AMDU-00200: Unable to read [number] bytes from Disk Nnumber at offset [number]
Cause:
A read operation failed for the reported disk.
Action:
Ensure that the disk is functioning properly.
AMDU-00201: Disk Nnumber: 'string'
Cause:
An error occurred with the reported disk. This message indicates the disk path name for the AMDU reported disk number.
Action:
Refer to additional message(s) for details.
AMDU-00202: Cannot reopen disk Nnumber
Cause:
Attempt to reopen disk failed.
Action:
AMDU-00203: File Deleted. Cannot extract file string.
Cause:
Specified ASM file does not exist.
Action:
Correct the ASM file number or name specified for extract.
AMDU-00204: Disk Nnumber is in currently mounted diskgroup string.
Cause:
Action:
Ensure that the ASM file number or name is specified correctly.
AMDU-00205: Disk Nnumber open failed during deep discovery.
Cause:
Attempt to open disk failed during discovery.
Action:
AMDU-00206: Shallow discovery failed for string with asmlib string.
Cause:
Attempt to discover ASMLIB disks failed.
Action:
Contact Oracle Support Services.
AMDU-00207: Shallow discovery failed for string.
Cause:
Attempt to discover disks failed.
Action:
AMDU-00208: File directory block not found. Cannot extract file string.
Cause:
File directory block for specified file is out of bounds.
Action:
AMDU-00209: Corrupt block found: Disk Nnumber AU [number] block [number] type [number]
Cause:
Block validation failed for reported block
Action:
AMDU-00210: No disks found in diskgroup string
Cause:
No disks were discovered for the specified disk group.
Action:
Ensure that the disk group name is entered correctly and that the member disks are discoverable.
AMDU-00211: Inconsistent disks in diskgroup string.
Cause:
Disk discovery discovered disks with identical names in multiple disk groups.
Action:
Specify the disk discovery string so as to avoid doscovery of disks with nonunique names.
AMDU-00212: Scan of diskgroup string does not appear in report.
Cause:
AMDU cannot locate information about the specified disk group in the report file.
Action:
Ensure that the -directory option points to a directory with a report file and dump for the specified disk group.
AMDU-00213: Disk Nnumber not found for group string
Cause:
AMDU encountered a map file entry for a disk that does not exist in the the report file. The mapfile may have been corrupted.
Action:
Re-create the original dump. If the operation still fails, contact Oracle Support Services.
AMDU-00214: Image files were not created for diskgroup string.
Cause:
The original AMDU dump request specified -noimage.
Action:
Re-create the AMDU dump including image files.
AMDU-00215: Mirror miscompares on number blocks of file string
Cause:
Comparison of mirrored blocks revealed mismatches.
Action:
AMDU-00216: 0xbadfda7a written to number blocks of file string
Cause:
AMDU was unable to read a number of blocks from the disk. It has written "0xbadfda7a" in place of these blocks.
Action:
AMDU-00218: Voting file not found. Cannot extract file string.
Cause:
Voting file is not present in specified disk group.
Action:
Ensure that the disk group name is specified correctly.
AMDU-00500: Operating system dependent operation:string failed with status: string
Cause:
There was an operating system call error.
Action:
AMDU-00501: Operating system failure message: string
Cause:
Action:
AMDU-00502: failure occurred at: string
Cause:
Action:
AMDU-00503: additional information: string
Cause:
Action:
