NCR-00001: NCR: Could not allocate memory
Cause:
Insufficient swap space or system memory.
Action:
Increase swap space or system memory.
NCR-00002: NCR: Invalid usage
Cause:
Bad function parameter.
Action:
Check function call.
NCR-00003: NCR: Initialization failure
Cause:
Usually insufficient swap space or system memory.
Action:
NCR-01003: NCRS: Read error.
Cause:
Failed to read data from an input device.
Action:
Check the input device driver return code for further information.
NCR-01004: NCRS: Write error.
Cause:
Failed to write data to an output device.
Action:
Check the output device driver return code for further information.
NCR-01005: NCRS: Failed to flush the output buffer.
Cause:
Failed to write data in the output buffer to an output device.
Action:
NCR-01006: NCRS: Data buffer overflow.
Cause:
An attempt to read or write data outside of a given data buffer.
Action:
Check data buffer size.
NCR-01007: NCRS: Operation is not supported in a given mode.
Cause:
Attempt to perform an operation which is not supported for the current mode.
Action:
See documentation for a list of work modes and supported operations.
NCR-01008: NCRS: Failed to obtain transport parameters.
Cause:
Could not identify transport layer parameters.
Action:
Check the transport layer return code for further information.
NCR-01009: NCRS: Record handling error.
Cause:
Encountered an invalid record or an attempt to read beyond last record.
Action:
See documentation for description of record handling methods.
NCR-01010: NCRS: Invalid network address length.
Cause:
Network address size is set to 0.
Action:
See documentation for valid network address sizes.
NCR-01011: NCRS: Send message failure.
Cause:
Failed to send a message over network.
Action:
Check the network interface return code for further information.
NCR-01012: NCRS: Receive message failure.
Cause:
Failed to receive a network message.
Action:
NCR-01013: NCRS: Unvalid connection type.
Cause:
Connection type is other than stream or message.
Action:
See documentation for description of connection types.
NCR-01018: NCRS: Encryption failure.
Cause:
Can not do the encryption for the data.
Action:
See the SNS documentation for more information.
NCR-01019: NCRS: Checksumming failure.
Cause:
Can not add the checksumming for the data.
Action:
NCR-01020: NCRS: Operation would block.
Cause:
An I/O operation returned with no data read/written because the transport connection is "non-blocking" and, to succeed, the operation would have needed to block.
Action:
This is a soft error; retry the operation.
NCR-02003: NCRF: Invalid type passed to format interpreter.
Cause:
The format interpreter was given a data type it did not recognize.
Action:
Check the types returned to the interpreter from either the type callback routine or from the type context structure.
NCR-02004: NCRF: Invalid format interpreter type context
Cause:
The format interpreter was given an invalid type context.
Action:
This error usually happens due to an improperly described aggregrate. For example, declaring NCRF_END_STRUCT_DATA_TYPE within a context, without a complementary NCRF_STRUCT_DATA_TYPE, is invalid.
NCR-02005: NCRF: Invalid session mode
Cause:
The data format layer received a session mode other than GET,PUT or FREE.
Action:
None
NCR-02006: NCRF: Invalid floating point representation received
Cause:
The data format layer received a floating point representation it did not recognize.
Action:
Check incoming format descriptor for errors.
NCR-02007: NCRF: Invalid format descriptor received
Cause:
The data format layer received an improperly formed format descriptor. Subsequent data could not be formatted.
Action:
Check for data integrity on receipt from remote host.
NCR-02008: NCRF: Error within stream processing in format interpreter
Cause:
An error occured while the interpreter was processing an NCRF_STREAM_DATA_TYPE.
Action:
Check for data integrity, or for stream existence.
NCR-02009: NCRF: Unable to open trace file
Cause:
Failure to open tracing file.
Action:
Make sure that this is a legal file name and that the user has write access.
NCR-02010: NCRF: Call context is not available
Cause:
Call context not passed to format context.
Action:
Make sure that create call context has been called.
NCR-02011: NCRF: Exceeded maximum number of rfids.
Cause:
Action:
Call Oracle Support.
NCR-03002: NCRO: Maximum number of contexts has been reached
Cause:
An attempt to create either a call context or a service context has failed because all context slots are in use.
Action:
Free-up context slots by destroying those contexts no longer required, or, reconfigure NCRO with more context slots.
NCR-03003: NCRO: Unexpected message
Cause:
Message read from service connection is not of the expected type.
Action:
Application error - debug and fix.
NCR-03004: NCRO: Unknown message
Cause:
Message read from service connection is of unknown type.
Action:
Internal error - contact customer support.
NCR-03005: NCRO: Orphan message
Cause:
Message read from service connection is for a call context that no longer exists.
Action:
NCR-03006: NCRO: Invalid operation
Cause:
Attempted operation over call context is invalid. For example, attempting to send IN args for a procedure which is defined to have none.
Action:
NCR-03007: NCRO: Context is busy
Cause:
Attempted operation failed because service/call context is busy performing a previous operaion.
Action:
NCR-03008: NCRO: Call rejected
Cause:
An attempt to execute a remote procedure has failed because the server has rejected the procedure id.
Action:
If wrong procedure id, send the correct one. If wrong server was contacted, then contact the right one.
NCR-03009: NCRO: Protocol version mismatch
Cause:
Client and server NCRO layers are at incompatible versions levels.
Action:
Upgrade to latest NCRO version.
NCR-03010: NCRO: Transfer callback error
Cause:
Application transfer callback function has returned a "FAILED" status.
Action:
Debug the transfer callback function.
NCR-03012: NCRO: Invalid session mode
Cause:
Attempted operation has failed because the session context is in an invalid state.
Action:
NCR-03013: NCRO: Operation not supportd
Cause:
Attempted operation is not supported on this service connection because it is incompatible with the NCRO version level of the remote application.
Action:
Link remote application with latest NCR library.
NCR-03014: NCRO: Bad transport address
Cause:
A service context cannot be created because the transport address descriptor (contained in the binding context) is invalid.
Action:
Application error - initialize the transport address descriptor correctly.
NCR-03015: NCRO: No transport address
Cause:
A service context cannot be created because no transport address was provided (in the binding context) and the transport protocol uses datagrams.
Action:
Application error - provide a transport address.
NCR-03016: NCRO: Message has bad address
Cause:
Message read from service connection has bad address information.
Action:
NCR-03017: NCRO: Transport type RSLV not supported
Cause:
Support for transport type RSLV has not been built.
Action:
Re-compile NCR library with NCR_USE_RSLV defined.
NCR-03018: NCRO: Failed to make RSLV connection
Cause:
Failure to make RSLV connection usually means that the name resolution failed or the resolved TNS address is bad.
Action:
Make sure that the name is in TNSNAMES.ORA and that it is set to the correct TNS address.
NCR-03019: NCRO: Unable to initialize thread support
Cause:
Attempt to initialize the Core thread package has failed.
Action:
NCR-03020: NCRO: Invalid call context
Cause:
The call context is not an valid call context.
Action:
Call context was destroyed, probably because the Break was received
NCR-03021: NCRO: Reset the in-band line
Cause:
Our parnter is asking to reset the in-band line, after receiving a break
Action:
The in-band line is required to be reset
NCR-03022: NCRO: Cannot send the break
Cause:
There is an error occur when sending the break using the side-band channel
Action:
Read the documention regarding to side-band break support issues
NCR-03023: NCRO: Cannot receive the break
Cause:
There is an error occur when receiving the break using the side-band channel
Action:
NCR-03024: NCRO: Transport type LIST not supported
Cause:
Support for transport type LIST has not been built.
Action:
Re-compile NCR library with NCR_USE_LIST defined.
NCR-03025: NCRO: Failed to make LIST connection(s)
Cause:
Failure to make LIST connection(s) usually means one of two things: (1) Address list syntax error, (2) Could not connect with supplied addresses
Action:
Check address list syntax and make sure that there is a 'listener' process for each (or some) of the supplied addresses.
NCR-03026: NCRO: The result buffer has overflowed
Cause:
The result buffer for holding the pickling result is too small.
Action:
Please enlarge the result buffer and try again.
NCR-03027: NCRO: No remote service session set up yet.
Cause:
Sender-makes-right needs the remote FID.
Action:
Please set up the remote session before using the Send Make's Right option.
NCR-03028: NCRO: Partner refused request for sender-makes-right.
Cause:
Sender-makes-right was requested by the current side, yet refused by the server.
Action:
Check the server side to see why it refused SMR.
NCR-04002: NCRR: Invalid interface descriptor
Cause:
An attempt to register an interface has failed because of an invalid interface descriptor.
Action:
Check interface descriptor passed into the ncrrri_register_interface call.
NCR-04003: NCRR: Interface exists
Cause:
An attempt to register an interface has failed because an interface already exists.
Action:
Application error - register a new interface, destroy the old one, or indicate that the old one must be replaced.
NCR-04004: NCRR: Invalid interface instance handle
Cause:
A service registration API call has failed because of an invalid instance handle.
Action:
NCR-04005: NCRR: Invalid procedure handle
Cause:
A procedure/object registration has failed because of an invalid procedural handle.
Action:
NCR-04006: NCRR: Invalid argument descriptor
Cause:
A procedure registration has failed because of an invalid argument descriptor.
Action:
NCR-04007: NCRR: Invalid object handle
Cause:
A service registration API call failed because of an invalid object handle, for example, one that does not exist.
Action:
NCR-04008: NCRR: Procedure exists
Cause:
An attempt to register a remote procedure has failed because the procedure already exists in this interface.
Action:
Application error - register a new procedure, destroy the old one, or indicate that the old one must be replaced.
NCR-04009: NCRR: Object exists
Cause:
An attempt to register an object has failed because the object already exists in this interface.
Action:
Application error - register a new object, destroy the old one, or indicate that the old one must be replaced.
NCR-04010: NCRR: Unable to contact Oracle Internet Directory Server
Cause:
Service export or import failed to contact Oracle Internet Directory Server.
Action:
Ensure Oracle Internet Directory configuration is correct. Otherwise, turn on tracing and/or contact customer support.
NCR-04011: NCRR: Oracle Internet Directory error
Cause:
Service export or import failed during interaction with Oracle Internet Directory Server.
Action:
Either wrong parameters with respect to the Remote Operations Service Registration Schema were passed in and/or the Oracle Internet Directory server refused to perform the requested operation. Refer the Remote Operations Service Registration Schema and/or turn on Oracle Internet Directory tracing and/or contact customer support.
NCR-04012: NCRR: Invalid address descriptor
Cause:
An ncrrei_export_interface call failed because of an invalid address descriptor.
Action:
NCR-04013: NCRR: Insufficient authorization
Cause:
Attempted Oracle Internet Directory Server operation has failed because of insufficient authorization.
Action:
Contact customer support.
NCR-04014: NCRR: Invalid instance name
Cause:
Service export or import failed because of an invalid instance name
Action:
NCR-04015: NCRR: Invalid interface name
Cause:
Service export or import failed because of an invalid interface name
Action:
NCR-04016: NCRR: Last interface instance handle
Cause:
The instance handle passed in is the last instance handle in the list.
Action:
Not an error - means reaching the end of the list.
NCR-04017: NCRR: Unable to find the interface instance handle
Cause:
The instance handle corresponding to the instance name was not found.
Action:
NCR-04018: NCRR: Unable to create the TNS address list
Cause:
Unable to create the TNS address list from the interface instance list.
Action:
NCR-04019: NCRR: Interface or instance name already exists
Cause:
Service export failed because the name already exists with the Oracle Internet Directory server
Action:
NCR-04020: NCRR: Interface or instance name does not exist
Cause:
Service expunge/query failed because the name does not exist with the Oracle Internet Directory server
Action:
Use Oracle Internet Directory tools on the relevant Oracle Internet Directory instance to verify the same. Otherwise turn on tracing and/or contact customer support
NCR-04021: NCRR: Pickler errors
Cause:
Service export/query failed because of pickler errors
Action:
NCR-04022: NCRR: Invalid procedure descriptor
Cause:
A procedure registration has failed because of an invalid procedural descriptor.
Action:
NCR-04023: NCRR: Invalid object descriptor
Cause:
An object registration has failed because of an invalid object descriptor.
Action:
NCR-04024: NCRR: Maximum number of procedures reached
Cause:
A procedure registration has failed because the procedures array is filled up.
Action:
Re-register the interface increasing the maximum # of procedures.
NCR-04025: NCRR: Operation timed out
Cause:
An operation for the Oracle Internet Directory server failed because it exceeded the timeout period.
Action:
Retry the operation and/or turn on Oracle Internet Directory tracing.
NCR-04026: NCRR: Operation not supported
Cause:
An operation for the Oracle Internet Directory server failed because it met with a server referral to another instance.
Action:
Unify the Remote Ops registration entries into the Oracle Internet Directory instance and/or turn on Oracle Internet Directory tracing.
NCR-04027: NCRR: Operation failed
Cause:
An operation for the Oracle Internet Directory server failed because the Service Registration interfaces met with invalid parameters.
Action:
NCR-04028: NCRR: Operation failed
Cause:
An operation for the Oracle Internet Directory server failed because the data involved exceeds the maximum allowed size.
Action:
Check the entries in the Oracle Internet Directory instance with tools available from Oracle Internet Directory and/or turn on Oracle Internet Directory tracing.
