Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
39 LRM-00100 to LRM-00123
LRM-00100: internal error [number]
Cause: An internal error has occurred.
Action: Contact Oracle Support Services and report the error.
LRM-00101: unknown parameter name 'string'
Cause: The parameter name was misspelled.
Action: Spell the parameter name correctly.
LRM-00102: 'string' is not in the legal range for 'string'
Cause: The value of the parameter is not within the legal range.
Action: Refer to the manual for the allowable values for this parameter.
LRM-00103: 'string' contains an illegal integer radix for 'string'
Cause: An illegal integer radix specification was found.
Action: Only 'd', 'h', 'D', and 'H' may be used as radix specifications.
LRM-00104: 'string' is not a legal integer for 'string'
Cause: The value is not a valid integer.
Action: Specify only valid integers for this parameter.
LRM-00105: 'string' is not a legal Boolean for 'string'
Cause: The value is not a valid Boolean.
Action: Refer to the manual for allowable Boolean values.
LRM-00106: out of memory
Cause: The operating system has run out of memory.
Action: Take action to make more memory available to the program.
LRM-00107: parameter name abbreviation 'string' is not unique
Cause: The given abbreviation was not unique.
Action: Use a longer abbreviation to make the parameter name unique.
LRM-00108: invalid positional parameter value 'string'
Cause: An invalid positional parameter value has been entered.
Action: Remove the invalid positional parameter.
LRM-00109: could not open parameter file 'string'
Cause: The parameter file does not exist.
Action: Create an appropriate parameter file.
LRM-00110: syntax error at 'string'
Cause: A syntax error was detected.
Action: Change the input so that the correct syntax is used.
LRM-00111: no closing quote for value 'string'
Cause: A quoted string was started but not finished.
Action: Put a closing quote in the proper location.
LRM-00112: multiple values not allowed for parameter 'string'
Cause: An attempt was made to specify multiple values for a parameter which can take only one value.
Action: Do not specify more than one value for this parameter.
LRM-00113: error when processing file 'string'
Cause: A problem occurred when processing this file.
Action: Examine the additional error messages and correct the problem.
LRM-00114: error when processing from command line
Cause: A problem occurred when processing the command line.
LRM-00115: error when processing an environment variable
Cause: A problem occurred when processing an environment variable.
LRM-00116: syntax error at 'string' following 'string'
LRM-00117: syntax error at 'string' at the start of input
LRM-00118: syntax error at 'string' at the end of input
LRM-00119: unable to obtain a valid value for 'string'
Cause: No valid value was obtained for this parameter.
Action: Rerun the application and enter a valid value.
LRM-00120: 'string' is not a legal Oracle number for 'string'
Cause: The value is not a valid Oracle number.
Action: Refer to the manual for allowable Oracle number values.
LRM-00121: 'string' is not an allowable value for 'string'
Cause: The value is not a legal value for this parameter.
Action: Refer to the manual for allowable values.
LRM-00122: value 'string' for 'string' must be between 'number' and 'number'
Action: Specify a value that is within the legal range.
LRM-00123: invalid character number found in the input file
Cause: A character that is invalid was found in the input file.
Action: Specify an input file that contains only valid characters.
