Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
131 RDJ-00001 to RDJ-00136
RDJ-00001: OK ADDRESS
Cause: The operation succeeded.
Action: No further action is necessary.
RDJ-00002: invalid operation:
Cause: The operation specified was incorrect.
Action: Specify a valid operation.
RDJ-00003: Error parsing "string"\nstring
Cause: An error occurred parsing an address.
Action: Correct the address using the other information in the error.
RDJ-00004: invalid trace level
Cause: The trace level specified was incorrect.
Action: Specify a valid trace level.
RDJ-00005: Operation: string failed. Error: string
Cause: An RD operation failed with the specified error.
Action: Re-try the operation with tracing enabled to to determine what happened.
RDJ-00006: invalid port number: number
Cause: The port number specified for a service is invalid.
Action: Specify a port number that is greater than zero.
RDJ-00008: invalid number specified:
Cause: The number specified contained non-numeric characters.
Action: Specify a number with only numeric characters.
RDJ-00009: invalid address format:
Cause: The format specified for an address was incorrect.
Action: Specify a valid format.
RDJ-00011: results processor may not be null
Cause: A null object was specified for the class that is to process the results of an operation.
Action: Specify a non-null object.
RDJ-00012: invalid instance uniqueness
Cause: The uniqueness value specified for an instance was not valid.
Action: Specify a valid uniqueness value.
RDJ-00013: Invalid service instance attribute
Cause: An attribute specified for a service instance was not valid.
Action: Specify an attribute in the correct format.
RDJ-00015: Invalid service instance tag: "string". Available tags:
Cause: The tag value specified for a service instance was incorrect.
Action: Specify a valid tag value.
RDJ-00017: invalid domain type: "string". Available domain types:
Cause: The type specified for a domain was not valid.
Action: Specify a valid domain type.
RDJ-00048: Unknown command: "string"
Cause: An invalid command was specified.
Action: Specify a valid command.
RDJ-00049: Unknown option: "string"
Cause: An invalid option was specified.
Action: Specify a valid option.
RDJ-00052: invalid flag value:
Cause: The value specified for a flag was not valid.
Action: Specify a valid flag value.
RDJ-00053: deletion of trace output file failed:
Cause: The tool attempted to remove a trace file so that it could create a new one. However, the attempt failed.
Action: Examine the accompanying exception for details about what happened.
RDJ-00054: deletion of error log file failed:
Cause: The tool attempted to remove an error log so that it could create a new one. However, the attempt failed.
RDJ-00055: trace file already exists:
Cause: The trace file specified already exists.
Action: Remove the file or specify a file which does not exist.
RDJ-00056: error log already exists:
Cause: The error log specified already exists.
RDJ-00057: trace file is a directory:
Cause: The trace file specified is actually a directory.
Action: Specify a file name.
RDJ-00058: error log is a directory:
Cause: The error log specified is actually a directory.
RDJ-00059: The trace file "string" cannot be created
Cause: The tool failed to create the trace file.
Action: Examine the accompanying exception for details about the error.
RDJ-00060: The error log "string" cannot be created. Check permissions on the parent directory:
Cause: The tool failed to create the error log.
RDJ-00061: The file stream cannot be created:
Cause: The tool failed to create the Java stream for a file.
RDJ-00062: The print stream cannot be created:
Cause: An error occurred when the tool tried to create a Java print stream for a file.
RDJ-00063: invalid time-to-live:
Cause: A non-numeric value was specified for the time to live.
Action: Specify a numeric value.
RDJ-00065: Option type must be greater than zero:
Cause: The type specified for an option was less than or equal to zero.
Action: Specify a type which is greater than zero.
RDJ-00134: unknown type:
Cause: The type specified is invalid.
Action: Specify a known type.
RDJ-00135: invalid stream type:
Cause: The stream type specified is invalid.
RDJ-00136: invalid argument count:
Cause: The number of arguments specified is invalid.
Action: Specify a valid number of arguments.
