Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleRowUpdatingEventArgs Class
The OracleRowUpdatingEventArgs class provides event data for the OracleDataAdapter.RowUpdating event.
Class Inheritance
System.Object
  System.EventArgs
    System.RowUpdatingEventArgs
      System.OracleRowUpdatingEventArgs
Declaration
// C#
public sealed class OracleRowUpdatingEventArgs : RowUpdatingEventArgs
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The example for the RowUpdated event shows how to use OracleRowUpdatingEventArgs. See RowUpdated event "Example".
OracleRowUpdatingEventArgs Members
OracleRowUpdatingEventArgs members are listed in the following tables.
OracleRowUpdatingEventArgs Constructors
OracleRowUpdatingEventArgs constructors are listed in Table 5-110.
Table 5-110 OracleRowUpdatingEventArgs Constructors
Constructor Description
Instantiates a new instance of OracleRowUpdatingEventArgs class (Overloaded)
OracleRowUpdatingEventArgs Static Methods
The OracleRowUpdatingEventArgs static methods are listed in Table 5-111.
Table 5-111 OracleRowUpdatingEventArgs Static Methods
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleRowUpdatingEventArgs Properties
The OracleRowUpdatingEventArgs properties are listed in Table 5-112.
Table 5-112 OracleRowUpdatingEventArgs Properties
Property Description
Command
Specifies the OracleCommand that is used when the OracleDataAdapter.Update() is called
Errors
Inherited from System.Data.Common.RowUpdatingEventArgs
Row
StatementType
Status
TableMapping
OracleRowUpdatingEventArgs Public Methods
The OracleRowUpdatingEventArgs public methods are listed in Table 5-113.
Table 5-113 OracleRowUpdatingEventArgs Public Methods
Public Method Description
Equals
GetHashCode
GetType
ToString
The OracleRowUpdatingEventArgs constructor creates a new instance of the OracleRowUpdatingEventArgs class using the supplied data row, IDbCommand, type of SQL statement, and table mapping.
Declaration
// C#
public OracleRowUpdatingEventArgs(DataRow row, IDbCommand command,
    StatementType statementType, DataTableMapping tableMapping);
Parameters
  • row
    The DataRow sent for Update.
  • command
    The IDbCommand executed during the Update.
  • statementType
    The StatementType enumeration value indicating the type of SQL statement executed.
  • tableMapping
    The DataTableMapping used for the Update.
The OracleRowUpdatingEventArgs static method is listed in Table 5-114.
Table 5-114 OracleRowUpdatingEventArgs Static Method
Method Description
Equals
The OracleRowUpdatingEventArgs properties are listed in Table 5-115.
Table 5-115 OracleRowUpdatingEventArgs Properties
Command
Errors
Row
StatementType
Status
TableMapping
Command
This property specifies the OracleCommand that is used when the OracleDataAdapter.Update() is called.
Declaration
// C#
public new OracleCommand Command {get; set;}
Property Value
The OracleCommand executed when Update is called.
The OracleRowUpdatingEventArgs public methods are listed in Table 5-116.
Table 5-116 OracleRowUpdatingEventArgs Public Methods
Equals
GetHashCode
GetType
ToString
