Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleFailoverEventArgs Class
The OracleFailoverEventArgs class provides event data for the OracleConnection.Failover event. When database failover occurs, the OracleConnection.Failover event is triggered along with the OracleFailoverEventArgs object that stores the event data.
Class Inheritance
System.Object
  System.EventArgs
    Oracle.DataAccess.Client.OracleFailoverEventArgs
Declaration
// C#
public sealed class OracleFailoverEventArgs
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
Not supported in a .NET stored procedure
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example (Oracle.DataAccess.Client only)
// Transparent Application Failover (TAF) Setup
// Refer Oracle® Database Net Services Administrator's Guide
// C#
using System;
using System.Threading;
using Oracle.DataAccess.Client;
using Oracle.DataAccess.Types;
class FailoverSample
  static void Main(string[] args)
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    // Register the event handler OnFailover
    con.Failover += new OracleFailoverEventHandler(OnFailover);
    Console.WriteLine("Wait for a failover for 5 seconds");
    Thread.Sleep(5000);
    con.Close();
    con.Dispose();
  // TAF callback function
  static FailoverReturnCode OnFailover(object sender,
    OracleFailoverEventArgs eventArgs)
    switch (eventArgs.FailoverEvent)
      case FailoverEvent.Begin:
        Console.WriteLine("FailoverEvent.Begin - Failover is starting");
        Console.WriteLine("FailoverType = " + eventArgs.FailoverType);
        break;
      case FailoverEvent.End:
        Console.WriteLine("FailoverEvent.End - Failover was successful");
        break;
      case FailoverEvent.Reauth:
        Console.WriteLine("FailoverEvent.Reauth - User reauthenticated");
        break;
      case FailoverEvent.Error:
        Console.WriteLine("FailoverEvent.Error - Failover was unsuccessful");
        // Sleep for 3 sec and Retry
        Thread.Sleep(3000);
        return FailoverReturnCode.Retry;
      case FailoverEvent.Abort:
        Console.WriteLine("FailoverEvent.Abort - Failover was unsuccessful");
        break;
      default:
        Console.WriteLine("Invalid FailoverEvent : " + eventArgs.FailoverEvent);
        break;
    return FailoverReturnCode.Success;
OracleFailoverEventArgs Members
OracleFailoverEventArgs members are listed in the following tables.
OracleFailoverEventArgs Static Methods
The OracleFailoverEventArgs static methods are listed in Table 11-1.
Table 11-1 OracleFailoverEventArgs Static Methods
Methods Description
Equals
Inherited from System.Object (Overloaded)
OracleFailoverEventArgs Properties
The OracleFailoverEventArgs properties are listed in Table 11-2.
Table 11-2 OracleFailoverEventArgs Properties
Name Description
FailoverType
Specifies the type of failover the client has requested
FailoverEvent
Indicates the state of the failover
OracleFailoverEventArgs Public Methods
The OracleFailoverEventArgs public methods are listed in Table 11-3.
Table 11-3 OracleFailoverEventArgs Public Methods
Name Description
Equals
GetHashCode
GetType
ToString
Table 11-4 OracleFailoverEventArgs Static Methods
Methods Description
Equals
The OracleFailoverEventArgs properties are listed in Table 11-5.
Table 11-5 OracleFailoverEventArgs Properties
Name Description
FailoverType
FailoverEvent
FailoverType
This property indicates the state of the failover.
Declaration
// C#
public FailoverType FailoverType {get;}
Property Value
A FailoverType enumeration value.
FailoverEvent
Declaration
// C#
public FailoverEvent FailoverEvent {get;}
Property Value
A FailoverEvent enumerated value.
The OracleFailoverEventArgs public methods are listed in Table 11-6.
Table 11-6 OracleFailoverEventArgs Public Methods
Name Description
Equals
GetHashCode
GetType
ToString
