Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
118 PRKR-01001 to PRKR-01082
PRKR-01001: cluster database {0} does not exist
Cause: The cluster database was never registered in the repository.
Action: Check if the database has been configured by printing a list of all cluster databases using 'srvctl config'.
PRKR-01002: cluster database {0} already exists
Cause: An attempt was made to register a cluster database which already existed in the repository.
Action: Check if the database has already been configured by printing a list of all cluster databases using 'srvctl config'.
PRKR-01003: instance {0} does not exist
Cause: The named instance was never registered in the repository.
Action: Use 'srvctl config instance' to check if the instance is registered in the repository.
PRKR-01005: adding of cluster database {0} configuration failed, {1}
Cause: Internal error.
Action: Contact your customer support representative.
PRKR-01006: deleting of cluster database {0} configuration failed, {1}
Action: Contact Oracle Support Services.
PRKR-01007: getting of cluster database {0} configuration failed, {1}
PRKR-01008: adding of instance {0} on node {1} to cluster database {2} failed.
PRKR-01009: deleting of instance {0} from cluster database {1} failed, {2}
PRKR-01010: moving of instance {0} to node {1} of cluster database {2} failed.
PRKR-01011: renaming of instance {0} to instance {1} of cluster database {2} failed, {3}
PRKR-01012: error {0} while serializing configuration of cluster database {1}
PRKR-01013: error {0} while deserializing configuration of cluster database {1}
PRKR-01014: error {0} while serializing directory
PRKR-01015: error {0} while deserializing directory
PRKR-01016: reading of cluster database {0} configuration failed, {1}, {2}
PRKR-01017: writing of cluster database {0} configuration failed, {1}, {2}
PRKR-01018: reading of directory failed, {0}, {1}
PRKR-01019: writing of directory failed, {0}, {1}
PRKR-01020: reading of version information failed, {0}, {1}
PRKR-01021: writing of version information failed, {0}, {1}
PRKR-01022: Cluster registry {0} contains incompatible version, {1} != {2}
PRKR-01023: file {0} does not exist
Cause: The named file did not exist.
Action: Specify a file that exists.
PRKR-01024: file {0} does not have {1} permissions
Cause: The named file did not have the specified permission.
Action: Try changing the permission on the file to the specified permission.
PRKR-01025: file {0} does not contain property {1}
Cause: The file did not contain the specified property.
PRKR-01026: property {0} not set in file {1}
PRKR-01027: failed to retrieve list of cluster databases
PRKR-01028: Cluster registry {0} is invalid\n[HINT: initialize cluster registry by using "srvconfig" tool]
Cause: The management repository was never initialized.
Action: Use 'srvconfig -init' to initialize the repository.
PRKR-01039: invalid option {0} specified
Cause: The specified option was invalid.
Action: Check the command documentation or the inline help display for usage details.
PRKR-01040: missing file argument for {0} option
Cause: The specified option was invalid for srvconfig.
PRKR-01050: file {0} creation in {1} directory failed
Cause: Either the directory did not exist or it did not have the required permissions.
Action: Create the directory if it did not exist or change the permission of the directory.
PRKR-01051: file {0} does not contain an entry for dbname {1}
PRKR-01052: file name {0} is not of cluster database name.conf form
PRKR-01053: invalid range {0} specified in node_list = {1}
PRKR-01054: invalid parameter {0} specified in inst_oracle_sid = {1}
PRKR-01055: invalid extra arguments {0} specified to {1} option
Cause: Provided invalid arguments to srvconfig.
PRKR-01056: invalid registry entry {0} found; should be of form {1}
PRKR-01057: environment variable does not exist
Cause: Attempted to retrieve non existing environment variable.
Action: Set the environment variable.
PRKR-01078: Database {0} of version {1} cannot be administered using current version of srvctl. Instead run srvctl from {2}
Cause: An attempt was made to access configuration of database using srvctl that was of different version than that of the database.
Action: Perform the operation using srvctl from the ORACLE_HOME mentioned in the error message.
PRKR-01082: Failed to get OCR locations
Cause: An error occurred while attempting to retrieve the OCR locations, possibly due to missing or incorrrect OCR locations file, or incomplete OCR configuration, or due to missing or incorrect SRVM shared libraries.
Action: Verify that the Clusterware has been correctly installed and configured. Verify that the ocr.loc file is present and readable in the appropriate location for your platform.
