Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
IOracleCustomType Interface
IOracleCustomType is an interface for converting between a Custom Type and an Oracle Object or Collection Type.
Declaration
// C#
public interface IOracleCustomType
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Types
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
IOracleCustomType Members
IOracleCustomType members are listed in the following tables.
IOracleCustomType Interface Methods
IOracleCustomType interface methods are listed in Table 16-22.
Table 16-22 IOracleCustomType Interface Methods
Interface Method Description
FromCustomObject
Returns the values that set the Oracle Object attributes
ToCustomObject
Provides the Oracle Object with the attribute values to set on the custom type
IOracleCustomType Interface methods are listed in Table 16-23.
Table 16-23 IOracleCustomType Interface Methods
FromCustomObject
ToCustomObject
FromCustomObject
This interface method creates an Oracle Object or Collection by setting the attribute or element values respectively on the specified Oracle UDT.
Declaration
// C#
void FromCustomObject(OracleConnection con, IntPtr pUdt);
Parameters
  • con
    An OracleConnection instance.
  • pUdt
    An opaque pointer to the Oracle Object or Collection to be created.
Remarks
The FromCustomObject method is used to build an Oracle Object or Collection from a custom object by setting attribute or element values respectively through the OracleUdt.SetValue method.
The OracleUdt.SetValue method is invoked as follows:
  • Oracle Object Type
    For a custom type that represents an Oracle Object Type, the OracleUdt.SetValue method must be invoked for each non-NULL attribute value that needs to be set.
  • Oracle Collection Type
    For a custom type that represents an Oracle Collection Type, a single call to OracleUdt.SetValue method specifies the collection element values.
ToCustomObject
This interface initializes a custom object using the specified Oracle UDT.
Declaration
// C#
void ToCustomObject (OracleConnection con, IntPtr pUdt);
Parameters
  • con
  • pUdt
    An opaque pointer to the Oracle UDT.
Remarks
The ToCustomObject method is used to initialize a custom object from the specified Oracle Object or Collection by retrieving attribute or element values respectively through the OracleUdt.GetValue method.
The OracleUdt.GetValue method is invoked as follows:
    For a custom type that represents an Oracle Object Type, the OracleUdt.GetValue method must be invoked for each attribute value to be retrieved.
  • For a custom type that represents an Oracle Collection Type, a single call to OracleUdt.GetValue method retrieves the collection element values.
