| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
The OracleArrayMappingAttribute class is required to mark a custom class field or property with information that ODP.NET uses when a custom type represents an Oracle Collection type.
Class Inheritance
System.Object
System.Attribute
System.OracleArrayMappingAttribute
Declaration
[AttributeUsageAttribute(AttributeTargets.Field|AttributeTargets.Property, AllowMultiple=false, Inherited=true)]
// C# public sealed class OracleArrayMappingAttribute : Attribute
Requirements
| Provider | ODP.NET, Unmanaged Driver |
| Assembly | Oracle.DataAccess.dll |
| Namespace | Oracle.DataAccess.Types |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 |
Remarks
An OracleArrayMappingAttribute object must be specified when a custom type represents an Oracle Collection. This attribute is applied only to the custom class member that stores the collection elements.
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
OracleArrayMappingAttribute members are listed in the following tables.
OracleArrayMappingAttribute Constructors
OracleArrayMappingAttribute constructors are listed in Table 16-15.
Table 16-15 OracleArrayMappingAttribute Constructors
| Constructor | Description |
OracleArrayMappingAttribute Constructors |
Instantiates a new instance of |
OracleArrayMappingAttribute Static Methods
OracleArrayMappingAttribute static methods are listed in Table 16-16.
Table 16-16 OracleArrayMappingAttribute Static Methods
| Method | Description |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleArrayMappingAttribute Properties
OracleArrayMappingAttribute properties are listed in Table 16-17.
Table 16-17 OracleArrayMappingAttribute Properties
| Property | Description |
Inherited from |
OracleArrayMappingAttribute Methods
OracleArrayMappingAttribute methods are listed in Table 16-18.
Table 16-18 OracleArrayMappingAttribute Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleArrayMappingAttribute constructors create new instances of the OracleArrayMappingAttribute class.
Overload List:
This constructor creates and initializes an OracleArrayMappingAttribute object.
Declaration
// C# public OracleArrayMappingAttribute();
Remarks
An OracleArrayMappingAttribute object must be applied when a custom class represents an Oracle Collection type, to specify the custom class field or property that stores the collection elements.
The OracleArrayMappingAttribute can be applied to only one field or property in the custom class.
OracleArrayMappingAttribute static methods are listed in Table 16-19.
Table 16-19 OracleArrayMappingAttribute Static Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleArrayMappingAttribute properties are listed in Table 16-20.
OracleArrayMappingAttribute methods are listed in Table 16-21.
Table 16-21 OracleArrayMappingAttribute Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
