| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
Table 12-34 lists all the OracleAQNavigationMode enumeration values with a description of each enumerated value.
Table 12-34 OracleAQNavigationMode Members
| Member Name | Description |
Retrieves the first message that is available and matches the search criteria. This resets the position to the beginning of the queue. |
Indicates that a call to You can use the |
Retrieves the next message that is available and matches the search criteria. If the previous message belongs to a message group, AQ retrieves the next available message that matches the search criteria and belongs to the message group. |
Skips the remainder of the current transaction group (if any) and retrieves the first message of the next transaction group. |
Requirements
| Provider | ODP.NET, Unmanaged Driver |
| Assembly | Oracle.DataAccess.dll |
| Namespace | Oracle.DataAccess.Client |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 |
