Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleAQMessageAvailableEventArgs Class
The OracleAQMessageAvailableEventArgs class provides event data for the OracleAQQueue.MessageAvailable event.
Class Inheritance
System.Object
  System.EventArgs
    Oracle.DataAccess.Client.OracleAQMessageAvailableEventArgs
Declaration
// C#
public sealed class OracleAQMessageAvailableEventArgs
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
This class cannot be inherited.
For detailed information on all the inherited properties and methods, please read the documentation provided by Microsoft's .NET Documentation.
OracleAQMessageAvailableEventArgs Members
OracleAQMessageAvailableEventArgs members are listed in the following tables.
OracleAQMessageAvailableEventArgs Properties
OracleAQMessageAvailableEventArgs properties are listed in Table 12-17.
Table 12-17 OracleAQMessageAvailableEventArgs Properties
Property Description
AvailableMessages
Specifies the number of messages that raised this notification.
ConsumerName
Provides the name of the consumer for which the message is available for dequeuing.
Correlation
Delay
Specifies the duration, in seconds, after which an enqueued message is available for dequeuing.
DeliveryMode
Specifies the delivery mode of the message.
EnqueueTime
Specifies the time when the message was enqueued.
ExceptionQueue
Specifies the name of the queue that the message is moved to if it cannot be processed successfully.
Expiration
Specifies the duration, in seconds, for which an enqueued message is available for dequeuing before expiring.
MessageId
Returns an array of message identifiers.
NotificationType
Indicates the type of notification such as regular, grouping, or timeout.
OriginalMessageId
Specifies the ID of the message, in the last queue, that generated this message.
Priority
Specifies the priority of the message.
QueueName
Indicates the name of the queue that contains the message to be dequeued.
SenderId
Identifies the original sender of the message.
State
Specifies the state of the message.
OracleAQMessageAvailableEventArgs properties are listed in Table 12-18.
Table 12-18 OracleAQMessageAvailableEventArgs Properties
AvailableMessages
ConsumerName
Correlation
Delay
DeliveryMode
EnqueueTime
ExceptionQueue
Expiration
MessageId
NotificationType
OriginalMessageId
Priority
QueueName
SenderId
State
AvailableMessages
This instance property specifies the number of messages that raised this notification.
Declaration
// C#
public int AvailableMessages{get;}
Property Value
An integer indicating the number of messages that raised this notification.
Remarks
The property value is 1 for a regular notification type. The notification type can be specified using the OracleAQQueue.Notification property.
This property is not relevant if the NotificationType is OracleAQNotificationType.Timeout.
ConsumerName
This property provides the name of the consumer for which the message is available for dequeuing.
Declaration
// C#
public string ConsumerName {get;}
Property Value
A string that identifies the name of the consumer.
Correlation
This instance property specifies the identification for the message.
Declaration
// C#
public string Correlation {get;}
Property Value
A string that specifies the identification for the message.
Remarks
This property specifies the correlation of the message for which the notification is raised. The consumer can then use this identification to dequeue specific messages by setting the "Correlation" property of the OracleAQDequeueOptions object.
Delay
This instance property specifies the duration, in seconds, after which an enqueued message is available for dequeuing.
Declaration
// C#
public int Delay {get;}
Property Value
An integer that indicates the duration, in seconds, after which an enqueued message is available for dequeuing.
DeliveryMode
This instance property specifies the delivery mode of the message.
Declaration
// C#
public OracleAQMessageDeliveryMode DeliveryMode {get;}
Property Value
An OracleAQMessageDeliveryMode enumerated value.
EnqueueTime
This instance property specifies the time when the message was enqueued.
Declaration
// C#
public DateTime EnqueueTime {get;}
Property Value
A DateTime object.
ExceptionQueue
This instance property specifies the name of the queue that the message is moved to if it cannot be processed successfully.
Declaration
// C#
public string ExceptionQueue {get;}
Property Value
The name of the queue that a message to is moved if it cannot be processed successfully.
Expiration
This instance property specifies the duration, in seconds, for which an enqueued message is available for dequeuing before expiring.
Declaration
// C#
public int Expiration {get;}
Property Value
An integer that specifies the duration, in seconds, for which an enqueued message is available for dequeuing.
MessageId
This instance property returns an array of message identifiers.
Declaration
// C#
public byte[][] MessageId{get;}
Property Value
A byte[][] that specifies the message identifiers received as part of the notification.
Remarks
This property specifies the message identifiers of the messages that raise the notification.
The size of the MessageId array is 1 for regular notifications. The size of the MessageId array is 1 for grouping notifications if the notification grouping type is OracleAQNotificationGroupingType.Last. This property is not relevant if the NotificationType is OracleAQNotificationType.Timeout.
NotificationType
This property indicates the type of notification such as regular, grouping, or timeout.
Declaration
// C#
public OracleAQNotificationType NotificationType {get;}
Property Value
An OracleAQNotificationType enum value.
OriginalMessageId
This property specifies the ID of the message, in the last queue, that generated this message.
Declaration
// C#
public byte[] OriginalMessageId {get;}
Property Value
A byte[] that specifies the original message ID.
Priority
This instance property specifies the priority of the message.
Declaration
// C#
public int Priority {get;}
Property Value
An integer that specifies the priority of the message.
QueueName
This property indicates the name of the queue that contains the message to be dequeued.
Declaration
// C#
public string QueueName {get;}
Property Value
A string.
SenderId
This property identifies the original sender of the message.
Declaration
// C#
public OracleAQAgent SenderId {get;}
Property Value
An OracleAQAgent object.
State
This instance property specifies the state of the message.
Declaration
// C#
public OracleAQMessageState State {get;}
Property Value
An OracleAQMessageState enumerated value.
