| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
FailoverType enumerated values are used to indicate the type of failover event that was raised.
Table 11-9 lists all the FailoverType enumeration values with a description of each enumerated value.
Table 11-9 FailoverType Enumeration Values
| Member Names | Description |
Indicates that the user has requested only session failover. |
Indicates that the user has requested select and session failover. |
Requirements
| Provider | ODP.NET, Unmanaged Driver |
| Assembly | Oracle.DataAccess.dll |
| Namespace | Oracle.DataAccess.Client |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 |
