Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
105 PRCZ-01000 to PRCZ-02051
PRCZ-01000: User name cannot be null or empty
Cause: An invalid value was supplied as user name.
Action: This is an internal error. Contact Oracle Support Services.
PRCZ-01001: Password cannot be null
Cause: A null value was supplied as password parameter to this API.
PRCZ-01002: Local node name cannot be null or empty
Cause: An invalid value was supplied as local node name parameter to this API.
PRCZ-01003: Remote node name cannot be null
Cause: An invalid value was supplied as remote node names parameter to this API.
PRCZ-01004: User name "{0}" does not contain a domain name
Cause: User name that was supplied was not in DOMAINNAME\\USERNAME format.
Action: User name needs to be supplied in DOMAINNAME\\USERNAME format.
PRCZ-01005: Remote node name list contains null or empty node names
Cause: An invalid value was contained in remote node names list.
PRCZ-01006: Parameter {0} value is not valid
Cause: This is an internal error. The value for the specified parameter is null or empty string.
Action: Contact Oracle Support Services.
PRCZ-01007: Unable to determine if user "{0}" has Windows administrator authority.
Cause: An attempt to determine if user specified has Windows administrator authority failed.
Action: Examine the accompanying error messages for details.
PRCZ-01008: Unable to determine if user "{0}" has Windows administrator authority on nodes "{1}"
Cause: An attempt to determine if user specified has Windows administrator authority on specified nodes failed.
PRCZ-01010: Cannot create an instance of Windows Security Services on this platform
Cause: An attempt was made to create an instance of Winoows Security Services on a non-Microsoft Windows platforms.
PRCZ-01011: Unable to determine if user "{0}" is a Windows domain user
Cause: An attempt to determine if user specified is a Windows domain user failed.
PRCZ-01012: Unable to determine if user "{0}" is a valid Windows user
Cause: An attempt to determine if user name and password for user specified are valid failed.
PRCZ-01013: Unable to determine if user "{0}" is a Windows managed service account user
Cause: An attempt to determine if user name specified is a Windows managed service account user failed.
PRCZ-01014: Windows user "{0}" could not be created
Cause: An attempt to create the specified Windows user failed.
PRCZ-01015: Could not create Windows user "{0}" because user name is a domain user
Cause: The user name was in DOMAINNAME\\USERNAME format.
Action: If a domain user should own the Oracle home make sure that the domain administrator has created the user. If a new user should be created specify the user name without the domain name.
PRCZ-01016: Windows user "{0}" could not be deleted
Cause: An attempt to delete the specified Windows user failed.
PRCZ-01017: Could not delete Windows user "{0}" because user name is a domain user
Action: Only the domain administrator can delete a domain user. Specify a user name without the domain name and the user will be deleted from the local machine.
PRCZ-01018: Failed to set user "{0}" as Oracle home service user for home "{1}"
Cause: An attempt to set specified user as the Oracle home service user for specified home failed.
PRCZ-01019: Failed to set user "{0}" as Oracle home service user for home "{1}" on nodes "{2}"
Cause: An attempt to set specified user as the Oracle home service user for specified home on the specified nodes failed.
PRCZ-01020: Failed to get the Oracle home service user
Cause: An attempt to get the Oracle home service user for current Oracle home failed.
PRCZ-01021: Failed to get the Oracle home service user for Oracle home "{0}"
Cause: An attempt to get the Oracle home service user for Oracle home at the path specified failed.
PRCZ-01022: Failed to get the Oracle home service user for Oracle home "{0}" on nodes "{1}"
Cause: An attempt to get the Oracle home service user for Oracle home at the path specified on the nodes specified failed.
PRCZ-01023: The Oracle home path "{0}" is invalid
Cause: An invalid value was supplied as Oracle home path.
Action: The path of Oracle home must be between 0 and 260 characters long and the directory must exist. The path must not contain wild card characters.
PRCZ-01024: Failed to determine if the Oracle home service user for Oracle home "{0}" is a Windows managed service account user
Cause: An attempt to determine if the Oracle home service user for the Oracle home specified is a Windows managed service account user failed.
PRCZ-01025: Failed to determine if the Oracle home service user for Oracle home "{0}" is the built in LocalSystem account
Cause: An attempt to determine if the Oracle home service user for the Oracle home specified is the built in LocalSystem account failed.
PRCZ-01026: Failed to determine if the Oracle home service user for Oracle home "{0}" is the built in LocalService account
Cause: An attempt to determine if the Oracle home service user for the Oracle home specified is the built in LocalService account failed.
PRCZ-01027: Unable to determine if the Oracle home service user for Oracle home "{0}" is a Windows built in user or managed service account user
Cause: An attempt to determine if user specified is a Windows built in user or managed service account user failed.
PRCZ-01028: Unable to determine if the Oracle home service user for Oracle home "{0}" is a Windows built in user or managed service account user on nodes "{1}"
Cause: An attempt to determine if user specified is a Windows built in user or managed service account user on nodes specified failed.
PRCZ-01029: Failed to set the Oracle home type as "{0}" for Oracle home "{1}"
Cause: An attempt to set specified type as the Oracle home type for specified Oracle home failed.
PRCZ-01030: Failed to set the Oracle home type as "{0}" for home "{1}" on nodes "{2}"
Cause: An attempt to set specified type as the Oracle home type for specified home on the specified nodes failed.
PRCZ-01031: Failed to get the Oracle home type for Oracle home "{0}"
Cause: An attempt to get the Oracle home type for Oracle home at the path specified failed.
PRCZ-01032: Failed to get the Oracle home type for Oracle home "{0}" on nodes "{1}"
Cause: An attempt to get the Oracle home type for Oracle home at the path specified on the nodes specified failed.
PRCZ-01033: Failed to get the Oracle home service user on node "{0}"
Cause: An attempt to get the Oracle home service user for current Oracle home on the node specified failed.
PRCZ-01034: Failed to determine if Oracle home service user for Oracle home "{0}" is the built in LocalSystem account on node "{1}"
Cause: An attempt to determine if the Oracle home service user for the Oracle home specified on the nodes specified is the built in LocalSystem account failed.
PRCZ-01035: Failed to locate Oracle home
Cause: An error occurred while attempting to retrieve value of environment variable ORACLE_HOME.
Action: Set ORACLE_HOME environment variable to point to current Oracle home path.
PRCZ-01036: Failed to determine the operating system privileges granted to Windows user "{0}"
Cause: An attempt to determine the operating system privileges granted to Windows user specified failed.
PRCZ-01037: Failed to determine the operating system privileges granted to Windows user "{0}" on nodes "{1}"
Cause: An attempt to determine the operating system privileges granted to Windows user specified on nodes specified failed.
PRCZ-01038: Failed to grant Windows user "{0}" operating system privileges required for Oracle home type "{1}"
Cause: An attempt to grant the required operating system privileges for specified Oracle home type to specified Windows user failed.
PRCZ-01039: Failed to grant Windows user "{0}" operating system privileges required for Oracle home type "{1}" on nodes "{2}"
Cause: An attempt to grant the required operating system privileges for specified Oracle home type to specified Windows user on nodes specified failed.
PRCZ-01040: Failed to revoke operating system privileges from Windows user "{0}" granted for owning Oracle home type "{1}"
Cause: An attempt to revoke operating system privileges granted to specified Windows user for owning specified Oracle home type failed.
PRCZ-01041: Failed to revoke operating system privileges from Windows user "{0}" granted for Oracle home type "{1}" on nodes "{2}"
Cause: An attempt to revoke operating system privileges granted to specified Windows user for owning specified Oracle home type on nodes specified failed.
PRCZ-01042: Failed to add Windows access control list (ACL) entry for user "{0}" for path "{1}"
Cause: An attempt to add Windows access control list entry for user specified to the path specified failed.
PRCZ-01043: Failed to add Windows access control list (ACL) entry for user "{0}" for path "{1}" on nodes "{2}"
Cause: An attempt to add Windows access control list entry for user specified to the path specified failed on nodes specified.
PRCZ-01044: Failed to remove Windows access control list (ACL) entry for user "{0}" for path "{1}"
Cause: An attempt to remove Windows access control list entry for user specified from the path specified failed.
PRCZ-01045: Failed to remove Windows access control list (ACL) entry for user "{0}" for path "{1}" on nodes "{2}"
Cause: An attempt to remove Windows access control list entry for user specified from the path specified failed on nodes specified.
PRCZ-01046: Failed to verify if Windows access control list (ACL) entry exists for user "{0}" for path "{1}"
Cause: An attempt to verify if Windows access control list entry exists for user specified for the path specified failed.
PRCZ-01047: Failed to verify Windows access control list (ACL) entry for user "{0}" for path "{1}" on nodes "{2}"
Cause: An attempt to verify if Windows access control list entry exists for user specified for the path specified failed on nodes specified.
PRCZ-01048: Windows user "{0}" does not have privileges "{1}" required for owning Oracle home "{2}"
Cause: An attempt to verify if the specified Windows user has all privileges required for owning Oracle home type specified found that user did not have some of the privileges required.
Action: Grant the privileges specified to the user.
PRCZ-01049: Windows user "{0}" does not have privileges "{1}" required for owning Oracle home "{2}" on node "{3}"
Cause: An attempt to verify if the specified Windows user has all privileges required for owning Oracle home type specified on node specified found that user did not have some of the privileges required.
PRCZ-01050: The path "{0}" specified as Windows service executable file for Windows service "{1}" is invalid
Cause: An invalid value was supplied as Windows service executable file for the specified Windows service.
Action: Specify the full file system path to a valid executable file, without wild card characters and not exceeding 260 characters long.
PRCZ-01051: Failed to update executable file to "{1}" for the Windows service "{0}"
Cause: An attempt to update the file from which specified Windows service runs to specified file failed.
PRCZ-01052: Failed to update executable file to "{1}" for the Windows service "{0}" on nodes "{2}"
Cause: An attempt to update the file from which specified Windows service runs to specified file on the nodes specified failed.
PRCZ-01053: Failed to update the Windows service "{0}" user password for Windows user "{1}"
Cause: An attempt to update the password for specified Windows user in the specified Windows service failed.
PRCZ-01054: Failed to update the Windows service "{0}" user password for Windows user "{1}" on nodes "{2}"
Cause: An attempt to update the password for specified Windows user in the specified Windows service on the nodes specified failed.
PRCZ-01055: Failed to update executable file to "{2}" and username and password for Windows user "{1}" for the Windows service "{0}"
Cause: An attempt to update the executable file, username and password to specified values for specified Windows service failed.
PRCZ-01056: Failed to update executable file to "{2}" and username and password for Windows user "{1}" for the Windows service "{0}" on nodes "{3}"
Cause: An attempt to update the executable file, username and password to specified values for specified Windows service on specified nodes failed.
PRCZ-01057: Invalid value {0} specified for Windows service access type parameter while creating the service "{1}"
Cause: An invalid value was supplied for Windows service access type parameter while creating specified Windows service.
PRCZ-01058: Service dependency list contains null or empty Windows service names while creating Windows service "{0}"
Cause: An invalid value was contained in service dependency list supplied while creating the specified Windows service.
PRCZ-01059: Failed to create Windows service "{0}"
Cause: An attempt to create specified Windows service failed.
PRCZ-01060: Failed to create Windows service "{0}" on nodes "{1}"
Cause: An attempt to create specified Windows service on nodes specified failed.
PRCZ-01061: Failed to delete Windows service "{0}"
Cause: An attempt to delete specified Windows service failed.
PRCZ-01062: Failed to delete Windows service "{0}" on nodes "{1}"
Cause: An attempt to delete specified Windows service on nodes specified failed.
PRCZ-01063: Failed to determine if the Windows service "{0}" will run as the built in LocalSystem account
Cause: An attempt to determine if the specified Windows service will run as the built in LocalSystem account failed.
PRCZ-01064: Failed to determine if the Windows service "{0}" will run as the built in LocalSystem account on nodes "{1}"
Cause: An attempt to determine if the specified Windows service on the nodes specified will run as the built in LocalSystem account failed.
PRCZ-01065: Failed to get the user account for the Windows service "{0}"
Cause: An attempt to get the user account the specified Windows service runs as failed.
PRCZ-01066: Failed to get the user account for the Windows service "{0}" on nodes "{1}"
Cause: An attempt to get the user account the specified Windows service runs as on specified nodes failed.
PRCZ-01067: Failed to retrieve a list of all Windows services that run as Windows user "{0}" from Oracle home "{1}"
Cause: An attempt to get a list of all Windows services that run as specified Windows user from specified Oracle home failed.
PRCZ-01068: Failed to obtain a list of all Windows services that run as Windows user "{0}" from Oracle home "{1}" on nodes "{2}"
Cause: An attempt to get a list of all Windows services that run as specified Windows user from specified Oracle home on nodes specified failed.
PRCZ-01069: Failed to update Windows user's password of all Windows services that run as Windows user "{0}" from Oracle home "{1}"
Cause: An attempt to update Windows user's password of all Windows services that run as specified Windows user from specified Oracle home failed.
PRCZ-01070: Failed to update Windows user's password of all Windows services that run as Windows user "{0}" from Oracle home "{1}" on nodes "{2}"
Cause: An attempt to update Windows user's password of all Windows services that run as specified Windows user from specified Oracle home on nodes specified failed.
PRCZ-01071: Failed to update Windows service "{0}" username to "{1}" because it differs from Oracle home user "{2}"
Cause: An attempt to update the Windows service execution user account failed because the specified user is not the Oracle home service user.
Action: All services from a home will run as the Oracle home service user.
PRCZ-01072: Failed to obtain a list of all Windows services that run as Windows user "{0}"
Cause: An attempt to obtain a list of all Windows services that run as specified Windows user failed.
PRCZ-01073: Failed to obtain a list of all Windows services that run as Windows user "{0}" on nodes "{1}"
Cause: An attempt to get a list of all Windows services that run as specified Windows user on nodes specified failed.
PRCZ-01074: Failed to update Windows user's password for all Windows services that run as Windows user "{0}"
Cause: An attempt to update Windows user's password for all Windows services that run as specified Windows user from specified Oracle home failed.
PRCZ-01075: Failed to update Windows user's password for all Windows services that run as Windows user "{0}" on nodes "{1}"
Cause: An attempt to update Windows user's password for all Windows services that run as specified Windows user from specified Oracle home on nodes specified failed.
PRCZ-01076: Windows group "{0}" could not be created
Cause: An attempt to create the specified Windows group failed.
PRCZ-01077: Windows user "{0}" could not be created on nodes "{1}"
Cause: An attempt to create the specified Windows group on the nodes specified failed.
PRCZ-01078: Windows group "{0}" could not be removed
Cause: An attempt to remove the specified Windows group failed.
PRCZ-01079: Windows group "{0}" could not be removed on nodes "{1}"
Cause: An attempt to remove the specified Windows group on the nodes specified failed.
PRCZ-01080: Unable to determine if Windows group "{0}" exists
Cause: An attempt to determine if the specified Windows group exists failed.
PRCZ-01081: Unable to determine if Windows group "{0}" exists on nodes "{1}"
Cause: An attempt to determine if the specified Windows group exists on the nodes specified failed.
PRCZ-01082: Failed to add Windows user or Windows group "{1}" to Windows group "{0}"
Cause: An attempt to add the specified Windows user or Windows group as member of the specified Windows group failed.
PRCZ-01083: Failed to add Windows user or Windows group "{1}" to Windows group "{0}" on nodes "{2}"
Cause: An attempt to add the specified Windows user or Windows group as a member of the specified Windows group on the nodes specified failed.
PRCZ-01084: Failed to remove Windows user or Windows group "{1}" from Windows group "{0}"
Cause: An attempt to remove the specified Windows user or Windows group from the specified Windows group failed.
PRCZ-01085: Failed to remove Windows user or Windows group "{1}" from Windows group "{0}" on nodes "{2}"
Cause: An attempt to remove the specified Windows user or Windows group from the specified Windows group on the nodes specified failed.
PRCZ-01086: Unable to determine if Windows user or Windows group "{1}" is a member of Windows group "{0}"
Cause: An attempt to determine if the specified Windows user or Windows group is a member of the specified Windows group failed.
PRCZ-01087: Unable to determine if Windows user or Windows group "{1}" is a member of Windows group "{0}" on nodes "{1}"
Cause: An attempt to determine if the specified Windows user or Windows group is a member of the specified Windows group on the nodes specified failed.
PRCZ-01088: The Windows group name "{0}" is invalid
Cause: An invalid value was supplied as Windows group name.
Action: The Windows group name must be between 0 and 256 characters long.
PRCZ-01089: The description text "{0}" for Windows group "{1}" is invalid
Cause: An invalid value was supplied as description text for specified Windows group name.
Action: The description text supplied must be between 0 and 256 characters long.
PRCZ-01090: {0} Element in remote node name list contains null or empty node name
PRCZ-01091: Failed to verify that user name "{0}" is a valid Windows user
Cause: An attempt to verify if the specified user name is a valid Windows user failed.
PRCZ-01092: The user name "{0}" does not exist as a Windows user
Cause: The specified user name was not a valid Windows user name.
Action: Specify a valid Windows user name.
PRCZ-01093: Failed to convert Windows security identifier "{0}" to a Windows user name
Cause: An attempt to convert the specified Windows security identifier to a Windows user name failed.
PRCZ-01094: Failed to add a Windows access control entry for user "{0}" to Windows access control list for path "{1}"
Cause: An attempt to add Windows access control list entry the specified user and path failed.
PRCZ-01095: Failed to add a Windows access control entry for user "{0}" to Windows access control list for path "{1}" on nodes "{2}"
Cause: An attempt to add Windows access control list entry for the specified user and path failed on nodes specified.
PRCZ-01096: Unable to determine if the password meets the requirements of the password policy
Cause: An attempt to determine if password meets the policy has failed.
PRCZ-01097: Unable to determine if a local account for user "{0}" exists on node "{1}"
Cause: An attempt to determine if the indicated local user account exists on the identified node has failed.
PRCZ-01098: Unable to determine the Windows domain name for user "{0}"
Cause: An attempt to determine the Windows domain name of indicated user account has failed.
PRCZ-01099: failed to migrate database services from Windows group "ORA_ASMDBA" to Windows group "ORA_ASMADMIN"
Cause: During the Oracle Clusterware upgrade, an attempt to migrate database services from Windows group 'ORA_ASMDBA' to Windows group 'ORA_ASMADMIN' failed.
PRCZ-01100: failed to migrate database services from Windows group "ORA_ASMADMIN" to Windows group "ORA_ASMDBA"
Cause: During the Oracle Clusterware downgrade, an attempt to migrate database services from Windows group 'ORA_ASMADMIN' to Windows group 'ORA_ASMDBA' failed.
PRCZ-02000: Failed to verify the password for user "{0}" on nodes "{1}"
Cause: An attempt to verify the specified user's password on nodes specified failed.
Action: Make sure that the password specified is correct and is same across all nodes of the cluster. Examine the accompanying error messages for details.
PRCZ-02001: File "{0}" was not found on nodes "{1}"
Cause: An attempt to verify that the specified file exists failed on the nodes specified.
Action: Make sure that the path to the specified file exists on all nodes. Make sure that the currently logged in user has read and execute permission on the file specified on nodes specified. Also look at the accompanying error messages for details.
PRCZ-02002: Failed to execute command "{0}" using 'sudo' from path "{1}" as user "{2}" on nodes "{3}"
Cause: An attempt to run the specified command as using 'sudo' from directory specified using the specified username and password on specfied nodes failed.
Action: Make sure that the path specified for the sudo command exists on all nodes. Make sure that the specified user has permission to run the sudo command on all nodes. Make sure that the command specified exists on all nodes. Make sure that the correct password was specified for the specified user. Make sure that the specified user has sudo privileges granted on all nodes. Also look at the accompanying error messages for details.
PRCZ-02003: Failed to verify the password for user "{0}"
Cause: An attempt to verify specified user's password failed.
PRCZ-02004: File "{0}" was not found
Cause: An attempt to verify that the specified file exists failed.
Action: Make sure that the path to the specified file exists. Make sure that the currently logged in user has read and execute permissions on the file specified. Also look at the accompanying error messages for details.
PRCZ-02005: Failed to execute command "{0}" using 'sudo' from path "{1}" as user "{2}"
Cause: An attempt to run the specified command as using 'sudo' from the path specified using the specified username failed.
Action: Make sure that the path specified for the sudo command exists. Make sure that the specified user has permission to run the sudo command. Make sure that the command specified exists. Make sure that the correct password was specified for the specified user. Also look at the accompanying error messages for details.
PRCZ-02006: Unable to establish SSH connection to node "{0}" to execute command "{1}"
Cause: An attempt to connect to specified node to execute specified command using SSH failed.
Action: Make sure that the specified node is reachable. Make sure that SSH daemon on the specified node is alive. Also look at the accompanying error messages for details.
PRCZ-02007: Failed to execute the command "{0}"
Cause: An attempt to execute the specified command failed.
Action: Make sure that the path to the specified command exists. Make sure that the currently logged in user has read and execute permissions on the file specified on nodes specified. Also look at the accompanying error messages for details.
PRCZ-02008: Failed to execute the command "{0}" on nodes "{1}"
Cause: An attempt to execute the specified command failed on the nodes specified.
Action: Make sure that the path to the specified command exists on all nodes. Make sure that the currently logged in user has read and execute permissions on the file specified on nodes specified. Also look at the accompanying error messages for details.
PRCZ-02009: Failed to execute command "{0}" as root within {1} seconds on nodes "{2}"
Cause: An attempt to run the specified command within the specified time on the nodes specified failed.
Action: Make sure that the specified command exists on all nodes. Make sure that the specified command has execute permission on all nodes. Make sure that the root user password specified is correct. Also look at the accompanying error messages for details.
PRCZ-02010: Failed to execute command "{0}" using 'sudo' from location "{1}" as user "{2}" within {3} seconds on nodes "{4}"
Cause: An attempt to run the specified command using 'sudo' from location specified as specified user within the specified time on the nodes specified failed.
Action: Make sure that the specified command exists on all nodes. Make sure that the specified command has execute permission on all nodes. Make sure that the location specified for sudo is correct. Make sure that the user specified has sudo privileges. Make sure that the correct password was specified for the user. Also look at the accompanying error messages for details.
PRCZ-02011: Failed to execute command "{0}" using 'pbrun' from location "{1}" as user "{2}" within {3} seconds on nodes "{4}"
Cause: An attempt to run the specified command using 'pbrun' from location specified as specified user within the specified time on the nodes specified failed.
Action: Make sure that the specified command exists on all nodes. Make sure that the specified command has execute permission on all nodes. Make sure that the location specified for pbrun is correct. Make sure that the user specified has pbrun privileges. Make sure that the correct password was specified for the user. Also look at the accompanying error messages for details.
PRCZ-02014: Failed to execute command "{0}" on nodes "{1}"
Cause: An attempt to run the specified command on the nodes specified failed.
Action: Examine the accompanying error messages for details. Ensure that the command exists and is executable on the indicated nodes.
PRCZ-02015: Upgrade pending on following active nodes "{0}"
Cause: An attempt to forcibly complete the upgrade was rejected because some nodes are active and have not yet been upgraded.
Action: Upgrade the active nodes.
PRCZ-02016: could not navigate to domain {0}, CLS credentials return string: {1}, error details: {2}
Cause: An error was encountered when looking for the specified domain of a credentials set.
Action: Ensure that an existing domain is being specified.
PRCZ-02017: could not obtain root credentials domain, CLS credentials return string: {0}, error details: {1}
Cause: An error was encountered when initializing credentials root domain. The root domain is part of the OCR within which all credentials domains are stored. A domain is part of the OCR tree used to store credentials.
Action: Check the included error details.
PRCZ-02018: deletion of credentials set failed, CLS credentials return string: {0}, error details: {1}
Cause: An error was encountered when deleting a credentials set.
PRCZ-02019: Credential set was not found in domain {0}.\n Return string: {1}, error details: {2}
Cause: Could not find the credentials set within the specified domain.
Action: Ensure that an existing domain is being specified, or insert appropriate credentials into the specified domain.
PRCZ-02020: the creation of domain {0} failed, CLS credentials return string: {1}, error details: {2}
Cause: An error occurred while creating the credentials domain.
PRCZ-02021: the creation of the credentials set failed, CLS credentials return string: {0}, error details: {1}
Cause: An error occurred while creating the credentials set.
PRCZ-02022: could not import wallet in file {0}, CLS credentials return string: {1}, error details: {2}
Cause: An error occurred while importing the wallet. The wallet must be stored in an auto-login wallet file.
Action: Check the wallet specified exists and that it is an auto-login wallet file with read permission on the file system.
PRCZ-02023: initialization of OCR context failed, error details: {0}
Cause: An error occurred when initializing the OCR context
PRCZ-02024: deletion of credentials set member in domain {0} failed, CLS credentials return string: {1}, error details: {2}
Cause: An error occurred while deleting a credentials set member.
Action: Ensure the domain being specified exists and that the credentials set member was previously imported into the OCR.
PRCZ-02025: The 'sudo' credentials cache could not be invalidated using the command "{0}".
Cause: An attempt to invalidate the 'sudo' credentials cache using the specified command failed.
Action: Make sure that the path to the specified command exists. Make sure that the user currently logged in has read and execute permissions on the file specified. Also, look at the accompanying error messages for details.
PRCZ-02026: The 'sudo' credentials cache could not be invalidated using the command "{0}" on nodes "{1}"
Cause: An attempt to invalidate the 'sudo' credentials cache using the specified command failed on the nodes specified.
Action: Make sure that the path to the specified command exists. Make sure that the currently logged in user has read and execute permissions on the file specified on the nodes specified. Also, look at the accompanying error messages for details.
PRCZ-02027: failed to get the connection information
Cause: An error occurred while retrieving the connection information.
PRCZ-02028: There is no connection information.
Cause: An error occurred while retrieving the connection information because the connection information does not exist.
Action: Use 'crsctl check crs' to make sure that the CRS stack is up; use the command 'srvctl status asm' to make sure that the ASM resource is running.
PRCZ-02029: failed to get the connection information because the connection information fetch would exceed buffer
Cause: An internal error occurred.
PRCZ-02030: unable to determine the existence of operating system user account "{0}"
Cause: An attempt to determine existence of the indicated operating system user account failed.
PRCZ-02031: unable to determine if operating system user account "{0}" exist on nodes "{1}"
Cause: An attempt to determine if the indicated operating system user account exist on the identified nodes failed.
PRCZ-02032: The deletion of credentials domain {0} failed. Error details:\n{1}
Cause: An error occurred while deleting the credentials domain.
Action: Respond based on the accompanying messages.
PRCZ-02033: Failed to set attributes of credentials domain {0}. Error details:\n{1}
Cause: An error occurred while setting attributes of the credentials domain.
PRCZ-02034: Failed to get attributes of credentials domain {0}. Error details:\n{1}
Cause: An error occurred while getting attributes of the credentials domain.
PRCZ-02035: Failed to set user name and password credentials for user {0}. Error details:\n{1}
Cause: An error occurred while setting user name and password credentials.
PRCZ-02036: Failed to import credentials from wallet path {0}. Error details:\n{1}
Cause: An error occurred while importing credentials from the specified wallet path.
PRCZ-02037: Failed to set user {0} as the owner of credentials domain {1}. Error details:\n{2}
Cause: An error occurred while setting the specified user as the owner of the credentials domain.
PRCZ-02038: Failed to find credentials domain {0} under parent domain {1}. Error details:\n{2}
Cause: The specified domain did not exist under the specified parent domain.
PRCZ-02039: Credentials domain {0} already exists under parent domain {1} when the domain is not expected to exist. Error details:\n{2}
Cause: The specified domain was already in existence under the specified parent domain.
Action: Ensure that a nonexisting domain is being specified.
PRCZ-02040: failed to retrieve Oracle VM Manager information because Oracle VM Manager is not configured
Cause: An attempt to retrieve Oracle VM Manager information failed because it was not configured.
Action: Configure Oracle VM Manager in the cluster.
PRCZ-02041: failed to remove Oracle VM Manager because Oracle VM Manager is not configured
Cause: An attempt to remove Oracle VM Manager failed because it was not configured.
PRCZ-02042: Failed to remove Oracle VM Manager because one or more VM resources is configured. Names of the configured VM resources: {0}
Cause: An attempt to remove Oracle VM Manager failed because one or more VM resources was still configured.
Action: Ensure that all VM resources are removed before issuing this command.
PRCZ-02043: Failed to find credentials domain {0} under the root domain. Error details:\n{1}
Cause: The specified domain did not exist under the root domain.
PRCZ-02044: failed to create Oracle VM Manager because a credentials error occurred
Cause: An attempt to create Oracle VM Manager failed because an error related to the credentials occurred.
PRCZ-02045: failed to create Oracle VM Manager because the Grid Infrastructure user could not be identified
Cause: An attempt to create Oracle VM Manager failed because an error occurred while retrieving the Grid Infrastructure user.
PRCZ-02046: failed to modify Oracle VM Manager information because a credentials error occurred
Cause: An attempt to modify Oracle VM Manager information failed because an error related to the credentials occurred.
PRCZ-02047: failed to modify Oracle VM Manager because the Grid Infrastructure user could not be identified
Cause: An attempt to modify Oracle VM Manager failed because an error occurred while retrieving the Grid Infrastructure user.
PRCZ-02048: failed to retrieve Oracle VM Manager information because a credentials error occurred
Cause: An attempt to retrieve Oracle VM Manager failed because an error related to the credentials occurred.
PRCZ-02049: failed to remove Oracle VM Manager because a credentials error occurred
Cause: An attempt to remove Oracle VM Manager failed because an error related to the credentials occurred.
PRCZ-02050: failed to remove Oracle VM Manager because the details on VM resources could not be retrieved
Cause: An attempt to remove Oracle VM Manager failed because an error occurred while retrieving the details on the configured VM resources.
PRCZ-02051: failed to import credentials because a wallet did not exist at the specified path {0}
Cause: An error occurred while importing credentials because the specified path did not contain a wallet.
Action: Retry the operation making sure to specify the path of an existing wallet file.
