NNO-00050: serious errors in configuration data, server cannot run
Cause:
The server's configuration data has a problem of some sort which prevents the server from starting.
Action:
Previous error messages in the log file will specify the exact problems leading to the shutdown. The problem most frequently occurs when the network is broken up into multiple administrative regions and the delegation points are incorrect. Read the Oracle Names documentation sections on region delegation and ensure that their directions are being followed correctly.
NNO-00051: domain count number exceeds maximum of number, first number will be loaded
Cause:
The server's configuration contains more domains than the server can support.
Action:
An internal error not normally visible to the user. Contact Worldwide Customer Support.
NNO-00052: invalid domain description list
Cause:
The server's configuration contains an invalid domain description list.
Action:
NNO-00053: duplicate domain description for domain "string"
Cause:
The server's configuration contains duplicate domain descriptions in the domain description list.
Action:
NNO-00054: invalid domain name "string"
Cause:
The server's configuration contains a domain description with an invalid name.
Action:
NNO-00055: invalid domain minimum TTL "string"
Cause:
The server's configuration contains a domain description with an invalid minimum TTL.
Action:
NNO-00056: warning: domain minimum TTL must be between number and number, set to number seconds
Cause:
The server's configuration contains a domain description with an invalid minimum TTL. This error is not fatal; the server will automatically set the TTL to a default value which is suitable for most uses.
Action:
NNO-00057: loading and verifying topology data
Cause:
An informational message written to the log file during normal server startup.
Action:
None
NNO-00058: cannot load topology data from configuration database
Cause:
An error was encountered while trying to load the server's topology data from the configuration database. If more information is available, it will appear under this error. This error will cause the server to shut down.
Action:
Make sure that the database is running, that its name and password as specified in the Oracle Network Manager are accurate, and that there is SQL*Net connectivity between the Oracle Names server and the database. To force the server to start up anyway, using its checkpoint data, start the server with the names.no_region_database parameter set to TRUE. If no checkpoint data is available, the server will shut down.
NNO-00059: cannot construct topology checkpoint file name
Cause:
the server could not construct a system-dependent file name.
Action:
An internal error not normally visible to the user. For further details, turn on tracing and restart the server. If the error persists, contact Worldwide Customer Support.
NNO-00060: loading server topology from checkpoint file "string"
Cause:
An informational message written to the log file when the server has been forced to load from its most recent topology checkpoint file, by setting the names.no_region_database parameter to TRUE.
Action:
None
NNO-00061: loading data for domain "string"
Cause:
Action:
None
NNO-00062: cannot load domain data from configuration database
Cause:
An error was encountered while trying to load the server's domain data from the configuration database. If more information is available, it will appear under this error. This error will cause the server to shut down.
Action:
NNO-00063: cannot construct domain checkpoint file name
Cause:
Action:
NNO-00064: loading domain data from checkpoint file "string"
Cause:
An informational message written to the log file when the server has been forced to load from its most recent domain checkpoint file, by setting the names.no_region_database parameter to TRUE.
Action:
None
NNO-00065: loading cached data from checkpoint file "string"
Cause:
Action:
None
NNO-00066: server will perform reload check of administrative region in number seconds
Cause:
An informational message written to the log file whenever the Oracle Network Manager or the Oracle Names control program send a reload request to the server.
Action:
None
NNO-00067: server reload check countdown aborted
Cause:
An informational message written to the log file whenever the Oracle Names control program halts a reload request previously sent to the server
Action:
None
NNO-00068: warning: administrative region check failed, next check in number seconds
Cause:
this warning is issued whenever the server fails to connect to the configuration database to see if any configuration data has changed. The server will automatically begin reissuing reload checks more frequently, and will eventually give up if connections fail continuously for three days.
Action:
NNO-00069: warning: too many administrative region check failures, checking disabled
Cause:
a warning issued whenever the server has continuously failed for three days in its attempts to connect to the configuration database. The server disables reload checking. Reload checking can later be re-enabled from the Oracle Network Manager or the Oracle Names control program.
Action:
NNO-00070: administrative region has changed, reloading domain data
Cause:
An informational message written to the log file whenever the server's configuration has changed, and the server is reloading the new configuration from the configuration database.
Action:
None
NNO-00071: cannot construct cache checkpoint file name
Cause:
Action:
NNO-00072: loading from region database
Cause:
normal
Action:
NNO-00073: loading server config from region database
Cause:
Action:
None
NNO-00074: downloading region from server string
Cause:
Action:
None
NNO-00080: domain "string" cannot be delegated because its parent is already delegated
Cause:
an internal delegation error has occurred. Delegation is controlled by the Oracle Network Manager, which enforces correct delegation rules.
Action:
NNO-00081: domain "string" has no name servers
Cause:
an internal configuration error has occurred. The Oracle Network Manager is responsible for configuring Oracle Names servers correctly.
Action:
NNO-00082: domain "string" is missing my name "string" as a name server
Cause:
Action:
NNO-00083: domain "string" server "string" has no addresses
Cause:
Action:
NNO-00084: domain "string" is not in the authoritative domain list
Cause:
Action:
NNO-00104: line string: syntax error, data ignored
Cause:
the server found a syntax error its domain data. This message will also appear if the server's internal checkpoint files become corrupted. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00105: line string: invalid name "string", data ignored
Cause:
the server found an invalid global name in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00106: line string: invalid TTL "string", data ignored
Cause:
the server found an invalid TTL in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00107: line string: ignoring stale checkpoint data
Cause:
an informational message which appears during server startup when the server detects out-of-date cached data in its cache checkpoint file. The message is part of normal server startup.
Action:
None
NNO-00108: line number: TTL of number seconds below domain minimum number, using minimum
Cause:
the server found an invalid TTL value in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00109: line string: invalid data type name "string", data ignored
Cause:
the server found an invalid data type name in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00110: line string: unknown data type "string", data ignored
Cause:
the server found an unknown data type in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00111: line string: data type "string" has syntax "string", should be "string", data ignored
Cause:
the server found an invalid data type syntax in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00112: line string: ignored duplicate data of type "string"
Cause:
the server found a duplicate record in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00113: line string: alias data already exists, all other data ignored
Cause:
the server found a alias and non-alias data with the same global name in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00114: line string: other data exists, alias data ignored
Cause:
Action:
NNO-00115: line string: single-value data type "string", other instances ignored
Cause:
the server found more than one record with the same name and type, when the type allows only a single record with a particular name. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00116: warning: data type "string" in string load
Cause:
the server found a record with an invalid data type in its domain data.
Action:
No action required; adjustments to data will eliminate warning.
NNO-00117: line string: missing data type, data ignored
Cause:
the server found a record with a missing data type in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00118: line string: data length string exceeds maximum of string, data ignored
Cause:
the server found a record whose length exceeds an internal limit. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00119: line string: server not authoritative for name "string", data ignored
Cause:
the server found a global name in its domain data for which it is not authoritative. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00120: line string: topology name "string" not allowed here
Cause:
the server found an invalid record in its domain data. The record in question is not loaded, but the server continues to load data.
Action:
NNO-00121: LDIF file string open failed: error = number
Cause:
Action:
NNO-00122: invalid name, data ignored: entry:\nstring
Cause:
Action:
NNO-00123: node "string" has no authoritative parent, data ignored
Cause:
an object in the domain data is apparently not in the domain(s) which the server is authoritative for. The record in question is not loaded, but the server continues to load data.
Action:
Check for inconsistencies in the data and correct any errors in topology definition or domain data outside of authoritative domains.
NNO-00150: warning: invalid hint list, no hints loaded
Cause:
The server's configuration contains an invalid hint description list. The server will continue to run, but will not load any hints.
Action:
NNO-00151: warning: ignoring hint for domain "string", server is authoritative
Cause:
the server's configuration contained a hint for a domain in the server's administrative region. The hint is ignored and the server continues to run.
Action:
NNO-00152: warning: hint count number exceeds maximum of number, first number will be loaded
Cause:
There are too many hints in the server's hint list. The server will load a specified maximum number of hints, ignore the rest, and continue running.
Action:
NNO-00153: warning: hint domain number has invalid name "string", hint domain ignored
Cause:
The server's configuration contains a hont domain with an invalid name. The domain is ignored and the server continues to run.
Action:
NNO-00154: warning: hint number has invalid server name "string", hint ignored
Cause:
The server's configuration contains a hint with an invalid server name. The hint is ignored and the server continues to run.
Action:
NNO-00155: warning: hint number has missing address, hint ignored
Cause:
The server's configuration contains a hint with no server address. The hint is ignored and the server continues to run.
Action:
NNO-00156: warning: hint number address length number exceeds maximum of number, hint ignored
Cause:
The server's configuration contains a hint whose address length exceeds an internal limit. The hint is ignored and the server continues to run.
Action:
NNO-00157: warning: hint number has invalid address, hint ignored
Cause:
The server's configuration contains a hint with an invalid address. The hint is ignored and the server continues to run.
Action:
NNO-00158: warning: hint domain count number exceeds maximum of number, first number will be loaded
Cause:
The server's hint domain list is too long. The server will load a specified maximum number of hint domains, ignore the rest, and continue running.
Action:
NNO-00159: warning: ignoring duplicate hint domain number name "string"
Cause:
The server's hint domain list contains a duplicate domain. The duplicate is ignored and the server continues running.
Action:
NNO-00160: warning: ignoring duplicate hint server "string"
Cause:
The server's hint server list contains a duplicate server. The duplicate is ignored and the server continues running.
Action:
NNO-00250: invalid administrative region description
Cause:
The server encountered an invalid administrative region description during startup. This error will prevent the server from starting. The administrative region description is stored in the server's names.ora configuration file.
Action:
Make sure that the names.admin_region parameter in names.ora is correct. The names.ora file is automatically generated by the Oracle Network Manager, but administrators can edit the file at any time, introducing errors. If the file was never changed, contact Worldwide Customer Support.
NNO-00251: missing administrative region parameter string
Cause:
The server's administrative region description is missing a required parameter. This error will prevent the server from starting. The administrative region description is stored in the server's names.ora configuration file.
Action:
NNO-00252: invalid administrative region parameter string value "string"
Cause:
The server encountered an invalid administrative region parameter. This error will prevent the server from starting. The administrative region description is stored in the server's names.ora configuration file.
Action:
NNO-00253: administrative region parameter string length string exceeds maximum of string
Cause:
The server encountered an administrative region parameter whose length exceeds an internal limit. This error will prevent the server from starting. The administrative region description is stored in the server's names.ora configuration file.
Action:
NNO-00254: warning: parameter string value must be between number and number, set to number seconds
Cause:
The server encountered an administrative region parameter with an invalid value. The value is set to a default suitable for most applications, and the server continues running. The administrative region description is stored in the server's names.ora configuration file.
Action:
NNO-00255: cannot initialize ROS
Cause:
The server was unable to initialize ROS during startup. The error prevents the server from running.
Action:
NNO-00256: using administrative region "string"
Cause:
an informational message which appears during server startup, and notes the name of the administrative region for future diagnostic use by administrators. The message is part of normal server startup.
Action:
None
NNO-00257: warning: cannot get serial number from region store
Cause:
The server encountered an error while trying to get the configuration database's serial number. The error occurs almost always because time the server is unable to access the configuration database. If the error occurs during server startup, the server will shut down. If the error occurs during server operation (the server checks the serial number periodically to see if it should reload itself), then the server assumes a transient failure has occurred and repeats the operation a short while later. If the repetitions continue to fail for three days, the server will log another error and stop issuing the serial number load operation.
Action:
First make sure that the Netadmin program has exported a server configuration for this name server. Next, make sure that the database is running, that its name and password as specified in the Oracle Network Manager are accurate, and that there is SQL*Net connectivity between the Oracle Names server and the database. If the error occurs during server startup, you can force startup anyway, with checkpoint data, by starting the server with the names.no_region_database parameter set to TRUE. If no checkpoint data is available, the server will shut down.
NNO-00258: cannot load configuration from configuration database
Cause:
An error was encountered while trying to load the server's configuration from the configuration database. If more information is available, it will appear under this error. This error will cause the server to shut down.
Action:
NNO-00259: configuration tables have not been installed or are inaccessible
Cause:
The configuration database has not been properly installed.
Action:
Make sure the Oracle Network Manager and its database have been properly installed
NNO-00260: loading configuration data from checkpoint file "string"
Cause:
An informational message written to the log file when the server has been forced to load from its most recent configuration checkpoint file, by setting the names.no_region_database parameter to TRUE.
Action:
None
NNO-00261: cannot construct configuration checkpoint file name
Cause:
Action:
NNO-00262: warning: cannot write checkpoint file "string"
Cause:
the server was unable to write the named checkpoint file. This problem is typically due to the file system's protection settings. The error is not fatal; it simply means the server will not create any checkpoint data. Note, however, that if the configuration database is ever unavailable during a future server startup, the lack of checkpoint data means you will be unable to force a startup from checkpoint data with the names.no_region_database parameter.
Action:
Check to see that the server has permission to write the file named in the error message.
NNO-00263: error from configuration database
Cause:
the server encountered an error while accessing the configuration database. The error can occur when the database is unavailable, or SQL*Net connectivity to the database is interrupted.
Action:
NNO-00264: configuration database query returned no data
Cause:
the server attempted to fetch data from the configuration database and no data was found.
Action:
The error generally appears underneath a more specific error which will tell you the exact nature of the problem.
NNO-00265: warning: cannot load data from checkpoint file
Cause:
the server was started using checkpoint data, and was unable to read that data. The remaining errors below this one on the error stack provide more specific information about the problem.
Action:
Check to see that the named file exists and that the server has permission to read it.
NNO-00266: cannot find document "string" in configuration database
Cause:
The server encountered an error while trying to get its configuration ID from the configuration database. The error can occur any time the server is unable to access the configuration database. This error will cause the server to shut down.
Action:
NNO-00267: warning: configuration database contains no data for server "string"
Cause:
the server successfully contacted the configuration database, but was unable to find any configuration information associated with the server's name. The name is specified in the server's names.ora configuration file. The error occurs almost always because the server configuration has not been exported from the Netadmin program.
Action:
Make sure that the Netadmin program has exported a server configuration for this name server.
NNO-00268: warning: configuration database is not used, using checkpoint data instead
Cause:
An informational message indicating that the server has been started with the names.no_region_database parameter set to TRUE, and that it will use checkpoint data rather than attempting to contact the configuration database.
Action:
None
NNO-00269: configuration database is version string, server requires at least version string
Cause:
The server cannot use the specified configuration database because it is of an incorrect version.
Action:
Run the document conversion utility supplied with the Network Manager and re-export your network. The conversion utility will upgrade old documents to a version which can be understood by the name server.
NNO-00270: ORACLE error string
Cause:
An ORACLE error was encountered while accessing the configuration database. The error can occur when the database is unavailable, or SQL*Net connectivity to the database is interrupted.
Action:
NNO-00271: warning: names.ora region is version string, network definition is version string
Cause:
The region description in names.ora is out of synch with the network definition.
Action:
No action is required unless the name server cannot run with the network definition. To be safe names.ora should be updated with one which is consistent with the network definition.
NNO-00272: line string; invalid DIT/DN
Cause:
There is a syntax error in the DIT/DN provided in the region description.
Action:
Correct the error and restart the server.
NNO-00300: no listen addresses specified, at least one is required
Cause:
the server's configuration is missing addresses on which to listen.
Action:
NNO-00301: server will shut down in number seconds
Cause:
An informational message written to the log file when the server receives a shutdown request from the Oracle Names control program.
Action:
None
NNO-00302: server stopped
Cause:
An informational message written to the log file when the server shuts down.
Action:
None
NNO-00303: server "string" started with process ID number
Cause:
An informational message written to the log file when the server successfully starts up.
Action:
None
NNO-00304: listen address string length string exceeds maximum of string
Cause:
the length of one of the server's listen addresses exceeds an internal limit.
Action:
NNO-00305: trace level changed from number to number
Cause:
An informational message written to the log file when the server changes its trace level in response to a request from the Oracle Names control program.
Action:
None
NNO-00306: server shutdown countdown aborted
Cause:
An informational message written to the log file whenever the Oracle Names control program halts a shutdown request previously sent to the server
Action:
None
NNO-00307: invalid server name "string"
Cause:
the server's name is invalid. The name is specified in the server's names.ora configuration file.
Action:
Make sure that the names.server_name parameter in names.ora is correct. The names.ora file is automatically generated by the Oracle Network Manager, but administrators can edit the file at any time, introducing errors. If the file was never changed, contact Worldwide Customer Support.
NNO-00308: server will restart in number seconds
Cause:
An informational message written to the log file when the server receives a restart request from the Oracle Names control program.
Action:
None
NNO-00309: server restarting
Cause:
An informational message written to the log file when the server restarts.
Action:
None
NNO-00310: server restart countdown aborted
Cause:
An informational message written to the log file whenever the Oracle Names control program halts a restart request previously sent to the server
Action:
None
NNO-00311: invalid listen address list
Cause:
the server's configuration contains an invalid listen address list.
Action:
NNO-00312: listen address string is invalid
Cause:
the server's configuration contains an invalid listen address.
Action:
NNO-00313: server password length string exceeds maximum of string
Cause:
the server's password length exceeds an internal limit.
Action:
NNO-00314: error changing trace level from number to number, level change ignored
Cause:
the server encountered an error while changing its trace level in response to a request from the Oracle Names control program.
Action:
NNO-00315: server is listening on address string
Cause:
An informational message written to the log file during server startup.
Action:
None
NNO-00316: statistic counter reset disabled
Cause:
An informational message written to the log file when the server disables statistic counter resetting in response to a request from the Oracle Names control program.
Action:
None
NNO-00317: statistic counter reset interval changed to number seconds
Cause:
An informational message written to the log file when the server changes its statistic counter reset interval in response to a request from the Oracle Names control program.
Action:
None
NNO-00318: overriding next statistic counter reset, resetting in number seconds
Cause:
An informational message written to the log file when the server resets its statistic counters in response to a request from the Oracle Names control program.
Action:
None
NNO-00320: missing server name parameter
Cause:
the server could not find a names.server_name parameter. The name is specified in the server's names.ora configuration file.
Action:
NNO-00321: statistic counter dump disabled
Cause:
An informational message written to the log file when the server disables statistics dumping in response to a request from the Oracle Names control program.
Action:
None
NNO-00322: statistic counter dump interval changed to number seconds
Cause:
An informational message written to the log file when the server changes its statistic dump interval in response to a request from the Oracle Names control program.
Action:
None
NNO-00323: overriding next statistic counter dump, dumping in number seconds
Cause:
An informational message written to the log file when the server dumps its statistic counters in response to a request from the Oracle Names control program.
Action:
None
NNO-00326: server statistic counter dump follows
Cause:
An informational message written to the log file at the beginning of a statistic dump. The message is followed by a set of server statistics, and ends with another informational message indicating the dump has finished.
Action:
None
NNO-00327: server statistic counter dump ends
Cause:
An informational message written to the log file at the end of a statistic dump. The message is preceded by a set of server statistics.
Action:
None
NNO-00328: server has reset statistic counters to zero
Cause:
An informational message written to the log file when the server resets its statistic counters to zero in response to a request from the Oracle Names control program.
Action:
None
NNO-00329: server will save the config file in number seconds
Cause:
An informational message written to the log file when the server saves the config to config file in response to a request from the Oracle Names control program.
Action:
None
NNO-00330: server saved the config file "string".
Cause:
Action:
None
NNO-00331: error saving new value string of string to the save config table.
Cause:
An informational message written to the log file when the a set operation is performed and the change cannot be saved in the save config ptable, but should be.
Action:
None
NNO-00332: warning: region store serial number reduced from number to number
Cause:
An informational message written to the log file when the server finds the region database has its serial number set lower than it was when the server previously loaded the region data. This is an unnatural condition- every update to the region should increment the serial number so a reduction of the serial number might reflect tampering or accidental manual alteration this and possibly other region tables.
Action:
Administrators should find out how/why the serial number decreased.
NNO-00333: warning: ROS admin_region types obsolete; using SQL
Cause:
the value set in names.admin_region is an obsolete ROS type
Action:
No action is necessary; administrators should set the value to the correct type- probably SQL, possibly LDAP or LDIF
NNO-00334: region load failure: ROS admin_region type number unsupported
Cause:
Action:
NNO-00600: warning: forwarder count number exceeds maximum of number, first number will be loaded
Cause:
the server's configuration contains too many default forwarders. The server loads a specified maximum number of forwarders, ignores the rest, and continues running.
Action:
NNO-00601: warning: no forwarders, DEFAULT-FORWARDERS-ONLY mode ignored
Cause:
the server's configuration enables DEFAULT-FORWARDERS-ONLY mode but the configuration contains no default forwarders. The server ignores the request and continues running.
Action:
NNO-00602: warning: forwarder number has invalid address, forwarder ignored
Cause:
One of the forwarders in the default forwarder list has an invalid address. The forwarder definition is ignored and the server continues running.
Action:
NNO-00603: enabling all request processing
Cause:
An informational message written to the log file when the server enables request processing in response to a request from the Oracle Names control program.
Action:
None
NNO-00604: disabling all request processing
Cause:
An informational message written to the log file when the server disables request processing in response to a request from the Oracle Names control program.
Action:
None
NNO-00605: enabling modification requests
Cause:
An informational message written to the log file when the server enables modification-request processing in response to a request from the Oracle Names control program.
Action:
None
NNO-00606: disabling modification requests
Cause:
An informational message written to the log file when the server disables modification-request processing in response to a request from the Oracle Names control program.
Action:
None
NNO-00607: server will forward to default forwarders only
Cause:
An informational message written to the log file when the server's configuration enables DEFAULT-FORWARDERS-ONLY mode.
Action:
None
NNO-00608: received corrupted message
Cause:
The server received a corrupted request. The request is ignored.
Action:
corrupted requests are usually caused by transient network problems. If many corrupted messages are received, turn on tracing for further information. If the errors persist, contact Worldwide Customer Support.
NNO-00609: warning: forwarder number address length number exceeds maximum of number, ignored
Cause:
the server's configuration contains a forwarder address whose length exceeds an internal limit.
Action:
NNO-00610: detected possible alias loop involving name "string"
Cause:
the server detected an alias loop involving the specified name. An alias loop occurs when an alias "X" points to another alias "Y", which points back to "X" rather than to an address or other name server data. The loop can contain more hops but the basic idea remains the same. Loops occur when administrators mis-enter network data, particularly when an alias in one administrative region points to data in another administrative region.
Action:
Use the Oracle Names control program to query for the specified name. The control program will describe the alias path, and you can use that information to find which names are incorrect and what administrative regions the incorrect data belongs to.
NNO-00611: disabling request forwarding
Cause:
An informational message written to the log file when the server disables request forwarding in response to a request from the Oracle Names control program.
Action:
None
NNO-00612: enabling request forwarding
Cause:
An informational message written to the log file when the server enables request forwarding in response to a request from the Oracle Names control program.
Action:
None
NNO-00613: disabling FORWARDING-DESIRED on system queries
Cause:
An informational message written to the log file when the server disables the FORWARDING-DESIRED attribute on queries that it generates. The message comes in response to a request from the Oracle Names control program.
Action:
None
NNO-00614: enabling FORWARDING-DESIRED on system queries
Cause:
An informational message written to the log file when the server enables the FORWARDING-DESIRED attribute on queries that it generates. The message comes in response to a request from the Oracle Names control program.
Action:
None
NNO-00615: disabling DEFAULT-FORWARDERS-ONLY mode
Cause:
An informational message written to the log file when the server disables DEFAULT-FORWARDERS-ONLY mode in response to a request from the Oracle Names control program.
Action:
None
NNO-00616: enabling DEFAULT-FORWARDERS-ONLY mode
Cause:
An informational message written to the log file when the server enables DEFAULT-FORWARDERS-ONLY mode in response to a request from the Oracle Names control program.
Action:
None
NNO-00617: enabling AUTHORITY-REQUIRED on system queries
Cause:
An informational message written to the log file when the server enables the AUTHORITY-REQUIRED attribute on queries that it generates. The message comes in response to a request from the Oracle Names control program.
Action:
None
NNO-00618: disabling AUTHORITY-REQUIRED on system queries
Cause:
An informational message written to the log file when the server disables the AUTHORITY-REQUIRED attribute on queries that it generates. The message comes in response to a request from the Oracle Names control program.
Action:
None
NNO-00622: warning: too many auto-refresh failures for name "string", query expired
Cause:
If an auto-refresh query is issued and continuously returns an error for three days, the query is removed from the auto-refresh queue and a warning logged. The query can be restarted from the Oracle Names control program.
Action:
this message will be preceded by numerous warnings that the query in question is failing. Use the Oracle Names control program to describe the failing query. Make sure the server being queried is running and that there is network connectivity between the querying server and the server being queried.
NNO-00623: setting auto-refresh retry interval to number seconds
Cause:
An informational message written to the log file when the server changes its auto-refresh retry interval in response to a request from the Oracle Names control program.
Action:
None
NNO-00624: setting auto-refresh expiration period to number seconds
Cause:
An informational message written to the log file when the server changes its auto-refresh expiration period in response to a request from the Oracle Names control program.
Action:
None
NNO-00625: overriding auto-refresh of name "string", type "string", refresh in number seconds
Cause:
An informational message written to the log file when the server changes the time when an auto-refresh query is next issued. The message comes in response to a request from the Oracle Names control program.
Action:
None
NNO-00626: cannot enable DEFAULT-FORWARDERS-ONLY mode, no default forwarders exist
Cause:
the Oracle Names control program issued a request to enable DEFAULT-FORWARDERS-ONLY mode, and the request was ignored because the server has no default forwarders.
Action:
None
NNO-00627: cancelling auto-refresh of name "string", type "string"
Cause:
An informational message written to the log file when the server removes a query from the auto-refresh queue in response to a request from the Oracle Names control program.
Action:
None
NNO-00628: setting maximum reforwards per query to number
Cause:
An informational message written to the log file when the server changes its maximum-reforward count in response to a request from the Oracle Names control program.
Action:
None
NNO-00629: warning: invalid forwarder list, no default forwarders loaded
Cause:
The server's configuration contains an invalid forwarder description list.
Action:
NNO-00630: setting request-processing delay to number seconds
Cause:
An informational message written to the log file when the server sets an artificial request-processing delay in response to a request from the Oracle Names control program.
Action:
None
NNO-00631: warning: forwarder number has invalid name "string", forwarder ignored
Cause:
The server's configuration contains a forwarder description with an invalid server name.
Action:
NNO-00632: warning: forwarder number has missing address, forwarder ignored
Cause:
The server's configuration contains a forwarder description with a missing address.
Action:
NNO-00633: detected fatal delegation loop involving server "string"
Cause:
the server detected a fatal delegation loop while forwarding a request. A loop occurs when the server's topology data indicates that it should forward a request to itself. The server immediately shuts down in response to this error.
Action:
NNO-00634: received authoritative name "string" when we are its authority
Cause:
a server "X" received authoritative data from another server "Y" when server "X" is also authoritative for the data. Such situations should never arise because if server "X" is authoritative for the requested data, it should never forward the request to another server.
Action:
NNO-00635: warning: ignoring duplicate forwarder "string"
Cause:
The server's default forwarder list contains a duplicate server. The duplicate is ignored and the server continues running.
Action:
NNO-00700: warning: cannot checkpoint the cache, trying again in number seconds
Cause:
The server was unable to perform its normal periodic cache checkpointing, typically because the cache checkpoint file could not be written. The cache checkpoint file name appears as an informational message during server startup.
Action:
Check to see that the server has permission to write the cache checkpoint file, and that there is sufficient disk space for the file to be written.
NNO-00701: warning: cannot construct checkpoint file name, checkpointing disabled
Cause:
Action:
NNO-00702: cache checkpointing disabled
Cause:
An informational message written to the log file when the server disables cache checkpointing in response to a request from the Oracle Names control program.
Action:
None
NNO-00703: checkpoint interval changed to number seconds
Cause:
An informational message written to the log file when the server changes its cache checkpoint interval in response to a request from the Oracle Names control program.
Action:
None
NNO-00705: warning: cannot open checkpoint file "string", checkpointing disabled
Cause:
the server was unable to open the named checkpoint file for writing. This problem is typically due to the file system's protection settings. The error is not fatal; it simply means the server will not checkpoint its cache.
Action:
NNO-00706: overriding next cache checkpoint, checking in number seconds
Cause:
An informational message written to the log file when the server checkpoints its cache in response to a request from the Oracle Names control program.
Action:
None
NNO-00707: server's cache will be flushed in number seconds
Cause:
An informational message written to the log file when the server flushes its cache in response to a request from the Oracle Names control program.
Action:
None
NNO-00708: cache flush countdown aborted
Cause:
An informational message written to the log file whenever the Oracle Names control program halts a cache flush request previously sent to the server
Action:
None
NNO-00709: failed delete of cache checkpoint file "string", cache flush may not work
Cause:
the server attempted to flush its cache, which also deletes the cache checkpoint file. The file deletion failed, although the rest of the cache flush succeeded. Succeeding errors describe the reason for the deletion failure.
Action:
This error typically occurs when two cache-flush operations are issued in succession without an intervening cache checkpoint operation (which would recreate the file). The first deletes the cache file, the second attempts to do so, but fails since the file has already been deleted. In such cases, the message is harmless and can be ignored. If, however, the error occurs because the server lacks permission to delete the file, then you must change the file system permissions so the server is allowed to delete the file.
NNO-00710: server's cache will be dumped to the trace file in number seconds
Cause:
An informational message written to the log file when the server dumps its cache to the trace file in response to a request from the Oracle Names control program.
Action:
None
NNO-00711: cache dump countdown aborted
Cause:
An informational message written to the log file whenever the Oracle Names control program halts a cache dump request previously sent to the server
Action:
None
NNO-00712: warning: group string cache checkpoint failed
Cause:
Action:
NNO-00800: Error: cannot read version from config database
Cause:
The query for the region database version failed. The database may be shut down, or the tables may not exist in the schema specified in names.ora.
Action:
Correct any access problems accordingly.
NNO-00801: Error: OCI_SUCCESS_WITH_INFO: string
Cause:
Diagnostic information was returned from OCI during region database access.
Action:
None
NNO-00802: Error: OCI_NEED_DATA
Cause:
The server did not provide sufficient data to the OCI interface while accesing the region database.
Action:
NNO-00803: Error: OCI_INVALID_HANDLE
Cause:
The server called OCI with an invalid handle whilc accessing the region database.
Action:
NNO-00804: Error: OCI_STILL_EXECUTE
Cause:
An OCI operation between the server and the database is still in progress.
Action:
None
NNO-00805: Error: OCI_CONTINUE
Cause:
Not possible.
Action:
None
NNO-00806: Error: OCI_ERROR: string
Cause:
An OCI occurred accessing the region database. More specific details will be written to the log file.
Action:
Find the appropriate entry in the log file and correct the cause of the failure if possible. Otherwise contact Worldwide Customer Support.
NNO-00807: End of Fetch: OCI_NO_DATA
Cause:
All rows have been returned from the region table.
Action:
None
NNO-00808: Error connecting to region database
Cause:
Not possible.
Action:
None
NNO-00809: Unknown OCI error: number
Cause:
Not possible.
Action:
None
NNO-00850: Error: LDAP query returns string
Cause:
The LDAP API returned an error. More specific details will be written to the log file.
Action:
NNO-00851: LDAP open/bind failed: error = number
Cause:
the server failed to connect to the LDAP directory.
Action:
Find the cause of the error and correct it and restart the server.
NNO-00852: failed to get LDAP entry: error = number
Cause:
the server could not retrieve query entries from the LDAP API.
Action:
NNO-00853: failed to get LDAP attribute/value: error = number
Cause:
Action:
NNO-00854: error unbinding LDAP: error = number
Cause:
Action:
