Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
117 PRKP-01000 to PRKP-01088
PRKP-01000: Cannot retrive configuration for cluster database {0}
Cause: The cluster database configuration could not be retrieved from the repository. This could occur either because the database was never registered, or because the repository itself had not been created.
Action: Check if the database has been configured by printing a list of all cluster databases using 'srvctl config'. If the repostitory has not been created, use 'srvconfig -init' to create it.
PRKP-01001: Error starting database instance {0} on node {1}
Cause: The instance could not be started using the SQL*Plus startup command.
Action: Try starting the named instance manually using SQL*Plus to see why it failed and examine the database instance alert log.
PRKP-01002: Error stopping database instance {0} on node {1}
Cause: The SQL*Plus shutdown command returned an error while stopping the instance.
Action: Try stopping the named instance manually using SQL*Plus to see why it failed and examine the database instance alert log.
PRKP-01003: Startup operation partially failed
Cause: Some components of the cluster database could not be started.
Action: Check the accompanying error messages for details.
PRKP-01004: Shutdown operation partially failed
Cause: Some components of the cluster database reported errors while being stopped.
PRKP-01005: Failed to start up cluster database {0}
Cause: The cluster database could not be started.
PRKP-01006: Failed to shut down cluster database {0}
Cause: The cluster database reported errors while being shut down.
PRKP-01007: Failed to start all the listeners associated with all the instances of cluster database {0}
Cause: Internal error.
Action: Contact your customer support representative.
PRKP-01008: Failed to start listeners associated with instance {0} on node {1}
PRKP-01009: Failed to stop all the listeners associated with all the instances of cluster database {0}
Cause: Either the listener name associated with an instance could not be determined, or 'lsnrctl stop' failed for a listener.
Action: Verify that listener.ora contains a SID_LIST entry for each instance of the named database, and that the 'lsnrctl stop' command succeeds for those listeners.
PRKP-01010: Failed to stop all the listeners associated with instance {0} on node {1}
PRKP-01011: Failed to get all the listeners associated with instance {0} on node {1}
Cause: The listener name associated with an instance could not be determined.
Action: Ensure that listener.ora contains a SID_LIST entry for the named instance.
PRKP-01012: Invalid environment variable {0} setting for cluster database {1}
Cause: The argument to the -t option was not of the form name=value or it contained special characters.
Action: Ensure that the -t option has an argument of the form name=value. Enclose the argument to the -t flag in quotes.
PRKP-01013: {0}: undefined environment variable for cluster database {1}
Cause: The named environment variable is not defined for the named cluster database
Action: Set a value for the variable with 'srvctl setenv'.
PRKP-01014: {0}: undefined environment variable for instance {1} of cluster database {2}
Cause: The named environment variable is not defined for the given instance
PRKP-01015: {0}: undefined environment variable
Action: Set a value for the named environment variable with 'srvctl setenv'.
PRKP-01084: Database "{0}" cannot have more than "{1}" services
Cause: Attempt to add a new service to database was rejected because database has already reached the maximum services limit.
Action: Retry after removing a service of this database via 'srvctl remove service' command, or contact Oracle Support Services.
PRKP-01088: Failed to retrieve configuration of cluster database {0}
Cause: Attempt to retrieve configuration of cluster database failed. This failure is most likely due to user incorrectly using a tool, such as SRVCTL, that is of different version than that of database's configuration.
Action: If error is due to user using SRVCTL that is of different version than than of the database's, then run SRVCTL tool from the ORACLE_HOME reported in the error message. Otherwise, contact Oracle support services.
