Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
97 PRCH-01000 to PRCH-01061
PRCH-01000: Failed to stop resources running from Oracle home {0}
Cause: An attempt to stop one or more resources in the specified Oracle home failed.
Action: Review the underlying error messages that provide the details of which resources failed to stop, check the cause and action for the individual resource stop failure and perform the steps for each resource that failed to stop.
PRCH-01001: Failed to start resources in Oracle home {0}
Cause: An attempt to start one or more resources in the specified Oracle home failed.
Action: Review the underlying error messages that provide the details of which resources failed to start, check the cause and action for the individual resource start failure and perform the steps for each resource that failed to start.
PRCH-01002: Failed to stop resources running from CRS home {0}
Cause: An attempt to stop one or more resources in the specified CRS home failed.
Action: Review the underlying error messages that provide the details of which resources failed to stop, check the cause and action for the individual resource stop failure, and perform the steps for each resource that failed to stop.
PRCH-01003: Failed to start resources in CRS home {0}
Cause: An attempt to start one or more resources in the specified CRS home failed.
PRCH-01004: Failed to stop service
Cause: An attempt to stop a service resource failed.
Action: Review the accompanying error messages for possible reasons and if needed, use the command 'srvctl stop service -db <db_unique_name>' to stop the service.
PRCH-01005: Failed to stop database
Cause: An attempt to stop the database resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop database -db <db_unique_name>' to stop the database.
PRCH-01006: Failed to stop Listener
Cause: An attempt to stop the listener resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop listener' to stop the listener.
PRCH-01007: Failed to stop Listener
PRCH-01008: Failed to start service
Cause: An attempt to start a service resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start service -db <db_unique_name>' to start the service.
PRCH-01009: Failed to start database
Cause: An attempt to start the database resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start database -db <db_unique_name>' to start the database.
PRCH-01010: Failed to start Listener
Cause: An attempt to start the listener resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start listener' to start the listener.
PRCH-01011: Failed to start Listener
PRCH-01012: Failed to stop EONS
Cause: An attempt to stop the EONS resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop nodeapps' to stop the EONS resource.
PRCH-01013: Failed to start EONS
Cause: An attempt to start the EONS resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start nodeapps' to start the EONS resource.
PRCH-01014: Failed to stop ONS
Cause: An attempt to stop the ONS resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop nodeapps' to stop the ONS resource.
PRCH-01015: Failed to start ONS
Cause: An attempt to start the ONS resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start nodeapps' to start the ONS resource.
PRCH-01016: Failed to stop GSD resource
Cause: An attempt to stop the GSD resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop nodeapps' to stop the GSD resource.
PRCH-01017: Failed to start GSD resource
Cause: An attempt to start the GSD resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start nodeapps' to start the GSD resource.
PRCH-01018: Failed to stop VIP resource
Cause: An attempt to stop the VIP resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop vip -node <node_name>' to stop the VIP resource.
PRCH-01019: Failed to start VIP resource
Cause: An attempt to start the VIP resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start vip -node <node_name>' to start the VIP resource.
PRCH-01020: Failed to stop Network resource
Cause: An attempt to stop the Network resource failed.
Action: Review the error messages for possible reasons, correct the error and use the command 'srvctl stop nodeapps' to stop the Network resource.
PRCH-01021: Failed to start Network resource
Cause: An attempt to start the Network resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start nodeapps' to start the Network resource.
PRCH-01022: Failed to stop SCAN VIP resource
Cause: An attempt to stop the SCAN VIP resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop scan' to stop the SCAN VIP resource.
PRCH-01023: Failed to start SCAN VIP resource
Cause: An attempt to start the SCAN VIP resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start scan' to start the SCAN VIP resource.
PRCH-01024: Failed to stop SCAN Listener resource
Cause: An attempt to stop the SCAN listener resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop scan_listener' to stop the SCAN listener resource.
PRCH-01025: Failed to start SCAN Listener
Cause: An attempt to start the SCAN listener resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start scan_listener' to start the SCAN listener resource.
PRCH-01026: Failed to stop ASM
Cause: An attempt to stop the ASM resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop asm' to stop the ASM resource.
PRCH-01027: Failed to start ASM
Cause: An attempt to start the ASM resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start asm' to start the ASM resource.
PRCH-01028: One or more resources failed to start: {0}
Cause: An attempt to start one or more resources failed.
PRCH-01029: One or more resources failed to stop: {0}
Cause: An attempt to stop one or more resources failed.
PRCH-01030: One or more resources failed to stop: {0}
Action: Review the accompanying resource error messages and their documentation, and correct the problems indicated.
PRCH-01031: One or more resources failed to start: {0}
PRCH-01032: Failed to stop GNS resource
Cause: An attempt to stop the GNS resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop gns' to stop the GNS resource.
PRCH-01033: Failed to start GNS resource
Cause: An attempt to start the GNS resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start gns' to start the GNS resource.
PRCH-01034: Failed to stop diskgroup resource
Cause: An attempt to stop the diskgroup resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop diskgroup -diskgroup <dg_name>' to stop the diskgroup resource.
PRCH-01035: Failed to start diskgroup resource
Cause: An attempt to start the diskgroup resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start diskgroup -diskgroup <dg_name>' to start the diskgroup resource.
PRCH-01036: The state file "{0}" does not exist
Cause: The state file required for the current operation was not found.
Action: Make sure the named file exists in the file system.
PRCH-01037: The filesystem object "{0}" is not a file
Cause: The content that was expected to be a file which turned out not to be a file.
Action: Retry the 'srvctl stop home' to generate this file. If the problem still exists, contact Oracle Support Services.
PRCH-01038: "{0}" is a non-readable file
Cause: The user does not have read permissions to open the file.
Action: Modify the file permissions so that the file becomes readable or execute the command from an OS userid with the required privileges.
PRCH-01039: Failed to stop CVU resource
Cause: An attempt to stop the CVU resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl stop cvu' to stop the CVU resource.
PRCH-01040: Failed to start CVU resource
Cause: An attempt to start the CVU resource failed.
Action: Review the accompanying error messages for possible reasons, correct the error and use the command 'srvctl start cvu' to start the CVU resource.
PRCH-01041: Failed while checking status of service "{0}"
Cause: An attempt to check the status of the listed service failed.
Action: Review the accompanying error messages for possible reasons, correct the error and retry.
PRCH-01042: Failed while checking status of database "{0}"
Cause: An attempt to check the status of the listed database failed.
PRCH-01043: Failed while checking status of database instance "{0}"
Cause: An attempt to check the status of the listed database instance failed.
PRCH-01044: Failed while checking status of listener "{0}"
Cause: An attempt to check the status of the listed listener failed.
PRCH-01045: Failed while checking status of VIP "{0}"
Cause: An attempt to check the status of the listed VIP failed.
PRCH-01046: Failed while checking status of SCAN VIP "{0}"
Cause: An attempt to check the status of the listed SCAN VIP failed.
PRCH-01047: Failed while checking status of SCAN Listener "{0}"
Cause: An attempt to check the status of the listed SCAN listener failed.
PRCH-01048: Failed while checking status of CVU resource "{0}"
Cause: An attempt to check the status of the listed CVU resource failed.
PRCH-01049: Failed while checking status of disk group "{0}"
Cause: An attempt to check the status of the listed disk group failed.
PRCH-01050: Failed while checking status of ASM "{0}"
Cause: An attempt to check the status of the listed ASM failed.
PRCH-01051: Failed while checking status of GNS "{0}"
Cause: An attempt to check the status of the listed GNS failed.
PRCH-01052: Failed while checking status of GSD "{0}"
Cause: An attempt to check the status of the listed GSD failed.
PRCH-01053: Failed while checking status of Network "{0}"
Cause: An attempt to check the status of the listed network failed.
PRCH-01054: Failed while checking status of ONS "{0}"
Cause: An attempt to check the status of the listed ONS failed.
PRCH-01055: Failed to create or open file "{0}"
Cause: State file processing failed because: the file specified is a directory rather than a file, the file did not exist but could not be created, or the file exists but could not be opened.
Action: Enable state file processing by: not specifying a directory name, ensuring the the directory is writable, or ensuring that an existing state file can be overwritten.
PRCH-01056: Failed to write to file "{0}"
Cause: An attempt to write to the given file failed.
Action: If the state file already exists, then make sure that it is writable. Otherwise, make sure that parent directory of the state file path is writable.
PRCH-01057: The Clusterware resource for database "{0}" does not exist.
Cause: The Oracle Clusterware resource for the database with the given name did not exist.
Action: Make sure that Oracle Clusterware resource for the database with the given name exists.
PRCH-01058: Failed while checking status of CRS home {0}
Cause: An attempt to check the status of the CRS home failed.
PRCH-01059: Failed while checking status of Oracle home {0}
Cause: An attempt to check the status of the Oracle home failed.
PRCH-01060: Status check for one or more resources failed: {0}
Cause: An attempt to check the status for one or more resources failed.
Action: Review the underlying error messages that provide the details of which resources failed to query their status, check the cause and action for the individual resource start failure and perform the steps for each resource that failed to start.
PRCH-01061: The following resources specified in the state file do not exist: {0}
Cause: An attempt to start one or more resources in the specified state file failed because they do not exist.
Action: Make sure the resources provided in the state file exist.
