Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
132 RMAN-00201 to RMAN-20514
RMAN-00201: Do you really want to execute the above repair (enter YES or NO)?
Cause: This is a user prompt.
Action: Answer the question to proceed.
RMAN-00202: Do you want to open the database (enter YES or NO)?
RMAN-00203: Do you want to open resetlogs the database (enter YES or NO)?
RMAN-00204: Do you really want to delete the above objects (enter YES or NO)?
RMAN-00205: Do you really want to drop all backups and the database (enter YES or NO)?
RMAN-00206: Do you really want to drop the database (enter YES or NO)?
RMAN-00207: Do you really want to unregister the database (enter YES or NO)?
RMAN-00208: Want to unregister the database with target db_unique_name (enter YES or NO)?
RMAN-00209: Do you really want to change the above failures (enter YES or NO)?
RMAN-00210: Do you really want to catalog the above files (enter YES or NO)?
RMAN-00211: Error occurred getting response - assuming NO response
Cause: An error occurred reading user response.
Action: No action is required, this is an informational message only.
RMAN-00212: "string" is an invalid response - please re-enter.
Cause: An incorrect response was entered.
Action: Enter a correct response.
RMAN-00550: parser package failed to load
Cause: lpmloadpkg() return an error indication.
Action: This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-00551: initialization of parser package failed
Cause: The parser package initialization routine returned an error.
RMAN-00552: syntax error in command line arguments
Cause: The arguments supplied to RMAN could not be parsed, or no arguments were supplied at all.
RMAN-00553: internal recovery manager package failed to load
RMAN-00554: initialization of internal recovery manager package failed
Cause: The internal package initialization routine returned an error.
RMAN-00555: target database connect string must be specified
Cause: The TARGET parameter was not specified.
Action: Supply the necessary parameter.
RMAN-00556: could not open CMDFILE "string"
Cause: An error occurred when trying to open the file.
Action: Check that the file name was specified correctly and that the file exists and that the user running RMAN has read permission for the file.
RMAN-00557: could not open MSGLOG "string"
Action: Check that the file name was specified correctly and that the file exists and that the user running RMAN has write permission for the file.
RMAN-00558: error encountered while parsing input commands
Cause: The parser detected a syntax error.
RMAN-00562: username too long
Cause: The specified user name exceeds the maximum allowable username length.
Action: Correct the username.
RMAN-00563: password too long
Cause: The specified password exceeds the maximum allowable password length.
Action: Correct the password.
RMAN-00564: host data too long
Cause: The SQL*NET host connect string exceeds the maximum allowable length.
Action: Correct the host string.
RMAN-00565: unable to read input file
Cause: An error occurred while trying to read from STDIN or from the CMDFILE.
Action: Ensure that the cmdfile is readable. The cmdfile must be a text file with 1 line per record.
RMAN-00566: could not open TRACE "string"
Action: Check that the file name was specified correctly and that the user running RMAN has write permission for the file.
RMAN-00567: Recovery Manager could not print some error messages\n
Cause: An error occurred while trying to print the error message stack.
Action: If the associated error message indicates a condition that can be corrected, do so, otherwise contact Oracle.
RMAN-00568: user interrupt received
Cause: The user typed ^C or ATTN.
Action: No action is required.
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
Cause: This message precedes an error message stack.
Action: The errors are printed in last-in first-out order. To interpret them correctly, read from the bottom to the top.
RMAN-00570: **end-of-file**
Cause: The end of an inline cmdfile was reached. This is just an informational message.
RMAN-00571: ===========================================================
Cause: Displayed to highlight the error message stack.
RMAN-00572: waiting for DBMS_PIPE input
Cause: This message is used only when the PIPE option was specified.
Action: enqueue some RMAN input into the pipe
RMAN-00573: DBMS_PIPE.NEXT_ITEM_TIME returned unknown type code: number
Cause: This is an internal error.
Action: contact Oracle Support Services.
RMAN-00574: rman aborting due to errors reading/writing DBMS_PIPE
Cause: RMAN was run with input/output being sent to DBMS_PIPE. An error was encountered while reading from or writing to the pipe. This error should be preceded by information describing the error.
Action: RMAN terminates. Refer to the cause/action for the preceding errors.
RMAN-00575: timeout while trying to write to DBMS_PIPE
Cause: RMAN was running in DBMS_PIPE mode. A timeout occurred while calling DBMS_PIPE.SEND_MESSAGE. This occurs when the pipe is full and no process has dequeued any of the messages. This is usually caused by death of the process that was talking to rman.
Action: RMAN will abort.
RMAN-00576: PIPE cannot be used with CMDFILE
Cause: The PIPE and CMDFILE options cannot be used together. When using the PIPE option, RMAN must obtain its input from the input pipe.
Action: Remove either the PIPE or CMDFILE option.
RMAN-00577: PIPE requires that TARGET be specified on the command line
Cause: The PIPE option obtains its input from, and writes its output to, an Oracle database pipe in the target database. Therefore, the target database connection must be specified on the command line, so that RMAN can connect to the target database to receive its input from the pipe.
Action: Specify the TARGET option on the RMAN command line.
RMAN-00578: pipe string is not private and owned by SYS
Cause: The pipe that RMAN needs to use for its input or output is either a public pipe or a private pipe that is not owned by SYS. This is a potential security problem, because it allows a non-SYS user to issue commands to RMAN or to retrieve the RMAN output.
Action: If you are attempting to put data on the RMAN input pipe prior to starting RMAN, so RMAN will process the data on the pipe as soon as it starts, you must be connected as SYS and you must first use the DBMS_PIPE.CREATE_PIPE function to explicitly create the pipe as a private pipe.
RMAN-00579: SCRIPT cannot be used with CMDFILE
Cause: The SCRIPT and CMDFILE options cannot be used together. When using the SCRIPT option, RMAN executes only the specified script.
Action: Remove either the SCRIPT or CMDFILE option.
RMAN-00600: internal error, arguments [string] [string] [string] [string] [string]
Cause: An internal error in recovery manager occurred.
Action: Contact Oracle Support Services.
RMAN-00601: fatal error in recovery manager
Cause: A fatal error has occurred.
RMAN-00700: SCRIPT requires that TARGET be specified on the command line
Cause: A SCRIPT option was included on the RMAN command line without a specified TARGET database.
RMAN-00701: SCRIPT requires that CATALOG be specified on the command line
Cause: A SCRIPT option was included on the RMAN command line without a specified CATALOG recovery catalog.
Action: Specify the CATALOG option on the RMAN command line.
RMAN-00702: The command has no syntax errors
Cause: This is an informational message only.
RMAN-00703: The cmdfile has no syntax errors
RMAN-01006: error signaled during parse
Cause: An error was signaled during parsing.
RMAN-01007: at line number column number file: string
Cause: This is an informational message indicating the line and column where a syntax error was detected.
RMAN-01008: the bad identifier was: string
Cause: This is an informational message indicating the identifier token that caused a syntax error.
RMAN-01009: syntax error: found "string": expecting one of: "string"
Cause: A syntax error was signaled during parsing.
Action: Correct the input.
RMAN-02000: wrong message file version (msg number not found)
Cause: The rmanxx.msb file is not the correct version.
Action: Check that the installation was done correctly. The RMAN binary (executable, load module, whatever it is called on your O/S) and the rmanxx.msb file must be from the same version, release, and patch level.
RMAN-02001: unrecognized punctuation symbol "string"
Cause: An illegal punctuation character was encountered.
Action: Remove the illegal character.
RMAN-02002: unexpected end of input file reached
Cause: This is probably caused by failure to supply the closing quote for a quoted string.
RMAN-02003: unrecognized character: string
Cause: An input character that is neither an alpha, digit, or punctuation was encountered.
Action: Remove the character.
RMAN-02004: quoted string too big
Cause: A quoted string longer than 2000 bytes was encountered.
Action: This may be caused by a missing close quote. If so, add the missing quote, otherwise shorten the string.
RMAN-02005: token too big
Cause: A token longer than 1000 bytes was encountered
Action: Tokens must be separated by whitespace or punctuation. Either add the missing whitespace or punctuation, or shorten the token.
RMAN-02006: script line too long
Cause: a line longer than 500 bytes was encountered
Action: break the line up into shorter lines
RMAN-02007: Integer value overflow
Cause: Parser failed to convert input string to integer
Action: Acceptable values for integer are from 0 to 2147483648. Retry command using valid integer value.
RMAN-02008: no value exists for variable "string"
Cause: The RMAN variable specified was either undefined or null
Action: Verify that a proper value has been given to that variable.
RMAN-02009: unexpected end of command file reached
Cause: This is probably caused by failure to supply the closing brace for a stored script in a command file.
RMAN-03000: recovery manager compiler component initialization failed
Cause: This message should be accompanied by other error message(s) indicating the cause of the error.
Action: Check the accompanying errors.
RMAN-03001: recovery manager command sequencer component initialization failed
RMAN-03002: failure of string command at string
RMAN-03003: command not implemented yet: string
Cause: The command is not implemented in the current release.
Action: Avoid using the command.
RMAN-03004: fatal error during execution of command
RMAN-03008: error while performing automatic resync of recovery catalog
RMAN-03009: failure of string command on string channel at string
RMAN-03010: fatal error during library cache pre-loading
RMAN-03011: Recovery Managerstring
Cause: This is the RMAN banner
RMAN-03012: fatal error during compilation of command
Cause: A fatal error occurred during compilation of a command.
RMAN-03013: Copyright (c) 1995, 2003, Oracle Corporation. All rights reserved.
Cause: This is the copyright banner
RMAN-03014: implicit resync of recovery catalog failed
Cause: This message is accompanied by other errors explaining the cause of the failure.
RMAN-03015: error occurred in stored script string
RMAN-03017: recursion detected in stored script string
Cause: A stored script is calling itself or another script which calls itself.
Action: Remove the recursion.
RMAN-03018: asynchronous RPCs are working correctly
RMAN-03019: asynchronous RPCs are NOT working
Cause: The RPCTEST command has determined that RPCs are not executing asynchronously. Instead, they are blocking. This is caused by using a SQL*NET driver that does not support non-blocking UPI.
Action: Try using a different SQL*NET driver.
RMAN-03020: asynchronous RPC test will take 1 minute
RMAN-03023: executing command: string
RMAN-03028: fatal error code for command string : number
Cause: Informational message. This precedes error 3012.
RMAN-03029: echo set on
Cause: a SET ECHO ON command was issued
RMAN-03030: echo set off
Cause: a SET ECHO OFF command was issued
RMAN-03031: this option of set command needs to be used inside a run block
Cause: The option used with the SET command is not valid outside a run block.
Action: Change the SET command or place it inside a run block.
RMAN-03032: this option of set command needs to be used outside of a run block
Cause: The option used with the SET command is not valid inside of a run block.
Action: Change the SET command or place it outside a run block.
RMAN-03033: current log archived
Cause: "ALTER SYSTEM ARCHIVE LOG CURRENT" command completed successfully.
Action: None, this is an informational message.
RMAN-03034: LEVEL number is invalid. LEVEL must be between string and string
Cause: An invalid DEBUG LEVEL was used.
Action: Change the DEBUG LEVEL argument.
RMAN-03035: Debugging turned off
Cause: a DEBUG OFF command was issued
RMAN-03036: Debugging set to level=number[string], types=string
Cause: a DEBUG command was issued
RMAN-03037: Spooling started in log file: string
Cause: a SPOOL LOG TO ... command was issued
RMAN-03038: Spooling started in trace file: string
Cause: a SPOOL TRACE TO ... command was issued
RMAN-03039: Spooling for log turned off
Cause: a SPOOL LOG OFF command was issued
RMAN-03040: Spooling for trace turned off
RMAN-03042: error while analyzing automatic repair options
RMAN-03090: Starting string at string
RMAN-03091: Finished string at string
RMAN-03098: stringRMAN-number: stringstring
Cause: This is the message prefix with a possible indentation.
RMAN-03099: job cancelled at user request
Cause: The user interrupted the current job.
Action: None
RMAN-03999: Oracle error occurred while while converting a date: ORA-number: string
Cause: Internal error converting a date.
RMAN-04000: memory allocation failure
Cause: A memory allocation request could not be satisfied.
Action: Increase the amount of memory available to RMAN.
RMAN-04001: heap initialization failure
RMAN-04002: OCIPI failed, ORA-string
Cause: OCI process level initialization failed.
Action: This error should not normally occur.
RMAN-04003: OCIINIT failed
Cause: The call to OCIEnvInit failed.
Action: This error should not normally happen. Contact Oracle Customer Support.
RMAN-04004: error from recovery catalog database: string
Cause: Oracle error signaled by catalog database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04005: error from target database: \nstring
Cause: Oracle error signaled by target database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04006: error from auxiliary database: string
Cause: Oracle error signaled by auxiliary database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04007: WARNING from recovery catalog database: string
Cause: Non fatal Oracle error signaled by catalog database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04008: WARNING from target database: \nstring
Cause: Non fatal Oracle error signaled by target database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04009: WARNING from auxiliary database: string
Cause: Non fatal Oracle error signaled by auxiliary database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04010: target database Password:
Cause: No password was provided for the target database.
Action: Provide target database password.
RMAN-04011: recovery catalog database Password:
Cause: No password was provided for the recovery catalog database.
Action: Provide recovery catalog database password.
RMAN-04012: auxiliary database Password:
Cause: No password was provided for the auxiliary database.
Action: Provide auxiliary database password.
RMAN-04013: must connect before startup
Cause: A STARTUP command was attempted before connecting to the database.
Action: Connect to database before attempting STARTUP command.
RMAN-04014: startup failed: string
Cause: The database failed to startup.
Action: The cause of the failure is included in the error message. Correct the cause of the failure and retry the startup command.
RMAN-04015: error setting target database character set to string
Cause: An error was received while setting the session character set in the target database.
RMAN-04016: could not get OCI error handle
Cause: An error was received while initializing the OCI layer.
RMAN-04017: startup error description: string
Cause: This is an additional informational message that indicates the cause of failure.
Action: See accompanying error messages indicating the cause of failure. No action is required.
RMAN-04020: target database name "string" does not match channel's name: "string"
Cause: The CONNECT clause in the ALLOCATE command has resulted in a connection to a database which is not the same as the one used to connect to the target database.
Action: Verify that the CONNECT string connects to the same database as the one specified in the TARGET connection for the CONNECT command.
RMAN-04021: target database DBID string does not match channel's DBID string
RMAN-04022: target database mount id string does not match channel's mount id string
RMAN-04024: starting Oracle instance without parameter file for retrieval of spfile
Cause: The instance could not be started because no default parameter file (either PFILE or SPFILE) could be found. The instance will be started in restricted mode with default parameters.
Action: None - this is an informational message.
RMAN-04025: unable to generate a temporary file
Cause: Creation of a temporary file failed. If could be that the system does not have enough resources (disk space, memory or similar).
Action: Verify and free some system resources memory and try again.
RMAN-04026: unable to open a temporary file: "string"
Cause: Opening of a temporary file failed. If could be that the system does not have enough resources (disk space, memory or similar).
RMAN-04027: unable to write to a temporary file: "string"
Cause: Writing to a temporary file failed. If could be that the system does not have enough resources (disk space, memory or similar).
RMAN-04031: \ninitialization parameters used for automatic instance:\nstring\n
RMAN-04032: using contents of file string
Cause: The specified file was included as part of the auxiliary database parameter file. This is an informational message.
RMAN-04033: cannot open auxiliary parameter file string
Cause: An auxiliary parameter file was specified with SET AUXILIARY INSTANCE PARAMETER FILE command but the specified file cannot be found.
Action: Set the parameter file to an existent file or retry the command without setting AUXILIARY INSTANCE PARAMETER FILE.
RMAN-04034: source recovery catalog database Password:
Cause: A password was not provided for the source recovery catalog database.
Action: Provide source recovery catalog database password.
RMAN-04035: error from source recovery catalog database: string
Cause: Oracle error signaled by source recovery catalog database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04036: WARNING from source recovery catalog database: string
Cause: Nonfatal Oracle error signaled by source recovery catalog database. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-04037: Connection should be as SYSDBA or as SYSBACKUP
Cause: An unsupported mode was specified on a target or clone connection.
Action: Specify a valid mode and retry the connection.
RMAN-04038: Connection should not specify a mode
Cause: A connection specified a mode when no mode is supported for this kind of connection
Action: Remove the mode specification and retry the connection.
RMAN-05000: CONFIGURE AUXNAME required for datafile string
Cause: Either: -) The control file mounted by the auxiliary database does not have an entry for this datafile, therefore file name conversion is not possible. -) A COPY DATAFILE TO AUXNAME command was issued, but no auxname was set for this datafile.
Action: Use the CONFIGURE AUXNAME command to specify a file name that the auxiliary database can use as a restore destination.
RMAN-05001: auxiliary file name string conflicts with a file used by the target database
Cause: RMAN is attempting to use the specified file name as a restore destination in the auxiliary database, but this name is already in use by the target database.
Action: Use the CONFIGURE AUXNAME command to specify a name for the data file that does not conflict with a file name in use by the target db.
RMAN-05002: aborting Tablespace Point-in-Time Recovery
Cause: Previously encountered error(s) were issued which require corrective action.
Action: Resolve the error conditions, and then re-issue the RECOVER command.
RMAN-05003: Tablespace Point-in-Time Recovery is not allowed for tablespace string
Cause: The SYSTEM, SYSUAX or a tablespace containing rollback segments is not allowed in Tablespace Point-in-Time Recovery.
Action: Remove the indicated tablespace from the recovery set and retry the operation.
RMAN-05004: target database log mode is NOARCHIVELOG
Cause: An attempt was made to apply Tablespace Point-in-Time Recovery or Pluggable Database Point-in-Time Recovery to a database that is in NOARCHIVELOG mode.
Action: If all required archived log files are available for Tablespace Point-in-Time Recovery or Pluggable Database Point-in-Time Recovery, alter the target database log mode to ARCHIVELOG and retry the operation. Otherwise, Tablespace Point-in-Time Recovery and Pluggable Database Point-in-Time Recovery cannot be applied to this database.
RMAN-05005: Tablespace Point-in-Time Recovery is not allowed for re-created tablespace string
Cause: The requested tablespace has been re-created and is not allowed in Point-in-Time Recovery.
RMAN-05006: cannot recover clone standby single tablespaces
Cause: Standby recover can only be performed for the whole database.
Action: Change the tablespace list to a database specification.
RMAN-05007: no channel allocated
Cause: A command was entered that requires a channel, and no channel is allocated.
Action: Use ALLOCATE CHANNEL before using the command
RMAN-05008: SKIP clause not valid for normal recovery
Cause: The SKIP clause was specified for non-Tablespace or Table Point-in-Time Recovery.
Action: Remove the UNDO TABLESPACE clause.
RMAN-05009: Block Media Recovery requires Enterprise Edition
Cause: The RECOVER...BLOCK command was specified.
Action: Remove the RECOVER...BLOCK command.
RMAN-05010: target database must be opened in READ WRITE mode for Tablespace Point-in-Time Recovery
Cause: The target database was not opened in read/write mode.
Action: Open the database in read/write mode.
RMAN-05011: auxiliary instance must be in NOMOUNT state for Tablespace Point-in-Time Recovery
Cause: The Auxiliary instance was not in NOMOUNT state.
Action: Open the auxiliary instance in NOMOUNT state.
RMAN-05013: auxiliary control file name string conflicts with a file used by the target database
Cause: RMAN is attempting to use the specified control file name for Tablespace Point-in-Time Recovery as a restore destination in the auxiliary database, but this name is already in use by the target database.
Action: Set control_files parameter in the auxiliary instance to a name that does not conflict with a file name in use by the target database.
RMAN-05014: Tablespaces with undo segments were not found in recovery catalog
Cause: The recovery catalog did not have information about tablespaces with undo segments.
Action: Manually specify the tablespaces with undo segments in the optional UNDO tablespaces clause of the RECOVER command.
RMAN-05015: WARNING: not enough information in recovery catalog for specified Point-in-Time recovery
Cause: The recovery catalog did not have information about the tablespaces with undo segments at the specified Point-in-Time. This happened because the current recovery catalog was not in use at the specified Point-in-Time. A list of tablespaces with undo segments was supplied.
Action: RMAN assumes that the current set of tablespaces with undo segments is the same set that was in use at the specified Point-in-Time. If the set of tablespaces with undo segments changes, the recovery fails. If recovery fails, use the optional UNDO TABLESPACE clause of the RECOVER command to specify the correct set of tablespaces.
RMAN-05016: failover to previous backup
Cause: This is an informational message to indicate the RMAN could not successfully restore the files using the specified backups. An attempt was made to restore the datafile/archived logs/ control file/SPFILE using a previous existing backup.
Action: See accompanying additional error messages indicating the cause of the failover.
RMAN-05017: no copy of datafile number found to recover
Cause: A RECOVER COPY command was not able to proceed because no copy of indicated file was found to recover. Possible causes include the following: 1. no copy of indicated file exists on disk that satisfy the criteria specified in the user's recover operands. 2. copy of indicated datafile exists on disk but no incremental backup was found to apply to the datafile copy.
Action: One of the following: 1. Use or correct TAG specification to recover a different datafile copy. 2. Use BACKUP FOR RECOVER OF COPY command to create necessary incremental backup or copy.
RMAN-05018: some datafile copies cannot be recovered, aborting the RECOVER command
Cause: This error message can follow one or more RMAN-5017 or RMAN-5019 error messages.
Action: See RMAN-5017 or RMAN-5019 error messages documentation for more information.
RMAN-05019: WARNING: no channel of required type allocated to recover copy of datafile number
Cause: A RECOVER COPY command could not proceed because incremental backup sets exist on a device type that has not been allocated.
Action: Use the LIST command to determine which device type is needed, then allocate a channel of that type.
RMAN-05020: cannot specify AUXILIARY DESTINATION option for normal recovery
Cause: The AUXILIARY DESTINATION option was specified for a normal recovery. It is only allowed for Tablespace or Table Point-in-Time Recovery.
Action: Remove the AUXILIARY DESTINATION option and rerun the RECOVER command.
RMAN-05021: this configuration cannot be changed for a BACKUP or STANDBY control file
Cause: The user attempted to modify the configuration which cannot be changed for a BACKUP or STANDBY control file while the mounted control file was either BACKUP or STANDBY. The following configurations can be changed only when connected to primary database instance that has CURRENT/CREATED control file type mounted: CONFIGURE RETENTION POLICY CONFIGURE EXCLUDE CONFIGURE ENCRYPTION CONFIGURE DB_UNIQUE_NAME
Action: Connect to primary database instance and execute the command.
RMAN-05022: TRANSPORT TABLESPACE may not be used with user-managed auxiliary instance
Cause: A user-managed auxiliary instance was specified.
Action: Retry the operation with an RMAN-managed auxiliary instance.
RMAN-05023: TABLESPACE DESTINATION required
Cause: A required TABLESPACE DESTINATION was not specified.
Action: Specify a TABLESPACE DESTINATION and retry the operation.
RMAN-05024: \nList of tablespaces presumed to have UNDO segments
Cause: Accompanying message to 5015.
Action: See action of message 5015.
RMAN-05025: Tablespace string
RMAN-05026: WARNING: presuming following set of tablespaces applies to specified Point-in-Time
Cause: RMAN assumes that the current set of tablespaces with undo segments is the same set that was in use at the specified Point-in-Time. If the set of tablespaces with undo segments changes, the recovery fails. If recovery fails, use the optional UNDO TABLESPACE clause of the RECOVER command to specify the correct set of tablespaces.
RMAN-05027: \nList of tablespaces expected to have UNDO segments
Cause: Accompanying message to 5026.
Action: See action of message 5026.
RMAN-05028: Tablespace string
RMAN-05029: UNDO TABLESPACE clause not valid for normal recovery
Cause: The UNDO TABLESPACE clause was specified for non-Tablespace or Table Point-in-Time Recovery.
RMAN-05030: CLONE clause only valid for normal recovery
Cause: The CLONE clause was specified for a Tablespace or Logical Point-in-Time Recovery.
Action: Remove the CLONE clause.
RMAN-05031: DATAPUMP DESTINATION clause is only valid for Table Point-in-Time Recovery
Cause: The DATAPUMP DESTINATION clause was specified for a non-Table Point-in-Time Recovery.
Action: Remove the DATAPUMP DESTINATION clause.
RMAN-05032: datafile string will be created automatically during restore operation
Cause: The specified datafile did not have an available backup.
Action: None. This is an informational message displayed for VALIDATE or PREVIEW option of the RESTORE command.
RMAN-05033: Media recovery start SCN is string
Cause: The above system change number (SCN) would be starting media recovery SCN, if the specified files are restored.
Action: None. This is an informational message displayed for PREVIEW option of the RESTORE command.
RMAN-05034: Recovery must be done beyond SCN string to clear datafile fuzziness
Cause: The above system change number (SCN) identifies the minimum SCN beyond which the media recovery must be performed on the specific datafile to clear the media recovery fuzziness for all datafile.
RMAN-05035: archived logs generated after SCN string not found in repository
Cause: The recovery catalog or target database control file did not have a record of archived logs containing the redo generated after the specified system change number (SCN).
Action: None. To avoid this message, perform a log switch if the database is in open mode.
RMAN-05036: FOR DB_UNIQUE_NAME option cannot be used for this configuration
Cause: An attempt was made to set the configuration which cannot be used with FOR DB_UNIQUE_NAME option.
Action: Remove FOR DB_UNIQUE_NAME option and execute the command.
RMAN-05037: FOR DB_UNIQUE_NAME option cannot be used in nocatalog mode
Cause: An attempt was made to set the remote configuration in nocatalog mode.
Action: Connect to recovery catalog and execute the command.
RMAN-05038: unable to determine UNTIL SCN for TRANSPORT
Cause: No archived logs were found in the control file.
Action: Add UNTIL clause to TRANSPORT command and retry.
RMAN-05039: One or more auxiliary set of datafiles could not be removed
Cause: There was an error while performing Tablespace or Table Point-in-Time Recovery. Some of the restored datafiles had Oracle Managed Files (OMF) names and were not deleted.
Action: Manually remove the auxiliary set of datafiles that were not deleted.
RMAN-05040: \n\nList of tablespaces that have been dropped from the target database:
Cause: One or more tablespaces in the recovery set were not found in the control file of the target database.
Action: None. Informational message.
RMAN-05041: Error during export of metadata
Cause: Export of metadata received an error from Data Pump.
Action: This message is accompanied by other error message(s) indicating the cause of the error.
RMAN-05042: Error during import of metadata
Cause: Import of metadata received an error from Data Pump.
RMAN-05043: Tablespace string
Cause: Accompanying message to 5040.
Action: See Action of message 5040.
RMAN-05044: \nPerforming export of metadata...
RMAN-05045: \nPerforming import of metadata...
RMAN-05046: Export completed\n
RMAN-05047: Import completed\n
RMAN-05048: specified file name string conflicts with a file used by the target database
Cause: The specified file name was already in use by another datafile in the database.
Action: Use SET NEWNAME command to specify a different name for the datafile that does not conflict with a file name in use by the target database.
RMAN-05050: flashing back control file to SCN string
Cause: RESTORE command was issued with a SET UNTIL clause and Flashback Database enabled. The control file was flashed back to the SET UNTIL time.
Action: This is an informational message only.
RMAN-05051: analyzing automatic repair options; this may take some time
RMAN-05052: Repair string is not compatible with this version of RMAN.
Cause: The specified repair was not compatible with this version of Recovery Manager (RMAN).
Action: Use a newer version of the RMAN executable.
RMAN-05053: AUXILIARY DESTINATION is only valid when using a RMAN-managed auxiliary instance
Cause: AUXILIARY DESTINATION clause was specified while using an user-managed auxiliary instance.
Action: Do not specify AUXILIARY DESTINATION clause and retry the operation or use a RMAN-managed auxiliary instance.
RMAN-05054: recover block operand string cannot be used to recover datafile
Cause: The specified operand could not be used with RECOVER datafile command.
Action: Delete the invalid operand and retry the command.
RMAN-05055: recover datafile operand string cannot be used to recover block
Cause: The specified operand could not be used with RECOVER block command.
RMAN-05056: Table string.string belongs to SYS
Cause: A SYS table was specified to be recovered.
Action: Remove SYS table, SYS objects cannot be recovered.
RMAN-05057: Table string.string not found
Cause: The specified table was not found in the dictionary at the specified point-in-time.
Action: Verify the name of the schema and table, or change the point-in-time and retry the command.
RMAN-05058: Cannot determine tablespace for table string.string
Cause: The specified table was not found in the data pump views at the specified point-in-time.
RMAN-05059: Table string.string resides in tablespace string
Cause: The tablespace that contained the specified table did not allow Tablespace Point-in-Time Recovery.
Action: Remove the offending table before attempting the operation again.
RMAN-05060: block specifier must be specified to recover block
Cause: Block Specifier was not specified in the command.
Action: Specify block specifier and resubmit the command.
RMAN-05061: analyzing automatic repair options complete
RMAN-05062: image copy needs no roll forward
Cause: The image copy that would be rolled forward by the RECOVER COPY command is already more recent than the specified UNTIL time or system change number (SCN).
Action: Usually this is the result of a recent OPEN RESETLOGS operation, and no action is needed, because the daily backup strategy will start rolling this copy forward after it becomes old enough to be eligible for rolling forward. To force the copy to be rolled forward, specify a more recent UNTIL time or system change number (SCN).
RMAN-05063: Cannot recover specified tables
Cause: Previously encountered errors required corrective action.
Action: Resolve the error conditions and reissue the Table Point-in-Time Recovery command.
RMAN-05064: REMAP TABLE clause is only valid for Table Point-in-Time Recovery
Cause: The REMAP TABLE clause was specified for a non-Table Point-in-Time Recovery.
Action: Remove the REMAP TABLE clause.
RMAN-05065: REMAP TABLESPACE clause is only valid for Table Point-in-Time Recovery
Cause: The REMAP TABLESPACE clause was specified for a non-Table Point-in-Time Recovery.
Action: Remove the REMAP TABLESPACE clause.
RMAN-05066: NOTABLEIMPORT clause is only valid for Table Point-in-Time Recovery
Cause: The NOTABLEIMPORT clause was specified for a non-Table Point-in-Time Recovery.
Action: Remove the NOTABLEIMPORT clause.
RMAN-05067: Table string already specified
Cause: The specified table was already specified to be recovered.
Action: Remove the duplicated table and retry the command.
RMAN-05069: New table name string for user string was already specified for other table
Cause: The same table name for the same user has already been specified for a different table.
Action: Remove or change the duplicated table name and retry the command.
RMAN-05070: Running TRANSPORT_SET_CHECK on recovery set tablespaces
RMAN-05071: TRANSPORT_SET_CHECK completed successfully
RMAN-05072: TRANSPORT_SET_CHECK failed
Cause: SYS.TS_PITR_CHECK was not empty for recovery set tablespaces.
Action: Fix dependencies before attempting TSPITR again.
RMAN-05073: Tablespace string creation SCN string is ahead of point-in-time SCN string
Cause: The tablespace was found in the control file but the creation system change number (SCN) of the datafile(s) is after the specified point-in-time. This can happen if a previous tablespace point-in-time recovery was performed, for the tablespace.
Action: If a previous TSPITR has been performed drop the tablespace and retry the command. Otherwise, verify the name of the tablespace and/or the point-in-time and resubmit the command.
RMAN-05074: Tablespace string does not exist at specified point-in-time SCN string
Action: Verify the name of the tablespace and/or the point-in-time and resubmit the command.
RMAN-05075: Remapped object string is not being recovered
Cause: The specified remapped object was not recovered.
Action: Add remapped object to object list or remove this remap specification.
RMAN-05076: Remapped tablespace string is not being recovered
Cause: The specified tablespace was not recovered. None of the objects being recovered belong to the specified tablespace.
Action: Revise the object list or remove the remapped tablespace specification.
RMAN-05077: New tablespace string does not exist in target database
Cause: The new tablespace in the REMAP TABLESPACE clause could not be found in the target database.
Action: Revise the object list or remove remapped tablespace specification.
RMAN-05078: Table Point-in-Time Recovery requires an UNTIL clause
Cause: Table Point-in-Time Recovery was specified without a point-in-time specification.
Action: Add a point-in-T\time specification and retry the command.
RMAN-05079: Table string already remapped
Cause: The same table appeared in another remap specification.
Action: Remove the duplicated remapped table and retry the command.
RMAN-05080: Not performing table import after point-in-time recovery
Cause: As requested, Data Pump Import was not performed after the point-in-time recovery was performed.
Action: Manually perform the Data Pump Import of the recovered tables into the target database.
RMAN-05081: Cannot use REMAP clauses if NOTABLEIMPORT clause is used
Cause: The NOTABLEIMPORT clause was specified together with either the REMAP TABLE or REMAP TABLESPACE clause. These clauses are used during importing of the tables and, therefore, are invalid.
Action: Remove the REMAP clauses or remove the NOTABLEIMPORT clause and retry the command.
RMAN-05082: Tablespace string already remapped
Cause: The same tablespace appeared in another remap specification.
Action: Remove the duplicated remapped tablespace and retry the command.
RMAN-05083: Partition string.string.string not found
Cause: The specified partition was not found in the dictionary at the specified point-in-time.
Action: Verify the name of the schema, table and partition, or change the point-in-time and retry the command.
RMAN-05084: \nPerforming export of tables...
RMAN-05085: \nPerforming import of tables...
RMAN-05086: DUMP FILE clause is only valid for Table Point-in-Time Recovery
Cause: The DUMP FILE clause was specified for a non-Table Point-in-Time Recovery.
Action: Remove the DUMP FILE clause.
RMAN-05087: \nPerforming export of metadata for specified tablespaces...
RMAN-05088: DB_CREATE_FILE_DEST is not set
Cause: TO NEW was specified for a RESTORE BACKUPPIECE command but DB_FILE_CREATE_DEST was not set for the target database.
Action: Specify DB_FILE_CREATE_DEST for the target database or specify FORMAT and retry the command.
RMAN-05089: Cannot specify string clause with cross-platform restore
Cause: The specified option was used for a cross-platform datafile restore.
Action: Remove the option and resubmit the command.
RMAN-05090: FROM PLATFORM clause can only be used with cross-platform datafile restore
Cause: FROM PLATFORM clause was specified for a noncross-platform datafile restore.
Action: Remove the clause and resubmit the command.
RMAN-05091: UNTIL cannot be used with cross-platform datafile restore
Cause: An UNTIL command was in effect or an UNTIL clause was specified for a cross-platform datafile restore.
Action: Remove the UNTIL clause or command and resubmit the command.
RMAN-05092: Option string cannot be used when restoring whole database with cross-platform datafile restore
Cause: The specified option was specified for whole database cross-platform datafile restore.
RMAN-05093: Restore cannot be mixed with cross-platform datafile restore
Cause: A restore specification was found when a cross-platform data file specification was expected.
Action: Use only one kind of restore specification in a single restore command.
RMAN-05094: Cross-platform whole database restore requires that the database is not mounted
Cause: FOREIGN DATABASE specification was found but the database was not in the correct state.
Action: Make sure that the database is not mounted when performing whole database cross-platform restore.
RMAN-05095: Data Pump import requires the database to be open read/write
Cause: During a cross-platform tablespace restore, DUMP FILE was specified without NOIMPORT and database was not open in read/write mode.
Action: Remove DUMP FILE specification or add NOIMPORT to it or, alternatively, open the database in read/write mode before retrying the command.
RMAN-05096: FROM SERVICE option is not supported for archived logs
Cause: The FROM SERVICE option was supplied but does not apply to restoring archived logs.
Action: Remove the FROM SERVICE operand and reenter the command.
RMAN-05097: could not validate file header for datafile string from service string
Cause: The specified datafile could not be accessed from the indicated service.
Action: Ensure that the datafile exists on the service and has same creation SCN as that of target database file. If the error can be corrected, do so and retry the operation.
RMAN-05099: not connected to target database with a password
Cause: A command that restores SPFILE to the target instance from a service name was requested. Such a command requires a password to be present in the connect string used to connect to the target instance.
Action: Exit RMAN session and then connect to target database using command line or CONNECT TARGET command with a password.
RMAN-05100: not connected to auxiliary database with a password
Cause: A command that restores SPFILE to the auxiliary instance from a service name was requested. Such a command requires a password to be present in the connect string used to connect to the auxiliary instance.
Action: Exit RMAN session and then connect to auxiliary instance using command line or CONNECT AUXILIARY command with a password.
RMAN-05101: Point-in-Time Recovery without CATALOG and TARGET not open requires that UNDO TABLESPACE is specified
Cause: A Point-in-Time Recovery was attempted when target database was not open without connection to a recovery catalog. It is necessary that the list of tablespaces with undo segments is provided with the UNDO TABLESPACE clause.
Action: Retry the command specifying the list of tablespaces with undo segments using the UNDO TABLESPACE clause.
RMAN-05102: auxiliary instance must be in the NOMOUNT state for Pluggable Database Point-in-Time Recovery
Cause: The Auxiliary instance was not in the NOMOUNT state.
Action: Put the auxiliary instance into the NOMOUNT state.
RMAN-05103: aborting Pluggable Database Point-in-Time Recovery
Action: Resolve the error conditions and then re-issue the RECOVER command.
RMAN-05104: Specifying more than one Pluggable Databases is not supported
Cause: The command was attempted on more than one Pluggable Databases. This is not supported.
Action: Separate the task into multiple RMAN commands so that each command operates on one Pluggable Database.
RMAN-05105: Specifying string database is not supported.
Cause: This operation was not supported for the Pluggable Database that was specified in the command.
Action: None. This is an informational message only.
RMAN-05106: datafile string conflicts with file used by database string
Cause: RMAN attempted to use the specified datafile number as a restore destination, but this datafile number was already in use by the specified database.
Action: Resolve the conflict and retry the command.
RMAN-05107: AUXILIARY DESTINATION option is not specified
Cause: The AUXILIARY DESTINATION option was not specified for Pluggable Database Point-in-Time Recovery or Flashback Pluggable Database. This is a mandatory option for these commands unless Fast Recovery Area is used.
Action: Specify the AUXILIARY DESTINATION option and retry the command.
RMAN-05108: Command is not supported for pluggable database
Cause: Pluggable database specified for this command. This is not supported.
Action: None - informational message only
RMAN-05109: UNTIL SCN (string) is orphan incarnation of Pluggable Database string
Cause: Specified UNTIL CHANGE was an orphan incarnation of the Pluggable Database.
Action: Check the UNTIL CHANGE or UNTIL RESTORE POINT. If the database needs to be restored to an orphan incarnation, use the RESET PLUGGABLE DATABASE command.
RMAN-05110: Pluggable Database string must be closed.
Cause: Pluggable Database Point-in-Time Recovery or Flashback Pluggable Datdabase was attempted while the Pluggable Database was open.
Action: Close the Pluggable Database and Retry the Command.
RMAN-05111: Pluggable Database Point-in-Time Recovery is not supported for standby
Cause: Pluggable Database Point-in-Time Recovery was attempted on standby. This is not supported.
Action: None - informational message only.
RMAN-05112: table "string"."string" already exists
Cause: The specified table was present in the dictionary in the target database.
Action: Verify the name of the schema and table, or change the table name using the REMAP option and retry the command.
RMAN-05113: import completed with errors; Oracle Data Pump dump file string is retained
Cause: Import completed with errors.
Action: See Data Pump Import output for details of the problem.
RMAN-05114: datafile string name string is already used by datafile string
Cause: RMAN attempted to use the specified data file name as a restore destination for the indicated data file, but this data file name was already in use by the specified database. This can happen during pluggable database point-in-time recovery to recover a dropped tablespace whose data file name was already in use by a pluggable database.
Action: Add a SET NEWNAME command prior to the RESTORE or RECOVER command to specify the restore destination for this file.
RMAN-05115: Cross-platform INSTANT RESTORE is not supported.
Cause: An instant restore was specified using a data file copy from a different platform.
Action: Specify a different data file copy that is formatted for the same platform where the restore is taking place.
RMAN-05116: feature was not enabled: string
Cause: The specified fature is not enabled.
Action: Do not attempt to use this feature.
RMAN-05117: archive logs missing from SCN string to SCN string
Cause: Archive logs were missing for the SCN range.
Action: Backup the missing archive logs for a successful recovery.
RMAN-05118: recovery will be done up to SCN string
RMAN-05119: recovery can not be done to a consistent state.
Cause: No archive logs or backups were found.
Action: Backup archive logs for a successful recovery.
RMAN-05120: failed to open the wallet for restore
Cause: An error occurred while opening the wallet with the specified password.
Action: Ensure that the wallet is configured properly and a correct password is specified.
RMAN-05121: decryption password set for string database
RMAN-05500: the auxiliary database must be not mounted when issuing a DUPLICATE command
Cause: A DUPLICATE command was issued, but the auxiliary database is mounted.
Action: Dismount the auxiliary database.
RMAN-05501: aborting duplication of target database
Cause: Previously encountered errors require corrective action.
Action: Resolve the error conditions, and reissue the DUPLICATE command.
RMAN-05502: the target database must be mounted when issuing a DUPLICATE command
Cause: A DUPLICATE command was issued, but the target database control file is not mounted.
Action: Mount the target database control file by issuing ALTER DATABASE MOUNT via Enterprise Manager or Server Manager.
RMAN-05503: at least one auxiliary channel must be allocated to execute this command
Cause: No auxiliary channels were allocated.
Action: Allocate an auxiliary channel.
RMAN-05504: at least two redo log files or groups must be specified for this command
Cause: Only one redo log file or group was specified
Action: Specify at least one more redo log file or group
RMAN-05505: auxiliary file name conversion of 'string' exceeds maximum length of string
Cause: When the given file name is converted to the name used for the auxiliary database, the converted name is larger than the maximum allowed file name.
Action: Change initialization parameter DB_FILE_NAME_CONVERT to convert to a valid file name.
RMAN-05506: error during recursive execution
RMAN-05507: standby control file checkpoint (string) is more recent than duplication point-in-time (string)
Cause: A DUPLICATE FOR STANDBY command was issued, but the checkpoint of the control file is more recent than the last archived log or the specified point-in-time.
Action: If an explicit point-in-time was specified, change it to be at least the control file checkpoint; otherwise archive (and backup/copy) the current log.
RMAN-05510: Duplicate finished
RMAN-05511: Datafile string skipped by request
RMAN-05512: Tablespace string cannot be skipped from duplication
Cause: The SYSTEM and SYSAUX tablespaces were not included in the DUPLICATE DATABASE. They must be present.
Action: Remove the SYSTEM and/or SYSAUX tablespace from the SKIP list and retry the operation.
RMAN-05513: cannot duplicate, control file is not current or standby
Cause: Target database did not have a current or standby control file. DUPLICATE requires the target database to have a current or standby control file.
Action: Open database to make control file current or connect to a different database before retrying the command.
RMAN-05514: Tablespace string has undo information, cannot skip
Cause: All tablespaces that have undo information must be included in the duplication.
Action: Remove the specified tablespace from the SKIP list and retry the operation.
RMAN-05515: Duplicate for standby does not allow the use of SET UNTIL
Cause: A SET UNTIL clause was specified for the command.
Action: Remove the SET UNTIL clause and try again.
RMAN-05516: duplicate operand specified: string
Cause: The specified operand appears more than once in the same DUPLICATE option list
Action: Delete the duplicated operand.
RMAN-05517: tempfile string conflicts with file used by target database
Cause: RMAN attempted to use the specified tempfile as a restore destination in the auxiliary database, but this name was already in use by the target database.
Action: Use the SET NEWNAME FOR TEMPFILE command to specify a name for the indicated tempfile, making sure that the new name does not conflict with a file name in use by target database. Alternatively, use DB_FILE_NAME_CONVERT and retry the command.
RMAN-05518: Automatically adding tablespace string
RMAN-05519: WARNING: tablespace string is always included when duplicating
Cause: The SYSTEM and SYSAUX tablespaces were included in the DUPLICATE TABLESPACE command. They were automatically included by the command and did not need to be explicitly named.
Action: To avoid this warning,, remove the SYSTEM and/or SYSAUX tablespace from the tablespaces list and retry the operation.
RMAN-05520: database name mismatch, auxiliary instance has string, command specified string
Cause: The database name specified in the initialization parameter was not the same as the database name provided in the DUPLICATE command.
Action: Correct the database name in the command or adjust the database name of the auxiliary instance.
RMAN-05521: DUPLICATE without CATALOG and TARGET not open requires that UNDO TABLESPACE is specified
Cause: A DUPLICATE was attempted when target database was not open without connection to a recovery catalog. It is necessary that the list of tablespaces with undo segments is provided with the UNDO TABLESPACE clause.
RMAN-05522: Skipping tablespace string
RMAN-05523: Tablespace string is read only and SKIP READONLY was specified
Cause: Conflicting parameters were provided.
Action: Remove SKIP READONLY or remove read-only tablespace from list of tablespaces to duplicate.
RMAN-05524: Tablespace string is offline
Cause: It was not possible to duplicate offline tablespaces.
Action: Remove offline tablespace from list or online tablespace to duplicate it.
RMAN-05525: SKIP TABLESPACE cannot be used when using DUPLICATE TABLESPACE
Cause: A SKIP TABLESPACE clause was specified for the command.
Action: Remove the SKIP TABLESPACE clause and try again.
RMAN-05526: datafile number not processed because file is OFFLINE IMMEDIATE
Cause: A DUPLICATE command omitted processing the indicated datafile because it is offline immediate. The tablespace to which this datafile belongs will also not be included. See message 5528.
Action: None, informational message only.
RMAN-05527: Tablespace string has one or more OFFLINE IMMEDIATE datafiles
Cause: It was not possible to duplicate a tablespace who had offline immediate tablespaces.
Action: Remove offending tablespace from list or recover datafile which are offline immediate in the tablespace before attempting the command again.
RMAN-05528: datafile number not processed because file belongs to tablespace with one or more offline immediate datafile (string)
Cause: A DUPLICATE command omitted processing the indicated datafile because it is part of a tablespace that has offline immediate datafile. See message 5526.
Action: No action is required. This is an informational message only.
RMAN-05529: WARNING: DB_FILE_NAME_CONVERT resulted in invalid ASM names; names changed to disk group only.
Cause: It was not possible to convert ASM Oracle Managed Files names using DB_FILE_NAME_CONVERT parameter. RMAN changed these invalid names to the converted disk group name instead.
Action: No action is required. This is an informational message only. If the automatic change is incorrect, use one of the following options instead of using DB_FILE_NAME_CONVERT for ASM Oracle Managed Files: 1) use RMAN command SET NEWNAME for each Oracle Managed File. 2) set DB_CREATE_FILE_DEST initialization parameter in auxiliary instance and not specify DB_FILE_NAME_CONVERT.
RMAN-05530: an UNTIL TIME or SCN cannot be specified with FROM ACTIVE DATABASE
Cause: A DUPLICATE with FROM ACTIVE DATABASE was specified along with either a SET UNTIL statment or UNTIL clause on the command. This is not supported. A DUPLICATE FROM ACTIVE DATABASE always creates a copy as of the current time.
Action: Check the statement and remove the use of UNTIL.
RMAN-05531: a mounted database cannot be duplicated while datafiles are fuzzy
Cause: A DUPLICATE with FROM ACTIVE DATABASE command was specified while the database was mounted or open read-only. Unless the database is open read/write, the datafiles cannot be fuzzy.
Action: Open the database read/write, then shutdown cleanly before mounting.
RMAN-05532: PASSWORD FILE specified without FROM ACTIVE DATABASE
Cause: The PASSWORD FILE clause of the DUPLICATE command was specified but the FROM ACTIVE DATABASE clause was not. A password file can only be duplicated if the FROM ACTIVE DATABSE clause has been used.
Action: Remove the PASSWORD FILE clause from the command, or perform an online duplicate of the database by specifying the FROM ACTIVE DATABASE clause.
RMAN-05533: string is not supported on string database
Cause: The specified command is not supported on this type of database. The type of database can be STANDBY, CLONE, or RAC.
Action: Do not use the specified command against this database.
RMAN-05534: WARNING: LOG_FILE_NAME_CONVERT resulted in invalid ASM names; names changed to disk group only.
Cause: It was not possible to convert ASM Oracle Managed Files names using LOG_FILE_NAME_CONVERT parameter. RMAN changed these invalid names to the converted disk group name instead.
Action: If the automatic change is incorrect, use one of the following options instead of using LOG_FILE_NAME_CONVERT for ASM Oracle Managed Files: 1) Use the LOGFILE clause for online log files. 2) After DUPLICATE completes, create standby log files using the SQL ALTER DATABASE ADD STANDBY LOGFILE command.
RMAN-05535: WARNING: All redo log files were not defined properly.
Cause: It was not possible to define all the redo log files. This can occur when LOG_FILE_NAME_CONVERT initialization parameter is defined but fails to match all the names or causes names to be created that are not in valid directories.
Action: Query the V$LOGFILE view to see what redo log files are defined after DUPLICATE has completed. Use the ALTER DATABASE RENAME FILE SQL command to correctly name the existing redo log files.
RMAN-05536: auxiliary logfile name string conflicts with a file used by the target database
Cause: RMAN attempted to use the specified logfile name as a standby redo log file in the auxiliary database, but this name was already in use by the target database.
Action: Use or alter LOG_FILE_NAME_CONVERT so that unique logfile names can be generated. Or wait for the command to complete and create standby logfiles using the SQL ALTER DATABASE ADD STANDBY LOGFILE command.
RMAN-05537: DUPLICATE without TARGET connection when auxiliary instance is started with spfile cannot use SPFILE clause
Cause: A DUPLICATE was attempted when the auxiliary database was started with a server parameter file and the SPFILE sub-clause was specified. RMAN cannot restore the server parameter file if the auxiliary database is already started with a server parameter file.
Action: Start the auxiliary database with a client parameter file or do not specify SPFILE sub-clause and retry.
RMAN-05538: WARNING: implicitly using DB_FILE_NAME_CONVERT
Cause: The duplicated SPFILE had DB_FILE_NAME_CONVERT set and it has been used to produce datafile names for the new database.
Action: No action is required. This is an informational message only. If this behavior was not intended, then do not duplicate the server parameter file, or explicitly set DB_FILE_NAME_CONVERT in the DUPLICATE command and retry the operation.
RMAN-05539: DUPLICATE TARGET DATABASE cannot be used without connecting to the TARGET
Cause: A DUPLICATE TARGET DATABASE was attempted and no connection to the TARGET database was established.
Action: Connect to TARGET or use DATABASE <db_name> clause.
RMAN-05540: no archived logs found in repository for database string
Cause: Recovery catalog did not have archived log records for the specified database. If database is running in NOARCHIVELOG mode, then specify NOREDO.
Action: Specify NOREDO for NOARCHIVELOG databases. Cannot duplicate an ARCHIVELOG database unless the recovery catalog or target database control file has archived redo log information about it.
RMAN-05541: no archived logs found in target database
Cause: Target database was running in archived log mode, but control file did not have any archived log records.
Action: Archive current log before retrying command.
RMAN-05542: Only UNTIL TIME can be used with DUPLICATE without TARGET and CATALOG connections
Cause: A DUPLICATE without TARGET and CATALOG connections was attempted specifying an UNTIL clause that was not TIME based.
Action: Retry the command with an UNTIL TIME clause or without an UNTIL clause.
RMAN-05543: DUPLICATE without TARGET connection requires that DATABASE is specified
Cause: A DUPLICATE without TARGET connection was attempted without specifying the database to duplicate.
Action: Retry the command specifying the DATABASE to duplicate.
RMAN-05544: Cannot specify ACTIVE DATABASE when not connected to target database
Cause: DUPLICATE from ACTIVE DATABASE required a connection to the target database.
Action: Connect to target database or remove from ACTIVE DATABASE and retry the command.
RMAN-05545: WARNING: Until SCN string is ahead of SCN of last full resync of recovery catalog: string
Cause: The specified point-in-time for duplication without a target connection was ahead of the last time that the datafile information was resynced to the recovery catalog. Information about offline and read-only datafiles might be incorrect.
Action: If duplication fails due to incorrectly identified offline and/or read-only datafiles, specify a point-in-time before the last resync of the recovery catalog and retry the command. Or perform full resync of the target database and retry the command.
RMAN-05546: DUPLICATE without TARGET and CATALOG connections requires that BACKUP LOCATION is specified
Cause: A DUPLICATE without TARGET and CATALOG connections was attempted without specifying BACKUP LOCATION.
Action: Retry the command specifying a BACKUP LOCATION.
RMAN-05547: Checking that duplicated tablespaces are self-contained
RMAN-05548: The set of duplicated tablespaces is not self-contained
Cause: A DUPLICATE TABLESPACE has specified a set of tablespaces that cannot function independently.
Action: Retry the command without incomplete tablespaces or add other tablespaces to make the set self-contained.
RMAN-05549: The following SYS objects were found in skipped tablespaces
Action: No action required.
RMAN-05550: TARGET database not open, cannot verify that set of tablespaces being duplicated does not have SYS objects
RMAN-05551: Not connected to TARGET, cannot verify that set of tablespaces being duplicated does not have SYS objects
RMAN-05552: Object string on tablespace string
Cause: A SYS object was found in one of the skipped tablespaces.
Action: Remove object if possible or include tablespace in duplicated tablespaces.
RMAN-05553: SYS objects in skipped tablespaces prevent duplication
Cause: Objects owned by SYS were found in the tablespaces that would not be duplicated.
Action: If using SKIP TABLESPACE, do not skip tablespaces that contain SYS objects. If using DUPLICATE TABLESPACE, make sure to specify all tablespaces containing SYS objects.
RMAN-05554: cannot specify INCARNATION when duplicating without TARGET and CATALOG connections
Cause: A DUPLICATE without TARGET and CATALOG connections was attempted when INCARNATION was also specified.
Action: Retry the command without specifying INCARNATION.
RMAN-05555: Not connected to TARGET or TARGET not open, cannot verify that subset of tablespaces is self-contained
RMAN-05556: not all datafiles have backups that can be recovered to SCN string
Cause: One or more datafiles being duplicated could not be restored as no available backups were found.
Action: Change the system change number (SCN) or make backups available for the specified datafiles and retry the command.
RMAN-05557: Target instance not started with server parameter file
Cause: SPFILE clause was used but target instance was not started with a server parameter file.
Action: Do not specify SPFILE clause, or restart target instance with server parameter file.
RMAN-05558: Must specify DB_UNIQUE_NAME with FOR STANDBY clause
Cause: A DUPLICATE FOR STANDBY ... SPFILE command was issued but DB_UNIQUE_NAME was not provided for the standby database.
Action: Specify a DB_UNIQUE_NAME in the SPFILE clause for the standby database.
RMAN-05559: error converting parameter string, string larger than number
Cause: While attempting to apply a PARAMETER_VALUE_CONVERT to the specified parameter value, the resulting string exceeded the maximum length for a value.
Action: Change the PARAMETER_VALUE_CONVERT so that, when converting the parameter, the maximum lenght is not reached.
RMAN-05560: Using previous duplicated file string for datafile number with checkpoint SCN of string
Cause: A datafile copy from a previous duplicate attempt matching the duplicate name requested was found for the specified datafile and will be used instead of restoring the datafile from a backup.
Action: No action needed unless this behavior is not desire. In that case, either use a different name for the datafile or use NORESUME to avoid using previous datafile copies for all the datafiles.
RMAN-05561: CATALOG did not return information about tablespaces with undo segments
Cause: A DUPLICATE with no target connection was attempted, but the recovery catalog did not have information about the tablespaces with undo segments at the specified point in time. It is necessary that the list of tablespaces with undo segments is provided with the UNDO TABLESPACE clause.
RMAN-05562: SPFILE backup not found for database string with DBID number created before string in string
Cause: RMAN could not locate a backup of the SPFILE in the specified location that satisfied the specified parameters.
Action: Change the parameters, or provide a different location and retry the command.
RMAN-05563: SPFILE backup not found for database with DBID number created before string in string
RMAN-05564: SPFILE backup not found for database string created before string in string
RMAN-05565: SPFILE backup created before string not found in string
RMAN-05566: SPFILE backup not found for database string with DBID number in string
RMAN-05567: SPFILE backup not found for database with DBID number in string
RMAN-05568: SPFILE backup not found for database string in string
RMAN-05569: SPFILE backup not found in string
Cause: RMAN could not locate a backup of the SPFILE in the specified location.
Action: Provide a different location and retry the command.
RMAN-05570: Duplicate for standby does not allow the use of LOGFILE
Cause: A LOGFILE clause was specified for the command.
Action: Remove the LOGFILE clause and try again.
RMAN-05571: DORECOVER specified for non standby duplication
Cause: A DORECOVER clause was specified and the duplicate did not specify FOR STANDBY.
Action: Remove the DORECOVER clause or add FOR STANDBY and try again.
RMAN-05572: Controlfile backup not found for database string with DBID number created before string in string
Cause: RMAN could not locate a backup of the control file in the specified location that satisfied the specified parameters.
RMAN-05573: CONTROLFILE backup not found for database with DBID number created before string in string
RMAN-05574: CONTROLFILE backup not found for database string created before string in string
RMAN-05575: CONTROLFILE backup created before string not found in string
RMAN-05576: CONTROLFILE backup not found for database string with DBID number in string
RMAN-05577: CONTROLFILE backup not found for database with DBID number in string
RMAN-05578: CONTROLFILE backup not found for database string in string
RMAN-05579: CONTROLFILE backup not found in string
Cause: RMAN could not locate a backup of the control file in the specified location.
RMAN-05580: Duplicate for standby does not allow the use of SKIP READONLY
Cause: A SKIP READONLY clause was specified for the command.
Action: Remove the SKIP READONLY clause and try again.
RMAN-05581: Duplicate for standby does not allow the use of SKIP TABLESPACE
RMAN-05582: Duplicate for standby does not allow the use of OPEN RESTRICTED
Cause: An OPEN RESTRICTED clause was specified for the command.
Action: Remove the OPEN RESTRICTED clause and try again.
RMAN-05583: Duplicate for standby does not allow the use of TABLESPACE
Cause: A TABLESPACE clause was specified for the command.
Action: Remove the TABLESPACE clause and try again.
RMAN-05584: Duplicate for standby does not allow the use of NOREDO
Cause: A NOREDO clause was specified for the command.
Action: Remove the NOREDO clause and try again.
RMAN-05585: Duplicate for standby does not allow the use of UNDO TABLESPACE
Cause: A UNDO TABLESPACE clause was specified for the command.
Action: Remove the UNDO TABLESPACE clause and try again.
RMAN-05586: The following materialized objects were found in skipped tablespaces
Cause: This is an informational message only.
RMAN-05587: Materialized table string on tablespace string
Cause: A materialized table was found in one of the skipped tablespaces.
RMAN-05588: Materialized index string on tablespace string
Cause: A materialized index was found in one of the skipped tablespaces.
RMAN-05589: Materialized objects in skipped tablespaces prevent duplication
Cause: Materialized objects found in the tablespaces that would not be duplicated.
Action: If using SKIP TABLESPACE, do not skip tablespaces that contain materialized objects. If using DUPLICATE TABLESPACE, make sure to specify all tablespaces containing SYS objects.
RMAN-05590: Reenabling controlfile options for auxiliary database
RMAN-05591: Ignoring error, reattempt command after duplicate finishes
Cause: A sql error was received during the execution of command.
RMAN-05592: Dropping offline and skipped tablespaces
RMAN-05593: Could not drop tablespace string due to constraints, will reattempt removal after other tablespaces are removed
RMAN-05594: Could not drop tablespace string due to constraints
Cause: The tablespace failed to be dropped several times, no more attempts will be made.
Action: Drop the tablespace manually after duplicate finishes.
RMAN-05595: Leaving database unopened, as requested
Cause: User requested that the new database was not open.
Action: After the database is opened with resetlogs you might want to: - Catalog datafile copies of read-only datafiles - Switch read-only datafiles to the cataloged datafile copies - Online read-only tablespaces - Drop skipped tablespaces - Enable supplemental logging - Enable force logging - Enable change tracking
RMAN-05596: Error while removing created server parameter file
Cause: Server parameter file was not deleted. This message should be accompanied by other error message(s) indicating the cause of the error.
Action: Check the accompanying errors. Remove file manually.
RMAN-05597: Database started with server parameter file and PFILE clause used in command
Cause: A PFILE clause was specified for duplicate command, but database was started with a server parameter file causing a conflict.
Action: Remove PFILE clause from command or restart database without using a server parameter file.
RMAN-05598: SPFILE and PFILE clause specified in command
Cause: SPFILE and PFILE clauses were specified for duplicate command causing a conflict.
Action: Remove either one of the clauses and retry the command.
RMAN-05599: PASSWORD clause is not needed when duplicating for standby database from active database
Cause: PASSWORD clause was specified when creating a standby database from active database. This is not needed, it is automatic.
RMAN-05600: Cannot specify UNTIL clause when duplicating from active database
Cause: An UNTIL clause in the command or with a SET UNTIL was in effect for an active database duplication.
Action: Remove UNTIL clause and reattempt duplication.
RMAN-05601: Failed to restore original settings to server parameter file
Cause: An error was received while duplicating the database after the server parameter file was modified by RMAN. An attempt was made to restore original settings to the server parameter file, but the original error was such that it was not possible to restore the settings.
Action: Before reattempting database duplication, the server parameter file needs to be fixed manually with the original values.
RMAN-05602: restarting auxiliary database without server parameter file
RMAN-05603: not connected to target database with a net service name
Cause: A command that restores files to the auxiliary instance from the target instance was requested. Such a command requires that a net service name be present in the connect string used to connect to the target instance.
Action: Exit RMAN session and then connect to target database using command line or CONNECT TARGET command with a net service name in the connect string. That service name must be valid on the auxiliary instance.
RMAN-05604: Cannot specify SECTION SIZE together with USING COPY
Cause: A SECTION SIZE clause was specified for the command. This option is valid only when USING BACKUPSET or USING COMPRESSED BACKUPSET option is specified.
Action: Remove the SECTION SIZE clause or specify USING BACKUPSET option and try again.
RMAN-05605: Cannot specify USING option when not using ACTIVE DATABASE option
Cause: A USING clause was specified for the command. This option is valid only when ACTIVE DATABASE option is specified.
Action: Remove USING option or specify ACTIVE DATABASE option and try again.
RMAN-05606: Cannot specify SECTION SIZE when not using ACTIVE DATABASE option
Cause: A SECTION SIZE clause was specified for the command. This option is valid only when ACTIVE DATABASE option is used.
Action: Remove SECTION SIZE option or specify ACTIVE DATABASE option and try again.
RMAN-05607: Cannot remove created server parameter file
Cause: Duplicate created a server parameter file that coould not be removed because no client parameter file was provided for the command.
Action: Remove manually the created server parameter file.
RMAN-05608: Tablespace string cannot be dropped due to partitioned table
Cause: A partitioned table was contained in the tablespaces that were not included in the new database, however the tablespaces cannot be dropped until the table is dropped.
Action: Manually drop the partitioned table and then the tablespaces.
RMAN-05609: Must specify a username for target connection when using active duplicate
Cause: An active duplication was attempted but no username was provided in the connection to the target database.
Action: Specify a username when connecting to the target and retry the operation.
RMAN-05610: Must specify a username for auxiliary connection when using active duplicate
Cause: An active duplication was attempted but no username was provided in the connection to the auxiliary database.
Action: Specify a username when connecting to the auxiliary and retry the operation.
RMAN-05611: Usernames for target and auxiliary connections must be the same when using active duplicate
Cause: An active duplication was attempted but the usernames provided in the connection to the target and auxiliary database are not the same.
Action: Specify the same username when connecting to the target and the auxiliary database and retry the operation.
RMAN-05612: Must specify a password for target connection when using active duplicate
Cause: An active duplication was attempted but no password was provided in the connection to the target database.
Action: Specify a password when connecting to the target and retry the operation.
RMAN-05613: Must specify a password for auxiliary connection when using active duplicate
Cause: An active duplication was attempted but no password was provided in the connection to the auxiliary database.
Action: Specify a password when connecting to the auxiliary and retry the operation.
RMAN-05614: Passwords for target and auxiliary connections must be the same when using active duplicate
Cause: An active duplication was attempted but the passwords provided in the connection to the target and auxiliary database are not the same.
Action: Specify the same passoword when connecting to the target and the auxiliary database and retry the operation.
RMAN-05615: SKIP and DUPLICATE PLUGGABLE DATABASE cannot be used together
Cause: SKIP PLUGGABLE DATABASE and DUPLICATE PLUGGABLE DATABASE were both specified in the same command. These options are incompatible and cannot be used together.
Action: Remove one of the incompatible options and retry the command.
RMAN-05616: pluggable database string cannot be skipped from duplication
Cause: The CDB$ROOT and PDB$SEED databases were not included in the DUPLICATE DATABASE. They must be present.
Action: Remove the CDB$ROOT and PDB$SEED database from the SKIP list and retry the operation.
RMAN-05617: duplicate operand DUPLICATE TABLESPACE string and PLUGGABLE DATABASE string
Cause: The specified operand refers to same PLUGGABLE DATABASE in the DUPLICATE option list.
Action: Delete the duplicate operand and retry the command.
RMAN-05618: duplicate operand SKIP TABLESPACE string and PLUGGABLE DATABASE string
RMAN-05619: SKIP PLUGGABLE DATABASE cannot be used with DUPLICATE TABLESPACE
Cause: A SKIP PLUGGABLE DATABASE clause was specified for the command.
Action: Remove the SKIP PLUGGABLE DATABASE clause and try again.
RMAN-05620: Skipping pluggable database string
RMAN-05621: password file location could not be found for the target database
Cause: The password file location did not exist for the target database instance.
Action: Set the password file location for the target database instance.
RMAN-05622: password file location could not be found for the auxiliary database
Cause: The password file location did not exist for the auxiliary database instance.
Action: Set the password file location for the auxiliary database instance.
RMAN-06000: could not open recovery manager library file: string
Cause: The "recover.bsq" file could not be opened.
Action: Check that the file was installed correctly and that the user running RMAN has authority to read the file.
RMAN-06001: error parsing job step library
Cause: A syntax error was encountered while parsing "recover.bsq".
Action: Ensure that the correct version of the file is installed and that it has not been modified in any way.
RMAN-06002: command not allowed when not connected to a recovery catalog
Cause: A command that is allowed only when a recovery catalog connect string was supplied was attempted.
Action: Avoid using the command, or restart RMAN and supply a recovery catalog connect string via the CATALOG parameter.
RMAN-06003: ORACLE error from target database: \nstring
Cause: This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-06004: ORACLE error from recovery catalog database: string
RMAN-06005: connected to target database: string (DBID=string)
RMAN-06006: connected to target database: string (not mounted)
RMAN-06007: target database not mounted and db_name not set in init.ora
Cause: The target database has not mounted the control file, and its "init.ora" file does not specify the DB_NAME parameter.
Action: MOUNT the target database, or add the DB_NAME parameter to its "init.ora" and restart the instance.
RMAN-06008: connected to recovery catalog database
RMAN-06009: using target database control file instead of recovery catalog
RMAN-06010: error while looking up datafile: string
Cause: An error occurred while looking up the specified datafile in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. Ensure that the file name is entered correctly. If the datafile was added recently, then a RESYNC CATALOG must be done to update the recovery catalog.
RMAN-06011: invalid level specified: number
Cause: An invalid incremental backup level was specified.
Action: Incremental backup level must be between 0 and 4.
RMAN-06012: channel: string not allocated
Cause: A RELEASE command was found for a channel identifier that was not yet allocated.
Action: Correct the channel identifier, or add an ALLOCATE CHANNEL command.
RMAN-06013: duplicate channel identifier found: string
Cause: A channel identifier was reused without first releasing the channel.
Action: Add a RELEASE CHANNEL command.
RMAN-06014: command not implemented yet: string
Cause: Not all commands are implemented for the beta release.
Action: Avoid using the command.
RMAN-06015: error while looking up datafile copy name: string
Cause: An error occurred while looking up the specified datafile copy name in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. Ensure that the file name is entered correctly. If the datafile copy was created when the recovery catalog was not available, then a RESYNC CATALOG must be done to update the recovery catalog.
RMAN-06016: duplicate backup operand specified: string
Cause: The specified operand appears more than once in the same backup specifier or backup command.
RMAN-06017: initialization of parser failed
Cause: The parser package initialization routine returned an error.
Action: This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-06018: duplicate operand specified in backup specification: string
Cause: A backup specification operand appears more than once in a backup specification.
Action: Delete the duplicate operand.
RMAN-06019: could not translate tablespace name "string"
Cause: An error occurred while looking up the specified tablespace name in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. Ensure that the tablespace is entered correctly. If the tablespace was added recently, then a RESYNC CATALOG must be done to update the recovery catalog.
RMAN-06020: connected to auxiliary database (not started)
RMAN-06021: FROM DATAFILECOPY/BACKUPSET may not be specified with archived logs
Cause: The FROM DATAFILECOPY/BACKUPSET option applies only to datafile and control file restores.
Action: Use this option only for datafile and control file restores.
RMAN-06022: invalid level specified for image copy: number
Cause: An invalid incremental backup level was specified for an image copy.
Action: Incremental backup level must be 0 for image copies.
RMAN-06023: no backup or copy of datafile number found to restore
Cause: A datafile, tablespace, or database restore could not proceed because no backup or copy of the indicated file was found. It may be the case that a backup or copy of this file exists but does not satisfy the criteria specified in the user's restore operands.
Action: None - this is an informational message. See message 6026 for further details.
RMAN-06024: no backup or copy of the control file found to restore
Cause: A control file restore could not proceed because no backup or copy of the control file was found. It may be the case that a backup or copy of this file exists but does not satisfy the criteria specified in the user's restore operands.
RMAN-06025: no backup of archived log for thread number with sequence number and starting SCN of string found to restore
Cause: An archived log restore restore could not proceed because no backup of the indicated archived log was found. It may be the case that a backup of this file exists but does not satisfy the criteria specified in the user's restore operands.
RMAN-06026: some targets not found - aborting restore
Cause: Some of the files specified for restore could not be found. Message 6023, 6024, or 6025 is also issued to indicate which files could not be found. Some common reasons why a file can not be restored are that there is no backup or copy of the file that is known to recovery manager, or there are no backups or copies that fall within the criteria specified on the RESTORE command, or some datafile copies have been made but not cataloged.
Action: The Recovery Manager LIST command can be used to display the backups and copies that Recovery Manager knows about. Select the files to be restored from that list.
RMAN-06027: no archived logs found that match specification
Cause: An archived log record specifier did not match any archived logs in the recovery catalog or target database control file.
Action: Resubmit the command with a different archived log record specifier. The Recovery Manager (RMAN) LIST command can be used to display all archived logs that RMAN knows about.
RMAN-06028: duplicate operand specified in restore specification: string
Cause: The CHANNEL, TAG, FROM, PARMS, VALIDATE, DEVICE TYPE, CHECK READONLY or DB_UNIQUE_NAME option was specified more than once in the restore command or in one of the restore specifications.
Action: Correct and resubmit the command.
RMAN-06029: the control file may be included only in a datafile backup set
Cause: The "include current/standby control file" option was specified for an archived log backup set.
Action: Use this option only for datafile backup sets.
RMAN-06030: the DELETE [ALL] INPUT option may not be used with a datafile backup set
Cause: The DELETE [ALL] INPUT option was specified for a backup that contains the current control file or datafile.
RMAN-06031: could not translate database keyword
Cause: An error was received when calling DBMS_RCVMAN
RMAN-06032: at least 1 channel of TYPE DISK must be allocated to execute a COPY command
Cause: No channel of TYPE DISK was allocated.
Action: Allocate a channel of TYPE DISK and re-issue the command.
RMAN-06033: channel string not allocated
Cause: An rman command requests a specific channel, but the requested channel has not been allocated.
Action: ALLOCATE the channel, or correct the channel identifier.
RMAN-06034: at least 1 channel must be allocated to execute this command
Cause: No channels were allocated.
Action: ALLOCATE a channel.
RMAN-06035: wrong version of recover.bsq, expecting string, found string
Cause: The "recover.bsq" file is incompatible with the RMAN executable.
Action: Install the correct version of recover.bsq.
RMAN-06036: datafile number is already restored to file string
Cause: A SET NEWNAME command was issued to restore a datafile to a location other than the original datafile, and Recovery Manager determined that the best candidate for restoring the file is the datafile copy with the same name, therefore the file is already restored and no action need be taken.
RMAN-06038: recovery catalog package detected an error
Cause: A call to DBMS_RCVMAN returned an error.
RMAN-06039: SET NEWNAME command has not been issued for datafile string
Cause: A SWITCH command was specified for a datafile, but no destination was specified and no SET NEWNAME command has been previously issued for that file. An explicit file to switch to must be specified if no SET NEWNAME command has been issued.
Action: Correct and resubmit the SWITCH command.
RMAN-06040: control file is already restored to file string
Cause: The best candidate control file for restoration is the one that is named in the RESTORE CONTROLFILE command, hence no action need be taken.
RMAN-06041: cannot switch file number to copy of file number
Cause: An attempt was made to switch a datafile to a copy of a different datafile.
RMAN-06042: PLUS ARCHIVELOG option is not supported with non-datafile backups
Cause: The PLUS ARCHIVELOG option was supplied but does not apply to this type of backup.
Action: Remove the PLUS ARCHIVELOG operand and reenter the command.
RMAN-06043: TAG option not supported for archived log copies
Cause: The tag option was supplied but does not apply to this type of copy.
Action: Remove the TAG operand and reenter the command
RMAN-06045: LEVEL option not supported for archived log or current/standby control file copies
Cause: The LEVEL option was supplied but does not apply to this type of copy.
Action: Remove the LEVEL operand and reenter the command.
RMAN-06046: archived log name: string
Cause: An error occurred while translating an archived log name to its recovery catalog RECID/time stamp. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-06047: duplicate datafile number specified for restoration from copy
Cause: The indicated datafile was specified more than once in the same restore command.
Action: Correct and resubmit the RESTORE command.
RMAN-06048: duplicate control file specified for restoration from copy
Cause: The control file was specified more than once in the same RESTORE command.
RMAN-06049: CHECK LOGICAL option not supported for archived log or current/standby control file copies
Cause: The check logical option was supplied but does not apply to this type of copy.
Action: Remove the CHECK LOGICAL operand and reenter the command
RMAN-06050: archived log for thread number with sequence number is already on disk as file string
Cause: An archived log which was requested to be restored (either explicitly or via a range specification) does not need to be restored because it already exists on disk.
RMAN-06051: DELETE INPUT option not implemented yet
Cause: This option was specified in a backup specification.
Action: Remove the DELETE INPUT option.
RMAN-06052: no parent backup or copy of datafile number found
Cause: An incremental backup at level 1 or higher could not find any parent backup or copy of the indicated datafile. A level 0 backup of the datafile will be taken automatically.
RMAN-06053: unable to perform media recovery because of missing log
Cause: This message is accompanied with another message identifying the missing log. The log would be needed to perform the media recovery, but the log is not on disk and no backup set containing the log is available.
Action: Determine if a backup set containing the log can be made available. If so, then use the CHANGE command to make the backup set available and retry the command. If not, then a point-in-time recovery up to the missing log is the only alternative.
RMAN-06054: media recovery requesting unknown archived log for thread string with sequence string and starting SCN of string
Cause: Media recovery is requesting a log whose existence is not recorded in the recovery catalog or target database control file.
Action: If a copy of the log is available, then add it to the recovery catalog and/or control file via a CATALOG command and then retry the RECOVER command. If not, then a point-in-time recovery up to the missing log is the only alternative and database can be opened using ALTER DATABASE OPEN RESETLOGS command.
RMAN-06055: could not find archived log with sequence string for thread string
Cause: A log which was on disk at the start of media recovery or which should have been restored from a backup set could not be found.
Action: Check the Recovery Manager message log to see if the log was restored by a previous job step. If so, then check the V$ARCHIVED_LOG view to see if the log is listed in the control file. If so, then validate that the log exists on disk and is readable. If the log was not restored, or was restored but no record of the log exists in V$ARCHIVED_LOG, then contact Oracle Support Services.
RMAN-06056: could not access datafile number
Cause: A backup or copy could not proceed because the datafile header could not be read or the header was not valid.
Action: Make the datafile accessible or skip it.
RMAN-06057: a standby control file cannot be included along with a current control file
Cause: "current control file" was specified along with "standby control file".
Action: Remove "current control file" or "standby control file" from backup specification.
RMAN-06058: a current control file cannot be included along with a standby control file
Cause: "standby control file" was specified along with "current control file".
Action: Remove "standby control file" or "current control file" from backup specification.
RMAN-06059: expected archived log not found, loss of archived log compromises recoverability
Cause: The archived log was not found. The recovery catalog or target database control file thinks it does exist. If the archived log has in fact been lost and there is no backup, then the database is no longer recoverable across the point-in-time covered by the archived log. This may occur because the archived log was removed by an outside utility without updating the recovery catalog or target database control file.
Action: If the archived log has been removed with an outside utility and the archived log has already been backed up, then you can synchronize the recovery catalog or target database control file by running CROSSCHECK ARCHIVELOG ALL. If the archived log has not been previously backed up, then you should take a full backup of the database and archived logs to preserve recoverability. Previous backups are not fully recoverable.
RMAN-06060: WARNING: skipping datafile compromises tablespace string recoverability
Cause: SKIP INACCESSIBLE or SKIP OFFLINE option resulted in skipping datafile during BACKUP. If the datafile has in fact been lost and there is no backup, then the tablespace is no longer recoverable without ALL archived logs since datafile creation. This may occur because the datafile was deleted by an outside utility or the datafile is made OFFLINE [DROP].
Action: If there is no backup of skipped datafile and the tablespace has to be recoverable without ALL archived logs since datafile creation, then you should make these datafile available for backup.
RMAN-06061: WARNING: skipping archived log compromises recoverability
Cause: SKIP INACCESSIBLE option resulted in skipping archived logs during BACKUP. If the archived log has in fact been lost and there is no backup, then the database is no longer recoverable across the point-in-time covered by the archived log. This may occur because archived log was removed by an outside utility without updating the recovery catalog or target database control file.
RMAN-06062: can not backup SPFILE because the instance was not started with SPFILE
Cause: A backup command requested a backup of the SPFILE, but no SPFILE was used to startup the instance.
Action: Create an SPFILE and re-start the instance using the SPFILE or modify the command.
RMAN-06063: DBID is not found in the recovery catalog
Cause: DBID is not found in the recovery catalog.
Action: Verify that the DBID is correct and restart the command.
RMAN-06064: creating datafile file number=string name=string
Cause: RESTORE/RECOVER command was issued and there were no backup available for the datafile.
Action: This is an informational message only.
RMAN-06065: The operand [string] conflicts with another specified operand.
Cause: An attempt was made to use two (or more) conflicting operands within the same statement.
Action: Remove one or both of the conflicting operands.
RMAN-06066: the target database must be mounted when issuing a RECOVER command
Cause: A RECOVER command was issued, but the target database control file is not mounted.
RMAN-06067: RECOVER DATABASE required with a backup or created control file
Cause: The control file has been restored from a backup or was created via ALTER DATABASE CREATE CONTROLFILE.
Action: Use the RECOVER DATABASE command to perform the recovery.
RMAN-06068: recovery aborted because of missing datafiles
Cause: This error should be accompanied by one or more instances of message ORA-06094.
Action: Refer to message ORA-06094.
RMAN-06069: the file name for datafile string is missing in the control file
Cause: Media recovery of a backup control file added this datafile to the control file, but it does not set the file name because that is unsafe.
Action: If the datafile is on disk, then issue ALTER DATABASE RENAME to correct the control file. Otherwise, RESTORE the datafile, and then use SWITCH to make it known to the control file. If the tablespace containing this datafile will be dropped, then reissue the RECOVER command with a SKIP clause to skip recovery of this tablespace.
RMAN-06070: DBWR could not identify datafile string
Cause: DBWR could not find the specified datafile.
Action: Ensure that the datafile exists and is accessible.
RMAN-06071: could not open datafile string
Cause: An error was encountered when trying to open the specified datafile.
RMAN-06073: file header is corrupt for datafile string
Cause: ORACLE detected a corruption in the file header. A media failure has probably occurred.
Action: RESTORE the datafile to a new location, then do a SWITCH, and then retry the RECOVER command.
RMAN-06074: file string is not an ORACLE datafile
Cause: The file header indicates that this file is not a datafile. The file may have been overlaid or corrupted.
RMAN-06075: datafile string does not belong to this database
Cause: The file header indicates that this file belongs to some other ORACLE database.
RMAN-06076: datafile string contains wrong datafile
Cause: The datafile header indicates the file contains a different datafile number.
Action: RESTORE the datafile, and then retry the RECOVER command.
RMAN-06077: datafile string is a different version than contained in the control file
Cause: The control file entry for this datafile specifies a different version of this datafile. Different versions of a datafile can exist when a tablespace is dropped, and a new tablespace is created which reuses the same datafile numbers.
Action: If the datafile is correct, the fix the control file by using the SWITCH command. Otherwise, RESTORE the correct version of this datafile and retry the RECOVER command.
RMAN-06078: the control file is older than datafile string
Cause: The control file appears to be older than the specified datafile, but it is not marked as a backup control file. This indicates that the control file has been replaced with an older version. This error does not occur when a backup control file which was created via Recovery Manager or the ALTER DATABASE BACKUP CONTROLFILE command is restored because such control files are marked as backups.
Action: RESTORE a control file and perform RECOVER DATABASE.
RMAN-06079: database must be mounted to perform recovery
Cause: A RECOVER command was issued, but the target database is not mounted.
Action: Issue ALTER DATABASE MOUNT.
RMAN-06080: SWITCH required for datafile string
Cause: The control file record for this datafile is for an older incarnation of the datafile. A SWITCH command must be issued to updated the control file before doing RECOVER.
Action: Issue SWITCH command then retry RECOVER.
RMAN-06081: error reading datafile header for datafile string, code string
Cause: X$KCVFH returned the specified code in the HXERR column when it was queried for the specified datafile.
Action: Ensure the datafile exists and is readable. Using a newer release of Recovery Manager may return a more meaningful error message. If you have no newer version of Recovery Manager, contact Oracle Support Services.
RMAN-06082: datafile copy tag string is ambiguous
Cause: The specified tag refers to multiple datafile copies belonging to different datafiles.
Action: Specify the datafile copy by file name rather than by tag.
RMAN-06083: error when loading stored script string
Cause: The recovery catalog database returned an error. This error explains the cause of the problem.
Action: Correct the problem and retry.
RMAN-06084: the target database may not be mounted when issuing REPLICATE
Cause: A REPLICATE command was issued, but the target database is already mounted.
Action: dismount the target database control file by issuing ALTER DATABASE CLOSE and ALTER DATABASE DISMOUNT via Enterprise Manager or Server Manager.
RMAN-06085: must use SET NEWNAME command to restore datafile string
Cause: A RESTORE command for the specified datafile could not find a destination name for the specified datafile.
Action: Add a SET NEWNAME command prior to the RESTORE command to specify the restore destination for this file.
RMAN-06086: offline files may only be skipped in a datafile backup set
Cause: The SKIP OFFLINE option was specified for an archived log backup set.
RMAN-06087: read-only files may only be skipped in a datafile backup set
Cause: The SKIP READONLY option was specified for an archived log backup set.
RMAN-06088: datafile copy string not found or out of sync with catalog
Cause: The indicated file is not found, or is found but is not the same file that the recovery catalog thinks it is. It is likely that some operation outside of Recovery Manager has altered the file, or that Recovery Manager has not resynced with the target database.
Action: Re-catalog the file and retry the operation.
RMAN-06089: archived log string not found or out of sync with catalog
RMAN-06090: error while looking up control file copy: string
Cause: An error occurred while looking up the specified control file copy in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. Ensure that the file name is entered correctly. If the control file copy was created when the recovery catalog was not available, then a RESYNC CATALOG must be done to update the recovery catalog.
RMAN-06091: no channel allocated for maintenance (of an appropriate type)
Cause: A command was entered that requires a maintenance channel, and no maintenance channel is allocated, or none of the appropriate type.
Action: Use ALLOCATE CHANNEL FOR MAINTENANCE before deleting backup pieces, or using the CROSSCHECK or DELETE EXPIRED commands. Proxy copies require a non-DISK channel.
RMAN-06092: error while looking up backup piece
Cause: An error occurred while looking up the specified backup piece in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. Ensure that the name or key is entered correctly. If the backup piece was created when the recovery catalog was not available, then a RESYNC CATALOG must be done to update the recovery catalog.
RMAN-06093: recovery catalog contains obsolete version of datafile string
Cause: The specified datafile number was dropped and then reused. The control file mounted by the target database contains the newer version of the datafile, but the recovery catalog contains information about only the older version.
Action: Issue a RESYNC command to update the recovery catalog, then reissue the failing command. If the error persists, contact Oracle Support Services.
RMAN-06094: datafile string must be restored
Cause: A RECOVER command was issued, and the recovery catalog indicates the specified datafile should be part of the recovery, but this datafile is not listed in the control file, and cannot be found on disk.
Action: Issue a RESTORE command for this datafile, using the same UNTIL clause specified to the RECOVER command (if any), then reissue the RECOVER.
RMAN-06095: a backup control file must be restored to recover datafile string
Cause: The control file currently mounted by the target database contains a newer incarnation of the datafile than the recovery catalog indicates is appropriate for the Point-in-Time being recovered to.
Action: Restore the control file, using the same UNTIL clause specified on the failing RECOVER command, then reissue the command. If no control file can be restored, then you should issue a CREATE CONTROLFILE command.
RMAN-06096: SWITCH required for newname of datafile string to take effect
Cause: A SET NEWNAME was issued for this datafile, but no SWITCH command was issued before the RECOVER command.
Action: Issue a SWITCH command to make the newname take effect before doing RECOVER.
RMAN-06098: the target database must be mounted when issuing a BACKUP command
Cause: A BACKUP command was issued, but the target database control file is not mounted.
RMAN-06099: error occurred in source file: string, line: number
Cause: See accompanying error.
Action: See accompanying error.
RMAN-06100: no channel to restore a backup or copy of datafile number
Cause: A datafile, tablespace, or database restore could not proceed because the backup of the indicated file exists on a device type that was not allocated for restore.
RMAN-06101: no channel to restore a backup or copy of the control file
Cause: A control file restore could not proceed because the backup of the indicated file exists on a device type that was not allocated for restore.
RMAN-06102: no channel to restore a backup or copy of archived log for thread number with sequence number and starting SCN of string
Cause: An archived log restore restore could not proceed because the backup of the indicated file exists on a device type that was not allocated for restore.
RMAN-06103: duplicate qualifier found in REPORT command: string
Cause: The indicated qualifier appears more than once in a REPORT qualifier list.
Action: delete the duplicate qualifier
RMAN-06105: duplicate qualifier found in LIST command: string
Cause: The indicated qualifier appears more than once in a LIST qualifier list.
RMAN-06106: this command requires that target database be mounted
Cause: A command was issued that requires the target database to be mounted, but the target database is not mounted.
RMAN-06107: WARNING: control file is not current for REPORT NEED BACKUP DAYS
Cause: The REPORT NEED BACKUP DAYS command may report some files as requiring backups when they really do not, because the most current online status of the file is not known unless a current control file is mounted.
Action: No action is required, however, a current control file should be mounted, if possible, to get the most accurate REPORT output.
RMAN-06108: changed datafile copy unavailable
RMAN-06109: changed archived log unavailable
RMAN-06110: changed control file copy unavailable
RMAN-06111: changed backup piece unavailable
RMAN-06112: changed datafile copy available
RMAN-06113: changed archived log available
RMAN-06114: changed control file copy available
RMAN-06115: changed backup piece available
RMAN-06116: cannot crosscheck unavailable object
Cause: An attempt was made to crosscheck an object which is unavailable.
Action: Make object available and try again or don't crosscheck object.
RMAN-06117: cannot do DELETE EXPIRED on an object which is not expired
Cause: An attempt was made to DELETE EXPIRED an object which is not expired.
Action: Remove EXPIRED keyword, crosscheck object, or don't delete object.
RMAN-06118: a backup control file older than SCN string must be used for this recovery
Cause: An attempt was made to recover the database, but some files had no backup, and were not present in the control file at the beginning of the restore. This happens when the control file used during the recovery is a backup control file taken before the creation of some of the files that had no backup. In this situation, the control file that is used must be taken before the creation of all files that have no backup. This will enable RMAN to automatically re-create all of the files that had no backup.
Action: Restore a control file that was backed up before the specified system change number (SCN). The following RMAN commands can be used to do this: SET UNTIL SCN x; (where x is the SCN displayed in the message) RESTORE CONTROLFILE;
RMAN-06119: uncataloged datafile copy
RMAN-06120: uncataloged archived log
RMAN-06121: uncataloged control file copy
RMAN-06122: CHANGE .. UNCATALOG not supported for BACKUPSET
Cause: The CHANGE BACKUPSET .. UNCATALOG command was entered. The UNCATALOG operation is not supported with backup set.
Action: Use CHANGE BACKUPSET .. DELETE instead.
RMAN-06123: operation not supported without the recovery catalog or mounted control file
Cause: A command was used which requires a connection to a recovery catalog database or the target database to be mounted. The command cannot be used when no backup repository is available.
Action: If a recovery catalog database is available, then connect to the recovery catalog and retry the command, otherwise enter a different command.
RMAN-06124: error while looking up datafile copy key: number
Cause: An error occurred while looking up the specified datafile copy key in the recovery catalog or target database control file.
RMAN-06125: error while looking up archived log key: number
Cause: An error occurred while looking up the specified archived log key in the recovery catalog or target database control file.
RMAN-06126: skipping offline file string
Cause: The indicated file will not be included in the backup set because it is offline and the SKIP OFFLINE option was specified.
RMAN-06127: skipping read-only file string
Cause: The indicated file could not be included in the backup set because it was read-only and the SKIP READONLY option was specified.
RMAN-06128: skipping inaccessible file string
Cause: The indicated file will not be included in the backup set because it could not be read, and the SKIP INACCESSIBLE option was specified.
RMAN-06129: invalid reserved channel ID: string
Cause: The specified channel id is invalid. DELETE and DEFAULT are reserved channel names and may not be specified by users.
Action: Specify a different channel ID.
RMAN-06131: SKIP OFFLINE and SKIP READONLY are only allowed with current control file
Cause: The target database control file was not current. The SKIP OFFLINE and SKIP READONLY options are only permitted when the target database control file is current. When the target control file is not current, it is not possible to obtain a datafile's offline or read-only status.
Action: Remove the SKIP option or mount a current control file on the target database.
RMAN-06132: cannot backup datafile string because it is not in the control file
Cause: A backup command was issued that includes the specified datafile, but the datafile is not listed in the control file. The control file is not current (it is a backup or a created control file).
Action: Recover the control file to make it current, then retry the backup command.
RMAN-06133: recovery catalog may have obsolete data for datafile string
Cause: A RESTORE UNTIL was issued, and the recovery catalog choose an older incarnation of the datafile than is listed in the control file.
Action: If the recovery catalog has correct data for the datafile, then restore a backup control file using the same UNTIL clause, then retry the datafile restore. Otherwise, restore a backup of the incarnation of the datafile listed in the control file.
RMAN-06134: host command complete
Cause: An operating system command has completed.
RMAN-06135: error executing host command: string
Cause: A host command returned a non-zero return code.
Action: Correct the offending command.
RMAN-06136: ORACLE error from auxiliary database: string
RMAN-06137: must have recovery catalog for REPORT SCHEMA AT TIME
Cause: A 'REPORT SCHEMA at_clause' command was issued, but there is no recovery catalog database.
Action: If you are not using a recovery catalog, then you may only issue the 'REPORT SCHEMA' command with no at_clause.
RMAN-06138: control file not mounted - must specify AT clause with REPORT command
Cause: A 'REPORT SCHEMA' with no at_clause was issued, and there is no recovery catalog, and there is also no control file mounted at the target database, so there is no place to get the information about the current list of files comprising the database.
Action: Use a recovery catalog or mount a control file at the target database.
RMAN-06139: WARNING: control file is not current for REPORT SCHEMA
Cause: A 'REPORT SCHEMA' with no at_clause was issued, and there is no recovery catalog, and the control file mounted by the target instance is not current, so the information about the current list of datafiles may not be current.
Action: Use a recovery catalog or mount a current control file.
RMAN-06140: cannot specify TAG option with LIST INCARNATION
Cause: The TAG option was specified with LIST INCARNATION. This is not permitted because there is no TAG associated with a database incarnation.
Action: Remove the TAG option and re-run the LIST command.
RMAN-06141: cannot specify ARCHIVELOG LIKE option with RESTORE
Cause: The ARCHIVELOG LIKE option was specified with RESTORE. This is not permitted because recovery catalog contains only those records that are not deleted from disk.
Action: Remove the ARCHIVELOG LIKE option and re-run the command.
RMAN-06142: DEVICE TYPE cannot be specified with this command
Cause: The DEVICE TYPE option was specified with a command that does not support it.
Action: Remove the DEVICE TYPE option and re-run the command.
RMAN-06143: LIKE may only be specified with COPY
Cause: The LIKE option was specified with a RMAN command. This is not permitted because only copies of datafiles, control files or archived logs have file names that may be tested with a LIKE operand.
Action: Remove the LIKE option and re-run the RMAN command.
RMAN-06144: FROM or UNTIL may not be specified with LIST INCARNATION
Cause: The FROM or UNTIL option was specified with LIST INCARNATION. This is not permitted because there is no time associated with a database incarnation.
Action: Remove the FROM or UNTIL option and re-run the LIST command.
RMAN-06145: control file is not current - obsolete file list may be incomplete
Cause: A CHANGE or REPORT command needs to compute the list of backups that are redundant and may be deleted. If the mounted control file is not current, it may not be possible to determine if a satisfactory backup exists for files which have been offline since the last OPEN RESETLOGS.
Action: No action need be taken - this is an informational message only. To ensure a complete report of obsolete backups, mount a current control file.
RMAN-06146: changes found for file number beyond offline SCN
Cause: A CHANGE or REPORT command needs to compute the list of backups that are redundant and may be deleted. A backup was found for a file which is shown as offline in the target database control file, but the backup contains changes beyond the system change number(SCN) when the file went offline. This is most likely because the target database control file is not really current, but is a restored copy of an older control file.
Action: Mount a current control file or a backup control file.
RMAN-06147: no obsolete backups found
Cause: A CHANGE or REPORT command could find no files that meet the specified criteria for obsoleteness.
RMAN-06148: redundancy count must be greater than zero
Cause: The REDUNDANCY operand specified for a CHANGE or REPORT OBSOLETE command was zero.
Action: Specify a REDUNDANCY operand of 1 or greater.
RMAN-06149: cannot BACKUP DATABASE in NOARCHIVELOG mode
Cause: A BACKUP DATABASE command was issued, but the target database was in NOARCHIVELOG mode and was open in READ/WRITE mode.
Action: Mount the target database control file by issuing ALTER DATABASE ARCHIVELOG using the Enterprise Manager or Server Manager.
RMAN-06150: auxiliary name for datafile number set to: string
Cause: This message is issued in response to a CONFIGURE AUXNAME command.
RMAN-06151: datafile string creation SCN string
Cause: This is an informational message. It should be accompanied by other messages.
Action: None
RMAN-06153: validation failed for datafile copy
Cause: The CHANGE DATAFILECOPY VALIDATE command discovered that the datafile copy could not be found or no longer contains the same data, so its record was deleted from the recovery catalog or target database control file.
RMAN-06154: validation succeeded for datafile copy
Cause: The CHANGE DATAFILECOPY VALIDATE command discovered that the datafile copy still matches its data in the recovery catalog or target database control file.
RMAN-06155: validation failed for control file copy
Cause: The CHANGE CONTROLFILECOPY VALIDATE command discovered that the control file copy could not be found or no longer contains the same data, so its record was deleted from the recovery catalog or target database control file.
RMAN-06156: validation succeeded for control file copy
Cause: The CHANGE CONTROLFILECOPY VALIDATE command discovered that the control file copy still matches its data in the recovery catalog or target database control file.
RMAN-06157: validation failed for archived log
Cause: The CROSSCHECK ARCHIVELOG command determined that the archived log could not be found or no longer contained the same data, so its record was marked expired.
RMAN-06158: validation succeeded for archived log
Cause: The CROSSCHECK ARCHIVELOG command or VALIDATE HEADER option determined that the archived log still matches its data.
RMAN-06159: error while looking up backup set
Cause: An error occurred while looking up the specified backup set in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. Ensure that the key is entered correctly. If the backup set was created when the recovery catalog was not available, then a RESYNC CATALOG must be done to update the recovery catalog.
RMAN-06160: no backup pieces found for backup set key: number
Cause: No backup pieces for the requested backup set were found in the recovery catalog, or the target database control file.
Action: Specify an existing backup set.
RMAN-06161: error when inspecting auxiliary file name: string
Cause: This error is accompanied by other errors explaining the cause.
Action: Correct the auxiliary file name if it is wrong via the CONFIGURE AUXNAME command.
RMAN-06162: sql statement: string
Cause: This is the sql statement about to be executed for a SQL command.
Action: None, informational message only.
RMAN-06163: some datafiles cannot be recovered, aborting the RECOVER command
Cause: This message should be followed by one or more 6162 or 6164 messages.
RMAN-06164: WARNING: no channel of required type allocated to recover datafile number
Cause: A RECOVER command could not proceed because incremental backup sets or archived log backup sets exist on a device type that has not been allocated.
Action: Use the LIST command to determine which device type is needed, then allocate a channel of that type.
RMAN-06165: datafile string is too old to recover, restore a more recent copy
Cause: The archived logs and/or incremental backup sets required to recover the datafile do not exist, but a more recent backup of the datafile exists which can be recovered.
Action: Issue a RESTORE for the datafile, then reissue the RECOVER command.
RMAN-06166: datafile string cannot be recovered
Cause: Incremental backups or archived redo logs needed to recover the datafile cannot be found, and no recoverable full backup or datafile copy exists.
Action: Use the LIST command to see if there is a backup set or datafile copy that can be made AVAILABLE. If not, then the datafile is unrecoverable. If a full or datafile copy exists, then a Point-in-Time Recovery may be possible.
RMAN-06167: already connected
Cause: a CONNECT command was issued, but RMAN is already connected to the specified database.
Action: RMAN has no DISCONNECT command, so to connect to a different instance, exit RMAN and start it again.
RMAN-06168: no backup pieces with this tag found: string
Cause: A tag was used to specify a list of backup pieces, but no backup pieces with this tag could be found.
Action: Make sure the tag is specified correctly.
RMAN-06169: could not read file header for datafile string error reason string
Cause: The specified datafile could not be accessed. The reason codes are: 1 - file name is MISSINGxx in the control file 2 - file is offline 3 - file is not verified 4 - DBWR could not find the file 5 - unable to open file 6 - I/O error during read 7 - file header is corrupt 8 - file is not a datafile 9 - file does not belong to this database 10 - file number is incorrect 12 - wrong file version 15 - control file is not current
Action: If the error can be corrected, do so and retry the operation. The SKIP option can be used to ignore this error during a backup.
RMAN-06170: no control file copy found with offline range RECID string STAMP string datafile string
Cause: This offline range is needed for recovering the specified data file, but the offline range record has aged out of the current control file and no control file copy with the record could be accessed. At least 1 control file copy containing the offline range was found in the recovery catalog and was in AVAILABLE status.
Action: Query the RC_CONTROLFILE_COPY view for the names of all control file copies, then issue a CHANGE CONTROLFILECOPY ... VALIDATE; command for them. Then reissue the RECOVER command.
RMAN-06171: not connected to target database
Cause: A command was issued but no connection to the target database has been established.
Action: Issue a CONNECT TARGET command to connect to the target database.
RMAN-06172: no AUTOBACKUP found or specified handle is not a valid copy or piece
Cause: A restore could not proceed because no AUTOBACKUP was found or specified handle is not a valid copy or backup piece. In case of restore from AUTOBACKUP, it may be the case that a backup exists, but it does not satisfy the criteria specified in the user's restore operands. In case of restore from handle, it may be the handle is not a backup piece or control file copy. In may be that it does not exist.
Action: Modify AUTOBACKUP search criteria or verify the handle.
RMAN-06173: SET NEWNAME command has not been issued for datafile string when restore auxiliary
Cause: Auxiliary type was specified for the control file, but no SET NEWNAME command has been previously issued for a datafile.
Action: Issue SET NEWNAME command for every datafile in the recovery set.
RMAN-06174: not connected to auxiliary database
Cause: An auxiliary command was issued but no connection to a auxiliary database has been established.
Action: Issue a CONNECT AUXILIARY command to connect to the auxiliary database.
RMAN-06175: deleted script: string
Cause: A DELETE SCRIPT command was executed.
RMAN-06176: no recovery required; all files are read-only or offline
Cause: An attempt was made to recover files that were offline or read-only. A RECOVER DATABASE command does not need to recover any files because all of the files to be recovered are offline or read-only. This can only occur when the SKIP clause includes the SYSTEM tablespace.
Action: None. This is an informational message only.
RMAN-06177: restore not done; all files read only, offline, or already restored
Cause: A RESTORE command does not need to restore any files, because all of the files to be restored are offline, read-only, or are already restored to their correct destinations.
RMAN-06178: datafile number not processed because file is offline
Cause: A RESTORE DATABASE or RECOVER DATABASE command omitted processing the indicated datafile because it is offline clean at the desired point-in-time.
RMAN-06179: datafile number not processed because file is read-only
Cause: A RESTORE DATABASE or RECOVER DATABASE command omitted processing the indicated datafile because it is part of a read-only tablespace at the desired point-in-time.
RMAN-06180: incremental backups require Enterprise Edition
Cause: A BACKUP command with INCREMENTAL LEVEL > 0 was specified.
Action: Use FULL, or INCREMENTAL LEVEL 0.
RMAN-06181: multiple channels require Enterprise Edition
Cause: Attempt to allocate more than 1 channel in a job.
Action: Remove all except one ALLOCATE CHANNEL command.
RMAN-06182: archived log string of thread string with sequence string larger than MAXSETSIZE
Cause: A BACKUP ARCHIVELOG command specified the MAXSETSIZE operand too low. The specified archived log is larger than MAXSETSIZE will allow.
Action: Increase MAXSETSIZE limit.
RMAN-06183: datafile or datafile copy string (file number string) larger than MAXSETSIZE
Cause: A BACKUP DATAFILE(copy) command specified the MAXSETSIZE operand too low. The specified datafile is larger than MAXSETSIZE will allow.
RMAN-06184: duplicate object in backup specifier: string string
Cause: A backup command specifies the same datafile or copy of a data file multiple times.
Action: Eliminate the duplicates.
RMAN-06185: Recovery Manager incompatible with string database: RMAN number.number.number.number to number.number.number.number required
Cause: This version of recovery manager was incompatible with the indicated database or the DBMS_BACKUP_RESTORE package installed in the indicated database.
Action: If the database has been upgraded from an earlier version, ensure that the catxxxx.sql script has been run successfully. Re-install dbmsbkrs.sql and prvtbkrs.plb if necessary. Otherwise, use a version of RMAN within the range specified in the error message.
RMAN-06186: PL/SQL package string.string version string in string database is too old
Cause: The specified PL/SQL package is a version that is too old to work with this version of the Recovery Manager (RMAN).
Action: If the database indicated is CATALOG, then you can use the UPGRADE CATALOG command to upgrade the recovery catalog to the most current version. If the database is TARGET or AUXILIARY, then you must either upgrade the specified database or use an older version of RMAN.
RMAN-06187: control file copy string not found or out of sync with catalog
RMAN-06188: cannot use command when connected to a mounted target database
Cause: An attempt was made to issue a command that can be used only when there is no connection to the target database or when the target database is not mounted.
Action: Dismount the database or restart RMAN and use the command before connecting to the target database.
RMAN-06189: current DBID number does not match target mounted database (number)
Cause: SET DBID was used to set a DBID that does not match the DBID of the database to which RMAN is connected.
Action: If the current operation is a restore to copy the database, do not mount the database. Otherwise, avoid using the SET DBID command, or restart RMAN.
RMAN-06190: PL/SQL package string.string version string in string database is not current
Cause: RMAN detected an old version of the specified package. RMAN will execute in backwards-compatible mode.
Action: No action is required, but certain features and bug-fixes may not be available when RMAN runs in backwards-compatible mode. If the database is CATALOG, then you can use the UPGRADE CATALOG command to upgrade the recovery catalog to the most current version. If the database is TARGET or AUXILIARY, then you must either upgrade the specified database or use an older version of RMAN. The files that must be run to upgrade the target or auxiliary database are dbmsrman.sql and prvtrman.plb.
RMAN-06191: PL/SQL package string.string version string in string database is too new
Cause: RMAN detected an incompatible version of the specified package.
Action: Use a newer version of recovery manager. Message 6439 indicates the minimum required version of recovery manager.
RMAN-06192: maximum value for MAXPIECESIZE or MAXSETSIZE must be between 1 KB and 2048 GB
Cause: Input size for MAXPIECESIZE or MAXSETSIZE was out of range.
Action: Specify a valid size and retry the command.
RMAN-06193: connected to target database (not started)
Action: The database must be started before any other RMAN commands are issued.
RMAN-06194: target database instance not started
Cause: A command was issued that requires the target database instance be started.
Action: Issue a STARTUP command to start the instance.
RMAN-06195: auxiliary database not started
Cause: A command was issued that requires the auxiliary database instance be started.
Action: Issue a STARTUP AUXILIARY command.
RMAN-06196: Oracle instance started
Cause: A STARTUP command completed successfully.
Action: None, this is an informational message.
RMAN-06197: Total System Global Area string bytes
Action: No action is required.
RMAN-06198: string string bytes
RMAN-06199: database mounted
RMAN-06200: Changed string objects to AVAILABLE status
RMAN-06201: Deleted string objects
RMAN-06202: Deleted string EXPIRED objects
RMAN-06203: Changed KEEP options for string objects
RMAN-06204: Changed string objects to UNAVAILABLE status
RMAN-06205: Uncataloged string objects
RMAN-06206: Crosschecked string objects
RMAN-06207: WARNING: string objects could not be deleted for string channel(s) due
RMAN-06208: to mismatched status. Use CROSSCHECK command to fix status
RMAN-06209: List of failed objects
RMAN-06210: List of Mismatched objects
RMAN-06211: ==========================
RMAN-06212: Object Type Filename/Handle
RMAN-06213: --------------- ---------------------------------------------------
RMAN-06214: string string
RMAN-06215: List of objects that must perform same operation at other database
Action: The specified list of objects were not accessible at connected target database. Re-run the CROSSCHECK command after connecting to database that has DB_UNIQUE_NAME displayed in output for the specified object.
RMAN-06216: WARNING: db_unique_name mismatch - string objects could not be updated
Cause: This is an informational message only.
Action: Run CROSSCHECK command after connecting to a primary or physical standby database that can access the specified objects.
RMAN-06217: not connected to auxiliary database with a net service name
Cause: A command that moves files from the target instance to the auxiliary instance was requested. Such a command requires a net service name be present in the connect string used to connect to the auxiliary instance.
Action: Issue a CONNECT AUXILIARY command and include a net serice name in the connect string. That service name must be valid on the target instance.
RMAN-06218: List of objects requiring same operation on database with db_unique_name string
Action: The specified list of objects were not accessible by the target database. Re-run the same command after connecting to database that has DB_UNIQUE_NAME displayed in output for the specified object.
RMAN-06219: List of objects not associated with all known db_unique_names
Action: The specified list of objects were not accessible by the target database. Re-run the same command after connecting to primary database or physical standby database that can access the specified objects.
RMAN-06220: \nCreating automatic instance, with SID='string'
Cause: No connection to the auxiliary instance was provided, but the command requires an auxiliary instance.
Action: No action is required unless you want to create a permanent database, in which case you should stop the command and re-run it, providing an auxiliary instance connection.
RMAN-06221: \nRemoving automatic instance
Cause: RMAN is removing the automatic auxiliary instance that was created for this command.
RMAN-06223: starting up automatic instance string\n
RMAN-06224: Automatic instance created
RMAN-06225: shutting down automatic instance string\n
RMAN-06226: Automatic instance removed
RMAN-06230: List of Stored Scripts in Recovery Catalog
Cause: This message is issued in response to a LIST SCRIPT NAMES command. The following fields are shown for each script that is stored in the recovery catalog: Header indicating to what database the script belongs. Script Name: name of the script. Description: comment associated with this script.
RMAN-06238: List of Databases
Cause: This message is issued in response to a LIST DB_UNIQUE_NAME command. The following fields are shown for each database that is known to the recovery catalog: DB Key: This is the unique key which identifies this database in the recovery catalog. DB Name: The name of the database. DB ID: The database ID. This is a number which remains the same for the life of the database, even if the database name is changed. DB_UNIQUE_NAME: db_unique_name value for the database.
RMAN-06246: List of Database Incarnations
Cause: This message is issued in response to a LIST INCARNATION OF DATABASE command. The following fields are shown for each database that is registered with the recovery catalog: DB Key: This is the unique key which identifies this database in the recovery catalog. Inc Key: This is the unique key which identifies this incarnation of the database in the recovery catalog. DB Name: The name of the database. DB ID: The database ID. This is a number which remains the same for the life of the database, even if the database name is changed. Status: 'YES' if this is the current incarnation of this database, otherwise 'NO'. Reset SCN: system change number (SCN) of the most recent RESETLOGS operation. Reset Time: Time of the most recent RESETLOGS operation.
RMAN-06250: Report of files that need backup due to unrecoverable operations
Cause: An unlogged change (such as 'create table unrecoverable') has been made to this file, and the most recent backup of the file does not contain those changes.
Action: Take a backup of this file. If this file is lost before a backup is taken, then the unlogged modifications will be lost. The message indicates whether a full backup is required or whether a incremental backup will suffice.
RMAN-06263: string string string
Cause: This message is issued in response to the REPORT NEED BACKUP INCREMENTAL command, for those files which would use more than the specified number of incrementals during recovery.
Action: To reduce the number of incremental backups which would be used during recovery of this datafile, take a new full backup of this file now.
RMAN-06270: Report of files whose recovery needs more than number days of archived logs
Cause: This message is issued in response to the REPORT NEED BACKUP DAYS command for those files which need more than the specified number of days' archived logs for recovery.
Action: To reduce the number of log files needed for recovery of this datafile, take a new full or incremental backup now.
RMAN-06274: Report of files that must be backed up to satisfy number days recovery window
Cause: This message is issued in response to the REPORT NEED RECOVERY WINDOW OF n DAYS command for those files that must be backed up to satisfy specified retention policy.
Action: To satisfy specified recovery window for this datafile, take a new full or incremental backup now.
RMAN-06275: invalid number of days specified for report : string days
Cause: This message is issued in response to the REPORT NEED RECOVERY WINDOW OF n DAYS or REPORT NEED BACKUP DAYS n command when an invalid number of days was specified in input command.
Action: The number of days specified in REPORT command must be greater than zero.
RMAN-06280: Report of obsolete backups and copies
Cause: This message is issued in response to the REPORT OBSOLETE command. Each of the files listed is obsolete because it is more redundant than the level of redundancy specified in the REPORT command.
Action: Depending on your needs, you might need to take new backups.
RMAN-06290: Report of database schema for database with db_unique_name string
Cause: This message is issued in response to the REPORT SCHEMA command. The report shows the physical schema of the database at the indicated time. The following fields are shown for each datafile and tempfile: File: The file number. Size(MB): The size of the file in mega bytes. Tablespace: The name of the tablespace which contains this file. RB segs: YES if this file is part of a tablespace containing rollback segments, otherwise NO. Datafile/Tempfile Name: The file name. Maxsize(MB): Maximum file size to which file can be extended
RMAN-06300: Report of files with less than number redundant backups
Cause: This message is issued when the REPORT NEED BACKUP REDUNDANCY command is used for those files which have less than the specified number of backups which can be used for recovery.
Action: Take another backup of the datafiles listed.
RMAN-06306: ====================
Cause: This message is issued in response to a LIST BACKUP DATABASE/TABLESPACE/DATAFILE command when some backups were taken with the PROXY option. If a recovery catalog is in use, then the information comes from the recovery catalog, otherwise it comes from the target database control file. The following fields are shown for each proxy datafile backup. Key: This is the unique key which identifies this proxy backup in the recovery catalog. This value can be used in a CHANGE command to change its status. If the target database control file is being used as the recovery catalog, then this field uniquely identifies this copy in the control file. File: The file number that this file was copied from. Status: This is the status of the file. Possible values are: A - Available U - Unavailable D - Deleted X - Expired Status 'U' will not be used if the target database control file is being used as the recovery catalog. Completion time: This is the date and time when the backup was created. This column will be printed in the default Oracle date format, unless overridden with a NLS_DATE_FORMAT environment variable. Ckp SCN: This is the checkpoint system change number (SCN) of the backup. The file contains all changes made at or before this SCN. Ckp time: This is the time that the file was last checkpointed. Handle: This is the media manager handle of the proxy backup.
RMAN-06378: List of Backup Sets
Cause: This message is issued in response to a LIST BACKUP command.
RMAN-06400: database opened
RMAN-06401: database is already started
Cause: A STARTUP command without the FORCE option was issued, but the target database is already started.
Action: Use the FORCE option if you want to restart the database.
RMAN-06402: Oracle instance shut down
RMAN-06403: could not obtain a fully authorized session
Cause: The most likely cause of this error is that one of the databases to which RMAN had previously connected is not started or has has been shutdown. Other error messages should identify exactly which database is the problem.
Action: Startup the database causing the problem.
RMAN-06404: database dismounted
RMAN-06405: database closed
RMAN-06406: deleted archived log
RMAN-06407: auxiliary instance file string deleted
RMAN-06408: recovery catalog upgraded to version string
Cause: This is an informational message issued by the UPGRADE CATALOG command. It indicates the version of the recovery catalog schema to which the recovery catalog was just upgraded. Note that this version number may not reflect the version number of your rman executable or target database, because the recovery catalog schema is not changed with each Oracle release.
RMAN-06409: LIKE clause in LIST BACKUP OF ARCHIVELOG is not supported
Cause: LIST BACKUP OF ARCHIVELOG LIKE was used, which is not supported.
Action: Remove LIKE clause from command.
RMAN-06410: cannot use command when channels are allocated
Cause: An attempt was made to issue a command that can be used only when there are no allocated channels.
Action: Do not use the command, or de-allocate channels and use the command when no channels are allocated.
RMAN-06411: backup copies setting out of range (1-4): number
Cause: An attempt was made to set backup copies to an invalid value.
Action: Use a value in the specified range.
RMAN-06412: no proxy copy channel found
Cause: A proxy copy was started, but no allocated channel supports proxy copy. This could be because the media management software used by the target database does not support proxy copy, or because all of the allocated channels are of type DISK, which never support proxy copy.
Action: If this is a backup, then either allocate a non-disk channel, or do not use the PROXY option. If this is a restore, then a channel of the same type which created the proxy backup was allocated, but now does not support proxy copy. If proxy copy is no longer supported by the media management software at the target database, the CROSSCHECK or CHANGE commands should be used so that those backups will not be considered for further restores.
RMAN-06413: channel string does not support proxy copy
Cause: The channel which was specified for this backup or restore does not support proxy copy. This could be because the media management software used by the target database does not support proxy copy, or because the channel is of type DISK, which never supports proxy copy.
Action: If this is a backup, then either allocate a non-disk channel, or do not use the PROXY option. If this is a restore, then a channel of the same type which created the proxy backup was allocated, but now does not support proxy copy. If proxy copy is no longer supported by the media management software at the target database, the CROSSCHECK command should be used so that those backups will not be considered for further restores.
RMAN-06414: target database COMPATIBLE option does not support proxy copy
Cause: PROXY was specified, and the target database uses a media manager that supports proxy copy, but the COMPATIBLE initialization parameter of the target database must be 8.1.0 or greater to create proxy backups. If the database is downgraded to the earlier release that is specified in the COMPATIBLE parameter, then it will no longer be able to restore proxy backups.
Action: Either take a non-proxy backup or change the target database COMPATIBLE parameter.
RMAN-06415: file string cannot be proxy backed up
Cause: The PROXY option was specified, but the media management software used by the target database cannot back up the specified file using proxy copy. If PROXY ONLY was specified, then the backup is terminated. If PROXY was specified, then this file will be placed into a non-proxy backup set.
Action: Remove the ONLY option to place the files into a regular backup set, or contact the media management vendor if you believe that the media management software should support proxy copy of this file.
RMAN-06416: PROXY ONLY was specified and some files could not be proxy copied
Cause: PROXY ONLY was specified, and some of the files to be backed up could not be backed up by the media management software used by the target database. Message 6415 is issued for each file that cannot be proxy copied.
Action: Remove the ONLY option to place the files into a regular backup set, or contact the media management vendor if you believe that the media management software should support proxy copy of these files.
RMAN-06417: command not allowed when connected to a virtual private catalog
Cause: The command that was entered cannot be used while connected to a virtual private catalog.
Action: Connect to the base catalog and re-execute the command.
RMAN-06418: proxy incremental backups with level > 0 not supported
Cause: PROXY was specified for a non-level-zero incremental backup. Proxy backups may only be full or level 0 backups.
Action: Remove one of the conflicting options.
RMAN-06419: file string cannot be proxy restored from handle string
Cause: The media management software used by the target database indicated that it cannot restore the specified file from the specified backup handle.
Action: Consult the media management software documentation to find out why this restriction exists or contact the media management vendor.
RMAN-06420: some files could not be proxy restored - aborting restore
Cause: Some of the files to be restored could not be restored by the media management software used by the target database. Message 6419 is issued for each file that cannot be restored.
Action: Contact the media management vendor if you believe that the media management software should support proxy copy of these files. The CROSSCHECK or CHANGE commands can be used to remove these proxy copies from the catalog to prevent the RESTORE command from trying to restore from them.
RMAN-06421: sent command to channel: string
RMAN-06422: no channels found for SEND command
Cause: No channels with the specified names or device types were found. If no channel qualifiers were specified, then no channels were allocated.
Action: Specify a different channel type or allocate a channel of the desired type.
RMAN-06423: requested limit of number exceeds vendor limit of number
Cause: A command was used to set the backup piece size limit, but the media management software used by the target database cannot create backup pieces that large.
Action: Specify a smaller backup piece limit.
RMAN-06424: error while looking up proxy copy
Cause: An error occurred while looking up the specified proxy copy in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. Ensure that the name or key is entered correctly. If the proxy copy was created when the recovery catalog was not available, then a RESYNC CATALOG must be done to update the recovery catalog.
RMAN-06425: datafile pathname not available
RMAN-06426: RECOVERY_CATALOG_OWNER role must be granted to user string
Cause: The CREATE CATALOG or UPGRADE CATALOG command was used, but the USERID that was supplied in the CATALOG connect string does not have the RECOVERY_CATALOG_OWNER role granted as a DEFAULT role.
Action: Grant the RECOVERY_CATALOG_OWNER role to the recovery catalog owner.
RMAN-06427: recovery catalog already exists
Cause: The CREATE CATALOG command cannot be used when the recovery catalog already exists.
Action: Use the UPGRADE CATALOG command to upgrade your recovery catalog to the most current release without losing any existing backup data. Use the DROP CATALOG command to remove an existing recovery catalog.
RMAN-06428: recovery catalog is not installed
Cause: A recovery catalog database connection has been made, but the recovery catalog tables and views have not been installed.
Action: If you mis-typed the recovery catalog owner USERID, then correct the USERID and reconnect to the recovery catalog. If this is the first time that you have signed on to Recovery Manager with this recovery catalog owner USERID, then use the CREATE CATALOG command to create the recovery catalog schema. Alternatively, exit RMAN and connect without specifying a recovery catalog connection.
RMAN-06429: string database is not compatible with this version of RMAN
Cause: The indicated database is not compatible with this version of the Recovery Manager (RMAN). Other messages have also been issued which detail the cause of the error.
Action: See the other messages. If the database is CATALOG, then you may be able to use the CREATE CATALOG or UPGRADE CATALOG commands to correct the problem. If the database is TARGET or AUXILIARY, then you must either upgrade the target database or use a newer version of the RMAN executable.
RMAN-06430: recovery catalog USERID cannot be SYS
Cause: A recovery catalog connection was made to USERID SYS. The recovery catalog must be created in a USERID other than SYS.
Action: Specify a different USERID in the CATALOG connect string.
RMAN-06431: recovery catalog created
Cause: This is an informational message issued by the CREATE CATALOG command.
RMAN-06432: recovery catalog dropped
Cause: This is an informational message issued by the DROP CATALOG command.
RMAN-06433: error installing recovery catalog
Cause: An error was received from the recovery catalog database while it was being installed. Another error message shows the error message from the server.
Action: The most common reasons for failure to install the recovery catalog are: - Lack of space in the recovery catalog database: allocate more space, use the DROP CATALOG command to remove any partially installed recovery catalog, and retry the command. - Object already exists: This is caused by a partial recovery catalog installation. Use the DROP CATALOG command to remove the partially installed recovery catalog and retry the command.
RMAN-06434: some errors occurred while removing recovery catalog
Cause: Some errors were received from the recovery catalog database while removing the recovery catalog.
Action: Correct the error(s) and retry the command. Note that Recovery Manager intercepts and ignores common errors, such as 'object not found', which can happen while removing a partially installed recovery catalog. Only serious errors will be displayed while removing the recovery catalog.
RMAN-06435: recovery catalog owner is string
Cause: This is an informational message issued by the UPGRADE CATALOG and DROP CATALOG commands.
RMAN-06437: cannot drop catalog - catalog is newer than this RMAN
Cause: The DROP CATALOG command was entered, but the recovery catalog was created by a newer version of the Recovery Manager (RMAN). This version of RMAN may not be able to drop the entire recovery catalog.
Action: Use the version of RMAN which most recently created or upgraded the recovery catalog.
RMAN-06438: error executing package DBMS_RCVMAN in string database
Cause: Recovery Manager requires the DBMS_RCVMAN package in the SYS schema of the indicated database. Normally this package is installed during database creation. To re-create the package, run the files dbmsrman.sql and prvtrmns.plb.
Action: re-create the DBMS_RCVMAN package in the SYS schema.
RMAN-06439: RMAN must be upgraded to version string to work with this package
Cause: This message indicates the minimum version of recovery manager required to use the package which was specified in message 6191.
Action: A newer version of RMAN must be used with this package.
RMAN-06440: virtual catalog dropped
Cause: This is an informational message issued by the DROP CATALOG command, when connected to a virtual private catalog. Note that dropping a virtual private catalog does not delete any data, because the catalog data is owned by the base catalog.
RMAN-06441: cannot upgrade catalog - catalog is already newer than this RMAN
Cause: The recovery catalog is already at a version level that is greater than this version of the Recovery Manager. The UPGRADE CATALOG command is not needed.
Action: Either upgrade to a more recent Recovery Manager, or continue to use the current version. Message 6191 will be issued if the recovery catalog is too new to work with this version of Recovery Manager.
RMAN-06443: error upgrading recovery catalog
Cause: An error was received from the recovery catalog database while upgrading the recovery catalog.
Action: Correct the error and retry the command. Note that the Recovery Manager intercepts and ignores common errors, such as 'column already exists,' which can happen if the recovery catalog has already been partially upgraded. Only serious errors will be displayed while upgrading the recovery catalog.
RMAN-06444: error creating string
Cause: During the CREATE CATALOG or UPGRADE CATALOG command, the indicated object could not be created due to errors.
Action: Make sure that the RECOVER.BSQ file has not been modified or damaged, and then if this error persists, contact Oracle support. If the error refers to one of the RMAN PL/SQL packages, connect to the recovery catalog owner and query the USER_ERRORS view to find out the details of the compilation errors.
RMAN-06445: cannot connect to recovery catalog after NOCATALOG has been used
Cause: The CONNECT CATALOG command was used after the user had already specified the NOCATALOG option.
Action: Re-start rman if you wish to use a recovery catalog.
RMAN-06446: changed proxy copy unavailable
RMAN-06447: changed proxy copy available
RMAN-06448: uncataloged proxy copy
RMAN-06449: deleted proxy copy
RMAN-06450: crosschecked proxy copy: found to be 'string'
RMAN-06451: proxy copy handle=string RECID=string STAMP=string
RMAN-06452: string package upgraded to version string
Cause: This is an informational message issued by the UPGRADE CATALOG command. It indicates the version to which the indicated package was just upgraded. Note that this version number may not reflect the version number of your rman executable or target database, because the recovery catalog packages are not changed with each Oracle release.
RMAN-06453: RECOVERABLE may only be used with datafile objects
Cause: An attempt was made to use LIST ... RECOVERABLE .. with OF CONTROLFILE or OF ARCHIVELOG.
Action: Remove the RECOVERABLE keyword and try again.
RMAN-06454: duplexed backups require Enterprise Edition
Cause: The SET COPIES or CONFIGURE BACKUP COPIES command was used to create more than one copy of each backup piece, but Enterprise Edition is not installed.
Action: Do not attempt to create more than one copy of each backup piece.
RMAN-06455: Tablespace Point-in-Time Recovery requires Enterprise Edition
Cause: Tablespace Point-in-Time Recovery was attempted, but Enterprise Edition is not installed.
Action: Do not attempt Tablespace Point-in-Time Recovery.
RMAN-06456: command is obsolete
RMAN-06457: UNTIL SCN (string) is ahead of last SCN in archived logs (string)
Cause: UNTIL SCN cannot be more than the last system change number (SCN) of the last archived log
Action: Check the UNTIL SCN.
RMAN-06458: AS COPY option cannot be used with RECOVERY FILES, RECOVERY AREA or DB_RECOVERY_FILE_DEST
Cause: The RECOVERY FILES, RECOVERY AREA or DB_RECOVERY_FILE_DEST was specified with AS COPY.
Action: Remove the AS COPY option and resubmit the command.
RMAN-06459: BACKUP <VALIDATE|DURATION> is not supported with PROXY
Cause: BACKUP <VALIDATE|DURATION> and PROXY were specified in the same backup command.
Action: Remove the incompatible option.
RMAN-06460: control file copy string cannot be backed up by proxy.
Cause: The PROXY option was specified, but proxy copy of control file is not supported. This file will be placed into a non-proxy backup set.
Action: No action required, this is an informational message.
RMAN-06461: current control file cannot be backed up by proxy.
RMAN-06462: no backup sets found on device DISK that match specification
Cause: A backup set record specifier did not match an backup set on device DISK in the recovery catalog.
Action: Resubmit the command with a different backup set record specifier. The Recovery Manager (RMAN) LIST command can be used to display all backup sets that RMAN knows about.
RMAN-06463: Backup set key string cannot be backed up by proxy.
Cause: The PROXY option was specified, but proxy copy of backup set is not supported. This file will be placed into a non-proxy backup set.
RMAN-06464: BACKUP BACKUPSET is not supported with VALIDATE option
Cause: BACKUP BACKUPSET and VALIDATE were specified in the same backup command.
Action: To validate a backup set, use the VALIDATE BACKUPSET or RESTORE VALIDATE command.
RMAN-06465: configuration not implemented: string
Cause: The configuration is not implemented in the current release.
Action: Avoid using the command.
RMAN-06466: error parsing configuration string (string)
Cause: Unsupported configuration string is stored in recovery catalog or target database control file.
Action: Check compatibility matrix rman executable and target database and recover catalog. Use DBMS_BACKUP_RESTORE.DELETECONFIG to remove problematic configuration.
RMAN-06467: could not translate DBA: number
Cause: An error was received when calling DBMS_RCVMAN
Action: This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-06468: Invalid Data Block Address: number
Cause: The DBA specified doesn't belong to the mentioned tablespace
Action: Check the DBA
RMAN-06469: could not translate corruption list
RMAN-06470: DEVICE TYPE is supported only when automatic channels are used
Cause: The DEVICE TYPE option was specified with a BACKUP, RESTORE, RECOVER, DUPLICATE, CHANGE, VALIDATE, CROSSCHECK, or DELETE EXPIRED command. This option is allowed only when automatically allocated channels are used.
Action: Remove the DEVICE TYPE option and re-run the command. Or Remove all ALLOCATE commands and re-run the script so that channels are automatically allocated.
RMAN-06471: no configuration found to allocate channels for string
Cause: Device type configuration was not found in recovery catalog
Action: Setup device type configuration using configure command for required device type
RMAN-06472: channel id string is automatically allocated
Cause: Channel id was used on ALLOCATE/RELEASE command.
Action: Use other channel id that does not belong to reserved channel id's name space
RMAN-06473: SET DATABASE can only be used in case of DUPLICATE without TARGET connection
Cause: A SET DATABASE command was specified when connected to target database or not connected to an auxiliary instance.
Action: Specify the command only when not connected to a target database and when connected to an auxiliary instance in preparation to DUPLICATE without TARGET connection.
RMAN-06474: maintenance channels are not allocated
Cause: RELEASE CHANNEL was used without allocating any maintenance channels.
Action: Allocate maintenance channel before executing this command.
RMAN-06475: parallelism setting out of range (1-254): number
Cause: Parallelism for the device type in CONFIGURE PARALLELISM command is out of range
Action: Enter value of parallelism that are within the allowed range.
RMAN-06476: channel number out of range (1-254): number
Cause: Channel number entered in CONFIGURE CHANNEL command is out of range.
Action: Enter channel number within allowed range and retry the command. for this device and retry the command
RMAN-06477: configuration value length exceeds 1024
Cause: CONFIGURE CHANNEL command entered has configuration value greater than 1024 bytes.
Action: Reduce the length of CONFIGURE CHANNEL command options
RMAN-06478: WARNING: datafile copy 'string' cannot be found on disk
Cause: The CHANGE DATAFILECOPY AVAILABLE command was used, but the datafile copy cannot be found on disk.
Action: If the storage containing the datafile copy has been removed from the host, restore it and retry the command. If the datafile copy is permanently gone, then issue the CHANGE DATAFILECOPY DELETE command for this datafile.
RMAN-06479: WARNING: control file copy 'string' cannot be found on disk
Cause: The CHANGE CONTROLFILECOPY AVAILABLE command was used, but the control file copy cannot be found on disk.
Action: If the storage containing the control file copy has been removed from the host, restore it and retry the command. If the control file copy is permanently gone, then issue the CHANGE CONTROLFILECOPY DELETE command for this control file.
RMAN-06480: WARNING: archived log 'string' cannot be found on disk
Cause: The CHANGE ARCHIVELOG AVAILABLE command was used, but the archived log cannot be found on disk.
Action: If the storage containing the archived log has been removed from the host, restore it and retry the command. If the archived log is permanently gone, then issue the CHANGE ARCHIVELOG DELETE command for this archived log.
RMAN-06481: WARNING: backup piece 'string' cannot be found on the storage medium
Cause: The CHANGE BACKUPPIECE AVAILABLE command was used, but the backup piece cannot be found on the storage medium.
Action: If the storage containing the backup piece has been removed from the host, restore it and retry the command. If the backup piece is permanently gone, then issue the CHANGE BACKUPPIECE DELETE command for this backup piece.
RMAN-06482: WARNING: proxy copy 'string' cannot be found on the storage medium
Cause: The CHANGE PROXY AVAILABLE command was used, but the proxy copy cannot be found on disk.
Action: If the storage containing the proxy copy has been removed from the host, restore it and retry the command. If the proxy copy is permanently gone, then issue the CHANGE PROXY DELETE command for this proxy copy.
RMAN-06483: changed datafile copy expired
RMAN-06484: changed control file copy expired
RMAN-06485: changed archived log expired
RMAN-06486: changed backup piece expired
RMAN-06487: changed proxy copy expired
RMAN-06488: restore from AUTOBACKUP does not allow any other modifiers
Cause: A control file or SPFILE restore from AUTOBACKUP was attempted and other restore options were used.
Action: Do not specify any other options for the control file AUTOBACKUP restore.
RMAN-06489: no configuration found to allocate clone channel number for device type string
Cause: Target channel configuration could not be used for clone channel as it contains CONNECT option.
Action: Setup clone channel configuration using CONFIGURE CLONE command for required number and type of channels.
RMAN-06490: WARNING: limit of AUTOBACKUPS for the day has been reached
Cause: No more control file AUTOBACKUPS are possible in this day.
Action: This is a warning message, no action is required.
RMAN-06491: control file AUTOBACKUP format "string" contains more than one "string" format specifier
Cause: A CONTROLFILE AUTOBACKUP FORMAT cannot have more than one reserved format specifier.
Action: Specify only one reserved format specifier or use an alternative format.
RMAN-06492: control file AUTOBACKUP format "string" must specify a "string" format specifier
Cause: A reserved format specifier was not specified for the CONTROLFILE AUTOBACKUP FORMAT
Action: Add a specifier to the CONTROLFILE AUTOBACKUP FORMAT
RMAN-06493: only UNTIL TIME clause is allowed when performing a restore from AUTOBACKUP, found: string
Cause: For restoring a control file AUTOBACKUP only SET UNTIL TIME can be used. It is not possible to translate the others to a precise day.
Action: Specify SET UNTIL TIME to indicate the day to start the restore of a control file AUTOBACKUP.
RMAN-06494: string = string is out of range (string-string)
Cause: The specified parameter for restoring a control file AUTOBACKUP is out of the valid range.
Action: Change the parameter value to a valid number or do not specify it.
RMAN-06495: must explicitly specify DBID with SET DBID command
Cause: Restore of a control file AUTOBACKUP or ADVISE FAILURE was attempted when the database is not mounted.
Action: Specify the DBID of the database using SET DBID or mount the database.
RMAN-06496: must use the TO clause when the database is mounted or open
Cause: A control file restore was attempted when the database is mounted or open and no alternate destination was specified.
Action: Specify an alternate destination with the TO clause or dismount the database.
RMAN-06497: WARNING: control file is not current, control file AUTOBACKUP skipped
Cause: Control file AUTOBACKUP is not possible without a current control file.
RMAN-06498: skipping datafile string; already backed up string time(s)
Cause: The indicated datafile will not be included in the backup set. It is already backed up on the device requested and file is offline/read-only datafile. Use the FORCE option to override backup optimization.
RMAN-06499: skipping archived log of thread string with sequence string; already backed up
Cause: The indicated log file will not be included in the backup set because it is already backed up on the device requested. Use FORCE option to override backup optimization.
RMAN-06500: skipping backup set key string; already backed up string time(s)
Cause: The indicated backup set will not be copied because it is already backed up on the device requested. Use FORCE option to override backup optimization.
RMAN-06501: skipping datafile string; already backed up on string
Cause: The indicated datafile will not be included in the backup set. It is already been backed up once, or before the since time specified.
RMAN-06502: skipping archived logs of thread string from sequence string to string; already backed up
Cause: Some archived logs were not be backed up because they were already backed up on the device requested.
Action: No action is required. You can use the FORCE option to override backup optimization and force these files to be backed up.
RMAN-06503: skipping backup set key string; already backed up on string
Cause: The indicated backup set will not be backed up. It has already been backed up on the device once, or before the since time specified.
RMAN-06504: PROXY option with multiple backup copies is not supported
Cause: Multiple backup copies and PROXY option were specified in BACKUP command.
Action: Resolve the conflict.
RMAN-06505: specified DATABASE: string does not match previous DATABASE: string
Cause: SET DBID was used to set a DBID that translated into a database name that does not match newly specified database name or a previous SET DATABASE set a different database name.
Action: Verify that the correct DBID was specified or avoid using the SET DATABASE command.
RMAN-06506: the MAXSETSIZE option cannot be used with a backup backup set
Cause: The MAXSETSIZE option was specified for a backup backup set command.
Action: Remove the option and resubmit the command.
RMAN-06507: trying alternate file for archived log of thread number with sequence number
Cause: This is an informational message, appearing when an archived log was found out of sync with catalog database.
RMAN-06508: MAXSETSIZE string KBYTES should be greater than block size string bytes
Cause: MAXSETSIZE configured or specified in backup command should be greater than database block size.
Action: Specify a larger MAXSETSIZE limit.
RMAN-06509: only SPFILE or control file can be restored from AUTOBACKUP
Cause: A datafile or archived log restore from AUTOBACKUP was attempted.
Action: Do not specify DATAFILE or ARCHIVELOG for restore from AUTOBACKUP.
RMAN-06510: RMAN retention policy is set to recovery window of number days
RMAN-06511: RMAN retention policy is set to redundancy number
RMAN-06512: copy will be obsolete on date string
RMAN-06513: copy will never be obsolete
RMAN-06514: archived logs required to recover from this copy will not be kept
RMAN-06515: archived logs required to recover from this copy will expire when this copy expires
RMAN-06516: time specified in KEEP UNTIL clause must be after today
Cause: KEEP UNTIL support only a future time.
Action: Correct the time and retry the command.
RMAN-06517: KEEP option is not supported for archived log backups
Cause: The KEEP option is not supported for archived logs.
Action: Either remove KEEP option and retry the command or don't specify archived logs for this backup.
RMAN-06518: backup will be obsolete on date string
RMAN-06519: backup will never be obsolete
RMAN-06520: archived logs will not be kept or backed up
RMAN-06521: archived logs required to recover from this backup will expire when this backup expires
RMAN-06522: KEEP FOREVER option is not supported without the recovery catalog
Cause: The KEEP FOREVER option was used, but it requires a connection to a recovery catalog database. The KEEP FOREVER option cannot be used when the backup repository is the target database control file. This is because information about this backup cannot be permanently stored. (If information is stored just in the control file it will be aged out depending on CONTROL_FILE_RECORD_KEEP_TIME initialization parameter.)
Action: If a recovery catalog database is available, then connect to the recovery catalog and retry the command, otherwise use a different KEEP option. 6523, 1, "unused"
RMAN-06524: RMAN retention policy will be applied to the command
RMAN-06525: RMAN retention policy is set to none
Cause: Command DELETE OBSOLETE and REPORT OBSOLETE requires that either: * RMAN retention policy is not NONE or, * RMAN retention policy is specified with REPORT/DELETE command.
Action: Either configure RMAN retention policy with CONFIGURE command or specify it at the end of DELETE/REPORT command.
RMAN-06526: KEEP option cannot be used with incremental backup
Cause: The KEEP option was specified for a incremental backup.
RMAN-06527: KEEP option is not supported for backup of backup sets
Cause: The KEEP option is not supported for backup of backup sets.
Action: Either remove KEEP option and retry the command or don't specify backup sets for this backup.
RMAN-06528: CHANGE ... KEEP not supported for BACKUPPIECE
Cause: The CHANGE BACKUPPIECE ... KEEP command was entered. KEEP attributes cannot be specified for backup pieces.
Action: Use CHANGE BACKUPSET ... KEEP instead.
RMAN-06529: CHANGE ... KEEP not supported for ARCHIVELOG
Cause: The CHANGE ARCHIVELOG ... KEEP command was entered. KEEP attributes cannot be specified for archived logs.
RMAN-06532: redundancy count must be greater than zero
Cause: The REDUNDANCY operand specified for the retention policy was zero.
RMAN-06533: KEEP ... NOLOGS option cannot be used when datafiles are fuzzy
Cause: The KEEP ... NOLOGS option was specified for a backup or copy of files in a fuzzy state. This kind of backup requires archived logs for recovery, so archived logs must be kept.
Action: Remove the KEEP ... NOLOGS option or make sure the files are not in a fuzzy state and resubmit the command.
RMAN-06534: archived logs required to recover from this backup will be backed up
Cause: This is an informational message only. An archivelog backup will be created and kept so the specified backup can be recovered to a consistent state.
RMAN-06535: LIST COPY OF SPFILE is not supported
Cause: LIST COPY OF SPFILE was used, which is not supported because SPFILE cannot have a copy.
Action: Remove SPFILE from the command.
RMAN-06536: BACKED UP ... TIMES option is supported only for archived logs
Cause: The BACKUP UP ... TIMES option was used as a qualifier. This option is supported only for archived logs.
RMAN-06537: CHANGE ... KEEP not supported for BACKUP
Cause: The CHANGE BACKUP... KEEP command was entered. KEEP attributes cannot be specified for copies and backup pieces in a single command.
RMAN-06538: The expected DB_UNIQUE_NAME is string, but found string
Cause: The is an informational message.
Action: Check other error messages associated with this message.
RMAN-06540: Tablespace string will be excluded from future whole database backups
RMAN-06541: Tablespace string will be included in future whole database backups
RMAN-06542: file string is excluded from whole database backup
Cause: The indicated file will not be included in the backup set because its tablespace is configured as excluded from backup.
RMAN-06543: duplicate or conflicting LIST options: string and string
Cause: The indicated options conflict with each other or appear more than once in a LIST command.
Action: remove the duplicate/conflicting option from the command.
RMAN-06547: SYSTEM tablespace cannot be excluded from whole database backup
Cause: The SYSTEM tablespace must be included in whole database backup.
Action: Remove the SYSTEM tablespace from the CONFIGURE ... EXCLUDE and retry the operation.
RMAN-06548: connected to auxiliary database: string (DBID=string)
RMAN-06549: connected to auxiliary database: string (not mounted)
RMAN-06550: clone database not mounted and db_name not set in init.ora
Cause: The clone database "init.ora" file does not specify the DB_NAME parameter.
Action: Add the DB_NAME parameter to the clone database "init.ora" and restart the instance.
RMAN-06551: error while looking up datafile copy for file number: string
Cause: An error occurred while looking up the specified datafile copy in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure. If the datafile copy was created during a RESTORE with a new name, ensure that the RESTORE completed successfully.
RMAN-06552: newname for datafile number was set to NEW, but file was not restored
Cause: A SWITCH command was specified for a datafile, but the newname was set to NEW and the file was not restored. If newname is set to NEW, the file must be restored before issuing a SWITCH command.
Action: Correct and resubmit the SWITCH command.
RMAN-06553: DB_CREATE_FILE_DEST must be set for SET NEWNAME ... TO NEW
Cause: The SET NEWNAME ... TO NEW option was specified but the OMF destination init parameter DB_CREATE_FILE_DEST is not set.
Action: Supply a full name to the SET NEWNAME command or set DB_CREATE_FILE_DEST at the target database.
RMAN-06554: WARNING: file string is in backup mode
Cause: A file which is being backed up or copied is in backup mode. RMAN will back up the file anyway, but files do not need to be put into backup mode before backing them up with RMAN.
Action: Use the ALTER TABLESPACE ... END BACKUP statement, at the target database server, to take the files out of backup mode.
RMAN-06555: datafile string must be restored from backup created before string
Cause: An incomplete recovery session was started, but the file is in newer than the UNTIL TIME clause.
Action: Check the UNTIL TIME clause or restore the file from a sufficient old backup.
RMAN-06556: datafile string must be restored from backup older than SCN string
Cause: An incomplete recovery session was started, but the file is newer than the UNTIL clause.
Action: Check the UNTIL clause or restore the file from a sufficient old backup.
RMAN-06557: unable to restore archived log of thread number with sequence number
Cause: Restore of the specified archived log failed because the size of the archived log is larger than available disk space.
Action: One of the following: 1) Increase the MAXSIZE parameter and retry the command. 2) Free up disk space in the recovery area.
RMAN-06558: archived log size of number kb is bigger than available space of number kb
Cause: This message should be followed by one or more 6557 messages.
Action: Check the accompanying errors.
RMAN-06559: MAXSIZE must be larger than 1 kb
Cause: The MAXSIZE parameter is out of range.
RMAN-06560: WARNING: backup set with key number will be read number times
Cause: This message should be followed by one or more 6562 messages.
Action: Check the accompanying messages.
RMAN-06561: available space must be larger than number kb
Cause: The recovery failed because it requires more disk space. One of the following could have caused this error: 1) The MAXSIZE option is used but is not large enough to restore files. 2) Files should be restored to recovery area, but available disk space is not large enough to restore files.
RMAN-06562: available space of number kb needed to avoid reading the backup set multiple times
Cause: A backup set is read more than once. Multiple reads of a backup set can slow restore performance. One of the following could have caused this: 1) The MAXSIZE option is used but is not large enough to restore files. 2) Files should be restored to a recovery area, but the available disk space is not large enough to restore files.
RMAN-06563: control file or SPFILE must be restored using FROM AUTOBACKUP
Cause: RESTORE CONTROLFILE or RESTORE SPFILE was specified without the FROM AUTOBACKUP option when RMAN is not connected to the recovery catalog.
Action: If the recovery catalog is available, connect to the recovery catalog and retry the restore. If the recovery catalog in not available, following is the procedure to restore control file or SPFILE: 1. Specify the DBID of the database with the SET DBID command. 2. If the AUTOBACKUP was created with non-default AUTOBACKUP format, then specify the AUTOBACKUP format using the SET CONTROLFILE AUTOBACKUP FORMAT command. 3. If the backup was created with SBT device, then allocate an SBT channel using the ALLOCATE CHANNEL command. 4. Restore control file or SPFILE by starting the RESTORE ... FROM AUTOBACKUP command.
RMAN-06564: must use the TO clause when the instance is started with SPFILE
Cause: A restore of the SPFILE from AUTOBACKUP was attempted when the instance is started with SPFILE and no alternate destination was specified.
Action: Specify an alternate destination with the TO clause.
RMAN-06565: WARNING: string: sqlcode number was caught, automatic retry #number
Cause: The RMAN client caught a transient error and will automatically retry several times.
RMAN-06566: target database incarnation not found in control file
Cause: RESETLOGS CHANGE# and/or time of the target database doesn't match any database incarnation in the control file.
Action: One of the following actions can be taken to resolve this error 1) Restore the control file from the incarnation. 2) To populate the new incarnation, inspect or restore an archived log/datafile/datafile copy/backup set from the target incarnation
RMAN-06567: connected to auxiliary database: string (DBID=string, not open)
RMAN-06568: connected to target database: string (DBID=string, not open)
RMAN-06569: DATABASE: string does not match previous DATABASE: string
Cause: SET DBID or SET DATABASE was used to specify the target database name which does not match specified database name in DUPLICATE command.
Action: Verify that the correct DBID or the correct DATABASE was specified or avoid specifying DATABASE in DUPLICATE command.
RMAN-06570: datafile number switched to datafile copy "string"
Cause: This message was issued in response to a SWITCH command.
Action: No action is required, this is an informational message.
RMAN-06571: datafile number does not have recoverable copy
Cause: The SWITCH command with the option TO COPY was specified but the datafile has no valid copy to switch to.
Action: Verify whether the datafile has a valid datafile copy.
RMAN-06572: database is open and datafile number is not offline
Cause: The SWITCH command with the option TO COPY was specified, but datafile is not offline and database is open.
Action: Either make sure the datafile is offline or the database must be mounted but not opened.
RMAN-06573: specified DBID: string does not match previous DBID: string
Cause: The DBID in the DUPLICATE command did not match the previously specified DBID in the SET DBID command.
Action: Verify that the correct DBID was specified or avoid using DBID in the DUPLICATE command.
RMAN-06575: platform id number found in datafile string header is not a valid platform id
Cause: The platform id found in the datafile header was not recognized.
Action: Verify that this is a valid datafile.
RMAN-06576: platform 'string' (number) found in header of datafile string does not match specified platform name 'string' (number)
Cause: The platform specified in the command did not match the platform found in the datafile header.
Action: Specify the correct platform name and retry the command.
RMAN-06577: FROM TAG option may only be used with datafile copies
Cause: The FROM TAG option was specified for datafiles.
RMAN-06578: INCREMENTAL LEVEL > 0 must be specified with FOR RECOVER OF
Cause: The FOR RECOVER OF option was specified without specifying INCREMENTAL LEVEL > 0.
Action: Specify INCREMENTAL LEVEL > 0 and resubmit the command.
RMAN-06580: the string option cannot be used with AS COPY
Cause: The specified option was specified for a backup as copy command.
RMAN-06581: option string not supported
Cause: This option was specified and it is not supported.
Action: Remove the specified option.
RMAN-06582: AS COPY option cannot be used when backing up backup sets
Cause: The backup set was specified with AS COPY.
Action: Remove the AS COPY option or remove the backup sets.
RMAN-06583: at least 1 channel of TYPE DISK must be allocated to use AS COPY option
Cause: No channel of TYPE DISK was allocated.
Action: Allocate a channel of TYPE DISK and re-issue the command or remove AS COPY.
RMAN-06584: WARNING: AS BACKUPSET option added due to allocation of multiple channel types
Cause: DISK and non DISK channels were allocated for a backup command. Configuration indicates to produce image copies to DISK, however due to the mixed channel types BACKUPSETS will be created on DISK.
Action: Do not allocate non DISK channels to produce image copies to DISK or allocate only non DISK channels to produce BACKUPSETS only.
RMAN-06585: no copy of datafile number found
Cause: An available datafile copy for the specified datafile could not be found.
Action: make sure that all specified datafiles have a copy available.
RMAN-06586: no copy of datafile number with tag string found
RMAN-06587: one or more datafile copies were not found
Cause: This error message was accompanied by an additional error message or messages indicating the cause of the error.
Action: Follow the recommended actions of the additional error message or messages.
RMAN-06588: number of patterns (number) to DB_FILE_NAME_CONVERT should be even
Cause: An uneven number of patterns was specified.
Action: Specify one more or one less pattern.
RMAN-06589: cannot specify DB_FILE_NAME_CONVERT option without AS COPY
Cause: The DB_FILE_NAME_CONVERT option was specified without AS COPY. This is not permitted for backup set backups where multiple files are combined into a set.
Action: Remove the DB_FILE_NAME_CONVERT option and re-run the BACKUP command.
RMAN-06590: Tablespace string cannot be converted
Cause: The system tablespaces could not be transported to other platforms.
Action: Remove the specified tablespace from the CONVERT command and retry the operation.
RMAN-06591: ALLOW INCONSISTENT can only be used with cross-platform backup
Cause: ALLOW INCONSISTENT was specified in a non cross-platform backup command.
Action: Remove ALLOW INCONSISTENT or add a cross-platform backup modifier.
RMAN-06593: platform name 'string' specified in FROM PLATFORM is not valid
Cause: The platform name was not recognized.
Action: Specify a valid platform name.
RMAN-06594: platform name 'string' specified in TO PLATFORM is not valid
RMAN-06595: platform name 'string' does not match database platform name 'string'
Cause: The platform name specified did not match the name of the database performing the conversion.
Action: Specify the correct platform name.
RMAN-06596: string requires target database compatibility string, currently set to string
Cause: A command or option was used that requires a higher database compatibility than is currently set at the target database.
Action: Raise the compatibility of the database before attempting the command again.
RMAN-06597: conversion between platforms 'string' and 'string' is not implemented
Cause: Conversion of Oracle datafiles between the specified platforms was not supported.
Action: Do not do the conversion.
RMAN-06599: Tablespace string is not read-only
Cause: A conversion was attempted on a tablespace which is not read-only.
Action: Change the tablespace to read-only and retry the operation.
RMAN-06600: old RMAN configuration parameters:
Cause: This message is issued in response to a CONFIGURE command.
Action: No action is required, this is an informational message only.
RMAN-06601: new RMAN configuration parameters:
RMAN-06602: TO DESTINATION option can be used only for disk device
Cause: The TO DESTINATION option was specified for non-disk device.
Action: Remove the TO DESTINATION option and resubmit the command.
RMAN-06603: TO DESTINATION option must be specified with RECOVERY AREA, RECOVERY FILES or DB_RECOVERY_FILE_DEST on disk device
Cause: RECOVERY FILES, RECOVERY AREA or DB_RECOVERY_FILE_DEST option was specified in BACKUP command on disk device without specifying TO DESTINATION option.
Action: Specify TO DESTINATION option and retry the command.
RMAN-06604: new RMAN configuration parameters are successfully stored
RMAN-06605: old RMAN configuration parameters are successfully deleted
RMAN-06606: RMAN configuration parameters are successfully reset to default value
RMAN-06607: RMAN configuration parameters for database with db_unique_name string are:
Cause: This message is issued in response to a SHOW command.
RMAN-06608: RMAN configuration has no stored or default parameters
RMAN-06609: AS COPY can be configured only for disk device
Cause: The AS COPY option was specified for non-disk device.
RMAN-06610: For record type string RECIDS from number to number are re-used before resync
Cause: This messages is issued when the control file records were re-used before resyncing to catalog database.
Action: Increase control_file_keep_record_time setting or issue BACKUP command that it will generate fewer control file records, e.g., backup few tablespaces instead of the complete database in one BACKUP command.
RMAN-06611: Following RMAN configuration applied before deleting logs:
Cause: This message is issued in response to a DELETE command.
RMAN-06612: Incompatible options were specified for archivelog deletion policy
Cause: Incompabitle options were specified on CONFIGURE ARCHIVELOG DELETION POLICY command.
Action: Remove incompabitle options and retry the command. BACKED UP option can be used individually or combined with SHIPPED or APPLIED option. Following are invalid combination of options: a) TO NONE cannot be used with other options b) SHIPPED ON STANDBY and SHIPPED ON ALL STANDBY cannot be used together. c) APPLIED ON STANDBY and APPLIED ON ALL STANDBY cannot be used together. d) SHIPPED and APPLIED cannot be used together.
RMAN-06613: Connect identifier for DB_UNIQUE_NAME string not configured
Cause: The connect identifier for the specified DB_UNIQUE_NAME initialization parameter was not configured.
Action: Do one of the following: - If the DB_UNIQUE_NAME belongs to a connected target database, then define the DB_UNIQUE_NAME parameter in LOG_ARCHIVE_DEST_n at the remote database from where the resynchronization is performed. Otherwise, define DB_UNIQUE_NAME parameter in LOG_ARCHIVE_DEST_n at the target database. Or, - Configure the appropriate connect identifier using the CONFIGURE DB_UNIQUE_NAME RMAN command and rerun the command.
RMAN-06614: DB_UNIQUE_NAME string is too long
Cause: The DB_UNIQUE_NAME initialization parameter string was too long.
Action: Configure the appropriate DB_UNIQUE_NAME initialization parameter string and re-run the command.
RMAN-06615: resyncing from database with DB_UNIQUE_NAME string
Cause: Resync was performed remotely for the specified DB_UNIQUE_NAME initialization parameter without connecting to it as target database. This type of remote resync has limitations. For example, RMAN output cannot be resynced. Please refer to RMAN documentation for a complete set of limitations.
Action: This is an informational message.
RMAN-06616: RMAN output not resynced for database with DB_UNIQUE_NAME string
Cause: V$RMAN_OUTPUT contents were not rescyned when the RESYNC CATALOG FROM DB_UNIQUE_NAME command was executed."
RMAN-06617: UNTIL TIME (string) is ahead of last NEXT TIME in archived logs (string)
Cause: UNTIL TIME was more than the last NEXT TIME of the last archived log.
RMAN-06618: RMAN client and database release mismatch; indicated database release is number.number.number.number
Cause: This release of RMAN was incompatible with either the indicated database or the DBMS_BACKUP_RESTORE package installed in the indicated database.
Action: If the database has been upgraded from an earlier release, ensure that the catuxxx.sql script has been run successfully. Reinstall dbmsbkrs.sql and prvtbkrs.plb if necessary. Otherwise, make sure that the RMAN client release is the same as the target database release.
RMAN-06619: recovery catalog schema release string is newer than RMAN release
Cause: The RMAN client release did not match the catalog schema release number for the database.
Action: This is an informational message. No action is required.
RMAN-06700: error parsing text script in file string
Cause: Incorrect syntax or invalid commands were found.
Action: Fix text script and retry the command.
RMAN-06701: could not construct path for file: "string"
Cause: An error was encountered when trying to construct the full pathname for the specified file.
Action: Ensure that the path is correct.
RMAN-06702: could not initialize for input file: "string"
Cause: An error was encountered when trying to initialize the specified file for input.
Action: Ensure that the file exists.
RMAN-06703: could not open file: "string" (reason=string)
Cause: An error was encountered when trying to open the specified file.
Action: Ensure that the file has correct permissions.
RMAN-06705: text script line is too long (>1024)
Cause: A text script contained a line longer than the permitted maximum length.
Action: Split the line in smaller lines an retry the operation.
RMAN-06706: could not close file: "string" (reason=string)
Cause: An error was encountered when trying to close the specified file.
Action: Ensure that the file has correct permissions and still exists.
RMAN-06707: could not initialize for output file: "string"
Cause: An error was encountered when trying to initialize the specified file for output.
RMAN-06708: short write while writing file "string". Wrote string bytes instead of string bytes
Cause: An attempt was made to write to a file system that was full.
Action: Ensure that the file system has room for the file. Check system logs.
RMAN-06709: \n No scripts in recovery catalog
Cause: An attempt was made to list the scripts in the catalog, but no scripts could be found in the specified recovery catalog.
Action: No action required, this is an informational message only.
RMAN-06710: script string not found in catalog
Cause: An attempt was made to call a script that could not be found in the target database or as a global script in the specified catalog.
Action: Verify the script name and retry the command.
RMAN-06711: global scripts require a TARGET connection
Cause: Connection to a TARGET database was not specified.
Action: Provide a TARGET connection and retry the command.
RMAN-06716: skipping datafile number; already restored to file string
Cause: Recovery Manager determined that this file is already restored. Use FORCE option to override this optimization.
RMAN-06717: Could not delete auxiliary instance file string
Cause: Auxiliary instance file was not deleted. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-06724: backup not done; all files already backed up
Cause: A BACKUP command does not need to backup any files, because all of the files to backup are already backed up.
RMAN-06725: database not open: sort area size too small
Cause: sort area size too small to execute RMAN commands.
Action: open the database or increase sort_area_size.
RMAN-06726: could not locate archived log string
Cause: The specified archived log could not be found on any allocated channel.
Action: Allocate additional channels on other nodes of the cluster or, if the archived logs has been deleted, use the CROSSCHECK ARCHIVELOG command to correct the recovery catalog or target database control file entries.
RMAN-06727: could not locate datafile copy string
Cause: The specified datafile copy could not be found on any allocated channel.
Action: Allocate additional channels on other nodes of the cluster or if the datafile copy has been deleted, use the CROSSCHECK DATAFILECOPY command to correct the recovery catalog or target database control file entries.
RMAN-06728: could not locate control file copy string
Cause: The specified control file copy could not be found on any allocated channel.
Action: Allocate additional channels on other nodes of the cluster or if the control file copy has been deleted, use the CROSSCHECK CONTROLFILECOPY command to correct the recovery catalog or target database control file entries.
RMAN-06729: no backup of the SPFILE found to restore
Cause: A SPFILE restore could not proceed because no backup of the SPFILE was found. It may be the case that a backup of this file exists but does not satisfy the criteria specified in the user's restore operands.
Action: Modify options for the SPFILE restore.
RMAN-06730: no channel to restore a backup of the SPFILE
Cause: A SPFILE restore could not proceed because the backup on a device type that was not allocated for restore.
Action: No action required, this is an informational message only. See message 6026 for further details.
RMAN-06731: command string:string%% complete, time left number:number:number
RMAN-06732: database dropped
RMAN-06733: database unregistered from the recovery catalog
RMAN-06737: database name "string" does not match target database name "string"
Cause: The UNREGISTER DATABASE command was used with a database name that does not match the name of the database to which RMAN is connected.
Action: Specify the correct database name or avoid specifying the database name when connected to the target database.
RMAN-06738: database name "string" is not unique in the recovery catalog
Cause: The UNREGISTER DATABASE command was used with a database name that is ambiguous.
Action: Use the SET DBID command to specify the database id and resolve the ambiguity.
RMAN-06739: database "string" is not found in the recovery catalog
Cause: The UNREGISTER DATABASE command was used with a database name that was not found in the recovery catalog.
Action: Make sure the database name specified in the DROP DATABASE command syntax is correct.
RMAN-06740: database name is not specified
Cause: The command failed because of the following: o RMAN is not connected to the target database o The database name is not specified in the command o DBID is not set with the SET DBID command
Action: Any one of the following actions will fix the problem: o Connect to the target database o Specify database name o Set DBID with SET DBID command
RMAN-06741: database name is "string" and DBID is string
RMAN-06742: platform name 'string' longer than number characters
Cause: The specified platform name exceeded the maximum allowed platform name.
Action: Correct the platform name.
RMAN-06743: specification does not match any backup set in the repository
Cause: The specified backup sets were not found in the recovery catalog or target database control file.
Action: Verify backup set existence and retry the command.
RMAN-06744: specification does not match any datafile copy in the repository
Cause: The specified datafile copies were not found in the recovery catalog or target database control file.
Action: Verify datafile copy existence and retry the command.
RMAN-06745: skipping datafile copy string; already backed up string time(s)
Cause: The indicated datafile copy was not included in the backup set because it was already backed up on the device requested.
Action: Use FORCE option to override backup optimization.
RMAN-06746: backup cancelled because there are no files to backup
Cause: There were no files or all files were skipped for this backup set, therefore no backup set was created.
Action: This message is informational only.
RMAN-06747: at least 1 channel of tertiary storage must be allocated to execute this command
Cause: The executed command requires a SBT channel, but no channels of type SBT were configured or allocated.
Action: ALLOCATE or CONFIGURE a SBT channel.
RMAN-06748: more than one channel types were allocated
Cause: RECOVERY FILES, RECOVERY AREA or DB_RECOVERY_FILE_DEST option was specified in BACKUP command, but more than one channel types was used and no DEVICE TYPE or CHANNEL option was specified.
Action: Specify CHANNEL or DEVICE TYPE option and retry the command.
RMAN-06749: restore point string does not exist.
Cause: The specified restore point does not exists in v$restore_point table of the target database.
Action: Check the name of restore point and retry the command.
RMAN-06750: SPFILE cannot be backed up by proxy.
Cause: The PROXY option was specified, but proxy copy of SPFILE is not supported. This file will be placed into a non-proxy backup set.
RMAN-06751: ASM file string cannot be proxy backed up.
Cause: The PROXY option was specified, but proxy copy of ASM file is not supported. This file will be placed into a non-proxy backup set.
RMAN-06752: error while looking up tempfile: string
Cause: An error occurred while looking up the specified tempfile in the recovery catalog or target database control file.
Action: This error is accompanied by other errors describing the reason for the failure; see those error messages for further information. One possible problem is that the tempfile name was not entered correctly.
RMAN-06753: tempfile not found in the repository
Cause: The specified tempfile is not found in the control file or recovery catalog.
Action: Make sure that the tempfile name is correct and retry
RMAN-06754: INCREMENTAL FROM SCN option is not supported with [string]
Cause: The INCREMENTAL FROM SCN option was supplied but does not apply to this type of backup.
Action: Remove the INCREMENTAL FROM SCN operand and reenter the command.
RMAN-06755: WARNING: datafile string: incremental-start SCN is too recent; using checkpoint SCN string instead
Cause: The incremental-start sysetm change number (SCN) which was specified when starting an incremental datafile backup is greater than the datafile checkpoint SCN, which could cause some blocks to be missed.
Action: Specify a smaller incremental-start system change number (SCN).
RMAN-06756: cannot flashback database to non-guaranteed restore point string when flashback is off
Cause: The indicated restore point was not guaranteed and flashback was disabled. When flashback is disabled, Oracle can flashback only to guaranteed restore point.
Action: Specify a guaranteed restore point or turn on flashback and retry the command. the command.
RMAN-06757: DB_UNIQUE_NAME "string" does not match target database ("string")
Cause: The value specified in the FOR DB_UNIQUE_NAME option did not match the DB_UNIQUE_NAME parameter setting of the target database.
Action: Use the RMAN STARTUP command, with no parameter file option, to start the target database without a parameter file, then run the RESTORE SPFILE command again.
RMAN-06758: DB_UNIQUE_NAME is not unique in the recovery catalog
Cause: RMAN could not identify which SPFILE to restore for this target database, because the recovery catalog contained two or more different instances of this database, each with different DB_UNIQUE_NAME values.
Action: Use the FOR DB_UNIQUE_NAME option to specify the name of the instance whose parameter file you want to restore.
RMAN-06759: skipping datafile copies that are already backed up
Cause: Some datafile copies were not be backed up because they were already backed up on the device requested.
RMAN-06760: skipping archived logs that are already backed up
RMAN-06761: skipping backup sets that are already backed up
Cause: Some backup sets were not be backed up because they were already backed up on the device requested.
RMAN-06762: ignoring encryption for proxy or image copies
Cause: This information message is displayed when the RMAN client is generating proxy or image copies and encryption was enabled for the input files.
Action: This is an informational message only.
RMAN-06763: specified encryption algorithm not supported
Cause: An encryption algorithm not supported by the database is specified during backup.
Action: Refer to contents of v$rman_encryption_algorithms view for the list of supported encryption algorithm. Specify a valid encryption algorithm and retry the command.
RMAN-06764: string
Cause: An error occurred when processing user request.
Action: n/a
RMAN-06765: Tablespace string will be encrypted in future backup sets
RMAN-06766: Tablespace string will not be encrypted in future backup sets
RMAN-06767: Tablespace string will default to database encryption configuration
RMAN-06768: duplicate or conflicting options are specified: string and string
Cause: An error occurred when processing the command because user specified two duplicate options or the two options are not allowed to be used together.
Action: Remove one of the above options and retry the command.
RMAN-06769: length of password must be greater than zero
Cause: Zero length password was specified for encrypted backups.
Action: Retry the command using a password with non-zero length.
RMAN-06771: cannot do IMPORT CATALOG after NOCATALOG has been used
Cause: The IMPORT CATALOG command was used after the NOCATALOG option was already specified.
Action: Restart RMAN and connect to recovery catalog if you wish to IMPORT CATALOG.
RMAN-06772: cannot do IMPORT CATALOG before connecting to recovery catalog
Cause: The IMPORT CATALOG command was used before connecting to the recovery catalog.
Action: Connect to recovery catalog using CONNECT CATALOG command if you wish to IMPORT CATALOG.
RMAN-06773: connected to source recovery catalog database
RMAN-06774: must specify a TNS service name for source recovery catalog database
Cause: The connect string does not contain TNS service name. IMPORT CATALOG without TNS service name is not supported.
Action: Specify a service name and resubmit the command.
RMAN-06775: not connected to source recovery catalog database
Cause: IMPORT CATALOG command was issued but no connection to the source recovery catalog database has been established.
Action: Resubmit IMPORT CATALOG command with correct connect string.
RMAN-06776: source recovery catalog database not started
Cause: IMPORT CATALOG command was issued which requires the source recovery catalog to be open.
Action: Open the source recovery catalog database and re-submit the command.
RMAN-06777: ORACLE error from source recovery catalog database: string
Cause: This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-06778: WARNING: string: sqlcode number was caught, automatic retry #string
Cause: The RMAN client caught a transient error during temporary resource allocate for IMPORT CATALOG command and will automatically retry several times.
RMAN-06779: import validation complete
Action: No action required.
RMAN-06780: database unregistered from the source recovery catalog
RMAN-06781: string package version string in source database is not of version string
Cause: The catalog schema version of the source recovery catalog is not the same as the target recovery catalog. The two catalog
Action: UPGRADE source recovery catalog schema and recovery catalog schema to same version and retry the command.
RMAN-06782: Datafile headers of locally managed datafiles need to be updated.
RMAN-06783: Update of datafile headers of locally managed datafiles finished.
RMAN-06784: One or more datafile headers of locally managed datafiles were not updated.
Cause: Errors prevented the update of one or more datafile headers.
Action: See trace file for details of the problem.
RMAN-06785: This operation might take some time.
RMAN-06786: could not read file header for datafile string to do FLASHBACK.
Cause: The indicated datafile header could not be read to do FLASHBACK DATABASE.
Action: If the database must be taken back in time then a restore and incomplete recovery must be performed.
RMAN-06787: WARNING: TAG string option is ignored; backups will be tagged with string
Cause: WITH TAG option and TAG option were used together. When WITH TAG option is used, all the backups created by the command will have tag specified with WITH TAG option.
Action: The TAG option can be removed to not display the message.
RMAN-06791: changed the DB_UNIQUE_NAME value from string to string
RMAN-06792: database db_unique_name is "string", db_name is "string" and DBID is string
Cause: UNREGISTER DB_UNIQUE_NAME or CHANGE DB_UNIQUE_NAME command was executed, hence RMAN displayed the database information for which DB_UNIQUE_NAME the metadata will be removed/renamed in the recovery catalog.
RMAN-06793: database with db_unique_name string unregistered from the recovery catalog
Cause: UNREGISTER DB_UNIQUE_NAME command was executed.
RMAN-06795: Flashback database logging is not on.
Cause: A FLASHBACK DATABASE command was tried but flashback database logging has not been enabled.
Action: Flashback database logging must be enabled via the ALTER DATABASE FLASHBACK ON command before a FLASHBACK DATABASE command can be tried. If the database must be taken back in time then a restore and incomplete recovery must be performed.
RMAN-06796: Not enough flashback database log data to do FLASHBACK.
Cause: There was not enough flashback database log data to do the FLASHBACK DATABASE.
RMAN-06797: Grant succeeded.
Cause: This is an informational message issued in response to a GRANT command.
RMAN-06798: Revoke succeeded.
Cause: This is an informational message issued in response to a REVOKE command.
RMAN-06799: found eligible base catalog owned by string
Cause: When creating a virtual private catalog, an 11g base catalog was found, owned by the specified user, and the currently connected catalog user has been granted privileges on this catalog, and can therefore create a virtual private catalog using this base catalog. This is an informational message issued in response to a CREATE VIRTUAL CATALOG command.
RMAN-06800: found ineligible base catalog owned by string
Cause: When creating a virtual private catalog, an 11g base catalog was found, owned by the specified user, and the currently connected catalog user has not been granted any privileges on this catalog. This is an informational message issued in response to a CREATE VIRTUAL CATALOG command.
RMAN-06801: no base catalog found
Cause: When trying to create a virtual catalog, either no base catalog was found, or this user has no privilege to create a virtual catalog against any existing base catalog.
Action: Establish the correct privileges and re-create the virtual catalog.
RMAN-06802: too many eligible base catalogs found
Cause: When trying to create a virtual catalog, more than one base catalog was found that is eligible to be the base catalog for this virtual catalog.
Action: Revoke privileges so that the current catalog user has privileges on only one base catalog, then re-issue the CREATE VIRTUAL CATALOG command.
RMAN-06803: created virtual catalog against base catalog owned by string
Cause: A virtual private catalog was created, where the base catalog data is owned by the specified user. This is an informational message issued in response to a CREATE VIRTUAL CATALOG command.
RMAN-06804: Enter value for string:
Cause: This is a user prompt.
Action: Enter a substitution value to proceed.
RMAN-06805: SET NEWNAME command has not been issued for tempfile string
Cause: A SWITCH command was specified for a tempfile, but no destination was specified and no SET NEWNAME command has been previously issued for that file. An explicit file to switch to must be specified if no SET NEWNAME command has been issued.
RMAN-06806: compression algorithm 'string' of release string not found
Cause: An unsupported compression algorithm was specified for the backup.
Action: Query the V$RMAN_COMPRESSION_ALGORITHM view for the list of suppmrted compression algorithms. Specify a valid compression algorithm and retry the command.
RMAN-06807: compression algorithm 'string' of release string cannot be used because database compatibility is less than string
Cause: The compression algorithm is not supported because the current compatibility level of the database is too low.
Action: Query the V$RMAN_COMPRESSION_ALGORITHM view for the list of supported compression algorithms. Specify a valid compression algorithm and retry the command.
RMAN-06808: SECTION SIZE cannot be used when piece limit is in effect
Cause: The SECTION SIZE backup option was used together with the MAXPIECESIZE channel limit. These options are mutually exclusive, because they are independant methods of creating multiple backup pieces with one backup command.
Action: Use one option or the other, but not both.
RMAN-06809: compression algorithm 'string' of release string requires advanced compression option
Cause: The compression algorithm was not supported because it requires advanced compression option to be enabled.
Action: Enable advanced compression option by setting advanced_compression_option_usable=true or specify a different compression algorithm.
RMAN-06810: specification does not match any datafile copy in the repository
Cause: No datafile copies were found that match specification in the recovery catalog or target database control file.
Action: Check the specifier.
RMAN-06811: specification does not match any control file copy in the repository
Cause: No control file copies were found that match specification in the recovery catalog or target database control file.
RMAN-06812: specification does not match any backup in the repository
Cause: No backups were found that match specification in the recovery catalog or target database control file.
RMAN-06813: could not translate pluggable database string
Cause: An error occurred while looking up the specified pluggable database in the repository.
Action: Ensure that the database name is entered correctly and retry the command.
RMAN-06814: cannot connect to pluggable database string
Cause: An error was received when connecting to database because the database is a pluggable database.
Action: Connect to the root database and retry the command.
RMAN-06815: cannot change the container in RMAN session.
Cause: An attempt was made by to change the container using the ALTER SESSION SET CONTAINER statement.
Action: This operation is not allowed in RMAN session.
RMAN-06817: Pluggable Database string cannot be backed up in NOARCHIVELOG mode.
Cause: Backing up the Pluggable Database when database was in NOARCHIVELOG mode is not allowed.
Action: Pluggable Database backups are not allowed when the database is in NOARCHIVELOG mode. Close the container database and backup the complete database using the BACKUP DATABASE command.
RMAN-06818: WARNING: last archived log from primary database not received at standby database
Cause: An archived log was switched at the primary database during backup at the standby database and this log was not shipped to the standby database. The backup created at the standby database will need more logs to recover.
Action: Check whether the standby database is configured correctly to receive logs from the primary database.
RMAN-06819: current log archived at primary database
Cause: The ALTER SYSTEM ARCHIVE LOG CURRENT command completed successfully at the primary database because the connected target instance was a physical standby database. The switched archived logs were included in the backup so that the backed up files could be recovered to a consistent point-in-time.
Action: None. This is an informational message.
RMAN-06820: WARNING: failed to archive current log at primary database
Cause: An attempt to switch the archived log at the primary database failed.
Action: Resolve the error messages associated with this message to avoid the warning.
RMAN-06821: backup is not consistent because the last archived log was not received at the standby
Cause: As part of the KEEP backup operation, the archived log at the primary database was switched but was not shipped to the standby database.
RMAN-06822: backup not consistent because switching of archived log failed at the primary
Cause: As part of the KEEP backup operation, the attempt to switch the archived log at the primary database failed.
RMAN-06896: cannot resolve circular path of synonym string
Cause: Synonym forms a circular reference that causes an infinite loop.
Action: Drop self-referential synonyms.
RMAN-06897: procedure, function, package, sequence, or type is not supported here
Cause: RMAN does not support DESCRIBE for procedures, functions, packages, sequences, or types.
Action: Use DESCRIBE for tables or views only.
RMAN-06898: recovery catalog is partially upgraded to string
Cause: The recovery catalog database was not completely upgraded to the specified version. Either there were some errors during execution of UPGRADE CATALOG or UPGRADE CATALOG was cancelled before completion.
Action: Execute UPGRADE CATALOG again.
RMAN-06899: updating recovery catalog with new database incarnation
Cause: The target database has a new incarnation that has not already been seen by the recovery catalog. This usually happens because a Point-in-Time Recovery was done. RMAN has made the necessary updates to the recovery catalog.
RMAN-06900: WARNING: unable to generate V$RMAN_STATUS or V$RMAN_OUTPUT row
Cause: The routine createRmanStatusRow() or createRmanOutputRow() could add new row into V$RMAN_STATUS or V$RMAN_OUTPUT.
Action: Check the associated error messages. If the associated error message indicates a condition that can be corrected, do so, otherwise contact Oracle.
RMAN-06901: WARNING: disabling update of the V$RMAN_STATUS and V$RMAN_OUTPUT rows
Cause: Informational message only.
RMAN-06902: AS COMPRESSED BACKUPSET option cannot be used when backing up backup sets
Cause: The backup set was specified with AS COMPRESSED BACKUPSET.
Action: Remove the AS COMPRESSED BACKUPSET option.
RMAN-06903: backup of datafile string was cancelled
Cause: This is an informational message displayed when PARTIAL option of DURATION option was specified on the BACKUP command and backup could not be completed within the given duration time.
Action: Run the BACKUP command to backup cancelled files, or let the next backup window backup the cancelled files. It should be noted that the files that were skipped in the current job will be given preference to other files for next the BACKUP command with DURATION option.
RMAN-06904: backup of archived log for thread number with sequence number and starting SCN of string was cancelled
Action: Run BACKUP command to backup cancelled files, or let the next backup window backup the cancelled files. It should be noted that the files that were skipped in the current job will be given preference to other files for next the BACKUP command with DURATION option.
RMAN-06905: backup of backup set key number was cancelled
RMAN-06906: backup of control file was cancelled
RMAN-06907: MINIMIZE LOAD option not allowed for the specified input files
Cause: This option was specified in a backup command specification for BACKUP BACKUPSET or BACKUP CURRENT CONTROLFILE command.
Action: Remove the MINIMIZE LOAD option and retry the command.
RMAN-06908: WARNING: operation will not run in parallel on the allocated channels
Cause: RMAN allocated more than one channel for a job, but the job will not run in parallel on these channels because parallelism require Enterprise Edition.
Action: None
RMAN-06909: WARNING: parallelism require Enterprise Edition
Action: None
RMAN-06910: can not invoke parallel recovery for test recovery
Cause: Recover database was called with TEST and PARALLEL option
Action: Call recover database with either just the TEST or PARALLEL option
RMAN-06911: only one PARALLEL or NOPARALLEL clause may be specified
Cause: Recover database was called with PARALLEL and NOPARALLEL option
Action: Call recover database with either just the PARALLEL or NOPARALLEL option.
RMAN-06912: backup of spfile was cancelled
RMAN-06913: validate cancelled because there are no files to validate
Cause: All files for this validate command were skipped, therefore no files to validate.
RMAN-06914: BLOCK string must be greater or equal to BLOCK string
Cause: The value of TO block number was less than the value of from block number.
Action: Increase the value of TO BLOCK past the value of from BLOCK and retry the command.
RMAN-06915: restore point string already exists
Cause: The specified restore point already exists on this database.
Action: Use LIST RESTORE POINT to see existing names and retry the command with a unique restore point name.
RMAN-06916: RECOVER DATABASE required for SNAPSHOT TIME recovery
Cause: RECOVER DATABASE must be used for SNAPSHOT TIME recovery.
Action: Use the RECOVER DATABASE command to perform the recovery.
RMAN-06917: skipping backup sets; RECOVERY FILES, RECOVERY AREA or DB_RECOVERY_FILE_DEST option cannot validate backup set
Cause: The RECOVERY FILES, RECOVERY AREA or DB_RECOVERY_FILE_DEST was specified in VALIDATE command to validate backup set. This is not supported.
Action: To validate a backup set, use the VALIDATE BACKUPSET or RESTORE VALIDATE command.
RMAN-06918: WARNING: allocated SBT channel to the Recovery Appliance in NOCATALOG mode
Cause: The Recovery Appliance might have run out of resources because congestion control could not be enabled in NOCATALOG mode.
Action: Use CATALOG mode to connect RMAN to a Recovery Appliance instance.
RMAN-06919: command not allowed when the Recovery Appliance is running
Cause: The command specified could not be used when the Recovery Appliance was running.
Action: Shut down the Recovery Appliance and retry the command.
RMAN-06920: database string is not open read-only
Cause: CONVERT DATABASE attempted on a database that was not open read-only.
Action: Open the database in read-only mode and retry the operation.
RMAN-06921: Convert database check failed
Cause: This database could not be transported because DBMS_TDB.CHECK_DB returned FALSE.
Action: None
RMAN-06922: External table string.string found in the database
Cause: An external table was found in the database.
Action: Redefine the table in the transported database.
RMAN-06923: Directory string.string found in the database
Cause: A directory object was found in the database.
Action: Redefine the directory in the transported database.
RMAN-06924: BFILE string.string found in the database
Cause: A BFILE was found in the database.
Action: Redefine the BFILE in the transported database.
RMAN-06925: BFILEs are used in the system, please redefine them in the transported database
Cause: BFILEs may or may not exist in the database. Automatically performed BFILE check failed because database was open read-only and could not allocate temporary space. This does not affect CONVERT DATABASE operation.
Action: Use DBMS_TDB.CHECK_EXTERNAL to perform BFILE check when the database is open in read/write mode.
RMAN-06926: User string with string privilege found in password file
Cause: Password file was used.
Action: Re-create the password file on the target platform using ORAPWD for the transported database.
RMAN-06927: Cannot specify NEW DATABASE clause more than once
Cause: NEW DATABASE clause specified more than once
Action: Remove redundant NEW DATABASE clause and retry the operation.
RMAN-06928: Cannot specify ON TARGET PLATFORM clause more than once
Cause: ON TARGET PLATFORM clause specified more than once
Action: Remove redundant ON TARGET PLATFORM clause and retry the operation.
RMAN-06929: Cannot specify TRANSPORT SCRIPT clause more than once
Cause: TRANSPORT SCRIPT clause specified more than once
RMAN-06930: Cannot specify SKIP clause more than once
Cause: SKIP clause specified more than once
Action: Remove redundant SKIP clause and retry the operation.
RMAN-06931: Cannot specify FROM PLATFORM clause
Cause: CONVERT DATABASE command cannot use FROM PLATFORM clause.
Action: Change FROM PLATFORM clause and retry.
RMAN-06932: Database name 'string' longer than number
Cause: The specified database name exceeded the maximum allowable database name length.
Action: Correct the database name.
RMAN-06933: Transport script name too long
Cause: The specified transport script name exceeded the maximum allowable script name length.
Action: Correct the script name.
RMAN-06934: Format string too long
Cause: The specified format string exceeded the maximum allowable format string length.
Action: Correct the format string.
RMAN-06935: Convert script name too long
Cause: The specified convert script name exceeded the maximum allowable script name length.
RMAN-06936: at least 1 channel of TYPE DISK must be allocated to use CONVERT
Cause: A channel of TYPE DISK was not allocated.
Action: Allocate a channel of TYPE DISK and reissue the command.
RMAN-06937: invalid format specifier 'string'
Cause: An invalid format specifier was found in an RMAN command.
Action: Correct the format specifier and retry the command.
RMAN-06941: Database must be closed and mounted EXCLUSIVE and RESTRICTED.
Cause: DROP DATABASE was attempted while the database was open or not mounted EXCLUSIVE and RESTRICTED.
Action: Change the database state to mounted EXCLUSIVE and RESTRICTED.
RMAN-06942: OPTION number is invalid; OPTION must be between string and string
Cause: An invalid OPTION was used.
Action: Change the OPTION argument.
RMAN-06943: no automatic repair OPTION number was listed in ADVISE FAILURE
Cause: The OPTION specified was not one of the automatic repair options listed by ADVISE FAILURE or there were no options listed by the ADVISE FAILURE command.
Action: Change the OPTION argument or resubmit ADVISE FAILURE with a different set of failures.
RMAN-06944: contents of repair script:
RMAN-06945: no repair script present for REPAIRID string
Cause: REPAIRID option specified in the command was invalid or the repair script had been purged from Automated Diagnostic Repository.
Action: Retry REPAIR FAILURE command with a different OPTION number.
RMAN-06946: executing repair script
RMAN-06947: searching flashback logs for block images until SCN string
Cause: Starting the flashback log search for RECOVER...BLOCK command. The log is searched until the indicated system change number (SCN).
Action: None. This is an informational message displayed for RECOVER...BLOCK command.
RMAN-06948: searching flashback logs for block images
Cause: Starting the flashback log search for RECOVER...BLOCK command. The log is searched until the end of the log.
RMAN-06949: finished flashback log search, restored string blocks
Cause: Flashback log search finished for RECOVER...BLOCK command.
RMAN-06950: invalid validate option specified: string
Cause: The specified object was invalid with VALIDATE command.
Action: Delete the invalid operand.
RMAN-06951: repair failure complete
RMAN-06952: database needs to be restarted
Cause: The target database control file was missing.
Action: Restart the instance and repair the database.
RMAN-06953: no automatic repairs were listed by ADVISE FAILURE
Cause: There were no automatic repairs listed by the ADVISE FAILURE command.
Action: Choose a different failure, submit ADVISE FAILURE command, and then submit REPAIR FAILURE command.
RMAN-06954: REPAIR command must be preceded by ADVISE command in same session
Cause: The ADVISE command was not issued in the same session as the REPAIR command.
Action: Submit ADVISE command and then submit the REPAIR command in same session.
RMAN-06955: Network copies are only supported for nonsection image copies.
Cause: An attempt was made to specify BACKUP AUXILIARY FORMAT without specifying the AS COPY clause. A network copy is only supported with an image copy without sections.
Action: Seek an alternate method of copying the desired files.
RMAN-06956: create datafile failed; retry after removing string from OS
Cause: An attempt was made to re-create a database file. This attempt failed.
Action: If the indicated file already exists, remove the file from operating system and retry the RMAN command.
RMAN-06957: finished standby search, restored string blocks
Cause: Standby search finished for RECOVER...BLOCK command.
RMAN-06958: Executing: string
RMAN-06959: WARNING: repair completed but could not verify that failures were fixed by it
Cause: RMAN repair command successfully completed but could not check if the failures were fixed.
Action: Use LIST FAILURE command to verify repair results.
RMAN-06960: EXPDP> string
RMAN-06961: IMPDP> string
RMAN-06962: Error received during export of metadata
Cause: Data Pump could not perform export of tablespace metadata.
Action: See accompanying datapump messages indicating the cause of the error.
RMAN-06963: Error received during import of metadata
Cause: Data Pump could not perform import of tablespace metadata.
RMAN-06964: option string cannot be used with string
Cause: Incompatible options were specified that caused the command to fail.
Action: Remove one of the options from the command and retry.
RMAN-06965: Datapump job has stopped
Cause: A Data Pump error has caused the job to stop.
Action: See accompanying datapump messages or look for a Data Pump trace file for the cause of the error.
RMAN-06966: Invalid release number string
Cause: An incorrectly formatted release number was specified.
Action: Specify a valid release number in n.n.n.n.n format.
RMAN-06967: finished primary search, recovered string blocks
Cause: Primary Database search finished for RECOVER...BLOCK command.
RMAN-06968: duplicate DUMP FILE specification
Cause: DUMP FILE specification already encountered for this command.
Action: Remove duplicate DUMP FILE specification and retry the command.
RMAN-06969: duplicate DATAPUMP specification
Cause: DATAPUMP specification already encountered for this command.
Action: Remove duplicate DATAPUMP specification and retry the command.
RMAN-06970: NEWNAME 'string' for database must include %number or %%U format
Cause: The newname in SET NEWNAME FOR DATABASE did not include a format specifier to produce different newnames for the datafiles.
Action: Include %f or %U in the newname or use SET NEWNAME FOR DATABASE TO NEW to ensure datafiles get different datafile names.
RMAN-06971: NEWNAME 'string' for tablespace must include %number or %%U format
Cause: The newname in SET NEWNAME FOR TABLESPACE did not include a format specifier to produce different newnames for the datafiles.
Action: Include %f or %U in the newname or use SET NEWNAME FOR TABLESPACE ... TO NEW to ensure datafiles get different datafile names.
RMAN-06980: The following errors need to be fixed before peforming this command
Cause: The tablespaces failed validation by DBMS_TTS.TRANSPORT_SET_CHECK.
Action: Fix accompanying violations before attempting the command again.
RMAN-06981: Violation: string
Cause: This message was issued to show a violation obtained from the DBMS_TTS.TRANSPORT_SET_CHECK.
Action: Fix violation before attempting the command again.
RMAN-06982: SQL command with length of string exceeds maximum length of string
Cause: The SQL command issued exceeded the maximum allowed length.
Action: Retry the command removing unnecessary spaces or use a shorter command.
RMAN-06983: unsupported data type string in column string for select
Cause: The select list included an unsupported data type. Not all SQL data types are supported by RMAN. Only simple data types are supported.
Action: Remove the column from select list or use a conversion function to change it to a simple data type.
RMAN-06985: \nstring rows selected
Action: No action is required.
RMAN-06986: Statement processed
RMAN-06987: NUMWIDTH option string out of range (number through number)
Cause: Value for NUMWIDTH option was out of the specified range.
Action: Check the limits of the option and enter a value that is within the range.
RMAN-06988: Only SELECT statements are supported for CATALOG modifier
Cause: SQL CATALOG was specified for a non-SELECT statement.
Action: Do not specify CATALOG or change the statement to be a SELECT statement.
RMAN-06989: \nno rows selected
RMAN-06990: Error in select list
Cause: The specified select list could not be processed.
Action: See accompanying errors for corrective action.
RMAN-06991: Name Null? Type
RMAN-06992: ----------------------------------------- -------- ----------------------------
RMAN-06993: LONG option string out of range (number through number)
Cause: Value for LONG option was out of the specified range.
RMAN-07000: List of SPFILE Backups
Cause: This message is issued in response to a LIST BACKUP OF SPFILE command.
RMAN-07025: string is not supported for foreign archived log
Cause: The specified option was not supported for foreign archived log.
Action: Do not use the specified command for foreign archived log.
RMAN-07200: no failures found that match specification
Cause: A failure specifier did not match any failures in the Automated Diagnostic Repository.
Action: Resubmit the command with a different failure specifier. You can use the LIST FAILURE ALL command in Recovery Manager to display all failures known to RMAN.
RMAN-07207: changed string failures to HIGH priority
RMAN-07208: changed string failures to LOW priority
RMAN-07209: closed string failures
RMAN-07210: new failures after most recent LIST FAILURE command
Cause: New failures were found since last LIST FAILURE command in this RMAN session.
Action: No action is required. This is an informational message only.
RMAN-07211: failure option not specified
Cause: ALL, CRITICAL, HIGH, LOW, or list of failure numbers was not specified.
Action: Specify a failure option and resubmit the command.
RMAN-07212: skipping failure string because it was CLOSED
Cause: The specified failure has been already closed, so ADVISE FAILURE or CHANGE FAILURE cannot be executed on this failure.
Action: This is an informational message only. No action is required.
RMAN-07213: Mandatory Manual Actions
RMAN-07215: Automated Repair Options
RMAN-07220: no manual actions available
RMAN-07222: =======================
RMAN-07251: Repair script: string
RMAN-07252: ========================
RMAN-07253: ========================
RMAN-07255: priority change for failure string failed
Cause: An attempt was made to change the priority of a child failure.
Action: Specify the parent failure ID to change the child failure.
RMAN-07256: cannot change priority of child failure
Cause: An attempt was made to change the priority of child failure.
Action: This message should be followed by one or more 7255 messages.
RMAN-07259: string critical failures exist; cannot exclude from ADVISE FAILURE
Cause: ADVISE FAILURE was executed for HIGH or LOW priority failures when CRITICAL failures existed.
Action: Execute ADVISE FAILURE with the CRITICAL or ALL options.
RMAN-07262: no automatic repair options available
Cause: This is an informational message only.
RMAN-07263: Database Role: string
RMAN-07500: searching for all files that match the pattern string
RMAN-07501: searching for all files in the recovery area
RMAN-07502: List of Files Unknown to the Database
Cause: This message is issued in response to a CATALOG command.
RMAN-07505: no files found to be unknown to the database
Cause: This is an informational message displayed by the CATALOG command. The command either found no files, or all files that matched the specified search pattern were already present in the target database control file.
RMAN-07507: cataloging files...
RMAN-07508: cataloging done
RMAN-07509: List of Cataloged Files
RMAN-07513: List of Files Which Were Not Cataloged
RMAN-07514: =======================================
RMAN-07515: File Name: string
RMAN-07516: Reason: Error reading
RMAN-07517: Reason: The file header is corrupted
Cause: Either the file is not an Oracle file or the file header is corrupted.
Action: Delete the file using OS utility.
RMAN-07518: Reason: Foreign database file DBID: string Database Name: string
RMAN-07519: Reason: Error while cataloging. See alert.log.
RMAN-07520: Reason: Data pump dump file
RMAN-07521: cannot create recovery catalog in database version string; version string required
Cause: An attempt was made to use a version of the recovery catalog schema that was incompatible with the version of the database.
Action: Upgrade the catalog database to at least the required version or install the catalog schema in a different database which is of at least the required version.
RMAN-07522: CREATE TYPE privilege must be granted to user string
Cause: The CREATE CATALOG or UPGRADE CATALOG command was used, but the USERID that was supplied in the CATALOG connect string does not have the CREATE TYPE privilege granted.
Action: Grant CREATE TYPE privilege to the recovery catalog owner.
RMAN-07523: List of files in Recovery Area not managed by the database
Cause: This message was issued in response to a CATALOG RECOVERY AREA command.
RMAN-07524: ==========================================================
RMAN-07525: Reason: File is not a supported file type in Recovery Area
Cause: This message should be accompanied by other message(s) indicating the name of file that was not supported in recovery area. Any file other than current control file, online log, archived log, RMAN backups and flashback log is not supported in recovery area. This is an informational message only.
RMAN-07526: Reason: File is not an Oracle Managed File
Cause: This message should be accompanied by other message(s) indicating the name of file that was not a oracle managed file. This is an informational message only.
RMAN-07527: Reason: File was not created using DB_RECOVERY_FILE_DEST initialization parameter
Cause: This message should be accompanied by other message(s) indicating the name of file that was not created using DB_RECOVERY_FILE_DEST initialization parameter. One of the following scenarios caused this error: 1) This is an archived log file and was created when the LOG_ARCHIVE_DEST_n initialization parameter was set explicitly to recovery area location. For example, LOG_ARCHIVE_DEST_1='location=+FRA' where '+FRA' was also your DB_RECOVERY_FILE_DEST value. 2) This is an RMAN backup file and was created in a recovery area using the FORMAT option of the BACKUP command. 3) This is an online log file or current control file and was created prior to setting the recovery area. 4) This file fits none of the above scenarios and is not supported by the recovery area.
Action: All of following actions will resolve future occurrences of this error: 1) To create archived logs in recovery area, set the LOG_ARCHIVE_DEST_n initialization parameter to 'location=USE_DB_RECOVERY_FILE_DEST'. Do not explicitly set the LOG_ARCHIVE_DEST_n initialization parameter to a recovery area location. 2) To create RMAN backups in recovery area, do not use the FORMAT option of the BACKUP command. All of following actions will resolve current problem: 1) If this is an archived log file or an RMAN backup file, use the CATALOG command to re-catalog the files. 2) If this is an online log file or a current control file to be managed by the recovery area, re-create the file using the DB_RECOVERY_FILE_DEST initialization parameter.
RMAN-07528: number of files not managed by recovery area is string, totaling string
Cause: This message should be accompanied by other message(s) indicating the list of files. Either the files listed are not known to the database or not managed by recovery area. The number and size of the files are shown. This is an informational message only.
RMAN-07529: Reason: catalog is not supported for this file type
Cause: The CATALOG command encountered one or more files of types that cannot be cataloged. These file types include online redo logs, flashback logs, block change tracking files, and data pump files. This message will be accompanied by other messages indicating the names of the file's that could not be cataloged.
RMAN-07530: Reason: This file type is not requested for cataloging
RMAN-07531: skipping datafile number; already restored to SCN string
Cause: Recovery Manager determined that this file was already restored to the specified SCN.
RMAN-07532: skipping datafilecopy string; already recovered to SCN string
Cause: Recovery Manager determined that this datafile copy was already recovered to the specified SCN.
RMAN-07535: waiting for ASM instance to release file state object
RMAN-07536: command not allowed when connected to a Pluggable Database
Cause: A command was attempted that can only be performed in the root container.
Action: Connect to the root container and retry the command.
RMAN-07537: command only allowed in a container database
Cause: A command was attempted that is only allowed in a CDB.
Action: Connect to a CDB and retry the command.
RMAN-07538: Pluggable Database qualifier not allowed when connected to a Pluggable Database
Cause: A command was attempted with Pluggable Database name qualifier. This is not allowed when connected to a Pluggable Database.
Action: Connect to the root container or remove the Pluggable Database qualifier and retry the command.
RMAN-07539: insufficient privileges to create or upgrade the catalog schema
Cause: The user specified in the connect string of the CREATE CATALOG or UPGRADE CATALOG command did not have the privileges required to create or upgrade the catalog schema.
Action: Execute '?/rdbms/admin/dbmsrmansys.sql' after connecting to a catalog database as SYS to grant the required privileges to run RMAN CREATE or UPGRADE command.
RMAN-07540: Cleanup is required for the VPC user schema
Cause: The VPC user specified in the connect string does have extra privileges granted.
Action: Execute '?/rdbms/admin/dbmsrmanvpc.sql' after connecting to a catalog database as SYS to cleanup VPC users schemas.
RMAN-07541: checkpoint of the data file is more recent than the last archived log
Cause: The checkpoint system change number (SCN) of the data file in the backup was higher than the SCN of the most recent archived log. THE RMAN DUPLICATE command will use the checkpoint SCN of the most recent backup data file as the UNTIL SCN value during restore and recovery.
RMAN-07999: Recovery Appliance catalog must be upgraded using Recovery Appliance RMAN executable
Cause: Recovery Appliance catalog could not be upgraded using this RMAN executable.
Action: Use RMAN executable from Recovery Appliance shiphome and upgrade the recovery catalog schema.
RMAN-08000: channel string: copied datafile string
RMAN-08001: restore not complete
Cause: All of the backup pieces have been successfully applied, but DBMS_BACKUP_RESTORE package indicates that the restore conversation is not complete. This usually means that the backup set contained corrupt data.
Action: Restore the files from a different backup set, if possible. The Recovery Manager CHANGE BACKUPPIECE UNAVAILABLE can be used to prevent Recovery Manager from attempting to restore from the corrupt backup piece(s).
RMAN-08002: starting full resync of recovery catalog
RMAN-08003: channel string: reading from backup piece string
RMAN-08004: full resync complete
RMAN-08005: new incarnation of database registered in recovery catalog
RMAN-08006: database registered in recovery catalog
RMAN-08007: channel string: copied datafile copy of datafile string
RMAN-08008: channel string: starting full datafile backup set
RMAN-08009: channel string: starting archived log backup set
RMAN-08010: channel string: specifying datafile(s) in backup set
RMAN-08011: including current control file in backup set
RMAN-08012: including control file copy in backup set
RMAN-08013: channel string: backup piece string
RMAN-08014: channel string: specifying archived log(s) in backup set
RMAN-08015: datafile string switched to datafile copy
RMAN-08016: channel string: starting datafile backup set restore
RMAN-08017: channel string: starting archived log restore to default destination
RMAN-08018: channel string: starting archived log restore to user-specified destination
RMAN-08019: channel string: restoring datafile string
RMAN-08020: including standby control file in backup set
RMAN-08021: channel string: restoring control file
RMAN-08022: channel string: restoring archived log
RMAN-08023: channel string: restored backup piece string
RMAN-08025: channel string: copied control file copy
RMAN-08026: channel string: copied archived log
RMAN-08027: channel string: copied current control file
RMAN-08028: channel string: copy current control file failed
RMAN-08029: snapshot control file name set to default value: string
RMAN-08030: allocated channel: string
RMAN-08031: released channel: string
RMAN-08032: channel string: RECID string STAMP string does not match recovery catalog
Cause: The record that identifies the source file for a copy or backup database does not contain the same data as is stored in the recovery catalog.
Action: Perform a full resync and retry the operation. If the problem persists, then contact Oracle.
RMAN-08033: channel string: including datafile copy of datafile string in backup set
RMAN-08034: full resync skipped, target database not mounted
RMAN-08035: partial resync skipped, target database not mounted
RMAN-08036: channel string: could not create control file record for string string
Cause: The record identifying the named file was no longer present in the target database control file, and repeated attempts to inspect the file were unsuccessful in creating the record. This could be because the circular-reuse section of the control file which holds information about the specified type of file is too small and there is other database activity which is causing the record to be overwritten before it can be used.
Action: Try increasing either the size of the control file circular-reuse section for this file type (datafile copy or archived log, as indicated in the error message, or the CONTROL_FILE_RECORD_KEEP_TIME initialization parameter. If neither of those remedies works then contact Oracle.
RMAN-08037: channel string: unexpected validation return code string
Cause: This is an internal error that should never be issued.
Action: Contact Oracle Support.
RMAN-08038: channel string: starting piece string at string
RMAN-08039: channel string: starting incremental datafile backup set restore
RMAN-08040: full resync skipped, control file is not current or backup
RMAN-08041: partial resync skipped, control file is not current or backup
RMAN-08042: channel string: copied standby control file
RMAN-08043: channel string: copy standby control file failed
RMAN-08044: channel string: finished piece string at string
RMAN-08045: channel string: finished piece string at string with string copies
RMAN-08046: channel string: starting compressed full datafile backup set
RMAN-08047: channel string: starting compressed incremental level string datafile backup set
RMAN-08048: channel string: starting incremental level string datafile backup set
RMAN-08049: channel string: starting compressed archived log backup set
RMAN-08050: cataloged datafile copy
RMAN-08051: cataloged archived log
RMAN-08052: cataloged control file copy
RMAN-08053: channel string: finished piece string at string with string copies and tag string
RMAN-08054: starting media recovery
RMAN-08056: skipping datafile string because it has not changed
Cause: The specified datafile has not had its checkpoint advanced since the previous backup, therefore it does not need a new incremental backup.
RMAN-08057: channel string: backup cancelled because all files were skipped
Cause: All datafiles for this backup were skipped, therefore no backup is created.
RMAN-08058: replicating control file
RMAN-08059: media recovery failed
RMAN-08060: unable to find archived log
RMAN-08061: WARNING: change failure ID string failed due to error ORA-string
Cause: CHANGE FAILURE for the indicated failure ID encountered an error.
Action: See the indicated ORA error message for the cause of the error.
RMAN-08062: WARNING: cannot change priority of a critical failure string
Cause: An attempt was made to change priority of a failure with CRITICAL priority.
RMAN-08063: Recovery catalog is down or not connected to catalog, trying to reconnect.
RMAN-08064: Reconnection with the recovery catalog is successful.
RMAN-08065: WARNING: Reconnection with the recovery catalog failed, switching to nocatalog mode.
Cause: RMAN failed to reconnect to the recovery catalog and switched to nocatalog mode.
RMAN-08066: database reset to incarnation string
RMAN-08070: deleted datafile copy
RMAN-08071: channel string: deleting archived log(s)
RMAN-08072: deleted control file copy
RMAN-08073: deleted backup piece
RMAN-08074: crosschecked backup piece: found to be 'string'
RMAN-08085: created script string
RMAN-08086: replaced script string
RMAN-08087: channel string: started backup set validation
RMAN-08088: applied offline range to datafile string
RMAN-08089: channel string: specifying datafile(s) to restore from backup set
RMAN-08090: channel string: starting proxy restore
RMAN-08091: channel string: specifying datafile(s) for proxy backup
RMAN-08092: channel string: specifying datafile copy of datafile string for proxy backup
RMAN-08093: specifying current control file for proxy backup
RMAN-08094: channel string: specifying datafile(s) for proxy restore
RMAN-08096: channel string: starting validation of datafile backup set
RMAN-08097: channel string: starting validation of archived log backup set
RMAN-08099: specifying standby control file for proxy backup
RMAN-08100: channel string: starting proxy validation
RMAN-08101: channel string: proxy validation complete
RMAN-08102: channel string: located backup piece: string
RMAN-08103: channel string: could not locate backup piece: string
RMAN-08104: channel string: input backup set: count=string, stamp=string, piece=string
RMAN-08105: channel string: backup cancelled because no pieces were found
Cause: All backup sets specified has no pieces. Therefore, no backup set is created.
RMAN-08106: channel string: restoring block(s)
RMAN-08107: skipping inaccessible backup set count=string STAMP=string
Cause: The indicated backup set will not be backed up because one or more pieces of the backup set could not be read, and the SKIP INACCESSIBLE option was specified.
RMAN-08108: channel string: specifying block(s) to restore from backup set
RMAN-08109: channel string: restored block(s) from backup piece string
RMAN-08110: failover to next copy of backup piece
RMAN-08111: some blocks not recovered: See trace file for details
Cause: Some blocks not recovered due to errors.
RMAN-08112: archived log failover was done on string, check alert log for more info
Cause: This is an informational message to indicate the server found a corrupted block in an archived log and had to switch to another copy of the same archived log in an alternate archived log destination to get corresponding un-corrupted block.
Action: If backup is done with delete input option, nothing needs to be done. Otherwise delete the archived log that has corrupted block(s) as recovery on applying this log would fail. Alert log contains name of the log that has corrupted block(s).
RMAN-08113: including current SPFILE in backup set
RMAN-08114: channel string: restoring SPFILE to PFILE
RMAN-08115: channel string: restoring SPFILE
RMAN-08116: output file name is original SPFILE location
RMAN-08117: channel string: the AUTOBACKUP does not contain an SPFILE
Cause: The requested AUTOBACKUP does not contain a SPFILE. This is because the instance was not started with a SPFILE when the AUTOBACKUP was created.
Action: No action is required. RMAN will try three older AUTOBACKUPS before signaling ORA-19687.
RMAN-08118: WARNING: could not delete the following archived redo log
Cause: The routine deleteArchivedLog() could not delete an archived redo log on the target instance.
Action: Check the accompanying file specification and the associated error messages. The file specification indicates what archived redo log on the target instance RMAN was trying to delete and the error messages indicate why RMAN was unable to delete it. Resolve the problem by first confirming that the archived redo log in question has been backed up, do the deletion manually, and then do a crosscheck so that RMAN is aware of the deletion.
RMAN-08119: skipping backup piece handle string; already exists
Cause: A BACKUP command does not need to backup control file AUTOBACKUP pieces, because they already exists.
Action: This is an informational message, no action is required.
RMAN-08120: WARNING: archived log not deleted, not yet applied by standby
Cause: This is an informational message to alert the user that an archived log that should have been deleted was not as it has not been applied to the standby database. The next message identifies the archived log
Action: Archivelog can be deleted after it has been applied to standby database.
RMAN-08121: keep attributes for the backup are deleted
RMAN-08122: keep attributes for the backup are changed
RMAN-08123: keep attributes for the datafile/control file copy are deleted
RMAN-08124: keep attributes for the datafile/control file copy are changed
RMAN-08125: keep attributes for the proxy copy are deleted
RMAN-08126: keep attributes for the proxy copy are changed
RMAN-08127: cataloged backup piece
RMAN-08128: uncataloged backup piece
RMAN-08129: failover to piece handle=string tag=string
Cause: This is an informational message to indicate the server found a corrupted block in a piece and had to switch to another copy of piece to get corresponding un-corrupted block.
Action: See alert log for information on corruption block(s) and the name of the piece that has the corrupted block(s).
RMAN-08130: failover to copy on device type string
Cause: This is an informational message to indicate the RMAN could not successfully restore the database using the specified backups. An attempt was made to restore the datafiles/archived logs/ control file/SPFILE using the same backup set on a different device type.
Action: See accompanying additional error messages indicating the cause of the failover.
RMAN-08131: channel string: specifying datafile copies to recover
RMAN-08132: WARNING: cannot update recovery area reclaimable file list
Cause: This error should be accompanied by other errors giving the cause of failure to update reclaimable file list.
Action: Check the accompanying error.
RMAN-08133: channel string: the AUTOBACKUP does not contain a standby control file.
Cause: The requested AUTOBACKUP did not contain a standby control file.
Action: No action is required, RMAN will try three older AUTOBACKUPS before signaling ORA-19687.
RMAN-08135: some corrupt blocks found during conversion of file string
Cause: While converting the specified file from one platform to another, some corrupt blocks were discovered in the specified file. Details about the corruption have been written to a server trace file.
Action: If these corrupt blocks are unexpected, you may be able to use Block Media Recovery at the source database to fix the problem, then re-convert the files.
RMAN-08136: channel string: deleting incremental backup(s)
Action: No Action Required.
RMAN-08137: WARNING: archived log not deleted, needed for standby or upstream capture process
Cause: An archived log that should have been deleted was not as it was required by upstream capture process or Data Guard. The next message identifies the archived log.
Action: This is an informational message. The archived log can be deleted after it is no longer needed. See the documentation for Data Guard to alter the set of active Data Guard destinations. See the documentation for Streams to alter the set of active streams.
RMAN-08138: WARNING: archived log not deleted - must create more backups
Cause: An archived log that should have been deleted was not as it it did not meet the user specified archive log deletion policy of number of backups required before deleting the logs.
Action: This is an informational message. The archived log can be deleted after more backups are created to satify archivelog deletion policy.
RMAN-08139: WARNING: archived redo log not deleted, needed for guaranteed restore point
Cause: An archived log that should have been deleted was not because it is required for guaranteed restore point.
Action: This is an informational message. The archived redo log can be deleted after backups are created or after deleting the guaranteed restore point that requires the log.
RMAN-08140: channel string: starting validation of datafile
RMAN-08141: channel string: specifying datafile(s) for validation
RMAN-08142: including standby control file for validation
RMAN-08143: including current control file for validation
RMAN-08144: channel string: validation complete, elapsed time: string
RMAN-08145: channel string: starting validation of archived log
RMAN-08146: channel string: specifying archived log(s) for validation
RMAN-08150: created global script string
RMAN-08151: replaced global script string
RMAN-08152: global script string written to file string
RMAN-08153: deleted global script: string
RMAN-08154: deleted script: string
RMAN-08155: printing stored global script: string
RMAN-08156: printing stored script: string
RMAN-08157: script string written to file string
RMAN-08158: executing script: string
RMAN-08159: executing global script: string
RMAN-08160: script commands will be loaded from file string
RMAN-08161: contents of Memory Script:
RMAN-08162: executing Memory Script
RMAN-08163: validation succeeded for backup piece
Cause: The VALIDATE HEADER option determined that the backup piece still matches its data.
Action: None - this is an informational message.
RMAN-08164: validation succeeded for proxy copy
Cause: The VALIDATE HEADER option determined that the proxy copy still matches its data.
RMAN-08165: could not locate proxy copy string
Cause: The specified proxy copy could not be found on proxy channel.
Action: If the proxy copy has been deleted, use the CROSSCHECK BACKUP command to correct the recovery catalog or target database control file entries.
RMAN-08166: validation succeeded for datafile copy and control file copy
Cause: The VALIDATE HEADER option discovered that the datafile copy and control file copy still matches its data in the recovery catalog or target database control file.
RMAN-08167: WARNING: string encountered a piece that was in use
Cause: The backup piece is currently in use by another BACKUP, RESTORE or DELETE operation.
Action: Use LIST to determine if backup has been deleted. If not deleted, then check if any process is hung while accessing the piece and terminate them before retrying DELETE. If using SBT device, then check Media Manager as well. Alternatively, consider the command DELETE FORCE.
RMAN-08168: channel string: using compressed network backup set from service string
RMAN-08169: channel string: using network backup set from service string
RMAN-08180: channel string: restore complete, elapsed time: string
RMAN-08181: media recovery complete, elapsed time: string
RMAN-08182: channel string: validation complete, elapsed time: string
RMAN-08183: channel string: block restore complete, elapsed time: string
RMAN-08184: added tempfile string to tablespace string in control file
RMAN-08185: renamed tempfile string to string in control file
RMAN-08186: tempfile string size altered in control file
Cause: One of tempfile size attributes AUTOEXTEND, MAXSIZE, NEXTSIZE was altered. This is an informational message only.
RMAN-08187: WARNING: media recovery until SCN string complete
Cause: Media recovery was completed until the indicated system change number (SCN) because the database was in NOARCHIVELOG mode.
RMAN-08190: validate found one or more corrupt blocks
Cause: Backup validate found that one or more blocks were corrupt in the specified datafiles. This message should be followed by 8191 message.
Action: Repair them at your earliest convenience.
RMAN-08191: See trace file string for details
RMAN-08300: Run SQL script string on the target platform to create database
RMAN-08301: Edit init.ora file string. This PFILE will be used to create the database on the target platform
RMAN-08302: Run RMAN script string on target platform to convert datafiles
RMAN-08303: To recompile all PL/SQL modules, run utlirp.sql and utlrp.sql on the target platform
Action: Transport script invokes utlirp.sql and utlrp.sql.
RMAN-08304: To change the internal database identifier, use DBNEWID Utility
Action: Transport script does not invoke DBNEWID Utility automatically.
RMAN-08305: channel string: starting to check datafiles
RMAN-08306: channel string: datafile checking complete, elapsed time: string
RMAN-08400: Running TRANSPORT_SET_CHECK on specified tablespaces
RMAN-08401: Cannot specify AS COPY when producing a cross-platform backup
Cause: Cross-platform backup modifier was specified and the type of backup is not a BACKUPSET.
Action: Use CONVERT command instead or specify AS BACKUPSET.
RMAN-08402: Cannot include controlfile in a cross-platform backup
Cause: Cross-platform backup modifier was specified and controlfile backup was also requested.
Action: Do not include controlfile in cross-platform backup or remove cross-platform backup modifiers.
RMAN-08403: Cannot include SPFILE in a cross-platform backup
Cause: Cross-platform backup modifier was specified and SPFILE backup was also requested.
Action: Do not include SPFILE in cross-platform backup or remove cross-platform backup modifiers.
RMAN-08404: Cannot backup a BACKUPSET in a cross-platform backup
Cause: Cross-platform backup modifier was specified and BACKUPSET clause was also requested.
Action: Do not include BACKUPSET clause in cross-platform backup or remove cross-platform backup modifiers.
RMAN-08405: Cannot backup datafile copies in a cross-platform backup
Cause: Cross-platform backup modifier was specified and datafile copies were also requested.
Action: Do not include datafile copies in cross-platform backup or remove cross-platform backup modifiers.
RMAN-08406: Cannot include archived logs in a cross-platform backup
Cause: Cross-platform backup modifier was specified and ARCHIVELOG clause was also requested.
Action: Do not include ARCHIVELOG clause in cross-platform backup or remove cross-platform backup modifiers.
RMAN-08407: Cannot translate DATAPUMP DESTINATION string (reason: string)
Cause: The specified DATAPUMP DESTINATION was invalid.
Action: Retry the command with a valid DATAPUMP DESTINATION
RMAN-08408: Cannot specify string clause when producing cross-platform backups
Cause: A clause that cannot be used with cross-platform backup was specified.
Action: Do not include the specified clause or remove cross-platform backup modifiers.
RMAN-08409: FROM PLATFORM only allowed with BACKUPPIECE clause
Cause: A BACKUP FROM PLATFORM command was specified with backup objects other than BACKUPPIECE.
Action: Remove FROM PLATFORM or specify BACKUPPIECE clause.
RMAN-08410: Cross-platform backups require the database to be open in read/write mode
Cause: Cross-platform backup modifier was specified, but the database was not open in read/write mode.
Action: Open the database in read/write mode or remove cross-platform backup modifiers.
RMAN-08411: DATAPUMP can only be used with cross-platform backup
Cause: DATAPUMP was specified but TO PLATFORM or FOR TRANSPORT clauses were not used.
Action: Do not specify DATAPUMP clause or specify either TO PLATFORM or FOR TRANSPORT.
RMAN-08412: DATAPUMP cannot be used with whole database cross-platform backup
Cause: DATAPUMP was specified together with whole database cross-platform backup.
Action: Do not specify DATAPUMP clause for a whole database cross- platform backup or specify only tablespaces.
RMAN-08413: Cross-platform backup of backup pieces requires FORMAT clause
Cause: A BACKUP BACKUPPIECE command was specified without FORMAT clause.
Action: Add a FORMAT clause to command and retry.
RMAN-08416: ALLOW INCONSISTENT allowed only for datafile backup
Cause: ALLOW INCONSISTENT was specified for a BACKUP BACKUPPIECE command.
Action: Do not specify ALLOW INCONSISTENT clause for BACKUP BACKUPPIECE command.
RMAN-08417: standby database must be open to do KEEP backups
Cause: KEEP backup was attempted on a standby database that was not open.
Action: Open the standby database in READ ONLY or READ ONLY WITH APPLY mode and retry the command.
RMAN-08418: KEEP backups are allowed only with current or standby control file
Cause: KEEP backup was attempted on a control file that was not current or standby.
Action: Convert the control file to current or standby and retry the command.
RMAN-08419: KEEP backups cannot find archivelog to make the backup consistent
Cause: Archived logs could not be found to make keep the backup consistent.
Action: Check if the database is opened and if archive logs can be created and retry the command.
RMAN-08500: channel string: SID=string device type=string
RMAN-08501: output file name=string RECID=string STAMP=string
RMAN-08503: piece handle=string comment=string
RMAN-08504: input archived log thread=string sequence=string RECID=string STAMP=string
RMAN-08505: output file name=string
RMAN-08506: input file name=string
RMAN-08507: input datafile copy RECID=string STAMP=string file name=string
RMAN-08508: archived log destination=string
RMAN-08509: destination for restore of datafile string: string
RMAN-08510: archived log thread=string sequence=string
RMAN-08511: piece handle=string tag=string
RMAN-08512: waiting for snapshot control file enqueue
RMAN-08513: datafile copy file name=string RECID=string STAMP=string
RMAN-08514: archived log file name=string RECID=string STAMP=string
RMAN-08515: archived log file name=string thread=string sequence=string
RMAN-08516: control file copy file name=string RECID=string STAMP=string
RMAN-08517: backup piece handle=string RECID=string STAMP=string
RMAN-08518: channel string: scanning control file copy string
RMAN-08519: channel string: scanning datafile copy string
RMAN-08520: channel string: scanning archived log string
RMAN-08521: offline range RECID=string STAMP=string
RMAN-08522: input datafile file number=string name=string
RMAN-08523: restoring datafile string to string
RMAN-08524: input control file copy name=string
RMAN-08525: backing up blocks string through string
RMAN-08526: channel string: string
RMAN-08527: channel string: starting string proxy datafile backup at string
RMAN-08528: channel string: proxy copy complete, elapsed time: string
RMAN-08529: proxy file handle=string
RMAN-08530: piece handle=string tag=string comment=string
RMAN-08531: channel string: proxy copy string is string in media management catalog
RMAN-08532: channel string: restoring block(s) from datafile copy string
RMAN-08533: restoring blocks of datafile string
RMAN-08534: channel string: control file restore from AUTOBACKUP complete
RMAN-08535: channel string: looking for AUTOBACKUP on day: string
RMAN-08536: channel string: AUTOBACKUP found: string
RMAN-08537: channel string: skipped, AUTOBACKUP already found
RMAN-08538: channel string: no AUTOBACKUP in string days found
RMAN-08539: backup set key=string RECID=string STAMP=string
RMAN-08540: channel string: backup set complete, elapsed time: string
RMAN-08541: channel string: SPFILE restore from AUTOBACKUP complete
RMAN-08542: channel string: starting proxy archived log backup at string
RMAN-08543: channel string: specifying archived log(s) for proxy backup
RMAN-08544: channel string: specifying archived log(s) for proxy restore
RMAN-08545: flashback command failed: See trace file for details
Cause: An attempt was made to issue a flashback command which failed due to errors. See trace file for details.
Action: See trace file for details of the problem.
RMAN-08546: channel string: AUTOBACKUP string found in the recovery area
RMAN-08547: channel string: no AUTOBACKUPS found in the recovery area
Cause: The recovery area does not have desired AUTOBACKUP.
Action: Check the option UNTIL TIME in case an existing AUTOBACKUP does satisfy the criteria specified in the restore command. Otherwise, verify the init.ora parameters DB_RECOVERY_FILE_DEST and DB_UNIQUE_NAME to verify whether the recovery area location is set correctly. Note that the parameters can be specified as options to the restore command.
RMAN-08548: recovery area destination: string
RMAN-08549: database name (or database unique name) used for search: string
RMAN-08550: AUTOBACKUP search with format "string" not attempted because DBID was not set
Cause: Restore of a control file AUTOBACKUP was attempted without DBID being set.
Action: If you want to search for AUTOBACKUP with the indicated format, then specify the DBID of the database using SET DBID and retry the command.
RMAN-08551: recovering datafile copy file number=string name=string
RMAN-08552: backup and output file names are identical: string
Cause: The backup file name chosen was identical to output file name specified for a restore operation.
Action: This is an informational message only. RMAN will failover to next available backup.
RMAN-08553: channel string: restoring control file from AUTOBACKUP string
RMAN-08554: channel string: restoring spfile from AUTOBACKUP string
RMAN-08555: channel string: restoring section string of string
RMAN-08556: channel string: backup piece complete, elapsed time: string
RMAN-08557: input Data Pump dump file=string
RMAN-08558: channel string: converting foreign backup pieces from platform string
RMAN-08559: channel string: converting foreign backup pieces
RMAN-08580: channel string: starting datafile copy
RMAN-08581: channel string: datafile copy complete, elapsed time: string
RMAN-08582: channel string: starting archived log copy
RMAN-08583: channel string: archived log copy complete, elapsed time: string
RMAN-08584: copying current control file
RMAN-08585: copying standby control file
RMAN-08586: output file name=string tag=string RECID=string STAMP=string
RMAN-08587: input is copy of datafile string: string
RMAN-08588: converted datafile=string
RMAN-08589: channel string: starting datafile conversion
RMAN-08590: channel string: datafile conversion complete, elapsed time: string
RMAN-08591: WARNING: invalid archived log deletion policy
Cause: An invalid ARCHIVELOG DELETION POLICY was supplied. The archived log deletion policy was APPLIED but there was no mandatory archived log destinations.
Action: One of the following: 1) Change archived log deletion policy using CONFIGURE command 2) Make one or more of standby destination as MANDATORY.
RMAN-08592: output file name=string tag=string
RMAN-08599: channel string: throttle time: string
RMAN-08600: ASM disk group to search: string
RMAN-08601: channel string: AUTOBACKUP string found in ASM disk group string
RMAN-08602: channel string: no AUTOBACKUPS found in ASM disk group string
Cause: The specified ASM area does not have desired AUTOBACKUP.
Action: Check the option UNTIL TIME in case an existing AUTOBACKUP does satisfy the criteria specified in the restore command. Otherwise, verify the values used for the format of the CONFIGURE CONTROLFILE AUTOBACKUP FORMAT command and DB_UNIQUE_NAME to verify whether the ASM area location is set correctly. Note that the DB_UNIQUE_NAME can be specified as option to the restore command.
RMAN-08603: skipping string; file in use by another process
Cause: The indicated file was not included in the backup because it is part of another restore or delete operation.
Action: No action is required. Wait for the other operation to complete, then retry.
RMAN-08604: skipping string; file deleted from recovery area to reclaim disk space
Cause: The indicated file was not included in the backup because it was deleted from the recovery area to reclaim disk space for other operations.
RMAN-08605: channel string: SID=string instance=string device type=string
RMAN-08606: WARNING: The change tracking file is invalid.
Cause: Backup found changed blocks that were not marked in the change tracking file. See alert log for more information.
Action: Do not use any of the incremental backups taken since the last full backup.
RMAN-08607: List of remote backup files
Cause: RESTORE command detected that one or more remote backup files were required to perform restore operation.
Action: Recall the media from remote site that contains the specified backup files before actual restore operation. The message should be accompanied with the list of remote backup files.
RMAN-08608: Initiated recall for the following list of remote backup files
Cause: This is an informational message displayed when the specified RECALL option of the RESTORE command detected that one or more remote backup files were required to perform the restore operation. The message indicated that RMAN had initiated the request on SBT channel to recall the remote backup files.
Action: No action required.
RMAN-08609: channel string: starting incremental datafile backup set
RMAN-08610: channel string: restoring datafile string to string
RMAN-08611: channel string: piece handle=string tag=string
RMAN-08612: channel string: failover to duplicate backup on device string
Cause: This is an informational message to indicate the RMAN could not successfully restore the files using the specified backups. An attempt was made to restore the datafiles/archived logs/ control file/SPFILE using a previous existing backup.
RMAN-08613: channel string: failover to piece handle=string tag=string
Cause: This is an informational message to indicate the server found a corrupted block in a backup piece and had to switch to another copy of the piece to get the same block.
Action: See alert log for information on corruption block(s) and the name of the backup piece that has the corrupted block(s).
RMAN-08614: channel string: errors found reading piece handle=string
Cause: This is an informational message to indicate the server found a corrupted block in a backup piece. Accompanying error will describe the action taken.
Action: See alert log for more information.
RMAN-08615: channel string
Cause: This is an informational message to indicate the server could not perform the restore due to the included errors. A least recent backup set will be used to perform the restore.
RMAN-08616: validating blocks string through string
RMAN-08617: validation failed for foreign archived log
Cause: The CROSSCHECK FOREIGN ARCHIVELOG command determined that the foreign archived log could not be found or no longer contained the same data, so its record was marked expired.
RMAN-08618: validation succeeded for foreign archived log
Cause: The CROSSCHECK FOREIGN ARCHIVELOG command determined that the foreign archived log still matches its data.
RMAN-08619: foreign archived log file name=string RECID=string STAMP=string
RMAN-08620: uncataloged foreign archived log
RMAN-08621: deleted foreign archived log
RMAN-08622: channel string: restoring all foreign files in backup piece
RMAN-08623: channel string: restoring all files in foreign tablespace string
RMAN-08624: channel string: restoring foreign file string
RMAN-08625: channel string: restoring Data Pump dump file to string
RMAN-08626: channel string: restoring foreign file string to string
RMAN-08627: channel string: foreign piece handle=string
RMAN-08628: channel string: restoring foreign datafilecopy string
RMAN-08629: waiting for resources on the Recovery Appliance for string channels
Cause: The number of channels required to complete this operation was not available. Channels will be allocated when they become available.
RMAN-08630: allocating the required resources on the Recovery Appliance
Cause: The required resources were allocated on a Recovery Appliance.
RMAN-10000: error parsing target database connect string "string"
Cause: An invalid target connect string was supplied.
Action: Specify a valid connect string and re-run the job.
RMAN-10001: error parsing recovery catalog connect string "string"
Cause: An invalid recovery catalog connect string was supplied.
RMAN-10002: ORACLE error: string
Cause: The specified Oracle error was received. This message should be accompanied by other error message(s) indicating the cause of the error.
Action: Check the accompanying errors.
RMAN-10003: unable to connect to target database
Cause: Recovery manager was unable to connect to the target database. This message should be accompanied by other error message(s) indicating the cause of the error.
Action: Ensure that that the target database is started, and that the connect string is valid.
RMAN-10004: unable to connect to recovery catalog
Cause: Recovery manager was unable to connect to the recovery catalog
Action: Ensure that that the recovery catalog is started, and that the connect string is valid. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-10005: error opening cursor
Cause: An error was received while trying to open a cursor. This message should be accompanied by other error message(s) indicating the cause of the error.
Action: If the associated Oracle error message indicates a condition that can be corrected, do so, otherwise contact Oracle.
RMAN-10006: error running SQL statement: string
Cause: An error message was received while running the SQL statement shown.
RMAN-10007: error closing cursor
Cause: An error was received while trying to close a cursor. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-10008: could not create channel context
Cause: An error was received while trying create a channel context. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-10009: error logging off of Oracle
Cause: An error was received while disconnecting from Oracle. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-10010: error while checking for RPC completion
Cause: Recovery Manager's channel context had an error while checking to see if a remote procedure call had completed. This message should be accompanied by other error message(s) indicating the cause of the error.
Action: If other error messages indicate a condition that can be corrected, do so, otherwise contact Oracle.
RMAN-10011: synchronization error while polling for rpc number, action=string
Cause: Recovery Manager could not synchronize properly with a remote procedure call.
Action: This is an internal error that should not be issued. Contact Oracle Support.
RMAN-10012: KGU error: string
Cause: An error occurred while initializing the KGU subsystem
RMAN-10013: error initializing PL/SQL
Cause: An error occurred while initializing the PL/SQL subsystem.
RMAN-10014: PL/SQL error number on line number column number: string
Cause: PL/SQL error
Action: The text of this message will be issued by the PL/SQL subsystem. See the PL/SQL error message manual.
RMAN-10015: error compiling PL/SQL program
Cause: An error occurred while compiling a PL/SQL program.
RMAN-10018: error cleaning up channel context
Cause: An error was received during inter-step cleanup of a channel context.
RMAN-10020: error initializing Recovery Manager execution layer
Cause: An error was received while initializing the Recovery Manager execution layer in preparation for running a job. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-10022: error in system-dependent sleep routine
Cause: An error was received while waiting for a remote RPC to complete. The error occurred in the system-dependent sleep routine.
RMAN-10023: RPC attempted to unrecognized package
Cause: The Recovery Manager internal RPC router received a package name that it could not understand.
RMAN-10024: error setting up for rpc polling
Cause: The Recovery Manager could not create the RPC polling context which is required to test for RPC completion. This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-10025: connection is already registered for events
Cause: The Recovery Manager could not enable the target database connection to test for RPC completion.
RMAN-10026: network error number-number occurred registering connection
Cause: An network error occurred while attempting to register the target database connection to test for RPC completion.
Action: This is an internal error that should not be issued. The message numbers are issued by the Sql*Net layer. Contact Oracle Support.
RMAN-10027: could not locate network layer context
Cause: Recovery Manager could not locate a necessary context area while attempting to register the target database connection to test for RPC completion.
RMAN-10028: network error number-number occurred during remote RPC
Cause: An network error occurred while waiting for a remote RPC to complete.
RMAN-10029: unexpected return code number from PL/SQL execution
Cause: PL/SQL returned an unexpected return code while executing one channel program.
RMAN-10030: RPC call appears to have failed to start on channel string
Cause: An RPC to a target database instance was issued, but was not observed to start within 5 timeouts.
Action: This error is probably accompanied by other error messages giving the precise cause of the failure.
RMAN-10031: RPC Error: ORA-number occurred during call to string.string
Cause: An RPC to the target database or recovery catalog database encountered an error.
Action: This error is accompanied with the error message from the server where the error occurred.
RMAN-10032: unhandled exception during execution of job step number: \nstring
Cause: An unhandled PL/SQL exception occurred during a job step.
Action: This error is accompanied by the error messages describing the exception.
RMAN-10033: error during compilation of job step number: string
Cause: PL/SQL detected a problem during the compilation of a job step
Action: This error message is accompanied by the error messages describing
RMAN-10034: unhandled exception during execution of job step number, error unknown
Cause: PL/SQL detected an unhandled exception during execution of a job step, but no further information available
Action: n/a
RMAN-10035: exception raised in RPC: \nstring
Cause: A call to a remote package resulted in an exception.
Action: The exception should indicate what went wrong.
RMAN-10036: RPC call OK on channel string
Cause: This is just an informational message. It should be preceded by message 10030.
RMAN-10037: RPC anomaly detected on channel string, UPINBLT=number
Cause: This is an debugging message and can be ignored.
RMAN-10038: database session for channel string terminated unexpectedly
Cause: The database connection for the specified channel no longer exists. Either the session was terminated by some external means or the channel terminated because of an internal error.
Action: Check for an oracle trace file for detailed information on why the session terminated.
RMAN-10039: error encountered while polling for RPC completion on channel string
Cause: This error should be accompanied by other errors giving the cause of the polling error.
RMAN-10040: asynchronous support not detected, RMAN will run synchronously
Cause: The database connection does not support asynchronous operation, so RMAN will not multi-task work among multiple channels. Multiple channels can still be allocated, but they will not run work concurrently.
Action: Use a connection type that supports asynchronous operations.
RMAN-10041: Could not re-create polling channel context following failure.
Cause: The RPC polling context, which is required to test for RPC completion, failed and Recovery Manager could not re-create this channel. This message should be accompanied by other error messages indicating the cause of the error.
RMAN-11000: message number number not found in recovery manager message file
Cause: Recovery manager message file is out of date.
Action: Make sure that the recovery manager error message file is current and installed in the correct location.
RMAN-11001: Oracle Error: \nstring
RMAN-11002: could not open a cursor to the target database
RMAN-11003: failure during parse/execution of SQL statement: string
RMAN-11004: format requires %character when duplexing
Cause: SET_DUPLEX=ON was specified, but %c was not part of the format.
Action: Include %c in format, or use %U.
RMAN-11005: conflicting media information for piece "string"
Cause: While restoring the specified backup piece, RMAN received conflicting information about the physical location of the piece from the Media Management software. This can cause poor restore performance.
Action: If RMAN does not parallelize the restore from all of the available channels, then you should contact the Media Management vendor.
RMAN-11006: WARNING: test recovery results: \nstring
Cause: User called recover database with the test option
Action: None required
RMAN-11007: new media label is "string" for piece "string"
Cause: This is an informational message indicating that the backup piece was moved from one media to another by media management software.
RMAN-12000: execution layer initialization failed
Cause: This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-12001: could not open channel string
Cause: An ALLOCATE CHANNEL command could not be processed.
Action: This message should be accompanied by other error message(s) indicating the cause of the error.
RMAN-12005: error during channel cleanup
RMAN-12007: cannot allocate more than number channels
Cause: The maximum number of RMAN channels has been exceeded. Note that one channel is reserved for RMAN.
Action: Allocate fewer channels. Contact Oracle if you have a need for more channels in a single job.
RMAN-12008: could not locate backup piece string
Cause: There was at least 1 backup set that could not be accessed by any of the allocated channels.
Action: Allocate additional channels on other nodes of the cluster
RMAN-12009: command aborted because some backup pieces could not be located
Cause: Same as 7008.
Action: Refer to 7008.
RMAN-12010: automatic channel allocation initialization failed
RMAN-12011: multiple records for default device type found in repository
Cause: Configuration for default device type was not consistent.
Action: Re-run CONFIGURE DEFAULT DEVICE TYPE command to set device type.
RMAN-12012: multiple records for string parallelism found in repository
Cause: Configuration for device parallelism was not consistent.
Action: Re-run CONFIGURE PARALLELISM command for device to set parallelism.
RMAN-12013: multiple records for string channel number found in repository
Cause: Configuration for the channel was not consistent.
Action: Re-run CONFIGURE CHANNEL command to configure this channel.
RMAN-12014: multiple records for default channel configuration for string found in repository
Action: Re-run CONFIGURE CHANNEL command to configure the channel.
RMAN-12015: configuration for string channel number is ignored
Cause: This is an informational message only. Parallelism for the device is less than associated channel number.
Action: To use this configuration increase parallelism for this device. To clear this configuration use CONFIGURE CHANNEL... CLEAR command.
RMAN-12016: using channel string
RMAN-12017: could not locate pieces of backup set key string
Cause: Copies of the specified backup set key could not be accessed on any of the allocated channels.
Action: Allocate additional channels on other nodes of the cluster or, if the backup pieces has been deleted, use the CROSSCHECK BACKUP command to correct the recovery catalog or target database control file entries.
RMAN-12018: channel string disabled, job failed on it will be run on another channel
Cause: This is an informational message displayed whenever a retryable error occurs for the job and there are channels available to run this step.
RMAN-12019: continuing other job steps, job failed will not be re-run
Cause: This is an informational message displayed whenever there is a non-retryable error occurred for the job.
RMAN-12020: error on step filtered for normal output \nstring
Cause: This message is added when stacking errors for failed jobs after channel failover was performed. It will be filtered from normal output.
RMAN-20000: abnormal termination of job step
Cause: A job step encountered an error and could not recover. This error should be followed by other errors indicating the cause of the problem.
RMAN-20001: target database not found in recovery catalog
Cause: target database is not found in the recovery catalog
Action: make sure that the target database is registered in the recovery recovery catalog
RMAN-20002: target database already registered in recovery catalog
Cause: target database is already registered in the recovery catalog
Action: if the target database is really registered, there is no need to register it again. Note that the recovery catalog enforces that all databases have a unique DBID. If the new database was created by copying files from an existing database, it will have the same DBID as the original database and cannot be registered in the same recovery catalog.
RMAN-20003: target database incarnation not found in recovery catalog
Cause: RESETLOGS CHANGE# and/or time of the target database doesn't match any database incarnation in the recovery catalog.
Action: if target database was opened with RESETLOGS option then use 'reset database' to register the new incarnation.
RMAN-20004: target database name does not match name in recovery catalog
Cause: name of the target database doesn't match the one stored in the recovery catalog
Action: This is an internal error.
RMAN-20005: target database name is ambiguous
Cause: two or more databases in the recovery catalog match this name
Action: n/a
RMAN-20006: target database name is missing
Cause: target database instance is not started or db_name initialization parameter is not set
Action: startup the instance and make sure that db_name parameter is set
RMAN-20009: database incarnation already registered
Cause: this incarnation is already registered in the recovery catalog
RMAN-20010: database incarnation not found
Cause: database incarnation does not match any database incarnation in the recovery catalog
Action: specify a valid database incarnation key
RMAN-20011: target database incarnation is not current in recovery catalog
Cause: the database incarnation that matches the RESETLOGS CHANGE# and time of the mounted target database control file is not the current incarnation of the database
Action: If 'reset database to incarnation key' was used to make an old incarnation current then restore the target database from a backup that matches the incarnation and mount it. You will need to do 'STARTUP NOMOUNT' before you can restore the control file using RMAN. Otherwise use 'reset database to incarnation key' make the intended incarnation current in the recovery catalog.
RMAN-20012: not authorized to register new database
Cause: You attempted to register a new database with this recovery catalog, but you are using a virtual private catalog, and you have not been granted permission by the catalog administrator to register this database with this recovery catalog
Action: Ask the catalog administrator to grant permission for you to register this database.
RMAN-20013: error upgrading virtual private catalog
Cause: An error occurred while automatically upgrading a virtual private catalog.
Action: Ensure that the virtual private catalog userid has all of the required privileges, such as being granted the RECOVERY_CATALOG_OWNER role.
RMAN-20014: virtual private catalog owner must be granted RECOVERY_CATALOG_OWNER role
Cause: An attempt was made to establish a virtual private RMAN catalog in a schema that is not granted the RECOVERY_CATALOG_OWNER role.
Action: Grant RECOVERY_CATALOG_OWNER to the virtual private catalog owner.
RMAN-20015: not authorized to share this catalog
Cause: You attempted to share a recovery catalog but were not authorized to do this by the catalog administrator.
Action: Ask the catalog administrator to grant permission for you to share this catalog.
RMAN-20016: virtual private catalog user cannot modify global scripts
Cause: A virtual private catalog user attempted to create, delete, or modify a global script. Virtual private catalog users cannot modify global scripts.
Action: Connect to the catalog owner userid and retry the global script operation.
RMAN-20017: illegal script update operation
Cause: An illegal script operation was performed.
Action: None
RMAN-20018: database not found in recovery catalog
Cause: An attempt was made to grant or revoke catalog access to a database whose name was not registered in the recovery catalog.
Action: Correct the database name and re-issue the GRANT or REVOKE command. If this is an attempt to grant or revoke access to a database that is not yet registered, then re-issue the command using the database ID of the desired database.
RMAN-20019: database name not unique in recovery catalog
Cause: An attempt was made to grant or revoke catalog access to a database whose name is not unique in the recovery catalog.
Action: Re-issue the command specifying the database ID of the desired database.
RMAN-20022: user not found
Cause: An attempt was made to grant a privilege to a user that does not exist.
Action: Reissue the command specifying a user that exists.
RMAN-20029: cannot make a snapshot control file
Cause: another operation that needs the snapshot control file is in progress
Action: try again later if necessary
RMAN-20030: resync in progress
Cause: this procedure cannot be called while a resync is in progress
RMAN-20031: resync not started
Cause: this procedure can only be called in a resync
RMAN-20032: checkpoint CHANGE# too low
Cause: the checkpoint change# is less than the one of the previous resync or the checkpoint change# is null
Action: make sure that the right control file is used
RMAN-20033: control file SEQUENCE# too low
Cause: the control file sequence is less than the one of the previous resync
RMAN-20034: resync not needed
Cause: the control file has not changed since the previous resync
Action: nothing since the recovery catalog is in sync
RMAN-20038: must specify FORMAT for CONVERT command
Cause: No FORMAT was specified when using CONVERT command.
Action: Resubmit the command using FORMAT clause.
RMAN-20039: format requires character when duplexing
RMAN-20045: must specify FORMAT for BACKUP INCREMENTAL FROM SCN command
Cause: No FORMAT was specified when using BACKUP INCREMENTAL FROM SCN command.
RMAN-20079: full resync from primary database is not done
Cause: Resync from standby detected that a full resync from primary database is required. One of the following events on primary database may have caused this error: 1) one or more tablespaces or datafiles were added 2) one or more tablespaces or datafiles were dropped 3) one or more datafiles status changed
Action: Perform full resync after connecting to primary database.
RMAN-20081: change stamp for the record
Cause: A record with same recid and stamp is already known to catalog.
Action: None. This error is automatically handled by RMAN client by changing the stamp in control file during resync.
RMAN-20108: control file for remote database cannot be updated
Cause: RESYNC CATALOG FROM DB_UNIQUE_NAME command was attempted, but the control file at the database with DB_UNIQUE_NAME needs to be resynced directly instead of through the current target.
Action: Directly connect as target to the remote database with the specified DB_UNIQUE_NAME and resync.
RMAN-20109: remote database has different database ID
Cause: Command RESYNC CATALOG FROM DB_UNIQUE_NAME was executed and the database ID of the remote database was different than the connected target database.
Action: The remote database should have the same database ID as the database connected as the target database. Fix the connect identifier for the remote database and retry the command.
RMAN-20140: database not yet registered in the Recovery Appliance
Cause: The database was not registered in the Recovery Appliance.
Action: Add a database to the Recovery Appliance schema by making a call to ADD_DB call.
RMAN-20141: target database ID mismatch with registered database in the Recovery Appliance
Cause: The database with the same DB_UNIQUE_NAME was already registered in a Recovery Appliance, but the database ID was different than the target database.
Action: Connect to the proper target database, or change the DB_UNIQUE_NAME and register it again in the Recovery Appliance.
RMAN-20142: version stamp of backup XML set is different
Cause: A new backup XML set was generated at the Recovery Appliance since the last read of watermarks.
Action: Retry the reconcile operation.
RMAN-20143: no records found to resync for incarnation view
Cause: The reconcile code at the Recovery Appliance expected incarnation records, but they were not sent by the recovery catalog.
RMAN-20144: no records found to resync for tablespace view
Cause: The reconcile code at the Recovery Appliance expected tablespace records, but they were not sent by the recovery catalog.
RMAN-20145: no records found to resync for data file view
Cause: The reconcile code at the Recovery Appliance expected datafile records, but they were not sent by the recovery catalog.
RMAN-20146: no records found to resync for thread view
Cause: The reconcile code at the Recovery Appliance expected thread records, but they were not sent by the recovery catalog.
RMAN-20147: no records found to resync for online redo log view
Cause: The reconcile code at the Recovery Appliance expected online redo log records, but they were not sent by the recovery catalog.
RMAN-20148: no records found to resync for offline range view
Cause: The reconcile code at the Backup Appaliance expected offline range records, but they were not sent by the recovery catalog.
RMAN-20149: required records are purged from the backup XML set at the Recovery Appliance
Cause: The recovery catalog was not reconciled from the Recovery Appliance recently, and records from backup XML set were purged at the Recovery Appliance.
Action: A new backup XML set must be created at the Recovery Appliance.
RMAN-20150: no records found to resync for Pluggable Database view
Cause: The reconcile code at the Recovery Appliance expected Pluggable Database records, but they were not sent by the recovery catalog.
RMAN-20151: no records found to resync for Pluggable Database incarnation view
Cause: The reconcile code at the Recovery Appliance expected Pluggable Database incarnation records, but they were not sent by the recovery catalog.
RMAN-20201: datafile not found in the recovery catalog
Cause: The specified datafile is not found in the recovery catalog
Action: make sure that the datafile name is correct and that the recovery catalog is up-to-date
RMAN-20202: Tablespace not found in the recovery catalog
Cause: the specified tablespace is not found in the recovery catalog
Action: make sure that the tablespace name is correct and that the recovery catalog is up-to-date
RMAN-20203: translation in progress
Cause: this procedure can not be called when name translation is in progress
RMAN-20204: translation not started
Cause: GETDATAFILE procedure was called before TRANSLATETABLESPACE
RMAN-20205: incomplete UNTIL clause
Cause: The sequence# was NULL
RMAN-20206: log sequence not found in the repository
Cause: The specified log sequence does not exists in log history of the current database incarnation
Action: check the thread# and sequence#
RMAN-20207: UNTIL TIME or RECOVERY WINDOW is before RESETLOGS time
Cause: UNTIL TIME and RECOVERY WINDOW cannot be less than the database creation time or RESETLOGS time.
Action: Check the UNTIL TIME or RECOVERY WINDOW. If the database needs to be restored to an old incarnation, use the RESET DATABASE TO INCARNATION command.
RMAN-20208: UNTIL CHANGE is before RESETLOGS change
Cause: UNTIL CHANGE cannot be less than the database RESETLOGS change.
Action: Check the UNTIL CHANGE. If the database needs to be restored to an old incarnation, use the RESET DATABASE TO INCARNATION command.
RMAN-20209: duplicate datafile name
Cause: Two datafiles have the same name
RMAN-20211: FROM TIME is before RESETLOGS time
Cause: FROM TIME cannot be less than the database creation time or RESETLOGS time.
Action: Check the FROM TIME. If the database needs to be restored to an old incarnation, use the RESET DATABASE TO INCARNATION command.
RMAN-20212: UNTIL CHANGE is an orphan incarnation
Cause: Specified UNTIL CHANGE was an orphan incarnation.
Action: Check the UNTIL CHANGE or UNTIL RESTORE POINT. If the database needs to be restored or flashed back to an orphan incarnation, use the RESET DATABASE TO INCARNATION command.
RMAN-20213: UNTIL TIME could not be translated to a valid SCN
Cause: Specified UNTIL TIME could not be translated to a valid SCN.
Action: Use a more recent UNTIL TIME.
RMAN-20215: backup set not found
Cause: The specified backup set key was not found in the recovery catalog or target database control file.
Action: Specify a different backup set key.
RMAN-20217: datafile not part of the database
Cause: the datafile does not exists or did not exist at until time/scn
Action: check the datafile name or number. This is an internal error. for restore database or tablespace.
RMAN-20218: datafile not found in repository
Cause: This is an internal error.
Action: Contact Oracle Support Services.
RMAN-20220: control file copy not found in the repository
Cause: The specified control file was not in the recovery catalog or target database control file or it was marked deleted.
Action: check the file name
RMAN-20221: ambiguous control file copy name
Cause: more than one control file copy in the recovery catalog match the specified name.
Action: n/a
RMAN-20222: datafile name not found in recovery catalog or is ambiguous
Cause: The specified datafile name is not the name of a datafile that is currently part of the target database, or an UNTIL clause has been specified and the file name was for a different datafile at the time specified by the UNTIL clause than it is now.
Action: Use a datafile number to specify the datafile you want to RESTORE or RECOVER.
RMAN-20223: DB_UNIQUE_NAME mismatch in snapshot control file
Cause: The DB_UNIQUE_NAME value in the snapshot control file was incorrect. This error can occur in Oracle RAC when the snapshot control file location is not shared across nodes and virtual IPs are setup in the remote database from where resynchronization is done using RESYNC CATALOG FROM DB_UNIQUE_NAME commnad.
Action: To avoid this error, one of the following actions can be taken: 1) Share the control file snapshot location. The snapshot location can be displayed by executing SHOW SNAPSHOT CONTROLFILE NAME at the RMAN prompt. 2) Do not use Virtual IPs in the service name used to define the connect identifiers. The connect identifiers can be displayed using SHOW DB_UNIQUE_NAME command at the RMAN prompt.
RMAN-20230: datafile copy not found in the repository
Cause: The specified datafile was not in the recovery catalog or target database control file or it was marked deleted.
Action: check the datafile copy name or key
RMAN-20231: ambiguous datafile copy name
Action: use the datafile copy key to uniquely specify the datafile copy
RMAN-20240: archived log not found in the repository
Cause: The specified archived log was not found in the recovery catalog or target database control file or it was marked deleted.
Action: check the archived log name or key
RMAN-20241: ambiguous archived log name
Cause: more than one archived log in the recovery catalog match the specified name
Action: use the archived log key to uniquely specify the archived log
RMAN-20242: specification does not match any archived log in the repository
Cause: No archived logs found that match specification in the recovery catalog or target database control file.
Action: check the archived log specifier
RMAN-20243: database db_unique_name is not known to the recovery catalog
Cause: the user specified DB_UNIQUE_NAME not known to the recovery catalog.
Action: change the database DB_UNIQUE_NAME to a known database value. To display list of known db_unique_names execute LIST DB_UNIQUE_NAME OF DATABASE
RMAN-20244: can not change currently connected database db_unique_name
Cause: the user specified currently connected DB_UNIQUE_NAME value to unregister.
Action: use the DB_UNIQUE_NAME other than connected target database's DB_UNIQUE_NAME value.
RMAN-20245: can not specify db_unique_name option in nocatalog mode
Cause: the user specified DB_UNIQUE_NAME in nocatalog mode.
Action: remove the DB_UNIQUE_NAME option from the command.
RMAN-20246: new db_unique_name is already known to the recovery catalog
Cause: the user specified known DB_UNIQUE_NAME value when renaming a DB_UNIQUE_NAME in the recovery catalog.
Action: change the database DB_UNIQUE_NAME to an known DB_UNIQUE_NAME value; or unregister the new DB_UNIQUE_NAME before renaming an old DB_UNIQUE_NAME value for a database. To display the list of all DB_UNIQUE_NAME for the databases LIST DB_UNIQUE_NAME OF DATABASE command can be executed.
RMAN-20247: specification does not match any foreign archived log in the repository
Cause: No foreign archived logs found that match specification in the recovery catalog or target database control file.
Action: check the foreign archived log specifier
RMAN-20250: offline range not found in the repository
Cause: The specified offline was not found in the recovery catalog or target database control file.
Action: check that recovery catalog is current
RMAN-20260: backup piece not found in the repository
Cause: The specified backup piece was not in the recovery catalog or target database control file or it was marked deleted.
Action: check the backup piece handle or key
RMAN-20261: ambiguous backup piece handle
Cause: more than one backup piece in the recovery catalog match the specified handle
Action: use the backup piece key to uniquely specify the backup piece
RMAN-20272: no parent backup found for the incremental backup
Cause: no available backup or copy that could be used as the parent of the incremental backup was found in the recovery catalog.
Action: take a level 0 backup or copy of the datafile first
RMAN-20280: too many device types
Cause: more than 8 device types were allocated
Action: make sure that the job allocates at most 8 different device types
RMAN-20298: DBMS_RCVCAT package not compatible with the recovery catalog
Cause: The version of the recovery catalog tables does not work with this version of the DBMS_RCVCAT package.
Action: Check that the recovery catalog packages and schema are installed correctly. The UPGRADE CATALOG command can be used to upgrade the recovery catalog tables and packages to the most current version.
RMAN-20299: DBMS_RCVMAN package not compatible with the recovery catalog
Cause: The version of the recovery catalog tables does not work with this version of the DBMS_RCVMAN package.
RMAN-20310: proxy copy not found in the repository
Cause: The specified proxy copy was not in the recovery catalog or target database control file or it was marked deleted.
Action: check the proxy copy handle or key
RMAN-20311: ambiguous proxy copy handle
Cause: more than one proxy copy in the recovery catalog matches the specified handle
Action: use the proxy copy key to uniquely specify the proxy copy
RMAN-20401: script already exists
Cause: a CREATE SCRIPT was issued, but a script with the specified name already exists.
Action: use a different name or use REPLACE SCRIPT.
RMAN-20501: redo logs from parent database incarnation cannot be applied
Cause: A RESTORE or RECOVER of a datafile was requested, but recovery of the datafile would require applying redo logs that were generated before the most recent OPEN RESETLOGS.
Action: If a full backup or datafile copy from the current database incarnation exists, ensure that it is marked AVAILABLE, and that a channel of the correct device type is allocated. It may also be necessary to remove the FROM BACKUPSET or FROM DATAFILECOPY or FROM TAG operands if these have been specified.
RMAN-20502: DELETE EXPIRED cannot delete objects that exist - run CROSSCHECK
Cause: A DELETE EXPIRED command was run, but the object was actually found to exist. This means the recovery catalog or target database control file is out of sync with reality.
Action: Run CROSSCHECK.
RMAN-20503: DELETE cannot delete expired objects - run CROSSCHECK or DELETE EXPIRED
Cause: A DELETE command was run without EXPIRED option, but the object doesn't exist. This means the recovery catalog or target database control file is out of sync with reality.
RMAN-20504: corruption list not found in recovery catalog
Cause: corruption list is empty
Action: make sure that one or more blocks are marked corrupted in v$copy_corruption and v$backup_corruption and recovery catalog is up-to-date.
RMAN-20505: create datafile during recovery
Cause: applying of archived log caused a create datafile redo-entry to to terminate recovery.
Action: none. This message is never displayed. RMAN automatically detects this case and creates the datafile.
RMAN-20506: no backup of archived log found
Cause: during the recover process, no backup was found from which the archived logs could be restored.
Action: this message should be followed by a list of missing archived logs. Please make the necessary archived log backups available and try again.
RMAN-20507: some targets are remote - aborting restore
Cause: during the restore process, one or more backup files were unavailable locally for the restore operation.
Action: This message should be accompanied with the list of remote backup files. Recall these backups from remote location and retry the RESTORE command.
RMAN-20508: temporary resource already in use
Cause: Temporary resource that was allocated for IMPORT CATALOG command was already in use.
Action: Retry IMPORT CATALOG command.
RMAN-20509: temporary resource not found
Cause: Temporary resource that was allocated for IMPORT CATALOG command was not found.
RMAN-20510: database not found in source recovery catalog database
Cause: Database that was specified in IMPORT CATALOG command was not found in the source recovery catalog database.
Action: Make sure that the database is registered in the source recovery catalog database.
RMAN-20511: database name is ambiguous in source recovery catalog database
Cause: Two or more databases in the source recovery catalog database match this name.
Action: Use DBID option in IMPORT CATALOG command to specify the source database.
RMAN-20512: source database already registered in recovery catalog
Cause: Source database was already registered in the recovery catalog.
Action: If the source database is really registered, there is no need to register it again. Note that the recovery catalog enforces that all databases have a unique DBID. If the new database was created by copying files from an existing database, it will have the same DBID as the original database and cannot be registered in the same recovery catalog.
RMAN-20513: UNTIL TIME or SCN is before Pluggable Database CREATION SCN
Cause: The UNTIL TIME or SCN specified was less than the Pluggable Database CREATION SCN. UNTIL TIME or SCN cannot be less than the Pluggable Database CREATION SCN.
Action: Check the UNTIL TIME or SCN and retry the command.
RMAN-20514: feature requires Oracle Recovery Appliance recovery catalog
Cause: The specified command required the Oracle Recovery Appliance recovery catalog.
Action: Connect to the Oracle Recovery Appliance recovery catalog and retry the command.
