| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
Table 12-30 lists all the OracleAQDequeueMode enumeration values with a description of each enumerated value.
Table 12-30 OracleAQDequeueMode Members
| Member Name | Description |
Reads the message without acquiring any lock on the message. This is equivalent to a |
Reads and obtains a write lock on the message. The lock lasts for the duration of the transaction. This is equivalent to a |
Reads the message and updates or deletes it. This is the default. The message can be retained in the queue table based on the retention properties |
Confirms receipt of the message but does not deliver the actual message content. |
Requirements
| Provider | ODP.NET, Unmanaged Driver |
| Assembly | Oracle.DataAccess.dll |
| Namespace | Oracle.DataAccess.Client |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 |
