PRGH-01001: Failed to get the name of the local node
Cause:
An attempt to retrieve local host name failed.
Action:
Examine the accompanying error messages.
PRGH-01002: Failed to copy files from {0} to {1}
Cause:
An attempt to copy the files failed.
Action:
PRGH-01003: Provisioning of Oracle home at location {0} failed
Cause:
One or more steps in provisioning the Oracle home failed.
Action:
PRGH-01004: Cloning operation for the Oracle home at location {0} failed
Cause:
An attempt to clone an Oracle Database home directory created from a Rapid Home Provisioning image failed.
Action:
PRGH-01005: Creation of database {0} at Oracle home location {1} failed
Cause:
An attempt to create database failed.
Action:
PRGH-01006: Changing the ownership for the software home at location {0} failed
Cause:
An attempt to change the ownership of software home failed.
Action:
Check the accompanying error messages.
PRGH-01007: Changing the group ownership for the software home at location {0} failed
Cause:
An attempt to change the group of software home failed.
Action:
PRGH-01008: Deletion of database {0} at Oracle home location {1} failed
Cause:
An attempt to delete the database failed.
Action:
Correct the problem indicated by the accompanying messages and retry the failed command
PRGH-01009: Deletion of Oracle home location {0} from inventory failed
Cause:
An attempt to detach the Oracle home failed
Action:
PRGH-01010: Removal of Oracle home {0} failed
Cause:
An attempt to remove the Oracle home failed
Action:
Correct the problem indicated by the accompanying messages and retry the failed command.
PRGH-01011: Move of database {0} to Oracle home location {1} failed
Cause:
An attempt to move the database to the new Oracle home failed.
Action:
PRGH-01012: Failed to execute sqlpatch for database {0} from Oracle home {1} on node {2}
Cause:
An attempt to execute sqlpatch on the database failed.
Action:
PRGH-01013: The destination working copy at {0} on cluster {1} has the following Oracle patches installed: {2}. Execute the post-patch SQL scripts for these databases: {3}.
Cause:
The post-patch SQL scripts were not executed because auto execution of the SQL script was not supported for this database version. Auto execution of the SQL script is not supported for Oracle Database versions prior to 12c.
Action:
Execute the 'postinstall.sql' script for these patches if they are located under the SQL patch directory in the Oracle home. Also refer to the patch documentation for these patches and perform any applicable post-patch steps manually.
PRGH-01014: Creation of database {0} at Oracle home location {1} failed becuase the nodes {2} specified in "-nodes" option are not active
Cause:
An attempt to create a database was rejected because the nodes specified in the "-nodes" option were not active.
Action:
Specify nodes in the "-nodes" option that are active.
PRGH-01015: Database {0} does not exist
Cause:
An attempt to delete a database failed because the specified database did not exist.
Action:
Specify a database name of a database that exists within the working copy.
PRGH-01017: failed to retrieve the platform information from the specified Oracle home path "{0}"
Cause:
An error occurred while attempting to retrieve the platform information.
Action:
Examine the accompanying errors for more information.
PRGH-01018: The creation of database "{0}" at Oracle home location "{1}" failed because the patches for bugs {2} have not been applied.
Cause:
An attempt to create a database was rejected because the required patches were not applied to the Oracle home.
Action:
Apply the required patches and retry the command.
