Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
5 ADVMK-00001 to ADVMK-00028
ADVMK-00001: Module load succeeded. Build information: %2 %3 %4 built on %5.
Cause: The ADVM driver was started.
Action: None, this is informational.
ADVMK-00002: Module load failed with status %2. Build information: %3 %4 %5 built on %6.
Cause: There was a problem the prevented the ADVM driver from loading.
Action: Reboot the system.If this happens again please report this error to Oracle Support Services.
ADVMK-00003: Module unloaded.
Cause: The ADVM driver was unloaded.
ADVMK-00004: Volume %2 in diskgroup %3 created.
Cause: An ADVM volume was created.
ADVMK-00005: The attempt to create volume %2 in diskgroup %3 failed.
Cause: Informational.
Action: None
ADVMK-00006: Volume %2 in diskgroup %3 disabled.
Cause: The ADVM volume was disabled or deleted.
ADVMK-00007: The attempt to disable volume %2 in diskgroup %3 failed.
Action: None
ADVMK-00008: The attempt to open/mount volume %2 in diskgroup %3 failed.
Action: None
ADVMK-00009: Volume %2 in diskgroup %3 resized, new size is %4 MB.
Cause: An ADVM volume was resized.
ADVMK-00010: Mirror recovery for volume %2 in diskgroup %3 started.
Cause: A volume needing recovery was mounted.
ADVMK-00011: Mirror recovery for volume %2 in diskgroup %3 completed.
Cause: Mirror recovery finished successfully.
ADVMK-00012: Mirror recovery for volume %2 in diskgroup %3 failed.
Cause: Volume mirror recovery failed.
Action: Report this error to Oracle Support Services.
ADVMK-00013: Cluster reconfiguration started.
Action: None
ADVMK-00014: Cluster reconfiguration completed.
Action: None
ADVMK-00015: Cluster reconfiguration failed.
Cause: Informational. .
Action: None
ADVMK-00016: The ASM instance was shutdown.
Cause: ASM was shutdown.
ADVMK-00017: The ASM instance terminated unexpectedly. All ADVM volumes will be taken offline.
Cause: ASM aborted or was shutdown with the 'abort' keyword.
Action: Close all applications using these volumes and unmount the file systems. After restarting the instance, you may need to re-enable the volumes for use.
ADVMK-00018: Diskgroup %2 was dismounted with the force option. All ADVM volumes in this diskgroup will be taken offline.
Cause: The diskgroup was force dismounted.
Action: Close all applications using these volumes and unmount the file systems. After re-mounting the diskgroup, you may need to re-enable the volumes for use.
ADVMK-00019: Volume %2 in disk group %3 was taken offline, all attempts to read or write to this volume will fail.
Cause: The volume was in use when either ASM aborted, or the diskgroup containing the volume was force dismounted.
Action: The volume must be dismounted.
ADVMK-00020: A read error was reported to the ASM instance for volume %2 in diskgroup %3.
Cause: A I/O read request returned failure from one of the disks hosting the volume.
ADVMK-00021: A write error was reported to the ASM instance for volume %2 in disk group %3.
Cause: A I/O write request return failure from one of the disks hosting the volume.
ADVMK-00022: An internal error occurred.
Cause: An internal ADVM error occurred.
ADVMK-00023: Volume name collision between %2 and %3.
Cause: Volume name collision occurred.
ADVMK-00024: WARNING: the OKS and ADVM drivers have different build information.
Cause: Warning - The ADVM label version should match the OKS label version.
Action: None
ADVMK-00025: ADVM build %2.
Action: None
ADVMK-00026: ADVM contains fixes '%2'.
Action: None
ADVMK-00027: OKS build %2.
Action: None
ADVMK-00028: OKS contains fixes '%2'.
Action: None
