Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleNotificationRequest Class
An OracleNotificationRequest class represents a notification request to be subscribed in the database. It contains information about the request and the characteristics of the notification. Using the OracleNotificationRequest class, Oracle Data Provider for .NET can create the notification registration in the database.
Class Inheritance
System.Object
  Oracle.DataAccess.Client.OracleNotificationRequest
Declaration
// C#
public sealed class OracleNotificationRequest
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Not supported in a .NET stored procedure
Thread Safety
All public static methods are thread-safe, although methods do not guarantee thread safety.
OracleNotificationRequest Members
OracleNotificationRequest members are listed in the following tables.
OracleNotificationRequest Static Method
The OracleNotificationRequest static method is listed in Table 9-12.
Table 9-12 OracleNotificationRequest Static Method
Static Method Description
Equals
Inherited from System.Object
OracleNotificationRequest Properties
OracleNotificationRequest properties are listed in Table 9-13.
Table 9-13 OracleNotificationRequest Properties
Properties Description
IsNotifiedOnce
Indicates whether or not the registration is to be removed upon notification
IsPersistent
Indicates whether or not the notification message should be queued persistently in the database before delivery
Timeout
Specifies the time that the registration remains alive
GroupingNotificationEnabled
Specifies whether grouping notification is enabled or not
GroupingType
Specifies the type of grouping notification
GroupingInterval
Specifies the interval between grouping notifications, in seconds
OracleNotificationRequest Methods
OracleNotificationRequest methods are listed in Table 9-14.
Table 9-14 OracleNotificationRequest Methods
Methods Description
Equals
GetHashCode
GetType
ToString
OracleNotificationRequest Static Methods
The OracleNotificationRequest static method is listed in Table 9-15.
Table 9-15 OracleNotificationRequest Static Method
Equals
The OracleNotificationRequest properties are listed in Table 9-16.
Table 9-16 OracleNotificationRequest Properties
IsNotifiedOnce
IsPersistent
Timeout
GroupingType
GroupingInterval
IsNotifiedOnce
This property indicates whether or not the registration is to be removed upon notification.
Declaration
// C#
public bool IsNotifiedOnce{get; set;}
Property Value
A bool value that indicates whether or not the registration is to be removed upon notification.
Remarks
The default value is false for AQ. This is different from change notification where the default value is true.
Modifying this property after the completion of a successful registration has no effect.
IsPersistent
This property indicates whether or not the notification message should be queued persistently in the database until delivery.
Declaration
// C#
public bool IsPersistent{get; set;}
Property Value
A bool value that indicates whether or not the notifications should be stored persistently in the database until delivery.
When the IsPersistent property is set to True, the message is queued persistently in the database and cannot be lost upon database failures or shutdowns. When the IsPersistent property is set to False, the message is stored in an in-memory queue before delivery and could be lost.
This property does not apply to NotificationRegistration which is always persistent.
This property only applies to the notification message after it has been sent.
Remarks
The default value is false.
The database performs faster if the message is stored in an in-memory queue rather than a database queue.
This property is ignored for grouping notifications.
Timeout
This property specifies the time, in seconds, that the registration remains alive.
Declaration
// C#
public long Timeout{get; set}
Property Value
A long value that specifies the time, in seconds, that the registration remains alive. The valid values for the Timeout property are between 0 and 4294967295.
Exceptions
ArgumentOutOfRangeException - The specified Timeout is invalid.
Remarks
The default value is 0 (infinite) for AQ and 50000 for change notification. If the Timeout property is set to 0, then the registration does not expire.
If the registration is removed because the Timeout value has been reached, then the database sends a notification indicating the expiration.
This property specifies whether grouping notification is enabled or not.
Declaration
// C#
public bool GroupingNotificationEnabled {get; set}
Property Value
A true value indicates that grouping notification is enabled. A false value indicates that grouping notification is disabled.
Remarks
GroupingType
This property specifies the type of grouping notification.
Declaration
// C#
public OracleAQNotificationGroupingType GroupingType {get; set}
Property Value
An OracleAQNotificationGroupingType enum value
Remarks
The default value is OracleAQNotificationGroupingType.Summary.
GroupingInterval
This property specifies the interval of grouping notification in seconds. The group notifications are delivered at intervals specified by this property.
Declaration
// C#
public int GroupingInterval {get; set}
Property Value
An integer specifying the grouping interval in seconds.
Remarks
The default value is 600 seconds.
The range of GroupingInterval is from 0 to Int32.MaxValue.
OracleNotificationRequest methods are listed in Table 9-17.
Table 9-17 OracleNotificationRequest Methods
Methods Description
Equals
GetHashCode
GetType
ToString
