| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript WSService Class of WebService Module Application Programming Interface (API).
The following section provides an alphabetical listing of the enums in the OpenScript WSService API.
The following section provides an alphabetical listing of the methods in the OpenScript WSService API.
The following table lists the WSService API methods in alphabetical order.
Table 28-2 List of WSService Methods
| Method | Description |
Add Security Attachment property settings to current URL. |
Convenience method to create a new Attachment. |
Convenience method to create a new Attachment[]. |
Gets the last browser response. |
Gets the last response code. |
Gets the last response contents. |
Request a web service using an HTTP POST method with requestSoap string, headers, URL encoding, and character sets. |
Performs a RESTful DELETE operation. |
Performs a RESTful GET operation. |
Performs a RESTful HEAD operation. |
Performs a RESTful OPTIONS operation. |
Performs a RESTful PATCH operation. |
Performs a RESTful POST operation. |
Performs a RESTful PUT operation. |
Convenience method to create a new WSSecurity object with a specified timeout value. |
Extract values from the browser's last retrieved contents using XPath notation. |
The following sections provide detailed reference information for each method and enum in the WSService Class of WebService Module Application Programming Interface.
Format
The ws.addSecurityAttachments method has the following command format(s):
ws.addSecurityAttachments(url, security, attachments);
Command Parameters
a String specifying the URL to request.
a WSSecurity object specifying the security settings for the specified URL.
a WSAttachments object specifying the attachment settings for the specified URL.
Throws
represents an exception that may be thrown during the execution of a script where the exception should be reported to an end user through the controller.
Example
Add Security Attachments with indicated property settings.
//No username token ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", null, null); //Username, Password Text ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", ws.security("username", decrypt("sO7ijipCONXoxAURd+8BQw=="), true, false, false), null); //Username, Password digest ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", ws.security("username", decrypt("sO7ijipCONXoxAURd+8BQw=="), false, false, false), null); //Username, Password text, Add Created Header ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", ws.security("username", decrypt("sO7ijipCONXoxAURd+8BQw=="), true, true, false), null); //Username, Password text, Add Timestamp, valid for 10 seconds ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", ws.security("username", decrypt("sO7ijipCONXoxAURd+8BQw=="), true, false, false, 10), null); //Username, Password text, Add Nonce ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", ws.security("username", decrypt("sO7ijipCONXoxAURd+8BQw=="), true, false, true), null); //Username, Password text, Add Created Header, //Add Timestamp, valid for 10 seconds, Add Nonce ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", ws.security("username", decrypt("sO7ijipCONXoxAURd+8BQw=="), true, true, true, 10), null); //Username, Password text, Add Created Header, //Add Timestamp, valid for 10 seconds, Add Nonce //With attachments ws.addSecurityAttachments("http://myserver/EmployeeLookup.asmx", ws.security("username", decrypt("sO7ijipCONXoxAURd+8BQw=="), true, true, true, 10), ws.attachments(AttachmentMechanism.DEFAULT, ws.attachment("C:\\MTOMService.xml", "attachmentPart"), ws.attachment("C:\\SecureService.xml","attachmentPart")));
Format
The ws.attachment method has the following command format(s):
ws.attachment(filename, attachmentPart);
Command Parameters
a String specifying the attachment file name.
a String specifying the Attachment part.
Example
Add Security with indicated attachments.
The AttachmentMechanism has the following values:
Table 28-3 List of AttachmentMechanism Values
| Value | Description |
DEFAULT |
Specifies the default transfer type specified by the Content-Type header. |
SWA |
Specifies Security SOAP Messages with Attachments. |
MTOM |
Specifies SOAP Message Transmission Optimization Mechanism. |
DIME |
Specifies Direct Internet Message Encapsulation. |
Format
The ws.attachments method has the following command format(s):
ws.attachments(am, attachments);
Command Parameters
an AttachmentMechanism enum specifying the attachment transfer type.
the Attachment objects.
Example
Format
The ws.getLastResponseContents method has the following command format(s):
ws.getLastResponseContents();
ws.getLastResponseContents(sourceType);
Format
The ws.post method has the following command format(s):
ws.post(recid, url, requestSoap, headers, bEncode, reqCharset, respCharset);
Command Parameters
ID of a previously recorded navigation, used for comparison purposes. May be null.
URL to request
A string representation of SOAP contents
a Header array specifying the Additional headers to add/remove from the request before submitting it to the server.
a boolean specifying the parameter encoding. Set to true to URL-encode the parameters before submitting them to the sever.
a String specifying the character set to use if URL-encoding any of the request parameters.
a String specifying the character set to use when reading the response contents.
Example
Specifies a POST navigation with requestSoap string, headers, URL encoding, and character sets.
//Example UI added Post ws.post(7, "http://myserver/EmployeeLookup.asmx", "requestSoap string", http.headers(http.header("name1", "value1", Header.HeaderAction.Add), http.header("name2", "value2", Header.HeaderAction.SetIfNotSet), http.header("name3", "value3", Header.HeaderAction.GlobalAdd), http.header("name4", "value4", Header.HeaderAction.GlobalSetIfNotSet)), true, "ASCII", "ASCII"); //Example WSDL Manager added Post with requestSoap string ws.post(8,"http://myserver/EmployeeLookup.asmx", "<soapenv:Envelope " + "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" " + "xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" " + "xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" " + "xmlns:web=\"http://example.com/webservices\">\r\n " + "<soapenv:Header/>\r\n " + "<soapenv:Body>\r\n " + "<web:addEmployee " + "soapenv:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\r\n " + "<data xsi:type=\"enc:Employee\" " + "xmlns:enc=\"http:/example.com/webservices/encodedTypes\">\r\n " + "<FirstName xsi:type=\"xsd:string\">string</FirstName>\r\n " + "<LastName xsi:type=\"xsd:string\">string</LastName>\r\n " + "<EmployeeID xsi:type=\"xsd:int\">0</EmployeeID>\r\n " + "<Address xsi:type=\"xsd:string\">string</Address>\r\n " + "<City xsi:type=\"xsd:string\">string</City>\r\n " + "<State xsi:type=\"xsd:string\">string</State>\r\n " + "<Zip xsi:type=\"xsd:string\">string</Zip>\r\n " + "<Phone xsi:type=\"xsd:int\">0</Phone>\r\n " + "</data>\r\n " + "</web:addEmployee>\r\n " + "</soapenv:Body>\r\n " + "</soapenv:Envelope>", http.headers(http.header("Content-Type","text/xml;charset=UTF-8", Header.HeaderAction.Modify), http.header("SOAPAction","\"http://example.com/webservices/addEmployee\"", Header.HeaderAction.Modify)), true, null, null);
Format
The ws.restDelete method has the following command format(s):
ws.restDelete(recid, url, deleteData, headers, bEncode, reqCharset, respCharset);
Command Parameters
a String specifying the URL for the request to the server.
a String specifying the data to DELETE.
a Header[] object specifying the header data.
a boolean specifying if the data is encoded.
Format
The ws.restGet method has the following command format(s):
ws.restGet(recid, url, headers, bEncode, reqCharset, respCharset);
Command Parameters
Format
The ws.restHead method has the following command format(s):
ws.restHead(recid, url, headers, bEncode, reqCharset, respCharset);
Command Parameters
Format
ws.restOptions(recid, url, optionsData, headers, bEncode, reqCharset, respCharset);
Command Parameters
a String specifying the OPTIONS data.
Format
The ws.restPatch method has the following command format(s):
ws.restPatch(recid, url, patchData, headers, bEncode, reqCharset, respCharset);
Command Parameters
a String specifying the data to PATCH to the URL's host.
Format
The ws.restPost method has the following command format(s):
ws.restPost(recid, url, postData, headers, bEncode, reqCharset, respCharset);
Command Parameters
a String specifying the data to POST to the URL's host.
Format
The ws.restPut method has the following command format(s):
ws.restPut(recid, url, putData, headers, bEncode, reqCharset, respCharset);
Command Parameters
a String specifying the data to PUT to the URL's host.
Format
The ws.security method has the following command format(s):
ws.security(username, securcode, plaintextSecurCode, addCreatedHeader, addNonce);
ws.security(username, securcode, plaintextSecurCode, addCreatedHeader, addNonce, timeToLive);
Command Parameters
a String specifying the username.
a String specifying the password.
a boolean specifying the password type. true for Password Text, false for Password Digest.
a boolean specifying if a created header is added.
a boolean specifying if Nonce is added.
a value specifying the timeout.
Example
Add Security with indicated property settings.
The value will be stored to the given variable.
Format
The ws.solveXpath method has the following command format(s):
ws.solveXpath(varName, xpath, resultIndex);
Command Parameters
a String specifying the variable name where the value will be stored. Must not be null.
a String specifying the XPath describing which value to parse from the last retrieved contents. Must not be null.
an index value specifying the 0-based index of the specific result to retrieve if the XPath returns multiple results. A null value specifies that all results should be returned.
Throws
if the XPath cannot be solved.
if happens error when parsing the xpath.
Example
Verifies the Xpath set to the script variable "solvedXPath" can vbe solved.
http.get(13, "http://example.com/stocks/", null,
null, true, "ASCII", "ASCII");
ws.solveXpath("solvedXPath", ".//FORM[@name='loginform']/@action", 0);
if (getVariables().get("solvedXPath").equals("default.asp"))
info ("method \"solveXpath()\" is passed.");
else
warn ("method \"solveXpath()\" is failed.");
