VID-00611: unable to access the BLOB for reading
Cause:
The BLOB could not be opened for reading.
Action:
Contact Oracle Support Services.
VID-00612: unable to open export destination file
Cause:
The file could not be created or opened.
Action:
Check that the file does not refer to an existing directory. Check that the file is not locked by another application.
VID-00613: export destination access denied
Cause:
Permission to write to destination file was denied.
Action:
Refer to the Oracle Multimedia documentation for information on granting privileges for the export() method.
VID-00614: I/O error during export
Cause:
The export operation failed because of an I/O error.
Action:
Check OS logs and contact Oracle Support Services.
VID-00702: unable to initialize video processing environment
Cause:
The initalization of the video processing procedure failed.
Action:
See the database administrator to make sure that enough memory has been allocated to JServer. If JServer does have enough memory, contact Oracle Support Services.
VID-00703: unable to read video data
Cause:
An error occurred while accessing the video source.
Action:
Make sure the video source is valid. For external sources, make sure all access priviliges are granted.
VID-00704: invalid input format or corrupted input data
Cause:
The video data in the source was not in the format specified by the format field of the video object. In some unusal cases, the video data is actually corrupted.
Action:
Provide a correct value in the format field. If the correct value is unknown, put NULL in the format field to invoke the DEFAULT format plug-in.
VID-00705: unsupported input format
Cause:
The file format of the video data was not supported. This error can only occur in the DEFAULT format plug-in package.
Action:
Refer to the Oracle Multimedia documentation for supported formats.
VID-00706: unsupported or corrupted input format
Cause:
The video data was either corrupted or the file format was not supported.
Action:
Refer to the Oracle Multimedia documentation for supported formats. If the video data is not corrupted and is in a supported file format, contact Oracle Support Services.
VID-00707: unable to read empty video data
Cause:
There is no data in the video object.
Action:
Refer to the Oracle Multimedia documentation for information on how to populate the video object with video data.
VID-00713: internal error while parsing video data
Cause:
An internal error occurred during parsing.
Action:
VID-00714: internal error
Cause:
An internal error occurred.
Action:
VID-00721: unable to find format plug-in package ORDPLUGINS.ORDX_string_VIDEO
Cause:
Custom video plug-in for user-specified format was not found.
Action:
Ensure correct video format is specified or proper custom video plug-in package is installed.
