NID-00001: Illegal command line syntax - parse error = (number)
Cause:
Illegal operand on command line.
Action:
Remove illegal operand.
NID-00002: Parse error: string
Cause:
An error was encountered while parsing the command line.
Action:
Remove offending operand.
NID-00010: Password:
Cause:
Password was not specified in command line.
Action:
Type password at this prompt.
NID-00100: Cannot open datafile "string"
Cause:
The specified datafile could not be opened.
Action:
Ensure that the specified datafile exists and is writable.
NID-00101: LOGFILE (string) not accessible
Cause:
The specified log file could not be opened.
Action:
Specify a log file that is writable.
NID-00102: Garbled target string
Cause:
The supplied connect string could not be parsed. The connect string does not have the correct format.
Action:
Refer to Oracle9i Database Concepts.
NID-00103: Missing password in connect string "string"
Cause:
Could not find the password in the supplied connect string. The connect string does not have the correct format.
Action:
NID-00104: Need to specify TARGET connection parameter in command line
Cause:
The mandatory parameter TARGET was not specified.
Action:
Specify TARGET=username/password when invoking this utility.
NID-00105: Need to specify "LOGFILE=logfile" when using APPEND=YES option
Cause:
The APPEND parameter was specified without a LOGFILE.
Action:
Specify APPEND=YES only when LOGFILE is also specified.
NID-00106: LOGIN to target database failed with Oracle error:\nstring
Cause:
An Oracle error was reported while attempting to log in to the target database.
Action:
Follow the actions for the specified Oracle error.
NID-00107: File I/O error on datafile "string" during string operation (number/string)
Cause:
An operating system error was reported while performing the specified operation in the specified file.
Action:
Verify the datafile and check for operating system errors.
NID-00109: DBNAME string length number exceeds maximum length of number
Cause:
The specified new database name exceeded the maximum size.
Action:
Specify a shorter, valid name.
NID-00110: Cannot use REVERT and specify a database name at the same time
Cause:
Conflicting options were specified in the command line.
Action:
Choose only one of the options.
NID-00111: Oracle error reported from target database while executing\nstring\nstring
Cause:
An Oracle error was reported when executing an OCI operation.
Action:
NID-00112: unsupported connection mode
Cause:
A mode different than SYSDBA or SYSBACKUP was specified for the connection to the target.
Action:
Specify only AS SYSDBA or AS SYSBACKUP.
NID-00113: Error reading answer - aborting
Cause:
Response caused an error.
Action:
Retry the operation.
NID-00114: Must specify new database name when SETNAME is used
Cause:
SETNAME=YES was specified but no DBNAME was provided.
Action:
Specify DBNAME or remove the SETNAME=YES option.
NID-00115: Database should be mounted
Cause:
The database was not mounted.
Action:
Mount the database.
NID-00120: Database should be mounted exclusively
Cause:
The database was started in parallel mode. To change the DBID, the database must be mounted exclusively.
Action:
Shut down the database and start it in exclusive mode.
NID-00121: Database should not be open
Cause:
The database was open. To change the DBID, the database must be mounted exclusively.
Action:
Shutdown the database and mount it in exclusive mode.
NID-00122: Database should have no offline immediate datafiles
Cause:
The database has one or more datafiles that are in OFFLINE IMMEDIATE mode.
Action:
Drop the datafiles or recover them and bring them online.
NID-00123: Magic number for datafile "string" is incorrect
Cause:
Block 0 header has an incorrect magic number for the specified datafile.
Action:
Verify that the datafile is correct and retry the operation.
NID-00124: Mismatched dbid for datafile string, expected number, found number
Cause:
The dbid of the datafile does not match the 'old' DBID or the 'new' DBID.
Action:
Verify that this datafile belongs to the database. You may need to restore a backup of the datafile.
NID-00125: Database should have no disabled datafiles
Cause:
The database has one or more datafiles that are disabled.
Action:
NID-00126: Database should have no datafiles in unknown state
Cause:
The database has one or more datafiles that are in an unknown state.
Action:
NID-00127: All online files in the database must have the same checkpoint SCN
Cause:
The database has one or more datafiles that have a checkpoint SCN that does not match the database checkpoint SCN.
Action:
Restart the database and shut it down cleanly, then retry the operation.
NID-00128: Cannot revert change of database, change not in progress
Cause:
The REVERT option was used, but the control file does not show that a change of DBID was in progress.
Action:
Do not use the REVERT option, or possibly restore the control file that was in place when the utility was started.
NID-00129: Invalid DBID for datafile "string", expecting number, found number
Cause:
A datafile header shows a different DBID from the rest of the database files.
Action:
Ensure that the file belongs to this database.
NID-00130: Mismatched CHECKPOINT_CHANGE# in datafile "string", expecting string, found string
Cause:
The datafile header does not match information in the control file.
Action:
Revert the change, open the database, and verify that all datafiles are consistent. Then, shut down the database and retry the operation.
NID-00131: Control file is not current
Cause:
A non-current control file is currently mounted.
Action:
Perform necessary actions to make the control file current and retry.
NID-00132: CHECKPOINT_CHANGE# in datafile "string": string in the future of controlfile: string
Cause:
The checkpoint in the datafile header is ahead of the checkpoint in the control file.
Action:
Make the database consistent and retry.
NID-00133: Database should have only consistent datafiles
Cause:
The database has one or more datafiles that are marked FUZZY in the control file.
Action:
Restart the database and shut down consistently, then retry the operation.
NID-00134: Datafile "string" is not consistent
Cause:
The datafile is marked as fuzzy in its header.
Action:
Restart the database and shut down cleanly, then retry the operation.
NID-00135: There are number active threads
Cause:
There are active threads in the database. The most likely cause is that the database crashed the last time it was shut down.
Action:
Ensure that all threads are closed before retrying the operation. Start and open the database to perform crash recovery, then shut down with the NORMAL or IMMEDIATE options to close it cleanly. Finally, try running the utility again.
NID-00137: All datafiles that are not dropped should be readable
Cause:
The database had one or more files that could not be read.
Action:
Restore the missing files and retry the operation.
NID-00138: Block verification failed for datafile string (number)
Cause:
Block header checksum yields a nonzero value for the specified datafile.
Action:
NID-00139: Mismatched dbname for datafile string, expected string, found string
Cause:
The dbname of the datafile does not match the 'old' dbname or the 'new' dbname.
Action:
NID-00140: Specified database name string does not match previous name used string
Cause:
This is a continuation of a failed attempt. However in the failed attempt, the database name is different than the one used in the last attempt.
Action:
Retry the command using the original database name.
NID-00141: No database name specified, previous attempt used string
Cause:
This is a continuation of a failed attempt. However, in the failed attempt, a database name was provided.
Action:
NID-00142: Only changing database name, previous attempt changed dbid to number
Cause:
This is a continuation of a failed attempt. However, in the failed attempt, the database id was also being changed.
Action:
Retry the command removing SETNAME=YES.
NID-00143: Mismatched controlfile string
Cause:
A controlfile did not have the correct status.
Action:
Shutdown the database, remove the mismatched controlfile, mount the database, and retry the operation.
NID-00144: New name for database string is the same as current name string
Cause:
The specified name is the same as the current name of the database.
Action:
Specify a different name or do not use the DBNAME option.
NID-00145: nls subsystem initialization failure for product=string, facility=string
Cause:
The NLS product/facility error message file could not be located or properly initialized.
Action:
Check that the error message directory and file(s) have been properly installed.
NID-00300: Connected to database string (DBID=number)
Cause:
Informational message.
Action:
No action required.
NID-00301: Datafile string - dbid changed, wrote new name
Cause:
Action:
No action required.
NID-00302: Datafile string - dbid changed
Cause:
Action:
No action required.
NID-00303: Datafile string - wrote new name
Cause:
Action:
No action required.
NID-00304: Datafile string - reverted
Cause:
Action:
No action required.
NID-00305: Datafile string - already changed
Cause:
Action:
No action required.
NID-00306: Datafile string - no revert needed
Cause:
Action:
No action required.
NID-00307: Control File string - dbid changed, wrote new name
Cause:
Action:
No action required.
NID-00308: Control File string - dbid changed
Cause:
Action:
No action required.
NID-00309: Control File string - wrote new name
Cause:
Action:
No action required.
NID-00310: Control File string - reverted
Cause:
Action:
No action required.
NID-00311: Control File string - modified
Cause:
Action:
No action required.
NID-00312: Connected to server version string
Cause:
Action:
No action required.
NID-00315: Operation already in progress, continuing
Cause:
Action:
No action required.
NID-00320: Operation cancelled at user request
Cause:
Action:
No action required.
NID-00321: Proceeding with operation
Cause:
Action:
No action required.
NID-00330: The following datafiles are offline immediate:
Cause:
Action:
No action required.
NID-00331: The following datafiles are disabled:
Cause:
Action:
No action required.
NID-00332: The following datafiles are in unknown state:
Cause:
Action:
No action required.
NID-00333: Cannot read the header of the following datafiles:
Cause:
Action:
No action required.
NID-00334: The following datafiles are not checkpointed to string:
Cause:
Action:
No action required.
NID-00335: The following datafiles are not consistent:
Cause:
Action:
No action required.
NID-00336: The following datafiles are offline clean:
Cause:
Action:
No action required.
NID-00337: The following datafiles are read-only:
Cause:
Action:
No action required.
NID-00338: Control Files in database:
Cause:
Action:
No action required.
NID-00350: string (number) string
Cause:
Action:
No action required.
NID-00351: string (number)
Cause:
Action:
No action required.
NID-00352: string (number), error: number
Cause:
Action:
No action required.
NID-00353: string
Cause:
Action:
No action required.
NID-00354: Instance shut down
Cause:
Action:
No action required.
NID-00370: Change database ID of database string? (Y/[N]) =>
Cause:
Action:
No action required.
NID-00371: Change database name of database string to string? (Y/[N]) =>
Cause:
Action:
No action required.
NID-00372: Change database ID and database name string to string? (Y/[N]) =>
Cause:
Action:
No action required.
NID-00373: Revert changes for database string (Y/[N]) =>
Cause:
Action:
No action required.
NID-00390: These files must be writable by this utility.
Cause:
Action:
No action required.
NID-00395: Reverting database name from string to string
Cause:
Action:
No action required.
NID-00396: Reverting database ID from number to number
Cause:
Action:
No action required.
NID-00397: Changing database name from string to string
Cause:
Action:
No action required.
NID-00398: Changing database ID from number to number
Cause:
Action:
No action required.
NID-00400: DBNEWID - Completed with errors.
Cause:
Action:
No action required.
NID-00401: Must finish REVERT changes before attempting any database operation.
Cause:
Action:
No action required.
NID-00402: Must finish change or REVERT changes before attempting any database operation.
Cause:
Action:
No action required.
NID-00403: DBNEWID - Completed with validation errors.
Cause:
Action:
No action required.
NID-00404: DBNEWID - Completed succesfully.
Cause:
Action:
No action required.
NID-00405: Reversion of database name and database ID failed.
Cause:
Action:
No action required.
NID-00406: Reversion of database name failed.
Cause:
Action:
No action required.
NID-00407: Reversion of database ID failed.
Cause:
Action:
No action required.
NID-00410: Reversion of database changes failed during validation - database is intact.
Cause:
Action:
No action required.
NID-00415: Change of database name and database ID failed.
Cause:
Action:
No action required.
NID-00416: Change of database name failed.
Cause:
Action:
No action required.
NID-00417: Change of database ID failed.
Cause:
Action:
No action required.
NID-00420: Change of database name and ID failed during validation - database is intact.
Cause:
Action:
No action required.
NID-00421: Change of database name failed during validation - database is intact.
Cause:
Action:
No action required.
NID-00422: Change of database ID failed during validation - database is intact.
Cause:
Action:
No action required.
NID-00425: Database name restored to string.
Cause:
Action:
No action required.
NID-00426: Database ID for database string restored to number.
Cause:
Action:
No action required.
NID-00430: Database is ready to be open or shut down.
Cause:
Action:
No action required.
NID-00431: DBNEWID - Reversion completed.
Cause:
Action:
No action required.
NID-00435: Database name changed to string.
Cause:
Action:
No action required.
NID-00436: Modify parameter file and generate a new password file before restarting.
Cause:
Action:
No action required.
NID-00440: Database ID for database string changed to number.
Cause:
Action:
No action required.
NID-00441: All previous backups and archived redo logs for this database are unusable.
Cause:
Action:
No action required.
NID-00442: Database has been shutdown, open database with RESETLOGS option.
Cause:
Action:
No action required.
NID-00450: Succesfully changed database name and ID.
Cause:
Action:
No action required.
NID-00451: Succesfully changed database name.
Cause:
Action:
No action required.
NID-00452: Succesfully changed database ID.
Cause:
Action:
No action required.
NID-00480: Database is intact - database is ready to be open or shut down.
Cause:
Action:
No action required.
NID-00481: DBNEWID - Cancelled.
Cause:
Action:
No action required.
NID-00482: Database is not aware of previous backups and archived logs in Recovery Area.
Cause:
Because the database id was changed, previous backups and archived redo logs in recovery area are not managed by this database.
Action:
This is the informational message only.
NID-00490: LOG being redirected to STDERR due to errors.
Cause:
Could no write message to log file.
Action:
None
NID-00500: Keyword Description (Default)
Cause:
Action:
No action required.
NID-00501: ----------------------------------------------------
Cause:
Action:
No action required.
NID-00502: TARGET Username/Password (NONE)
Cause:
Action:
No action required.
NID-00503: DBNAME New database name (NONE)
Cause:
Action:
No action required.
NID-00504: LOGFILE Output Log (NONE)
Cause:
Action:
No action required.
NID-00505: REVERT Revert failed change NO
Cause:
Action:
No action required.
NID-00506: SETNAME Set a new database name only NO
Cause:
Action:
No action required.
NID-00507: APPEND Append to output log NO
Cause:
Action:
No action required.
NID-00508: HELP Displays these messages NO
Cause:
Action:
No action required.
NID-00600: Internal Error - [number] [number] [number] [number]
Cause:
This is the generic internal error number for program exceptions. This indicates that the program has encountered an exceptional condition.
Action:
Report as a bug - the first argument is the internal error number
NID-00601: Internal Error - [number] [string] [number] [number]
Cause:
Action:
NID-00602: Could not allocate number bytes for "string"
Cause:
Memory allocation failed.
Action:
Free memory at the operating system level and retry operation.
NID-00603: No datafiles found in database
Cause:
Controlfile has not datafiles recorded
Action:
NID-00604: No control files found in database
Cause:
Instance has no control files recorded
Action:
