| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
An OracleConnection object represents a connection to an Oracle database.
Class Inheritance
System.Object
System.MarshalByRefObject
System.ComponentModel.Component
System.Data.Common.DbConnection
Oracle.DataAccess.Client.OracleConnection
Declaration
// C# public sealed class OracleConnection : DbConnection, IDbConnection, ICloneable
Requirements
| Provider | ODP.NET, Unmanaged Driver | ODP.NET, Managed Driver |
| Assembly | Oracle.DataAccess.dll |
Oracle.ManagedDataAccess.dll |
| Namespace | Oracle.DataAccess.Client |
Oracle.ManagedDataAccess.Client |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 | 4.0, 4.5 |
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleConnectionSample
static void Main()
// Connect
string constr = "User Id=scott;Password=tiger;Data Source=oracle";
OracleConnection con = new OracleConnection(constr);
con.Open();
// Execute a SQL SELECT
OracleCommand cmd = con.CreateCommand();
cmd.CommandText = "select * from emp";
OracleDataReader reader = cmd.ExecuteReader();
// Print all employee numbers
while (reader.Read())
Console.WriteLine(reader.GetInt32(0));
// Clean up
reader.Dispose();
cmd.Dispose();
con.Dispose();
OracleConnection members are listed in the following tables.
OracleConnection Constructors
OracleConnection constructors are listed in Table 5-17.
Table 5-17 OracleConnection Constructors
| Constructor | Description |
Instantiates a new instance of the |
OracleConnection Static Properties
The OracleConnection static property is listed in Table 5-19.
Table 5-18 OracleConnection Static Property
| Property | Description |
Indicates whether or not the implicit database connection is available for use |
OracleConnection Static Methods
The OracleConnection static methods are listed in Table 5-19.
Table 5-19 OracleConnection Static Methods
| Method | Description |
Inherited from |
Clears the connection pool that is associated with the provided Not supported in a .NET stored procedure |
Clears all connections from all the connection pools Not supported in a .NET stored procedure |
OracleConnection Properties
OracleConnection properties are listed in Table 5-20.
Table 5-20 OracleConnection Properties
Specifies the action name for the connection |
Specifies the client identifier for the connection |
Specifies the client information for the connection |
Specifies connection information used to connect to an Oracle database |
Indicates the maximum amount of time that the |
Determines whether a particular connection object is associated with a TimesTen database connection, an Oracle database connection, or no physical connection Not available in ODP.NET, Managed Driver |
Inherited from |
Not Supported |
Specifies the name of the database domain to which the connection is set |
Specifies the name of the database to which the connection is set |
Specifies the Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect |
Specifies the name of the host to which the connection is set |
Specifies the name of the instance to which the connection is set |
Sepcifies the logical transaction id that is associated with the connection at the time of the invocation |
Specifies the module name for the connection |
Specifies the version number of the Oracle database to which the |
Specifies the name of the service to which the connection is set |
Inherited from |
Specifies the current state of the connection |
Specifies the current size of the statement cache associated with this connection |
OracleConnection Public Methods
OracleConnection public methods are listed in Table 5-21.
Table 5-21 OracleConnection Public Methods
| Public Method | Description |
Begins a local transaction (Overloaded) Not supported in a .NET stored procedure for context connection |
Not Supported |
Creates a copy of an Not supported in a .NET stored procedure |
Closes the database connection |
Creates and returns an |
Inherited from |
Inherited from |
Enables applications to explicitly enlist in a specified distributed transaction Not supported in a .NET stored procedure |
Enables applications to enlist in a specified distributed transaction Not supported in a .NET stored procedure |
Inherited from |
Flushes all updates and deletes made through Not available in ODP.NET, Managed Driver |
Inherited from |
Inherited from |
Returns the status of the current local transaction associated with the connection |
Returns schema information for the data source of the |
Returns or refreshes the property values of the |
Inherited from |
Inherited from |
Opens a database connection with the property settings specified by the |
Opens a new connection with the new password Not supported in a .NET stored procedure for context connection |
Flushes the Statement Cache by closing all open cursors on the database, when statement caching is enabled |
Alters the session's globalization settings with the property values provided by the |
Inherited from |
OracleConnection Events
OracleConnection events are listed in Table 5-22.
Table 5-22 OracleConnection Events
| Event Name | Description |
Inherited from |
An event that is triggered when an Oracle failover occurs Not supported in a .NET stored procedure Not Available in ODP.NET, Managed Driver |
An event that is triggered when an HA event occurs. |
An event that is triggered for any message or warning sent by the database |
An event that is triggered when the connection state changes |
OracleConnection constructors instantiate new instances of the OracleConnection class.
Overload List:
This constructor instantiates a new instance of the OracleConnection class using default property values.
This constructor instantiates a new instance of the OracleConnection class with the provided connection string.
Declaration
// C# public OracleConnection();
Remarks
The properties for OracleConnection are set to the following default values:
ConnectionString = empty string
ConnectionTimeout = 15 (default value of 0 is used for the implicit database connection)
DataSource = empty string
ServerVersion = empty string
Declaration
// C#
public OracleConnection(String connectionString);
Parameters
connectionString
The connection information used to connect to the Oracle database.
Remarks
The ConnectionString property is set to the supplied connectionString. The ConnectionString property is parsed and an exception is thrown if it contains invalid connection string attributes or attribute values.
The properties of the OracleConnection object default to the following values unless they are set by the connection string:
The OracleConnection static property is listed in Table 5-23.
Table 5-23 OracleConnection Static Property
This property indicates whether or the implicit database connection is available for use.
Declaration
// C#
public static bool IsAvailable {get;}
Property Value
Returns true if the implicit database connection is available for use.
Remarks
The availability of the implicit database connection can be checked at runtime through this static property. When Oracle Data Provider for .NET is used within a .NET stored procedure, this property always returns true. Otherwise, false is returned.
To obtain an OracleConnection object in a .NET stored procedure that represents the implicit database connection, set the ConnectionString property of the OracleConnection object to "context connection=true" and invoke the Open method.
Note that not all features that are available for an explicit user connection are available for an implicit database connection. See "Implicit Database Connection" for details.
Example
// C# (Library/DLL)
using System;
public class IsAvailableSample
static void MyStoredProcedure()
OracleConnection con = new OracleConnection();
if (OracleConnection.IsAvailable)
// This function is invoked as a stored procedure
// Obtain the implicit database connection by setting
// "context connection=true" in the connection string
con.ConnectionString = "context connection=true";
else
// This function is not invoked as a stored procedure
// Set the connection string for a normal client connection
con.ConnectionString = "user id=scott;password=tiger;data source=oracle";
con.Open();
Console.WriteLine("connected!");
The OracleConnection static methods are listed in Table 5-24.
Table 5-24 OracleConnection Static Methods
Inherited from |
This method clears the connection pool that is associated with the provided OracleConnection object.
Declaration
// C# public static void ClearPool(OracleConnection connection);
Remarks
When this method is invoked, all idle connections are closed and freed from the pool. Currently used connections are not discarded until they are returned to the pool.
Beginning with ODP.NET 12c Release 1 (12.1), ClearPool does not automatically repopulate the pool with new connections. This prevents the pool from being repopulated with invalid connections if client remains unable to connect with the database server. Developers programmatically control when the pool is repopulated by calling OracleConnection.Open(), which will repopulate the pool with at least the Min Pool Size number of connections.
Connections created after this method invocation are not cleared unless another invocation is made.
This method can be invoked with an OracleConnection object before opening the connection as well as after, provided the ConnectionString is properly set.
Exceptions
InvalidOperationException – Either the connection pool cannot be found or the provided connection string is invalid.
Example
// C#
// Sample demonstrating the use of ClearPool API in OracleConnection class
using System;
class ClearPoolSample
static void Main()
Console.WriteLine("Running ClearPool sample..." );
string strConn = "User Id=scott;Password=tiger;Data Source=oracle;" +
"Min pool size=5;";
OracleConnection conn = new OracleConnection(strConn);
// Open the connection
conn.Open();
// Clears the connection pool associated with connection 'conn'
OracleConnection.ClearPool (conn);
// This connection will be placed back into the pool
conn.Close ();
// Open the connection again to create additional connections in the pool
conn.Open();
// Create a new connection object
OracleConnection connNew = new OracleConnection(strConn);
// Clears the pool associated with Connection 'connNew'
// Since the same connection string is set for both the connections,
// connNew and conn, they will be part of the same connection pool.
// We need not do an Open() on the connection object before calling
// ClearPool
OracleConnection.ClearPool (connNew);
// cleanup
conn.Close();
Console.WriteLine("Done!");
This method clears all connections from all the connection pools.
Declaration
// C# public static void ClearAllPools();
Remarks
This call is analogous to calling ClearPool for all the connection pools that are created for the application.
Exceptions
InvalidOperationException – No connection pool could be found for the application.
Example
// C#
// Sample demonstrating the use of ClearAllPools API in OracleConnection class
using System;
class ClearAllPoolsSample
static void Main()
Console.WriteLine("Running ClearAllPools sample..." );
"Min pool size=5;";
// Create another connection object with a different connection string
string strConnNew = "User Id=scott;Password=tiger;Data Source=oracle;";
OracleConnection connNew = new OracleConnection(strConnNew);
// Open the connections. Separate pools are created for conn and connNew
conn.Open();
connNew.Open();
// Clears the pools associated with conn and connNew
OracleConnection.ClearAllPools ();
// cleanup
conn.Close();
connNew.Close();
OracleConnection properties are listed in Table 5-25
Table 5-25 OracleConnection Properties
Inherited from |
Not Supported |
Inherited from |
This property specifies the action name for the connection.
Declaration
// C#
public string ActionName {set;}
Property Value
The string to be used as the action name.
Remarks
The default value is null.
Using the ActionName property allows the application to set the action name in the application context for a given OracleConnection object.
The ActionName property is reset to null when the Close or Dispose method is called on the OracleConnection object.
This property specifies the client identifier for the connection.
Declaration
// C#
public string ClientId {set;}
Property Value
The string to be used as the client identifier.
Remarks
Using the ClientId property allows the application to set the client identifier in the application context for a given OracleConnection object.
Setting ClientId to null resets the client identifier for the connection. ClientId is set to null when the Close or Dispose method is called on the OracleConnection object.
This property specifies the client information for the connection.
Declaration
// C#
public string ClientInfo {set;}
Property Value
The string to be used as the client information.
Remarks
Using the ClientInfo property allows the application to set the client information in the application context for a given OracleConnection object.
The ClientInfo property is reset to null when the Close or Dispose method is called on the OracleConnection object.
This property specifies connection information used to connect to an Oracle database.
Declaration
// C#
public override string ConnectionString{get; set;}
Property Value
If the connection string is supplied through the constructor, this property is set to that string.
Implements
IDbConnection
Exceptions
ArgumentException - An invalid syntax is specified for the connection string.
InvalidOperationException - ConnectionString is being set while the connection is open.
Remarks
The default value is an empty string.
ConnectionString must be a string of attribute name and value pairings, separated by a semi-colon, for example:
"User Id=scott;password=tiger;data source=oracle"
If the ConnectionString is not in a proper format, an exception is thrown. All spaces are ignored unless they are within double quotes.
When the ConnectionString property is set, the OracleConnection object immediately parses the string for errors. An ArgumentException is thrown if the ConnectionString contains invalid attributes or invalid values. Attribute values for User Id, Password, Proxy User Id, Proxy Password, and Data Source (if provided) are not validated until the Open method is called.
The connection must be closed to set the ConnectionString property. When the ConnectionString property is reset, all previously set values are reinitialized to their default values before the new values are applied.
Starting with ODP.NET 11.1, password and proxy password connection string attribute values are accepted as case-sensitive strings. Thus, they are passed to the database for authentication in the case provided in the connection string. Therefore, if the database is configured to support case-sensitive passwords, passwords must be passed in the correct case.
If a connection string attribute is set more than once, the last setting takes effect and no exceptions are thrown.
Boolean connection string attributes can be set to either true, false, yes, or no.
Remarks (.NET Stored Procedure)
To obtain an OracleConnection object in a .NET stored procedure that represents the implicit database connection, set the ConnectionString property of the OracleConnection object to "context connection=true" and invoke the Open method. Other connection string attributes cannot be used in conjunction with "context connection" when it is set to true.
Supported Connection String Attributes
Table 5-26 lists the supported connection string attributes.
Table 5-26 Supported Connection String Attributes
| Connection String Attribute | Description | Default Value |
Minimum life time (in seconds) of the connection. This attribute specifies the lifetime of the connection in seconds. Before the |
Minimum time (in seconds) to wait for a free connection from the pool. This attribute specifies the minimum amount of time (in seconds) that the This attribute value takes effect for pooled connection requests and not for new connection requests. (The default value is |
Returns an implicit database connection if set to An implicit database connection can only be obtained from within a .NET stored procedure. Other connection string attributes cannot be used in conjunction with Supported in a .NET stored procedure only |
Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect. |
empty string |
Administrative privileges This connection string attribute only accepts |
empty string |
Number of connections that are closed when an excessive amount of established connections are unused. This connection string attribute controls the maximum number of unused connections that are closed when the pool regulator makes periodic checks. The regulator thread is spawned every 3 minutes and closes up to |
Controls the enlistment behavior and capabilities of a connection in context of COM+ transactions or If this attribute is set to |
Enables ODP.NET connection pool to proactively remove connections from the pool when an Oracle RAC service, service member, or node goes down. This feature can only used against an Oracle RAC database and only if This attribute can be set to |
Enables ODP.NET connection pool to balance work requests across Oracle RAC instances based on the load balancing advisory and service goal. This feature can only used against an Oracle RAC database and only if This attribute can be set to |
Number of new connections to be created when all connections in the pool are in use. This connection string attribute determines the number of new connections that are established when a pooled connection is requested, but no unused connections are available and |
Maximum number of connections in a pool. This attribute specifies the maximum number of connections allowed in the particular pool used by that |
Caches metadata information. This attribute indicates whether or not metadata information for executed queries are cached for improved performance. |
Minimum number of connections in a pool. This attribute specifies the minimum number of connections to be maintained by the pool during its entire lifetime. Simply changing this attribute in the connection string does not change the |
Password for the user specified by This attribute specifies an Oracle user's password. |
empty string |
Retrieval of the password in the connection string. If this attribute is set to |
Connection pooling. This attribute specifies whether or not connection pooling is to be used. Pools are created using an attribute value matching algorithm. This means that connection strings which only differ in the number of spaces in the connection string use the same pool. If two connection strings are identical except that one sets an attribute to a default value while the other does not set that attribute, both requests obtain connections from the same pool. This attribute can be set to either |
Promotable to distributed transaction or not. If |
promotable |
User name of the proxy user. This connection string attribute specifies the middle-tier user, or the proxy user, who establishes a connection on behalf of a client user specified by the |
empty string |
For the proxy user to connect to an Oracle database using operating system authentication, the |
Password of the proxy user. This connection string attribute specifies the password of the middle-tier user or the proxy user. This user establishes a connection on behalf of a client user specified by the The case of this attribute value is preserved if it is surrounded by double quotes. |
empty string |
Statement cache purged when the connection goes back to the pool. If statement caching is enabled, setting this attribute to |
Statement cache enabled and cache size set size, that is, the maximum number of statements that can be cached. A value greater than zero enables statement caching and sets the cache size to itself. This value should not be greater than the value of the |
0 |
Enables or disables self-tuning for the connection. If self-tuning is enabled, then the If self-tuning is disabled, then a |
Oracle user name. This attribute specifies the Oracle user name. The case of this attribute value is preserved if it is surrounded by double quotes. For the user to connect to an Oracle database using operating system authentication, set the |
empty string |
Validation of connections coming from the pool. Validation causes a round-trip to the database for each connection. Therefore, it should only be used when necessary. |
This property indicates the minimum amount of time that the Open method can take to obtain a pooled connection before the request is terminated.
Declaration
// C#
public override int ConnectionTimeout {get;}
Property Value
The minimum time allowed for a pooled connection request, in seconds.
Implements
IDbConnection
Remarks
This property indicates the connection timeout that has been set using the ConnectionString attribute Connection TimeOut.
This property is read-only.
There is no connection string specified by the application and a connection on the implicit database is always available, therefore, this property is set to 0.
This property enables an ODP.NET application to determine whether a particular connection object is associated with an Oracle database connection, a TimesTen database connection, or no physical connection at all.
Declaration
// C#
public OracleConnectionType ConnectionType {get;}
Property Value
The OracleConnectionType that this connection object is associated with.
This property is not supported.
Declaration
// C#
public override string Database {get;}
Property Value
A string.
Implements
IDbConnection.Database
Remarks
This property is not supported. It always returns an empty string.
This property specifies the name of the database domain that this connection is connected to.
Declaration
// C#
public string DatabaseDomainName {get;}
Property Value
The database domain that this connection is connected to.
This property specifies the name of the database that this connection is connected to.
Declaration
// C#
public string DatabaseName {get;}
Property Value
The database that this connection is connected to.
This property specifies the Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect
Declaration
// C#
public override string DataSource {get;}
Property Value
The value of this property is always an empty string for the implicit database connection.
This property specifies the name of the host that this connection is connected to.
Declaration
// C#
public string HostName {get;}
Property Value
The host that this connection is connected to.
This property specifies the name of the instance that this connection is connected to.
Declaration
// C#
public string InstanceName {get;}
Property Value
The instance that this connection is connected to.
This property provides the logical transaction ID that the connection is associated with.
Declaration
// C#
public string LogicalTransactionId {get;}
Property Value
LogicalTransactionId returns a byte [ ] that represents the logical transaction id that is associated with the connection at the time of the invocation.
Remarks
LogicalTransactionId can then be used to get the status of the logical transaction by invoking GetLogicalTransactionStatus and passing the byte[ ] as an input parameter.
The return value is NULL if the database version is not greater than or equal to 12.1.
Only local transactions support using LogicalTransactionId. The property is not supported with distributed transactions.
This property specifies the module name for the connection.
Declaration
// C#
public string ModuleName {set;}
Property Value
The string to be used as the module name.
Remarks
Using the ModuleName property allows the application to set the module name in the application context for a given OracleConnection object.
The ModuleName property is reset to null when the Close or Dispose method is called on the OracleConnection object.
This property specifies the version number of the Oracle database to which the OracleConnection has established a connection.
Declaration
// C#
public override string ServerVersion {get;}
Property Value
The version of the Oracle database.
Exceptions
InvalidOperationException - The connection is closed.
Remarks
The default is an empty string.
This property specifies the name of the service that this connection is connected to.
Declaration
// C#
public string ServiceName {get;}
Property Value
The service that this connection is connected to.
This property specifies the current state of the connection.
Declaration
// C#
public override ConnectionState State {get;}
Property Value
The ConnectionState of the connection.
Implements
IDbConnection
Remarks
ODP.NET supports ConnectionState.Closed and ConnectionState.Open for this property. The default value is ConnectionState.Closed.
This property specifies the current size of the statement cache associated with this connection.
Declaration
// C#
public int StatementCacheSize{get;}
Property Value
An integer value indicating the size of the statement cache.
Remarks
If self tuning is not enabled, then the default value of this property depends upon the statement cache size specified in the connection string, application configuration file, or the registry. If none of these values are specified, then a default value of 0 is used.
If self tuning is enabled, then the property value is adjusted automatically. Any values specified in the connection string, application configuration file, or the registry are ignored.
OracleConnection public methods are listed in Table 5-27.
Table 5-27 OracleConnection Public Methods
Not Supported |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
BeginTransaction methods begin local transactions.
Overload List
This method begins a local transaction.
BeginTransaction(IsolationLevel)
This method begins a local transaction with the specified isolation level.
Declaration
// C# public OracleTransaction BeginTransaction();
Return Value
An OracleTransaction object representing the new transaction.
Implements
IDbConnection
Exceptions
InvalidOperationException - A transaction has already been started.
Remarks
The transaction is created with its isolation level set to its default value of IsolationLevel.ReadCommitted. All further operations related to the transaction must be performed on the returned OracleTransaction object.
Using this method in a .NET stored procedure for context connection causes a Not Supported exception.
Declaration
// C#
public OracleTransaction BeginTransaction(IsolationLevel isolationLevel);
Parameters
isolationLevel
The isolation level for the new transaction.
Return Value
Implements
IDbConnection
Exceptions
ArgumentException - The isolationLevel specified is invalid.
Remarks
The following isolation levels are supported: IsolationLevel.ReadCommitted and IsolationLevel.Serializable.
Although the BeginTransaction method supports the IsolationLevel.Serializable isolation level, serializable transactions are not supported when using System.Transactions and TransactionScope.
Requesting other isolation levels causes an exception.
Example
// C#
using System;
using System.Data;
class BeginTransactionSample
static void Main()
con.Open();
// Create an OracleCommand object using the connection object
// Start a transaction
OracleTransaction txn = con.BeginTransaction(IsolationLevel.ReadCommitted);
// Update EMP table
cmd.CommandText = "update emp set sal = sal + 100";
cmd.ExecuteNonQuery();
// Rollback transaction
txn.Rollback();
Console.WriteLine("Transaction rolledback");
// Clean up
txn.Dispose();
cmd.Dispose();
con.Dispose();
This method is not supported.
Declaration
// C#
public override void ChangeDatabase(string databaseName);
Parameters
databaseName
The name of the database that replaces the current database name.
Implements
IDbConnection.ChangeDatabase
Exceptions
NotSupportedException - Method not supported.
Remarks
This method is not supported and throws a NotSupportedException if invoked.
This method creates a copy of an OracleConnection object.
Declaration
// C# public object Clone();
Return Value
An OracleConnection object.
Implements
ICloneable
Remarks
The cloned object has the same property values as that of the object being cloned.
This method is not supported for an implicit database connection.
Example
// C#
using System;
class CloneSample
static void Main()
con.Open();
// Need a proper casting for the return value when cloned
OracleConnection clonedCon = (OracleConnection)con.Clone();
// Cloned connection is always closed, regardless of its source,
// But the connection string should be identical
clonedCon.Open();
if (clonedCon.ConnectionString.Equals(con.ConnectionString))
Console.WriteLine("The connection strings are the same.");
else
Console.WriteLine("The connection strings are different.");
// Close and Dispose OracleConnection object
clonedCon.Dispose();
This method closes the connection to the database.
Declaration
// C# public override void Close();
Implements
IDbConnection
Remarks
Performs the following:
Rolls back any pending transactions.
Places the connection to the connection pool if connection pooling is enabled. Even if connection pooling is enabled, the connection can be closed if it exceeds the connection lifetime specified in the connection string. If connection pooling is disabled, the connection is closed.
Closes the connection to the database.
The connection can be reopened using Open().
This method creates and returns an OracleCommand object associated with the OracleConnection object.
Declaration
// C# public OracleCommand CreateCommand();
Return Value
The OracleCommand object.
Implements
IDbConnection
Example
// C#
using System;
using System.Data;
class CreateCommandSample
static void Main()
// Connect
con.Open();
// Clean up
reader.Dispose();
cmd.Dispose();
con.Dispose();
This method enables applications to explicitly enlist in a specific distributed transaction after a connection has been opened.
Declaration
// C#
public void EnlistDistributedTransaction(ITransaction transaction);
Parameters
transaction
An ITransaction interface.
Exceptions
InvalidOperationException - The connection is part of a local transaction or the connection is closed.
Remarks
EnlistDistributedTransaction enables objects to enlist in a specific transaction that is passed to the method. The ITransaction interface can be obtained by applying an (ITransaction) cast to the ContexUtil.Transaction property within the component that started the distributed transaction.
The connection must be open before calling this method or an InvalidOperationException is thrown.
If a connection is part of a local transaction that was started implicitly or explicitly while attempting to enlist in a distributed transaction, the local transaction is rolled back and an exception is thrown.
By default, distributed transactions roll back, unless the method-level AutoComplete declaration is set.
Invoking the commit on the ITranasction raises an exception.
Invoking the rollback on the ITransaction method and calling ContextUtil.SetComplete on the same distributed transaction raises an exception.
Using this method causes a Not Supported exception.
Example
Application:
// C#
/* This is the class that will utilize the Enterprise Services
component. This module needs to be built as an executable.
The Enterprise Services Component DLL must be built first
before building this module.
In addition, the DLL needs to be referenced appropriately
when building this application.
using System;
using System.EnterpriseServices;
using DistribTxnSample;
class DistribTxnSample_App
static void Main()
DistribTxnSample_Comp comp = new DistribTxnSample_Comp();
comp.DoWork();
Component:
// C#
/* This module needs to be
1) built as a component DLL/Library
2) built with a strong name
This library must be built first before the application is built.
using System;
using System.Data;
namespace DistribTxnSample
[Transaction(TransactionOption.RequiresNew)]
public class DistribTxnSample_Comp : ServicedComponent
public void DoWork()
string constr =
"User Id=scott;Password=tiger;Data Source=oracle;enlist=false";
con.Open();
// Enlist in a distrubuted transaction
con.EnlistDistributedTransaction((ITransaction)ContextUtil.Transaction);
// Update EMP table
cmd.CommandText = "UPDATE emp set sal = sal + .01";
// Commit
ContextUtil.SetComplete();
// Dispose OracleConnection object
con.Dispose();
See Also:
This method enlists the connection to the specified transaction.
Declaration
// C#
public override void EnlistTransaction(Transaction transaction)
Parameters
transaction
A System.Transactions.Transaction object.
Exceptions
Remarks
Invocation of this method immediately enlists the connection to a transaction that is specified by the provided transaction parameter.
If OracleConnection is still associated with a distributed transaction that has not completed from a previous EnlistTransaction method invocation, calling this method will cause an exception to be thrown.
In general, for transaction enlistments to succeed, the "enlist" connection string attribute must be set to either "true" or "dynamic" before invoking the Open method. Setting the "enlist" connection string attribute to "true" will implicitly enlist the connection when the Open method is called, if the connection is within a transaction context. Setting it to "dynamic" allows the connection to dynamically enlist in transactions when an EnlistTransaction or EnlistDistributedTransaction method is called. The "enlist" attribute should be set to "false" only if the connection will never enlist in a transaction.
This method flushes all updates and deletes made through REF objects retrieved using this connection.
Declaration
// c# public void FlushCache();
Exceptions
InvalidOperationException - The specified connection is not open.
Remarks
Before flushing objects, it is required that the application has explicitly started a transaction by executing the BeginTransaction method on the OracleConnection object. This is because if the object being flushed has not already been locked by the application, an exclusive lock is obtained implicitly for the object. The lock is only released when the transaction commits or rollbacks.
This method on the already existing OracleConnection object returns the status of the current local transaction associated with the connection.
Declaration
// C# public ?? OracleLogicalTransactionStatus GetLogicalTransctionStatus(byte);
Return Value
The status of the current local transaction associated with the connection.
Exceptions
If this method is invoked on the same OracleConnection object from which the LTXID is obtained, an "ORA-14906: GetLTXID outcome operation is not permitted on the current session" exception will be thrown.
Remarks
This call returns a NULL if the LTXID is NULL or if the Oracle Database version is not greater than or equal to 12.1.
Example
// C#
// NOTE: User HR requires execution access on SYS.DBMS_APP_CONT for this demo.
// NOTE: The database service must be set with commit_outcome = true
// FIXME – show this example is used after a session loss
using System;
class TransactionGuardDemo
static void Main(string[] args)
// Establish a connection to an Oracle database for checking the status
string statusConStr = "user id=hr;password=hr;data source=oracle";
OracleConnection statusCon = new OracleConnection(statusConStr);
statusCon.Open();
// Establish a connection to an Oracle database for the transaction
string txnConStr = "user id=hr;password=hr;data source=oracle";
OracleConnection txnCon = new OracleConnection(txnConStr);
txnCon.Open();
// Obtain the logical transaction id
byte[] logicalTransactionId = txnCon.LogicalTransactionId;
try
// Begin a local transaction
OracleTransaction txn = txnCon.BeginTransaction();
// Do transactional work
OracleCommand cmd = new OracleCommand("update employees set salary=salary+10 where employee_id=100", txnCon);
// Commit the transaction
txn.Commit();
finally
// Obtain the transaction status for the specified logical transaction id
OracleLogicalTransactionStatus status =
statusCon.GetLogicalTransactionStatus(logicalTransactionId);
// Output the status of the logical transaction
Console.WriteLine("Has the transaction been committed? " + status.Committed);
Console.WriteLine("Has the user call been completed? " + status.UserCallCompleted);
GetSchema methods return schema information for the data source of the OracleConnection.
Overload List
This method returns schema information for the data source of the OracleConnection.
GetSchema (string collectionName)
This method returns schema information for the data source of the OracleConnection using the specified string for the collection name.
GetSchema (string collectionName, string[] restrictions)
This method returns schema information for the data source of the OracleConnection using the specified string for the collection name and the specified string array for the restriction values.
Declaration
// C# public override DataTable GetSchema();
Return Value
A DataTable object.
Exceptions
InvalidOperationException – The connection is closed.
Remarks
This method returns a DataTable object that contains a row for each metadata collection available from the database.
The method is equivalent to specifying the String value "MetaDataCollections" when using the GetSchema(String) method.
Example
// C#
using System;
using System.Data;
using System.Data.Common;
class GetSchemaSample
string constr = "User Id=scott; Password=tiger; Data Source=oracle;";
string ProviderName = "Oracle.DataAccess.Client";
DbProviderFactory factory = DbProviderFactories.GetFactory(ProviderName);
using (DbConnection conn = factory.CreateConnection())
try
conn.ConnectionString = constr;
conn.Open();
//Get all the schema collections and write to an XML file.
//The XML file name is Oracle.DataAccess.Client_Schema.xml
DataTable dtSchema = conn.GetSchema();
dtSchema.WriteXml(ProviderName + "_Schema.xml");
catch (Exception ex)
Console.WriteLine(ex.Message);
Console.WriteLine(ex.StackTrace);
Declaration
// C#
public override DataTable GetSchema (string collectionName);
Parameters
collectionName
Name of the collection for which metadata is required.
Return Value
A DataTable object.
Exceptions
ArgumentException – The requested collection is not defined.
InvalidOperationException – The requested collection is not supported by current version of Oracle database.
InvalidOperationException – No population string is specified for requested collection.
Example
// C#
using System;
using System.Data;
try
conn.Open();
//Get MetaDataCollections and write to an XML file.
//This is equivalent to GetSchema()
DataTable dtMetadata =
conn.GetSchema(DbMetaDataCollectionNames.MetaDataCollections);
dtMetadata.WriteXml(ProviderName + "_MetaDataCollections.xml");
//Get Restrictions and write to an XML file.
DataTable dtRestrictions =
conn.GetSchema(DbMetaDataCollectionNames.Restrictions);
dtRestrictions.WriteXml(ProviderName + "_Restrictions.xml");
//Get DataSourceInformation and write to an XML file.
DataTable dtDataSrcInfo =
conn.GetSchema(DbMetaDataCollectionNames.DataSourceInformation);
dtDataSrcInfo.WriteXml(ProviderName + "_DataSourceInformation.xml");
//data types and write to an XML file.
DataTable dtDataTypes =
conn.GetSchema(DbMetaDataCollectionNames.DataTypes);
dtDataTypes.WriteXml(ProviderName + "_DataTypes.xml");
//Get ReservedWords and write to an XML file.
DataTable dtReservedWords =
conn.GetSchema(DbMetaDataCollectionNames.ReservedWords);
dtReservedWords.WriteXml(ProviderName + "_ReservedWords.xml");
//Get all the tables and write to an XML file.
DataTable dtTables = conn.GetSchema("Tables");
dtTables.WriteXml(ProviderName + "_Tables.xml");
//Get all the views and write to an XML file.
DataTable dtViews = conn.GetSchema("Views");
dtViews.WriteXml(ProviderName + "_Views.xml");
//Get all the columns and write to an XML file.
DataTable dtColumns = conn.GetSchema("Columns");
dtColumns.WriteXml(ProviderName + "_Columns.xml");
Declaration
// C# public override DataTable GetSchema (string collectionName, string[] restrictions);
Parameters
collectionName
The name of the collection of metadata being retrieved.
restrictions
An array of restrictions that apply to the metadata being retrieved.
Return Value
A DataTable object.
Exception
InvalidOperationException – One of the following conditions exist:
The requested collection is not supported by the current version of Oracle database.
More restrictions were provided than the requested collection supports.
Remarks
This method takes the name of a metadata collection and an array of String values that specify the restrictions for filtering the rows in the returned DataTable. This returns a DataTable that contains only rows from the specified metadata collection that match the specified restrictions.
For example, if the Columns collection has three restrictions (owner, tablename, and columnname), to retrieve all the columns for the EMP table regardless of schema, the GetSchema method must pass in at least these values: null, EMP.
If no restriction value is passed in, default values are used for that restriction, which is the same as passing in null. This differs from passing in an empty string for the parameter value. In this case, the empty string ("") is considered the value for the specified parameter.
collectionName is not case-sensitive, but restrictions (string values) are.
Example
// C#
using System;
using System.Data;
try
conn.Open();
//Get Restrictions
DataView dv = dtRestrictions.DefaultView;
dv.RowFilter = "CollectionName = 'Columns'";
dv.Sort = "RestrictionNumber";
for (int i = 0; i < dv.Count; i++)
Console.WriteLine("{0} (default) {1}" ,
dtRestrictions.Rows[i]["RestrictionName"],
dtRestrictions.Rows[i]["RestrictionDefault"]);
//Set restriction string array
string[] restrictions = new string[3];
//Get all columns from all tables owned by "SCOTT"
restrictions[0] = "SCOTT";
DataTable dtAllScottCols = conn.GetSchema("Columns", restrictions);
// clear collection
for (int i = 0; i < 3; i++)
restrictions[i] = null;
//Get all columns from all tables named "EMP" owned by any
//owner/schema
restrictions[1] = "EMP";
DataTable dtAllEmpCols = conn.GetSchema("Columns", restrictions);
// clear collection
//Get columns named "EMPNO" from tables named "EMP",
//owned by any owner/schema
restrictions[2] = "EMPNO";
DataTable dtAllScottEmpCols = conn.GetSchema("Columns", restrictions);
// clear collection
//Get columns named "EMPNO" from all
//tables, owned by any owner/schema
DataTable dtAllEmpNoCols = conn.GetSchema("Columns", restrictions);
Console.WriteLine(ex.Source);
GetSessionInfo returns or refreshes an OracleGlobalization object that represents the globalization settings of the session.
Overload List:
This method returns a new instance of the OracleGlobalization object that represents the globalization settings of the session.
GetSessionInfo(OracleGlobalization)
This method refreshes the provided OracleGlobalization object with the globalization settings of the session.
Declaration
// C# public OracleGlobalization GetSessionInfo();
Return Value
The newly created OracleGlobalization object.
Example
// C#
using System;
class GetSessionInfoSample
static void Main()
con.Open();
// Get session info from connection object
OracleGlobalization info = con.GetSessionInfo();
// Update session info
info.DateFormat = "YYYY-MM-DD";
con.SetSessionInfo(info);
// Execute SQL SELECT
cmd.CommandText = "select TO_CHAR(hiredate) from emp";
Console.WriteLine("Hire Date ({0}): {1}",
info.DateFormat, cmd.ExecuteScalar());
// Clean up
cmd.Dispose();
con.Dispose();
Declaration
// C#
public void GetSessionInfo(OracleGlobalization oraGlob);
Parameters
oraGlob
The OracleGlobalization object to be updated.
This method opens a connection to an Oracle database.
Declaration
// C# public overide void Open();
Implements
IDbConnection
Exceptions
ObjectDisposedException - The object is already disposed.
InvalidOperationException - The connection is already opened or the connection string is null or empty.
Remarks
The connection is obtained from the pool if connection pooling is enabled. Otherwise, a new connection is established.
It is possible that the pool does not contain any unused connections when the Open() method is invoked. In this case, a new connection is established.
If no connections are available within the specified connection timeout value, when the Max Pool Size is reached, an OracleException is thrown.
This method opens a new connection with the new password.
Declaration
// C#
public void OpenWithNewPassword(string newPassword);
Parameters
newPassword
A string that contains the new password.
Remarks
This method uses the ConnectionString property settings to establish a new connection. The old password must be provided in the connection string as the Password attribute value.
This method can only be called on an OracleConnection in the closed state.
This method is not supported in a .NET stored procedure for context connection.
Note: If connection pooling is enabled, then invoking theOpenWithNewPassword method also clears the connection pool. This closes all idle connections created with the old password. |
This method flushes the statement cache by closing all open cursors on the database, when statement caching is enabled.
Declaration
// C# public void PurgeStatementCache();
Remarks
Flushing the statement cache repetitively results in decreased performance and may negate the performance benefit gained by enabling the statement cache.
Statement caching remains enabled after the call to PurgeStatementCache.
Invocation of this method purges the cached cursors that are associated with the OracleConnection. It does not purge all the cached cursors in the database.
Example
// C#
using System;
using System.Data;
class PurgeStatementCacheSample
static void Main()
string constr = "User Id=scott;Password=tiger;Data Source=oracle;" +
"Statement Cache Size=20";
con.Open();
OracleCommand cmd = new OracleCommand("select * from emp", con);
cmd.CommandType = CommandType.Text;
// Purge Statement Cache
con.PurgeStatementCache();
Console.WriteLine("Statement Cache Flushed");
con.Close();
con.Dispose();
This method alters the session's globalization settings with all the property values specified in the provided OracleGlobalization object.
Declaration
// C#
public void SetSessionInfo(OracleGlobalization oraGlob);
Parameters
oraGlob
An OracleGlobalization object.
Remarks
Calling this method is equivalent to calling an ALTER SESSION SQL on the session.
Example
// C#
using System;
class SetSessionInfoSample
static void Main()
con.Open();
info.DateFormat = "MM-DD-RR";
// Execute SQL SELECT again
// Clean up
cmd.Dispose();
con.Dispose();
OracleConnection events are listed in Table 5-28.
Table 5-28 OracleConnection Events
Inherited from |
An event that is triggered when an Oracle failover occurs Not supported in a .NET stored procedure Not available in ODP.NET, Managed Driver |
This event is triggered when an Oracle failover occurs.
Declaration
// C# public event OracleFailoverEventHandler Failover;
Event Data
The event handler receives an OracleFailoverEventArgs object which exposes the following properties containing information about the event.
FailoverType
Indicates the type of the failover.
FailoverEvent
Indicates the state of the failover.
Remarks
The Failover event is raised when a connection to an Oracle instance is unexpectedly severed. The client should create an OracleFailoverEventHandler delegate to listen to this event.
This event is triggered when an HA event occurs.
Declaration
// C# public static event OracleHAEventHandler HAEvent;
Event Data
The event handler receives an OracleHAEventArgs object which exposes the following properties containing information about the event.
Source
Indicates the source of the event.
Status
Indicates the status of the event.
DatabaseName
Indicates the database name affected by this event.
DatabaseDomainName
Indicates the database domain name affected by this event.
HostName
Indicates the host name affected by this event.
InstanceName
Indicates the instance name affected by this event.
ServiceName
Indicates the service name affected by this event.
Time
Indicates the time of the event.
Remarks
The HAEvent is static, which means that any HA Events that happen within the application domain can trigger this event. Note that in order to receive HA event notifications, OracleConnection objects that establish connections within the application domain must have "ha events=true" in the application. Otherwise, the application never receives any HA Events.
This event is triggered for any message or warning sent by the database.
Declaration
// C# public event OracleInfoMessageEventHandler InfoMessage;
Event Data
The event handler receives an OracleInfoMessageEventArgs object which exposes the following properties containing information about the event.
Errors
The collection of errors generated by the data source.
Message
The error text generated by the data source.
Source
The name of the object that generated the error.
Remarks
In order to respond to warnings and messages from the database, the client should create an OracleInfoMessageEventHandler delegate to listen to this event.
This event is triggered when the connection state changes.
Declaration
// C# public override event StateChangeEventHandler StateChange;
Event Data
The event handler receives a StateChangeEventArgs object which exposes the following properties containing information about the event.
CurrentState
The new state of the connection.
OriginalState
The original state of the connection.
Remarks
The StateChange event is raised after a connection changes state, whenever an explicit call is made to Open, Close or Dispose.
See Also:
