CLSMDNS-00000: no error
Cause:
A command completely successfully.
Action:
No action is needed.
CLSMDNS-00001: GIPC endpoint creation failed.
Cause:
An attempt to create a GIPC endpoint for use multicast operations failed.
Action:
Examine the accompanying error (if any) and the log file for details as to why the operation failed.
CLSMDNS-00002: bind failed.
Cause:
An attempt to bind an address to a GIPC endpoint failed.
Action:
CLSMDNS-00003: address creation failed.
Cause:
An attempt to create a GIPC address failed.
Action:
CLSMDNS-00004: attribute setting failed.
Cause:
An attempt to set an attribute on a GIPC endpoint or address failed.
Action:
CLSMDNS-00005: interface registration failed.
Cause:
The registration of an interface with mDNS failed.
Action:
CLSMDNS-00006: failed to get name server list.
Cause:
An attempt to get the list of available name servers failed.
Action:
CLSMDNS-00007: mDNS initialization failed.
Cause:
The initialization of the mDNS subsystem failed.
Action:
CLSMDNS-00008: start of host query failed.
Cause:
The query for hosts from mDNS failed to start.
Action:
CLSMDNS-00009: stop of host query failed.
Cause:
Termination of the query for hosts from mDNS failed.
Action:
CLSMDNS-00010: Initialization of name server name retrieval failed.
Cause:
The initialization of the retrieval of the names of the name servers used by multicast DNS failed.
Action:
Examine the accompanying messages(s) that detail the platform error(s) for details about the exception.
CLSMDNS-00011: retrieval of name server name failed.
Cause:
The retrieval of the name of a name server to be used by multicast DNS failed.
Action:
CLSMDNS-00012: no name servers found.
Cause:
No name servers were found that could be used by multicast DNS.
Action:
Check the system configuration and ensure that or more DNS name servers are configured, operating and accessible.
CLSMDNS-00013: Send of response to DNS server failed.
Cause:
An attempt to send a response to a query from the DNS server failed.
Action:
Examine accompanying exceptions for details about the exact error.
CLSMDNS-00015: invalid record type: number
Cause:
The DNS server sent a record whose type is unknown.
Action:
This is a warning message which can be ignored because the error should occur very infrequently. If the error occurs frequently, Oracle Customer Support should be contacted.
CLSMDNS-02000: unknown error.
Cause:
An unknown error occurred. This error can occur when the multicast DNS server is not running.
Action:
If the multicast server is not running, start it and try the operation again. If it is running, this is an internal error and Oracle Customer Support should be contacted with details about how and when the error occurred.
CLSMDNS-02001: no such name exists.
Cause:
This error is internal and should not ordinarily be seen by the user.
Action:
Contact Oracle Customer Support.
CLSMDNS-02002: memory allocation failure.
Cause:
The allocation of process memory failed.
Action:
If memory is low on the system, terminate other processes and/or threads and try the operation again. Otherwise, this is an internal error and Oracle Customer Support should be contacted.
CLSMDNS-02003: invalid parameter.
Cause:
Action:
CLSMDNS-02004: invalid reference.
Cause:
Action:
CLSMDNS-02005: invalid state.
Cause:
Action:
CLSMDNS-02006: invalid flags.
Cause:
Action:
CLSMDNS-02007: operation is unsupported.
Cause:
Action:
CLSMDNS-02008: uninitialized.
Cause:
Action:
CLSMDNS-02009: no cache.
Cause:
Action:
CLSMDNS-02010: record or service is already registered.
Cause:
Action:
CLSMDNS-02011: name conflict found.
Cause:
Action:
CLSMDNS-02012: Invalid.
Cause:
Action:
CLSMDNS-02013: Firewall.
Cause:
Action:
CLSMDNS-02014: Incompatible.
Cause:
Action:
CLSMDNS-02015: invalid interface.
Cause:
Action:
CLSMDNS-02016: Refused.
Cause:
Action:
CLSMDNS-02017: no such record.
Cause:
Action:
CLSMDNS-02018: no authentication.
Cause:
Action:
CLSMDNS-02019: no such key.
Cause:
Action:
CLSMDNS-02020: error occurred while passing through NAT.
Cause:
Action:
CLSMDNS-02021: double NAT encountered.
Cause:
Action:
CLSMDNS-02022: invalid time.
Cause:
Action:
CLSMDNS-02023: invalid signature.
Cause:
Action:
CLSMDNS-02024: invalid key.
Cause:
Action:
CLSMDNS-02025: transient error.
Cause:
Action:
CLSMDNS-02250: connection pending.
Cause:
Action:
CLSMDNS-02251: connection failed.
Cause:
Action:
CLSMDNS-02252: connection established.
Cause:
Action:
CLSMDNS-02253: more memory needed for cache.
Cause:
Action:
CLSMDNS-02254: configuration changed.
Cause:
Action:
CLSMDNS-02255: memory free needed.
Cause:
Action:
