Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
98 PRCI-01000 to PRCI-01168
PRCI-01000: Failed to retrieve install information on local node using OUI location {0}
Cause: An attempt to retrieve install information on the local node from the specified location failed.
Action: Examine the accompanying error messages for details.
PRCI-01001: Failed to retrieve install information on remote node {0} using OUI location {1}
Cause: An attempt to retrieve install information on a remote node from the specified location failed.
PRCI-01100: Failed to get Vendor Cluster for CRS home {0}
Cause: Unable to locate vendor cluster library or execute lsnodes.
Action: Install Vendor Clusterware. Then try to run lsnodes again.
PRCI-01101: Failed to get Vendor Cluster for CRS home {0} on node {1}
Cause: Unable to locate vendor cluster library or execute lsnodes on the specified node.
Action: Install Vendor Clusterware on the specified node. Then try to run lsnodes again.
PRCI-01102: Failed to get OracleCM Cluster for CRS home {0}
Cause: Failed to get OracleCM Cluster for the local node using CRS home provided.
Action: Install Oracle 9i and make sure that /etc/ORCLcluster exists.
PRCI-01103: Failed to get OracleCM Cluster for CRS home {0} on node {1}
Cause: Failed to get OracleCM Cluster for the specified node using CRS home provided.
PRCI-01104: Failed to check Oracle Restart running state for Oracle Restart home {0}
Cause: Failed to check whether Oracle Restart is running from the specified home on the local node.
PRCI-01105: Failed to check Oracle Restart running state for Oracle Restart home {0} on node {1}
Cause: Failed to check whether Oracle Restart is running from the specified home on the specified node.
PRCI-01106: Failed to check Oracle Restart configuration state for Oracle Restart home {0} on node {1}
Cause: Failed to check whether Oracle Restart is configured for the specified home on the specified node.
PRCI-01107: Failed to check CRS running state for CRS home {0}
Cause: Failed to check whether Oracle Clusterware is running from the specified home on the local node.
PRCI-01108: Failed to check CRS running state for CRS home {0} on node {1}
Cause: Failed to check whether Oracle Clusterware is running from the specified home on the specified node.
PRCI-01109: Failed to check CRS configuration state for CRS home {0}
Cause: Failed to check whether Oracle Clusterware is configured for the specified home on the specified node.
PRCI-01110: Failed to check CRS configuration state for CRS home {0} on node {1}
Cause: Failed to check whether Oracle Clusterware is configured for the specified home on the local node.
PRCI-01111: File path is null
Cause: The specified file is null or an empty string.
Action: Provide a valid file path that is not null.
PRCI-01112: Directory name passed was null
Cause: The specified directory name is null or an empty string.
Action: Provide a valid directory name that is not null.
PRCI-01113: Directory {0} does not exist
Cause: Could not find the specified directory or it was a file instead of a directory.
Action: Provide an existing directory name.
PRCI-01114: Node name is null
Cause: The specified node name is null or an empty string.
Action: This is an internal error. Contact Oracle Support Services.
PRCI-01115: argument passed is null
Cause: The specified database name is null or an empty string.
PRCI-01116: Failed to check if a database named {0} exists
Cause: Failed to execute the command 'crsctl stat resource <database_resource_name>' to decide whether the specified database exists or not.
PRCI-01117: Failed to retrieve list of databases under high availability management
Cause: Failed to execute the command 'crsctl stat resource -w TYPE=ora.database.type filter' in order to get the list of databases managed by Oracle Restart.
PRCI-01118: Failed to determine if database {0} depends on Automatic Storage Management
Cause: Failed to execute crsctl command to decide whether the specified database depended on Automatic Storage Management (ASM).
PRCI-01119: Failed to determine if database {0} is configured on node {1}
Cause: An attempt to determine the nodes on which a database is configured failed. Either the specified node name is invalid or an internal request failed.
PRCI-01120: Failed to retrieve list of databases under high availability management for node {0}
Cause: Failed to get the list of database managed by Oracle Restart on the specified node because the specified node is null or an invalid node or crsctl command execution failed.
PRCI-01121: Failed to determine if database {0} depends on Automatic Storage Management on node {1}
Cause: Failed to execute crsctl command to decide whether the specified database depended on Automatic Storage Management (ASM) on the specified node because the specified node is null or an invalid node or crsctl command execution failed.
PRCI-01122: Failed to determine if the public network is using dynamic address assignment (DHCP)
Cause: An attempt to determine whether the public network is using dynamic address assignment (DHCP) failed.
PRCI-01123: CRS home does not exist on the local node
Cause: CRS home is not installed on the local node.
Action: Install a CRS home using the Oracle Universal Installer.
PRCI-01124: Oracle Restart home does not exist on the local node
Cause: Oracle Restart home is not installed.
Action: Install an Oracle Restart home using the Oracle Universal Installer.
PRCI-01125: CRS home does not exist on node {0}
Cause: CRS home is not installed on the specified node.
PRCI-01126: Oracle Restart home does not exist on node {0}
Cause: Oracle Restart home is not installed on the specified node.
PRCI-01127: CRS active version cannot be queried in a non-cluster environment
Cause: Clusterware is not configured.
Action: Ensure that Clusterware is configured.
PRCI-01128: Failed to check Oracle Restart configuration state for Oracle Restart home {0}
Cause: Oracle Restart may not be configured
Action: Ensure that Oracle Restart is installed and configured
PRCI-01129: Failed to check Oracle Restart configuration state on node {1}
PRCI-01130: Failed to check CRS configuration state
Cause: Clusterware CRS may not be configured
Action: Ensure that Clusterware CRS is installed and configured
PRCI-01131: Failed to check CRS configuration state on node {1}
PRCI-01132: Failed to get clustername for CRS home {0} and version {1}
Cause: Clusterware is not configured and CRS stack is not up
Action: Ensure that Clusterware CRS is installed and configured and the stack is up.
PRCI-01133: The IP address {0} does not have the same number of fields with the subnet mask {1}
Cause: IP address is in IPv4 address format while the subnet mask is in IPv6 address format or the other way around.
Action: Ensure that both the IP address and the subnet mask use the same representation (the longer required among IPv4 and IPv6).
PRCI-01134: Applying subnet mask {0} to IP address {1} resulted in an invalid IP address format
Cause: This won't ever happen. Message added just in case.
Action: None
PRCI-01135: Failed to check if path {0} on node {1} is on ACFS
Cause: An attempt to determine if the specified path is on ACFS failed. This can occur because: 1. The Clusterware stack is down on the specified node. 2. ASM is down on the specified node. 3. A diskgroup associated with the path is not online. 4. The path is not mounted.
Action: Perform checks corresponding to the above causes: 1. Ensure the Clusterware stack is running on the specified node. 2. Ensure that ASM is running on the specified node. 3. Ensure that the diskgroup associated with the path is online. 4. Ensure that the file system is mounted on the node.
PRCI-01136: The specified path {0} is not on Oracle Automatic Storage Manager Cluster File System (ACFS)
Cause: The specified path is not on ACFS.
Action: Specify a path that is on ACFS. This check will only accept paths on ACFS.
PRCI-01137: Failed to check if path {0} is on ACFS
PRCI-01138: Failed to check Oracle Restart configuration state
Cause: Oracle Restart was not configured.
Action: Ensure that Oracle Restart is installed and configured.
PRCI-01140: Error occurred while reading input from console
Cause: An attempt to read input from console failed
Action: Make sure that the process running this program has a valid standard input (stdin).
PRCI-01141: Failed to get volume device for path {0}
Cause: An attempt to retrieve the volume device for the given ACFS path failed. This can occur because: 1. The Clusterware stack is down on the node. 2. ASM is down on the node. 3. A diskgroup associated with the path is not online. 4. The path is not mounted.
Action: Perform checks corresponding to the above causes: 1. Ensure the Clusterware stack is running on the node. 2. Ensure that ASM is running on the node. 3. Ensure that the diskgroup associated with the path is mounted. 4. Ensure that the file system is mounted on the node.
PRCI-01142: Failed to get volume device for path {0} on node {1}
Cause: An attempt to retrieve the volume device for the given ACFS path failed. This can occur because: 1. The Clusterware stack is down on the specified node. 2. ASM is down on the specified node. 3. A diskgroup associated with the path is not online. 4. The path is not mounted.
Action: Perform checks corresponding to the above causes: 1. Ensure the Clusterware stack is running on the specified node. 2. Ensure that ASM is running on the specified node. 3. Ensure that the diskgroup associated with the path is mounted. 4. Ensure that the file system is mounted on the specified node.
PRCI-01143: Error executing the script {0} on nodes {1}
Cause: An error occurred in executing the script on the list of nodes mentioned. This message is accompanied by others providing details of the error.
Action: Correct the problem indicated by the accompanying messages and retry.
PRCI-01144: Failed to retrieve Oracle Grid Infrastructure home path
Cause: An attempt to read Grid Infrastructure home path from OLR configuration file or registry entry failed.
Action: Examine the accompanying error messages for details. 1. Make sure Grid Infrastructure is configured as either Oracle Clusterware or Oracle Restart,and that the invoking user is able to read the configuration. 2. Issue the command 'GI home/srvm/admin/getcrshome' and examine the resulting output.
PRCI-01145: Failed to retrieve Oracle Grid Infrastructure home path on node {0}
Cause: An attempt to read Grid Infrastructure home path from OLR configuration file or registry entry on specified node failed.
PRCI-01146: invalid {0} argument passed
Cause: The argument provided was null.
PRCI-01147: root script operation failed on the first node {0}
Cause: The root configuration or upgrade failed on the first node. This message is accompanied by other messages providing details of the error.
PRCI-01148: root script operation failed on the last node {0}
Cause: The root configuration or upgrade failed on the last node. This message is accompanied by other messages providing details of the error.
PRCI-01149: olsnodes utility failed to get the cluster node active roles
Cause: An attempt to execute olsnodes -a has failed.
PRCI-01150: failed to retrieve the active node role of the node {0}
Cause: An attempt to retrieve the active node role of an invalid node of the cluster has failed.
Action: Enter a valid node of the cluster.
PRCI-01151: crsctl utility failed to get the cluster node configured roles
PRCI-01152: failed to retrieve the configured node role of the node {0}
Cause: An attempt to retrieve the configured node role of an invalid node of the cluster has failed.
PRCI-01156: The GNS VIP {0} does not match any of the available subnets {1}.
Cause: The provided Grid Naming Service (GNS) virtual internet protocol (VIP) did not belong to an available subnet.
Action: Ensure that GNS VIP belongs to one of subnets connected to the node.
PRCI-01157: Failed to retrieve the node name on which the management database is running.
Cause: An attempt to retrieve the management database node was made when the management database was not running.
Action: Use the 'srvctl start mgmtdb' command to start the management database and retry.
PRCI-01158: Failed to retrieve the size of management database
Cause: An attempt to retrieve the management database size failed because of underlying errors.
PRCI-01159: Path {0} is not on an ACFS file system
Cause: The supplied path was not on an ACFS filesystem.
Action: Supply a path that is on ACFS.
PRCI-01160: Failed to determine if database {0} is administrator-managed
Cause: An internal command to determine management status of the specified database failed.
Action: Examine the accompanying error message for details.
PRCI-01161: Failed to retrieve nodes on which database {0} is configured
Cause: An internal command to determine the nodes configured for the specified database failed.
PRCI-01162: The specified subnets {0} do not match with any of the subnets {1} present in the node {2}.
Cause: An attempt to check whether the specified subnets were present in the current node failed.
Action: Ensure that the provided subnets match with the subnets present in the current node.
PRCI-01163: The public subnets {0} do not match with any of subnets {1} present in the node {2}.
Cause: An attempt to check whether the VIP belongs to a public subnet failed.
Action: Ensure that the VIP address belongs to a public subnet. The public subnets are displayed by the command 'oifcfg getif'.
PRCI-01164: File "{0}" does not exist.
Cause: The specified file could not be found.
Action: Reissue the command specifying the name of an existing file.
PRCI-01165: XSD resource "{0}" could not be located.
Cause: The XML Schema Definition file was not found at the designated location. This is an internal error.
Action: Contact Oracle Support Services.
PRCI-01166: Credential file "{0}" is invalid.
Cause: The provided credentials file was invalid.
Action: Reissue the command specifying a valid credentials file.
PRCI-01167: failed to extract atttributes from the specified file "{0}"
Cause: An attempt to extract attributes for the specified credentials file failed. This is an internal error.
PRCI-01168: The OCRDUMP utility failed to get all cluster nodes.
Cause: An attempt to execute "ocrdump -noheader -stdout -keyname SYSTEM.version.hostnames" failed. This is an internal error.
