LSX-00001: NULL pointer
Cause:
A NULL pointer was detected as an internal error condition.
Action:
This is a programming error by the caller of the Schema processor. Contact someone who can fix the problem.
LSX-00002: root element is not schema
Cause:
The top-level element of an XML Schema must be schema.
Action:
Correct the Schema; consult the Schema specification.
LSX-00003: invalid attribute "~1S" for element "~2S"
Cause:
The named Schema element had an invalid attribute.
Action:
LSX-00004: unexpected XML node type
Cause:
Schema contains an XML node other than element, text (or CDATA),
Action:
Other node types are not permitted; remove them.
LSX-00008: feature "~s" is not implemented
Cause:
An attempt was made to use a feature that is not yet implemented.
Action:
Make an enhancement request for the feature.
LSX-00009: data missing for type "~S"
Cause:
Data is missing for an element or attribute of a simple type.
Action:
Add data in the element or attribute.
LSX-00010: extra element(s) at end of "~S"
Cause:
Extra elements exist at the end of schema component declarations.
Action:
Remove the extra elements.
LSX-00011: internal error: ~s\n
Cause:
Implementation error.
Action:
File a bug.
LSX-00013: element "~S" not from Schema of Schemas
Cause:
Bogus element exists in the schema file. Its name is not from Schema of Schemas.
Action:
Remove the bogus element.
LSX-00014: empty instance document
Cause:
Instance document to be Schema validated was empty (no top-level element).
Action:
Provide a complete XML instance document.
LSX-00015: failed to parse document
Cause:
Failed to parse the schema document using the given URI.
Action:
Provide the correct URI and make sure that the schema document is valid.
LSX-00016: schema and instance document have incompatible character sets
Cause:
Parsed schema components were in a simple-type character set while the parsed instance document data was not. A simple-type character set is single-byte, not shift sensitive, and has no linguistic specials in use.
Action:
Reinitialize the schema global context with appropriate parser context settings, i.e. pass a parser context with its output encoding set to be a multibyte or Unicode character set.
LSX-00018: invalid schema context
Cause:
An invalid schema context was provided to the processor. Multiple schema documents were loaded and assembled into the schema context. At least one of them is not fully valid with respect to a schema corresponding to the Schema for Schemas.
Action:
Check the errors reported when schema documents were loaded, mapped, or validated. Correct errors found in the identified schema documents and reload them into a new schema context. Then provide the new schema context to the processor.
LSX-00020: unknown type "~S"
Cause:
A specified type was unknown (not defined in any loaded Schemas).
Action:
Make sure the type was defined and that the type usage referenced the correct Schema.
LSX-00021: undefined element "~S"
Cause:
Element is undefined in the specified namespace.
Action:
If the element name is misspelled, correct the spelling.
LSX-00022: unknown namespace prefix "~S"
Cause:
Prefix in a QName is undefined in the current scope.
Action:
Correct the prefix name if it's misspelled.
LSX-00023: unknown namespace URI "~S"
Cause:
Namespace URI is unknown to the schema processor.
Action:
Correct the namespace URI if it's misspelled.
LSX-00024: unknown attribute group "~S"
Cause:
The name of attribute group is unknown to the schema processor in the current scope.
Action:
Correct the name of attribute group if it's misspelled.
LSX-00025: unknown group "~S"
Cause:
The name of group is unknown to the schema processor in the current scope.
Action:
Correct the name of group if it's misspelled.
LSX-00026: unknown attribute "~S"
Cause:
The name of attribute is unknown to the schema processor in the current scope.
Action:
Correct the name of attribute if it's misspelled.
LSX-00027: property "~s" unknown
Cause:
The named validation property was unknown.
Action:
Refer to the documentation for the complete list of validation properties.
LSX-00102: duplicate element "~S"
Cause:
Element declaration is not unique within its scope.
Action:
Rename the element.
LSX-00103: duplicate group "~S"
Cause:
Group declaration is not unique within its scope.
Action:
Rename the group.
LSX-00104: duplicate type "~S"
Cause:
Type definition is not unique within its scope.
Action:
Rename the type.
LSX-00105: duplicate attribute group "~S"
Cause:
Attribute group declaration is not unique within its scope.
Action:
Rename the attribute group.
LSX-00106: duplicate attribute "~S"
Cause:
Attribute declaration is not unique within its scope.
Action:
Rename the attribute.
LSX-00110: facet "~S" should have single value attribute
Cause:
A facet declaration did not have a value attribute.
Action:
Each facet declaration must contain one and only one value attribute.
LSX-00111: type "~S" contains invalid facets
Cause:
A specified facet was invalid for a type. Each datatype has a different set of facets which may apply.
Action:
Use only applicable facets for the type.
LSX-00112: facet "~S" duplicated
Cause:
A facet (other than "enumeration") was specified more than once.
Action:
Only the enumeration facet may be used more than once for a type.
LSX-00113: facet "~1S" has invalid value "~2S"
Cause:
Facet value contained illegal characters or its value was out of range.
Action:
Remove illegal characters.
LSX-00114: facet "~S" not in schema schema
Cause:
Facets are not defined in the XMLSchema namespace.
Action:
Remove illegal facet declarations.
LSX-00116: mutually exclusive facets are not allowed
Cause:
Mutual exclusiveness violations were found for facets. For example, both "length" and either "minLength" or "maxLength" are not allowed to be facets.
Action:
Remove the facets that are at fault.
LSX-00117: "minLength" should not be greater than "maxLength"
Cause:
The value of "minLength" must be less than or equal to the value of "maxLength".
Action:
Correct either "minLength" or "maxLength".
LSX-00118: fixed facet value cannot be changed
Cause:
The value of a fixed facet in the base type definition should remain the same.
Action:
Remove the fixed facet specification in the parent's type for the erroneous facet component.
LSX-00119: value is not valid restriction of parent's minLength
Cause:
There was an error in that minLength was among the members of {facets} of {base type definition} and {value} was less than the {value} of the parent minLength.
Action:
Increase the {value} of minLength.
LSX-00120: value is not valid restriction of parent's maxLength
Cause:
There was an error in that maxLength was among the members of {facets} of {base type definition} and {value} was greater than the {value} of the parent maxLength.
Action:
Increase the {value} of maxLength.
LSX-00121: value is not valid restriction of parent's length
Cause:
There was an error in that length was among the members of {facets} of {base type definition} and {value} was not equal to the {value} of the parent length.
Action:
Make {value} the same as parent's.
LSX-00122: value is not valid restriction of parent's whiteSpace
Cause:
There was an error in that whiteSpace was among the members of {facets} of {base type definition} and at least one of the following conditions was true: 1 {value} is replace or preserve and {value} of the parent whiteSpace is collapse 2 {value} is preserve and the {value} of the parent whiteSpace is replace
Action:
Change the {value} of whiteSpace.
LSX-00123: base type is required
Cause:
Missing base type declaration in the type definition.
Action:
Define a base type.
LSX-00124: "list" element is improperly defined
Cause:
A "list" element either must have its "itemType" attribute set or have one of its children be a "simpleType" element, but both conditions cannot exist.
Action:
Remove the erroneous condition.
LSX-00125: "restriction" element is improperly defined
Cause:
A "restriction" element either must have its "base" attribute set or have one of its children be a "simpleType" element, but both conditions cannot exist.
Action:
LSX-00126: facet "~1S" has invalid value "~u"
Cause:
Action:
LSX-00127: totalDigits must be greater than or equal to fractionDigits
Cause:
The value of the facet totalDigits is less than the value of the facet fractionDigits.
Action:
Ensure that totalDigits is greater than or equal to fractionDigits.
LSX-00130: attribute "processContents" has invalid value "~S"
Cause:
Attribute "processContents" in the "any" element or "anyAttribute" declaration has an invalid value.
Action:
Specify one of the following values: lax, skip, or strict.
LSX-00132: attribute "~1S" has invalid occurrences value "~2S"
Cause:
A minOccurs or maxOccurs attribute had an invalid value (not a integer or less than zero).
Action:
Use a legal "occurs" value.
LSX-00133: attribute "use" has invalid value "~S"
Cause:
A "use" attribute had an invalid value. Choices for "use" are "default", "fixed", "optional", "prohibited", or "required".
Action:
Change the attribute to one of the above values.
LSX-00134: attribute "~1S" has invalid qualification "~2S"
Cause:
An attribute that specifies qualification (form, attributeFormDefault, elementFormDefault) was invalid; it must be one of "qualified" or "unqualified".
Action:
LSX-00135: invalid min/max Occurs for all element, must be 0/1
Cause:
"minOccurs" has a value other than 0/1 or "maxOccurs" has a value other than 1.
Action:
Specify 0/1 for "minOccurs" or "maxOccurs".
LSX-00136: "maxOccurs" is less than "minOccurs"
Cause:
The value of the "maxOccurs" specification is less than the value of the "minOccurs" specification.
Action:
Correct "minOccurs" or "maxOccurs".
LSX-00141: ID type may only be used in attributes
Cause:
For backward compatibility with DTD, ID type may only be used in attributes.
Action:
Remove the ID type.
LSX-00142: invalid sub-element "~1S" for element "~2S"
Cause:
There was an invalid sub-element in the content of either the attribute or the element declaration. This was because the sub-element was either at the wrong position or out of context.
Action:
Remove the sub-element or move it to the correct position.
LSX-00143: element "~S" must have type or ref
Cause:
A Schema element was declared but was neither type or reference.
Action:
One of type or reference must be specified.
LSX-00144: attribute "~1S" invalid derivation-restriction value "~2S"
Cause:
An attribute which specifies a derivation-restriction setting (block, content, final) had an invalid value. Choices are "#all", "extension", or "restriction".
Action:
LSX-00145: attribute "~1S" invalid derived value "~2S"
Cause:
A derivedBy attribute had an invalid value. Choices are "extension" or "restriction".
Action:
LSX-00146: element or attribute is improperly defined
Cause:
An element or attribute definition must have either its "type" attribute set or must have one of its children be a "simpleType" or "complexType" element but both conditions cannot exist.
Action:
LSX-00147: "~1S" cannot contain "~2S"
Cause:
An invalid schema component exists in the current declaration.
Action:
Remove the schema component.
LSX-00148: annotation must come first in "~S"
Cause:
"annotation" element must be the first in the content.
Action:
Make "annotation" the first element.
LSX-00149: duplicated ID specified in "~S"
Cause:
An attempt was made to specify two distinct members of {attribute uses}with {attribute declaration}s, both of whose {type definition}s are from ID or are derived from ID.
Action:
Declare only one member of the {attribute uses} whose {type definition} is from ID or will be derived from ID.
LSX-00150: attributeGroup reference shouldn't have children
Cause:
A reference-to-attributeGroup element has children. It is suppose to be empty except for annotations.
Action:
Remove the children.
LSX-00151: invalid combination of attributes "ref" and "name"
Cause:
If the item's parent is not schema, then either the "ref" or the "name" attribute must be present, but not both. Top-level elements or attributes must have a name.
Action:
Specify either the "ref" or "name" attribute.
LSX-00152: only "minOccurs", "maxOccurs", or "id" is allowed
Cause:
If the item's parent is not schema and "ref" is present, then "complexType", "simpleType", "key", "keyref", "unique", "nillable", "default", "fixed", "form", "block", and "type" must be absent.
Action:
Remove the prohibited attribute.
LSX-00153: invalid combination of default and fixed attributes
Cause:
It is an error for a declaration to contain both fixed and default attributes.
Action:
Remove either the default or the fixed attributes.
LSX-00154: attribute "use" must have its value set to "optional"
Cause:
If "default" and "use" are both present, use must have its value set to "optional".
Action:
Remove the default attribute or change the value of the "use" attribute.
LSX-00155: invalid use of attribute "ref"
Cause:
If the item's parent is not schema and the attribute "ref" is present, then the element "simpleType" and the attributes "form" and "type" must be absent.
Action:
Remove the prohibited items.
LSX-00156: type is final and no derivations are allowed
Cause:
Derivation from a type that is declared to be final occurred.
Action:
Remove the final declaration from the base type.
LSX-00157: "~S" is abstract and cannot be used in an instance document
Cause:
The element declaration or the type definition was abstract.
Action:
When an element is declared to be abstract, a member of that element's substitution group must appear in the instance document. When an element's corresponding type definition is declared as abstract, all instances of that element must use xsi:type to indicate a derived type that is not abstract.
LSX-00158: base type of "~S" must be simple type or primitive datatype
Cause:
The derivation constraint was violated.
Action:
Use complexType instead of simpleType.
LSX-00159: list content of multiple simple types is not allowed
Cause:
Two or more simple types were specified within the list content .
Action:
Specify only one simple type.
LSX-00160: invalid substitution group affiliation between "~S" and "~S"
Cause:
There was an error in that {substitution group exclusions} prevented substitution group affiliation by type restriction or type extension.
Action:
Remove the offending deriving method from the {substitution group exclusions} list.
LSX-00161: disallowed type substitution between "~S" and "~S"
Cause:
There was a substituted type whose deriving method falls in the union of the {disallowed substitutions} and the {type definition}'s {prohibited substitutions}.
Action:
Remove the offending deriving method from the element's {disallowed substitutions} list or the {type definition}'s {prohibited substitutions} list.
LSX-00162: string "~S" is an invalid default for the complex type
Cause:
If the {content type} is a simple type definition, then the string must be valid with regard to the simple type definition as defined by String Valid (3.14.4). If the {content type} is mixed, then the {content type}'s particle must be emptiable as defined by Particle Emptiable (3.9.6). However, one of these conditions was not met, resulting in this error.
Action:
Make the default string a valid default with regard to the complex type definition.
LSX-00163: duplicated content specification in "~S"
Cause:
There was a duplicate content specification in the children of complexType.
Action:
Remove the duplicate content specification.
LSX-00164: no content specified in "~S"
Cause:
In a simpleContent specification, either "restriction" or "extension" was not specified as a child.
Action:
Add either a "restriction" or an "extension" element information item.
LSX-00165: content type of "~S" must be simple type
Cause:
The content type of the type definition was not a simple type definition.
Action:
Use complexContent instead of simpleContent .
LSX-00166: both content types must be mixed or both must be element-only
Cause:
If the content types of the derived type and base type are not the same simple type definition and the content type of the base type is not empty, then both content types must be mixed or both must be element-only. This was not the case, resulting in this error.
Action:
Add attribute mixed="true" or remove it.
LSX-00167: defining form of "~S" must occur at the top level
Cause:
The defining form did not occur at the top level of a schema.
Action:
Move attributeGroup or group definition to the top level of the schema.
LSX-00168: referring form of "~S" must NOT occur at the top level
Cause:
The referring form did not occur within a complex type definition or an attribute group definition.
Action:
Move the attributeGroup definition to within a complex type definition or an attribute group definition. Or, move the group definition to within a complex type, restriction, extension, choice, or sequence.
LSX-00169: circular group reference is disallowed outside redefine
Cause:
There was a circular group reference.
Action:
One of the group references needs to be changed to a group definition.
LSX-00170: union must have memberTypes attribute or some simpleType children
Cause:
There was no member type definition for the union declaration.
Action:
Add memberTypes attribute or simpleType children.
LSX-00171: missing required sub-element "~S"
Cause:
The sub-element specified in the error message was required.
Action:
Add the required sub-element.
LSX-00172: "~S" is not a valid restriction of "~S"
Cause:
The schema component constraint, Derivation Valid (Restriction, Complex) or Particle Valid (Restriction), was violated.
Action:
Modify the base type (particle) or the restricted type (particle) definition.
LSX-00173: ~S of ~S type is not a valid restriction of ~S of ~S type
Cause:
The schema component constraint, Particle Restriction OK (Elt:Elt -- NameAndTypeOK), was violated.
Action:
Modify either or both element declaration particles.
LSX-00174: "~S" is not a valid derivation of "~S"
Cause:
The schema component constraint, Derivation Valid (Restriction, simple), (Restriction, complex) or (Extension), was violated.
Action:
Modify the base type or the derived type definition.
LSX-00175: a complex base within "simpleContent" must have simple content
Cause:
A complex base within "simpleContent" was not restricted to contain only simple content.
Action:
LSX-00176: circular reference detected in schema component named "~S"
Cause:
An attempt was made to use a circular reference. This is not allowed. For example, it is not possible to return to an element declaration by repeatedly following the {substitution group affiliation} property. Or, within the {particles} of a group there must not be at any depth a particle whose {term} is the group itself.
Action:
Modify one of the schema components in the loop.
LSX-00200: element "~S" not empty
Cause:
Content of the element must be empty.
Action:
Remove any schema components in the content.
LSX-00201: contents of "~S" should be elements only
Cause:
Node with type other than "element", "processing instruction", or "comment" exists in the content of the violating element.
Action:
Remove the offending nodes.
LSX-00202: contents of "~S" should be text only
Cause:
Node with type other than "text", "processing instruction", or "comment" exists in the content of the violating element.
Action:
LSX-00204: extra data at end of complex element
Cause:
Extra nodes exist at the end of an element with a complex type definition.
Action:
Remove the offending nodes or check the definition of the complex type.
LSX-00205: element "~1S" value "~2S" is wrong (must be "~3S")
Cause:
The element had a value other than its fixed value.
Action:
Use the fixed value as its value.
LSX-00206: substitution for element "~S" is disallowed
Cause:
An attempt was made to substitute an element that violated a constraint.
Action:
Change to a valid new element that can be substituted for the headElement.
LSX-00207: empty list is disallowed
Cause:
An empty list was supplied where at least one value is required.
Action:
Specify at least one valid list item.
LSX-00208: circular type reference disallowed
Cause:
A type referenced itself as a member type, either directly or indirectly using other types.
Action:
Remove the circular type dependency.
LSX-00209: fixed or default not allowed on ID-based type
Cause:
A type derived from the ID type specified a fixed value or a default value.
Action:
Remove the fixed or default value from the type.
LSX-00210: value "~1S" out of range for type "~2S"
Cause:
Value is out of range for the data with a specific type.
Action:
Fix the value.
LSX-00211: value "~1S" whose fractional digits exceeds ~2d
Cause:
Too many fractional digits after the decimal point.
Action:
Remove the extra fractional digits.
LSX-00212: value "~1s" whose total digits exceeds ~2d
Cause:
Too many digits in the decimal data.
Action:
Remove the extra digits.
LSX-00213: only ~1d occurrences of particle "~2S", minimum is ~3d
Cause:
Too few occurrences of particles in the node.
Action:
Specify more particles.
LSX-00214: too many occurrences of particle "~1S", maximum is ~2d
Cause:
Too many occurrences of particles in the node.
Action:
Remove extra ones.
LSX-00215: value "~1S" whose total digits exceeds ~2d
Cause:
There were too many digits in the decimal data.
Action:
LSX-00220: "~1S" is wrong length, should be ~2d
Cause:
Data of simple type has invalid length.
Action:
Fix the length of the data.
LSX-00221: "~1S" is too short (minimum length is ~2d)
Cause:
The length of the data is too short.
Action:
Prepend extra characters (such as zeros or blank characters) to make the data longer.
LSX-00222: "~1S" is too long (maximum length is ~2d)
Cause:
The length of the data is too long.
Action:
Remove extra characters from the data.
LSX-00229: item type is not a valid type for a list simple type
Cause:
The specified item type must not itself be a list type, and must be one of the types identified in [XML Schemas: Datatypes] as a suitable item type for a list simple type.
Action:
Change the list schema component's declaration.
LSX-00230: invalid integer "~S"
Cause:
Illegal characters exist in the "integer" or its derivative type declarations.
Action:
LSX-00231: invalid unsigned integer "~S"
Cause:
Illegal characters exist in the "unsignedLong", "unsignedInt", "unsignedShort", or "unsignedByte" declarations.
Action:
LSX-00232: invalid unsigned long "~S"
Cause:
Illegal characters exist in the "unsignedLong" declaration.
Action:
LSX-00233: invalid long "~S"
Cause:
Illegal characters exist in the "long" declaration.
Action:
LSX-00234: invalid decimal "~S"
Cause:
Illegal characters exist in the "decimal" declaration.
Action:
LSX-00235: invalid URI "~S"
Cause:
Invalid URI specification for data of "anyURI" type.
Action:
LSX-00237: invalid Name "~S"
Cause:
Invalid XML name.
Action:
LSX-00238: invalid Nmtoken "~S"
Cause:
Invalid Nmtoken.
Action:
LSX-00240: bad float "~S"
Cause:
Invalid value for "float" type data.
Action:
LSX-00241: bad double "~S"
Cause:
Invalid value for "double" type data.
Action:
LSX-00242: bad Boolean "~S"
Cause:
Boolean data must have a value from the following set: "1", "0", "true", or "false".
Action:
Specify one of "1", "0", "true", or "false".
LSX-00243: invalid date "~S"
Cause:
Invalid value for data of "date" type.
Action:
LSX-00244: invalid NCName "~S"
Cause:
Invalid value for data of "NCName" type.
Action:
LSX-00245: invalid ID "~S"
Cause:
Data specified is not of "NCName" type.
Action:
LSX-00246: invalid QName "~S"
Cause:
Invalid value for data of "QName" type.
Action:
LSX-00247: invalid language specification "~S"
Cause:
Invalid value for data of "language" type.
Action:
LSX-00248: invalid duration "~S"
Cause:
Invalid value for data of "duration" type.
Action:
LSX-00249: invalid date or time "~S"
Cause:
Invalid value for data of "dateTime", "time", "gYearMonth", "gYear", "gMonthDay", "gDay", or "gMonth" type.
Action:
LSX-00250: invalid normalizedString "~S"
Cause:
Invalid value for data of "normalizedString" type.
Action:
LSX-00251: invalid token "~S"
Cause:
Invalid value for data of "token" type.
Action:
LSX-00252: invalid union "~S"
Cause:
Data of simple type is not one of the union type.
Action:
Use one of the union type as its type.
LSX-00253: branch is empty
Cause:
The pattern specification "branch1 | branch2" has either "branch1" or "branch2" missing.
Action:
Remove '|' or add either "branch1" or "branch2".
LSX-00255: mismatched parentheses
Cause:
")" found without a matching "(" in a pattern specification.
Action:
Add "(" to the pattern specification.
LSX-00256: empty character class expression
Cause:
"[]" found when processing a character class expression.
Action:
Specify the character group within the brackets.
LSX-00257: atom specification is missing
Cause:
A quantifier was found without an atom specification.
Action:
Add an atom specification in front of the quantifier.
LSX-00258: invalid escape character
Cause:
"x" in "\x" is not a valid escape character.
Action:
Change "x" to a valid escape character.
LSX-00259: invalid character found in the pattern
Cause:
An unexpected character was found in the pattern.
Action:
Fix the pattern.
LSX-00260: unexpected end of pattern
Cause:
Something is missing at the end of the pattern.
Action:
Fix the pattern.
LSX-00261: invalid character property
Cause:
An error occurred when processing the character property. For example, "{" is missing after "\p" or "\P".
Action:
Fix the character property.
LSX-00262: attribute "~1S" cannot have complex type "~2S"
Cause:
The type of the attribute is "complex".
Action:
Specify the type of the attribute to be "simple".
LSX-00263: undefined attribute "~S"
Cause:
Violating attribute is not defined in the current scope.
Action:
Correct the attribute name if it's misspelled.
LSX-00264: attribute "~S" is prohibited (may not occur)
Cause:
Global declarations cannot contain the attributes "ref", "minOccurs", or "maxOccurs", or the use of this attribute is explicitly declared as "prohibited" by the schema.
Action:
Remove the attribute.
LSX-00265: attribute "~1S" value "~2S" is wrong (must be "~3S")
Cause:
Attribute has a value other than its fixed value.
Action:
Use fixed value as its value.
LSX-00266: missing required attribute "~S"
Cause:
A required attribute is missing.
Action:
Add the required attribute.
LSX-00270: hex-encoded binary has odd length
Cause:
Data of "hexBinary" type has odd number of digits.
Action:
Add missing digits as appropriate.
LSX-00271: invalid character "~c" in hex-encoded binary
Cause:
Data of "hexBinary" type has invalid characters.
Action:
LSX-00272: BASE64-encoded binary grouped improperly (not 4's)
Cause:
Number of digits is not a multiple of four.
Action:
LSX-00273: invalid character "~c" in base64-encoded binary
Cause:
Data of "base64Binary" type has invalid characters.
Action:
LSX-00274: invalid padding in base64-encoded binary
Cause:
Invalid padding characters at the end of data.
Action:
Use "=" as the padding characters.
LSX-00280: duplicate ID "~S"
Cause:
ID name is not unique within the schema scope.
Action:
Rename the ID.
LSX-00281: referenced ID "~S" is not defined
Cause:
Referenced ID name is not defined within the schema scope.
Action:
Define the ID.
LSX-00282: duplicate notation name "~S"
Cause:
The name of the "notation" element is not unique within the schema scope.
Action:
Rename the element.
LSX-00283: referenced notation "~S" is not defined
Cause:
Referenced notation name is not defined within the schema scope.
Action:
Define the element.
LSX-00284: duplicate constraint name "~S"
Cause:
Each constraint declaration has a name which exists in a single symbol space for constraints.
Action:
Choose a different name.
LSX-00285: referenced key "~S" is not defined
Cause:
Referenced key name is not defined within the schema scope.
Action:
Define the key.
LSX-00286: duplicate key "~S" for {"~S"}"~S"
Cause:
The key value was not unique within its scope.
Action:
Change the key value.
LSX-00287: duplicate key "~S"
Cause:
Action:
LSX-00290: invalid enumeration choice "~S"
Cause:
The value of the data is not one of the enumeration choice.
Action:
Select one of the enumeration choice as its value.
LSX-00291: value "~1S" is less than minimum "~2S" (~3S)
Cause:
Data has a value less than required minimum.
Action:
Increase the value.
LSX-00292: value "~1S" is greater than maximum "~2S" (~3S)
Cause:
Data has a value greater than maximum.
Action:
Decrease the value.
LSX-00293: missing one or more fields from element "~S"
Cause:
The required fields were missing from the content of the element.
Action:
Add the fields.
LSX-00294: field "~S" produced multiple hits
Cause:
XPath expressions relative to each element selected by a {selector}are specified by {fields}. These XPath expressions must identify a single node (element or attribute) whose content or value was used in the constraint. This content or value must be of a simple type.
Action:
Remove duplicate elements or attributes.
LSX-00295: field element "~S" is not a simple type
Cause:
The field element evaluated to a node-set with a member that was not a simple type.
Action:
Change the field element's type.
LSX-00296: field value "~S" could not be compared to facet
Cause:
The value of the data could not be compared to the facet value because one value had a time zone while the other did not.
Action:
Correct the data to add the necessary time zone or to remove the unnecessary time zone.
LSX-00300: group must have name or ref but not both
Cause:
"ref" or "name" attributes are either both missing or have both been specified.
Action:
Specify either "ref", "name", but not both.
LSX-00310: local element or attribute should be namespace qualified
Cause:
Element or attribute name is not namespace qualified.
Action:
Add prefix or default namespace URI declaration.
LSX-00311: local element or attribute shouldn't be namespace qualified
Cause:
Element or attribute name is namespace qualified.
Action:
Remove prefix or default namespace URI declaration from itself or ancestors.
LSX-00320: missing required elements in all
Cause:
Some required elements in "all" particle are missing.
Action:
Add the missing elements.
LSX-00330: missing range start character
Cause:
Missing range start character in a character range specification.
Action:
Add the missing characters.
LSX-00331: missing comma
Cause:
A comma is missing in a range specification.
Action:
LSX-00332: bad decimal digits in a quantifier specification
Cause:
Quatifier has invalid characters.
Action:
LSX-00333: literal "~S" is not valid with respect to the pattern
Cause:
Literal is not valid with respect to the pattern.
Action:
Choose correct characters in the literal.
LSX-00340: improper namespace value for the imported element
Cause:
If the namespace attribute is present, then its actual value must not match the actual value of the enclosing schema's targetNamespace attribute. If the namespace attribute is not present, then the enclosing schema must have a targetNamespace attribute.
Action:
Match namespace value.
LSX-00341: ENTITY or ENTITIES type may only be used in attributes
Cause:
For compatibility, ENTITY or ENTITIES should be used only on attributes.
Action:
Remove the ENTITY or ENTITIES.
LSX-00342: value of attribute "base" must be a complex type definition
Cause:
If the "complexContent" alternative is chosen, then the type definition resolved to by the actual value of the attribute "base" must be a complex type definition.
Action:
Choose a complex type definition as its base type.
LSX-00343: "~S" is not nillable
Cause:
Attribute nillable was set to be "false" in element's declaration.
Action:
Remove attribute xsi:nil from the instance document.
LSX-00344: namespace values "~1S" and "~2S" differ
Cause:
The targetNamespace specified in the schema document differed from either: a) the value of the enclosing schema's namespace attribute, or b) the value of the namespace attribute identified in the import element information item.
Action:
Match the namespace value to the enclosing schema's targetNamespace attribute or the actual value of the namespace attribute identified in the import element information item.
LSX-00345: Element ("~1S") from "~2S" namespace is unexpected. Expecting element from "~3S" namespace
Cause:
The namespace of the Xml Node in the instance document does not match with the expected element definition namespace
Action:
n/a
