PRCR-01000: Resource {0} already exists
Cause:
An attempt was made to create a resource that already exists.
Action:
Check the resource using the command 'srvctl config object' and if the resource should not exist then remove it using the command 'srvctl remove object'.
PRCR-01001: Resource {0} does not exist
Cause:
An attempt was made to operate on a resource that does not exist.
Action:
Check the resource using the command 'srvctl config object' and if the resource does not exist, then create it using the command 'srvctl add object'.
PRCR-01002: Resource {0} is already enabled
Cause:
An attempt was made to enable a resource that is already enabled.
Action:
If the resource is already enabled then no action is needed. Use the command 'srvctl status object' to determine whether it is enabled.
PRCR-01003: Resource {0} is already disabled
Cause:
An attempt was made to disable a resource that is already disabled.
Action:
If the resource is already disabled then no action is needed. Use the command 'srvctl status object' to determine whether it is disabled.
PRCR-01004: Resource {0} is already running
Cause:
An attempt was made to start a resource that is already running.
Action:
If the resource is already running then no action is needed. Use the command 'srvctl status object' to determine whether it is running.
PRCR-01005: Resource {0} is already stopped
Cause:
An attempt was made to stop a resource that is already stopped.
Action:
If the resource is already stopped then no action is needed. Use the command 'srvctl status object' to determine whether it is stopped.
PRCR-01006: Failed to add resource {0} for {1}
Cause:
An attempt to add the specified resource failed.
Action:
Examine the accompanying error messages for details.
PRCR-01007: Failed to check status of resource {0}
Cause:
An attempt to check status of specified resource has failed.
Action:
Check the help for the underlying exception.
PRCR-01008: Failed to retrieve version of resource {0}
Cause:
An attempt to retrieve version of the specified resource has failed.
Action:
PRCR-01009: Failed to retrieve permissions of resource {0}, ACL {1}
Cause:
Internal error.
Action:
Contact Oracle Support Services.
PRCR-01010: Failed to update permissions of resource {0}
Cause:
An attempt to update permissions of specified resource has failed.
Action:
PRCR-01011: Failed to enable resource {0}
Cause:
An attempt to enable specified resource has failed.
Action:
PRCR-01012: Failed to disable resource {0}
Cause:
An attempt to disable specified resource has failed.
Action:
PRCR-01013: Failed to start resource {0}
Cause:
An attempt to start specified resource on several nodes failed.
Action:
PRCR-01014: Failed to stop resource {0}
Cause:
An attempt to stop specified resource on several nodes failed.
Action:
PRCR-01015: Failed to relocate resource {0}
Cause:
An attempt to relocate specified resource has failed.
Action:
PRCR-01016: Failed to modify resource {0}
Cause:
An attempt to modify specified resource has failed.
Action:
PRCR-01024: Failed to remove resource {0} on nodes {1}
Cause:
An attempt to remove the resource on the specified nodes failed.
Action:
Check the accompanying error messages for details.
PRCR-01025: Resource {0} is still running
Cause:
The specified resource is not stopped.
Action:
Check the accompanying error messages to decide whether to stop the specified resource.
PRCR-01026: Resource {0} is not running
Cause:
The specified resource is not started.
Action:
Check the accompanying error messages to decide whether to start the specified resource.
PRCR-01028: Failed to remove resource {0}
Cause:
An attempt to remove specified resource failed.
Action:
Check the help for the underlying CRSException.
PRCR-01029: Attribute {0} does not exist in resource {1} definition
Cause:
An attempt was made to get an attribute which is not defined for that resource type.
Action:
Make sure that the attribute exists in the resource definition.
PRCR-01030: Resource attribute name {0} is not valid
Cause:
Internal error.
Action:
PRCR-01031: Resource attribute {0} value {1} is not valid
Cause:
Specified resource attribute value is not valid.
Action:
Try recreating the resource attribute value using srvm APIs or recreating the resource using srvctl commands.
PRCR-01032: Current state of resource {0} is not valid
Cause:
Internal error.
Action:
PRCR-01033: Resource type {0} does not exist
Cause:
An attempt to retrieve the type has failed.
Action:
Make sure that the type exists.
PRCR-01035: Failed to look up CRS resource {0} for {1}
Cause:
An attempt to access the specified resource failed because it did not exist.
Action:
Check that the specified name and resource type are correct.
PRCR-01036: Failed to retrieve cardinality of the resource {0}
Cause:
An attempt to retrieve cardinality of resource has failed.
Action:
Examine the accompanying error messages to determine how to respond.
PRCR-01037: Failed to update cardinality of the resource {0} to {1}
Cause:
An attempt to set cardinality of the resource has failed.
Action:
PRCR-01039: Server pool {0} does not exist
Cause:
An attempt was made to retrieve the server pool which does not exists.
Action:
Make sure that requested server pool exists.
PRCR-01040: Resource {0} is already enabled on node(s) {1}
Cause:
An attempt was made to enable a resource that is already enable on nodes.
Action:
The status of a resource can be checked by using the command 'srvctl status object'.
PRCR-01041: Resource {0} is already disabled on node(s) {1}
Cause:
An attempt was made to disable a resource that is already disabled on nodes.
Action:
PRCR-01042: Failed to get dependent resources {0} of resource {1}: {2}
Cause:
Failed to retrieve dependent resources of the given resource.
Action:
PRCR-01043: Failed to update dependent resources {0} of resource {1} to resource {2}
Cause:
Failed to update dependent resources of the given resource.
Action:
PRCR-01050: Resource {0} is not configured in Oracle cluster environment
Cause:
The environment for the specified resource is not Oracle Clusterware.
Action:
The specified commands or APIs can only be used when Oracle Clusterware is running. If the environment is configured as Oracle Restart, use the correspond commands and APIs for Oracle Restart.
PRCR-01051: OracleCM Cluster is not found on node {0}
Cause:
The OracleCM Cluster was not found on the specified node because the library for OracleCM Cluster was not found.
Action:
Install OracleCM Cluster on the specified node.
PRCR-01052: Failed to find OracleCM Cluster library on node {0}
Cause:
Failed to check OracleCM Cluster because of the error in executingthe command to find the file /etc/ORCLcluster/oracm/lib/libskgxn2.so.
Action:
Make sure that the caller has the read and execute permission for the library file.
PRCR-01053: Vendor Cluster is not found on node {0}
Cause:
The Vendor Cluster was not installed and configured on the specified node.
Action:
Install and configure the Vendor Cluster on the specified node.
PRCR-01054: Failed to find Vendor Cluster library on node {0}
Cause:
Failed to check OracleCM Cluster because of the error in executing the command to find the file /etc/ORCLcluster/lib/libskgxn2.so.
Action:
PRCR-01055: Cluster membership check failed for node {0}
Cause:
The specified node does not belong to the cluster.
Action:
Check whether the node name is correct.
PRCR-01061: User permissions are insufficient
Cause:
User permissions are insufficient to register resource/type.
Action:
Make sure the user is crs-user or root.
PRCR-01062: Failed to retrieve attributes of resource {0} on node {1}
Cause:
An attempt to retrieve attributes of the resource has failed.
Action:
Make sure that resource exists.
PRCR-01063: Failed to create context
Cause:
Internal error.
Action:
PRCR-01064: Failed to start resource {0} on node {1}
Cause:
An attempt to start the resource has failed.
Action:
Make sure that resource is ready to start on the node before starting it.
PRCR-01065: Failed to stop resource {0}
Cause:
An attempt to stop the resource failed because the resource wasn't running or the running resource had dependent resources also running.
Action:
Check the accompanying messages to identify dependent resources and stop them. Make sure that resource is running before stopping it.
PRCR-01067: Failed to create a filter
Cause:
An attempt to create a filter has failed.
Action:
PRCR-01068: Failed to query resources
Cause:
An attempt to query the resource failed.
Action:
PRCR-01069: Attribute {0} of {1} {2} not found
Cause:
Internal error.
Action:
PRCR-01070: Failed to check if {0} {1} is registered
Cause:
Failed to check if resource is registered.
Action:
PRCR-01071: Failed to register or update {0} {1}
Cause:
An attempt to register or update the resource failed.
Action:
PRCR-01072: Failed to unregister {0} {1}
Cause:
An attempt to unregister specified Oracle clusterware entity failed.
Action:
PRCR-01074: Failed to retrieve attributes for {0} {1}
Cause:
Failed to retrieve attributes for specified resource.
Action:
PRCR-01075: Failed to retrieve status for resource {0}
Cause:
Failed to retrieve status for specified resource.
Action:
PRCR-01076: Failed to retrieve status for resource {0}: {1} is missed
Cause:
Internal error.
Action:
PRCR-01077: Failed to calculate status for resource {0}: {1}/{2}
Cause:
Internal error.
Action:
PRCR-01078: Failed to retrieve attributes of resource {0}
Cause:
Action:
PRCR-01079: Failed to start resource {0}
Cause:
Action:
Make sure that resource is ready to start before starting it.
PRCR-01085: Unknown typeAsString: {0}
Cause:
Internal error.
Action:
PRCR-01086: {0} {1} is already registered
Cause:
An attempt to register specified resource failed.
Action:
Make sure that a resource is not registered before register it.
PRCR-01087: Failed to retrieve resource {0} instances
Cause:
Internal error.
Action:
PRCR-01088: Failed to stop resource {0}: it was not started on node {1}
Cause:
The resource was not started on the node..
Action:
Make sure that resource was started before stopping it.
PRCR-01089: Failed to relocate resource {0}.
Cause:
An attempt to relocate specified resource failed.
Action:
PRCR-01090: Failed to relocate resource {0}. It is not running.
Cause:
The resource was not started.
Action:
Make sure that resource was started before relocating it.
PRCR-01091: Failed to relocate resource {0}. It is not running on node {1}.
Cause:
Action:
PRCR-01092: Failed to relocate resource {0}. It is running on more than one node
Cause:
The resource was started on more than one node.
Action:
Make sure that resource is running on one node only before relocating it.
PRCR-01093: Failed to relocate resource {0}. It is already running on node {1}
Cause:
The resource is running that node.
Action:
Make sure that resource is not running on a node before relocating it.
PRCR-01094: Failed to start resources on node {0}: {1}
Cause:
Resources defined by filter cannot be started on the node.
Action:
Make sure that resources are not running and ready to run before starting them. Make sure that the node is online.
PRCR-01095: Failed to start resources using filter {0}
Cause:
Resources defined by filter cannot be started.
Action:
PRCR-01096: Filter cannot be null
Cause:
An attempt to use filter has failed.
Action:
Make sure that a filter is provided.
PRCR-01097: Resource attribute not found: {0}
Cause:
Requested resource attribute not found.
Action:
Make sure that resource has requested attribute.
PRCR-01098: Could not set rolling upgrade mode {0}
Cause:
An attempt to start the resource in rolling upgrade mode has failed.
Action:
Make sure that the correct LD_LIBRARY_PATH is set and all shared libraries are present.
PRCR-01099: Cannot start resource {0} on {1} additional nodes because it would exceed the resource cardinality {2}. Resource is already running on {3} nodes
Cause:
Resource cannot be started because of its cardinality restriction.
Action:
Make sure that number of additional nodes does not exceed the resource cardinality.
PRCR-01100: Cannot start resource {0} on {1} nodes because it would exceed the resource cardinality {2}
Cause:
Action:
Make sure that number of nodes does not exceed the resource cardinality.
PRCR-01101: Cannot stop resource {0} on {1} nodes, it is running on {2} nodes.
Cause:
The resource does not have enough running instances to stop.
Action:
Make sure that resource has enough running instances to stop.
PRCR-01102: Failed to verify if user {0} has CRS administrator role
Cause:
Failed to verify if the user has CRS administrator role.
Action:
Resolve the reported error message and retry.
PRCR-01104: Unsupported relocate option {0}
Cause:
Internal error.
Action:
PRCR-01105: Failed to relocate resource {0} to node {1}
Cause:
An attempt to relocate the resource to the specified node has failed.
Action:
Examine accompanying message(s) that provide details of the error, and respond accordingly.
PRCR-01106: Failed to relocate resource {0} from node {1} to node {2}
Cause:
An attempt to relocate the resource from the specified node to another has failed.
Action:
PRCR-01107: Error while trying to set default network as dependent resource for {0}
Cause:
An attempt to set default network dependency for the specified resource failed.
Action:
Examine the accompanying error message(s) for details.
PRCR-01108: ONS cannot be created because default network is not configured.
Cause:
An attempt was made to create ONS resource with out creating the dependent default network resource.
Action:
Network resource can be created using the command 'srvctl add nodeapps'. Create the network resource and try this command again.
PRCR-01109: Failed to remove attributes "{1}" from resource {0}
Cause:
Possible reasons: Oracle Clusterware stack might not be active, CRS resource may not exist, or the CRS resource may not have given attributes set.
Action:
Make sure that Oracle Clusterware is active, the CRS resource exists and has given attributes set.
PRCR-01110: Failed to retrieve processed attributes of resource {0} for node {1}
Cause:
Oracle Clusterware stack was not active or CRS resource did not not exist.
Action:
Make sure that Oracle Clusterware is active, the CRS resource exists.
PRCR-01111: Failed to retrieve processed attributes of resource {0} for node {1}
Cause:
requested CRS resource did not exist.
Action:
Make sure that the CRS resource exists.
PRCR-01112: Failed to retrieve current event sequence number
Cause:
Oracle Clusterware stack was not active.
Action:
Make sure that Oracle Clusterware is active.
PRCR-01113: Failed to create detailed error message, rc = {0}
Cause:
Internal error
Action:
PRCR-01114: Failed to relocate servers {0} into server pool {1}
Cause:
Failed to relocate servers into the given server pool. This message may be accompanied by others providing additional details. A likely cause is violation of defined configuration attributes such as pool MIN_SIZE, SERVER_NAMES etc.
Action:
If the problem stems from violating configuration attributes, either modify the attributes or reformulate the request. Otherwise, contact Oracle Support Services.
PRCR-01115: Failed to find entities of type {0} that match filters {1} and contain attributes {2}
Cause:
Failed to look up entitites of given type that match given filters. This message may be accompanied by others providing additional details. A likely cause is that current user does not have permissions to read attributes of entities of given type.
Action:
If lack of permissions is the cause of this failure, then use the command 'srvctl config object -a' to find the current owner of the entity and retry the query as that owner user. Otherwise, contact Oracle Support Services.
PRCR-01116: {0} {1} cannot be created and registered now
Cause:
Oracle Clusterware stack could not create and register an object.
Action:
PRCR-01117: Failed to stop resources using filter {0}
Cause:
An attempt to stop resources using specified filter failed.
Action:
Respond based on the accompanying exception message.
PRCR-01118: Failed to generate resource permissions for the resource
Cause:
Creation of the Access Control List (permission) structures for the resource failed. This message is accompanied by others providing details of the error.
Action:
Respond based on the accompanying exception message(s).
PRCR-01119: Failed to look up CRS resources of {0} type
Cause:
An attempt to find the resource for the specified resource type failed because it did not exist.
Action:
Create a resource of the type.
PRCR-01120: Resources are already running: {0}
Cause:
An attempt to start resources failed because they are already running. For detailed information about resources review the accompanying error messages.
Action:
None
PRCR-01121: Value of parameter "{0}" cannot be null or empty
Cause:
An attempt to construct ACFS resource name failed due to null or empty value for the indicated parameter.
Action:
This is an internal error. Contact Oracle Support Services.
PRCR-01122: Resource type {0} is not registered with Oracle Clusterware
Cause:
Given resource type was not registered.
Action:
Make sure that required resource type is registered.
PRCR-01123: Failed to rename resource type {0}
Cause:
An attempt was made to change name of the given resource type. Resource types cannot be renamed.
Action:
None
PRCR-01124: Failed to check resource {0}
Cause:
An attempt to check the resource failed.
Action:
Correct any problems reported in accompanying messages. Make sure that resource is registered with Oracle Clusterware.
PRCR-01125: Failed to check resource {0} on node {1}
Cause:
An attempt to check the resource on specified node failed.
Action:
PRCR-01126: Failed to relocate resource {0} from node {1}
Cause:
An attempt to relocate the resource from the specified node has failed.
Action:
Examine the accompanying error messages and respond accordingly.
PRCR-01127: Resource {0} does not have attributes {1} on per node basis
Cause:
An attempt to remove given attributes failed because these attributes do not exist on per node basis.
Action:
Retry after supplying attributes that exist on per node basis.
PRCR-01128: Resource {0} does not have attributes {1} on node {2}
Cause:
An attempt to remove given attributes failed because these attributes do not exist on the given node.
Action:
Retry after supplying attributes that exist on the node.
PRCR-01129: Failed to upgrade resource type {0}
Cause:
An attempt to upgrade specified resource type failed.
Action:
Examine the accompanying error message(s) and respond accordingly.
PRCR-01130: Failed to get the name for resource type {0} from resource type enum class
Cause:
An attempt to get the name of the resource type for the given resource type enum class.
Action:
Ensure that the resource type enum class contains the proper resource type name.
PRCR-01131: CVU resource cannot be created because default network is not configured.
Cause:
An attempt was made to create CVU resource without creating the dependent default network resource.
Action:
PRCR-01132: Failed to stop resources using a filter
Cause:
An attempt to stop resources failed because resources were not running or running resources had dependent resources also running.
Action:
Check the accompanying messages to identify dependent resources and stop them. Make sure that resources are running before stopping them.
PRCR-01133: Failed to stop database {0} and its running services
Cause:
An attempt to stop given database and its running services failed.
Action:
PRCR-01134: Failed to stop database {0} and its running services on nodes {1}
Cause:
An attempt to stop the given database and its running services failed on the specified nodes.
Action:
PRCR-01135: Failed to check if node with node number 0 exists
Cause:
An attempt failed to determine whether a node numbered 0 exists.
Action:
Follow action specified for accompanying message.
PRCR-01136: Action {0} is not allowed for snapshot entities
Cause:
Internal error.
Action:
PRCR-01137: Action {0} is not allowed for CRS local entities
Cause:
Internal error.
Action:
PRCR-01138: Failed to get cached attributes for entity {0} on node {1}
Cause:
Internal error.
Action:
PRCR-01139: Cache is not ready to generate a snapshot
Cause:
Internal error.
Action:
PRCR-01140: Wrong sequence number {0}, expected {1} or more
Cause:
Internal error.
Action:
PRCR-01141: Attribute {0} is not set for local entity {1}
Cause:
Internal error.
Action:
PRCR-01142: Failed to build a snapshot
Cause:
Internal error.
Action:
PRCR-01143: Snapshot does not have information about database {0}
Cause:
Internal Error: An attempt was made to operate on a database that does not exist in a snapshot.
Action:
PRCR-01144: Failed to evalute the effects of the proposed request \n{0}
Cause:
An error occurred during processing of the proposed request.
Action:
PRCR-01145: The proposed operation being evaluated would result in an error \n{0}
Cause:
The effect of the proposed WhatIf request resulted in an error.
Action:
Examine the accompanying error messages for details of the error that would result from the proposed operation.
PRCR-01146: The cluster active version doesn't allow the requested action
Cause:
CRS failed to perform a request because the cluster upgrade is not completed.
Action:
Complete the cluster upgrade and retry the request.
PRCR-01147: Snapshot support was interrupted
Cause:
Internal error.
Action:
PRCR-01149: Failed to initialize snapshot subsystem
Cause:
An attempt to initialize snapshot subsystem failed.
Action:
Check the accompanying messages. Make sure that Oracle Clusterware is active.
PRCR-01150: Snapshot subsystem was not initialized
Cause:
An attempt was made to create a snapshot but snapshot subsystem is not initialized.
Action:
PRCR-01151: Snapshot does not have information about server {0}
Cause:
An attempt was made to operate on a server that does not exist in a snapshot. Either the server name was misspelled or the server has not been registered at the time of snapshot creation.
Action:
Make sure that the server name spelling is correct. Review the accompanying error messages for details about the failure. Retry after resolving those issues.
PRCR-01152: Invalid CRS cache mode: {0}
Cause:
CRS cache does not support requested mode.
Action:
Retry after supplying correct value for CRS Cache mode.
PRCR-01153: Snapshot internal error: {0}
Cause:
Internal error.
Action:
PRCR-01154: Failed to create file output stream with file name: {0}
Cause:
An attempt to create file output failed because of IO problems opening the file.
Action:
PRCR-01155: Failed to create file output stream with file name: {0} due to security manager does not allowed to permit the operation
Cause:
An attempt to create file output failed due to security manager does not allowed to permit the operation.
Action:
Run as different user or modify the security permissions or controls.
PRCR-01156: Failed to create file output stream with file name: {0} because 'count' or 'limit' is invalid
Cause:
An attempt to create file output failed because of illegal arguments 'count' < 1 or 'limit' < 0.
Action:
Retry with proper arguments 'limit' >= 0 or 'count' >= 1.
PRCR-01157: Failed to close the file output stream with file name: {0} due to security manager does not allow to close
Cause:
An attempt to create file output failed due to security manager does not permit the operation.
Action:
PRCR-01158: Directory {0} in file path does not exist
Cause:
An attempt was made to operate on a directory that does not exist.
Action:
Retry with valid directory.
PRCR-01159: Failed to create file output stream because of empty file name
Cause:
An attempt to create file output stream failed because of empty file name.
Action:
Specify valid file name.
PRCR-01160: Output stream does not exist
Cause:
An attempt was made to operate on an output stream that does not exist.
Action:
PRCR-01161: Failed to write to output stream
Cause:
An attempt to write to an output stream failed.
Action:
Check if file system runs out of space otherwise contact Oracle Support Services.
PRCR-01162: Failed to format a message
Cause:
An attempt to format a log message failed.
Action:
PRCR-01163: Failed to open or create the output stream with file name: {0}
Cause:
An attempt to open or create an output file failed.
Action:
PRCR-01164: Failed to flush an output stream
Cause:
An attempt to flush a log output stream failed.
Action:
PRCR-01165: Failed to close the output stream
Cause:
An attempt to close a log file failed.
Action:
PRCR-01166: An operation on output stream failed
Cause:
An operation on output stream failed.
Action:
PRCR-01169: Mismatch between the number of attribute names ({0}) and the number of the corresponding attribute values ({1})
Cause:
Internal error.
Action:
PRCR-01170: Failed to add resource {0}
Cause:
Action:
PRCR-01171: Insufficient number of arguments while executing "{0}"
Cause:
An attempt was made to execute the specified script with insufficient number of arguments.
Action:
PRCR-01172: Failed to execute "srvmhelper" for {0}
Cause:
Failed to execute srvmhelper for the specified API.
Action:
PRCR-01173: Failed to look up CRS resource for type {0}
Cause:
An attempt to search for resource of the specified type failed.
Action:
Check that at least one of the specified type exists. Examine the accompanying error messages for details.
PRCR-01174: Resource {0} is not running on node {1}
Cause:
The specified resource is not started or not running on the specified node.
Action:
Check that specified resource is running on the specified node.
PRCR-01175: Failed to add ASM Listener "{0}" because a dependent resource does not exist.
Cause:
During creation of an ASM listener resource, internal updates to associated ASM or IOServer resources could not be made because the resource(s) did not exist.
Action:
Review the accompanying messages for more details.
PRCR-01176: A software exception has occurred.
Cause:
An internal exception occurred while attempting to update resource dependencies during creation of an ASM Listener configuration.
Action:
PRCR-01177: Failed to update dependency on related resources when adding ASM listener "{0}"
Cause:
During creation of an ASM listener resource, updates to associated ASM or IOServer resources failed.
Action:
PRCR-01178: Execution of command failed on one or more nodes
Cause:
Execution of a command through the administrator helper resource failed.
Action:
Examine the accompanying error messages that provide the details of why and where command execution failed . Resolve the reported problem and retry.
PRCR-01179: Failed to retrieve nodes suitable for configuring an administrator-managed database
Cause:
An attempt to execute the command 'olsnodes -a' has failed.
Action:
Ensure that the clusterware stack is up. If it is, and the errors reported by olsnodes cannot be resolved, contact Oracle Support Services.
PRCR-01180: No response received
Cause:
A response was not received while executing the command through the administrator helper resource.
Action:
Ensure that the node specified is reachable and responsive. If the problem persists, Contact Oracle Support Services.
PRCR-01181: Failed to request action {0} on resource {1}
Cause:
An attempt to request the action on the resource failed.
Action:
Make sure that the resource is running.
PRCR-01182: Failed to request action {0} on resource {1} on nodes {2}
Cause:
An attempt to request the action on the resource failed on the specified nodes.
Action:
Make sure that the resource is running on the specified nodes.
PRCR-01183: Failed to request action {0} on multiple resources
Cause:
An attempt to request the action on multiple resources failed.
Action:
Make sure that the resources are running.
PRCR-01184: Response from the resource on which the action was requested was not in the correct format
Cause:
An internal error occurred. The callback message for the requested action was not in the correct format during an attempt to request the action.
Action:
PRCR-01185: failed to execute "srvmhelper" for command "{0}" with the following errors:\n{1}
Cause:
An attempt to execute the command has failed.
Action:
Examine the accompanying error messages that provide the details of why and where command execution failed. Resolve the reported problem and retry.
PRCR-01186: Multiple final messages for the requested action were received for node {0}
Cause:
An internal error occurred. Multiple final messages for the requested action were received during an attempt to request the action.
Action:
PRCR-01187: No final message for the requested action was received.
Cause:
An internal error occurred. No final message for the requested action was received during an attempt to request the action.
Action:
PRCR-01188: The requested action cannot be executed because there is no resource instance.
Cause:
The resource has no instance on the specified nodes or, if nodes were not specified, in the cluster.
Action:
Make sure that at least one resource instance exists on the specified nodes or, if nodes were not specified, in the cluster.
PRCR-01189: The user {1} does not have read and execute permissions for the ACFS file system resource associated with path {0}.
Cause:
A check on the permissions for the ACFS file system resource associated with the indicated path failed because the user indicated in the message did not have read and execute permissions for the resource.
Action:
Verify that the specified user has read and execute permissions on the ACFS file system resource using 'srvctl config filesystem'. To change permissions use 'srvctl modify filesystem'.
PRCR-01190: The specified VIP name {0} resolves to multiple {1} addresses.
Cause:
The specified VIP name did not resolve to a single IPv4 or IPv6 address.
Action:
Specify a numeric GNS VIP address or ensure that the specifed VIP name resolves to a single IPv4 or IPv6 address. Use 'nslookup vipname' to display the addresses to which the VIP name resolves.
PRCR-01191: The stop request failed because the resource is not running on nodes {0}.
Cause:
A request to stop a resource was rejected because the resource did not have a running instance on the specified nodes.
Action:
Specify nodes where the resource is running.
PRCR-01192: The specified instance on cardinality ID {0} of resource {1} is already enabled.
Cause:
An attempt to enable the specified resource instance was rejected because the resource instance was already enabled.
Action:
No action is needed.
PRCR-01193: The specified instance on cardinality ID {0} of resource {1} is already disabled.
Cause:
An attempt to disable the specified resource instance was rejected because the resource instance was already disabled.
Action:
PRCR-01194: Resource {0} does not have attributes {1} on cardinality ID {2}.
Cause:
An attempt to remove the specified attributes failed because these attributes did not exist on the specified cardinality.
Action:
Retry after specifying attributes that exist on the cardinality.
