Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
41 MGTCA-01001 to MGTCA-01117
MGTCA-01001: clusterware stack did not respond
Cause: A wallet operation was requested when the Oracle Clusterware stack was down.
Action: Contact Oracle Support Services.
MGTCA-01002: clusterware stack did not respond to wallet operation
Cause: User attributes could not be read because the Grid Infrastructure Management Repository wallet location was not accessible.
MGTCA-01003: wallet access denied
Cause: An attempt to access the wallet was denied because the user does not have the required permissions.
MGTCA-01004: clusterware wallet internal error
Cause: An invalid wallet operation was performed or Oracle Cluster Registry storage for wallet was not present.
MGTCA-01005: cannot perform database operation while setting Grid Infrastructure Management Repository users
Cause: Failed to connect to Grid Infrastructure Management Repository using JDBC during new user setup.
MGTCA-01006: could not change user credentials for Grid Infrastructure Management Repository
Cause: SQL execute query failed.
MGTCA-01007: Grid Infrastructure Management Repository is not running on this node
Cause: During the execution of 'mgmtca', no running instance of the Grid Infrastructure Management Repository was found on the node.
Action: Run 'mgmtca' on the node having Grid Infrastructure Management Repository.
MGTCA-01008: An internal error occurred while querying for the node running Grid Infrastructure Management Repository
Cause: During the execution of 'mgmtca', an internal error occurred while querying for the node running Grid Infrastructure Management Repository.
MGTCA-01100: This utility is used to configure the Grid Infrastructure Management Repository.\nUsage: mgmtca [[-em passwd] | [-gridhome] | [[setpasswd -user user-1 [passwd-1] [, user-n passwd-n]]]
Cause: None
Action: None
MGTCA-01101: failure in Oracle Grid Infrastructure Management Repository operation
Cause: A SQL request to the Oracle Grid Infrastructure Management Repository encountered an error.
MGTCA-01102: failure in performing database operation to retrieve the name of the Pluggable Database in the Oracle Grid Infrastructure Management Repository
Cause: An attempt to retrieve the name of the Pluggable Database in Oracle Grid Infrastructure Management Repository failed.
MGTCA-01103: failure in performing database operation to unlock the user of Oracle Grid Infrastructue Management Database
Cause: The user account to be unlocked did not exist.
MGTCA-01104: An internal error occurred during the remote execution of 'mgmtca' on the node running the Grid Infrastructure Management Repository.
Cause: During the execution of 'mgmtca', an internal error occurred while remotely executing the operation of the node running the Grid Infrastructure Management Repository.
MGTCA-01105: Grid Infrastructure Management Repository is not running in the cluster.
Cause: The execution of 'mgmtca' could not complete because the Grid Infrastructure Management Repository was not running in the cluster.
MGTCA-01106: An internal error occurred while querying the state of the Grid Infrastructure Management Repository.
Cause: During the execution of 'mgmtca', an internal error occurred while querying the state of the Grid Infrastructure Management Repository.
MGTCA-01107: The resource for the Grid Infrastructure Management Repository does not exist.
Cause: The execution of 'mgmtca' could not complete because the resource for the Grid Infrastructure Management Repository did not exist.
MGTCA-01108: failed to determine CRS Home location
Cause: Execution of 'mgmtca' to retrieve the CRS Home location failed. This is an internal error.
MGTCA-01109: failed to determine Oracle Base location
Cause: Execution of 'mgmtca' to retrieve the Oracle Base location failed. This is an internal error.
MGTCA-01110: An internal error occurred while querying the state of the Grid Infrastructure Management Repository during reconfiguration.
Cause: The execution of 'mgmtca' could not complete because an internal error occurred while querying the state of the Grid Infrastructure Management Repository during reconfiguration.
MGTCA-01111: An internal error occurred while stopping the existing instance of the Grid Infrastructure Management Repository during reconfiguration.
Cause: The execution of 'mgmtca' could not complete because an internal error occurred while stopping the existing instance of the Grid Infrastructure Management Repository during reconfiguration.
MGTCA-01112: An internal error occurred while removing the existing instance of the Grid Infrastructure Management Repository during reconfiguration.
Cause: The execution of 'mgmtca' could not complete because an internal error occurred while removing the existing instance of the Grid Infrastructure Management Repository during reconfiguration.
MGTCA-01113: The reconfigure operation for the Grid Infrastructure Management Repository could not complete because there was already an instance running on the cluster.
Cause: The reconfigure operation for the Grid Infrastructure Management Repository could not complete because there was already an instance running on the cluster.
MGTCA-01114: An internal error occurred while creating the Grid Infrastructure Management Repository during reconfiguration.
Cause: The execution of 'mgmtca' could not complete because an internal error occurred while creating the Grid Infrastructure Management Repository during reconfiguration.
MGTCA-01115: An internal error occurred while starting the resource for the Grid Infrastructure Management Repository during reconfiguration.
Cause: The execution of 'mgmtca' could not complete because an internal error occurred while starting the resource for the Grid Infrastructure Management Repository during reconfiguration.
MGTCA-01116: The syntax of the 'mgmtca' command is incorrect.
Cause: The 'mgmtca' command was rejected because the syntax as entered was incorrect.
Action: Reenter the 'mgmtca' command with the correct syntax. Enter 'mgmtca -h' to display usage.
MGTCA-01117: The username specififed in the 'mgmtca' command is incorrect.
Action: Provide correct username for the 'mgmtca' command.
