Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
48 NNL-00001 to NNL-01078
NNL-00001: request argument "string" is invalid
Cause: The user entered an invalid request command argument.
Action: Supply a valid argument.
NNL-00002: request argument "string" is not allowed with this operation
Cause: The user entered a request command argument which is not valid with the particular request command.
NNL-00003: memory exhausted
Cause: The program has run out of memory
Action: Check the amount of available memory on your machine to ensure that there is enough memory to run this executable. If necessary, free up memory by running fewer programs, then try again.
NNL-00004: invalid command argument "string"
Cause: The user entered an invalid command argument.
NNL-00005: no server has been set. Use the "SET SERVER" command first
Cause: The user attempted to issue a command which requires that a default managed Oracle Names server be set first.
Action: Use the SET SERVER command to set your default server, then reissue the command. Alternatively, if the command allows, re-issue it with a specific server name so the control program does not need to use the default.
NNL-00006: timeout, server is not responding
Cause: The control program issued a request to an Oracle Names server and no response arrived in a timely fashion. The network connection between the control program and the server may be faulty, the server may be very heavily loaded, or there may be substantial network delays between the control program and the server. The latter is especially true for WAN links.
Action: Reissue the command; if it continues to fail, check to see that the server being managed is running correctly and that the network connection between the server and the control program is working correctly.
NNL-00007: server responded with an error
Cause: The control program issued a request to an Oracle Names server and the server responded with an error.
Action: For further details, turn on tracing and re-execute the failing operation. If the error persists, contact Worldwide Customer Support.
NNL-00008: request not understood by server
Cause: The control program issued a request to an Oracle Names server and the server did not understand the request.
Action: If the server and the control program have different versions, they may be unable to communicate. Check your documentation for version compatibility constraints. If the server and control program are compatible, turn on tracing for further details, and re-execute the failing operation. If the error persists, contact Worldwide Customer Support.
NNL-00009: encryption of server password failed
Cause: The control program attempted and failed to encrypt a server password, supplied either through the SET PASSWORD command or the namesctl.server_password configuration parameter.
Action: An internal error not normally visible to the user. Contact Worldwide Customer Support.
NNL-00010: error getting address for server "string"
Cause: The control program attempted to translate a server name to its corresponding address, and failed. There are a large number of possible causes for the failure. The control program's SQLNET.ORA file must exist in the correct system-specific location, and must be readable by the control program. The file must contain a names.preferred_servers entry with valid name server addresses. If the user has changed managed servers with the SET SERVER command, the new server must be running, and must be able to resolve the address or forward the request to another server which can resolve the address. Alternatively, a TNSNAMES.ORA file with valid name server names and addresses must exist in the correct system-specific location.
NNL-00011: no server with name "string" exists
Cause: The user issued a SET SERVER request and the current managed Oracle Names server was unable to translate that name into an address. Alternatively, the user issued a control program request to a specific server, and that server's name could not be translated into an address. Both problems are almost always caused by mis-typing the server name.
Action: Re-issue the request with a valid server name.
NNL-00012: invalid "string" value "string"
Cause: The first argument is a data type, the second is a value. The user supplied an invalid data value of the specified type.
Action: Re-issue the failing operation with correct data.
NNL-00013: not performed, permission denied for supplied password
Cause: The user issued a request to an Oracle Names server, and the password supplied with the request was incorrect.
Action: Check to see that the password sent by the control program to the server is correct for that server. You can set a new password with the SET PASSWORD control program command.
NNL-00014: unknown data type "string"
Cause: The user issued a name server request which contained an unknown data type.
Action: It is possible that the server had no information on the type, but automatically fetched it in response to the failing request. Re-issue the failing request; if the server has in the meantime fetched the appropriate data type information, the error will go away. If the error persists, the data type is probably invalid.
NNL-00015: type "string" has "string" syntax, which has no textual representation
Cause: Not all data type syntaxes can be represented as text. This message indicates that the user issued a name server request for a type with an non-textual representation.
Action: Re-issue the operation with a data type that has a syntax with a textual representation.
NNL-00016: cannot start server, error getting program directory's name
Cause: The user issued a STARTUP request, but the control program was unable to start the server because it was unable to find the name of the directory where the server executable resides.
NNL-00017: cannot start server, program "string" does not exist
Cause: The user issued a STARTUP request, but the control program was unable to start the server because it was unable to find the server executable.
Action: Make sure that a copy of the server executable exists in your system's oracle executable directory.
NNL-00018: warning: could not contact default name server
Cause: The control program was unable to contact its default name server during startup. There are a number of possible causes for this error. The control program's SQLNET.ORA file must exist in the correct system-specific location, and must be readable by the control program. The file must contain a names.preferred_servers entry with valid name server addresses. The first server in the preferred-server list must be running, and there must be network connectivity between the control program and that server.
Action: Check to see that all of the above are true. If the control program is still unable to contact its default server, turn on tracing and restart the control program. If the error persists, contact Worldwide Customer Support.
NNL-00019: warning: server either changed or ignored your request
Cause: The user issued a request to an Oracle Names server and that request was altered in some way. Typically the user specified an invalid argument of some sort, and the server either ignored the request, or replaced the invalid argument with a reasonable default.
Action: Use the control program to check the current state of the value that you attempted to change. The server's log file may also contain information about the exact cause of the problem. Re-issue the operation with correct arguments.
NNL-00020: warning: no TNSNAMES.ORA file and no preferred name servers in SQLNET.ORA
Cause: The control program was unable to find a TNSNAMES.ORA file and was unable to find a default name server in SQLNET.ORA. The control program will operate in this state, but will be unable to resolve any names until a default server has been set, and that server must be set using its raw TNS address.
Action: The control program's SQLNET.ORA file must exist in the correct system-specific location, and must be readable by the control program. The file must contain a names.preferred_servers entry with valid name server addresses. The first server in the preferred-server list must be running, and there must be network connectivity between the control program and that server. Alternatively, a TNSNAMES.ORA file with valid name server information must exist in the correct system-specific location.
NNL-00022: error changing trace level from string to string, level change ignored
Cause: The user attempted to change the control program's local trace level, and the program encountered an error while changing the level. Usually the problem is that tracing was enabled for the first time (by changing the trace level from OFF to something else) and the trace file is not writeable by the control program.
Action: Check to see that the trace file is writeable. Your documentation will tell you the name of the trace file.
NNL-00023: SET command is missing an argument
Cause: The user attempted to issue a SET command with no argument.
Action: Supply a valid argument to the SET command.
NNL-00024: warning: no preferred name servers in SQLNET.ORA
Cause: The control program was unable to find any preferred name servers in SQLNET.ORA, and will therefore not connect to a default server.
Action: Make sure that the SQLNET.ORA file contains a valid names.preferred_servers entry.
NNL-00035: File string or nested IFILEs not found.
Cause: Error in loading from the tnsfile.
Action: None
NNL-00036: No records loaded
Cause: No loadable data.
Action: None
NNL-00037: Error number while sequencing through parameter table.
Cause: The NL Parameter system reported an error while retrieving the next name from the table.
NNL-00038: Distinguished Name syntax error
Cause: Distinguished Name incorrectly specified.
Action: Supply a valid DN.
NNL-00039: no RRs
Cause: Object has no relevant RRs to be mapped to LDAP objects.
Action: None
NNL-00040: Distinguished Name exceeds buffer length: string
Cause: Distinguished Name derived from Domain Name is too long.
Action: Either move the object to a domain whose name is shorter or manually update the LDAP object.
NNL-00041: Object string not in domain string
Action: None
NNL-00042: LDAP bind failure: number, string
Cause: Call to ldap_bind failed with return set to given number.
Action: Correct user/pwd parameters or definitions.
NNL-00043: LDAP open failure
Cause: LDAP server could not be contacted.
Action: Correct connect info or server unavailability.
NNL-00044: Unsupported data type string not mapped
Cause: ONames data type could not be mapped to LDAP attributes
NNL-00045: No host given for LDAP server
Cause: LDAP open will dump core without a host.
Action: Provide appropriate host with '-h' option.
NNL-00046: Name string exceeds DN template depth
Cause: There are more domains in the name than are specified in the DN template.
Action: Add fields to the template or migrate subdomains with separate dump operations.
NNL-00047: LDAP modify returned error: 0xnumber, string
Cause: LDAP failed with the return code shown.
Action: Refer to LDAP documentation for the meaning of the error.
NNL-00048: Error opening file: string
Cause: Named file cannot be opened.
Action: Provide for access to file.
NNL-00049: Output in string cannot be renamed to string
Cause: The given file cannot be created.
Action: Insure that the file specified can be created before running the command. Or use the temporary file itself.
NNL-00201: Shutdown occurs in string
Cause: Control program general message.
Action: None
NNL-00202: No shutdown currently scheduled
Action: None
NNL-00203: Scheduled shutdown to occur in string
Action: None
NNL-00204: Cancelled shutdown
Action: None
NNL-00205: Reload check occurs in string
Action: None
NNL-00206: No reload check currently scheduled
Action: None
NNL-00207: Scheduled reload check to occur in string
Action: None
NNL-00208: Cancelled reload check
Action: None
NNL-00209: Cache checkpoint interval is currently string
Action: None
NNL-00210: Cache checkpointing is currently disabled
Action: None
NNL-00211: Cache checkpoint interval is now string
Action: None
NNL-00212: Cache checkpointing is now disabled
Action: None
NNL-00213: No entry with specified index number, try "SHOW SYSTEM_QUERIES"
Action: None
NNL-00214: Next auto-refresh for specified index number occurs in string
Action: None
NNL-00215: Scheduled specified index number's next auto-refresh to occur in string
Action: None
NNL-00216: Disabled auto-refresh for specified index number
Action: None
NNL-00217: Controller is sleeping for number seconds
Action: None
NNL-00218: Ignoring spurious trailing text "string"
Action: None
NNL-00219: Statistic counter logging interval is currently string
Action: None
NNL-00220: Statistic counter logging is currently disabled
Action: None
NNL-00221: Statistic counter logging interval is now string
Action: None
NNL-00222: Statistic counter logging is now disabled
Action: None
NNL-00223: Statistic counters are next logged in string
Action: None
NNL-00224: Scheduled statistic counters to be logged in string
Action: None
NNL-00225: Currently managing name server "string"
Action: None
NNL-00226: Current request-processing delay is string
Action: None
NNL-00227: Request-processing delay is currently disabled
Action: None
NNL-00228: Request-processing delay is now string
Action: None
NNL-00229: Request-processing delay is now disabled
Action: None
NNL-00230: Controller NOCONFIRM mode is currently string
Action: None
NNL-00231: Controller NOCONFIRM mode is now string
Action: None
NNL-00232: Auto-refresh failure-retry interval is currently string
Action: None
NNL-00233: Auto-refresh failure-retry interval is now string
Action: None
NNL-00234: Auto-refresh failure-retry expiration period is currently string
Action: None
NNL-00235: Auto-refresh failure-retry expiration period is now string
Action: None
NNL-00236: Statistic counter reset interval is currently string
Action: None
NNL-00237: Resetting of statistic counters is currently disabled
Action: None
NNL-00238: Statistic counter reset interval is now string
Action: None
NNL-00239: Resetting of statistic counters is now disabled
Action: None
NNL-00240: Starting "string"...
Action: None
NNL-00241: Processing of modification requests is currently enabled
Action: None
NNL-00242: Processing of modification requests is currently disabled
Action: None
NNL-00243: Processing of modification requests is now enabled
Action: None
NNL-00244: Processing of modification requests is now disabled
Action: None
NNL-00245: General request processing is currently enabled
Action: None
NNL-00246: General request processing is currently disabled
Action: None
NNL-00247: General request processing is now enabled
Action: None
NNL-00248: General request processing is now disabled
Action: None
NNL-00249: DEFAULT-FORWARDERS-ONLY mode is currently enabled
Action: None
NNL-00250: DEFAULT-FORWARDERS-ONLY mode is currently disabled
Action: None
NNL-00251: DEFAULT-FORWARDER-ONLY mode is now enabled
Action: None
NNL-00252: DEFAULT-FORWARDER-ONLY mode is now disabled
Action: None
NNL-00253: Server-generated requests currently request forwarding
Action: None
NNL-00254: Server-generated requests currently do not request forwarding
Action: None
NNL-00255: Server-generated requests now request forwarding
Action: None
NNL-00256: Server-generated requests now do not request forwarding
Action: None
NNL-00257: Server-generated requests currently require authoritative answers
Action: None
NNL-00258: Server-generated requests currently do not require authoritative answers
Action: None
NNL-00259: Server-generated requests now require authoritative answers
Action: None
NNL-00260: Server-generated requests now do not require authoritative answers
Action: None
NNL-00261: Request forwarding is currently enabled
Action: None
NNL-00262: Request forwarding is currently disabled
Action: None
NNL-00263: Request forwarding is now enabled
Action: None
NNL-00264: Request forwarding is now disabled
Action: None
NNL-00266: Round trip time is string
Action: None
NNL-00267: Address is string
Action: None
NNL-00268: Enter name server password:
Cause: Prompt for password after user has issued 'set password'
Action: Type password, invisibly.
NNL-00270: Current default domain is "string"
Action: None
NNL-00271: Default domain is now "string"
Action: None
NNL-00272: Removed name "string" from caches along the following path:
Action: None
NNL-00273: server successfully started\n
Action: None
NNL-00274: server not started, errors follow
Action: None
NNL-00275: Trace level is currently number
Action: None
NNL-00276: Trace level is now number
Action: None
NNL-00277: Maximum number of times a request can be reforwarded is currently number
Action: None
NNL-00278: Maximum number of times a request can be reforwarded is now number
Action: None
NNL-00279: Restart occurs in string
Action: None
NNL-00280: No restart currently scheduled
Action: None
NNL-00281: Scheduled restart to occur in string
Action: None
NNL-00282: Cancelled restart
Action: None
NNL-00283: Next cache checkpoint occurs in string
Action: None
NNL-00284: Scheduled cache checkpoint to occur in string
Action: None
NNL-00285: Server has no queued system queries
Action: None
NNL-00286: Server does not own any domains
Action: None
NNL-00287: Cache flush occurs in string
Action: None
NNL-00288: No cache flush currently scheduled
Action: None
NNL-00289: Scheduled cache flush to occur in string
Action: None
NNL-00290: Cancelled cache flush
Action: None
NNL-00291: Statistic counters are next reset in string
Action: None
NNL-00292: Scheduled statistic counters to be reset in string
Action: None
NNL-00293: Controller's trace level remains unchanged
Action: None
NNL-00294: No entries found
Action: None
NNL-00295: Controller's local trace level is currently number
Action: None
NNL-00296: Controller's local trace level changed from number to number
Action: None
NNL-00297: Cache will be dumped to trace file in string
Action: None
NNL-00298: No cache dump currently scheduled
Action: None
NNL-00299: Scheduled server cache dump to occur in string
Action: None
NNL-00300: Cancelled server cache dump
Action: None
NNL-00301: Server shutting down
Action: None
NNL-00302: Server restarting
Action: None
NNL-00303: Server checking for reload
Action: None
NNL-00304: Server flushing its cache
Action: None
NNL-00305: Server dumping statistics to the log file
Action: None
NNL-00306: Server setting all statistic counters to zero
Action: None
NNL-00307: Server checkpointing its cache
Action: None
NNL-00308: Server dumping its cache to the trace file
Action: None
NNL-00340: Trace file name is currently string
Action: None
NNL-00341: Trace file name is now string
Action: None
NNL-00342: Log file name is currently string
Action: None
NNL-00343: Log file name is now string
Action: None
NNL-00344: Save_config_on_stop is currently ON
Action: None
NNL-00345: Save_config_on_stop is currently OFF
Action: None
NNL-00346: Save_config_on_stop is now ON
Action: None
NNL-00347: Save_config_on_stop is now OFF
Action: None
NNL-00348: Server saving the config file now
Action: None
NNL-00349: Configuration will be saved in string
Action: None
NNL-00350: No save config currently scheduled
Action: None
NNL-00351: Scheduled configuration save to occur in string
Action: None
NNL-00352: Cancelled save config
Action: None
NNL-00353: Not allowed
Action: None
NNL-00400: Response status:
Action: None
NNL-00401: Authoritative answer: string
Action: None
NNL-00402: Authoritative server: string
Action: None
NNL-00403: Number of answers: number
Action: None
NNL-00404: TTL: string
Action: None
NNL-00405: Forwarding information:
Action: None
NNL-00406: Canonical name: string
Action: None
NNL-00407: Alias translations:
Action: None
NNL-00408: Answers:
Action: None
NNL-00409: data type is "string"
Action: None
NNL-00410: Average response time: string
Action: None
NNL-00411: Minimum response time: string
Action: None
NNL-00412: Number of requests: number
Action: None
NNL-00413: Total response time: string
Action: None
NNL-00414: Maximum response time: string
Action: None
NNL-00415: Name: string
Action: None
NNL-00416: Last timestamp: number
Action: None
NNL-00417: Distinguished Name: string
Action: None
NNL-00418: Attributes Mapped: number
Action: None
NNL-00500: Shows information on domains served by this server
Cause: Control program help text.
Action: None
NNL-00501: set|show log_stats_interval [seconds] [<server_list>] :\nset|show the server's statistic counter logging interval
Action: None
NNL-00502: Shows, sets, or cancels when the server next dumps its statistic counters
Action: None
NNL-00503: repeat number command [args] : repeat a command number times
Action: None
NNL-00505: log_stats [<server_list>] : write Names server statistics to the log file
Action: None
NNL-00506: reset_stats [<server_list>] : reset Names server statistics
Action: None
NNL-00507: Shows, sets, or cancels the time when an auto-refresh query is next issued
Action: None
NNL-00508: show system_queries [<server_list>] : show system query information
Action: None
NNL-00509: set|show cache_checkpoint_interval [seconds] [<server_list>] :\nset|show the server's cache checkpoint interval
Action: None
NNL-00510: Adds a data record to an existing name
Action: None
NNL-00511: Shows or sets the server's system query authority requirements
Action: None
NNL-00512: Shows or sets the server's auto-refresh expiration period
Action: None
NNL-00513: Shows or sets the server's auto-refresh failure retry interval
Action: None
NNL-00514: Creates a new name with a default TTL
Action: None
NNL-00515: Deletes a name and its data
Action: None
NNL-00516: Displays complete server status
Action: None
NNL-00517: Insert-replaces a data item under an existing name
Action: None
NNL-00518: Shows or sets the maximum number of times a server can reforward a request
Action: None
NNL-00519: Shows, enables, or disables modification request processing
Action: None
NNL-00520: Changes an existing name's TTL
Action: None
NNL-00521: Shows or sets the server's system query forwarding requirements
Action: None
NNL-00522: Removes a data item from a name by value or by type
Action: None
NNL-00523: Renames an existing name
Action: None
NNL-00524: Replaces a data item with another data item
Action: None
NNL-00525: Shows or sets the server's default-forwarding status
Action: None
NNL-00526: Starts a server using a non-standard executable and optional arguments
Action: None
NNL-00527: Shows, sets, or cancels the time when the server next checkpoints its cache
Action: None
NNL-00528: [set] password password : set the password for subsequent calls
Action: None
NNL-00529: set|show default_domain [<domain_name>] : set|show the current default domain
Action: None
NNL-00530: quit|exit : exit the names control program
Action: None
NNL-00531: flush_name name :\nremoves a name from caches along a route to an authoritative server
Action: None
NNL-00532: set|show forwarding_available [<on|off>] [<server_list>] :\nenable, disable or show server request forwarding
Action: None
NNL-00533: ping [<server_list>] : ping one or more Names servers
Action: None
NNL-00534: query name [type] : query for a desired name and RR type
Action: None
NNL-00535: reload [<server_list>] : reload server cache data if there are changes
Action: None
NNL-00536: set|show requests_enabled [<on|off>] [<server_list>] :\nenable, disable or show server request processing
Action: None
NNL-00537: set|show server [<server_name>] : set|show the currently managed server
Action: None
NNL-00538: stop|shutdown [<server_list>] : stop one or more Names servers
Action: None
NNL-00539: start|startup [args] : start the Names server with optional arguments
Action: None
NNL-00540: [show] status [<server_list>] : display server status summary
Action: None
NNL-00541: set|show trace_level [level] [<server_list>] :\nset|show the server's tracing level
Action: None
NNL-00542: restart [<server_list>] : restart one or more Names servers
Action: None
NNL-00543: [show] version [<server_list>] :\nshow the name and version of one or more Names servers
Action: None
NNL-00544: Displays operations statistics
Action: None
NNL-00545: Displays query request statistics
Action: None
NNL-00546: Displays delete request statistics
Action: None
NNL-00547: Displays rename request statistics
Action: None
NNL-00548: Displays update request statistics
Action: None
NNL-00549: Displays stream usage statistics
Action: None
NNL-00550: flush [<server_list>] : flush one or more servers' cache(s)
Action: None
NNL-00551: Displays cache statistics
Action: None
NNL-00553: Displays forwarding statistics
Action: None
NNL-00555: Displays meta data statistics
Action: None
NNL-00556: set|show reset_stats_interval [seconds] [<server_list>] :\nset|show server statistic counter reset interval
Action: None
NNL-00557: Causes the controller to sleep for N seconds
Action: None
NNL-00558: set|show namesctl_trace_level : set|show the controller's tracing level
Action: None
NNL-00559: Shows, sets, or cancels the time for the next cache dump to the trace file
Action: None
NNL-00560: Shows or sets the server's request-processing delay
Action: None
NNL-00561: register name [-ttype] [-daddress] [-hhostname] [-l<listener_name>] :\nregister an object with Oracle Names
Action: None
NNL-00562: unregister name [-daddress] [-l<listener_name>] :\nunregister an object with Oracle Names
Action: None
NNL-00563: timed_query [timestamp] : query all objects in the Names server's cache
Action: None
NNL-00565: set trace_file_name [filename] [<server_list>] :\nset|show the server's trace file name
Action: None
NNL-00566: set|show log_file_name [filename] [<server_list>] :\nset|show the log file name on one or more servers
Action: None
NNL-00567: reorder_ns [<server_address>] : Generate the enhanced discovery file
Action: None
NNL-00568: delegate_domain <domain_name> <NS_name> <NS_Addr> : Delegate the given domain to the given nameserver
Action: None
NNL-00569: domain_hint <domain_name> <NS_name> <NS_Addr> : Provide hint of a nameserver for a given domain
Action: None
NNL-00570: save_config [<server_list>] : saves server configuration to parameter file
Action: None
NNL-00571: set|show save_config_on_stop [<on|off>]
Action: None
NNL-00572: set|show save_config_interval [seconds] [<server_list>] : set time of next config save
Action: None
NNL-00573: load_tnsnames [file, ... ] : load tnsnames into ONames
Action: None
NNL-00574: dump_tnsnames [file] : dump ONames addresses into tnsnames file
Action: None
NNL-00575: list_objects: list all objects in a domain or subtree
Action: None
NNL-00576: list_delegated: list all delegated domains in the region or subtree
Action: None
NNL-00577: list_domains: list authoritative domains in the region or subtree
Action: None
NNL-00578: dump_ldap: dump addresses in the domain or region to LDAP
Action: None
NNL-00579: _scan: find objects/records matching the given types
Action: None
NNL-00580: register_ns: name server address domain
Action: None
NNL-00581: unregister_ns: name server domain
Action: None
NNL-00582: dump_alias: dump aliases in the domain or region to LDAP
Action: None
NNL-00800: Query requests received: number
Cause: Control program statistic description
Action: None
NNL-00801: Queries received, type ANY: number
Action: None
NNL-00802: Queries received, type ADDRESS: number
Action: None
NNL-00803: Queries received, type ALIAS: number
Action: None
NNL-00804: Queries received, type META-DATA: number
Action: None
NNL-00805: Queries received, type NAME-SERVER: number
Action: None
NNL-00806: Queries received, type RELATED-INFO: number
Action: None
NNL-00807: Queries received, type SOA: number
Action: None
NNL-00808: Queries received, all user-defined types: number
Action: None
NNL-00809: Queries received, multiple types: number
Action: None
NNL-00810: Queries received with no type: number
Action: None
NNL-00811: Fastest query processing time: string
Action: None
NNL-00812: Slowest query processing time: string
Action: None
NNL-00813: Average query processing time: string
Action: None
NNL-00814: Total query processing time: string
Action: None
NNL-00830: Delete requests received: number
Action: None
NNL-00831: Deletes refused, name is not a leaf name: number
Action: None
NNL-00832: Deletes refused, name is a topology name: number
Action: None
NNL-00833: Fastest delete processing time: string
Action: None
NNL-00834: Slowest delete processing time: string
Action: None
NNL-00835: Average delete processing time: string
Action: None
NNL-00836: Total delete processing time: string
Action: None
NNL-00850: Rename requests received: number
Action: None
NNL-00851: Renames refused, name is not a leaf name: number
Action: None
NNL-00852: Renames refused, name is a topology name: number
Action: None
NNL-00853: Renames refused, new name already exists: number
Action: None
NNL-00854: Fastest rename processing time: string
Action: None
NNL-00855: Slowest rename processing time: string
Action: None
NNL-00856: Average rename processing time: string
Action: None
NNL-00857: Total rename processing time: string
Action: None
NNL-00870: Update requests received: number
Action: None
NNL-00871: Updates refused, name is a topology name: number
Action: None
NNL-00872: Updates refused, data is topology data: number
Action: None
NNL-00873: Fastest update processing time: string
Action: None
NNL-00874: Slowest update processing time: string
Action: None
NNL-00875: Average update processing time: string
Action: None
NNL-00876: Total update processing time: string
Action: None
NNL-00890: Messages received: number
Action: None
NNL-00891: Corrupted messages received: number
Action: None
NNL-00892: Duplicate requests received: number
Action: None
NNL-00893: Similar requests received: number
Action: None
NNL-00894: Requests refused, permission denied: number
Action: None
NNL-00895: Requests refused, processing disabled: number
Action: None
NNL-00896: Requests refused, modifications disabled: number
Action: None
NNL-00897: Messages sent: number
Action: None
NNL-00898: Responses sent: number
Action: None
NNL-00899: OK responses sent: number
Action: None
NNL-00900: NO SUCH NAME responses sent: number
Action: None
NNL-00901: CONTENT ERROR responses sent: number
Action: None
NNL-00902: ALIAS LOOP responses sent: number
Action: None
NNL-00903: SERVER FAILURE responses sent: number
Action: None
NNL-00904: NAME EXISTS responses sent: number
Action: None
NNL-00905: NOT AUTHORITY responses sent: number
Action: None
NNL-00906: NOT A LEAF NAME responses sent: number
Action: None
NNL-00907: NOT ALLOWED responses sent: number
Action: None
NNL-00908: UNKNOWN TYPE responses sent: number
Action: None
NNL-00909: META VIOLATION responses sent: number
Action: None
NNL-00910: VERSION SKEW responses sent: number
Action: None
NNL-00911: Responses sent with invalid error code: number
Action: None
NNL-00912: Alias loops detected: number
Action: None
NNL-00913: Server-generated requests sent: number
Action: None
NNL-00914: Forwarding desired on server queries: string
Action: None
NNL-00915: Authority required on server queries: string
Action: None
NNL-00916: Modification requests enabled: string
Action: None
NNL-00917: Artificial request processing delay: string
Action: None
NNL-00918: Time until server restart: string
Action: None
NNL-00919: Time until server shutdown: string
Action: None
NNL-00920: Time until next config save: string
Action: None
NNL-00930: Requests refused, unknown data type: number
Action: None
NNL-00931: Requests refused, no cached meta-data: number
Action: None
NNL-00932: Requests refused, type syntax mismatch: number
Action: None
NNL-00933: Requests refused, OTHER-DATA violation: number
Action: None
NNL-00934: Requests refused, ALIAS-EXISTS violation: number
Action: None
NNL-00935: Requests refused, SINGLE-VALUE violation: number
Action: None
NNL-00936: Requests refused, DATA-EXISTS violation: number
Action: None
NNL-00950: Cache lookup requests: number
Action: None
NNL-00951: Names created on lookup: number
Action: None
NNL-00952: Cache lookup failures: number
Action: None
NNL-00953: Cache lookup exact matches: number
Action: None
NNL-00954: Hash tables created: number
Action: None
NNL-00955: Hash tables enlarged: number
Action: None
NNL-00956: Hash tables freed: number
Action: None
NNL-00957: Name nodes created: number
Action: None
NNL-00958: Name nodes freed: number
Action: None
NNL-00959: Time until cache dump to trace file: string
Action: None
NNL-00960: Time until cache flush: string
Action: None
NNL-00961: Cache checkpoints: number
Action: None
NNL-00962: Cache checkpoint failures: number
Action: None
NNL-00963: Timeouts, name TTL expired: number
Action: None
NNL-00970: System query index number: number
Action: None
NNL-00971: Query ID: number
Action: None
NNL-00972: Query next issued in: string
Action: None
NNL-00973: Query state: number
Action: None
NNL-00974: Name: string
Action: None
NNL-00975: Desired data type: string
Action: None
NNL-00980: Forwarding failures: number
Action: None
NNL-00981: Timeouts, server not responding: number
Action: None
NNL-00982: Not forwarded, no servers found: number
Action: None
NNL-00983: Name-to-hint translations: number
Action: None
NNL-00984: Name-to-hint translations failed: number
Action: None
NNL-00985: Requests reforwarded using referrals: number
Action: None
NNL-00986: Reforwarded requests expired: number
Action: None
NNL-00987: Authoritative answers when authority: number
Action: None
NNL-00988: Non-authoritative NACKs received: number
Action: None
NNL-00989: Objects received with no TTL: number
Action: None
NNL-00990: DEFAULT-FORWARDERS-ONLY mode: string
Action: None
NNL-00991: Maximum number of reforwards per request: number
Action: None
NNL-00992: Auto-refresh failure retry interval: string
Action: None
NNL-00993: Auto-refresh failure retry expiration: string
Action: None
NNL-00994: Responses received: number
Action: None
NNL-00995: Unmatched responses received: number
Action: None
NNL-00996: OK responses received: number
Action: None
NNL-00997: NO SUCH NAME responses received: number
Action: None
NNL-00998: CONTENT ERROR responses received: number
Action: None
NNL-00999: ALIAS LOOP responses received: number
Action: None
NNL-01000: SERVER FAILURE responses received: number
Action: None
NNL-01001: NAME EXISTS responses received: number
Action: None
NNL-01002: NOT AUTHORITY responses received: number
Action: None
NNL-01003: NON LEAF responses received: number
Action: None
NNL-01004: NOT ALLOWED responses received: number
Action: None
NNL-01005: UNKNOWN TYPE responses received: number
Action: None
NNL-01006: META VIOLATION responses received: number
Action: None
NNL-01007: VERSION SKEW responses received: number
Action: None
NNL-01008: Outbound message contexts allocated: number
Action: None
NNL-01009: Outbound message contexts freed: number
Action: None
NNL-01010: Forwarding contexts allocated: number
Action: None
NNL-01011: Forwarding contexts freed: number
Action: None
NNL-01030: Domain index number: number
Action: None
NNL-01031: Name: string
Action: None
NNL-01032: Minimum TTL: string
Action: None
NNL-01040: Data streams opened by server: number
Action: None
NNL-01041: Data stream open failures: number
Action: None
NNL-01042: Data streams answered by server: number
Action: None
NNL-01043: Data stream answer failures: number
Action: None
NNL-01044: Errors reading data stream: number
Action: None
NNL-01045: Errors writing data stream: number
Action: None
NNL-01050: Version banner is "string"\n
Action: None
NNL-01051: Server name: string
Action: None
NNL-01052: Server has been running for: string
Action: None
NNL-01053: Request processing enabled: string
Action: None
NNL-01054: Request forwarding enabled: string
Action: None
NNL-01055: Requests received: number
Action: None
NNL-01056: Requests forwarded: number
Action: None
NNL-01057: Foreign data items cached: number
Action: None
NNL-01058: Region data next checked for reload in: string
Action: None
NNL-01059: Region data reload check failures: number
Action: None
NNL-01060: Cache next checkpointed in: string
Action: None
NNL-01061: Cache checkpoint interval: string
Action: None
NNL-01062: Cache checkpoint file name: string
Action: None
NNL-01063: Statistic counters next reset in: string
Action: None
NNL-01064: Statistic counter reset interval: string
Action: None
NNL-01065: Statistic counters next logged in: string
Action: None
NNL-01066: Statistic counter logging interval: string
Action: None
NNL-01067: Trace level: number
Action: None
NNL-01068: Trace file name: string
Action: None
NNL-01069: Log file name: string
Action: None
NNL-01070: System parameter file name: string
Action: None
NNL-01071: Command-line parameter file name: string
Action: None
NNL-01072: Administrative region name: string
Action: None
NNL-01073: Administrative region description: string
Action: None
NNL-01074: ApplTable Index: number
Action: None
NNL-01075: Contact string
Action: None
NNL-01076: Operational Status number
Action: None
NNL-01077: Save Config on Stop string
Action: None
NNL-01078: Access/Create File Error : string
Cause: Failed to access/create named file or its backup File due to incorrect permissions
Action: Provide correct access to file.
