Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
24 DRG-10000 to DRG-52403
DRG-10000: failed to read column string.string
Cause: Error during read of specified text column
Action: check existence and privs of column
DRG-10001: can not access result table string
Cause: specified table does not exist or server does not have write privileges
Action: check result table
DRG-10002: can not insert into result table
Cause: text server is not privileged to insert, tablespace exhausted
Action: check privileges and tablespace
DRG-10011: invalid object name string
Cause: a table, column or procedure name specified had an invalid format. It is either too long or contains illegal characters. Probably you are passing in incorrect parameters.
Action: check parameter values
DRG-10015: id exceeds limit(2147483642) of a number
Cause: the limit of an id is 2147483642
Action: use an id with value 214748364 or under
DRG-10016: you must be the owner to modify this object
Cause: you tried to modify an object which you do not own
Action: have the owner modify the object
DRG-10017: you must be string to do this: string
Cause: you tried to modify an object which you have no privilege
DRG-10100: invalid argument found: string
Cause: invalid command argument was specified
Action: check the documentation for the legal arguments and re-execute the command
DRG-10101: no value for argument: string
Cause: this argument requires value(s)
Action: re-execute the command with the correct argument value(s)
DRG-10102: mandatory argument missing: string
Cause: this argument is mandatory
Action: re-execute the command and specify the argument
DRG-10103: illegal value for argument: string
Cause: an illegal value was passed to this argument
Action: check the documentation for the legal values for this argument
DRG-10200: invalid server personality mask: string
Cause: the specification for the server personality mask is invalid
Action: check the documentation and specify the correct mask
DRG-10202: server failed to register
Cause: the server failed to register itself with the data dictionary
Action: look at the next error on the stack
DRG-10203: server named string does not exist
Cause: update was called with the name of a server that does not exist
Action: correct the name of the server
DRG-10204: server update failed
Cause: the attempt to update the server failed
DRG-10205: server deregister failed
Cause: the attempt to deregister the server from the data dictionary failed
DRG-10206: failed to perform recovery for a server or client
Cause: Contact oracle support
Action: Contact oracle support
DRG-10301: timed out waiting for responses from servers
Cause: Not enough servers are running to handle the current system load, and a large backlog of commands has accumulated; perhaps no servers are running. This message could also indicate an internal error where one of the servers has crashed trying to process a given request
Action: Check that enough servers are running, and that they are processing commands of the correct type. For instance, a DDL command might timeout if all the servers are setup to exclusively process query commands. Also, check the server log files.
DRG-10302: interrupted waiting for responses from servers
Cause: User interrupted the request before it was completed
Action: Restart the request
DRG-10303: could not queue given commands to be processed
Cause: The given command or commands could not (all) be queued. This could indicate an extremely high system load, but it is more likely an internal error.
Action: Check if any servers are running to process the command.
DRG-10304: unexpected error sending command(s) to Oracle Text server
Cause: There was an unexpected error sending command(s) to server
Action: Call customer support.
DRG-10305: pipe string is full
Cause: Could not send command to pipe, because the pipe was full
Action: Check if any servers are running to process the commands on that pipe
DRG-10306: server terminated unexpectedly while processing command
Cause: The server shutdown during execution of your command. This could be caused by a shutdown abort, or by an internal error in the server.
Action: If the server terminated had an internal error, contact customer support.
DRG-10307: no servers running
Cause: Could not process command because no servers are running with the correct personality mask.
Action: Start some servers with correct personality mask.
DRG-10308: no server with the required string personality mask is running
DRG-10309: not enough job queue processes
Cause: Could not process command because no servers with the correct personality mask are running.
Action: increase the JOB_QUEUE_PROCESSES initialization parameter or reduce the parallel degree for this statement.
DRG-10310: servers were shutdown before processing request
Cause: The command could not be completed because the servers were shut down or terminated before processing the request.
Action: Start another server with the correct personality mask.
DRG-10311: remote send not supported
Cause: You tried to specify a database link in an index specification
Action: Specify only local index names
DRG-10312: logfile name must be specified
Cause: You tried to start logging without specifying a logfile name
Action: Specify a logfile name
DRG-10313: logging has already been started
Cause: You tried to start logging even though logging has already been started
Action: Stop logging first, or ignore
DRG-10314: logging has not been started
Cause: You tried to stop logging even though logging has not been started
Action: Start logging first, or ignore
DRG-10315: logging is not supported on MTS
Cause: You tried to start logging on MTS
Action: n/a
DRG-10500: CREATE_INDEX failed: column spec string
Cause: failed to create text index on the specified column
Action: See the next errors on stack and take appropriate action
DRG-10501: invalid stopword: string
Cause: The stopword specified cound be lexed into multiple tokens with current lexer preference
Action: Check lexer preference and Respecifies the stopword
DRG-10502: index string does not exist
Cause: the specified index does not exist or you do not have access to it.
Action: Specify an existing index
DRG-10503: table string cannot be indexed because it has no primary key
Cause: a textkey needs to be a single column unique key whose length does not exceed 64 bytes. no such key was defined as an unique index or declared as a primary or unique key constraint
Action: create a suitable textkey for the table or specify it explicitly in this procedure call
DRG-10504: primary key is required when using the DETAIL_DATASTORE
Cause: you tried to use the detail datastore to index a table with no primary key constraint
Action: add a primary key constraint on the table
DRG-10506: table does not exist: string
Cause: The table, view, or synonym specified does not exist. There may also be a permissions problem reading the table.
Action: Reinvoke the operation with the correct table name
DRG-10507: duplicate index name: string
Cause: the specified index already exists in the dictionary
Action: this index can be updated or deleted, however this is only allowed if there is no text index available on the text column
DRG-10509: invalid text column: string
Cause: the column specified is not valid
Action: check that the followings are valid: a) text column is of supported datatype b) valid table name, column name in the specification.
DRG-10510: stopword is missing
Cause: The stopword to be added was not specified.
Action: Specify the stopword
DRG-10511: index string does not exist or is incomplete
Cause: index creation is not complete
Action: create index before performing this operation
DRG-10513: index string metadata is corrupt
Cause: dictionary contains bad preferences for this index
Action: contact you DBA
DRG-10516: failed to perform DDL operation due to an Oracle error
Cause: the ddl operation requested has failed because of an Oracle error
Action: see the Oracle error on the stack and take the appropriate action
DRG-10517: index string is already valid
Cause: The index was in a valid state and did not need the requested operation.
Action: Check the requested operation
DRG-10518: an operation is in progress which conflicts with string request
Cause: another session is operating on this index. it could be: a) DML is requested and DDL is in progress or b) DDL is requested and DML is in progress operation on the index
Action: try again later
DRG-10520: failed to drop index: string
Cause: Failed to drop index on the specified index
DRG-10525: missing REBUILD keyword
Cause: all Oracle Text alter index options require the REBUILD keyword
Action: specify alter index with the REBUILD keyword
DRG-10528: primary keys of type string are not allowed
Cause: you tried to create an index on a table with an illegal primary key datatype
Action: change the textkey to one of the followings: VARCHAR2, NUMBER, VARCHAR, DATE, CHAR, MLSLABEL
DRG-10531: parallel parameter must be > 0
Cause: you called create index with parallel = 0
Action: specify with value > 0
DRG-10532: table is not partitioned
Cause: you called parallel create index on non-partitioned table
Action: recreate the table with partitions or remove the PARALLEL clause
DRG-10533: invalid user name: string
Cause: you specified a user name that is invalid
Action: specify the correct user name
DRG-10535: failed to optimize text index string
Cause: the optimize operation requested has failed because of an Oracle error
DRG-10549: length of the object name string exceeded the limit
Cause: object name has exceeded the maximun length of 30 bytes
Action: Reduce the length of the object name if you want to re-create it
DRG-10550: illegal syntax for index, preference, source or section name
Cause: name may have additional periods(.)
Action: check the syntax of the name
DRG-10553: illegal syntax for column specification string
Cause: column specification may have additional periods(.)
Action: check the syntax of column specification if you want to re-create it
DRG-10561: index string is not valid for requested operation
Cause: The index was not in a valid state due to some prior error.
Action: Drop index and create index again.
DRG-10562: missing alter index parameter
Cause: The parameter string was missing
Action: Provide correct parameter string with regard to the requested alter index operation.
DRG-10569: table or column does not exist: string
Cause: The table, view, synonym or column specified does not exist. There may also be a permissions problem reading the table.
Action: Reinvoke the operation with the correct table name or column name
DRG-10573: index string is obsolete
Cause: you specified an obsolete index
Action: perform upgrade_index on the index
DRG-10574: failed to upgrade text index string
Cause: the upgrade operation has failed because of an Oracle error
DRG-10579: must provide text query criteria
Cause: text query criteria is mandatory
Action: provide text query criteria
DRG-10580: parallel indexing is not supported: string
Cause: attempted to create index with parallel servers
Action: Drop index and set parallel to 1 in create index
DRG-10581: indirect datastores cannot be used with long or lob text columns
Cause: You tried to create an index on a long or lob column using an indirect datastore such as the file or url datastores
Action: Use direct datastore or a varchar column
DRG-10582: column string does not exist in table string
Cause: you specified an invalid column
Action: specify valid column
DRG-10583: TRUNCATE INDEX failed: string
Cause: Failed to truncate index
DRG-10584: failed to string string string due to an Oracle error
Cause: a DDL operation on an index object failed due to SQL error
Action: see following error
DRG-10595: ALTER INDEX string failed
Cause: failed to alter index
DRG-10597: invalid rebuild online operation
Cause: REBUILD ONLINE is not supported for requested operation.
Action: Alter index without the online option.
DRG-10598: invalid parallel operation
Cause: PARALLEL is not supported for requested operation.
Action: Alter index without the parallel option
DRG-10599: column is not indexed
Cause: The column specified is not indexed.
Action: Create index on the column before performing this operation
DRG-10601: failed to remove pending DML for this index
Cause: The system could not remove triggers setup to monitor updates to the requested table
Action: See next error on stack to determine course of action. Call Oracle support if necessary. Until this error is fixed, updates to all text columns in the given table may not be indexed.
DRG-10602: failed to queue DML change to column string for primary key string
Cause: The system could not record that a change had been made to the given column
DRG-10606: server failed to access the DML Queue
Cause: The server was had an error accessing the DML Queue
Action: See next error on stack.
DRG-10607: index meta data is not ready yet for queuing DML
Cause: the meta data for the index has not been created yet
Action: retry the DML operation
DRG-10608: rowid to primary key mapping not available in base table
Cause: Procedural replication is on and no rowid to primary key mapping available in base table
Action: Modify base table to include a primary key
DRG-10609: cannot encode composite key with more than 16 columns
Cause: Cannot encode composite key with more than 16 columns
Action: Modify base table to have composite key with less than 16 columns
DRG-10610: Procedure not supported with Procedural replication on: string
Cause: This procedure is not supporeted when Procedural replciation is on
Action: Turn off procedural replication to execute this procedure
DRG-10700: preference does not exist: string
Cause: the preference name specified does not exists
Action: retry with the correct preference name
DRG-10701: preference string.string already exists
Cause: the specified preference already exists
Action: must drop the preference if you want to re-create it.
DRG-10702: cannot create or modify preference in another user's schema
Cause: you tried to create a preference for another user
Action: owner or CTXSYS or a user who has CTXADMIN role should create preference
DRG-10703: invalid framework object string
Cause: you specified an invalid object type
Action: use a valid framework object
DRG-10704: preference string does not have an attribute named string
Cause: you tried to set value for a invalid attribute (not supported by the object.
Action: specify the correct attribute name
DRG-10705: invalid value string for attribute string
Cause: you tried to set an illegal value for an attribute
Action: specify the correct attribute value for the datatype of the attribute
DRG-10706: length of string exceeds maximum size of string
Cause: Parameter is too many bytes
Action: Correct preference setting and resubmit
DRG-10707: a value is required for attribute string of preference string
Cause: A required attribute was not provided
DRG-10708: invalid class id string for preference string
Cause: the specified class id is not correct for the specified preference
Action: specify the correct class id
DRG-10709: this preference is referenced by string and cannot be dropped
Cause: the specified preference is used as part of another preference and cannot be dropped until the referring preference is modified
Action: modify the referring preference
DRG-10710: Invalid value string for string attribute
Cause: Invalid value provided for save_copy attribute It should be one of these: (PLAINTEXT, FILTERED, NONE)
Action: Provide correct SAVE_COPY attribute value
DRG-10711: Invalid value for SAVE_COPY attribute: string
Cause: Invalid value provided for SAVE_COPY attribute. It should be a boolean value
Action: Provide boolean value for SAVE_COPY attribute
DRG-10712: preference string already has value for an attribute named string
Cause: Cannot call set_sec_grp_attr for an attribute whose value is already set in a preference
Action: Call add_sec_grp_attr_val to add an additional value for attribute
DRG-10713: preference string does not have any value for attribute named string
Cause: Cannot call add_sec_grp_attr_val for an attribute without calling set_sec_grp_attr for the same attribute
Action: Call set_sec_grp_attr to set value for attribute and then call add_sec_grp_attr_val to add an additional value for attribute
DRG-10714: cannot add or remove value for attribute named string
Cause: Cannot call add_sec_grp_attr_val or rem_sec_grp_attr_val for a boolean attribute
Action: Do not call add_set_grp_attr_val or rem_sec_grp_attr_val for a boolean attribute. Use set_sec_grp_attr and unset_sec_grp_attr instead.
DRG-10715: preference string has incompatible values for string and string
Cause: Cannot set related attributes to incompatible values
Action: Set or add a compatible value for related attributes
DRG-10716: invalid prefix_ns_mapping attribute value string
Cause: Value of prefix_ns_mapping is neither of the form xmlns:pfx="ns" nor of the form xmlns="ns"
Action: Call rem_sec_grp_attr_val to remove this prefix_ns_mapping attribute value.
DRG-10750: unknown parameter string
Cause: Unrecognized parameter
Action: Specify correct parameter
DRG-10751: invalid value for parameter
Cause: Wrong data type or out of range
Action: Specify correct parameter value
DRG-10752: DEFAULT_INDEX_MEMORY cannot be greater than MAX_INDEX_MEMORY
Cause: You tried to set DEFAULT_INDEX_MEMORY to a value higher than the maximum set in MAX_INDEX_MEMORY
Action: Specify a lower value
DRG-10753: invalid size (in bytes) string string
Cause: You specified an incorrectly formatted size string
Action: Specify a correctly formatted size string
DRG-10754: Size (in bytes) must be between string and string
Cause: You specified size (in bytes) which is outside the allowed range
Action: Specify size (in bytes) within the allowed range
DRG-10755: string and string have characters in common
Cause: the join character sets cannot have characters in common
Action: Correct the attribute values and resubmit
DRG-10756: neither text indexing nor theme indexing has been selected
Cause: INDEX_TEXT and INDEX_THEMES preferences both cannot be FALSE.
Action: Set either of INDEX_TEXT or INDEX_THEMES or both to TRUE.
DRG-10757: stoplist cannot have more than 4096 stopwords
Cause: a stoplist cannot have more than 4096 stopwords. This includes stopthemes.
Action: none required
DRG-10758: index owner does not have the privilege to use file or URL datastore
Cause: index owner does not have the role defined in FILE_ACCESS_ROLE
Action: grant index owner the appropriate role
DRG-10759: invalid role
Cause: the role does not exist in the database
Action: check the role name or create the role
DRG-10760: illegal format for procedure name
Cause: the procedure name specified is invalid. For instance, it may have a semicolon
Action: check the procedure name
DRG-10761: procedure string does not exist
Cause: the specified procedure could not be found
Action: check input. Try a fully-specified format such as OWNER.OBJECT
DRG-10762: index owner does not have access to procedure string
Cause: the index owner does not have execute privilege on the specified procedure
Action: grant index owner execute permission on the procedure
DRG-10763: value string is not a valid character set
Cause: the value specified for the filename_charset attribute of the file datastore is not a valid character set name
Action: specify a valid Oracle character set name
DRG-10764: only SYS can modify FILE_ACCESS_ROLE
Cause: For security reasons, only SYS can modify the FILE_ACCESS_ROLE system parameter
Action: Connect as SYS before modifying the parameter
DRG-10765: stoplist cannot have more than 250 stopclasses with stoppatterns
Cause: a stoplist cannot have more than 250 stopclasses with stoppatterns. This does not include NUMBERS stopclass.
DRG-10800: query failed: string string string
Cause: Failed to process the query
Action: Check the errors on stack and take appropriate action
DRG-10801: cannot create an SQE for another user
Cause: You tried to create an SQE for another user
Action: Remove owner from SQE name specification
DRG-10816: display/highlight call failed
Cause: See the next error on the stack.
Action: See the next error on the stack.
DRG-10817: CONTAINS term consists of stopword or phrase of stopwords: string
Cause: One or more terms within a CONTAINS query consist of just a stopword or a phrase of just stopwords
Action: Replace the stopword or use stopwords within phrases containing non-stopwords.
DRG-10819: could not open contains cursor
Cause: An error occurred while trying to open a contains cursor
Action: See accompanying error messages in the stack
DRG-10820: invalid contains cursor id
Cause: You tried to fetch or close a contains cursor with an id which does not exist.
Action: Review fetch or close invocation
DRG-10821: contains cursor is not open
Cause: You tried to fetch from a contains cursor which was not open.
Action: Open cursor first
DRG-10822: duplicate query name
Cause: You tried to create a stored query with a name already used.
Action: Use different name
DRG-10823: invalid query name
Cause: The query name specified is not valid
Action: Check the query name
DRG-10825: stored query does not exist: string
Cause: The specified stored query does not exist.
DRG-10826: no document with the specified textkey is found
Cause: There is no document with the specified textkey.
Action: Check the textkey
DRG-10827: open_con must be performed before count_last
Cause: last_count returns hit from in-memory query,so an in-memory query must be run before you can use count_last
Action: execute open_con before run count_last
DRG-10828: token string is longer than maximum length for column string
Cause: A token to be inserted in the feedback table is longer than the maximum allowed column size.
Action: Modify the query, or the column size for feedback table, or feedback procedure arguments accordingly.
DRG-10829: feedback id string is longer than the maximum length of string bytes
Cause: Feedback id is longer than the maximum allowed length for the feedback_id column.
Action: Use a smaller feedback_id.
DRG-10830: SHARELEVEL is not 0 or 1
Cause: You specified a sharelevel which is not 0 or 1
Action: Use sharelevel equal to 0 or 1 only.
DRG-10831: can not insert into feedback table string
Cause: Not privileged to insert.
Action: Check privileges.
DRG-10832: can not delete from feedback table string
Cause: Not privileged to delete.
DRG-10833: feedback failed
Cause: Failed to process feedback request
DRG-10834: upper-case form of section name string too long
Cause: upper-case form of the section name is longer then supported length
Action: reduce length of section name when adding section
DRG-10835: WITHIN operator not supported for theme index
Cause: WITHIN operator used in theme index query
Action: Rewrite query without WITHIN operator
DRG-10836: field section and attribute section can not be nested
Cause: A field section or a attribute section is specified in a nested section search
Action: Rewrite query without nested field sections
DRG-10837: section string does not exist
Cause: The given section name does not exist in USER_SECTIONS
Action: Rewrite query with valid section name
DRG-10838: invalid SPAN argument supplied to NEAR
Cause: An invalid value was supplied for SPAN argument to NEAR
Action: Provide a valid SPAN. Valid values are integers from 0 to 100.
DRG-10839: invalid ORDER argument supplied to NEAR
Cause: An invalid value was supplied for ORDER argument to NEAR
Action: Provide a valid ORDER. Valid values are T, TRUE, F, FALSE (case insensitive).
DRG-10840: CONTAINS predicate including 0 is not supported by FIRST_ROWS hint
Cause: User attempts to issue a query with CONTAINS predicate including 0 while giving FIRST_ROWS hint.
Action: remove FIRST_ROWS hint.
DRG-10841: invalid SCORE argument supplied to FUZZY
Cause: An invalid value was supplied for SCORE argument to FUZZY
Action: Provide a valid SCORE. Valid values are integers from 1 to 80.
DRG-10842: invalid NUMRESULTS argument supplied to FUZZY
Cause: An invalid value was supplied for NUMRESULTS argument to FUZZY
Action: Provide a valid NUMRESULTS. Valid values are integers from 0 to 5000.
DRG-10843: invalid WEIGHT argument supplied to FUZZY
Cause: An invalid value was supplied for WEIGHT argument to FUZZY
Action: Set WEIGHT to WEIGHT or NOWEIGHT.
DRG-10844: index cannot execute this structured predicate efficiently
Cause: You specified a combination of condition and order by columns in a catsearch query which cannot be executed by the index's index set efficiently
Action: n/a
DRG-10845: column string is not indexed
Cause: You specified a column in a condition or order by which is not part of the ctxcat index
Action: n/a
DRG-10846: order by columns must be all ascending or all descending
Cause: You specified an order by clause which has some columns ascending and some descending. This is not currently supported by catsearch
Action: n/a
DRG-10847: catsearch requires prefix index for this type of query
Cause: For efficient execution of this Vgram query, we require presence of a prefix index.
Action: create a prefix index
DRG-10848: invalid structured clause
Cause: you have specified an invalid structured clause
Action: n/a
DRG-10849: catsearch does not support functional invocation
Cause: the query plan for your query is invoking a catsearch operator functionally rather than as an index rowsource. The catsearch operator does not support functional invocation
Action: add optimizer hints so that all catsearch operators are performed through index scans
DRG-10850: CTXRULE indextype does not support the operator
Cause: Used an operator not supported by CTXRULE. Currently it only supports AND, NEAR, phrase, NOT, WITHIN, OR, ABOUT, EQUIVALENCE, STEM and THESAURUS operators
Action: Rewrite query without this operator
DRG-10851: Invalid grammar string specified for query template
Cause: incorrect grammar specification
Action: Rewrite query specifying valid grammar name
DRG-10852: Invalid scoring type string specified for query template
Cause: incorrect scoring type specification
Action: Rewrite query specifying valid scoring type (integer/float)
DRG-10853: Catsearch does not support this operator
Cause: unsupported operator specified
Action: Rewrite query using valid operators
DRG-10854: Invalid scoring algorithm string specified for query template
Cause: incorrect scoring algorithm specification
Action: Rewrite query specifying valid scoring algorithm (default/count)
DRG-10855: CTXRULE indextype does not support the token type
Cause: Unsupported VGRAM token type 1.
Action: n/a
DRG-10856: SDATA section string does not exist
Cause: The given SDATA section name does not exist in USER_SECTIONS
Action: Rewrite query with valid SDATA section name
DRG-10857: literal is not compatible with the data type of the SDATA section
Cause: The given literal is not compatible with the data type of the specified SDATA section.
Action: Rewrite query with a compatible literal
DRG-10858: SDATA operator is not allowed in WITHIN
DRG-10859: Only one predefined scoring component can be used in DEFINESCORE
Cause: More than one predefined scoring component (i.e. RELEVANCE, OCCURRENCE, etc.) is used in the scoring expression of the DEFINESCORE operator
Action: Rewrite query using only one predefined component
DRG-10860: All expressions under the same WITHIN must use the same predefined scoring component
Cause: The query side of the same within mixes different types of scoring components(i.e. RELEVANCE, OCCURRENCE, etc.)
Action: Rewrite query using only one type of predefined component
DRG-10861: COMPLETION score must be used with WITHIN operator
Cause: The completion score is used without using the WITHIN operator
Action: Rewrite query to include a within operator
DRG-10862: string attribute cannot be used with CTXRULE indexes
Cause: Used an attribute not supported by CTXRULE. This restriction is due to lack of wildcard support for CTXRULE indexes.
Action: Rewrite query without this attribute
DRG-10863: invalid ORDER argument supplied to NDATA
Cause: An invalid value was supplied for ORDER argument to NDATA
Action: Set ORDER to ORDER or NOORDER.
DRG-10864: invalid PROXIMITY argument supplied to NDATA
Cause: An invalid value was supplied for PROXIMITY argument to NDATA
Action: Set PROXIMITY to PROXIMITY or NOPROXIMITY.
DRG-10865: invalid datatype in user scoring expression
Cause: The scoring expression specified in DEFINESCORE or NORMALIZATION_EXPR in the query template either contains components with unsupported datatypes or does not return numerical values.
Action: Rewrite the scoring expression.
DRG-10866: The right hand operand of MINUS cannot use IGNORE score
Cause: The IGNORE score is used as the right hand operand of MINUS
DRG-10867: OCCURRENCE and COMPLETION score cannot be used with ABOUT in DEFINESCORE
Cause: The OCCURRENCE and COMPLETION score cannot be used with ABOUT queries
DRG-10868: matches does not support functional invocation
Cause: the query plan for your query is invoking a matches operator functionally rather than as an index rowsource. The matches operator does not support functional invocation
Action: add optimizer hints so that all matches operators are performed through index scans
DRG-10869: Invalid span supplied to NEAR2 operator
Cause: Near2 span must be between 0 and 100
Action: Use acceptable span
DRG-10870: Invalid weight supplied to NEAR2 operator
Cause: Near2 weights must be between 0 and 10
Action: Use acceptable weight
DRG-10871: NDATA operator not supported with string
Cause: NDATA operator is not supported in the specified operation
Action: Rewrite the query without NDATA operator
DRG-10872: Characters cannot be outside string in an XML query
Cause: Charaters outside query element are not valid
Action: Write the characters inside querytextquery
DRG-10873: Invalid characters location in the XML query
Cause: Charaters between certain elements are not allowed
Action: Write the characters in designed places
DRG-10874: Syntax error in XML Query Template
Cause: XML template is wrong. Possible causes include missing closing tag or receiving invalid attributes or characters.
Action: Check that the query is valid XML
DRG-10875: Missing closing tag in XML Query
Cause: Some tag has been opened and not closed properly.
Action: Close all tags properly
DRG-10876: Invalid ordering of elements in XML Query
Cause: Occurrence of some element that should be only between another element that was not found
Action: Check the proper ordering of elements
DRG-10877: query should always start an XML Query
Cause: Either query is missing or is wrongly possitioned
Action: Insert query properly
DRG-10878: Invalid ordering in XML Query: string should be string of string
Cause: Invalid ordering of tags as of specs
Action: Rewrite query properly
DRG-10879: Invalid string element repetition in XML Query
Cause: Invalid repetition of XML element
Action: Rewrite query, merging both repeated elements
DRG-10880: Invalid nesting of string in XML Query
Cause: Invalid nesting of same element has been encountered
Action: Either close element properly or avoid nesting
DRG-10881: Invalid setting of savescore in ctxfiltercache
Cause: savescore argument must be true or false
Action: set savescore to true or false
DRG-10882: Invalid setting of topn in ctxfiltercache
Cause: topn argument must be true or false
Action: set topn to true or false
DRG-10883: savescore must be true to use topn in ctxfiltercache
Cause: savescore must be true to use topn in ctxfiltercache
Action: set savescore to true to use topn processing
DRG-10884: invalid use of ctxfiltercache with topn
Cause: ctxfiltercache with topn must be child of AND, THRESHOLD, or WEIGHT operators
Action: invalid query
DRG-10885: ctxfiltercache operator requires non-zero query_filter_cache_size
Cause: used ctxfiltercache operator with zero query_filter_cache_size
Action: Set a non-zero query_filter_cache_size
DRG-10886: topn must be used with order by score desc in ctxfiltercache
Cause: must order query results by score desc when topn argument is true
Action: Add order by score desc and use oracle hint DOMAIN_INDEX_SORT
DRG-10887: Query cannot be processed, index partition is set to non-readable mode
Cause: Index partition has been set to non-readable mode
Action: Use 'alter index modify pratition' to set read mode to TRUE
DRG-10891: invalid MINREQD argument supplied to NEAR
Cause: An invalid value was supplied for MINREQD argument to NEAR
Action: Provide a valid MINREQD. Valid values are integers from 0 to 63.
DRG-10900: out of memory
Cause: can not allocate more memory
Action: Contact your system adminstrator
DRG-11000: invalid keyword string
Cause: A keyword was invalid.
Action: Respecify the parameter string with correct keyword
DRG-11001: missing keyword when expecting one of string
Cause: A keyword was missing.
Action: Respecify the parameter string with keyword
DRG-11002: missing value for string
Cause: A value for the argument was missing.
Action: Respecify the parameter string with value
DRG-11003: invalid value string for string
Cause: An invalid value was given for the argument
Action: Specify a valid value
DRG-11004: duplicate or conflicting value for string
Cause: More than one value has been specified for the argument
Action: Check parameter string and correct the problem parameter
DRG-11005: invalid create index parameter string
Cause: the supplied parameter string is not correct
Action: drop index and recreate index with correct parameters
DRG-11006: invalid alter index parameter string
Cause: The parameter string was invalid.
Action: Reissue the statement with the correct parameter string.
DRG-11007: multiple stopwords specified
Cause: Tried to add more than one stopword
Action: Specify one stopword at a time
DRG-11008: invalid create index partition parameter string
DRG-11100: unable to connect to the database
Cause: failed to connect to Oracle database
Action: check the Oracle error and connect string
DRG-11101: failed to open file string
Cause: failed to open a file
Action: check whether the file exist or access permission available
DRG-11102: assigned lexer can not operate on string language setting
Cause: Single byte lexer selected in multibyte language setting
Action: check RDBMS language setting or text columns lexer setting
DRG-11104: Oracle Text error:
Cause: See the next error on stack
Action: See the next error on stack
DRG-11106: user database session has terminated during this operation
Cause: this database session does not exist or has terminated
Action: determine why the user database session terminated while the operation was still being carried out.
DRG-11107: invalid path specification: string
Cause: the path specified is not valid
Action: check the path specification
DRG-11108: invalid filename specified: string
Cause: the filename specified is not valid
Action: check the filename for beginning or trailing spaces, invalid characters, or other such problems.
DRG-11109: assigned lexer does not support string query operator
Cause: This lexer does not support this query operator
Action: do not use the operator in your query
DRG-11111: value of string must be between string and string
Cause: You specified a value for the parameter which is out of range
Action: Specify a value which is in the allowed range
DRG-11112: length of string exceeds maximum of string
Cause: You specified a value for the parameter which is too long
Action: Specify a value which is less than or equal to the maximum length
DRG-11113: value of string must be one of string
Cause: You specified a value for the parameter which is invalid
Action: Specify a valid value for the parameter
DRG-11114: result table format is not correct for this operation
Cause: You specified a result table which has the wrong number, type, or names of columns for this operation.
Action: Check result table. Refer to the documentation for the correct format for each operation
DRG-11115: a value for string must be specified
Cause: You did not specify a value for the parameter
Action: Specify a value for the parameter
DRG-11116: value of string must be less than or equal to value of string
Cause: You specified values for the two parameters which are invalid
Action: Specify valid values for the parameters
DRG-11117: name is already used by an existing object
Cause: You tried to create an object whose name conflicts with an object of that type which already exists
Action: Specify a new name
DRG-11118: object string does not exist
Cause: You tried to modify or drop an object which does not exist
Action: Specify correct object name
DRG-11119: operation is not supported by this index type
Cause: You tried to invoke an operation on an index which is not supported by the index type
Action: n/a
DRG-11120: failed to write to file string
Cause: failed to write to a file
DRG-11121: failed to read from file string
Cause: failed to read from a file
DRG-11122: unsupported section group
Cause: unsupported section group is specified for functional contains
Action: change the section group to NULL_SECTION_GROUP
DRG-11123: theme indexing is not supported
Cause: theme indexing is on in the lexer preference for functional contains
Action: turn off theme indexing
DRG-11124: invalid value string
Cause: you specified an invalid value
Action: specify a valid value
DRG-11125: invalid format of existing log file string
Cause: the file specified by START_LOG already exists, and is not a previously written log file
Action: specify a new file, or remove the existing file
DRG-11126: context index is empty
Cause: the training table is empty or the context index of training table is not populated
Action: populate the training table or context index
DRG-11127: inconsistent index policy with trained rule
Cause: the ctxrule index policy is inconsistent with the policy in which the rule was trained
Action: change the ctxrule index policy
DRG-11128: invalid format of rule
Cause: the rule format is not valid for this operation
Action: check the rule type and operation type
DRG-11129: the rule table is empty
Cause: the rule table is empty
Action: populate the rule table by training
DRG-11130: no data found in the collection
Cause: feature preparation program can not find any feature in the specified collection
Action: check the setting for extracting features.
DRG-11131: Error from Oracle XML parser: string
Cause: The Oracle XML parser reported an error
Action: Check the document for the error, and fix if necessary
DRG-11132: Invalid character in logfile name
Cause: The logfile parameter to CTX_OUTPUT.START_LOG or CTX_OUTPUT.START_QUERY_LOG contains an invalid character (such as a forward slash)
Action: Remove the invalid character
DRG-11133: failed to convert a datatime value [ora-number]
Cause: Failed to convert the datetime value.
Action: Check the error code
DRG-11134: The file string is currenly being used for logging by another process
Cause: The file is currently being used by another process.
Action: Give a different file name.
DRG-11135: feature not generally available
Cause: You tried to use a feature not generally available.
Action: Contact customer support
DRG-11136: assigned lexer does not support entity extraction
Cause: This lexer does not support entity extraction
Action: Do not use this lexer for entity extraction
DRG-11137: tracing is not supported on MTS
Cause: you tried to use ctx_output tracing in an MTS session
Action: connect using a dedicated session and retry the operation
DRG-11138: trace string is already enabled
Cause: you tried to enable a trace that is already enabled
Action: disable the trace first
DRG-11139: trace string is not enabled
Cause: you tried to disable a trace that is not enabled
Action: enable the trace first
DRG-11140: Section string is not MDATA
Cause: you tried to perform MDATA operation on non-mdata section
Action: provide correct mdata section name
DRG-11141: CTX_DDL.REMOVE_MDATA() and CTX_DDL.ADD_MDATA() not allowed for MDATA Section string
Cause: you tried to call CTX_DDL.REMOVE_MDATA() or CTX_DDL.ADD_MDATA() on a MDATA section which is created with ALLOW_ADD_REM parameter set to FALSE.
Action: do not call CTX_DDL.REMOVE_MDATA() or CTX_DDL.ADD_MDATA() on a MDATA section that is created with ALLOW_ADD_REM parameter set to FALSE.
DRG-11142: string cannot be string
Cause: The value for the specified parameter cannot be as specified
Action: Specify the correct value
DRG-11143: Only 64 errors can be traced
Cause: You tried to trace more than 64 errors with ctx_output
Action: Trace fewer errors, or use DRG_DUMP_ALL_ERRORS
DRG-11144: Invalid value for radius parameter: string
Cause: You specified invalid value for radius parameter
Action: Provide non-negative/non-decimal value for radius parameter
DRG-11145: Invalid value for max_length parameter: string
Cause: You specified invalid value for max_length parameter
Action: Provide non-negative/non-decimal value for max_length parameter
DRG-11146: Invalid value for use_saved_copy: string
Cause: You specified invalid value for use_saved_copy parameter
Action: Use one of these: SAVE_COPY_FALLBACK / SAVE_COPY_ERROR / SAVE_COPY_IGNORE
DRG-11147: Invalid lexer for ctx_doc.policy_stems
Cause: You specified/used a lexer which does not support ctx_doc.policy_stems
Action: Use auto lexer for ctx_doc.policy_stems
DRG-11148: Invalid lexer for ctx_doc.policy_noun_phrases
Cause: You specified/used a lexer which does not support ctx_doc.policy_noun_phrases
Action: Use auto lexer for ctx_doc.policy_noun_phrases
DRG-11149: Invalid lexer for ctx_doc.policy_part_of_speech
Cause: You specified/used a lexer which does not support ctx_doc.policy_part_of_speech
Action: Use auto lexer for ctx_doc.policy_part_of_speech
DRG-11150: Reverse Index feature not enabled
Cause: Feature not enabled
Action: Enable Reverse Index feature
DRG-11203: INSO filter not supported on this platform
Cause: You tried to use the INSO filter on a platform which does not support it
Action: Do not use the INSO filter
DRG-11204: user filter command is too long
Cause: The user filter command must be 32 characters or less
Action: Specify a shorted user filter command
DRG-11205: user filter command contains illegal characters
Cause: The user filter command cannot contain special characters such as slashes, parentheses, semicolons, etc.
Action: Correct command specification
DRG-11206: user filter command string could not be executed
Cause: The user filter command could not be executed.
Action: Check that the command exists in $ORACLE_HOME/ctx/bin, and that it is executable.
DRG-11207: user filter command exited with status string
Cause: The user filter command exited with the given error status.
Action: See any DRG-11220, DRG-11221, DRG-11222, DRG-11223, DRG-11224, DRG-11225, or DRG-11227 error message on the error stack otherwise see error status.
DRG-11208: ORACLE_HOME is not set
Cause: ORACLE_HOME is not set
Action: make sure ORACLE_HOME is set when running ctxsrv
DRG-11209: filename for string exceeds maximum length of string
Cause: Value of the file name is too long
Action: Specify a shorter filename
DRG-11210: format column must be a char, varchar, or varchar2 type
Cause: you specified a format column which is not a char, varchar, or varchar2 type.
Action: specify a format column of correct type
DRG-11211: charset column must be a char, varchar, or varchar2 type
Cause: you specified a charset column which is not a char, varchar, or varchar2 type.
Action: specify a charset column of correct type
DRG-11212: procedure filter procedure name contains a semicolon
Cause: the procedure name specified had a semicolon
Action: remove semicolon or rename procedure name. The correct format is PACKAGENAME.PROCEDURE_NAME
DRG-11213: CTXSYS does not own procedure filter stored procedure: string
Cause: CTXSYS does not have execute privilege to the procedure filter stored procedure
Action: make sure the package is owned by CTXSYS and the procedure exist
DRG-11214: execution of procedure filter stored procedure has failed
Cause: an error occur while executing the proedure filter stored procedure
Action: check or debug the stored procedure
DRG-11215: index owner does not have access to filter stored procedure: string
Cause: the index owner does not have execute privilege of the procedure
Action: CTXSYS to grant execute privilege of the procedure to index owner
DRG-11216: length of datastore data exceeds limit
Cause: the length of the datastore data passed to the filter stored procedure is longer than the maximum length (32767 bytes)
Action: check primary key parameter
DRG-11217: INSO safe callout failed
Cause: The INSO safe callout cannot be executed
Action: check the Oracle errpr
DRG-11218: malformed mail line, line string
Cause: The mail message has an error at the indicated line
Action: manually edit mail message, if possible
DRG-11219: malformed mail configuration file, line string
Cause: mail filter configuration file has an error at the indicated line
Action: manually edit mail filter configuration file, if possible
DRG-11220: Third-party filter is out of memory.
Cause: Third-party filter could not filter this document because it was unable to allocate sufficient virtual memory.
Action: Increase virtual memory provided by the Operating System and reindex this document.
DRG-11221: Third-party filter indicates this document is corrupted.
Cause: Third-party filter could not filter this document because this document is corrupted.
Action: Fix the corruption and reindex this document.
DRG-11222: Third-party filter does not support this known document format.
Cause: Third-party filter was able to recognize the format of this document but could not filter it because this format is not supported.
Action: Remove this document or specify it to be ignored.
DRG-11223: Third-party filter indicates this document is password protected or encrypted.
Cause: Third-party filter encountered a password protected or encrypted document and could not filter it because this level of password protection or encryption is not supported.
DRG-11224: Third-party filter is unable to create or write to temporary file.
Cause: Third-party filter could not filter this document because it was unable to create a temporary file or unable to write to a temporary file.
Action: Make sure that the Operating System specified temporary directory has enough space and that the Operating System Oracle user has the privileges to create files in this temporary directory.
DRG-11225: Third-party filter timed out.
Cause: Third-party filter could not filter this document because the filter timed out.
Action: Increase the value of the TIMEOUT attribute of INSO_FILTER filter type and reindex this document. When TIMEOUT attribute is set to 0 and the session hangs then contact Oracle Support.
DRG-11226: Error initializing third-party filter: string
Cause: There was an error initializing the third-party filter.
Action: Check the following messages for details
DRG-11227: Third-party filter does not support this document format.
Cause: Third-party filter does not support the format of this document.
DRG-11228: Charset filter does not support binary documents.
Cause: The format column specifies a binary document
Action: Do not attempt to filter binary documents using the charset filter
DRG-11229: configuration column must be a char, varchar, or varchar2 type
Cause: you specified a configuration column which is not a char, varchar, or varchar2 type.
Action: specify a configuration column of correct type
DRG-11301: error while indexing document
Cause: An error was encountered while indexing the document. The error may have occurred during lexing, parsing for sections, or other action during document tokenization
Action: review document and update with valid data. Note that the document contents may have been partially indexed, so it may be returned by some queries.
DRG-11303: secondary indexes are not supported by this indextype
Cause: You attempted to create an index on an index-organized table, but the indextype does not support this action.
Action: n/a
DRG-11304: function-based indexes are not supported by this indextype
Cause: You attempted to create a function-based index but the indextype does not support this action.
Action: n/a
DRG-11305: create/alter index string is in progress in another session
Cause: you attempted to mark the index from INPROGRESS to FAILURE but create/alter on the same index is in progress in another session
Action: n/a
DRG-11306: operation cannot be performed on a policy
Cause: you attempted to perform an operation on a policy, but the operation is only valid for an index.
Action: n/a
DRG-11307: operation cannot be performed on an index
Cause: you attempted to perform an operation on an index, but the operation is only valid for a policy.
Action: n/a
DRG-11308: unsupported column expression string
Cause: You attempted to create an index with an unsupported column expression.
Action: n/a
DRG-11309: invalid filter by column: string
Action: check that the followings are valid: a) column is of supported datatype b) valid table name, column name in the specification.
DRG-11310: invalid order by column: string
DRG-11311: string cannot be specified for this optimization mode
Cause: the specified option is not valid for this optimization mode
Action: remove the specified option
DRG-11312: source and new policy must have same owner
Cause: the new policy has a different owner than the source policy
Action: Ensure that both policies are owned by the same user
DRG-11313: populate index error on index partition string
Cause: failed to polulate the text index on the specified partition
DRG-11314: changing TRANSACTIONAL property on index with rows on pending queue not allowed
Cause: the index has pending unsynced rows
Action: sync the index before changing the TRANSACTIONAL property
DRG-11316: $S table cannot be created with string
Cause: the $S table cannot be created with the specified storage option
Action: remove the specified option from the index preference and retry the index creation
DRG-11317: rowid string is not in the index
Cause: you specified an invalid rowid in ctx_ddl.add_mdata
Action: correct the rowid and retry
DRG-11318: error processing dr$sdata_update
Cause: there was an error
Action: check the error stack for more details
DRG-11319: more than 1 index found on $I. OPTIMIZE REBUILD not supported
Cause: OPTIMIZE REBUILD is not supported due to the specified reason
Action: resolve the issue, and retry the operation
DRG-11320: no index found on $I. OPTIMIZE REBUILD not supported
DRG-11321: triggers detected on $I. OPTIMIZE REBUILD not supported
DRG-11322: fast optimize not supported for big_io option
Cause: OPTIMIZE FAST is not supported with big_io option
Action: run optimize full or rebuild instead
DRG-11323: merge optimize requires near_realtime option
Cause: OPTIMIZE MERGE requires near_realtime option
Action: run another optimize mode
DRG-11324: fast optimize not supported for separate_offsets option
Cause: OPTIMIZE FAST is not supported with separate_offsets option
DRG-11325: stageitab only supported for context index
Cause: STAGEITAB requires context index
Action: don't use stageitab on non context indexes
DRG-11326: separate offsets only supported for context index
Cause: SEPARATE_OFFSETS requires context index
Action: don't use separate_offsets on non context indexes
DRG-11327: big_io only supported for context index
Cause: BIG_IO requires context index
Action: don't use big_io on non context indexes
DRG-11328: optimize validation failed
Cause: optimize validation failed
Action: file a bug
DRG-11332: Index already has STAGE_ITAB set
Cause: Index already has stage_itab set
Action: Do not add stage_itab to this index
DRG-11333: Index does not have STAGE_ITAB set
Cause: Index does not have stage_itab set
Action: Do not remove stage_itab from this index
DRG-11334: Index already has BIG_IO set
Cause: Index already has big_io set
Action: Do not add big_io to this index
DRG-11335: Index does not have BIG_IO set
Cause: Index does not have big_io set
Action: Do not remove big_io from this index
DRG-11336: Index already has SEPARATE_OFFSETS set
Cause: Index already has separate_offsets set
Action: Do not add separate_offsets to this index
DRG-11337: Index does not have SEPARATE_OFFSETS set
Cause: Index does not have separate_offsets set
Action: Do not remove separate_offsets from this index
DRG-11338: policy string does not exist
Cause: the specified policy does not exist or you do not have access to it.
DRG-11339: $A table cannot be created with string
Cause: the $A table cannot be created with the specified storage option
DRG-11340: $F table cannot be created with string
Cause: the $F table cannot be created with the specified storage option
DRG-11341: Index optimization failed for one or more tokens
Cause: Index optimization generated an error for one or more tokens, possibly due to corruption of the token_info blob.
Action: Check the index optimization log for the detailed error, or retry the optimize call with logging enabled
DRG-11342: OPTIMIZE REBUILD not supported for partitioned $I and global $X
DRG-11343: OPTIMIZE REBUILD not supported for current $I partitioning scheme
DRG-11344: SPLIT DOLLARI does not allow an empty mapping table input
Cause: SPLIT DOLLARI doesn't generate any output for empty mapping table
Action: populate the mapping table, and retry the operation
DRG-11345: Index optimization was interrupted
Cause: Index optimization was interrupted by ctx_adm.stop_optimize
Action: None
DRG-11346: FORWARD INDEX only supported for context index
Cause: FORWARD INDEX needs context index
Action: Don't use FORWARD INDEX on non context indexes
DRG-11347: FORWARD INDEX does not exist for this index
Cause: FORWARD INDEX does not exist
Action: Enable forward index for the index
DRG-11348: OPTIMIZE REBUILD not supported for $I with character length semantics columns
DRG-11349: FILTER CACHE only supported for context index
Cause: FILTER CACHE only for context index
Action: Don't use FILTER_CACHE on non context indexes
DRG-11350: SAVE COPY only supported for context index
Cause: SAVE COPY needs context index
Action: Don't use SAVE COPY on non context indexes
DRG-11351: Unable to fetch partition Id for given rowid: string
Cause: Not able to fetch partition id for given rowid
Action: Make sure index tables are partitioned correctly.
DRG-11352: Not able to fetch partition name for given partition position: number
Cause: Not able to fetch partition name for given partition position
Action: Make sure valid parition position has been provided
DRG-11353: xml_enable is not allowed for a local index
Cause: Section group attribute xml_enable set to TRUE for a local index
Action: Set xml_enable to FALSE for a local index.
DRG-11354: stage_itab_target_size need to be set, if stage_itab storage preference is set
Cause: Storage option stage_itab needs to be accompanied with stage_target_max_size
Action: Add stage_target_max_size to storage preference
DRG-11355: Not able to fetch partition position from rowid: string
Cause: Not able to fetch partition position for given rowid
Action: Make sure valid rowid has been provided
DRG-11356: Optimize operations are not permitted on partition string
Cause: READ mode for this partition is set to FALSE. No optimize operations are permitted in this mode.
Action: Set READ mode for this partition to be TRUE.
DRG-11357: FORWARD INDEX must be specified at index, not partition level string
Cause: forward index was specified at partition level and not at index level
Action: Specify forward index option at index level. All partitions inherit.
DRG-11358: Save Copy must be specified at index, not partition level string
Cause: save copy was specified at partition level and not at index level
Action: Specify save copy option at index level. All partitions inherit.
DRG-11400: failed to parse document with key string
Cause: the document specified for linguistic extraction could not be parsed. This could indicate that the document is not well-formed English
Action: check the document contents
DRG-11403: primary key value too long
Cause: the primary key value parameter passed to the service request is longer than the maximum primary key length (64 bytes)
DRG-11404: no primary key value specified
Cause: the primary key value parameter passed to the service request is null
DRG-11410: could not insert into string result table
Cause: an ORACLE error occurred while linguistic output was being inserted into the result table
Action: take action appropriate to the ORACLE error code.
DRG-11418: insufficient document content for linguistic parser
Cause: the document specified for linguistic extraction was parsed but the document content was insufficient for linguistic extraction by the specified parser.
Action: check the document contents or try modifying linguistic settings
DRG-11422: linguistic initialization failed
Cause: linguistic services initialization failed
Action: Check to see if knowledge base files present for the language
DRG-11425: gist level string is invalid
Cause: invalid gist level
Action: Specify a valid gist level
DRG-11427: valid gist level values are string
Cause: Invalid gist level
DRG-11428: document contains invalid characters
Cause: The document contains invalid characters
Action: Remove invalid characters
DRG-11432: file error while accessing knowledge base
Cause: An oracle error was encountered during knowledge base access
DRG-11435: primary key value is invalid
Cause: the primary key value parameter passed to the service request is not valid
DRG-11439: index name length exceeds maximum of string bytes
Cause: the length of the index name is longer than the maximum index name size
Action: drop the index and recreate the index with a shorter index name
DRG-11440: operation not supported for the string language
Cause: the requested operation is not supported for the current language
Action: Do not request this operation
DRG-11441: gist numParagraphs string is invalid
Cause: invalid gist numparagraphs
Action: Specify valid gist numparagraphs
DRG-11442: valid gist numParagraphs values are string
DRG-11443: gist maxPercent string is invalid
Cause: invalid gist max percent
Action: Specify valid gist max percent
DRG-11444: valid gist maxPercent values are string
DRG-11445: rowid value is invalid: string
Cause: the rowid value parameter passed to the service request is not valid
Action: check rowid parameter
DRG-11446: supplied knowledge base file string not installed
Cause: Either using Oracle Express edition or supplied Knowledge Base was required but was not installed.
Action: If using Oracle Express edition then upgrade to Oracle Enterprise or Oracle Standard edition. Otherwise see post-installation tasks section of the Database Installation Guide for instructions to install supplied Knowledge Base.
DRG-11480: ctxkbtc memory allocation error: %(1)
Cause: Unable to allocate memory
Action: Contact your system administrator
DRG-11481: linguistic feature not enabled
Cause: linguistic feature not enabled
Action: enable linguistic feature
DRG-11500: column name expected, found string on line string
Cause: possibly miss-spelt column name or keyword
Action: check spellings and punctuation around specified line
DRG-11501: identifier string found in place of column name on line string
Action: check spellings around specified line
DRG-11502: read of file failed at line string for file string
Cause: bad file name, wrong file_type or file system error
Action: check file name, type and/or file integrity
DRG-11503: insert statement overflows maximum statement size
Cause: total length of statement exceeds database maximum
Action: reduce length of column names or number of columns
DRG-11504: invalid longsize parameter of string specified
Cause: invalid option argument
Action: specify long buffer size in kbytes above 0
DRG-11505: long data on line string not found or invalid
Cause: either bad data or bad data file
Action: check file exists and is accessible, if separate
DRG-11506: record ignored on line string because of error(s)
Cause: an error occured parsing this row's data
Action: move and amend line in error to alternate load file
DRG-11507: file error trying to read file string
Cause: file not found or could not be read
Action: check name and location of file
DRG-11508: bad or missing string token on line string
Cause: token expected was not found
Action: move and amend record affected to error load file
DRG-11509: value expected on line string
Cause: could not make sense of text where value expected
DRG-11510: encountered unrecoverable error on line string
Cause: see previous messages
Action: see previous errors
DRG-11511: specified table does not contain a LONG RAW column
Cause: text must be inserted into a LONG RAW type column
Action: check table and type of data
DRG-11512: bad syntax for thesaurus load file at line string
Cause: load file must have specific format for loading thesaurus
Action: check documentation for description of correct format
DRG-11513: unable to open or write to file string
Cause: an attempt to open or to write to the given file failed
Action: check with system administrator
DRG-11514: user string does not have UPDATE or SELECT privilege on string
Cause: user has not been granted UPDATE or SELECT privilege
Action: check privilege on the user
DRG-11515: not enough text key values
Cause: number of values provided does not match the number of text keys
Action: provide same number of values as the number of text keys
DRG-11516: user must be at least in role CTXUSER to perform this operation
Cause: user does not have CTXUSER, CXAPP or CTXADMIN role
Action: grant user the proper role
DRG-11517: error when validating text objects
Cause: see accompanying Oracle error
Action: see accompanying Oracle error
DRG-11518: text table string does not have a LONG or LONG RAW column
Cause: table specified does not have a LONG or LONG RAW column
Action: check the table
DRG-11519: encounter error when exporting a LONG or LONG RAW column
Cause: see accompanying error message
Action: see accompanying error message
DRG-11520: error writing to file
Cause: file does not exist
Action: make sure file exists
DRG-11521: encounter error when updating a LONG or LONG RAW column
DRG-11522: no row exists for the text key(s) specified
Cause: no row in the table has the text key(s) specified
Action: use a valid text key(s)
DRG-11523: unable to lock the specified row for update
Cause: some other process has a lock on the row
Action: release the lock or wait until the lock is released
DRG-11524: primary key value is missing
Cause: primary key value is not provided
Action: provide the primary key value(s)
DRG-11525: invalid commitafter parameter of string specified
Action: specify commitafter above 0
DRG-11526: filename exceeds maximum length
Cause: value of the file name is too long
Action: Specify a shorter file name
DRG-11527: end token not found on line string
Cause: TEXTEND not found at end of record
Action: processing discontinued - amend record
DRG-11528: LONG or LONG RAW column defintion found in structure data
Cause: could be misplaced
Action: remove reference to LONG or LONG RAW column from structure data
DRG-11529: token exceeds maximum length
Cause: value of the column name or value is too long
DRG-11530: token exceeds maximum length
Cause: value of the phrase or relation word is too long
DRG-11531: start token not found on line string
Cause: <TEXTSTART: not found at start of record
DRG-11532: error reading through end of line string for file string
Cause: characters encountered while reading through end of line
Action: remove extraneous characters
DRG-11533: improper value of column string
Cause: value of the column is too long or mismatched quote
DRG-11534: invalid column string
Cause: column does not exist or it's misspelled
DRG-11535: error writing phrase or qualifier: string on line string to memory
Cause: not enough memory
Action: allocate more memory, contact WorldWide Support if problem persists
DRG-11600: URL store: string has permanently moved
Cause: the document referred to by the URL has permanently moved
Action: find the new address, if any, of the document
DRG-11601: URL store: bad syntax on request for string
Cause: client did not make correct request
Action: contact support
DRG-11602: URL store: access to string requires authentication
Cause: user has to provide password or other authentication
Action: get required access, or check URL
DRG-11603: URL store: payment required to access string
Cause: payment is required before the URL can be accessed
Action: check URL, or pay if required if access necessary
DRG-11604: URL store: access to string is denied
Cause: access to the URL is denied
Action: check URL; if correct, do not try to access URL again
DRG-11605: URL store: document specified by string not found
Cause: the document can not be found on the host specified
Action: check URL
DRG-11606: URL store: access to string timed out waiting for client request
Cause: client did not make response within timeout period
Action: check URL
DRG-11607: URL store: access to string was denied due to garbled response
Cause: Web server identified in URL doesn't obey HTTP protocol
Action: contact the Web administrator of the remote host
DRG-11608: URL store: host portion of string specified incorrectly
Cause: host portion of the URL could not be parsed
Action: check URL
DRG-11609: URL store: unable to open local file specified by string
Cause: attempt to open local file failed
Action: check URL
DRG-11610: URL store: unable to read local file specified by string
Cause: attempt to read local file failed
Action: contact system administrator
DRG-11611: URL store: unknown protocol specified in string
Cause: the protocol parsed is neither http or file
Action: check URL
DRG-11612: URL store: unknown host specified in string
Cause: the address of the host specified could not be resolved
Action: check URL
DRG-11613: URL store: connection refused to host specified by string
Cause: attempt to connect to host was forcibly refused
Action: check URL
DRG-11614: URL store: communication with host specified in string timed out
Cause: a network operation timed out
Action: try again later; network connection may be down to Web server
DRG-11615: URL store: write failed sending to string over network
Cause: unknown error writing request to Web server
Action: check network connection
DRG-11616: URL store: too many redirections trying to access string
Cause: too long a chain of HTTP redirections given the URL
DRG-11617: URL store: URL string is too long
Cause: The length of the URL string is longer than URLSIZE
Action: set URLSIZE attribute to a larger value
DRG-11618: URL store: document identified by string is too large
Cause: document larger than user-set maximum size
Action: do not access URL, or increase document size limit
DRG-11619: URL store: row in table is empty
Cause: row deleted or otherwise missing
Action: check table if necessary
DRG-11620: URL store: thread operation error
Cause: thread operation failed
DRG-11621: URL store: socket open error for string
Cause: socket open failed; probably too many open file descriptors
Action: reduce the maximum number of threads started
DRG-11622: URL store: unknown HTTP error string getting string
Cause: an unexpected HTTP error has occurred
Action: consult HTTP error codes; if valid, contact support
DRG-11623: URL store: unknown error getting string
Cause: unexpected error
DRG-11624: invalid attribute string for string: proper range string to string
Action: change attribute value
DRG-11625: MAXURLS * URLSIZE must be less than string
Cause: MAXURLS * URLSIZE cannot be larger than the limit
Action: Lower either MAXURLS or URLSIZE
DRG-11626: URL store: unknown protocol specified during redirect from string
Cause: the URL redirected to a site with neither http nor file protocol
Action: check URL
DRG-11627: URL store: not implemented error getting string
Cause: The remote host returned a 501 not implemented error
Action: Check URL
DRG-11628: URL store: bad gateway error getting string
Cause: The remote host returned a 502 bad gateway error
Action: Check URL
DRG-11629: URL store: service unavailable error getting string
Cause: The remote host returned a 503 service temporarily unavailable error
Action: Check URL
DRG-11630: URL store: gateway timeout error getting string
Cause: The remote host returned a 504 gateway timeout error
Action: Check URL
DRG-11700: thesaurus string already exists
Cause: thesaurus with same name exists
Action: use another name
DRG-11701: thesaurus string does not exist
Cause: thesaurus does not exist
Action: use another thesaurus or create it
DRG-11702: string
Cause: error while parsing thesaurus operator in query term. see error message for details.
Action: see error message
DRG-11703: user string must have at least CTXAPP role to execute this function
Cause: privilege is not sufficient
Action: grant user CTXAPP role
DRG-11704: phrase 'string' does not exist
Cause: phrase does not exist
Action: use another phrase or create it
DRG-11705: multilevel jump from string to string
Cause: the thesaurus load file has a multilevel jump which could not be parsed.
Action: correct thesaurus file
DRG-11706: invalid relation string
Cause: You specified an invalid relation. The set of valid relations will be displayed. Additionally, you may be able to specify a translation, which has the syntax languagename: where languagename can be any string up to 10 bytes
Action: Specify a valid relation
DRG-11707: valid relations: string
DRG-11708: too many thesauri
Cause: ctxkbtc cannot compile more than 16 thesauri
Action: Specify fewer thesauri
DRG-11709: too many terms in thesaurus
Cause: number of thesaurus terms exceeds maximum
Action: Use a thesaurus with fewer terms
DRG-11710: thesaurus term string too long
Cause: knowledge base does not permit terms longer than 80 characters
Action: Correct thesaurus
DRG-11711: too much data for term string
Cause: internal limit on size of data per term
Action: redesign thesaurus
DRG-11712: multiple Broader Terms for term string
Cause: There is a term in the thesaurus with multiple broader terms
Action: make sure each term has only one broader term
DRG-11713: multiple Preferred Terms per synonym ring
Cause: There is a synonym ring in the thesaurus with multiple preferred terms
Action: make sure each synonym ring has only one preferred term
DRG-11714: synonyms have different Broader Terms
Cause: Some synonyms in a synonym ring have different broader terms
Action: make sure all synonyms have the same broader term
DRG-11715: attempt to add a BT relation between 2 KB categories string and string
Cause: BT relation cannot be between two existing knowledge base categories
Action: redesign the BT hierarchy
DRG-11716: attempt to add Narrower Term string for non-Preferred Term string
Cause: only a PT can have NTs
Action: attach the NT to the preferred term
DRG-11717: attempt to add Related Term string to non-Preferred Term string
Cause: only a PT can have RTs
Action: attach the RT
DRG-11718: multiple Preferred Terms for term string
Cause: There are multiple preferred terms for this term
DRG-11719: Broader Term hierarchy too deep
Cause: The broader term hierarchy in this thesaurus is too deep
Action: flatten the hierarchy for best results
DRG-11720: too many synonyms per synonym ring
Cause: too many synonyms for a single preferred term
Action: introduce further distinctions to deepen the hierarchy
DRG-11721: thesaurus string is empty
Cause: no entries in thesaurus
Action: add some entries or drop the thesaurus
DRG-11722: invalid language specification
Cause: language specification cannot be more than 10 characters
Action: reduce language specification to less or equal to 10 char
DRG-11723: phrase cannot be NULL
Cause: you tried to add a NULL phrase to the thesaurus
Action: specify a valid phrase
DRG-11724: phrase string already exists
Cause: phrase with same name exists
DRG-11725: phrase does not have any synonyms
Cause: you tried to nominate a phrase with no synonyms to be the preferred term, or you tried to drop SYN from a phrase with no synonyms
Action: None
DRG-11726: phrase is not a preferred term
Cause: you tried to remove the preferred term relation from a phrase which is not a preferred term.
Action: None
DRG-11727: phrase does not have any related terms
Cause: you tried to drop a relation which does not exist
Action: None
DRG-11728: phrase does not have any broader terms of this type
Action: None
DRG-11729: phrase does not have any narrower terms of this type
Action: None
DRG-11730: relation does not exist
Action: None
DRG-11731: translation does not exist
Cause: you tried to drop a translation which does not exist
Action: None
DRG-11732: phrase does not have any translations
Cause: you tried to drop translations which does not exists
Action: None
DRG-11733: more than one translation for the term in the specified language
Cause: the term has more than one translation in the specified language
Action: specified a translation
DRG-11734: missing homograph
Cause: A term of the form 'homograph(disambiguation)' is missing the the homograph.
Action: None
DRG-11735: missing disambiguation
Cause: A term of the form 'homograph(disambiguation)' is missing the the disambiguation (i.e., homograph()).
Action: None
DRG-11736: illegal text after disambiguated homograph
Cause: A term of the form 'homograph(disambiguation)' has text after the disambiguation (e.g, homograph(disambiguation) extra text".
Action: None
DRG-11801: Continue
Cause: Enquire user to decide if continue is necessary HTTP_ERROR = 100
Action: Upon positive response, continue the original operation
DRG-11802: Switching Protocols
Cause: Telling client a protocol switching just happened HTTP_ERROR = 101
Action: The user agent takes proper actions
DRG-11803: OK
Cause: Telling client things are ok HTTP_ERROR = 200
DRG-11804: Created
Cause: Telling client things are created HTTP_ERROR = 201
DRG-11805: Accepted
Cause: Telling client things are accepted but not commited HTTP_ERROR = 202
DRG-11806: Non-authoritative Information
Cause: The returned metainformation is not the definitive set HTTP_ERROR = 203
Action: The user agent knows the information is Non-authoritative
DRG-11807: No Content
Cause: request has been fulfilled but no new information found HTTP_ERROR = 204
DRG-11808: Reset Content
Cause: Telling client to reset the document view HTTP_ERROR = 205
DRG-11809: Partial Content
Cause: Telling client document content is a patial content HTTP_ERROR = 206
DRG-11810: Partial Update OK
Cause: Telling client document is partially updated HTTP_ERROR = 207
DRG-11811: Multiple Choices
Cause: Telling client multiple choices of resources is possible HTTP_ERROR = 300
DRG-11812: Moved Permanently
Cause: The URI has been assigned a new permanent URI HTTP_ERROR = 301
DRG-11813: Moved Temporarily
Cause: The URI resides temporarily under a different URI. HTTP_ERROR = 302
DRG-11814: See Other
Cause: The URI can be found using GET METHOD under a different URI HTTP_ERROR = 303
DRG-11815: Not Modified
Cause: Response to conditional GET, indicating document not modified. HTTP_ERROR = 304
DRG-11816: Use Proxy
Cause: The client should use specified proxy to repeat the request HTTP_ERROR = 305
DRG-11817: Proxy Redirect
Cause: Proxy redirection. Not used HTTP_ERROR = 306
Action: Outdated due to HTTP evolution
DRG-11818: Temporary Redirect
Cause: The resource is temporarily under a different URI. HTTP_ERROR = 307
Action: The takes proper actions
DRG-11819: Bad Request
Cause: The URL syntax is incorrect. Request rejected by server. HTTP_ERROR = 400
DRG-11820: Unauthorized
Cause: The request requires further authentication. HTTP_ERROR = 401
DRG-11821: Payment Required
Cause: Reserved for future use. HTTP_ERROR = 402
DRG-11822: Forbidden
Cause: The server refuses to fulfil the request from client HTTP_ERROR = 403
DRG-11823: Not Found
Cause: The server can not find the requested URI HTTP_ERROR = 404
DRG-11824: Method Not Allowed
Cause: The user agent specified method not allowed HTTP_ERROR = 405
Action: The user agent reads allow header to decide alternatives.
DRG-11825: Not Acceptable
Cause: Requested resource is not acceptable according to request header HTTP_ERROR = 406
Action: The user agent should query the user for the next action.
DRG-11826: Proxy Authentication Required
Cause: The client must authenticate itself with the proxy. HTTP_ERROR = 407
DRG-11827: Request Timeout
Cause: The server is tired of waiting for the requst HTTP_ERROR = 408
Action: The user agent repeat the request
DRG-11828: Conflict
Cause: The request conflicts with the current state of the URI HTTP_ERROR = 409
DRG-11829: Gone
Cause: The resource is no longer available and no forwarding address. HTTP_ERROR = 410
DRG-11830: Length Required
Cause: The server must receive a content-length header. HTTP_ERROR = 411
DRG-11831: Precondition Failed
Cause: Telling the user agent that the resource failed preconditions HTTP_ERROR = 412
DRG-11832: Request Entity Too Large
Cause: Request rejected because request entity is too large. HTTP_ERROR = 413
Action: If Retry-After header found, the user agent should retry.
DRG-11833: Request-URI Too Big
Cause: The server is refusing to accept the URI which is too big. HTTP_ERROR = 414
DRG-11834: Unsupported Media Type
Cause: The server is refusing the request because of media type HTTP_ERROR = 415
DRG-11835: Requested Range Not Satisfiable
Cause: The byte range request can not be satisfied by the resource extent. HTTP_ERROR = 416
Action: The user agent reads content-range header in the response.
DRG-11836: Expectation Failed
Cause: Server can not meet the user agent's expectation. HTTP_ERROR = 417
DRG-11837: Reauthorization Required
Cause: Reserved HTTP_ERROR = 418
Action: Reserverd
DRG-11838: Proxy Reauthentication Required
Cause: Reserved HTTP_ERROR = 419
Action: Reserved
DRG-11839: Internal Server Error
Cause: The server encountered internal error in fulfilling the request. HTTP_ERROR = 500
DRG-11840: Not Implemented
Cause: The server can't support a request feature which has yet to be implemented. HTTP_ERROR = 501
DRG-11841: Bad Gateway
Cause: In serving the request, the server received invalid response from gateway. HTTP_ERROR = 502
DRG-11842: Service Unavailable
Cause: Server overloaded or in maintenance mode. HTTP_ERROR = 503
Action: If retry-after header is in the response, retry the request.
DRG-11843: Gateway Timeout
Cause: Upstream server did not timely respond to the gateway server. HTTP_ERROR = 504
DRG-11844: HTTP Version Not Supported
Cause: The HTTP version in the request header is rejected by the server. HTTP_ERROR = 505
DRG-11845: No Partial Update
Cause: Reserved HTTP_ERROR = 506
Action: Reserved
DRG-11846: Response Is Stale
Cause: The the user agent knows the returned reponse is stale. HTTP_CACHE_ERROR = 10
Action: The user agent client takes proper actions.
DRG-11847: Revalidation Failed
Cause: User agent's attempt to revalidate a stale response failed. HTTP_CACHE_ERROR = 11
DRG-11848: Disconnected Operation
Cause: The cache is intentionally disconnected for a time period. HTTP_CACHE_ERROR = 12
DRG-11849: Heuristic Expiration
Cause: Cache freshness lifetime and response age both greater than 24 hours. HTTP_CACHE_ERROR = 13
DRG-11850: Transformation Applied
Cause: Telling cache manager, content encoding/media type has been changed in cache. HTTP_CACHE_ERROR = 14
DRG-11851: Cache Related Warning
Cause: Arbitrary information about cache to be presented to logger. HTTP_CACHE_ERROR = 99
Action: The user agent client must not take any automated action.
DRG-11852: Can't Locate Remote Host
Cause: connection to remote host failed USER_AGENT_ERROR
DRG-11853: No Host Name Found
Cause: The host name is not specicied in URI. USER_AGENT_ERROR
Action: The user agent client takes proper action.
DRG-11854: No File Name Found Or File Not Accessible
Cause: Unable to open the file specified USER_AGENT_ERROR
DRG-11855: FTP Server Replies
Cause: FTP server responds to the agent request USER_AGENT_ERROR
DRG-11856: FTP Server Doesn't Reply
Cause: No response from FTP server during operation. USER_AGENT_ERROR
DRG-11857: Server Timed Out
Cause: Server operation timed out USER_AGENT_ERROR
DRG-11858: Gopher Server Replies
Cause: Gopher server responds to the agent request. USER_AGENT_ERROR
DRG-11859: Data Transfer Interrupted
Cause: Processing of URL request was interrupted USER_AGENT_ERROR
DRG-11860: Connection Establishment Interrupted
Cause: Connection operation was interupped USER_AGENT_ERROR
DRG-11861: CSO-server Replies
Cause: Telling client things are ok USER_AGENT_ERROR
DRG-11862: This Is Probaly A HTTP Server 0.9 Or Less
Cause: A very old web server USER_AGENT_ERROR
DRG-11863: Bad, Incomplete, Or Unknown Response
Cause: The server is mumbering something not understandable USER_AGENT_ERROR
DRG-11864: Unknown Access Authentication Scheme
Cause: The server is using an unkown access authentication scheme USER_AGENT_ERROR
DRG-11865: News Server Replies
Cause: News Server is responding USER_AGENT_ERROR
DRG-11866: Please Try `ftp://' Instead Of `file://'
Cause: wrong access scheme is used. USER_AGENT_ERROR
DRG-11867: Method Not Suited For Automatic Redirection
DRG-11868: Too Many Redirections
Cause: The web server setup configured too many redirections USER_AGENT_ERROR
Action: The user agent client should take proper actions
DRG-11869: Premature End Of File Detected
Cause: Detected end of file is unexpected USER_AGENT_ERROR
DRG-11870: Response From WAIS Server Too Large -- Extra Lines Ignored
Cause: Response from WAIS caused buffer overflow USER_AGENT_ERROR
DRG-11871: WAIS Server Doesn't Return Any Data
Cause: Bad WAIS Server USER_AGENT_ERROR
DRG-11872: Can't Connect To WAIS Server
Cause: Connect to WAIS server failed USER_AGENT_ERROR
DRG-11873: System Call Replies
Cause: register what system call replies USER_AGENT_ERROR
DRG-11874: Wrong Or Unknown Access Scheme
Cause: Protocol class is wrongfully connected to ther server USER_AGENT_ERROR
DRG-11875: Access Scheme Is Not Allowed
DRG-11876: When Your Are Connected, You Can Log In
Cause: Pass information to telnet agent USER_AGENT_ERROR
DRG-11877: This Cache Version Has Expired And Will Be Automatically Reloaded
Cause: Need to tell user that cache entry has been reloaded USER_AGENT_ERROR
DRG-11878: Loading New Rules Must Be Explicitly Acknowledged
Cause: Let user agent client be aware of new rule loading USER_AGENT_ERROR
DRG-11879: Automatic Proxy Redirection Msut Be Explicitly Acknowledged
Cause: Let user agent client be aware of proxy redirection USER_AGENT_ERROR
DRG-12001: Please enter username:
Cause: Prompt user for name W3CLIB_MSG = 0
DRG-12002: Please enter username for proxy authentication:
Cause: Prompt user for name W3CLIB_MSG = 1
DRG-12003: Please enter username for this FTP server:
Cause: Prompt user for name W3CLIB_MSG = 2
DRG-12004: Password:
Cause: Prompt user for password W3CLIB_MSG = 3
DRG-12005: Please give name of file to save in:
Cause: Prompt user for file name W3CLIB_MSG = 4
DRG-12006: Plase enter account:
Cause: Prompt user for account W3CLIB_MSG = 5
DRG-12007: You might not be allowed to use this method here, continue?
Cause: Warn user of deny of service. W3CLIB_MSG = 6
DRG-12008: Location has moved, continue?
Cause: Warn user of location changes. W3CLIB_MSG = 7
DRG-12009: A new set of rules is requested to be added to your setup - continue?
Cause: Warn user of rule changes. W3CLIB_MSG = 8
DRG-12010: This file already exists - replace existing file?
Cause: Warn user of pending replacement W3CLIB_MSG = 9
DRG-12011: Authentication failed - retry?
Cause: Warn user of authentication failure W3CLIB_MSG = 10
DRG-12012: Proxy authentication failed - retry?
Cause: Warn user of proxy authentication failure W3CLIB_MSG = 11
DRG-12013: This method has already been performed - repeat operation?
Cause: Warn user the repetition of previous method used W3CLIB_MSG = 12
DRG-12014: This document is very big - continue operation?
Cause: Warn user of big document processing W3CLIB_MSG = 13
DRG-12015: The source document for this operation has moved - continue?
Cause: Warn user of location changes W3CLIB_MSG = 14
DRG-12016: The target document for this operation has moved - continue?
Cause: Warn user of destination document changes W3CLIB_MSG = 15
DRG-12017: A redirection may change the behavior of this method - proceed anyway?
Cause: Warn user of redirection effects on method W3CLIB_MSG = 16
DRG-12018: Encountered an automatic request for changing proxy - continue?
Cause: Warn user of automatic proxy change W3CLIB_MSG = 17
DRG-12201: section group string already exists
Cause: Section group with the same name already exists
Action: Use another name or delete the existing one first
DRG-12202: error while creating section group
Cause: detect an Oracle error while creating section group
Action: see the accompanying Oracle error and take appropriate action
DRG-12203: section group string does not exist
Cause: section group provided does not exist
Action: provide an existing section group
DRG-12204: error while dropping section group string
Cause: detect an Oracle error while dropping a section group
DRG-12206: tag string already exists in section group string
Cause: the start tag provided already exists in the same Section
Action: provide another start tag
DRG-12210: error while adding section string
Cause: detect an Oracle error while adding a section
DRG-12211: section or section id string does not exist
Cause: Section name or Section id to be dropped does not exist
Action: provide an existing Section name or Section id
DRG-12212: error while dropping section string
Cause: detect an Oracle error while dropping a Section
DRG-12213: cannot create/drop section group or sections for other user
Cause: You can only create/drop section group objects of your own
Action: have the other user create/drop his/her own objects
DRG-12217: tags cannot be more than 64 bytes
Cause: max limit of start and end tag is 64 bytes
Action: provide a shorter start and end tag
DRG-12218: section group name missing
Cause: must provide section group name
Action: provide a section group name when creating Section or section group
DRG-12219: section name missing
Cause: must provide Section name when creating a Section
Action: provide a Section name
DRG-12220: a valid tag must be provided
Cause: must provide tag when adding a section to a section group
Action: provide a tag
DRG-12223: section name string is a reserved name
Cause: you tried to name a section a reserved name
Action: Specify a different name for the section
DRG-12224: use ctx_ddl.create_section_group to create section groups
Cause: you tried to use ctx_ddl.create_preference to create a section group
Action: use ctx_ddl.create_section_group
DRG-12225: this type of section cannot be added to this section group
Cause: You tried to add sections to the null section group, add a stop section to a non-auto section group, or add a zone or field section to the auto section group
Action: Do not add this type of section to this section group
DRG-12226: a field section named string already exists in this section group
Cause: you tried to name an attribute or zone section the same name as an existing field section
DRG-12227: a zone section named string already exists in this section group
Cause: you tried to name an attribute or field section the same name as an existing zone section
DRG-12228: maximum number of field sections (string) exceeded
Cause: a section group has more than the maximum number of unique field sections
Action: no action required
DRG-12229: special section string already exists in this section group
Cause: you tried to add a special section which already exists
DRG-12230: special section name must be one of string
Cause: you tried to add an invalid special section
Action: specify a valid special section
DRG-12231: an attr section named string already exists in this section group
Cause: you tried to name a field or zone section the same name as an existing attribute section
DRG-12232: invalid attribute tag format
Cause: you specified a tag for use as an attribute tag which did not have the correct format. An attribute tag must have the form TAG@ATTR
Action: use correct format
DRG-12233: xml sections cannot co-exist with other section types
Cause: you tried to add an xml section to a section group or index which already has zone, field, attr, or special sections, or you tried to add a zone, field, attr, or special section to a section group or index which already has xml sections
Action: n/a
DRG-12234: column string already mapped in section group string
Cause: you tried to add a column section which already exists
DRG-12235: an sdata section named string already exists in this section group
Cause: you tried to name a non-sdata section the same name as an existing sdata section
DRG-12236: an mdata section named string already exists in this section group
Cause: you tried to name a non-mdata section the same name as an existing mdata section
DRG-12237: a section named string already exists in this section group
Cause: you tried to map a column but the section name is already being used by another section
DRG-12238: maximum number of mdata sections (string) exceeded
Cause: a section group has more than the maximum number of unique mdata sections
DRG-12239: maximum number of sdata sections (string) exceeded
Cause: a section group has more than the maximum number of unique sdata sections
DRG-12240: ORDER BY column string must be indexed as an SDATA section
Cause: an order by column has been mapped to an MDATA section
Action: adjust section group
DRG-12241: column name string is not a valid section name
Cause: an order by or filter by column cannot be implicitly mapped to an SDATA section because the name is not valid as a section name
Action: adjust section group to map column name to a valid section name
DRG-12242: value of string is too large for section string
Cause: the value of a filter by or order by column is too large to be indexed
Action: update the row
DRG-12243: invalid datatype
Cause: the datatype specified for a sdata or mdata section is invalid
Action: specify a supported datatype
DRG-12244: data conversion error for sdata section string
Cause: failed to convert data
Action: check the format of the data
DRG-12245: SDATA operator not compatible with the sdata section string
DRG-12246: SDATA operand not compatible with the sdata section string
DRG-12247: maximum number of NDATA sections (string) exceeded
Cause: a section group has more than the maximum number of unique NDATA sections
DRG-12248: a NDATA section named string already exists in this section group
Cause: you tried to name a non-NDATA section the same name as an existing NDATA section
DRG-12249: a MVDATA section named string already exists in this section group
Cause: you tried to name a non-MVDATA section the same name as an existing MVDATA section
DRG-12250: maximum number of mvdata sections (string) exceeded
Cause: a section group has more than the maximum number of unique mvdata sections
DRG-12251: MVDATA section in XML_SECTION_GROUP is not supported
Cause: you tried to add MVDATA section in XML_SECTION_GROUP
Action: n/a
DRG-12252: No valid rowid provided with MVDATA update procedure
Cause: No valid rowid(s) provided with MVDATA update procedure
Action: Provide at least one valid rowid with this procedure
DRG-12300: an index with this column list already exists in the index set
Cause: You tried to add an index to an index set, but an index with the specified column list already exists
Action: n/a
DRG-12301: index does not exist in index set
Cause: You tried to remove an index from an index set, but the specified index was not found
Action: n/a
DRG-12302: invalid column list
Cause: You specified an invalid column list -- it may have a syntax error, duplicate columns, or invalid column names
Action: n/a
DRG-12303: cannot add more than 99 indexes to an index set
Cause: You tried to add too many indexes to the index set
Action: n/a
DRG-12304: index set string does not exist
Cause: You specified an invalid index set name
Action: n/a
DRG-12305: column string data type is not supported for index set columns
Cause: You specified a column in the column list of an index of an index set which does not have a valid datatype
Action: use only DATE, NUMBER, CHAR, or VARCHAR2 columns in index column lists
DRG-12306: column string is too long for index set columns
Cause: You specified a column in the column list of an index of an index set which is too long
Action: CHAR and VARCHAR2 columns must be 30 bytes or less max length
DRG-12307: column string is NULL and cannot be indexed
Cause: You tried to index a row where at least one of the meta columns was NULL.
Action: provide a value for the meta column and reindex the row
DRG-12308: use ctx_ddl.create_index_set to create index sets
Cause: you tried to use ctx_ddl.create_preference to create an index set
Action: use ctx_ddl.create_index_set
DRG-12309: not to use compression on attributes lob column
Cause: you tried to use compression on attributes lob column for xml full text index
Action: not to use compression on attributes lob column for xml full text index
DRG-12400: template string is empty
Cause: The template is empty.
Action: Check the template was installed successfully.
DRG-12401: invalid template: query within a loop
Cause: A CTX EXEC tag cannot occur within a CTX REPEAT tag.
Action: Remove the CTX EXEC tag.
DRG-12402: error processing template string, line string
Cause: An error occurred when processing a template.
Action: See other errors on the stack and take the appropriate action.
DRG-12403: template string was not found
Cause: The template does not exist.
Action: Check the name of the template and check that it is installed.
DRG-12404: more than one template string found
Cause: More than one template with the same name was found.
Action: Remove templates as appropriate.
DRG-12405: error occurred processing CTX REDIRECT or CTX LABEL tag
Cause: Error in syntax of a tag.
Action: Correct the syntax of the tag.
DRG-12406: invalid CTX EXEC tag attribute (string)
Cause: The specified attribute is incorrectly specified.
Action: Check the sytax of the specified attribute.
DRG-12407: invalid CTX REPEAT tag attribute (string)
DRG-12408: invalid variable reference: string.string
Cause: The variable referenced does not exist.
Action: Check the label and column name.
DRG-12409: syntax error for label in string
Cause: The SQL in a CTX EXEC tag has incorrect syntax for a label or label type.
Action: Check the SQL attribute of the CTX EXEC tag.
DRG-12410: could not process CTX EXEC tag
Cause: An error occurred when processing the SQL attribute of a CTX EXEC tag.
DRG-12411: SQL processing error: string
Cause: Error executing SQL from SQL attribute of CTX EXEC tag.
Action: Check the SQL in the SQL attribute.
DRG-12412: missing or invalid Template Processor attribute (string)
Cause: The specified attribute was missing or invalid in a HTML input field.
Action: Check the Template Processor-specific attributes in the INPUT, SELECT, RADIO and CHECKBOX tags of the template.
DRG-12422: write to client failed
Cause: See the following messages.
Action: Contact the administrator.
DRG-12430: mandatory argument missing: string
Cause: This argument is mandatory.
Action: Re-submit the URL with this argument supplied.
DRG-12431: configuration section string not found
Cause: Specified conf argument is invalid.
Action: Re-submit the URL with this argument corrected.
DRG-12432: configuration file string not found or unreadable
Cause: An error occurred when processing the configuration file.
DRG-12433: load of string JDBC driver class failed
Cause: Driver class is invalid.
Action: Contact the administrator to modify configuration.
DRG-12434: connection failed using configuration string information
Cause: Configuration information is not correct.
DRG-12435: highlight table allocation failed
DRG-12436: document table allocation failed
DRG-12437: highlight table release failed
DRG-12438: document table release failed
DRG-12439: highlight table read failed
DRG-12440: document table read failed
DRG-12441: counting the number of highlights failed
DRG-12500: stoplist string already exists
Cause: the specified stop list already exists
Action: must remove the duplicate stop list if you want to re-create it.
DRG-12501: null stoplist is not allowed
Cause: the specified stop list is null
Action: mustspecify a valid stop list
DRG-12502: cannot modify stoplists owned by other users
Cause: You can only create/drop Stop List or Stop Word objects of your own
DRG-12503: error while creating or dropping stoplist
Cause: detect an Oracle error while creating Stop List
DRG-12504: stoplist string does not exist
Cause: the specified stop list does not exist
Action: check that the Stop List is valid
DRG-12505: error while adding or removing a stop word
Cause: detect an Oracle error while adding or removing Stop Word
DRG-12506: stop word string does not exist in stoplist string
Cause: the specified Stop Sord does not exist
Action: check that the Stop Word is valid
DRG-12507: stop word string already exists in this stoplist
Cause: the specified stop word already exists
Action: must remove the duplicate word if you want to re-create it.
DRG-12508: null stop words are not allowed
Cause: the specified stop word is null
Action: must remove the null stop word if you want to re-create it.
DRG-12509: length of the stop word string exceeded the limit of string bytes
Cause: A stop list entry has exceeded the maximun length
Action: Reduce the length of the stop list entry
DRG-12511: use ctx_ddl.create_stoplist to create stoplists
Cause: you tried to use ctx_ddl.create_preference to create a stoplist
Action: use ctx_ddl.create_stoplist
DRG-12512: invalid stop class string
Cause: you specified an invalid stop class
Action: specify a valid stop class
DRG-12513: valid stop classes are: string
Cause: You specified an invalid stop class
Action: Specify a valid stop class
DRG-12514: languages must be specified for stopwords in a MULTI_STOPLIST
Cause: You tried to add a stopword to a multi_stoplist without specifying the language of the stopword
Action: Specify the language of the stopword
DRG-12515: cannot specify language for stopwords in a BASIC_STOPLIST
Cause: You tried to add a language-specific stopword to a basic stoplist.
Action: Do not specify language for the stopword
DRG-12516: language column must be specified when using the multi stoplist
Cause: you tried to create an index using a multi stoplist but you did not specify a language column
Action: specify a language column
DRG-12517: cannot add stopthemes to a MULTI_STOPLIST
Cause: you tried to add a stoptheme to a MULTI_STOPLIST. This is not supported in this version.
Action: n/a
DRG-12518: cannot use this option with MULTI_STOPLIST
Cause: index already has multi_stoplist
Action: can only be used to migrate from basic to multi stoplist
DRG-12519: LANGUAGE COLUMN missing
Cause: index does not have a language column
Action: specify language column value
DRG-12520: LANGUAGE COLUMN mismatch
Cause: LANGUAGE COLUMN does not match language column of the Index
Action: index language column should match specified one
DRG-12521: cannot add STOP PATTERN to NUMBERS stopclass
Cause: NUMBERS is a predefined stopclass to specify numeric values
Action: use any other alphanumeric word
DRG-12600: user datastore procedure name contains a semicolon
DRG-12601: invalid user datastore procedure name: string
Cause: the format of the procedure name is invalid. It should be in the form PACKAGENAME.PROCEDURENAME or PROCEDURENAME
Action: make sure PROCEDURE attr has the format PACKAGENAME.PROCEDURENAME or PROCEDURENAME
DRG-12602: index owner does not have access to user datastore procedure: string
DRG-12603: CTXSYS does not own user datastore procedure: string
Cause: CTXSYS does not have execute privilege to the user datastore procedure
DRG-12604: execution of user datastore procedure has failed
Cause: an error occur while executing the user datastore procedure
Action: check or debug the datastore procedure
DRG-12605: datatype of column number in COLUMNS list is not supported
Cause: one or more of the columns in the column list of the multi datastore are of a type which the multi datastore is unable to process
Action: change the column list of the multi datastore to contain only supported types. PL/SQL functions can be used in the comlumn list to convert unsupported types to supported types.
DRG-12606: error encountered while parsing COLUMNS list
Cause: An oracle error was encountered while parsing the columns list of the multi datastore.
Action: See next error on stack and take appropriate action
DRG-12607: only ctxsys can create MULTI_COLUMN preferences
Cause: In order to create a multi column datastore preference, the effective user must be ctxsys.
Action: contact your DBA to create the preference as ctxsys
DRG-12700: seed word must be a single word
Cause: seed word is not a single word
Action: use a single-word seed word
DRG-12800: Attribute NESTED_TYPE must have owner name as prefix
Cause: the attribute NESTED_TYPE does not have an owner name prefix
Action: reset the attribute NESTED_TYPE to include owner name prefix
DRG-12801: invalid type: string
Cause: invalid nested_type or
Action: check the owner and the type attribute names
DRG-12802: invalid type column: string
Cause: column specified does not exist in the type table
Action: check the type table
DRG-12803: invalid text datatype
Cause: LONG and LONG RAW are not supported in nested table
Action: change text column to a supported data type
DRG-12900: Operation:string for index: string has already been started
Cause: the specified operation has been started
Action: n/a
DRG-13000: error while adding or removing a sub lexer
Cause: see next error
Action: n/a
DRG-13001: sub lexer and multi lexer must have the same owner
Cause: you specified a sub lexer which is not owned by the owner of the enclosing multi-lingual lexer preference
Action: specify a sub lexer owned by the owner of the multi-lexer preference
DRG-13002: preference string is not a MULTI_LEXER
Cause: you tried to add a sub lexer to a lexer preference which cannot accept sub lexers. Only multi-lingual lexers can accept sub lexers.
Action: specify a multi lingual lexer
DRG-13003: preference string cannot be used as a sub lexer
Cause: you specified a preference for sub lexer which is not a lexer, or is a multi-lingual lexer or is an auto lexer
Action: specify a sub lexer which is not a multi-lingual lexer or an auto lexer
DRG-13004: language is invalid
Cause: you specified an invalid language for the sub lexer or stopword
Action: specify a valid language -- see NLS Support Guide for a list of valid languages
DRG-13005: alt_value cannot be an NLS language name
Cause: you specified an NLS language name as the alt value
Action: specify a non-NLS value
DRG-13006: sub lexer for this language is not defined
Cause: you tried to remove a sub lexer for a language, but no sub lexer was defined for that language
Action: None
DRG-13007: cannot define an alternate value for the DEFAULT sub lexer
Cause: you tried to define an alternate value for the DEFAULT sub lexer
Action: None
DRG-13008: cannot remove the DEFAULT sub lexer
Cause: you tried to remove the DEFAULT sub lexer
Action: None
DRG-13009: multi lexer preference does not have a DEFAULT sub lexer
Cause: you tried to use a multi lexer preference which does not have a DEFAULT sub lexer defined
Action: add a DEFAULT sub lexer to the multi lexer preference and retry
DRG-13010: alt_value is already used by another sub lexer
Cause: you tried to specify an alt value which is already in use by another sub lexer in the lexer preference
Action: specify a different alt value
DRG-13011: language column must be specified when using the multi lexer
Cause: you tried to create an index using a multi lexer preference, but you did not specify a language column
DRG-13012: language column must be a char, varchar, or varchar2 type
Cause: you specified a language column which is not a char, varchar, or varchar2 type.
Action: specify a language column of correct type
DRG-13013: cannot have language independent DEFAULT sub lexer
Cause: you tried to define a language independent DEFAULT sub lexer
Action: DEFAULT sub lexer can only be language dependent
DRG-13014: base table has rows with language column value string
Cause: there are documents in the base table with language column value set to symbol for sublexer or stopword being removed
Action: base table should not have such rows
DRG-13015: sublexer string already exists in the index
Cause: cannot add a sub_lexer more than once
Action: if you want to update sub_lexer preferences, use update sub_lexer parameter or remove currently used sub_lexer
DRG-13100: index is not partitioned
Cause: you attempted to invoke a partition-level operation on an index which is not partitioned
Action: invoke appropriate index-level operation
DRG-13101: partition string does not exist in this index
Cause: you specified a partition name which does not exist
Action: specify correct partition name
DRG-13102: index partition name must be specified
Cause: you attempted to invoke a partition-level operation on a partitioned index but did not specify the partition name
Action: n/a
DRG-13103: index table string is partitioned
Cause: you attempted to perform an exchange partition including indexes, but one or more of the internal index tables are partitioned.
Action: specify EXCLUDING INDEXES on the exchange partition, then manually rebuild the indexes.
DRG-13104: indexes do not have equivalent settings for string
Cause: you attempted to perform an exchange partition including indexes, but the specified metadata setting is not equivalent across the two indexes, so the data cannot be exchanged
DRG-13200: failed to load dictionary file string
Cause: failed to load a dictionary file
Action: check whether the dictionary file exists in $ORACE_HOME/ctx/data/kolx or access permission is available
DRG-13201: KOREAN_LEXER is desupported
Cause: Using lexer type KOREAN_LEXER which is desupported.
Action: Use lexer type KOREAN_MORPH_LEXER instead.
DRG-13300: document size bigger than string bytes
Cause: size of the document being indexed is larger than the maximum supported size for the VARCHAR2 interface of stored procedure
Action: use the CLOB interface for the stored procedure
DRG-13301: syntax error in token data when expecting string, at line string
Cause: token data returned by the user-defined lexer procedure is incorrect
Action: modify user-defined lexer procedure to return expected data
DRG-13302: number of wildcard offsets must be in the range string..string, at line string
Cause: number of wildcard offsets specified as value for the wildcard attribute does not meet the supported range
Action: modify user-defined lexer query procedure to return valid number of wildcard offsets
DRG-13303: value of wildcard offset must be in the range string..string, at line string
Cause: value of pre-normalized wildcard offset or post-normalized wildcard offset specified as value for the wildcard attribute does not meet the supported range
Action: modify user-defined lexer query procedure to return valid value for wildcard offset
DRG-13304: character referenced by wildcard attribute is not a wildcard character, at line string
Cause: The wildcard attribute value specified the offset of a wildcard character. The character at the specified offset is neither the '%' character nor the '_' character.
Action: Modify user-defined lexer query procedure.
DRG-13305: 'off' attribute value must be in the range string..string, at line string
Cause: value of 'off' attribute does not meet the supported range
Action: modify user-defined lexer index procedure to return valid value for 'off' attribute
DRG-13306: 'len' attribute value must be in the range string..string, at line string
Cause: value of 'len' attribute does not meet the supported range
Action: modify user-defined lexer index procedure to return valid value for 'len' attribute
DRG-13307: 'off'=string and 'len'=string references character past end-of-file of string character document, at line string
Cause: value of 'off' attribute plus value of 'len' attribute is greater than the number of characters in the document
Action: modify user-defined lexer index procedure to return valid values for 'off' and 'len' attributes
DRG-13308: query operator ABOUT not supported by USER_LEXER
Cause: the query contains an ABOUT operator while using USER_LEXER lexer type
Action: remove ABOUT operator from query or use lexer type other than USER_LEXER
DRG-13309: operation not supported by USER_LEXER
Cause: USER_LEXER does not support this operation
Action: stop the operation or use alternate lexer type
DRG-13310: index owner does not have EXECUTE privilege on USER_LEXER stored procedure string
Cause: user CTXSYS did not grant EXECUTE privilege on USER_LEXER stored procedure to the index owner
Action: user CTXSYS grant EXECUTE privilege on USER_LEXER stored procedure to index owner
DRG-13311: USER_LEXER stored procedure name contains a semicolon
Cause: the procedure name contains a semicolon character
Action: remove semicolon from procedure name or rename stored procedure
DRG-13312: user CTXSYS does not own USER_LEXER stored procedure string
Cause: CTXSYS does not have EXECUTE privilege on the USER_LEXER stored procedure
Action: make sure the stored procedure exists and is owned by CTXSYS
DRG-13400: Oracle Data Mining was not installed
Cause: The function you used depends on Oracle Data Mining, which has not been installed yet.
Action: make sure the Oracle Data Mining is installed
DRG-13401: the preference string type is not supported in this API
Cause: the type you have specified is not supported
Action: use a different type
DRG-13500: Parameter_string must start with string
Cause: Wrong syntax for parameter_string.
Action: Make sure the parameter_string has the correct syntax
DRG-13501: Shadow Index Already Exists
Cause: A shadow index was previously created already
Action: Drop the shadow index and try again
DRG-13502: NOPOPULATE is not allowed in recreate_index_online
Cause: Specify NOPOPULATE in parameter_string in recreate_index_online
Action: Don't specify NOPOPULATE.
DRG-13503: POPULATE is not allowed for a local index in create_shadow_index
Cause: Specify POPULATE for a local index during create_shadow_index
Action: Don't specify POPULATE.
DRG-13504: string has no shadow index
Cause: Tried to perform exchange shadow without creating shadow index first
Action: create a shadow index before doing exchanges_shadow_index
DRG-13505: Keyword string is not allowed here in parameter_string
DRG-13506: string has no shadow part
Cause: Tried to perform exchange shadow part without creating shadow part first
Action: create a shadow part before doing exchanges_shadow_index on the partition.
DRG-13507: SWAP and NOPOPULATE is incompatible
Cause: Specified SWAP and NOPOUPLATE in parameter string
Action: Correct the parameter string setting
DRG-13508: Not all partitions for index string are swapped
Cause: try to swap an local partitioned index when not all partitions are swapped
Action: Swap all partitions first, then swap the (local) index.
DRG-13509: error while swapping shadow index
Cause: an error occurred during the shadow index swap
Action: check error message stack for the actual error
DRG-13510: shadow index does not exist
DRG-13600: Syntax error in the result set descriptor at string
Cause: The result set descriptor has a syntax error
Action: check the syntax of the result set descriptor
DRG-13601: Syntax error in the order attribute
Cause: The order attibute has a syntax error
Action: check the syntax of the order attibute
DRG-13602: Number parsing error in string
Cause: The number string is malformed
Action: check the syntax of the number string
DRG-13603: To many sort keys
Cause: Too many sort keys are specified
Action: reduce the number of sort keys
DRG-13604: To many items to select
Cause: Too many select items are specified
Action: reduce the number of select items
DRG-13605: Too many group tags
Cause: Too many group tags are specified
Action: reduce the number of group tags
DRG-13606: start_hit_num is not specified or out of valid range number..number
Cause: start_hit_num is not specified or out of valid range
Action: set a correct start_hit_num value
DRG-13607: end_hit_num is not specified or out of valid range number..number
Cause: end_hit_num is not specified or out of valid range
Action: set a correct end_hit_num value
DRG-13608: Temporary lob not created for ctx_query.result_set_document
Cause: Temporary lob is not allocated for ctx_query.result_set_document
Action: Create a temporary lob for ctx_query.result_set_document
DRG-13609: Result set Interface should only have group mvdata element in absence of a query
Cause: No query is specified and result set descriptor has invalid elements
Action: either specify query or change result set descriptor
DRG-13610: Missing group_values in the result set interface
Cause: MVDATA group values not specified in RSI
Action: add group_values element for group counting
DRG-13611: Missing value id for MVDATA group counting in the result set interface
Action: add value id element for group counting
DRG-13612: Missing path element in the result set interface
Cause: Path element not specified for the ctx_tree element
Action: add path element for the ctx_tree element
DRG-13613: Missing index name
Cause: index name not specified in the API
Action: specify an index name
DRG-13614: result_set_inteface not supported with security policy
Cause: result set interface not supported with security policies
Action: cannot use result set interface on table with security policy
DRG-13615: Only one snippet element allowed in result set interface
Cause: More than one snippet element specified with result set interface
Action: Specify only one snippet element with result set interface
DRG-13616: Invalid MVDATA group counting topn in result set interface
Cause: Cannot use group values and topn for the same group counting
Action: Use group_values or topn
DRG-13617: Invalid MVDATA value for topn in result set interface
Cause: Cannot use topn less than or equal to zero
Action: Use topn greater than zero
DRG-13618: Error in group counting in result set interface
Cause: Cannot do group count for facets with no data
Action: Check facet name or index needed facet values
DRG-13619: Invalid value for MVDATA sortby in result set interface
Cause: Invalid value provided for sortby criteria in result set interface
Action: Select either count or alpha
DRG-13620: Invalid value for MVDATA order in result set interface
Cause: Invalid value provided for order criteria in result set interface
Action: Select either asc or desc
DRG-13621: Duplicate group count element in result set interface
Cause: Group Count element specified more than once for group
Action: Specify one count element for a group
DRG-13700: Syntax error in the Extraction Rule Descriptor
Cause: The Extraction Rule descriptor has a syntax error
Action: check the syntax of the Extraction rule descriptor
DRG-13701: Invalid rule_id
Cause: rule_id is NULL or rule_id <= 0
Action: rule_id must be number > 0
DRG-13702: Rule not found
Cause: No rule for given rule_id
Action: Specify a valid rule_id
DRG-13703: Invalid Type Specified: string
Cause: An invalid entity type was specified
Action: Specify a valid entity type
DRG-13704: Invalid Entity Type List
Cause: An invalid entity type list was specified
Action: Check format and types on entity type list
DRG-13705: Must use an Extract Policy
Cause: Using a non-extraction policy
Action: Use a policy created with ctx_entity.create_extract_policy
DRG-13706: Cannot use Entity Extraction Policy here
Cause: Using an entity extraction policy
Action: Use a policy created with ctx_ddl.create_policy
DRG-13707: Rule Engine Loading Failed
Cause: A user rule has an error
Action: Fix the user rule with the error
DRG-13708: Dictionary Loading Failed
Cause: The user dictionary has an error
Action: Fix the user dictionary
DRG-13709: Unsupported Language Specified: string
Cause: Unsupported Language Specified
Action: Specify a supported language
DRG-13710: Syntax Error in Dictionary
Cause: Syntax error in dictionary
Action: Correct syntax error in dictionary
DRG-13711: Stop Entity Not Found
Cause: Tried to remove a non-existent stop entity
Action: Cannot remove non-existent stop entity
DRG-13712: User Dictionary already loaded
Cause: Tried to load a 2nd user dictionary to a policy
Action: Drop the dictionary, and then load
DRG-13713: No User Dictionary loaded
Cause: No user dictionary loaded for this policy
Action: Cannot drop non-existent dictionary
DRG-13714: Duplicate Stop Entity
Cause: Trying to load a duplicate uncompiled stop entity
Action: Stop entity is already present
DRG-13715: Null name and type for Stop entity
Cause: Trying to load a stop entity with null name and type
Action: Stop entity must have at least one parameter non-null
DRG-13716: Entity Extraction not enabled
Cause: Haven't loaded correct event
Action: Must load correct event and level
DRG-13717: Null entry or alternate form in user dict
Cause: A entry or alternate form has null value
Action: Entries or alternate forms must be non-null
DRG-13718: No entity type given in user dict
Cause: An entry was not given an entity type
Action: All entries must have an entity type
DRG-13719: File and Drop are mutually exclusive
Cause: Tried to run ctxload with file and drop
Action: file and drop are mutually exclusive
DRG-13720: Stop entity already marked for deletion
Cause: Tried to re-drop a stop entity
Action: Only drop this stop entity once
DRG-13721: Duplicate Type on Typelist
Cause: Duplicate type on typelist
Action: Typelist must be unique
DRG-13722: Invalid Backreference
Cause: Backreference not between 1 and 10
Action: Backreferences must be between 1 and 10
DRG-13723: Invalid Attribute: string
Cause: Unsupported Attribute
Action: Follow correct syntax for rule or dictionary
DRG-13724: Invalid Attribute Value: string
Cause: Unsupported attribute value
DRG-13725: Type Name Too Long
Cause: Type name more than 30 bytes
Action: Type must be less than 30 bytes
DRG-13726: Invalid Tag: string
Cause: Unsupported Tag
DRG-13727: Missing Tag: string
Cause: Missing Necessary Tag
Action: Add tag for rule or dictionary
DRG-13728: Missing Attribute: string
Cause: Missing Necessary Attribute
Action: Add attribute for rule or dictionary
DRG-13800: MVDATA section string does not exist
Cause: The given MVDATA section name does not exist in USER_SECTIONS
Action: Rewrite query with valid MVDATA section name
DRG-13801: literal is not compatible with the data type of the MVDATA section
Cause: The given literal is not compatible with the data type of the specified MVDATA section.
Action: Rewrite query with a compatible literal
DRG-13802: MVDATA operand not compatible with the mvdata section string
DRG-13803: Illegal MVDATA value
DRG-13804: ctx_tree.register_index() not run for index string and mvdata section string
Cause: failed to create data
Action: create the data (trees) first
DRG-13805: Invalid character in node name string
DRG-13806: Duplicate path 'string' in CTX_TREE.ADD_NODE()
Cause: The path specified in ctx_tree.add_node() adds the node with the same name in the same tree at the same level
Action: change path
DRG-13807: Node string does not exist or is deleted
Cause: failed to lookup input node
Action: check if the path exists
DRG-13808: Empty path passed into string
Cause: path is empty
Action: pass in a non-empty and valid path
DRG-13809: Index with MVDATA sections must have big_io turned on
Cause: Big_io option not specified for MVDATA index
Action: turn on big_io for the index
DRG-13810: Index with support_ctx_tree must have atleast one MVDATA section
Cause: MVDATA section not specified for ctx_tree usage
Action: add one MVDATA section for the index
DRG-13811: Invalid path 'string' in CTX_TREE.ADD_NODE()
Cause: The path specified in ctx_tree.add_node() is invalid.
Action: change path
DRG-13812: Partitioned Index with MVDATA must have index-level big_io
Cause: Index-level big_io was not specified
Action: turn on big_io at index level
DRG-13900: Auto_Optimize Process is already started
Cause: Auto_Optimize Process is already started
Action: Can't start auto_optimize when it's already running
DRG-13901: Index must have stage_itab
Cause: Auto_Optimize works on indexes with stage_itab
Action: Use an index with stage_itab for auto_optimize
DRG-13902: Index/Partition already added to auto_optimize list
Cause: Index/Partition already added to auto_optimize list
Action: Can't add index/partition to list twice
DRG-13903: Index/Partition not on the auto_optimize list
Cause: Index/Partition not on the auto_optimize list
Action: Can't remove index/partition from list
DRG-50000: requested size larger than pagesize
Cause: The requested memoery size is larger than page size,
Action: Contact support
DRG-50100: CORE LSF error: string
Cause: detect a CORE LSF error
Action: look up the core error and take appropriate action
DRG-50101: CORE LEM error: string
Cause: detect a CORE LEM error while reading the error stack
DRG-50200: Third-party filter internal error
Cause: Third-party filter could not filter this document because of an internal error.
Action: Contact Oracle Support.
DRG-50300: error sending message from server to client
Cause: internal database error or internal Text error
Action: Call customer support
DRG-50301: server error reading request queue
Cause: database error or internal Text error
DRG-50302: server error reading OOB break queue; cannot detect interrupts
DRG-50303: error in bufout
Cause: This is an internal error
DRG-50304: error in execute()
DRG-50305: getcmd() called when one of the queue names is NULL
DRG-50400: maximum number of fuzzy match candidates exceeded: string
Cause: Internal error, probably result of large number of indexed words
Action: Contact Oracle support
DRG-50401: failed to retrieve fuzzy match candidates from db: string
DRG-50402: Index validation failed for one or more tokens
Cause: Index validation generated an error for one or more tokens
Action: Check the ctx log for the detailed errors
DRG-50403: Invalid MVDATA entries exist in the index
DRG-50500: only RULE_CLASSIFIER is accepted in this API
Cause: you specified an illegal classifier
Action: use RULE_CLASSIFIER
DRG-50501: classifier preference not specified
Cause: the classifier preference is not specified
Action: specify a classifier preference
DRG-50502: cannot use RULE_CLASSIFIER in this API
Cause: you specified RULE_CLASSIFIER
Action: use a different classifier
DRG-50503: unsupported classification method
Cause: you spcified an unsupported classification method
DRG-50504: invalid column datatype for string table
Cause: the column datatype is invalid
Action: specify a different datatype
DRG-50600: assertion failed
Cause: An internal check-condition has been violated
Action: Contact Oracle support for assistance
DRG-50601: fatal error
Cause: A fatal error has occurred
DRG-50603: unrecognized operation code string
Cause: Bad operation code was encountered (reached switch default:)
Action: check .h files versions
DRG-50607: failed to obtain column info for cid string
Cause: internal error, probably a bug
Action: call customer support
DRG-50608: unexpected end of data
DRG-50609: pipe internal error
DRG-50610: internal error: string
DRG-50611: Third party lexer internal error: string
Cause: internal error from inxight lexer
DRG-50612: internal error: you need to call bind first for this insertion mode
DRG-50613: internal error: model type is not supported in drctrwpf
DRG-50614: library loading error in string
DRG-50615: Third party lexer timed out
Cause: Third-party auto lexer could not complete tokenization because the lexer timed out.
Action: Increase the value of the TIMEOUT attribute of the auto_lexer and reindex the document. If TIMEOUT is set to 0 and the lexer still hangs context Oracle Support.
DRG-50616: Stop-Optimize List not found
Action: calll customer support
DRG-50617: Query string too long: string
Action: Invalid query string provided
DRG-50700: unknown command (args=queue, command)
Cause: this is an internal error
Action: Contact Oracle support to report a bug
DRG-50701: error in listener.get_cmd()
DRG-50702: error in drtlsleep()
Cause: this is an internal error in a testing function
DRG-50703: listener startup error
DRG-50704: Net8 listener is not running or cannot start external procedures
Cause: Oracle Text needs to call external code to complete your request, and could not start the extproc agent process.
Action: Start listener if it is configured for external procedures and is not running. If your listener is running, configure it for starting external procedures and restart it. Consult Oracle documentation for details.
DRG-50800: failed to open cursor
Cause: Too many cursors open for internal queries
Action: implement cursor cleanup routine
DRG-50801: failed to parse cursor
Cause: parse error on an internal query
Action: check versions of code
DRG-50802: failed to bind input
Cause: bind error on an internal query
DRG-50803: failed to define output
Cause: define error on an internal query
DRG-50804: failed to exec cursor
Cause: exec error on an internal query
Action: debug code
DRG-50805: failed to close cursor
Cause: cursor close error on an internal query
DRG-50806: failed to rollback
Cause: transaction rollback error
Action: contact support
DRG-50807: failed to commit
DRG-50850: string
Cause: This is an oracle error
Action: See RDBMS documentation
DRG-50851: SQL execute failed
Cause: failed to execute a sql statement
Action: please report this as a bug
DRG-50852: failed to turn SQL trace on
Action: Please contact Oracle support
DRG-50853: fetch error
Cause: fetch error on an internal query
DRG-50855: logoff fail
Cause: Fail to logoff from the database
DRG-50857: oracle error in string
Cause: this is an informational message
Action: See error
DRG-50858: OCI error: string
Cause: a generic OCI error occurred
DRG-50859: failed to allocate statement handle
DRG-50860: failed to prepare statement
DRG-50861: failed to obtain type descriptor
DRG-50862: failed to create new Oracle object
DRG-50863: string assignment failed
DRG-50864: number assignment failed
DRG-50865: failed to append to collection
DRG-50866: failed to resize string
DRG-50867: failed to free Oracle object
DRG-50868: failed to free statement handle
DRG-50900: text query parser error on line string, column string
Cause: bad query
Action: fix query
DRG-50901: text query parser syntax error on line string, column string
Cause: bad query
Action: fix query
DRG-50902: unexpected character string
Cause: bad query
Action: fix query
DRG-50903: invalid weight string
Cause: invalid weight
Action: fix query
DRG-50904: weight string outside valid range 0.1 to 10.0
Action: fix query
DRG-50905: invalid score threshold string
Cause: invalid score threshold
Action: fix query
DRG-50906: score threshold string is not an integer
Action: fix query
DRG-50907: score threshold string outside valid range 1 to 100
Action: fix query
DRG-50908: invalid maximum number of documents string
Cause: invalid maximum number of documents
Action: fix query
DRG-50909: maximum number of documents string is not an integer
Action: fix query
DRG-50910: max documents requested string outside valid range 1 to 65535
Action: fix query
DRG-50911: invalid first document number string
Cause: invalid first document number
Action: fix query
DRG-50912: first document number string is not an integer
Action: fix query
DRG-50913: first document requested string is not a positive number
Action: fix query
DRG-50914: invalid last document number string
Cause: invalid last document number
Action: fix query
DRG-50915: last document number string is not an integer
Action: fix query
DRG-50916: last document string is less than first document
Action: fix query
DRG-50917: escape on at end of text query string
Cause: unbalanced escape characters
Action: turn escape off
DRG-50918: mismatched close escape character
Cause: no matching open escape character for close escape
Action: match open and close escapes
DRG-50919: NEAR operand not a phrase, equivalence or another NEAR expression
Cause: invalid operand type for NEAR operator
Action: correct operand type
DRG-50920: part of phrase not itself a phrase or equivalence
Cause: invalid type of expression which is part of phrase
Action: fix query
DRG-50921: EQUIV operand not a word or another EQUIV expression
Cause: invalid operand type for EQUIV operator
DRG-50922: PL/SQL execution failed for string
Cause: PL/SQL function may not exist or is returning bad value
Action: PL/SQL may not exist or is returning bad value
DRG-50923: could not rewrite PL/SQL for execution
Cause: parser internal
Action: call support
DRG-50924: PL/SQL inside PL/SQL not supported
Cause: PL/SQL function call returned another PL/SQL call
Action: remove recursive PL/SQL
DRG-50925: could not parse return value of PL/SQL
Cause: string returned by PL/SQL function could not be parsed
Action: fix PL/SQL function being called
DRG-50926: invalid text query string
Cause: query string empty or made up of invalid characters
Action: fix query
DRG-50927: parser failed on line string on column string
Cause: bug
DRG-50928: reserved failure on line string on column string
Cause: bug
DRG-50929: parser internal on line string on column string
Cause: bug
DRG-50930: parser memory failure on line string on column string
Cause: memory allocation or freeing error
DRG-50931: parser not opened
Cause: bug
DRG-50932: parser preference initialization failed
Cause: bug
DRG-50933: parser hash insert failure
Cause: bug
DRG-50934: parser hash create failure
Cause: bug
DRG-50935: parser component failure
Cause: bug
Action: look for other errors
DRG-50936: query word string is too complex for index
Cause: bug
DRG-50937: query too complex
Cause: query is too complex for our query evaluator
Action: make query smaller
DRG-50938: parser already bound
Cause: internal coding mistake
DRG-50939: parser not set
Cause: bug
DRG-50940: parser not parsed
Cause: bug
DRG-50941: PL/SQL function string cannot be executed
Cause: PL/SQL function may not exist or cannot be executed by user
Action: rewrite PL/SQL function specified in query
DRG-50942: errors: stringstring
Cause: PL/SQL function encountered error -- this is the error message
Action: See error message
DRG-50943: query token too long on line string on column string
Cause: A query token is longer than 256 bytes
DRG-50944: NEAR operator not supported for theme index
Cause: NEAR operator used in theme index query
Action: Rewrite query without NEAR operator
DRG-50945: Illegal phrase in query for theme index
Cause: Phrase incorrectly defined in theme index query
DRG-50946: Invalid unary operator for theme index
Cause: Stemming, fuzzy match and soundex not allowed for theme index
DRG-50947: ABOUT clause not allowed without a theme index
Cause: The query contains an ABOUT clause, but there is no theme index to support it
DRG-50948: ABOUT clause required in the absence of a text index
Cause: There is no text index, but the query does not contain any about clause. With only a theme index present, each query term must belong to an ABOUT clause
DRG-50949: too many SQEs
Cause: Too many SQEs to expand
Action: Rewrite query or SQE
DRG-50950: circular SQE found
Cause: Circular SQE reference is found.
DRG-50951: Unable to resolve element name for attribute string
Cause: XPATH expression such as A/*/@B or A//@B is not supported.
DRG-50952: Section is not PATH section group
Cause: XPATH expression has section which is not created using PATH section group.
Action: Rewrite query not to use XPATH expression or create the index with PATH section group
DRG-50953: Unable to determine section name
Cause: XPATH expression should not end with . or *
Action: Rewrite the path expression not to use . or * at the end
DRG-50954: Theme index is required for CTXCAT about queries
Cause: There is no theme index, but the catsearch query contains about clause. You must create a theme index before using ABOUT query against CTXCAT index
Action: create theme index
DRG-50955: Missing comma in transform clause string
Cause: A transform clause in a query template is missing a comma
Action: Add the comma in the appropriate position
DRG-50956: Theme index is required for THEMES transform queries
Cause: There is no theme index, but the operator TRANSFORM is used with THEMES as its parameter. You must create a theme index before using THEMES in TRASNFORM operator.
DRG-50957: Missing textquery element in query template string
Cause: The textquery tag is missing or misspelled in a query template
Action: Correct the missing tag
DRG-50958: Missing quote in transform clause string
Cause: A transform clause in a query template is missing a quote
Action: Add the quote in the appropriate position
DRG-50959: Query length exceeds string bytes
Cause: the query length exceeds the maximum allowed length
Action: reduce the length of the query
DRG-50960: Mild not operand not a term or phrase
Cause: invalid operand type for MNOT operator
DRG-50961: Missing string for string clause
Cause: the specified tag is missing from the specified complex query clause
Action: Add missing clause
DRG-50962: Query operators are not allowed in transform input string
Cause: You specified an operator (such as wildcard) in the input string for the transform operator
Action: Remove or escape the query operator
DRG-51002: unexpected component failure
DRG-51017: unable to open storage buffer for fuzzy match candidates
Cause: Internal error, probably insufficient memory
DRG-51019: unable to open or illegal format for fuzzy match data file: string
Cause: Unable to open OS file containing fuzzy matching information or the file was not of the correct format
Action: Consult the documentation for correct location of the fuzzy match information files and check for file damage
DRG-51020: out of memory in fuzzy matcher
Cause: Cannot allocate more memory
Action: Contact your system adminstrator
DRG-51021: undefined error in fuzzy matcher
DRG-51022: undefined error in stemmer
DRG-51023: stemmer file cannot be opened
Cause: Unable to open OS file containing stemmer lexicon, or the file contents were not correct
Action: Consult documentation for for correct location of the stemmer lexicons and check for file damage
DRG-51024: out of memory in stemmer
Action: Contact your system administrator
DRG-51025: an invalid character was passed to the stemmer
Cause: Invalid character in word input to the stemmer
Action: Remove invalid character from word to be stemmed
DRG-51028: unexpected error in fuzzy match expansion: %(1)
DRG-51029: unexpected error in stemmer expansion: %(1)
DRG-51030: wildcard query expansion resulted in too many terms
Cause: User error
Action: Make wildcard query narrower
DRG-51100: invalid program argument index
Action: Contact Oracle Support to report a bug
DRG-51101: argument processing callback failed
DRG-51200: open keymap failed for index id = string
Cause: Failed to initialize the keymap for the column id specified.
Action: Check index ID. Contact support if caused by internal errors
DRG-51201: failed to perform DDL operation: database object string
Cause: Textkey mapping service failed on DDL operation
Action: Check Oracle error and take corrective action
DRG-51202: invalid key mapping operation mode : string
Cause: invalid keymap mode value found. This is an internal error
DRG-51203: found doc ids without mappings during get maps
Cause: found doc ids without mappings during get mapping by doc ids, the index data and keymap service are out of synch.
DRG-51300: error getting dml Queue lock
Cause: a server must have hung while processing the dml Queue, leaving it locked
DRG-51301: error releasing dml Queue lock
Cause: internal database error, or perhaps someone dropped the lock while we were using it
DRG-51311: DML lock handle previously allocated
DRG-51312: DML lock internal error string
DRG-51313: timeout while waiting for lock
Cause: most likely an internal error
DRG-51314: index is not empty
Cause: you attempted to invoke populate_pending against an index which already has or has had indexed documents.
Action: populate pending manually, or recreate the index NOPOPULATE
DRG-51403: New index name not provided by kernel
DRG-51801: failed to seek in file: %(1)
DRG-51802: failed to read from file: %(1)
DRG-51803: failed to open file: %(1)
DRG-51804: failed to write to file: %(1)
DRG-52100: string returned internal error code string
DRG-52101: an invalid session handle was passed to Oracle Text
DRG-52102: an invalid transaction handle was passed to Oracle Text
DRG-52103: the Oracle Text environment could not reset
DRG-52104: the Oracle Text environment could not initialize
DRG-52105: no delete function found
DRG-52106: Oracle Text service results could not be committed
DRG-52107: ctxkbtc internal error
DRG-52108: failed to delete knowledge base user extension
Action: check file permissions or contact Oracle support
DRG-52109: error in reading thesaurus
DRG-52110: error in writing extended knowledge base
DRG-52111: error in knowledge base cache
DRG-52112: improper Chinese string string of length number
Action: n/a
DRG-52113: improper Japanese string string of length number
Action: n/a
DRG-52200: invalid state during export
DRG-52201: imcompatible Oracle Text versions
Cause: attempting to import an incompatible version of Oracle Text data
Action: make sure source and target Oracle Text versions are compatible
DRG-52202: invalid class name: string
Cause: the specified class name is not valid
DRG-52203: invalid object name: string
Cause: the specified object name is not valid
DRG-52204: error while registering index
DRG-52205: class string and object string already exists for this index
Cause: duplicate entry of class and object
DRG-52206: error while registering index object
DRG-52207: the specified attribute does not exist: string
DRG-52208: the specified attribute already exist: string
DRG-52210: error while registering value for attribute: string
DRG-52211: error while registering partition
DRG-52212: error while registering cdi columns
DRG-52300: Index string.string does not exist
Cause: The given index does not exist for the current user
Action: Give a valid index name
DRG-52301: Query Stats is already enabled for this index
Cause: attempting to enable the query stats for an index for which it is already enabled
Action: None. No need to enable again
DRG-52302: Query Stats is not enabled for this index
Cause: attempting to disable the query stats for an index for which it is not enabled
Action: None. No need to disable if it is not already enabled
DRG-52303: Option String is full
Cause: Index option string is full
Action: None
DRG-52304: This operation requires Query Stats to be enabled for the index
Cause: attempting to do an operation which required query stats option for the index to be enabled
Action: Enable query stats option for the index using ctx_output.enable_query_stats()
DRG-52305: Unknown value, string, passed in to stat_type
Cause: An invalid value is passed in to the parameter stat_type
Action: Give a valid value
DRG-52400: Dictionary string already exists
Cause: The specified dictionary already exists
Action: Must drop the dictionary if you want to re-create it.
DRG-52401: Invalid language string specified
Cause: Language specified is invalid
Action: Must specify a valid language
DRG-52402: Dictionary name is invalid
Cause: The specified dictionary name is invalid
Action: Must provide valid dictionary name
DRG-52403: Dictionary string does not exist
Cause: The specified dictionary does not exist
Action: Retry with the correct dictionary name
