Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleParameterStatus Enumeration
The OracleParameterStatus enumeration type indicates whether a NULL value is fetched from a column, or truncation has occurred during the fetch, or a NULL value is to be inserted into a database column.
Table 5-129 lists all the OracleParameterStatus enumeration values with a description of each enumerated value.
Table 5-129 OracleParameterStatus Members
Member Name Description
Success
Indicates that (for input parameters) the input value has been assigned to the column. For output parameter, it indicates that the provider assigned an intact value to the parameter.
NullFetched
Indicates that a NULL value has been fetched from a column or an OUT parameter.
NullInsert
Indicates that a NULL value is to be inserted into a column.
Truncation
Indicates that truncation has occurred when fetching the data from the column.
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
