Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleNotificationEventArgs Class
The OracleNotificationEventArgs class provides event data for a notification.
Class Inheritance
System.Object
  System.EventArgs
    Oracle.DataAccess.Client.OracleNotificationEventArgs
Declaration
// C#
public sealed class OracleNotificationEventArgs
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Not supported in a .NET stored procedure
Thread Safety
All public static methods are thread-safe, although methods do not guarantee thread safety.
OracleNotificationEventArgs Members
OracleNotificationEventArgs members are listed in the following tables.
OracleNotificationEventArgs Static Fields
The OracleNotificationEventArgs static field is listed in Table 9-18.
Table 9-18 OracleNotificationEventArgs Static Field
Static Field Description
Empty
Inherited from System.EventArgs
OracleNotificationEventArgs Static Methods
The OracleNotificationEventArgs static method is listed in Table 9-19.
Table 9-19 OracleNotificationEventArgs Static Method
Static Method Description
Equals
Inherited from System.Object
OracleNotificationEventArgs Properties
OracleNotificationEventArgs properties are listed in Table 9-20.
Table 9-20 OracleNotificationEventArgs Properties
Properties Description
Details
Contains detailed information about the current notification
Info
Indicates the database events for the notification
ResourceNames
Indicates the database resources related to the current notification
Source
Returns the database event source for the notification
Type
Returns the database event type for the notification
OracleNotificationEventArgs Methods
OracleNotificationEventArgs methods are listed in Table 9-21.
Table 9-21 OracleNotificationEventArgs Methods
Methods Description
Equals
GetHashCode
GetType
ToString
The OracleNotificationEventArgs static field is listed in Table 9-22.
Table 9-22 OracleNotificationEventArgs Static Field
Empty
The OracleNotificationEventArgs static method is listed in Table 9-23.
Table 9-23 OracleNotificationEventArgs Static Method
Equals
OracleNotificationEventArgs properties are listed in Table 9-24.
Table 9-24 OracleNotificationEventArgs Properties
Details
Info
ResourceNames
Source
Type
Details
This property contains detailed information about the current notification.
Declaration
// C#
Public DataTable Details{get;}
Property Value
A DataTable instance that contains detailed information about the current notification.
Remarks
The returned DataTable object contains column data about the current notification in order as shown in Table 9-25.
Table 9-25 DataTable Object Column Data
Name Type Description
ResourceName
System.String
The resource name of the invalidated object in the format <Schema_name>.<object_name>
Info
OracleNotificationInfo
The information about the database event that occurs on a resource
Rowid
System.String
The rowid for the invalidated table row
QueryId
Int32
The CHANGE_NOTIFICATION_QUERY_ID
The QueryId column contains the CHANGE_NOTIFICATION_QUERY_ID that corresponds to the pseudo-column that may have been retrieved by a SELECT statement at the time of the query-based notification. Also, the OracleDependency object maintains all the CHANGE_NOTIFICATION_QUERY_IDs that are registered with it.
For Continuous Query Notification:
  • The Details property indicates changes for each invalidated object in the notification in the data table.
  • If ROWID information is requested, then the ROWID information is populated into the Rowid column. However, if many rows are modified in a table, then the whole table is invalidated, and ROWID information is not provided. Therefore, the Rowid column contains all Null values.
  • If the database event is related to a DDL change of the table or a table drop, then the Rowid column is set to Null.
Info
This property indicates the database events for the notification.
Declaration
// C#
public OracleNotificationInfo Info{get;}
Property Value
An OracleNotificationInfo value that indicates the database event for the notification.
Remarks
The OracleNotificationInfo value is an enumeration type. If several events are received from the invalidation message, the Info property is set to one of the OracleNotificationInfo enumeration values associated with the database events. For example, if a table has been altered and a new row has been inserted into another table, the Info property is set to either OracleNotificationInfo.Altered or OracleNotificationInfo.Insert.
To obtain more detailed information from the invalidation message, use the Details and the ResourceNames properties.
ResourceNames
This property indicates the database resources related to the current notification.
Declaration
// C#
public string[] ResourceNames{get;}
Property Value
A string array that indicates the database resources related to the current notification.
Remarks
For Continuous Query Notification, the ResourceNames property contains information about the invalidated object names in the format <schema_name>.<object _name>. To obtain more detailed information about the changes for invalidated objects, use the Details property.
Source
This property returns the database event source for the notification.
Declaration
// C#
public OracleNotificationSource Source{get;}
Property Value
The OracleNotificationSource value for the notification.
Remarks
The OracleNotificationSource value is an enumeration type. If several event sources are received from the notification message, the Source property is set to one of the OracleNotificationSource enumeration values related to the database event source. For example, if a table has been altered (by the ALTER TABLE command) and a new row has been inserted into the same table, the Source property is set to either OracleNotificationSource.Object or OracleNotificationSource.Data.
  • When the Source property is set to OracleNotificationSource.Data:
    • The Info property is set to one of the following:
      • OracleNotificationInfo.Insert
      • OracleNotificationInfo.Delete
      • OracleNotificationInfo.Update
    • The ResourceNames property is set, and the elements are set to the invalidated object names.
    • The Details property contains detailed information on the change of each invalidated table.
  • When the Source property is set to OracleNotificationSource.Database:
      • OracleNotificationInfo.Startup
      • OracleNotificationInfo.Shutdown
      • OracleNotificationInfo.Shutdown_Any
      • OracleNotificationInfo.Dropped
  • When the Source property is set to OracleNotificationSource.Object:
    • The Info property is set to either OracleNotificationInfo.Altered or OracleNotificationInfo.Dropped.
    • The ResourceNames property is set, and the array elements of the ResourceNames property are set to the object names that have been altered or dropped.
    • The Details property contains detailed information on the changes of the object.
  • When the Source property is set to OracleNotificationSource.Subscription:
    • The Info property is set to the following:
      • OracleNotificationInfo.End
Type
This property returns the database event type for the notification.
Declaration
// C#
public OracleNotificationType Type{get;}
Property Value
An OracleNotificationType enumeration value that represents the type of the database event notification.
Remarks
The OracleNotificationType value is an enumeration type. If several event types are received from the notification message, then the Type property is set to one of the OracleNotificationType enumeration values related to the database event type.
OracleNotificationEventArgs methods are listed in Table 9-26.
Table 9-26 OracleNotificationEventArgs Methods
Methods Description
Equals
GetHashCode
GetType
ToString
