CLSNS-00000: no error
Cause:
Operation was successful.
Action:
No action needed.
CLSNS-00001: unspecified error
Cause:
An unknown error occurred. This is an internal error.
Action:
Contact Oracle Customer Support and provide details about how and when the error occurred.
CLSNS-00002: memory allocation of number bytes failed
Cause:
An operation failed because it was not possible to allocate enough process memory.
Action:
If memory is low on the system, terminate other processes and/or threads and try the operation again. Otherwise, this is an internal error and Oracle Customer Support should be contacted.
CLSNS-00003: string buffer too small. required: number provided: number
Cause:
Action:
CLSNS-00004: length of value "string": number exceeds maximum: number
Cause:
The value specified exceeds the maximum allowed.
Action:
Specify a shorter value. This error can occur when creating a TXT record. If it occurs in another context, it is an internal error. In that case, contact Oracle Customer Support and provide details about how and when the error occurred
CLSNS-00005: operation timed out
Cause:
A name resolution operation took too long to complete.
Action:
This can happen on a heavily loaded system, for example. Retry the operation a few more times. If it still does not succeed, contact Oracle Customer Support and provide details about how and when the error occurred.
CLSNS-00006: duplicate object
Cause:
Action:
CLSNS-00007: object not found
Cause:
Action:
CLSNS-00008: invalid argument: string
Cause:
Action:
CLSNS-00009: invalid context
Cause:
Action:
CLSNS-00010: invalid DNS message received
Cause:
Action:
CLSNS-00011: corrupt list
Cause:
Action:
CLSNS-00012: corrupt record
Cause:
Action:
CLSNS-00013: invalid property
Cause:
Action:
CLSNS-00014: invalid operation code
Cause:
Action:
CLSNS-00015: invalid record type: number
Cause:
Action:
CLSNS-00016: invalid flag
Cause:
Action:
CLSNS-00017: invalid status
Cause:
Action:
CLSNS-00018: invalid section: number
Cause:
Action:
CLSNS-00019: communications failure
Cause:
It was not possible to contact a naming service.
Action:
Examine the accompanying errors to determine what the cause may be.
CLSNS-00020: DNS configuration retrieval failed
Cause:
Retrieval of configuration information failed.
Action:
Examine any accompanying errors and logs for more information.
CLSNS-00021: permission denied
Cause:
An operation failed because the user did not have the necessary permissions.
Action:
CLSNS-00022: credential retrieval failure
Cause:
An operation failed because the user did not have the necessary credentials.
Action:
CLSNS-00023: connection to GNS failed
Cause:
The connection to the GNS server failed.
Action:
Examine the accompanying errors for more information about the error.
CLSNS-00024: unable to initialize GNS
Cause:
It was not possible to initialize the GNS server for the cluster.
Action:
Determine if GNS is running. If it is not, ask the administrator to start it. If GNS is running, it is an error and Oracle Customer Support should be contacted with the details of the error.
CLSNS-00025: unable to locate GNS
Cause:
It was not possible to locate the GNS server for the cluster.
Action:
CLSNS-00026: failed to resolve name with GNS
Cause:
It was not possible to resolve a name with GNS.
Action:
Examine the accompanying errors for details. If the name is indeed advertised with GNS, please contact Oracle Customer Support.
CLSNS-00027: operation is unsupported
Cause:
The specified operation is not supported.
Action:
This is an internally-visible error and should not ordinarily be seen by users. Contact Oracle Customer Support and provide details about how and when the error occurred.
CLSNS-00028: no space for record in message
Cause:
Not enough space exists in a DNS message for a record.
Action:
CLSNS-00029: advertisement of name "string" failed
Cause:
Advertisement of the records attached to specified name failed.
Action:
Examine the accompanying error messages for more information.
CLSNS-00030: deletion of name "string" failed
Cause:
Deletion of the records attached to the pecified name failed.
Action:
CLSNS-00031: refresh of name "string" failed
Cause:
Refresh of the records attached to the specified name failed.
Action:
CLSNS-00032: retrieval of GPnP profile failed
Cause:
The retrieval of the Grid Plug and Play profile failed.
Action:
See the accompanying error messages for more information.
CLSNS-00033: initialization of GPnP failed
Cause:
The initialization of Grid Plug and Play failed.
Action:
CLSNS-00034: number of retries exceeeded maximum: number
Cause:
The retries allotted for an operation exceeded the maximum.
Action:
Check to see if the name service being used is functioning correctly.
CLSNS-00035: Invalid IP address: string
Cause:
GNS discovery address was not in IPv4 nor IPv6 format.
Action:
Specify an address using IPv4 or IPv6 format.
