Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleDataAdapter Class
An OracleDataAdapter object represents a data provider object that populates the DataSet and updates changes in the DataSet to the Oracle database.
Class Inheritance
System.Object
  System.MarshalByRefObject
    System.ComponentModel.Component
      System.Data.Common.DataAdapter
        System.Data.Common.DbDataAdapter
          Oracle.DataAccess.Client.OracleDataAdapter
Declaration
// C#
public sealed class OracleDataAdapter : DbDataAdapter, IDbDataAdapter
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The following example uses the OracleDataAdapter and the dataset to update the EMP table:
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleDataAdapterSample
  static void Main()
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    string cmdstr = "SELECT empno, sal from emp";
    // Create the adapter with the selectCommand txt and the
    // connection string
    OracleDataAdapter adapter = new OracleDataAdapter(cmdstr, constr);
    // Create the builder for the adapter to automatically generate
    // the Command when needed
    OracleCommandBuilder builder = new OracleCommandBuilder(adapter);
    // Create and fill the DataSet using the EMP
    DataSet dataset = new DataSet();
    adapter.Fill(dataset, "EMP");
    // Get the EMP table from the dataset
    DataTable table = dataset.Tables["EMP"];
    // Indicate DataColumn EMPNO is unique
    // This is required by the OracleCommandBuilder to update the EMP table
    table.Columns["EMPNO"].Unique = true;
    // Get the first row from the EMP table
    DataRow row = table.Rows[0];
    // Update the salary
    double sal = double.Parse(row["SAL"].ToString());
    row["SAL"] = sal + .01;
    // Now update the EMP using the adapter
    // The OracleCommandBuilder will create the UpdateCommand for the
    // adapter to update the EMP table
    adapter.Update(dataset, "EMP");
    Console.WriteLine("Row updated successfully");
OracleDataAdapter Members
OracleDataAdapter members are listed in the following tables.
OracleDataAdapter Constructors
OracleDataAdapter constructors are listed in Table 5-29.
Table 5-29 OracleDataAdapter Constructors
Constructor Description
Instantiates a new instance of OracleDataAdapter class (Overloaded)
OracleDataAdapter Static Methods
The OracleDataAdapter static method is listed in Table 5-30.
Table 5-30 OracleDataAdapter Static Method
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleDataAdapter Properties
OracleDataAdapter properties are listed in Table 5-31.
Table 5-31 OracleDataAdapter Properties
Property Description
AcceptChangesDuringFill
Inherited from System.Data.Common.DataAdapter
Container
Inherited from System.ComponentModel.Component
ContinueUpdateOnError
DeleteCommand
A SQL statement or stored procedure to delete rows from an Oracle database
IdentityInsert
Determines whether or not to insert identity column values in the DataSet into the database when the Update method is invoked.
IdentityUpdate
Determines whether or not to update identity column values in the DataSet into the database when the Update method is invoked.
InsertCommand
A SQL statement or stored procedure to insert new rows into an Oracle database
MissingMappingAction
MissingSchemaAction
Requery
Determines whether or not the SelectCommand is reexecuted on the next call to Fill
ReturnProviderSpecificTypes
Determines if the Fill method returns ODP.NET-specific values or .NET common language specification values
SafeMapping
Creates a mapping between column names in the result set to .NET types, to preserve the data
Not available in the ODP.NET, Managed Driver
SelectCommand
A SQL statement or stored procedure that returns a single or multiple result set
Site
TableMappings
UpdateBatchSize
Specifies a value that enables or disables batch processing support, and specifies the number of SQL statements that can be executed in a single round-trip to the database
UpdateCommand
A SQL statement or stored procedure to update rows from the DataSet to an Oracle database
OracleDataAdapter Public Methods
OracleDataAdapter public methods are listed in Table 5-32.
Table 5-32 OracleDataAdapter Public Methods
Public Method Description
CreateObjRef
Inherited from System.MarshalByRefObject
Dispose
Equals
Fill
Adds or refreshes rows in the DataSet to match the data in the Oracle database (Overloaded)
FillSchema
Inherited from System.Data.Common.DbDataAdapter
GetFillParameters
GetHashCode
GetLifetimeService
GetType
InitializeLifetimeService
ToString
Update
OracleDataAdapter Events
OracleDataAdapter events are listed in Table 5-33.
Table 5-33 OracleDataAdapter Events
Event Name Description
Disposed
FillError
RowUpdated
This event is raised when row(s) have been updated by the Update() method
RowUpdating
This event is raised when row data are about to be updated to the database
OracleDataAdapter constructors create new instances of an OracleDataAdapter class.
Overload List:
OracleDataAdapter()
This constructor creates an instance of an OracleDataAdapter class with no arguments.
Declaration
// C#
public OracleDataAdapter();
Remarks
Initial values are set for the following OracleDataAdapter properties as indicated:
  • MissingMappingAction = MissingMappingAction.Passthrough
  • MissingSchemaAction = MissingSchemaAction.Add
OracleDataAdapter(OracleCommand)
This constructor creates an instance of an OracleDataAdapter class with the provided OracleCommand as the SelectCommand.
Declaration
// C#
public OracleDataAdapter(OracleCommand selectCommand);
Parameters
  • selectCommand
    The OracleCommand that is to be set as the SelectCommand property.
Remarks
OracleDataAdapter(string, OracleConnection)
This constructor creates an instance of an OracleDataAdapter class with the provided OracleConnection object and the command text for the SelectCommand.
Declaration
// C#
public OracleDataAdapter(string selectCommandText, OracleConnection
    selectConnection);
Parameters
  • selectCommandText
    The string that is set as the CommandText of the SelectCommand property of the OracleDataAdapter.
  • selectConnection
    The OracleConnection to connect to the Oracle database.
Remarks
The OracleDataAdapter opens and closes the connection, if it is not already open. If the connection is open, it must be explicitly closed.
OracleDataAdapter(string, string)
This constructor creates an instance of an OracleDataAdapter class with the provided connection string and the command text for the SelectCommand.
Declaration
// C#
public OracleDataAdapter(string selectCommandText, string
   selectConnectionString);
Parameters
  • selectCommandText
  • selectConnectionString
    The connection string.
Remarks
The OracleDataAdapter static method is listed in Table 5-34.
Table 5-34 OracleDataAdapter Static Method
Method Description
Equals
OracleDataAdapter properties are listed in Table 5-35.
Table 5-35 OracleDataAdapter Properties
Container
DeleteCommand
IdentityInsert
IdentityUpdate
InsertCommand
MissingSchemaAction
Requery
SafeMapping
Not Available in ODP.NET, Managed Driver
SelectCommand
Site
TableMappings
UpdateBatchSize
UpdateCommand
DeleteCommand
This property is a SQL statement or stored procedure to delete rows from an Oracle database.
Declaration
// C#
public OracleCommand DeleteCommand {get; set;}
Property Value
An OracleCommand used during the Update call to delete rows from tables in the Oracle database, corresponding to the deleted rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the DeleteCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this.
IdentityInsert
When inserting DataSet data into the database, this property indicates whether the database generates the inserted row's identity column value or DataSet supplies this value.
Declaration
// C#
public bool IdentityInsert {get; set;}
Property Value
When set to true, ODP.NET inserts DataSet identity column values into the database. When set to false, the database determines the inserted identity column values.
Remarks
This property applies only to identity columns of type GENERATED BY DEFAULT and GENERATED BY DEFAULT ON NULL. Identity column of type GENERATED ALWAYS will ignore this property and will always use database generated values.
When set to false, the server will generate an identity value for the row. That generated identity value returns back to the client to update the DataSet value.
When this property is set to true for the GENERATED BY DEFAULT case and the application attempts to insert a NULL value into the database's identity column, the NOT NULL constraint is violated and an error occurs. ODP.NET will then allow the database to generate the identity column value and return the generated value to the DataSet.
The default value for this property is false.
IdentityUpdate
When updating DataSet data into the database, this property indicates whether to replace the database's identity column values with values of the DataSet or leave the current values unchanged.
Declaration
// C#
public bool IdentityUpdate {get; set;}
Property Value
When set to true, ODP.NET updates the database identity column values with the values of the DataSet. When set to false, the database identity columns are left unchanged.
Remarks
This property applies only to identity columns of type GENERATED BY DEFAULT and GENERATED BY DEFAULT ON NULL. In the case of type GENERATED ALWAYS, this property will be ignored and the database will always retain its current identity values.
When set to false, the existing identity column value in the server is returned to the DataSet.
When this property is set to true for the GENERATED BY DEFAULT and GENERATED BY DEFAULT ON NULL cases and the application attempts to update the database's identity column with a NULL value, the NOT NULL constraint is violated and an error occurs. ODP.NET will then not update the identity column value and instead return the database's existing identity column value to the DataSet.
InsertCommand
This property is a SQL statement or stored procedure to insert new rows into an Oracle database.
Declaration
// C#
public OracleCommand InsertCommand {get; set;}
Property Value
An OracleCommand used during the Update call to insert rows into a table, corresponding to the inserted rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the InsertCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this property.
Requery
This property determines whether or not the SelectCommand is reexecuted on the next call to Fill.
Declaration
// C#
public Boolean Requery {get; set;}
Property Value
Returns true if the SelectCommand is reexecuted on the next call to Fill; otherwise, returns false.
This property determines if the Fill method returns ODP.NET-specific values or .NET common language specification compliant values.
Declaration
// C#
public Boolean ReturnProviderSpecificTypes {get; set;}
Property Value
A value that indicates whether or not the Fill method returns ODP.NET-specific values. A value of false indicates that the Fill method returns .NET common language specification compliant values. The default is false.
SafeMapping
This property creates a mapping between column names in the result set to .NET types that represent column values in the DataSet, to preserve the data.
Declaration
// C#
public Hashtable SafeMapping {get; set;}
Property Value
A hash table.
Remarks
Default = null
The SafeMapping property is used, when necessary, to preserve data in the following types:
  • DATE
  • TimeStamp (refers to all TimeStamp objects)
  • INTERVAL DAY TO SECOND
  • NUMBER
Example
See the example in "OracleDataAdapter Safe Type Mapping".
SelectCommand
This property is a SQL statement or stored procedure that returns single or multiple result sets.
Declaration
// C#
public OracleCommand SelectCommand {get; set;}
Property Value
An OracleCommand used during the Fill call to populate the selected rows to the DataSet.
Remarks
Default = null
If the SelectCommand does not return any rows, no tables are added to the dataset and no exception is raised.
If the SELECT statement selects from a VIEW, no key information is retrieved when a FillSchema() or a Fill() with MissingSchemaAction.AddWithKey is invoked.
UpdateBatchSize
This property specifies a value that enables or disables batch processing support, and specifies the number of SQL statements that can be executed in a single round-trip to the database.
Declaration
// C#
public virtual int UpdateBatchSize {get; set;}
Property Value
An integer that returns the batch size.
Exceptions
ArgumentOutOfRangeException - The value is set to a number < 0.
Remarks
Update batches executed with large amounts of data may encounter an "PLS-00123: Program too large" error. To avoid this error, reduce the size of UpdateBatchSize to a smaller value.
For each row in the DataSet that has been modified, added, or deleted, one SQL statement will be executed on the database.
Values are as follows:
  • Value = 0
    The data adapter executes all the SQL statements in a single database round-trip
  • Value = 1 - Default value
    This value disables batch updating and SQL statements are executed one at a time.
  • Value = n where n > 1
    The data adapter updates n rows of data per database round-trip.
UpdateCommand
This property is a SQL statement or stored procedure to update rows from the DataSet to an Oracle database.
Declaration
// C#
public OracleCommand UpdateCommand {get; set;}
Property Value
An OracleCommand used during the Update call to update rows in the Oracle database, corresponding to the updated rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the UpdateCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this property.
OracleDataAdapter public methods are listed in Table 5-36.
Table 5-36 OracleDataAdapter Public Methods
CreateObjRef
Dispose
Equals
Fill
FillSchema
GetFillParameters
GetHashCode
GetLifetimeService
GetType
ToString
Update
Fill
Fill populates or refreshes the specified DataTable or DataSet.
Overload List:
Fill(DataTable, OracleRefCursor)
This method adds or refreshes rows in the specified DataTable to match those in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataTable dataTable, OracleRefCursor refCursor);
Parameters
  • dataTable
    The DataTable object being populated.
  • refCursor
    The OracleRefCursor that rows are being retrieved from.
Return Value
The number of rows added to or refreshed in the DataTable.
Exceptions
ArgumentNullException - The dataTable or refCursor parameter is null.
InvalidOperationException - The OracleRefCursor is already being used to fetch data.
NotSupportedException - The SafeMapping type is not supported.
Remarks
No schema or key information is provided, even if the Fill method is called with MissingSchemaAction set to MissingSchemaAction.AddWithKey.
Fill(DataSet, OracleRefCursor)
This method adds or refreshes rows in the DataSet to match those in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataSet dataSet, OracleRefCursor refCursor);
Parameters
  • dataSet
    The DataSet object being populated.
  • refCursor
Return Value
Returns the number of rows added or refreshed in the DataSet.
Exceptions
ArgumentNullException - The dataSet or refCursor parameter is null.
InvalidOperationException - The OracleRefCursor is ready to fetch data.
Remarks
If there is no DataTable to refresh, a new DataTable named Table is created and populated using the provided OracleRefCursor object.
Fill(DataSet, string, OracleRefCursor)
This method adds or refreshes rows in the specified source table of the DataSet to match those in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataSet dataSet, string srcTable, OracleRefCursor
   refCursor);
Parameters
  • dataSet
  • srcTable
    The name of the source table used in the table mapping.
  • refCursor
Return Value
Returns the number of rows added or refreshed into the DataSet.
Exceptions
InvalidOperationException - The OracleRefCursor is already being used to fetch data or the source table name is invalid.
Remarks
Fill(DataSet, int, int, string, OracleRefCursor)
This method adds or refreshes rows in a specified range in the DataSet to match rows in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataSet dataSet, int startRecord, int maxRecords,
   string srcTable, OracleRefCursor refCursor);
Parameters
  • dataSet
  • startRecord
    The record number to start with.
  • maxRecords
    The maximum number of records to obtain.
  • srcTable
  • refCursor
Return Value
This method returns the number of rows added or refreshed in the DataSet. This does not include rows affected by statements that do not return rows.
Exceptions
Remarks
OracleDataAdapter events are listed in Table 5-37.
Table 5-37 OracleDataAdapter Events
Disposed
FillError
RowUpdated
RowUpdating
RowUpdated
This event is raised when row(s) have been updated by the Update() method.
Declaration
// C#
public event OracleRowUpdatedEventHandler RowUpdated;
Event Data
The event handler receives an OracleRowUpdatedEventArgs object which exposes the following properties containing information about the event.
  • Command
    The OracleCommand executed during the Update.
  • Errors (inherited from RowUpdatedEventArgs)
    The exception, if any, is generated during the Update.
  • RecordsAffected (inherited from RowUpdatedEventArgs)
    The number of rows modified, inserted, or deleted by the execution of the Command.
  • Row (inherited from RowUpdatedEventArgs)
    The DataRow sent for Update.
  • StatementType (inherited from RowUpdatedEventArgs)
    The type of SQL statement executed.
  • Status (inherited from RowUpdatedEventArgs)
    The UpdateStatus of the Command.
  • TableMapping (inherited from RowUpdatedEventArgs)
    The DataTableMapping used during the Update.
Example
The following example shows how to use the RowUpdating and RowUpdated events.
// C#
using System;
using System.Data;
class RowUpdatedSample
  // Event handler for RowUpdating event
  protected static void OnRowUpdating(object sender,
                                      OracleRowUpdatingEventArgs e)
    Console.WriteLine("Row updating.....");
    Console.WriteLine("Event arguments:");
    Console.WriteLine("Command Text: " + e.Command.CommandText);
    Console.WriteLine("Command Type: " + e.StatementType);
    Console.WriteLine("Status: " + e.Status);
  // Event handler for RowUpdated event
  protected static void OnRowUpdated(object sender,
                                     OracleRowUpdatedEventArgs e)
    Console.WriteLine("Row updated.....");
  static void Main()
    string cmdstr = "SELECT EMPNO, ENAME, SAL FROM EMP";
    // Set the event handlers for the RowUpdated and the RowUpdating event
    // the OnRowUpdating() method will be triggered before the update, and
    // the OnRowUpdated() method will be triggered after the update
    adapter.RowUpdating += new OracleRowUpdatingEventHandler(OnRowUpdating);
    adapter.RowUpdated += new OracleRowUpdatedEventHandler(OnRowUpdated);
    // The OnRowUpdating() and the OnRowUpdated() methods will be triggered
RowUpdating
This event is raised when row data are about to be updated to the database.
Declaration
// C#
public event OracleRowUpdatingEventHandler RowUpdating;
Event Data
The event handler receives an OracleRowUpdatingEventArgs object which exposes the following properties containing information about the event.
  • Command
  • Errors (inherited from RowUpdatingEventArgs)
  • Row (inherited from RowUpdatingEventArgs)
  • StatementType (inherited from RowUpdatingEventArgs)
  • Status (inherited from RowUpdatingEventArgs)
  • TableMapping (inherited from RowUpdatingEventArgs)
Example
The example for the RowUpdated event also shows how to use the RowUpdating event. See RowUpdated event "Example".
