Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
100 PRCO-00001 to PRCO-00019
PRCO-00001: Failed to initialize olsnodes
Cause: Unable to initialize and start olsnodes
Action: Ensure that the clusterware is running.
PRCO-00002: Unable to communicate with the clusterware
Cause: Unable to communicate with the clusterware
PRCO-00003: OCR operation failed \nstring\n
Cause: OCR operation failed
Action: Refer to the OCR error message
PRCO-00004: OCR initialization failed \nstring\n
Cause: OCR initialization failed
PRCO-00008: Unable to retrieve local node number
Cause: Unable to retrieve local node number from clusterware
PRCO-00009: Unable to retrieve local node name
Cause: Unable to retrieve local node name from clusterware
PRCO-00010: Unable to retrieve max number of nodes
Cause: Unable to retrieve maximum number of nodes from clusterware
PRCO-00011: Unable to retrieve node name
Cause: Unable to retrieve node name from clusterware
PRCO-00012: Unable to retrieve node number
Cause: Unable to retrieve node number from clusterware
PRCO-00013: Unable to retrieve private interconnect name
Cause: Unable to retrieve private interconnect name from clusterware
PRCO-00014: Unable to retrieve node virtual IP
Cause: Unable to retrieve node virtual IP from clusterware
PRCO-00015: Not a cluster member
Cause: Specified node is not a cluster member
Action: Specify a cluster member node.
PRCO-00016: Cluster node membership interface for retrieving nodes list returned error code number
Cause: Call to the CSS nodelist service failed with the specified error as return value
Action: Ensure that the clusterware is running and look at the Clusteware log files
PRCO-00017: Cluster attribute retrieval interface to retrieve max node length failed
Cause: Call to the CSS attribute fetch service failed for attribute max node length
Action: Ensure that the clusterware is running, and look at the Clusterware log files
PRCO-00018: Unable to retrieve cluster name
Cause: Unable to retrieve cluster name from clusterware
PRCO-00019: Failure retrieving list of nodes in the cluster
Cause: The list of cluster nodes could not be determined. Additional details on the problem are in accompanying message(s).
Action: Take action based on the accompanying message(s).
