Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
104 PRCW-01001 to PRCW-01017
PRCW-01001: Could not allocate new memory
Cause: Could not allocation any new memory.
Action: Retry after make more memory available.
PRCW-01002: Network Security error code {0}
Cause: Failed to perform the network security operation.
Action: Look at the network security error for the appropriate action.
PRCW-01003: Failed to do the cluster wallet operation {0}
Cause: Failed to perform the cluster wallet operation.
Action: Look at the cluster wallet error for the appropriate action.
PRCW-01004: Could not open the wallet {0} due to error {1} : {2}
Cause: Failed to open the cluster wallet.
PRCW-01005: Wallet {1} did not exist due to error code {1}
Cause: The cluster wallet did not exist.
Action: Need to create the cluster wallet.
PRCW-01006: Alias {0} in Wallet {1} did not exist
Cause: The alias within the cluster wallet did not exist.
Action: Need to create the alias within the cluster wallet.
PRCW-01007: Alias {0} in Wallet {1} could not be read due to error {2}
Cause: Could not read the alias within the cluster wallet.
PRCW-01008: Alias {0} in Wallet {1} could not be written due to error code {2}
Cause: Could not write the secret of the alias to the cluster wallet.
PRCW-01009: Wallet {0} could not be saved due to error code {1}
Cause: Could not save the cluster wallet.
PRCW-01010: Wallet {0} could not be created due to error {1}: {2}
Cause: Could not create the cluster wallet.
PRCW-01011: Wallet {0} could not be accessed due to error code {1}
Cause: Could not access the cluster wallet.
Action: Use the correct cluster wallet password.
PRCW-01012: Wallet {0} could not be deleted due to error code {1}
Cause: Could not delete the cluster wallet.
PRCW-01013: Failed to initialize cluster wallet context due to error code {0}
Cause: Could not initialize the cluster wallet context.
PRCW-01014: Failed to terminate cluster wallet context due to error code {0}
Cause: Could not terminate the cluster wallet context.
PRCW-01015: Wallet {0} does not exist. {1}
Cause: An attempted wallet operation could not find the specified wallet.
Action: Ensure that the correct wallet type was supplied, or create the wallet if appropriate.
PRCW-01016: Wallet name is missing for wallet type {0}
Cause: An attempted wallet operation failed as wallet name was not specified.
Action: This is an internal error. Contact Oracle Support Services.
PRCW-01017: Cluster wallet context to be terminated does not exist
Cause: An attempt to terminate the cluster wallet context failed as it has not been initialized.
