Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
25 EVM-00001 to EVM-00901
EVM-00001: Cannot write raw events to a terminal
Cause: Attempted to redirect binary events to a terminal.
Action: Use evmshow to format events for display.
EVM-00002: Use evmshow to format events for display
Action: Use evmshow instead.
EVM-00003: Failed to open file "string": string
Cause: Filename, path or the permisions were not valid.
Action: Use a valid path and filename, check permissions. Otherwise contact Oracle Customer Support.
EVM-00004: Failed to open channel config file "string"
Cause: Configuration file name,the path or the permissions were not valid.
Action: Use a vaild path and filename, check permissions. Otherwise contact Oracle Customer Support.
EVM-00006: Failed to create temporary file
Cause: The file being used as a temporary file for evmsort had one of the following issues; filename, path or the permisions were not valid.
EVM-00007: Failed to write to temporary file
EVM-00008: Failed to read from temporary file
EVM-00009: Failed to create EVM posting connection
Cause: Error occured while communicating with the EVM daemon.
Action: Check log and status of the EVM daemon.
EVM-00010: Failed to read from EVM posting connection
EVM-00011: Failed to write to EVM posting connection
EVM-00012: Failed to create EVM listening connection
EVM-00013: Failed to read from EVM listening connection
EVM-00014: Failed to write to EVM listening connection
EVM-00015: Failed to create EVM service connection
EVM-00016: Failed to read from EVM service connection
EVM-00017: Failed to start EVM service "string"
Cause: EVM daemon failed to start.
Action: Check log for the EVM daemon.
EVM-00018: Failed to write to output stream
Cause: Failed to write to standard output.
Action: Contact Oracle Customer Support.
EVM-00019: Failed to read event from input stream
Cause: Bad input file for evmshow/evmsort EOF missing.
Action: Check the input file.
EVM-00020: Failed to create event subscription
Cause: Bad network connection between subscriber and EVM daemon.
Action: Check the network connection and filter string.
EVM-00021: Failed to create filter
Cause: Used a null filter string or memory allocation failed.
Action: Use a non null filter string.
EVM-00022: Invalid filter string
Cause: Used a null or invalid filter string.
EVM-00023: Filter test operation failed
Action: Use a non null filter string. Otherwise contact Oracle Customer Support.
EVM-00024: Lost connection to EVM daemon
Cause: Evmlogger lost connection to evmdaemon.
Action: Check status of evmlogger,evmd daemons and logs.
EVM-00025: Authorization database error
Cause: Not authorized to post/listen for certain events.
Action: Check evm.auth file to ensure the current user is authorized to post/listen for specific events.
EVM-00026: Failed to post event "string"
Cause: Evmpost failed to post an event.
Action: Check the status and log for EVM daemon.
EVM-00027: Memory allocation failure
Cause: The system is running low on memory.
Action: Check the availability of memory in the system.
EVM-00029: Event contains invalid values
Cause: Invalid syntax for an event was used.
Action: Use a valid syntax for an event.
EVM-00030: Event name is missing
Cause: Name of the event was missing.
EVM-00031: Event name has too few components
EVM-00032: Failed to write event
Cause: Failed to write event to output file.
Action: Check the permissions of the file. Otherwise contact Oracle Customer Support.
EVM-00033: Error in input file "string", line number
Cause: Failed to parse input file.
Action: Check input file and the line for possible errors. Otherwise contact Oracle Customer Support.
EVM-00034: Error: string
Cause: Error Occured.
Action: Look at the error message for details.
EVM-00035: EVM service "string" terminated with exit code number
Cause: EVM daemon died.
Action: Check the EVM daemon log.
EVM-00036: Host "string" is unknown
Cause: Invalid hostname discovered while trying to create a connection to the EVM daemon.
Action: Check the hostname, on which EVM daemon is running. Otherwise contact Oracle Customer Support.
EVM-00037: Failed to connect to EVM daemon on "string"
Cause: EVM daemon is dead or is not responding.
Action: Check the status of EVM daemon and logs.
EVM-00038: Failed to create an EVM event
Cause: Failed to create an EVM event.
EVM-00039: Invalid port number in host name "string"
Cause: Used an invalid port number.
Action: Use a valid or a different port number.
EVM-00040: Error occurred while reading from "string"
Cause: Error occured when evmshow was reading from an input file.
EVM-00042: Use "string -A" to format events, or pipe output to evmshow
Cause: Invalid use of evmshow command.
Action: Use evmshow command as instructed.
EVM-00043: Attempting to reconnect to the EVM daemon...
Cause: Evmwatch trying to reconnect to the evm daemon.
Action: Not an error message.
EVM-00044: Attempting to reconnect to the EVM daemon on "string"...
Cause: Evmwatch trying to reconnect to the evm daemon on this host.
EVM-00045: EVM connection re-established
Cause: Evmwatch was able to reconnect to the evm daemon.
EVM-00104: End of file reached unexpectedly
Cause: End of event template file reached unexpectedly.
Action: Check the event template file in evm/admin.
EVM-00105: Missing end-of-group character
Cause: end-of-group character missing in event template file.
EVM-00106: Missing end-of-string character
Cause: end-of-string character missing in event template file.
EVM-00107: Value "string" is not valid
Cause: Invalid value found in the event template file.
EVM-00108: Keyword "string" is not valid
Cause: Invalid keyword found in the event template file.
EVM-00201: Failed to allocate space for application object
EVM-00202: Failed to allocate space for local lock pathname
EVM-00301: Failed to open logger config file "string"
Cause: Configuration file had one of the following problems; filename, path or permissions were not valid.
Action: Check whether path and permissions are valid. Otherwise contact Oracle Customer Support.
EVM-00302: Configuration error - using default configuration
Cause: Configuration file had invalid configuration details
Action: Check the configuration file.
EVM-00303: Keyword "string" is invalid in this position
Cause: Valid Keyword was used in an invalid position in configuration file.
Action: Use the correct syntax.
EVM-00304: Configuration error in file string, line number
Cause: Configuration error in configuration file.
EVM-00305: Memory allocation failure for "string"
EVM-00306: Failed to create filter for "string"
Cause: Failed to create a filter for events for evmlogger.
Action: Check the availability of memory.
EVM-00307: Filter string invalid for "string"
EVM-00308: Failed to open eventlog "string": string
Cause: Eventlog file had one of the following problems; filename, path or permissions were not valid.
EVM-00309: Failed to write to eventlog "string"
Cause: Eventlog had one of the following problems; size or permissions were not valid.
Action: Check the permissions and the size of the eventlog file. Otherwise contact Oracle Customer Support.
EVM-00310: Invalid suppression filter for eventlog "string"
Cause: Invalid filter was used.
Action: Use a non null filter. Otherwise contact Oracle Customer Support.
EVM-00311: Invalid entry in eventlog "string" (number events OK)
Cause: Evmlogger found an invalid entry in eventlog.
Action: Check the eventlog file.
EVM-00312: Eventlog "string" disabled
Cause: Events could not be written to the eventlog file.
Action: Check the permissions,max size of the logfile.
EVM-00313: Eventlog "string" re-enabled
Cause: Events logging is reenabled.
EVM-00314: Forwarder "string" disabled
Cause: Forwarding is disabled by the evmlogger.
EVM-00315: Forwarder "string" re-enabled
EVM-00316: Suppression disabled for "string"
Cause: Error message filtering supression disabled for this string.
EVM-00317: Suppression re-enabled for "string"
Cause: Error message filtering supression reenabled for this string.
EVM-00318: Failed to open config info file "string"
EVM-00319: Keyword "string" is not allowed in a secondary config file
Cause: Invalid Keyword was used.
Action: Use a valid Keyword.
EVM-00323: Config file "string" has insecure write permission
Cause: The configuration file had write permissions for the group 'other'.
Action: Change the write permissions for the configuration file
EVM-00324: Config file "string" has incorrect ownership
Cause: Configuration file should be owned by root or bin.
Action: Change the owner of configuration file to root or bin.
EVM-00325: Config file "string" is not a regular file
Cause: Configuration file is not a regular file.
EVM-00401: Failed to open binary event library file
Cause: Binary event file had one of the following problems; filename, path or permissions were not valid.
EVM-00601: Data read from the input stream is not a valid EVM event
Cause: evmshow tried to read an invalid EVM event.
Action: Check the logs for the evm daemon.
EVM-00701: Check that the event is registered and you are authorized to post it
Cause: Not authorized to post for certain events.
Action: Check evm.auth file to ensure the current user is authorized to post the specific event.
EVM-00702: Priority must be an integer in the range 0-number
Cause: Used an integer out of the range for priority.
Action: Use a valid integer.
EVM-00801: Missed number subscribed-to event(s)
Cause: Missed some events during the connection setup phase.
EVM-00802: Failed to reconnect within number seconds - terminating
Cause: Failed to establish a connection with EVM daemon.
Action: Check the logs for EVM daemon.
EVM-00901: Invalid sort specification "string"
Cause: Invalid sort specification used for evmsort.
Action: Use a valid sort specification. Look at documentation for evmsort using evmsort -h.
