| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
The OracleIdentityType enumeration specifies how Oracle identity column values are generated.
Table 5-128 lists all the OracleIdentityType enumeration values with a description of each enumerated value.
Table 5-128 OracleIdentityType Members
| Member Name | Description |
Indicates that unique values are generated for every insertion. No updates or inserts are allowed for this identity column. |
Indicates that the values are generated only if no explicit value is provided for the identity column. Null values are not allowed for this identity column. |
Indicates that the values are generated only if no explicit value is provided or a |
Requirements
| Provider | ODP.NET, Unmanaged Driver | ODP.NET, Managed Driver |
| Assembly | Oracle.DataAccess.dll |
Oracle.ManagedDataAccess.dll |
| Namespace | Oracle.DataAccess.Client |
Oracle.ManagedDataAccess.Client |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 | 4.0, 4.5 |
See Also:
