NDFN-00020: missing IPMI userid
Cause:
Required user name argument was not specified.
Action:
Reissue command with correct arguments.
NDFN-00021: missing node list
Cause:
Required node list was not supplied.
Action:
Re-issue command with correct arguments.
NDFN-00022: unrecognized command option: 'string'
Cause:
Operation type missing or mis-spelled.
Action:
NDFN-00023: no password read. Re-issue request
Cause:
Required administrator password was not read in response to the password prompt before finding end-of-line.
Action:
Re-issue command and be sure to type the password immediately following the prompt.
NDFN-00024: caught I/O exception: string
Cause:
Unexpected I/O exception was encountered while attempting to read the password. Exception string should indicate the precise cause.
Action:
Re-issue command after repairing root cause.
NDFN-00025: string failed for node string
Cause:
The indicated operation could not be completed for the specified node. The lower-level error messages attached should indicate the root cause.
Action:
Re-issue command after repairing the condition indicated.
