("Attribute Name: " + allAttr[j]);
info("Attribute Value: " + child.getAttribute(allAttr[j]));
else
info("No attribute");
// print values
if (child.getValue() != null) {
info("Value: " + child.getValue());
// print parent
info("Parent: \n" + child.getParent());
Format
The utilities.loadXMLContent method has the following command format(s):
utilities.loadXMLContent(contents);
Command Parameters
The XML contents to be loaded.May contain {{ }} syntax for transforming.
Throws
Example
Loads an XML string into an XML object and prints the contents to the Results view.
//load XML file by file name string.
String contents = "<GroceryStore><StoreName>Fourth Coffee</StoreName>" +
"<Departments><Department Name=\"Breads\">" +
"<Item ID=\"B2\" Type=\"Muffin\"><Name>Blueberry Muffin</Name>" +
"<Price>3.99</Price><New/></Item>" +
"</Department></Departments></GroceryStore>";
XML xml = utilities.loadXMLContent(contents);
Format
The utilities.parameters method has the following command format(s):
utilities.parameters(obj, param);
Command Parameters
a List<Object> of parameters for SQL a query.
Optional list of parameters for the SQL query List<Object>.
Example
Creates a database connection, execute SQL statements and query database with parameters object, then disconnect the database connecton.
//define database
query = "Update Employee SET LastName = 'Davis'
WHERE ID = ? and LastName = ?";
utilities.getSQLService().executeUpdate("myOracleDB", query,
utilities.parameters(101, "Smith"));
//print table
info(rowContent);
Format
The utilities.parseJSON method has the following command format(s):
utilities.parseJSON(json);
Example
//File input DocumentContext doc = utilities.parseJSON(new File (filePath)); List<Double> priceList = doc.read("$.store.book[?(@.price >10)].price"); System.out.println(priceList.toString()); //String Input List<Double> priceList2 = utilities.parseJSON(new File (filePath)).read("$.store.book[?(@.price >10)].price"); System.out.println(priceList2.toString());
Reads the given JsonPath or creates a new JsonPath and applies it to the provided JSON string or JSON file.
Format
The utilities.readJSONValue method has the following command format(s):
<T> T utilities.readJSONValue(json, path, <T> type );
<T> Tutilities.readJSONValue(json, jsonPath);
<T> T utilities.readJSONValue(jsonFile, jsonPath);
Command Parameters
the expected return type.
a JSON string.
the path to apply.
Returns
the result or list of objects matched by the given path. If it can not find the value according to given path, it will return null.
Example
Reads the given JSON path or creates a new JsonPath and applies it to the provided JSON string or JSON file.
//File input String filePath = "path of json file"; List<String> authors =utilities.readJSONValue(new File (filePath), "$.store.book[*].author"); System.out.println(authors.toString()); //String Input List<Double> booksName= utilities.readJSONValue(jsonString, "$.store.book[?(@.price >10)].price"); System.out.println(booksName.toString());
Format
The utilities.saveCSV method has the following command format(s):
utilities.saveCSV(table, csvFilename, overwrite);
utilities.saveCSV(table, repository, pathRelToRepository, overwrite);
Command Parameters
a Table object.
a String specifying the full path and name of a file where the Table is saved. May contain {{ }} syntax for transforming.
a Boolean that specifies whether or not to overwrite an existing file.
a String specifying the name of repository where the Table is to be saved. May contain {{ }} syntax for transforming. Must not be null.
String specifying the path to the file within the named repository.May contain {{ }} syntax for transforming. Must not be null. Any leading file separator on the path, such as / or \, is ignored.
Example
Saves a CSV Table object to a new file in overwrite mode
String repository = "Default";
String pathRelToRepository = "Data/fmstocks_data.csv";
String newCSVFile = "new_fmstocks_data.csv";
boolean overwrite = true;
Table table = utilities.loadCSV(repository, pathRelToRepository);
