PRCS-01000: Failed to get enabled status of {0}
Cause:
An attempt to check whether a server is enabled failed.
Action:
Examine the accompanying error messages for details.
PRCS-01001: Failed to enable {0}
Cause:
An attempt to enable the specified server failed.
Action:
PRCS-01002: Failed to disable {0}
Cause:
An attempt to disable the specified server failed.
Action:
PRCS-01005: Failed to create server {0}
Cause:
An attempt to create the specified server failed.
Action:
PRCS-01006: Failed to get server for node {0}
Cause:
An attempt to get server for the specified node failed.
Action:
PRCS-01007: Server pool {0} already exists
Cause:
The specified server pool already exists.
Action:
PRCS-01008: Server pool {0} does not exist
Cause:
The specified server pool does not exist.
Action:
Use the srvctl command to create server pool.
PRCS-01009: Failed to create server pool {0}
Cause:
An attempt to create specified server pool failed.
Action:
PRCS-01010: Failed to get {0} of server pool {1}
Cause:
An attempt to get the attribute value of the specified server pool failed.
Action:
PRCS-01011: Failed to modify server pool {0}
Cause:
An attempt to modify the specified server pool failed.
Action:
PRCS-01012: Failed to remove server pool {0}
Cause:
Failed to unregister server pool. This message is followed by the reason for failure.
Action:
Retry after resolving the issue reported in the failure message.
PRCS-01013: Failed to look up server pool {0}
Cause:
An attempt to get the specified server pool failed.
Action:
PRCS-01014: Server {0} is already part of server pool {1}
Cause:
An attempt to add the server as a candidate for the specified server pool failed because the server is already in the pool's SERVER_NAME attribute.
Action:
No action is needed.
PRCS-01015: Server {0} is not part of server pool {1}
Cause:
An attempt to remove the server from the SERVER_NAMES attribute of the server pool failed because the specified server is not in the pool's SERVER_NAME attribute.
Action:
Add the server to the server pool.
PRCS-01016: Failed to resolve Single Client Access Name {0}
Cause:
An attempt to resolve specified Single Client Access Name to a list of IP addresses failed because Single Client Access Name could not be resolved in DNS using nslookup or using other lookup methods.
Action:
Check whether the specified Single Client Access Name is correct. Review the underlying error messages that provide the details of which resource failed to resolve. Check the cause and action for the individual error. If Single Client Access Name should be resolved in DNS, check the configuration of Single Client Access Name in DNS.
PRCS-01017: Failed to configure Single Client Access Name {0}
Cause:
An attempt to add cluster configuration for Single Client Access Name failed.
Action:
Review the underlying error messages that provide the details of which resources failed to create. Check the cause and action for the individual resource creation failure.
PRCS-01018: Failed to add cluster configuration for Single Client Access Name listener {0}
Cause:
An attempt to configure Single Client Access Name listener failed because endpoints were not specified correctly or other reasons.
Action:
Review the underlying error messages that provide the details of which resources failed to create. Check the cause and action for the individual resource creation failure. If the endpoints were not specified correctly, correct endpoints.
PRCS-01019: Failed to remove the configuration for Single Client Access Name listener {0}
Cause:
An attempt to remove the configuration of Single Client Access Name listener failed because other resources depended on it or other reasons.
Action:
Review the underlying error messages that provide the details of which resources failed to remove. Stop Single Client Access Name listener resource before removing it. Can consider using force flag to remove Single Client Access Name listener resources if no other resources depend on it.
PRCS-01020: Failed to enable Single Client Access Name resources {0}
Cause:
An attempt to enable Single Client Access Name resources failed.
Action:
Review the underlying error messages that provide the details of which resources failed to enable. Check the cause and action for the individual resource creation failure.
PRCS-01021: Failed to disable Single Client Access Name resources {0}
Cause:
An attempt to disable Single Client Access Name resources failed because current user did not have sufficient privileges to perform this operation or other reasons.
Action:
Review the underlying error messages that provide the details of which resources failed to disable. Check the cause and action for the individual resource failure. Make sure that the user has root privileges on Linux/Unix's and Administrator on Windows.
PRCS-01022: Failed to start Single Client Access Name resources {0}
Cause:
An attempt to start Single Client Access Name resources failed.
Action:
Review the underlying error messages that provides the details of which resources failed to start.
PRCS-01023: Failed to stop Single Client Access Name resources {0}
Cause:
An attempt to stop Single Client Access Name resources failed because Single Client Access Name listeners were not stopped/relocated or other reasons.
Action:
Review the underlying error messages that provides the details of which resources failed to stop. Check the cause and action for the individual resource creation failure. Stop Single Client Access Name listeners first or use force flag to stop Single Client Access Name Virtual Internet Protocol(VIP) resources if no other resources depend on them.
PRCS-01024: Failed to remove Single Client Access Name Virtual Internet Protocol(VIP) resources {0}
Cause:
Could not remove Single Client Access Name Virtual Internet Protocol(VIP) resources because the resources are running or Single Client Access Name listeners depend on or other reasons.
Action:
Review the underlying error messages that provides the details of which resources failed to remove. Stop the Single Client Access Name VIPs and Single Client Access Name listeners, then remove Single Client Access Name listeners. Or use force flag to remove Single Client Access Name Virtual Internet Protocol(VIP) resources if no other resources depend on them.
PRCS-01025: Could not find any Single Client Access Name (SCAN) Virtual Internet Protocol (VIP) resources using filter {0}
Cause:
An attempt to retrieve the SCAN VIP resources failed.
Action:
Ensure that the resource name supplied is correct. Examine the accompanying error messages for additional details.
PRCS-01026: Could not find any Single Client Access Name (SCAN) listener resources using filter {0}
Cause:
An attempt to retrieve the SCAN listener resources failed.
Action:
PRCS-01027: Could not find any Single Client Access Name listener with ordinal number {0}
Cause:
Could not find the Single Client Access Name listener for specified ordinal number.
Action:
Use the command 'srvctl config scan_listener' to check available ordinal number.
PRCS-01028: Single Client Access Name (SCAN) listener resources already exist on network {0}
Cause:
Single Client Access Name listeners were already created on the specified network.
Action:
Use the command 'srvctl modify scan_listener' to modify attributes if needed.
PRCS-01031: Failed to modify Single Client Access Name listeners using endpoints {0}
Cause:
An attempt to modify Single Client Access Name listeners failed.
Action:
Check if the endpoints specified are valid.
PRCS-01032: No server pool was found that matches the query {0}
Cause:
An attempt to find server pools that match the given query found no matching server pool.
Action:
Either configure a server pool via the command 'srvctl add srvpool' or modify existing a server pool via the command 'srvctl modify srvpool' to match the query and retry the request.
PRCS-01034: Failed to modify Single Client Access Name {0}
Cause:
Failed to modify the configuration of Single Client Access Name because the endpoints were not specified correctly or extra Single Client Access Name VIPs could not be removed or other reasons.
Action:
Review the underlying error messages that provides the details of which resources failed to modify. Resolve the reported problem and retry. If to modify the endpoints, specify correct endpoints. If to update the number of Single Client Access Name VIPs, stop the Single Client Access Name listeners that depend on.
PRCS-01035: Invalid number of TCP ports ({0}) for SCAN Listener
Cause:
Either no port was specified, or more than one port was specified.
Action:
Specify only one port number for TCP protocol for SCAN listener.
PRCS-01037: Single Client Access Name (SCAN) Virtual Internet Protocol (VIP) resources already exist on network {0}
Cause:
An attempt was made to add SCAN VIPs when SCAN VIPs were already configured. Only one SCAN per cluster network can be configured.
Action:
Remove the existing SCAN on the given network and add a new SCAN. Or, modify the SCAN to use a new SCAN name or have the existing SCAN name map to different SCAN VIPs.
PRCS-01038: Failed to find Single Client Access Name Virtual Internet Protocol(VIP) associated with listener {0}
Cause:
Cannot find Single Client Access Name Virtual Internet Protocol(VIP) associated with the given listener.
Action:
Examine the accompanying error messages to determine how to respond.
PRCS-01039: Failed to find Single Client Access Name listener associated with the given Virtual Internet Protocol(VIP) {0}
Cause:
Cannot find Single Client Access Name listener associated with the given Virtual Internet Protocol(VIP).
Action:
PRCS-01040: User {0} does not have CRS administrator role
Cause:
The specified user did not have CRS administrator role.
Action:
Grant CRS administrator role to the user by using the command 'crsctl add crs administrator -u <user_name>' and retry.
PRCS-01041: Invalid builtin server pool name {0}
Cause:
The specified builtin server pool name is invalid.
Action:
Provide a valid builtin server pool name. It can be Generic or Free.
PRCS-01042: Server pool {0} is not hosting any database currently
Cause:
A database could not be found referencing the given server pool.
Action:
Create the database configuration using the command 'srvctl add database ... -serverpool <server_pool>' and retry.
PRCS-01043: Server pool {0} is not hosting any database service currently
Cause:
A service could not be found referencing the given server pool.
Action:
Create the service configuration using the command 'srvctl add service ... -serverpool <server_pool>' and retry.
PRCS-01046: Name {0} is not valid
Cause:
Specified name was not valid.
Action:
Specify a valid string name, and retry.
PRCS-01047: Minimum size of {0} is not valid
Cause:
Specified minimum size was not valid.
Action:
Specify minimum size to be an integer equal to or greater than zero and less than the maximum size (other than -1), and retry.
PRCS-01048: Maximum size of {0} is not valid
Cause:
Specified maximum size was not valid.
Action:
Specify maximum size to be an integer greater than or equal to -1 and retry.
PRCS-01049: Importance of {0} is not valid
Cause:
Specified importance was not valid.
Action:
Specify importance value to be an integer greater than or equal to 0 and retry.
PRCS-01050: Could not add GNS VIP {0} because another one with name {1} already exists
Cause:
The name of the GNS VIP to be added matches one that already existed.
Action:
Specify another name.
PRCS-01051: Could not add GNS VIP using network {0} because registered another one using network {1} already exists
Cause:
The network specified for the GNS VIP to be added matches one that already existed.
Action:
Specify another network.
PRCS-01053: failed to resolve address for Grid Naming Service VIP {0}:\n{1}
Cause:
The address specified for the GNS VIP could not be resolved.
Action:
Specify a valid address.
PRCS-01054: Failed to configure VIP for Grid Naming Service VIP {0}
Cause:
The creation of the GNS VIP failed.
Action:
Examine the accompanying error message for details.
PRCS-01055: Failed to modify Grid Naming Service VIP {0}
Cause:
The modification of the GNS VIP failed.
Action:
PRCS-01056: Could not find resources for Grid Naming Service Virtual Internet Protocol(VIP) {0}
Cause:
The specified GNS VIP did not exist.
Action:
Specify a valid GNS VIP name.
PRCS-01057: INTERNAL ERROR: no attributes specified.
Cause:
No attributes to modify GNS with were passed to a method.
Action:
This is an internal error. Please contact Oracle Customer Support.
PRCS-01058: INTERNAL ERROR: unsupported query type: "${0}"
Cause:
The type of query to be made to GNS is unrecognized.
Action:
This is an internal error and should not be visible. Please contact Oracle Customer Support.
PRCS-01059: Failed to get sub-server pools of server pool {0}
Cause:
Failed to look up PARENT_POOLS attribute of server pools containing the given server pool name. Ensure that current user has read permissions on the given server pool and its sub-server pools.
Action:
Grant read permissions on the given server pool and its sub-server pools.
PRCS-01060: Failed to relocate servers {0} into server pool {1}
Cause:
Failed to relocate servers into the given server pool. This message may be accompanied by others providing additional details. A likely cause is violation of defined configuration attributes such as pool MIN_SIZE, SERVER_NAMES etc.
Action:
If the problem stems from violating configuration attributes, either modify the attributes or reformulate the request. Otherwise, contact Oracle Support Services.
PRCS-01061: Failed to find running database instances hosted by server pool {0}
Cause:
Failed to find running database instances hosted by the servers in the given server pool. This message is accompanied by others providing additional details. A likely cause is that current user may not have permissions to query profiles of databases hosted by the given server pool.
Action:
If lack of permissions is the cause of this failure, then use the command 'srvctl config object -a' to find the current owner of entity and retry the query as that owner user. Otherwise, contact Oracle Support Services.
PRCS-01062: Failed to determine whether server pool {0} has any parents or children
Cause:
Failed to find parents or children of the given server pool. A likely cause is that current user may not have permissions to query profile of given server pool or profiles of other server pools whose PARENT_POOLS attribute contains this server pool name.
Action:
If lack of permissions is the cause of this failure, then use the command 'srvctl config serverpool serverpool -a' to find the current owner of the server pool and retry the query as that owner user. Otherwise, contact Oracle Support Services.
PRCS-01063: Server pool {0} with minimum size {1}, maximum size {2}, importance {3} and server list ({4}) can not be created
Cause:
Specified server pool cannot be created because of the reason provided by an accompanying exception message.
Action:
Respond based on the accompanying exception message.
PRCS-01064: Failed to find server pools using filter {0}
Cause:
Attempt to look up server pool entitites using given filter failed. A likely cause is that current user does not have permissions to query server pool entities
Action:
If lack of permissions is the cause of this failure, then use the command 'srvctl config serverpool -a' to find the current owner of the server pools and retry the query as that owner user. Otherwise, contact Oracle Support Services.
PRCS-01065: GNS server is not configured in this cluster.
Cause:
A command that applies only to a GNS server cluster was rejected because this cluster has not been configured as a GNS server.
Action:
If GNS server is to run in this cluster, use the 'srvctl add gns' command to configure it.
PRCS-01066: Server group {0} with server list ({1}) can not be created
Cause:
Specified server group cannot be created because of the reason provided by an accompanying exception message.
Action:
PRCS-01067: Failed to find online database instances hosted by server pool {0}
Cause:
Failed to find online database instances hosted by the servers in the given server pool. This message is accompanied by others providing additional details. A likely cause is that current user may not have permissions to query profiles of databases hosted by the given server pool.
Action:
If lack of permissions is the cause of this failure, then use the command 'srvctl config object -a' to find the current owner of the entity and retry the query as that owner user. Otherwise, contact Oracle Support Services.
PRCS-01068: Oracle Clusterware server entity for node {0} does not exist
Cause:
The server entity for the specified node does not exist.
Action:
Start Oracle Clusterware on the given node and retry.
PRCS-01069: Label {0} in GNS domain name {1} does not follow RFC-1035 convention
Cause:
The specified portion of the GNS domain name does not follow RFC-1035 label conventions.
Action:
Specify a domain name that follows RFC-1035 conventions. According to RFC-1035 conventions, the domain name consists of a set of labels separated by ".". A label must begin with an alphabetic character and can contain only alphanumerics and "-" (dash or minus character), end with an alphanumeric, and be no more than 63 characters long.
PRCS-01070: Label {0} part of GNS domain name {1} is too long
Cause:
The specified portion of the GNS domain name does not follow RFC-1035 label conventions, as it is longer than 63 characters.
Action:
Specify a domain name that follows RFC-1035 conventions. The domain name consists of a set of labels separated by ".". Label must begin with an alphabetic character and can contain only alphanumeric characters and "-" (dash or minus character), end with an alphanumeric and be no more than 63 characters long.
PRCS-01071: An error occurred while trying to look up IP address for domain name {0}
Cause:
An error occurred while trying to translate the indicated fully domain qualified name (FQDN) to an IP addresses.
Action:
Make sure that name servers on local node are correctly configured. If the domain in the FDQN is GNS domain make sure that DNS has been set up to forward request to GNS and GNS resource is online. Make sure that there are no firewalls between the local node and the name servers.
PRCS-01072: Failed to create server pool with reserved name {0}
Cause:
Request to create the specified server pool was rejected because specified server pool name is the name of builtin server pool of Oracle Clusterware.
Action:
Supply a server pool name other than the builtin server pool name (Generic or Free) of Oracle Clusterware and retry.
PRCS-01073: The specified GNS logging level {0} was outside the expected range of {1} to {2}
Cause:
The 'log_level' value in the 'srvctl start gns -loglevel <log_level>' command was less than the minimum limit.
Action:
Ensure that the 'log_level' value is within the valid range.
PRCS-01074: The specified GNS logging level {0} was outside the expected range of {1} to {2}
Cause:
The 'log_level' value in the 'srvctl start gns -loglevel <log_level>' command was greater than the maximum limit.
Action:
PRCS-01075: GNS Domain name {0} ends with invalid character {1}
Cause:
The specified GNS domain name ends with an invalid character and does not follow RFC-1035 label conventions.
Action:
Specify a domain name that follows RFC-1035 conventions. According to RFC-1035 conventions, the domain name consists of a set of labels separated by ".". A label must begin with an alphabetic character and can contain only alphanumeric characters or "-" (dash or minus character), end with an alphanumeric, and be no more than 63 characters long.
PRCS-01076: Invalid Single Client Access Name {0}. The subnet {1} of SCAN VIP {2} differs from the subnet {3} of network {4}
Cause:
The SCAN VIPs resolved from the specified Single Client Access Name are in a subnet that differs from the network's subnet.
Action:
Use the SCAN name that can be resolved to the SCAN VIPs in the same subnet of network resource.
PRCS-01077: The specified trace level {0} was outside the expected range of {1} to {2}
Cause:
The trace level value was less than the minimum limit or greater than the maximum limit.
Action:
Ensure that the trace level value is within the valid range.
PRCS-01078: Failed to update the invited nodes {0} for service registration with Scan Listener {1}
Cause:
An attempt to update the invited nodes attribute failed.
Action:
Retry the request after ensuring that the CRS stack is running, the SCAN listener resource has been configured, and the user has update permission on the SCAN listener resource.
PRCS-01079: Failed to retrieve the invited nodes for service registration with Scan Listener {0}
Cause:
An attempt to retrieve the invited nodes attribute value of scan listener failed.
Action:
PRCS-01080: Failed to update the invited subnets {0} for service registration with Scan Listener {1}
Cause:
An attempt to update the invited subnets attribute of scan listener failed.
Action:
PRCS-01081: Failed to retrieve the invited subnets for service registration with Scan Listener {0}
Cause:
An attempt to retrieve the invited subnets attribute of scan listener failed.
Action:
PRCS-01082: Invalid built-in server category name {0}
Cause:
The specified category name was invalid.
Action:
Provide a valid category name. It can be ora.hub.category or ora.leaf.category.
PRCS-01083: There is no server category {0} registered in CRS
Cause:
The server category did not exist.
Action:
Add the server category using the command 'crsctl add category <category_name>' or use the command 'crsctl status category' to get a list of server categories already registered in CRS.
PRCS-01084: Failed to find server categories using filter {0}
Cause:
An attempt to look up server category entitites using the given filter failed.
Action:
See the accompanying error messages for further details.
PRCS-01085: Server category {0} already exists
Cause:
A server category that already exists was specified.
Action:
PRCS-01086: Failed to create category {0}
Cause:
An attempt to create the specified server category failed.
Action:
PRCS-01087: SCAN name "{0}" does not resolve to an IPv4 or IPv6 address
Cause:
The SCAN name did not resolve to an IP address (either IPv4 or IPv6).
Action:
Ensure that the SCAN name resolves to an IP address.
PRCS-01088: SCAN name "{0}" resolves to a different number of IPv4 ({1}) and IPv6 ({2}) addresses
Cause:
The number of IPv4 and IPv6 addresses that the SCAN name resolved to were not equal.
Action:
Ensure that the SCAN name resolves to an equal number of IPv4 and IPv6 addresses.
PRCS-01089: Domain must be supplied because network "{0}" has type "{1}".
Cause:
An attempt to add GNS on a non-static network was rejected because a domain was not supplied.
Action:
Ensure that a domain is forwarded from DNS, and supply the domain using the command 'srvctl add gns -vip address -domain domain'.
PRCS-01090: Failed to retrieve the sub-domain configured for GNS
Cause:
An attempt to retrieve the sub-domain attribute of the specified Grid Naming Service (GNS) failed.
Action:
Retry the request after ensuring that the CRS stack is running, the GNS resource has been configured, and the user has read permission on the GNS resource.
PRCS-01091: The scan name "{0}" resolves to {1} addresses such as "{2}", while network {3} has only {4} subnet
Cause:
The given scan name resolved to a type of addresses that the network did not have.
Action:
Either modify the network via the command 'srvctl modify network -subnet' to include the missing type or make sure that the scan name resolves only to the addresses of the same type as the network.
PRCS-01092: Failed to get the value for the attribute {0} of server category {1}
Cause:
An attempt to get the attribute value of the specified server category failed.
Action:
PRCS-01093: Server pool {0} does not have a server category defined
Cause:
The server pool did not have the server category defined as required for policy-managed databases in a an Oracle Flex Cluster.
Action:
Modify the server pool using the command 'srvctl modify srvpool -serverpool serverpool -category category -servers ""'.
PRCS-01094: Server category {0} of server pool {1} has the following non-hub active CSS role: {2}
Cause:
The server category of the server pool did not have ACTIVE_CSS_ROLE=HUB as required for policy-managed databases in a Flex Cluster.
Action:
Modify the server pool to use a server category that has the hub active CSS role or modify the server category to use ACTIVE_CSS_ROLE=HUB.
PRCS-01095: Conflicting specification of 'servers' and 'category' arguments for the serverpool {0}
Cause:
Both 'servers' and 'category' arguments were specified on the command.
Action:
Retry the request with either 'servers' or 'category' argument.
PRCS-01096: The serverpool {0} already contains the server names
Cause:
The command 'srvctl modify srvpool' specified 'category' option, but the server pool already has a server names attribute.
Action:
Remove the server names attribute by issuing the command 'srvctl modify srvpool -serverpool <pool_name> -servers ""'
PRCS-01097: The serverpool {0} already contains the server category
Cause:
A 'srvctl modify srvpool' command specified 'servers' but the server pool already has a server category attribute.
Action:
Remove the server category attribute by issuing the command 'srvctl modify srvpool -serverpool <pool_name> -category ""'
PRCS-01098: Active CSS role of the server category {0} of PQ server pool {1} is not set
Cause:
The server category of the server pool did not specify ACTIVE_CSS_ROLE.
Action:
Modify the PQ server pool to use a server category that has a valid active CSS role or modify the server category to set ACTIVE_CSS_ROLE.
PRCS-01099: Nodes {0} of the server pool {1} do not have HUB active CSS roles
Cause:
The server pool did not have nodes with ACTIVE_CSS_ROLE=HUB as required for policy-managed databases in a Flex Cluster.
Action:
Modify the server pool to use nodes that have HUB active CSS roles.
PRCS-01100: Nodes {0} of the PQ server pool {1} do not have LEAF active CSS roles
Cause:
The server pool did not have nodes with ACTIVE_CSS_ROLE=LEAF as required for policy-managed databases in a Flex Cluster.
Action:
Modify the server pool to use nodes that have LEAF active CSS roles.
PRCS-01101: Unable to create GNS resource because it already exists.
Cause:
An attempt was made to add the GNS resource but the resource already exists.
Action:
Either remove the GNS resource and then add it, or avoid adding an already existing resource.
PRCS-01102: Could not find any Single Client Access Name (SCAN) Virtual Internet Protocol (VIP) resources using filter {0} on network {1}
Cause:
An attempt to retrieve the SCAN VIP resources on the indicated network failed.
Action:
PRCS-01103: Could not find any Single Client Access Name (SCAN) listener resources using filter {0} on network {1}
Cause:
An attempt to retrieve the SCAN listener resources on the indicated network failed.
Action:
PRCS-01104: Could not find the Single Client Access Name (SCAN) listener with ordinal number {0} on network {1}
Cause:
An attempt to find the SCAN listener for the specified ordinal number and network failed.
Action:
Use the command 'srvctl config scan_listener -netnum' to check the available ordinal numbers on the given network.
PRCS-01105: Server category {0} of Parallel Query server pool {1} has the following non-leaf active CSS role: {2}
Cause:
The server category of the server pool did not have ACTIVE_CSS_ROLE=LEAF as required for the parallel query helper service of the policy-managed databases in a Flex Cluster.
Action:
Modify the Parallel Query server pool to use a server category that has the leaf active CSS role or modify the server category to use ACTIVE_CSS_ROLE=LEAF.
PRCS-01106: Nodes {0} of the Parallel Query server pool {1} do not have the leaf active CSS role
Cause:
Action:
Modify the server pool to use nodes that have the leaf active CSS role.
PRCS-01107: Cannot add resource on network {0}, which is configured as leaf.
Cause:
An attempt to add a resource using a network configured as 'leaf' was made.
Action:
Add the resource on a network not configured as 'leaf'.
PRCS-01108: Cannot modify resource to use network {0}, which is configured as leaf.
Cause:
An attempt to modify a resource using a network configured as 'leaf' was made.
Action:
Provide a network not configured as 'leaf'.
PRCS-01110: Single Client Access Name (SCAN) {0} does not resolve to {1} addresses although it should resolve to both IPv4 and IPv6 addresses
Cause:
An attempt to modify the SCAN name while the network type was 'BOTH' was rejected because the specified SCAN name did not resolve to both IPv4 and IPv6 addresses required by the network.
Action:
Make sure that the specified SCAN name resolves to both IPv4 and IPv6 addresses.
PRCS-01111: Could not modify GNS VIP because registered type and IP address type are different
Cause:
The IP address type specified for the GNS VIP to be added differed from the registered network type.
Action:
Specify an IP address of the type that is registered.
PRCS-01112: Server {0} is not assigned to any server pool.
Cause:
The given server was not yet recognized by Oracle Clusterware and therefore was not active in any server pool.
Action:
Check the state of the server using the command 'crsctl status server server -f'.
PRCS-01113: The Single Client Access Name (SCAN) VIP address "{0}" does not belong to network {1} which has only an {2} subnet.
Cause:
The network modification failed because the type of the specified SCAN VIP address was incompatible with the subnet of the specified network.
Action:
Either modify the network via the command 'srvctl modify network -subnet' to include the missing type or make sure that the SCAN VIP is an address of the same type as the network.
PRCS-01115: An attempt to retrieve the Rapid Home Provisioning Server host name and port number failed with the following error:\n{0}
Cause:
While looking up Rapid Home Provisioning Server connection details in Grid Naming Service (GNS), an attempt to retrieve the host name and port number failed.
Action:
Address the accompanying error message. Make sure that both the GNS and the Rapid Home Provisioning Server are running on the RHPS cluster.
PRCS-01116: no SRV record for service {0} found in the Grid Naming Service (GNS)
Cause:
Action:
Contact Oracle Support Services.
PRCS-01117: invalid format for SRV record {0} returned from the Grid Naming Service (GNS)
Cause:
Action:
PRCS-01118: The supplied GNS VIP name "{0}" resolves to multiple IP addresses.
Cause:
Multiple addresses were found while looking up the specified GNS VIP name.
Action:
Supply a GNS VIP name that resolves to exactly one address, or supply a numeric GNS VIP address.
