NPL-00100: cannot initialize ASN.1 context
Cause:
The ASN.1 program interface could not be initialized, probably because its error message file could not be found.
Action:
Check that SQL*Net has been installed properly and that all message files are in their proper locations.
NPL-00101: uninitialized ASN.1 context
Cause:
The ASN.1 program interface received an uninitialized ASN.1 handle.
Action:
Not normally visible to the user. For further details, turn on tracing and re-execute the failing operation. If the error persists, contact Worldwide Customer Support.
NPL-00102: missing stream functions in ASN.1 context initialization
Cause:
An internal function imporoperly attempted to initialize an ASN.1 handle.
Action:
NPL-00103: unusable ASN.1 context
Cause:
The ASN.1 program interface received an unusable ASN.1 handle.
Action:
NPL-00300: maximum ASN.1 element nesting depth string exceeded on read
Cause:
An ASN.1 construct is too complex for the program interface to read.
Action:
NPL-00301: maximum ASN.1 element nesting depth string exceeded on write
Cause:
An ASN.1 construct is too complex for the program interface to write.
Action:
NPL-00302: ASN.1 type tag is greater than maximum of 16383
Cause:
An internal function attempted to create an illegal ASN.1 construct
Action:
NPL-00303: uninitialized ASN.1 class attribute
Cause:
Action:
NPL-00304: uninitialized ASN.1 tag attribute
Cause:
Action:
NPL-00305: unsupported ASN.1 "UNIV" type string
Cause:
Action:
NPL-00307: ASN.1 sequence has already been ended on write
Cause:
An internal function attempted to end an ASN.1 construct prematurely.
Action:
NPL-00308: requested ASN.1 class string does not match received class string
Cause:
An internal function requested an ASN.1 construct different from that received by the ASN.1 protocol engine.
Action:
NPL-00309: requested ASN.1 type tag string does not match received type tag string
Cause:
Action:
NPL-00310: ASN.1 sequence has already been ended on read
Cause:
An internal function attempted to finish reading an ASN.1 construct which has already been completely read.
Action:
NPL-00311: cannot end constructed ASN.1 encoding, string encoding octets unread
Cause:
An internal function attempted to finish reading an ASN.1 construct prematurely.
Action:
NPL-00312: attempt to put ASN.1 "UNIV" type with illegal tag string
Cause:
An internal function attempted to create an illegal ASN.1 construct.
Action:
NPL-00313: requested form string does not match actual form string
Cause:
An internal function received an ASN.1 construct different from that expected.
Action:
NPL-00410: incoming ASN.1 value too large (string octets) to store locally
Cause:
The ASN.1 protocol engine was unable to translate an ASN.1 construct to its host representation because the construct was too big.
Action:
NPL-00411: incoming ASN.1 NULL encoding has nonzero length of string
Cause:
The ASN.1 protocol engine received a corrupted ASN.1 construct.
Action:
NPL-00412: incoming ASN.1 BOOLEAN encoding has incorrect length of string
Cause:
Action:
NPL-00413: incoming ASN.1 encoding has length string, maximum allowed is string
Cause:
The ASN.1 protocol engine received an ASN.1 construct too large for it to process.
Action:
NPL-00414: incoming ASN.1 type tag is greater than maximum of 16383
Cause:
The ASN.1 protocol engine received an illegal ASN.1 construct.
Action:
NPL-00415: received unsupported ASN.1 INDEFINITE-LENGTH encoding
Cause:
The ASN.1 protocol engine received an ASN.1 encoding which it could not process because its implementation does not support it.
Action:
NPL-00416: received illegal ASN.1 encoding length of string
Cause:
Action:
NPL-00417: received ASN.1 length octet count greater than maximum of string
Cause:
The ASN.1 protocol engine received an ASN.1 encoding which it could not process because its implementation does not support it..
Action:
NPL-00418: received malformed ASN.1 object identifier
Cause:
Action:
NPL-00419: received ASN.1 object identifier with sub-identifier that is too large
Cause:
Action:
NPL-00420: received ASN.1 object identifier with more than 256 sub-identifiers
Cause:
Action:
